Hello All,
I am trying out the Freescale Sensor Fusion Toolbox (build on 11 september 2015).
I only got the following problem when flashing the file: FRDM-KL25Z-V-NED.hex (stand alone) to the MBED drive.
I am getting the error BAD EXTENSION FILE (in the fail.txt file)
This is on MBED with MBED firmware rev 203. Bootloader version from Pemicro is v111.
On which version has it been working/tested? Is there an updated file (hex/bin) available? Or any suggestion what to try more?
Thanks in advance!
Antoine van der Heijde
已解决! 转到解答。
Antoine,
The GUI is assuming that KL25Z boards are programmed with OpenSDA V1 by P&E Micro. That's why they won't work with your MBED-enabled board.
If you reprogram the board to the P&E interface, it should work just fine.
Mike
Antoine,
Mike
