SE05X - Support for concurrent and parallel access
nofarbe
I am working with the SE05x using the Plug & Trust middleware, and I would like to understand its support for concurrent (parallel) access.
Is it possible to access the SE05X from multiple threads or processes concurrently?
If yes:
- Are there any limitations or constraints when using concurrent access?
- Does the SE05X internally handle synchronization, or is it expected to be managed entirely on the host side?
- Are there recommended best practices for multi-threaded or multi-session usage?
If not:
- What is the recommended architecture for using SE05X in a multi-threaded or multi-process environment?
Any clarification or references to relevant documentation would be highly appreciated.
Thank you!
EduardoZamora
Hello @nofarbe
Hope you are doing well.
SE05x supports a multi-tenant model. Please refer to SE050A/B/C/D User Guidelines / EdgeLock SE050E User Guidelines, Chapter 5.
Eduardo.
%3CLINGO-SUB%20id%3D%22lingo-sub-2370726%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ESE05X%20-%20Support%20for%20concurrent%20and%20parallel%20access%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2370726%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3CBR%20%2F%3E%26nbsp%3B%3C%2FP%3E%3CP%3EI%20am%20working%20with%20the%20SE05x%20using%20the%20Plug%20%26amp%3B%20Trust%20middleware%2C%20and%20I%20would%20like%20to%20understand%20its%20support%20for%20concurrent%20(parallel)%20access.%3CBR%20%2F%3E%26nbsp%3B%3C%2FP%3E%3CP%3EIs%20it%20possible%20to%20access%20the%20SE05X%20from%20multiple%20threads%20or%20processes%20concurrently%3F%3CBR%20%2F%3E%26nbsp%3B%3C%2FP%3E%3CP%3EIf%20yes%3A%3CBR%20%2F%3E-%20Are%20there%20any%20limitations%20or%20constraints%20when%20using%20concurrent%20access%3F%3CBR%20%2F%3E-%20Does%20the%20SE05X%20internally%20handle%20synchronization%2C%20or%20is%20it%20expected%20to%20be%20managed%20entirely%20on%20the%20host%20side%3F%3CBR%20%2F%3E-%20Are%20there%20recommended%20best%20practices%20for%20multi-threaded%20or%20multi-session%20usage%3F%3CBR%20%2F%3E%26nbsp%3B%3C%2FP%3E%3CP%3EIf%20not%3A%3CBR%20%2F%3E-%20What%20is%20the%20recommended%20architecture%20for%20using%20SE05X%20in%20a%20multi-threaded%20or%20multi-process%20environment%3F%3CBR%20%2F%3E%26nbsp%3B%3C%2FP%3E%3CP%3EAny%20clarification%20or%20references%20to%20relevant%20documentation%20would%20be%20highly%20appreciated.%3CBR%20%2F%3E%26nbsp%3B%3C%2FP%3E%3CP%3EThank%20you!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2370726%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3ESmart%20Cards%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2373252%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SE05X%20-%20Support%20for%20concurrent%20and%20parallel%20access%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2373252%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F263104%22%20target%3D%22_blank%22%3E%40nofarbe%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EHope%20you%20are%20doing%20well.%3C%2FP%3E%0A%3CP%3ESE05x%20supports%20a%20multi-tenant%20model.%20Please%20refer%20to%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DAN12514%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ESE050A%2FB%2FC%2FD%20User%20Guidelines%3C%2FA%3E%20%2F%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DAN13483%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EEdgeLock%20SE050E%20User%20Guidelines%3C%2FA%3E%2C%20Chapter%205.%3C%2FP%3E%0A%3CP%3ERegards%2C%3CBR%20%2F%3EEduardo.%3C%2FP%3E%3C%2FLINGO-BODY%3E
