Code Warrior 10.3 error license key in license file does not match other data in file
2,447 次查看
rossrhone
I am currently using Windows 10, which installs the Flexid drivers 9 and 10. My license file has the correct key in it, but it continues to give me this message. Any thoughts on how I could fix this?
Ross
标签 (1)
1 回复
2,235 次查看
TomasPaez
Some suggestions
Share the host ID from the license.dat ,or Entitlement ID
Check your dongle red led is on
Label on Dongle ID and License should Match
Check the following attachment.
