Hi, I recently purchased a developer level license for CW10 for QorIQ. I successfully (I thought) installed the floating license - Code Warrior reports I have a CW10 license good for 363 more days. I can build my projects, but when I try to debug a project, I get an error that I don't have a CWTAP license. I'm trying to debug a bare metal project. Can you help? I'm using Ubuntu 14.04 and CW 10.0.8. This has stalled us at a critical time.
Solved! Go to Solution.
I will contact you thru regular support case media to solve this specific case.
Seems there are some features not defined on the license file that support CWTAP use , i will check your account and test your license to determine the root cause.
Regards.
Regards.
Here are the license details for the CW10 license:
Detail information for product "CodeWarrior Development Studio for QorIQ LS series - ARM V7 ISA" version "10.0"
status: "License expiring in 363 day(s)."
License model: "class com.freescale.core.ide.license.flexlm.FlexlmActivate11"
Contact Email: licensing@freescale.com
Register URL: http://www.freescale.com/cwregister/
Purchase URL: http://www.freescale.com/webapp/sps/site/homepage.jsp?nodeId=0152102726
FlexLM Eval Period: 5 day(s)
GTL Server: gtlsrvr.metrowerks.com
GTL Port: 80 (8,080)
Wants Host ID: true
License file path: C:\Freescale\CW4NET_v2016.01\Common\license.dat
flexlmFileLocator: null
flexlmFile: ${ARMv7_TOOLS_HOME}/../../Common/license.dat
License file URL: file:/C:/Freescale/CW4NET_v2016.01/CW_ARMv7/eclipse/../ARMv7/../../Common/license.dat
Error String:
Optional feature group #1:
Optional feature undefined: FSLTAP 1.0
Optional feature undefined: REMOTEDEBUG 1.0
Optional feature undefined: PE_SCENARIOS 2.8
Group status: Included
Optional feature group #2:
Optional feature undefined: PE_SCENARIOS_ADVANCED 2.8
Optional feature undefined: DDR_Validation_QorIQ 4.0
Optional feature undefined: SERDES_Validation_QorIQ 4.0
Optional feature undefined: GPTRACE 10.0
Optional feature undefined: STMDEBUGPRINT 1.0
Optional feature group #3:
Optional feature undefined: PE_PACKETTOOL 2.8
Optional feature undefined: SYSTRACE 1.0
Mandatory feature keys:
ARMv7DBG 10.0, status : 363 day(s)
CMSISDAP 1.0, status : 363 day(s)
Alternate Keys:
(no keys)
LM_PATH=null
License file Content (C:\Freescale\CW4NET_v2016.01\Common\license.dat):
#CodeWarrior Development Suite for Networked Applications, Developer Level,
#Floating License - CodeWarrior for QorIQ LS Series ARMv7 ISA for Jason
#Hendrix Software Account
SERVER CISERVER DISK_SERIAL_NUM=289331BC
VENDOR metrowks
USE_SERVER
INCREMENT ARMv7DBG metrowks 11.10 11-may-2017 1 247ADB48CD93 \
VENDOR_STRING="CodeWarrior for QorIQ LS Series ARMv7 ISA" \
DUP_GROUP=UH ISSUER="Freescale Semiconductor" \
ISSUED=11-may-2016 ck=152 SN="FSL - 16294467" TS_OK
INCREMENT CMSISDAP metrowks 11.10 11-may-2017 1 B7ABD4426272 \
ISSUED=11-may-2016 ck=50 SN="FSL - 16294467" TS_OK
INCREMENT FSLTAP metrowks 11.10 11-may-2017 1 05301C546555 \
ISSUED=11-may-2016 ck=89 SN="FSL - 16294467" TS_OK
INCREMENT PE_SCENARIOS metrowks 11.10 11-may-2017 1 F6A97AF2F325 \
ISSUED=11-may-2016 ck=109 SN="FSL - 16294467" TS_OK
INCREMENT REMOTEDEBUG metrowks 11.10 11-may-2017 1 52E6C59E988F \
ISSUED=11-may-2016 ck=112 SN="FSL - 16294467" TS_OK
