READ DATA OF MMA8452
1,315件の閲覧回数
594160903
    I am a rookie of using MMA8452, I want to read data of mma8452 to know the x,y,z;But I read data is always F and 4095,
please help me , thanks!!!
void Multiple_Read_MMA8452(void)
uchar i;
MMA8452_Start();
MMA8452_SendByte(0x38 )
MMA8452_SendByte(0x01);
MMA8452_Start();
MMA8452_SendByte(0x38 +1);
for (i=0; i<6; i++)
BUF[i] = MMA8452_RecvByte();
if (i == 5)
MMA8452_SendACK((BitAction)1);
else
MMA8452_SendACK((BitAction)0);
MMA8452_Stop();
Delay5ms();
void Init_MMA8452(void)
Single_Write_MMA8452(0x2A,0x01); //
Single_Write_MMA8452(0x2B,0x02); //
1,087件の閲覧回数
david_diaz
Thank you very much for writing.
In this case, I’d like to recommend the application note AN4076 below:
Data Manipulation and Basic Settings of the MMA8451, 2, 3Q
This application note accompanies the MMA8451, 2, 3Q Driver Code and will explain the following:
  • Changing the operational modes (Standby, Active 2g, Active 4g and Active 8g)
  • Changing Oversampling Modes
  • Changing the Data Rate
  • Changing the High-Pass Filter Cutoff Frequency
  • 8-bit data vs. 14/12/10-bit data
  • Changing Data Formats (hex to counts to decimal numbers)
  • Streaming XYZ data polling vs. Streaming XYZ data with interrupts
  • Using the FIFO in the MMA8451
Besides, you may use the sample project below as a reference for your application.
MMA8451Q - Bare metal example project
Please let me know if you have any further question.
David
%3CLINGO-SUB%20id%3D%22lingo-sub-642695%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMMA8452%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-642695%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%A7%81%E3%81%AFMMA8452%E3%81%AE%E5%88%9D%E5%BF%83%E8%80%85%E3%81%A7%E3%81%99%E3%80%82mma8452%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%80%81x%E3%80%81y%E3%80%81z%E3%82%92%E7%9F%A5%E3%82%8A%E3%81%9F%E3%81%84%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E8%AA%AD%E3%81%BF%E5%8F%96%E3%81%A3%E3%81%9F%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AF%E5%B8%B8%E3%81%ABF%E3%81%A84095%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E5%8A%A9%E3%81%91%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%81%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86!!!%3C%2FP%3E%3CP%3Evoid%20Multiple_Read_MMA8452(void)%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%E3%82%A6%E3%83%81%E3%83%A3%E3%83%AB%20i%3B%3CBR%20%2F%3E%20MMA8452_%E9%96%8B%E5%A7%8B()%3B%3CBR%20%2F%3E%20MMA8452_SendByte(0x38%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%EF%BC%89%3CBR%20%2F%3E%20MMA8452_SendByte(0x01)%3B%3CBR%20%2F%3E%20MMA8452_%E9%96%8B%E5%A7%8B()%3B%3CBR%20%2F%3E%20MMA8452_SendByte(0x38%3CSPAN%20class%3D%22%22%3E%20%3C%2FSPAN%3E%2B1)%3B%3CBR%20%2F%3E%20(i%3D0%3B%20i%26lt%3B6%3B%20i%2B%2B)%20%E3%81%AE%E5%A0%B4%E5%90%88%3CBR%20%2F%3E%7B%3CBR%20%2F%3E%20BUF%5Bi%5D%20%3D%20MMA8452_RecvByte()%3B%3CBR%20%2F%3E%E3%82%82%E3%81%97%20(i%20%3D%3D%205)%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%20MMA8452_SendACK((%E3%83%93%E3%83%83%E3%83%88%E3%82%A2%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3)1)%3B%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%E3%81%9D%E3%82%8C%E4%BB%A5%E5%A4%96%3CBR%20%2F%3E%7B%3CBR%20%2F%3E%20MMA8452_SendACK((%E3%83%93%E3%83%83%E3%83%88%E3%82%A2%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3)0)%3B%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%20MMA8452_%E5%81%9C%E6%AD%A2()%3B%3CBR%20%2F%3E%E9%81%85%E5%BB%B65ms()%3B%3CBR%20%2F%3E%20%7D%3C%2FP%3E%3CP%3E%3CBR%20%2F%3Evoid%20Init_MMA8452(void)%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BFMMA8452(0x2A%2C0x01)%3B%20%2F%2F%3CBR%20%2F%3E%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BFMMA8452(0x2B%2C0x02)%3B%20%2F%2F%3CBR%20%2F%3E%3CBR%20%2F%3E%20%7D%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-642696%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20READ%20DATA%20OF%20MMA8452%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-642696%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3E%E3%81%94%E9%80%A3%E7%B5%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20%E3%83%8E%E3%83%BC%E3%83%88%20AN4076%20%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Fassets%2Fdocuments%2Fdata%2Fen%2Fapplication-notes%2FAN4076.pdf%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EMMA8451%E3%80%812%E3%80%813Q%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E6%93%8D%E4%BD%9C%E3%81%A8%E5%9F%BA%E6%9C%AC%E8%A8%AD%E5%AE%9A%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20%E3%83%8E%E3%83%BC%E3%83%88%E3%81%AF%20MMA8451%E3%80%812%E3%80%813Q%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AB%E4%BB%98%E5%B1%9E%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E6%AC%A1%E3%81%AE%E5%86%85%E5%AE%B9%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CUL%3E%3CLI%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%E5%8B%95%E4%BD%9C%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AE%E5%A4%89%E6%9B%B4%EF%BC%88%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%90%E3%82%A4%E3%80%81%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%202g%E3%80%81%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%204g%E3%80%81%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%208g%EF%BC%89%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AA%E3%83%B3%E3%82%B0%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AE%E5%A4%89%E6%9B%B4%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%E3%83%87%E3%83%BC%E3%82%BF%E3%83%AC%E3%83%BC%E3%83%88%E3%81%AE%E5%A4%89%E6%9B%B4%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%E3%83%8F%E3%82%A4%E3%83%91%E3%82%B9%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BF%E3%81%AE%E3%82%AB%E3%83%83%E3%83%88%E3%82%AA%E3%83%95%E5%91%A8%E6%B3%A2%E6%95%B0%E3%81%AE%E5%A4%89%E6%9B%B4%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E8%E3%83%93%E3%83%83%E3%83%88%E3%83%87%E3%83%BC%E3%82%BF%E3%81%A814%2F12%2F10%E3%83%93%E3%83%83%E3%83%88%E3%83%87%E3%83%BC%E3%82%BF%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%E3%83%87%E3%83%BC%E3%82%BF%E5%BD%A2%E5%BC%8F%E3%81%AE%E5%A4%89%E6%9B%B4%EF%BC%8816%E9%80%B2%E6%95%B0%E3%81%8B%E3%82%89%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%E3%80%8110%E9%80%B2%E6%95%B0%E3%81%B8%EF%BC%89%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%9F%E3%83%B3%E3%82%B0%20XYZ%20%E3%83%87%E3%83%BC%E3%82%BF%20%E3%83%9D%E3%83%BC%E3%83%AA%E3%83%B3%E3%82%B0%20vs.%20%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E4%BB%98%E3%81%8D%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%9F%E3%83%B3%E3%82%B0%20XYZ%20%E3%83%87%E3%83%BC%E3%82%BF%3C%2FLI%3E%3CLI%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3EMMA8451%E3%81%AEFIFO%E3%81%AE%E4%BD%BF%E7%94%A8%3C%2FLI%3E%3C%2FUL%3E%3CBR%20%2F%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%82%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-98836%22%20target%3D%22_blank%22%3EMMA8451Q%20-%20%E3%83%99%E3%82%A2%E3%83%A1%E3%82%BF%E3%83%AB%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%83%BB%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%3C%2FA%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E4%BB%96%E3%81%AB%E3%81%94%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%82%89%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%93%E3%83%83%E3%83%89%3C%2FP%3E%3C%2FLINGO-BODY%3E
