Why I can't debug example project? I got error message "Current license does not allow downloading C++ code"
2,252 次查看
olegivanus
Hello, I want to debug example project using u-Multilink debugger with MPC5643L MCU, but I get the following message:
Failed to resume target process.
What should I do to solve this problem?
标签 (1)
1 回复
1,813 次查看
ZhangJennie
only professional edition can support C++. i wonder you should use standard or other lower version that can't support C++.
i suggest you upgrade your license.
here is the link for For a complete list of CodeWarrior Suite Features:
http://www.freescale.com/webapp/sps/site/overview.jsp?code=CW_SUITES&tid=CWH Hope this helps!
this answer is for you. if this answers your question, please click on the "correct answer" button.
JunZhang
