question about KMZ49
5,485件の閲覧回数
sunning2018
How to install KMZ49 and use it? I want to measure the angle of sheet.
Thank you very much.
        SunNing
4 返答(返信)
5,300件の閲覧回数
TomasVaverka
Hi Sunning,
KMZ49 is in principle similar to the KMZ60, so you may find useful the attached application note.
Hope it helps!
Tomas
5,300件の閲覧回数
sunning2018
Hi Tomas,
The intruction book about KMZ60 has been read. Permanent Magnet is necessary to use KMZ60. Would you tell me how to buy the Permanent Magnet ?
Thank you very much !
Sunning
5,300件の閲覧回数
sunning2018
thank  you for your help, Tomas.
5,300件の閲覧回数
sunning2018
"sheet" should be "shaft"
