Dongle License work on LAN?
Dipin
 I have licensed the CW using Dongle.
Now i wish to work on 2 systems over LAN with same license at a time, is that possible.
my CW has got node lock perpectual licensing.
Please somebody tell me if its possible or not.
Thanks in advance.
J2MEJediMaster
Specialist I
You can carry the dongle between the two machines, but you can not be using both at the same time. You can set up a floating license to share between the two networked machines, but again, only one machine at a time will be able to use the tools.
---Tom
J2MEJediMaster
Specialist I
---Tom
