mpx2100dp
mpx2100dp
francesco_panic
Can you send me 3d model file for MPX2100DP
reyes
Dear Francesco,
Unfortunately, there are no 3D model for the MPX2100DP (Case344C), however, there is a 3D model for the case 867C which is the same package and same size as the 344C, but with 6 pins instead (by removing pins 1 and 6, the package would be exactly the same).
Case 867C 3D STEP model: https://community.nxp.com/docs/DOC-100736
You can find the drawing of these two packages in the following links:
Case 334C: https://www.nxp.com/docs/en/package-information/98ASB14912C.pdf
Case 867C: https://www.nxp.com/docs/en/package-information/98ASB42797B.pdf
I hope the 3D model of the 867C can be useful.
%3CLINGO-SUB%20id%3D%22lingo-sub-887641%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Empx2100dp%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-887641%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ECan%20you%20send%20me%203d%20model%20file%20for%20MPX2100DP%3C%2FP%3E%3CP%3EThanks%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-887642%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20mpx2100dp%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-887642%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDear%20Francesco%2C%26nbsp%3B%20%26nbsp%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EUnfortunately%2C%20there%20are%20no%203D%20model%20for%20the%20MPX2100DP%20(Case344C)%2C%20however%2C%20there%20is%20a%203D%20model%20for%20the%20case%20867C%20which%20is%20the%20same%20package%20and%20same%20size%20as%20the%20344C%2C%20but%20with%206%20pins%20instead%20(by%20removing%20pins%201%20and%206%2C%20the%20package%20would%20be%20exactly%20the%20same).%3CBR%20%2F%3ECase%20867C%203D%20STEP%20model%3A%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-100736%22%20target%3D%22test_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-100736%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EYou%20can%20find%20the%20drawing%20of%20these%20two%20packages%20in%20the%20following%20links%3A%3CBR%20%2F%3ECase%20334C%3A%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fpackage-information%2F98ASB14912C.pdf%22%20target%3D%22test_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fpackage-information%2F98ASB14912C.pdf%3C%2FA%3E%3CBR%20%2F%3ECase%20867C%3A%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fpackage-information%2F98ASB42797B.pdf%22%20target%3D%22test_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fpackage-information%2F98ASB42797B.pdf%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20hope%20the%203D%20model%20of%20the%20867C%20can%20be%20useful.%3C%2FP%3E%3C%2FLINGO-BODY%3E
