duplicated sensor records
2,774件の閲覧回数
trekwh
I was logging, through usb, overnight data from FRDM-FXS-Multi2-B with FRDM-k64F board, and noticed that quite frequent duplicated records for the same epoch, see below (bold epoch numbers),
pl. comment, thanks,
2604.076,Acc+Mag+Gyro,Aerospace,0.6,0.6,123.2,-0.013,0.016,1.037,-7.2,-9.8,34.9,0.30,5.00,-0.05,0.4749,-0.0022,0.0079,0.8800,0.25,0.10,-0.05,0.001,0.002,-0.039,-21.4,-56.4,-38.8,1.000,1.000,1.000,0.000,0.000,0.000,205,7.8,30.4,69.8,-0.00190,-0.00003,0.00000,-0.00213,-0.00043,-0.00057,-0.00010,0.00000,0.00000,0.00000,0.00000,0.00000,0.042,4.880,0.001,69.84,-77.294,24.50
2604.116,Acc+Mag+Gyro,Aerospace,0.6,0.6,123.2,-0.013,0.016,1.037,-7.2,-9.8,34.9,0.30,5.00,-0.05,0.4749,-0.0022,0.0079,0.8800,0.25,0.10,-0.05,0.001,0.002,-0.039,-21.4,-56.4,-38.8,1.000,1.000,1.000,0.000,0.000,0.000,205,7.8,30.4,69.8,-0.00190,-0.00003,0.00000,-0.00213,-0.00043,-0.00057,-0.00010,0.00000,0.00000,0.00000,0.00000,0.00000,0.042,4.880,0.001,69.84,-77.293,24.50
2604.116,Acc+Mag+Gyro,Aerospace,0.6,0.6,123.2,-0.014,0.014,1.041,-6.8,-10.6,34.1,-0.35,5.55,-0.10,0.4750,-0.0022,0.0079,0.8800,-0.40,0.65,-0.10,0.001,0.002,-0.039,-21.4,-56.4,-38.8,1.000,1.000,1.000,0.000,0.000,0.000,205,7.8,30.4,69.8,-0.00190,-0.00003,0.00000,-0.00213,-0.00043,-0.00057,-0.00010,0.00000,0.00000,0.00000,0.00000,0.00000,0.042,4.880,0.001,69.84,-77.293,24.50
2604.356,Acc+Mag+Gyro,Aerospace,0.6,0.6,123.2,-0.013,0.014,1.040,-7.0,-10.6,32.8,0.05,4.40,-0.10,0.4750,-0.0022,0.0078,0.8799,0.00,-0.40,-0.10,0.002,0.002,-0.038,-21.4,-56.4,-38.8,1.000,1.000,1.000,0.000,0.000,0.000,205,7.8,30.4,69.8,0.00047,-0.00163,0.00000,0.00403,0.00410,0.00207,0.00000,-0.00007,0.00000,0.00003,0.00003,0.00000,0.042,4.880,0.001,69.79,-77.300,24.50
2604.356,Acc+Mag+Gyro,Aerospace,0.6,0.6,123.2,-0.013,0.015,1.038,-6.7,-10.7,33.9,0.05,4.40,-0.10,0.4750,-0.0022,0.0078,0.8799,0.00,-0.40,-0.10,0.002,0.002,-0.038,-21.4,-56.4,-38.8,1.000,1.000,1.000,0.000,0.000,0.000,205,7.8,30.4,69.8,0.00047,-0.00163,0.00000,0.00403,0.00410,0.00207,0.00000,-0.00007,0.00000,0.00003,0.00003,0.00000,0.042,4.880,0.001,69.79,-77.300,24.50
2604.396,Acc+Mag+Gyro,Aerospace,0.6,0.6,123.2,-0.013,0.015,1.038,-6.7,-10.7,33.9,0.05,4.40,-0.10,0.4750,-0.0022,0.0078,0.8799,0.00,-0.40,-0.10,0.002,0.002,-0.038,-21.4,-56.4,-38.8,1.000,1.000,1.000,0.000,0.000,0.000,205,7.8,30.4,69.8,0.00047,-0.00163,0.00000,0.00403,0.00410,0.00207,0.00000,-0.00007,0.00000,0.00003,0.00003,0.00000,0.042,4.880,0.001,69.79,-77.300,24.50
2604.396,Acc+Mag+Gyro,Aerospace,0.6,0.6,123.2,-0.014,0.017,1.041,-7.2,-10.8,35.0,0.00,4.65,0.00,0.4751,-0.0022,0.0079,0.8799,0.00,-0.15,0.00,0.002,0.002,-0.039,-21.4,-56.4,-38.8,1.000,1.000,1.000,0.000,0.000,0.000,205,7.8,30.4,69.8,-0.00053,-0.00073,0.00000,0.00493,0.00840,0.00353,0.00000,-0.00003,0.00000,0.00003,0.00007,0.00003,0.042,4.880,0.001,69.78,-77.300,24.50
2604.636,Acc+Mag+Gyro,Aerospace,0.6,0.6,123.2,-0.013,0.013,1.042,-7.1,-9.8,35.3,0.05,5.15,0.25,0.4751,-0.0021,0.0081,0.8799,0.00,0.30,0.20,0.002,0.002,-0.040,-21.4,-56.4,-38.8,1.000,1.000,1.000,0.000,0.000,0.000,205,7.8,30.4,69.8,-0.00140,-0.00013,0.00000,0.00120,0.00403,0.00143,-0.00007,0.00000,0.00000,0.00000,0.00003,0.00000,0.042,4.880,0.001,69.77,-77.334,24.50
3 返答(返信)
2,482件の閲覧回数
michaelestanley
Trek,
I assume you are logging using the Sensor Fusion Toolbox for Windows and standard K64F build?  Which software version were you using? And the board was not moving during the test?
We may just be seeing the result of limited precision in the time stamp variable, with data good otherwise.  If you can respond to the questions above, we'll take a look at it.
Mike
2,482件の閲覧回数
trekwh
I was using the standard K64F build downloaded fresh from NXP webiste in late Dec 2015. The snesor fusion toolbox for windows has a build date of 11 Sep 2015. The board was stationary throughout the test.
I think by default, the record is 25Hz, which is 0.04sec interval, looking at the first two epochs, 2604.076, 2604.116, which is exactly 0.04, however then it output 6 idential time epochs and the time tag jumps to 2604.356, perhaps the cpu is overwhelmed with 9axis kalman filter task?
thanks.
2,482件の閲覧回数
markpedley
The problem is not at the Kinetis end. All the supported Kinetis MCUs run all the algorithms in parallel with time to spare even on the low end processors like the KL25Z. The K64F is high end with a floating point unit and is being stressed at less than 10% of its compute capacity.
The problem arises at the PC Windows end but is only really a minor annoyance in my opinion. I've just captured the following On Time stamps on the log file:
2824.92
2825.04
2825.04
2825.04
2825.08
2825.12
The correct interval at 25Hz is 40ms or 0.04s. Whenever you see the On Time stamp sticking it is associated with a larger time stamp gap immediately beforehand. In the sequence above the gaps between records are 0.12, 0, 0, 0.4, 0.4s. So it's self correcting and the On Time doesn't accumulate an error with time.
The root cause is that Windows is not a real time operating system and doesn't guarantee a response time. In the example above, Windows only activated its serial port callback when three groups of packets had been received and processed them all at once. The serial port activities and data logging activities are in different threads which also adds a certain lack of determinism.
I'll try to find a workaround for the next release.
%3CLINGO-SUB%20id%3D%22lingo-sub-462720%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E9%87%8D%E8%A4%87%E3%81%97%E3%81%9F%E3%82%BB%E3%83%B3%E3%82%B5%E8%A8%98%E9%8C%B2%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-462720%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%A7%81%E3%81%AF%E3%80%81FRDM-FXS-Multi2-B%E3%81%8B%E3%82%89FRDM-k64F%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E7%B5%8C%E7%94%B1%E3%81%97%E3%81%A6%E5%A4%9C%E9%96%93%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92USB%E7%B5%8C%E7%94%B1%E3%81%A7%E8%A8%98%E9%8C%B2%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E5%90%8C%E3%81%98%E3%82%A8%E3%83%9D%E3%83%83%E3%82%AF%E3%81%A7%E9%87%8D%E8%A4%87%E3%81%97%E3%81%9F%E8%A8%98%E9%8C%B2%E3%81%8C%E9%A0%BB%E7%B9%81%E3%81%AB%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E6%B0%97%E3%81%A5%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E4%BB%A5%E4%B8%8B%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%EF%BC%88%E5%A4%AA%E5%AD%97%E3%81%AE%E3%82%A8%E3%83%9D%E3%83%83%E3%82%AF%E7%95%AA%E5%8F%B7%EF%BC%89%E3%80%82%20%3C%2FP%3E%3CP%3E%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSTRONG%3E2604.076%2C%3C%2FSTRONG%3E%E5%8A%A0%E9%80%9F%E5%BA%A6%2B%E7%A3%81%E6%B0%97%2B%E3%82%B8%E3%83%A3%E3%82%A4%E3%83%AD%2C%E8%88%AA%E7%A9%BA%E5%AE%87%E5%AE%99%2C0.6%2C0.6%2C123.2%2C-0.013%2C0.016%2C1.037%2C-7.2%2C-9.8%2C34.9%2C0.30%2C5.00%2C-0.05%2C0.4749%2C-0.0022%2C0.0079%2C0.8800%2C0.25%2C0.10%2C-0.05%2C0.001%2C0.002%2C-0.039%2C-21.4%2C-56.4%2C-38.8%2C1.000%2C1.000%2C%201.000%2C0.000%2C0.000%2C0.000%2C205%2C7.8%2C30.4%2C69.8%2C-0.00190%2C-0.00003%2C0.00000%2C-0.00213%2C-0.00043%2C-0.00057%2C-0.00010%2C0.00000%2C0.00000%2C0.00000%2C0.00000%2C0.042%2C4.880%2C0.001%2C69.84%2C-77.294%2C24.50%3C%2FP%3E%3CP%3E%3CSTRONG%3E2604.116%2C%3C%2FSTRONG%3E%E5%8A%A0%E9%80%9F%E5%BA%A6%2B%E7%A3%81%E6%B0%97%2B%E3%82%B8%E3%83%A3%E3%82%A4%E3%83%AD%2C%E8%88%AA%E7%A9%BA%E5%AE%87%E5%AE%99%2C0.6%2C0.6%2C123.2%2C-0.013%2C0.016%2C1.037%2C-7.2%2C-9.8%2C34.9%2C0.30%2C5.00%2C-0.05%2C0.4749%2C-0.0022%2C0.0079%2C0.8800%2C0.25%2C0.10%2C-0.05%2C0.001%2C0.002%2C-0.039%2C-21.4%2C-56.4%2C-38.8%2C1.000%2C1.000%2C%201.000%2C0.000%2C0.000%2C0.000%2C205%2C7.8%2C30.4%2C69.8%2C-0.00190%2C-0.00003%2C0.00000%2C-0.00213%2C-0.00043%2C-0.00057%2C-0.00010%2C0.00000%2C0.00000%2C0.00000%2C0.00000%2C0.042%2C4.880%2C0.001%2C69.84%2C-77.293%2C24.50%3C%2FP%3E%3CP%3E%3CSTRONG%3E2604.116%3C%2FSTRONG%3E%20%2C%E5%8A%A0%E9%80%9F%E5%BA%A6%2B%E7%A3%81%E6%B0%97%2B%E3%82%B8%E3%83%A3%E3%82%A4%E3%83%AD%2C%E8%88%AA%E7%A9%BA%E5%AE%87%E5%AE%99%2C0.6%2C0.6%2C123.2%2C-0.014%2C0.014%2C1.041%2C-6.8%2C-10.6%2C34.1%2C-0.35%2C5.55%2C-0.10%2C0.4750%2C-0.0022%2C0.0079%2C0.8800%2C-0.40%2C0.65%2C-0.10%2C0.001%2C0.002%2C-0.039%2C-21.4%2C-56.4%2C-38.8%2C1.000%2C1.00%200%2C1.000%2C0.000%2C0.000%2C0.000%2C205%2C7.8%2C30.4%2C69.8%2C-0.00190%2C-0.00003%2C0.00000%2C-0.00213%2C-0.00043%2C-0.00057%2C-0.00010%2C0.00000%2C0.00000%2C0.00000%2C0.00000%2C0.042%2C4.880%2C0.001%2C69.84%2C-77.293%2C24.50%3C%2FP%3E%3CP%3E%3CSTRONG%3E2604.116%2C%3C%2FSTRONG%3E%E5%8A%A0%E9%80%9F%E5%BA%A6%2B%E7%A3%81%E6%B0%97%2B%E3%82%B8%E3%83%A3%E3%82%A4%E3%83%AD%2C%E8%88%AA%E7%A9%BA%E5%AE%87%E5%AE%99%2C0.6%2C0.6%2C123.2%2C-0.014%2C0.014%2C1.041%2C-6.8%2C-10.6%2C34.1%2C-0.35%2C5.55%2C-0.10%2C0.4750%2C-0.0022%2C0.0079%2C0.8800%2C-0.40%2C0.65%2C-0.10%2C0.001%2C0.002%2C-0.039%2C-21.4%2C-56.4%2C-38.8%2C1.000%2C1.00%200%2C1.000%2C0.000%2C0.000%2C0.000%2C205%2C7.8%2C30.4%2C69.8%2C-0.00190%2C-0.00003%2C0.00000%2C-0.00213%2C-0.00043%2C-0.00057%2C-0.00010%2C0.00000%2C0.00000%2C0.00000%2C0.00000%2C0.042%2C4.880%2C0.001%2C69.84%2C-77.293%2C24.50%3C%2FP%3E%3CP%3E%3CSTRONG%3E2604.116%2C%3C%2FSTRONG%3E%E5%8A%A0%E9%80%9F%E5%BA%A6%2B%E7%A3%81%E6%B0%97%2B%E3%82%B8%E3%83%A3%E3%82%A4%E3%83%AD%2C%E8%88%AA%E7%A9%BA%E5%AE%87%E5%AE%99%2C0.6%2C0.6%2C123.2%2C-0.014%2C0.014%2C1.041%2C-6.8%2C-10.6%2C34.1%2C-0.35%2C5.55%2C-0.10%2C0.4750%2C-0.0022%2C0.0079%2C0.8800%2C-0.40%2C0.65%2C-0.10%2C0.001%2C0.002%2C-0.039%2C-21.4%2C-56.4%2C-38.8%2C1.000%2C1.00%200%2C1.000%2C0.000%2C0.000%2C0.000%2C205%2C7.8%2C30.4%2C69.8%2C-0.00190%2C-0.00003%2C0.00000%2C-0.00213%2C-0.00043%2C-0.00057%2C-0.00010%2C0.00000%2C0.00000%2C0.00000%2C0.00000%2C0.042%2C4.880%2C0.001%2C69.84%2C-77.293%2C24.50%3C%2FP%3E%3CP%3E%3CSTRONG%3E2604.116%2C%3C%2FSTRONG%3E%E5%8A%A0%E9%80%9F%E5%BA%A6%2B%E7%A3%81%E6%B0%97%2B%E3%82%B8%E3%83%A3%E3%82%A4%E3%83%AD%2C%E8%88%AA%E7%A9%BA%E5%AE%87%E5%AE%99%2C0.6%2C0.6%2C123.2%2C-0.014%2C0.014%2C1.041%2C-6.8%2C-10.6%2C34.1%2C-0.35%2C5.55%2C-0.10%2C0.4750%2C-0.0022%2C0.0079%2C0.8800%2C-0.40%2C0.65%2C-0.10%2C0.001%2C0.002%2C-0.039%2C-21.4%2C-56.4%2C-38.8%2C1.000%2C1.00%200%2C1.000%2C0.000%2C0.000%2C0.000%2C205%2C7.8%2C30.4%2C69.8%2C-0.00190%2C-0.00003%2C0.00000%2C-0.00213%2C-0.00043%2C-0.00057%2C-0.00010%2C0.00000%2C0.00000%2C0.00000%2C0.00000%2C0.042%2C4.880%2C0.001%2C69.84%2C-77.293%2C24.50%3C%2FP%3E%3CP%3E%3CSTRONG%3E2604.116%2C%3C%2FSTRONG%3E%E5%8A%A0%E9%80%9F%E5%BA%A6%2B%E7%A3%81%E6%B0%97%2B%E3%82%B8%E3%83%A3%E3%82%A4%E3%83%AD%2C%E8%88%AA%E7%A9%BA%E5%AE%87%E5%AE%99%2C0.6%2C0.6%2C123.2%2C-0.014%2C0.014%2C1.041%2C-6.8%2C-10.6%2C34.1%2C-0.35%2C5.55%2C-0.10%2C0.4750%2C-0.0022%2C0.0079%2C0.8800%2C-0.40%2C0.65%2C-0.10%2C0.001%2C0.002%2C-0.039%2C-21.4%2C-56.4%2C-38.8%2C1.000%2C1.00%200%2C1.000%2C0.000%2C0.000%2C0.000%2C205%2C7.8%2C30.4%2C69.8%2C-0.00190%2C-0.00003%2C0.00000%2C-0.00213%2C-0.00043%2C-0.00057%2C-0.00010%2C0.00000%2C0.00000%2C0.00000%2C0.00000%2C0.042%2C4.880%2C0.001%2C69.84%2C-77.293%2C24.50%3C%2FP%3E%3CP%3E%3CSTRONG%3E2604.356%2C%3C%2FSTRONG%3E%E5%8A%A0%E9%80%9F%E5%BA%A6%2B%E7%A3%81%E6%B0%97%2B%E3%82%B8%E3%83%A3%E3%82%A4%E3%83%AD%2C%E8%88%AA%E7%A9%BA%E5%AE%87%E5%AE%99%2C0.6%2C0.6%2C123.2%2C-0.013%2C0.014%2C1.040%2C-7.0%2C-10.6%2C32.8%2C0.05%2C4.40%2C-0.10%2C0.4750%2C-0.0022%2C0.0078%2C0.8799%2C0.00%2C-0.40%2C-0.10%2C0.002%2C0.002%2C-0.038%2C-21.4%2C-56.4%2C-38.8%2C1.000%2C1.0%2000%2C1.000%2C0.000%2C0.000%2C0.000%2C205%2C7.8%2C30.4%2C69.8%2C0.00047%2C-0.00163%2C0.00000%2C0.00403%2C0.00410%2C0.00207%2C0.00000%2C-0.00007%2C0.00000%2C0.00003%2C0.00003%2C0.00000%2C0.042%2C4.880%2C0.001%2C69.79%2C-77.300%2C24.50%3C%2FP%3E%3CP%3E2604.356%2C%E5%8A%A0%E9%80%9F%E5%BA%A6%2B%E7%A3%81%E6%B0%97%2B%E3%82%B8%E3%83%A3%E3%82%A4%E3%83%AD%2C%E8%88%AA%E7%A9%BA%E5%AE%87%E5%AE%99%2C0.6%2C0.6%2C123.2%2C-0.013%2C0.015%2C1.038%2C-6.7%2C-10.7%2C33.9%2C0.05%2C4.40%2C-0.10%2C0.4750%2C-0.0022%2C0.0078%2C0.8799%2C0.00%2C-0.40%2C-0.10%2C0.002%2C0.002%2C-0.038%2C-21.4%2C-56.4%2C-38.8%2C1.00%200%2C1.000%2C1.000%2C0.000%2C0.000%2C0.000%2C205%2C7.8%2C30.4%2C69.8%2C0.00047%2C-0.00163%2C0.00000%2C0.00403%2C0.00410%2C0.00207%2C0.00000%2C-0.00007%2C0.00000%2C0.00003%2C0.00003%2C0.00000%2C0.042%2C4.880%2C0.001%2C69.79%2C-77.300%2C24.50%3C%2FP%3E%3CP%3E2604.356%2C%E5%8A%A0%E9%80%9F%E5%BA%A6%2B%E7%A3%81%E6%B0%97%2B%E3%82%B8%E3%83%A3%E3%82%A4%E3%83%AD%2C%E8%88%AA%E7%A9%BA%E5%AE%87%E5%AE%99%2C0.6%2C0.6%2C123.2%2C-0.013%2C0.015%2C1.038%2C-6.7%2C-10.7%2C33.9%2C0.05%2C4.40%2C-0.10%2C0.4750%2C-0.0022%2C0.0078%2C0.8799%2C0.00%2C-0.40%2C-0.10%2C0.002%2C0.002%2C-0.038%2C-21.4%2C-56.4%2C-38.8%2C1.00%200%2C1.000%2C1.000%2C0.000%2C0.000%2C0.000%2C205%2C7.8%2C30.4%2C69.8%2C0.00047%2C-0.00163%2C0.00000%2C0.00403%2C0.00410%2C0.00207%2C0.00000%2C-0.00007%2C0.00000%2C0.00003%2C0.00003%2C0.00000%2C0.042%2C4.880%2C0.001%2C69.79%2C-77.300%2C24.50%3C%2FP%3E%3CP%3E2604.356%2C%E5%8A%A0%E9%80%9F%E5%BA%A6%2B%E7%A3%81%E6%B0%97%2B%E3%82%B8%E3%83%A3%E3%82%A4%E3%83%AD%2C%E8%88%AA%E7%A9%BA%E5%AE%87%E5%AE%99%2C0.6%2C0.6%2C123.2%2C-0.013%2C0.015%2C1.038%2C-6.7%2C-10.7%2C33.9%2C0.05%2C4.40%2C-0.10%2C0.4750%2C-0.0022%2C0.0078%2C0.8799%2C0.00%2C-0.40%2C-0.10%2C0.002%2C0.002%2C-0.038%2C-21.4%2C-56.4%2C-38.8%2C1.00%200%2C1.000%2C1.000%2C0.000%2C0.000%2C0.000%2C205%2C7.8%2C30.4%2C69.8%2C0.00047%2C-0.00163%2C0.00000%2C0.00403%2C0.00410%2C0.00207%2C0.00000%2C-0.00007%2C0.00000%2C0.00003%2C0.00003%2C0.00000%2C0.042%2C4.880%2C0.001%2C69.79%2C-77.300%2C24.50%3C%2FP%3E%3CP%3E2604.356%2C%E5%8A%A0%E9%80%9F%E5%BA%A6%2B%E7%A3%81%E6%B0%97%2B%E3%82%B8%E3%83%A3%E3%82%A4%E3%83%AD%2C%E8%88%AA%E7%A9%BA%E5%AE%87%E5%AE%99%2C0.6%2C0.6%2C123.2%2C-0.013%2C0.015%2C1.038%2C-6.7%2C-10.7%2C33.9%2C0.05%2C4.40%2C-0.10%2C0.4750%2C-0.0022%2C0.0078%2C0.8799%2C0.00%2C-0.40%2C-0.10%2C0.002%2C0.002%2C-0.038%2C-21.4%2C-56.4%2C-38.8%2C1.00%200%2C1.000%2C1.000%2C0.000%2C0.000%2C0.000%2C205%2C7.8%2C30.4%2C69.8%2C0.00047%2C-0.00163%2C0.00000%2C0.00403%2C0.00410%2C0.00207%2C0.00000%2C-0.00007%2C0.00000%2C0.00003%2C0.00003%2C0.00000%2C0.042%2C4.880%2C0.001%2C69.79%2C-77.300%2C24.50%3C%2FP%3E%3CP%3E2604.396%2C%E5%8A%A0%E9%80%9F%E5%BA%A6%2B%E7%A3%81%E6%B0%97%2B%E3%82%B8%E3%83%A3%E3%82%A4%E3%83%AD%2C%E8%88%AA%E7%A9%BA%E5%AE%87%E5%AE%99%2C0.6%2C0.6%2C123.2%2C-0.013%2C0.015%2C1.038%2C-6.7%2C-10.7%2C33.9%2C0.05%2C4.40%2C-0.10%2C0.4750%2C-0.0022%2C0.0078%2C0.8799%2C0.00%2C-0.40%2C-0.10%2C0.002%2C0.002%2C-0.038%2C-21.4%2C-56.4%2C-38.8%2C1.00%200%2C1.000%2C1.000%2C0.000%2C0.000%2C0.000%2C205%2C7.8%2C30.4%2C69.8%2C0.00047%2C-0.00163%2C0.00000%2C0.00403%2C0.00410%2C0.00207%2C0.00000%2C-0.00007%2C0.00000%2C0.00003%2C0.00003%2C0.00000%2C0.042%2C4.880%2C0.001%2C69.79%2C-77.300%2C24.50%3C%2FP%3E%3CP%3E2604.396%2C%E5%8A%A0%E9%80%9F%E5%BA%A6%2B%E7%A3%81%E6%B0%97%2B%E3%82%B8%E3%83%A3%E3%82%A4%E3%83%AD%2C%E8%88%AA%E7%A9%BA%E5%AE%87%E5%AE%99%2C0.6%2C0.6%2C123.2%2C-0.014%2C0.017%2C1.041%2C-7.2%2C-10.8%2C35.0%2C0.00%2C4.65%2C0.00%2C0.4751%2C-0.0022%2C0.0079%2C0.8799%2C0.00%2C-0.15%2C0.00%2C0.002%2C0.002%2C-0.039%2C-21.4%2C-56.4%2C-38.8%2C1.000%2C%201.000%2C1.000%2C0.000%2C0.000%2C0.000%2C205%2C7.8%2C30.4%2C69.8%2C-0.00053%2C-0.00073%2C0.00000%2C0.00493%2C0.00840%2C0.00353%2C0.00000%2C-0.00003%2C0.00000%2C0.00003%2C0.00007%2C0.00003%2C0.042%2C4.880%2C0.001%2C69.78%2C-77.300%2C24.50%3C%2FP%3E%3CP%3E2604.636%2C%E5%8A%A0%E9%80%9F%E5%BA%A6%2B%E7%A3%81%E6%B0%97%2B%E3%82%B8%E3%83%A3%E3%82%A4%E3%83%AD%2C%E8%88%AA%E7%A9%BA%E5%AE%87%E5%AE%99%2C0.6%2C0.6%2C123.2%2C-0.013%2C0.013%2C1.042%2C-7.1%2C-9.8%2C35.3%2C0.05%2C5.15%2C0.25%2C0.4751%2C-0.0021%2C0.0081%2C0.8799%2C0.00%2C0.30%2C0.20%2C0.002%2C0.002%2C-0.040%2C-21.4%2C-56.4%2C-38.8%2C1.000%2C1%20.000%2C1.000%2C0.000%2C0.000%2C0.000%2C205%2C7.8%2C30.4%2C69.8%2C-0.00140%2C-0.00013%2C0.00000%2C0.00120%2C0.00403%2C0.00143%2C-0.00007%2C0.00000%2C0.00000%2C0.00003%2C0.00000%2C0.042%2C4.880%2C0.001%2C69.77%2C-77.334%2C24.50%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-462720%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BB%E3%83%95%E3%83%A5%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-462723%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20duplicated%20sensor%20records%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-462723%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%95%8F%E9%A1%8C%E3%81%AFKinetis%E5%81%B4%E3%81%AB%E3%81%82%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%20Kinetis%20MCU%20%E3%81%AF%E3%80%81KL25Z%20%E3%81%AA%E3%81%A9%E3%81%AE%E3%83%AD%E3%83%BC%E3%82%A8%E3%83%B3%E3%83%89%20%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%81%A7%E3%82%82%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%A2%E3%83%AB%E3%82%B4%E3%83%AA%E3%82%BA%E3%83%A0%E3%82%92%E4%BD%99%E8%A3%95%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E4%B8%A6%E5%88%97%E3%81%AB%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82K64F%20%E3%81%AF%E6%B5%AE%E5%8B%95%E5%B0%8F%E6%95%B0%E7%82%B9%E3%83%A6%E3%83%8B%E3%83%83%E3%83%88%E3%82%92%E5%82%99%E3%81%88%E3%81%9F%E3%83%8F%E3%82%A4%E3%82%A8%E3%83%B3%E3%83%89%E3%81%A7%E3%80%81%E3%81%9D%E3%81%AE%E8%A8%88%E7%AE%97%E8%83%BD%E5%8A%9B%E3%81%AE%2010%25%20%E6%9C%AA%E6%BA%80%E3%81%A7%E3%82%B9%E3%83%88%E3%83%AC%E3%82%B9%E3%81%8C%E3%81%8B%E3%81%8B%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AF%20PC%20%E3%81%AE%20Windows%20%E5%81%B4%E3%81%A7%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E7%A7%81%E3%81%AE%E6%84%8F%E8%A6%8B%E3%81%A7%E3%81%AF%E3%80%81%E6%9C%AC%E5%BD%93%E3%81%AB%E5%B0%8F%E3%81%95%E3%81%AA%E8%BF%B7%E6%83%91%E3%81%A7%E3%81%97%E3%81%8B%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%AD%E3%82%B0%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E6%AC%A1%E3%81%AE%20On%20Time%20%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%97%E3%82%92%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E2824.92%3C%2FP%3E%3CP%3E2825.04%3C%2FP%3E%3CP%3E2825.04%3C%2FP%3E%3CP%3E2825.04%3C%2FP%3E%3CP%3E2825.08%3C%2FP%3E%3CP%3E2825.12%3C%2FP%3E%3CP%3E25Hz%20%E3%81%A7%E3%81%AE%E6%AD%A3%E3%81%97%E3%81%84%E9%96%93%E9%9A%94%E3%81%AF%2040ms%20%E3%81%BE%E3%81%9F%E3%81%AF%200.04%20%E7%A7%92%E3%81%A7%E3%81%99%E3%80%82On%20Time%20%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%97%E3%81%8C%E8%B2%BC%E3%82%8A%E4%BB%98%E3%81%91%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%82%92%E7%9B%AE%E3%81%AB%E3%81%99%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%AF%E3%80%81%E3%81%9D%E3%81%AE%E7%9B%B4%E5%89%8D%E3%81%AB%E3%82%BF%E3%82%A4%E3%83%A0%20%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%97%E3%81%AE%E5%A4%A7%E3%81%8D%E3%81%AA%E3%82%AE%E3%83%A3%E3%83%83%E3%83%97%E3%81%8C%E3%81%82%E3%81%A3%E3%81%9F%E3%81%93%E3%81%A8%E3%82%92%E6%84%8F%E5%91%B3%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E4%B8%8A%E8%A8%98%E3%81%AE%E3%82%B7%E3%83%BC%E3%82%B1%E3%83%B3%E3%82%B9%E3%81%A7%E3%81%AF%E3%80%81%E3%83%AC%E3%82%B3%E3%83%BC%E3%83%89%E9%96%93%E3%81%AE%E3%82%AE%E3%83%A3%E3%83%83%E3%83%97%E3%81%AF%200.12%E3%80%810%E3%80%810%E3%80%810.4%E3%80%810.4%20%E7%A7%92%E3%81%A7%E3%81%99%E3%80%82SO%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E8%87%AA%E5%B7%B1%E4%BF%AE%E6%AD%A3%E7%9A%84%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E3%82%AA%E3%83%B3%E3%82%BF%E3%82%A4%E3%83%A0%E3%81%AF%E6%99%82%E9%96%93%E3%81%AE%E7%B5%8C%E9%81%8E%E3%81%A8%E3%81%A8%E3%82%82%E3%81%AB%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%92%E8%93%84%E7%A9%8D%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E6%A0%B9%E6%9C%AC%E7%9A%84%E3%81%AA%E5%8E%9F%E5%9B%A0%E3%81%AF%E3%80%81Windows%20%E3%81%8C%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%BF%E3%82%A4%E3%83%A0%20%E3%82%AA%E3%83%9A%E3%83%AC%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81%E5%BF%9C%E7%AD%94%E6%99%82%E9%96%93%E3%82%92%E4%BF%9D%E8%A8%BC%E3%81%97%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%E4%B8%8A%E8%A8%98%E3%81%AE%E4%BE%8B%E3%81%A7%E3%81%AF%E3%80%81Windows%20%E3%81%AF%203%20%E3%81%A4%E3%81%AE%E3%83%91%E3%82%B1%E3%83%83%E3%83%88%20%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97%E3%81%8C%E5%8F%97%E4%BF%A1%E3%81%95%E3%82%8C%E3%80%81%E3%81%9D%E3%82%8C%E3%82%89%E3%82%92%E3%81%99%E3%81%B9%E3%81%A6%E4%B8%80%E5%BA%A6%E3%81%AB%E5%87%A6%E7%90%86%E3%81%97%E3%81%9F%E3%81%A8%E3%81%8D%E3%81%AB%E3%81%AE%E3%81%BF%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%20%E3%83%9D%E3%83%BC%E3%83%88%20%E3%82%B3%E3%83%BC%E3%83%AB%E3%83%90%E3%83%83%E3%82%AF%E3%82%92%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E5%8C%96%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%20%E3%83%9D%E3%83%BC%E3%83%88%20%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%93%E3%83%86%E3%82%A3%E3%81%A8%E3%83%87%E3%83%BC%E3%82%BF%20%E3%83%AD%E3%82%AE%E3%83%B3%E3%82%B0%20%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%93%E3%83%86%E3%82%A3%E3%81%AF%E7%95%B0%E3%81%AA%E3%82%8B%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%81%93%E3%82%8C%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E3%82%82%E6%B1%BA%E5%AE%9A%E8%AB%96%E6%80%A7%E3%81%8C%E6%AC%A0%E5%A6%82%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E6%AC%A1%E3%81%AE%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%AB%E5%90%91%E3%81%91%E3%81%A6%E5%9B%9E%E9%81%BF%E7%AD%96%E3%82%92%E6%8E%A2%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-462722%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20duplicated%20sensor%20records%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-462722%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%A7%81%E3%81%AF%E3%80%812015%20%E5%B9%B4%2012%20%E6%9C%88%E4%B8%8B%E6%97%AC%E3%81%AB%20NXP%20Web%20%E3%82%B5%E3%82%A4%E3%83%88%E3%81%8B%E3%82%89%E6%96%B0%E3%81%97%E3%81%8F%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%9F%E6%A8%99%E6%BA%96%E3%81%AE%20K64F%20%E3%83%93%E3%83%AB%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82Windows%20%E7%94%A8%E3%81%AE%20SNESOR%20Fusion%20Toolbox%20%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E6%97%A5%E3%81%AF%202015%20%E5%B9%B4%209%20%E6%9C%88%2011%20%E6%97%A5%E3%81%A7%E3%81%99%E3%80%82%E3%83%86%E3%82%B9%E3%83%88%E4%B8%AD%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AF%E9%9D%99%E6%AD%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%A7%E3%81%AF%E8%A8%98%E9%8C%B2%E3%81%AF25Hz%E3%80%81%E3%81%A4%E3%81%BE%E3%82%8A0.04%E7%A7%92%E9%96%93%E9%9A%94%E3%81%A7%E3%80%81%E6%9C%80%E5%88%9D%E3%81%AE2%E3%81%A4%E3%81%AE%E3%82%A8%E3%83%9D%E3%83%83%E3%82%AF2604.076%E3%82%92%E8%A6%8B%E3%82%8B%E3%81%A8%E3%80%812604.116%20%E3%81%AF%E3%81%A1%E3%82%87%E3%81%86%E3%81%A9%200.04%20%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%81%9D%E3%81%AE%E5%BE%8C%206%20%E3%81%A4%E3%81%AE%E5%90%8C%E4%B8%80%E6%99%82%E9%96%93%E3%82%A8%E3%83%9D%E3%83%83%E3%82%AF%E3%81%8C%E5%87%BA%E5%8A%9B%E3%81%95%E3%82%8C%E3%80%81%E6%99%82%E9%96%93%E3%82%BF%E3%82%B0%E3%81%8C%202604.356%20%E3%81%AB%E3%82%B8%E3%83%A3%E3%83%B3%E3%83%97%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%8A%E3%81%9D%E3%82%89%E3%81%8F%E3%80%81CPU%20%E3%81%8C%209%20%E8%BB%B8%E3%82%AB%E3%83%AB%E3%83%9E%E3%83%B3%20%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BF%E3%83%BC%20%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%A7%E9%81%8E%E8%B2%A0%E8%8D%B7%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-462721%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20duplicated%20sensor%20records%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-462721%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%83%88%E3%83%AC%E3%83%83%E3%82%AF%E3%80%81%3C%2FP%3E%3CP%3ESensor%20Fusion%20Toolbox%20for%20Windows%20%E3%81%A8%E6%A8%99%E6%BA%96%E3%81%AE%20K64F%20%E3%83%93%E3%83%AB%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%AD%E3%82%B0%E3%81%AB%E8%A8%98%E9%8C%B2%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%A9%E3%81%AE%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%3F%E3%83%86%E3%82%B9%E3%83%88%E4%B8%AD%E3%81%AF%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AF%E5%8B%95%E3%81%84%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%97%E5%A4%89%E6%95%B0%E3%81%AE%E7%B2%BE%E5%BA%A6%E3%81%8C%E9%99%90%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E7%B5%90%E6%9E%9C%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A0%E3%81%91%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E3%81%9D%E3%82%8C%E4%BB%A5%E5%A4%96%E3%81%AF%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AF%E8%89%AF%E5%A5%BD%E3%81%A7%E3%81%99%E3%80%82%E4%B8%8A%E8%A8%98%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%AB%E3%81%94%E5%9B%9E%E7%AD%94%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%82%8C%E3%81%B0%E3%80%81%E6%A4%9C%E8%A8%8E%E3%81%95%E3%81%9B%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3EMike%3C%2FP%3E%3C%2FLINGO-BODY%3E
