Question On MMA7660 Offset Calibration
3,397件の閲覧回数
wxb
according to AN3841 "Performing Offset Calibration using theMMA7660FC"
//Hold MMA7660FC on horizontal plane, put it in active mode and get the shift value
X_Shift = (64 times reading sum)/64*(-2)
Y_Shift = (64 times reading sum)/64*(-2)
Z_Shift = ((64 times reading sum)/64-21) *(-2)
My question is how to get the X_shift,Y_shift and Z_shift?
Is obtained from the register of REG00-REG02?
3,061件の閲覧回数
reyes
Correct, “(64 times reading sum)/64” is equal to get the average value in 64 reads of REG00 (for the example of X_Shift), so, for example, X_Shift would be the result of the average value of reading REG00 64 times *-2
Also could be seen as:
X_Shift = (sum of 64 times reading REG00)/64*-2
Y_Shift = (sum of 64 times reading REG01)/64*-2
Z_Shift = ((sum of 64 times reading REG02)/64-21)*-2
Does this make sense to you? Please let me know if still not clear.
Jose Reyes
3 返答(返信)
3,062件の閲覧回数
reyes
Jose Reyes
3,061件の閲覧回数
wxb
thinks for your reply,
    I want to reads the x-axis、y-axis and z-axis tilt angle as following codes ,if get reg00  is 22 ,can i think this time the x-aixs angle is 0 °?
    How to understand the MMA7660 Datasheet  "APPENDIX C - MMA7660FC ACQUISITION CODE TABLE" ,Angle X or Y blank meaning when 6-bit result is 22 - 42.
float TILT_XY[64] = {0, 2.69, 5.38, 8.08, 10.81, 13.55, 16.33, 19.16, 22.02, 24.95, 27.95, 31.04, 34.23, 37.54, 41.01, 44.68, 48.59, 52.83, 57.54, 62.95, 69.64, 79.86, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, -79.86, -69.64, -62.95, -57.54, -52.83, -48.59, -44.68, -41.01, -37.54, -34.23, -31.04, -27.95, -24.95, -22.02, -19.16, -16.33, -13.55, -10.81, -8.08, -5.38, -2.69};
int main()
    unsigned char x;
    float AngleX;
    //Device initialization
    // Reads the reg00
    x = MMA7660_GetResult(reg00);
    //Get the X-axis angle
   AngleX =  TILT_XY[x];
3,061件の閲覧回数
reyes
Every g-force value bigger than +1g or lower than -1g cannot be converted in angle measurement since you would not be measuring “Static Acceleration” (used to measure tilt angulations), the reason is that the reference is the 1g from gravity force. If the value is bigger than +1g or lower than -1g, then an additional force called “Dynamic Acceleration” (movement for example) would be added to the formula, and no tilt angle measurement is possible for this case.
Now, the formula to calculate the angle according to the g-force measured is:
Angle = ASIN(g-value)*180/Pi
And it is not possible to calculate ASIN values for numbers bigger than 1 (or lower than -1).
*Remember that ASIN(1) = 90°
So, for values between 22 and 42 (in the 6-bit result column), there is no valid data angle (it is not 0 either). If you get a number between 22 and 42 it means that an external force (additional to the gravity force) is applied (linear movement for example), and if you get a number between 28 and 36 means that you should be shaking the device.
Jose Reyes
%3CLINGO-SUB%20id%3D%22lingo-sub-359969%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMMA7660%E3%81%AE%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E8%B3%AA%E5%95%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-359969%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3EAN3841%E3%80%8C%3C%2FSPAN%3E%20MMA7660FC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E5%AE%9F%E8%A1%8C%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%E3%80%8D%3C%2FSPAN%3E%E3%81%AB%E3%82%88%E3%82%8B%E3%81%A8%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%3B%20font-size%3A%2014px%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208pt%3B%22%3E%3CEM%3E%2F%2FMMA7660FC%E3%82%92%E6%B0%B4%E5%B9%B3%E9%9D%A2%E4%B8%8A%E3%81%AB%E4%BF%9D%E6%8C%81%E3%81%97%E3%80%81%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E3%81%97%E3%81%A6%E3%82%B7%E3%83%95%E3%83%88%E5%80%A4%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%BE%E3%81%99%20%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%3B%20font-size%3A%2014px%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208pt%3B%22%3E%3CEM%3EX_Shift%20%3D%20(64%E5%9B%9E%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E5%90%88%E8%A8%88)%2F64*(-2)%20%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%3B%20font-size%3A%2014px%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208pt%3B%22%3E%3CEM%3EY_Shift%20%3D%20(64%E5%9B%9E%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E5%90%88%E8%A8%88)%2F64*(-2)%20%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%3B%20font-size%3A%2014px%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208pt%3B%22%3E%3CEM%3EZ_Shift%20%3D%20((64%E5%9B%9E%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E5%90%88%E8%A8%88)%2F64-21)%20*(-2)%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%3B%20font-size%3A%2014px%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%208pt%3B%22%3E%3CEM%3E%3CBR%20%2F%3E%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%3B%20font-size%3A%2014px%3B%22%3E%E8%B3%AA%E5%95%8F%E3%81%AF%E3%80%81X_shift%E3%80%81%20%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%3B%20font-size%3A%2014px%3B%22%3EY_shift%E3%80%81%20%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20%E5%BE%AE%E8%BD%AF%E9%9B%85%E9%BB%91%3B%20font-size%3A%2014px%3B%22%3EZ_shift%20%E3%82%92%E5%8F%96%E5%BE%97%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%8B%E3%81%A8%E3%81%84%E3%81%86%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3EREG00%EF%BD%9EREG02%3CSPAN%20style%3D%22color%3A%20%23434343%3B%20font-family%3A%20Tahoma%2C%20Arial%3B%20background-color%3A%20%23f2f2f2%3B%22%3E%E3%81%AE%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%8B%E3%82%89%E5%8F%96%E5%BE%97%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8B%3C%2FSPAN%3E%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-359969%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E3%82%BB%E3%83%B3%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%BB%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-359972%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Question%20On%20MMA7660%20Offset%20Calibration%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-359972%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%2B1g%20%E3%82%88%E3%82%8A%E5%A4%A7%E3%81%8D%E3%81%84%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%20-1g%20%E3%82%88%E3%82%8A%E5%B0%8F%E3%81%95%E3%81%84%20g%20%E5%8A%9B%E3%81%AE%E5%80%A4%E3%81%AF%E3%80%81%E8%A7%92%E5%BA%A6%E6%B8%AC%E5%AE%9A%E3%81%A7%E3%81%AF%E5%A4%89%E6%8F%9B%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E3%80%8C%E9%9D%99%E7%9A%84%E5%8A%A0%E9%80%9F%E5%BA%A6%E3%80%8D%EF%BC%88%E5%82%BE%E3%81%8D%E3%81%AE%E6%B8%AC%E5%AE%9A%E3%81%AB%E4%BD%BF%E7%94%A8%EF%BC%89%E3%82%92%E6%B8%AC%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E5%9F%BA%E6%BA%96%E3%81%8C%E9%87%8D%E5%8A%9B%E3%81%8B%E3%82%89%E3%81%AE%201g%20%E3%81%A7%E3%81%82%E3%82%8B%E3%81%9F%E3%82%81%E3%81%A7%E3%81%99%E3%80%82%E5%80%A4%E3%81%8C%20%2B1g%20%E3%82%88%E3%82%8A%E5%A4%A7%E3%81%8D%E3%81%84%E3%81%8B%20-1g%20%E3%82%88%E3%82%8A%E5%B0%8F%E3%81%95%E3%81%84%E5%A0%B4%E5%90%88%E3%80%81%E3%80%8C%E5%8B%95%E7%9A%84%E5%8A%A0%E9%80%9F%E5%BA%A6%E3%80%8D%E3%81%A8%E5%91%BC%E3%81%B0%E3%82%8C%E3%82%8B%E8%BF%BD%E5%8A%A0%E3%81%AE%E5%8A%9B%20(%E3%81%9F%E3%81%A8%E3%81%88%E3%81%B0%E5%8B%95%E3%81%8D)%20%E3%81%8C%E5%BC%8F%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%95%E3%82%8C%E3%80%81%E3%81%93%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%E5%82%BE%E6%96%9C%E8%A7%92%E5%BA%A6%E3%81%AE%E6%B8%AC%E5%AE%9A%E3%81%AF%E4%B8%8D%E5%8F%AF%E8%83%BD%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%B8%AC%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%9F%E9%87%8D%E5%8A%9B%E5%8A%A0%E9%80%9F%E5%BA%A6%E3%81%AB%E5%BF%9C%E3%81%98%E3%81%A6%E8%A7%92%E5%BA%A6%E3%82%92%E8%A8%88%E7%AE%97%E3%81%99%E3%82%8B%E5%BC%8F%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E8%A7%92%E5%BA%A6%20%3D%20ASIN(g%E5%80%A4)*180%2FPi%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%80%811%20%E3%82%88%E3%82%8A%E5%A4%A7%E3%81%8D%E3%81%84%E6%95%B0%E5%80%A4%20(%E3%81%BE%E3%81%9F%E3%81%AF%20-1%20%E3%82%88%E3%82%8A%E5%B0%8F%E3%81%95%E3%81%84%E6%95%B0%E5%80%A4)%20%E3%81%AE%20ASIN%20%E5%80%A4%E3%82%92%E8%A8%88%E7%AE%97%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E*ASIN(1)%20%3D%2090%C2%B0%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E8%A6%9A%E3%81%88%E3%81%A6%E3%81%8A%E3%81%84%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%8122%20%E3%80%9C%2042%20%E3%81%AE%E5%80%A4%20(6%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E7%B5%90%E6%9E%9C%E5%88%97)%20%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E6%9C%89%E5%8A%B9%E3%81%AA%E3%83%87%E3%83%BC%E3%82%BF%E8%A7%92%E5%BA%A6%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%20(0%20%E3%81%A7%E3%82%82%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93)%E3%80%8222%20%E3%81%8B%E3%82%89%2042%20%E3%81%BE%E3%81%A7%E3%81%AE%E6%95%B0%E5%80%A4%E3%81%8C%E5%87%BA%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E5%A4%96%E5%8A%9B%20(%E9%87%8D%E5%8A%9B%E3%81%AB%E5%8A%A0%E3%81%88%E3%81%A6)%20%E3%81%8C%E9%81%A9%E7%94%A8%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%20(%E7%9B%B4%E7%B7%9A%E9%81%8B%E5%8B%95%E3%81%AA%E3%81%A9)%20%E3%82%92%E6%84%8F%E5%91%B3%E3%81%97%E3%80%8128%20%E3%81%8B%E3%82%89%2036%20%E3%81%BE%E3%81%A7%E3%81%AE%E6%95%B0%E5%80%A4%E3%81%8C%E5%87%BA%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E6%8C%AF%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E6%84%8F%E5%91%B3%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E3%81%99%E3%81%A6%E3%81%8D%E3%81%AA%E4%B8%80%E6%97%A5%E3%82%92%E3%80%81%3CBR%20%2F%3E%E3%83%9B%E3%82%BB%E3%83%BB%E3%83%AC%E3%82%A4%E3%82%A8%E3%82%B9%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E-----------------------------------------------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%3A%20%E3%81%93%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%A7%E8%B3%AA%E5%95%8F%E3%81%8C%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%80%8C%E6%AD%A3%E8%A7%A3%E3%80%8D%E3%83%9C%E3%82%BF%E3%83%B3%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%EF%BC%81%3CBR%20%2F%3E%20-----------------------------------------------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-359971%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Re%3A%20Question%20On%20MMA7660%20Offset%20Calibration%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-359971%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%20x%20%E8%BB%B8%E3%80%81y%20%E8%BB%B8%E3%80%81z%20%E8%BB%B8%E3%81%AE%E5%82%BE%E3%81%8D%E8%A7%92%E5%BA%A6%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%9F%E3%81%84%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%20%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%22%3Ereg00%20%E3%81%8C%2022%20%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E4%BB%8A%E5%BA%A6%E3%81%AF%20x%20%E8%BB%B8%E8%A7%92%E5%BA%A6%E3%81%8C%200%20%C2%B0%20%E3%81%A7%E3%81%82%E3%82%8B%E3%81%A8%E8%80%83%E3%81%88%E3%82%89%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EMMA7660%20%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%80%8C%E4%BB%98%E9%8C%B2%20C%20-%20MMA7660FC%20%E5%8F%96%E5%BE%97%E3%82%B3%E3%83%BC%E3%83%89%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%80%8D%E3%81%AE%E7%90%86%E8%A7%A3%E6%96%B9%E6%B3%95%E3%80%816%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E7%B5%90%E6%9E%9C%E3%81%8C%2022%20-%2042%20%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AE%E8%A7%92%E5%BA%A6%20X%20%E3%81%BE%E3%81%9F%E3%81%AF%20Y%20%E3%81%AE%E7%A9%BA%E7%99%BD%E3%81%AE%E6%84%8F%E5%91%B3%E3%80%82%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22SH_RESERVED%22%20style%3D%22color%3A%20%230000ff%3B%22%3E%E6%B5%AE%E5%8B%95%E5%B0%8F%E6%95%B0%E7%82%B9%3C%2FSPAN%3ETILT_XY%5B%20%3CSPAN%20class%3D%22SH_BUILTIN%22%20style%3D%22color%3A%20%23ff0000%3B%22%3E64%3C%2FSPAN%3E%20%5D%20%3D%20%7B%20%3CSPAN%20class%3D%22SH_BUILTIN%22%3E0%3C%2FSPAN%3E%20%2C%20%3CSPAN%20class%3D%22SH_BUILTIN%22%3E2.69%3C%2FSPAN%3E%20%2C%20%3CSPAN%20class%3D%22SH_BUILTIN%22%3E5.38%3C%2FSPAN%3E%20%2C%20%3CSPAN%20class%3D%22SH_BUILTIN%22%3E8.08%3C%2FSPAN%3E%20%2C%20%3CSPAN%20class%3D%22SH_BUILTIN%22%3E10.81%3C%2FSPAN%3E%20%2C%20%3CSPAN%20class%3D%22SH_BUILTIN%22%3E13.55%3C%2FSPAN%3E%20%2C%20%3CSPAN%20class%3D%22SH_BUILTIN%22%3E16.33%3C%2FSPAN%3E%20%2C%20%3CSPAN%20class%3D%22SH_BUILTIN%22%3E19.16%3C%2FSPAN%3E%20%2C%20%3CSPAN%20class%3D%22SH_BUILTIN%22%3E22.02%3C%2FSPAN%3E%20%2C%20%3CSPAN%20class%3D%22SH_BUILTIN%22%3E24.95%3C%2FSPAN%3E%20%2C%20%3CSPAN%20class%3D%22SH_BUILTIN%22%3E27.95%3C%2FSPAN%3E%20%2C%20%3CSPAN%20class%3D%22SH_BUILTIN%22%3E31.04%3C%2FSPAN%3E%20%2C%3CSPAN%20class%3D%22SH_BUILTIN%22%3E34.23%E3%80%8137.54%E3%80%8141.01%E3%80%8144.68%E3%80%8148.59%E3%80%8152.83%E3%80%8157.54%E3%80%8162.95%E3%80%8169.64%E3%80%8179.86%E3%80%810%E3%80%810%E3%80%810%E3%80%810%E3%80%810%E3%80%810%E3%80%810%E3%80%810%E3%80%810%E3%80%810%E3%80%810%E3%80%810%E3%80%810%E3%80%810%E3%80%810%E3%80%810%E3%80%810%E3%80%810%E3%80%810%E3%80%810%E3%80%810%E3%80%810%E3%80%810%E3%80%810%E3%80%810%E3%80%810%E3%80%810%E3%80%810%E3%80%810%E3%80%810%E3%80%810%E3%80%810%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22SH_BUILTIN%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22SH_BUILTIN%22%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22SH_BUILTIN%22%3E-79.86%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22SH_BUILTIN%22%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22SH_BUILTIN%22%3E-69.64%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22SH_BUILTIN%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22SH_BUILTIN%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22SH_BUILTIN%22%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22SH_BUILTIN%22%3E-62.95%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%22%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22SH_BUILTIN%22%3E-57.54%3C%2FSPAN%3E%20%E3%80%81%20%3CSPAN%20class%3D%22SH_BUILTIN%22%3E-52.83%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22SH_BUILTIN%22%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22SH_BUILTIN%22%3E-48.59%3C%2FSPAN%3E%3CSPAN%20class%3D%22SH_BUILTIN%22%3E%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22SH_BUILTIN%22%3E%E3%80%81%3C%2FSPAN%3E%20-44.68%20%3CSPAN%20class%3D%22SH_BUILTIN%22%3E%E3%80%81%3C%2FSPAN%3E%3CSPAN%20class%3D%22SH_BUILTIN%22%3E%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22SH_BUILTIN%22%3E-41.01%3C%2FSPAN%3E%20%E3%80%81%20%3CSPAN%20class%3D%22SH_BUILTIN%22%3E-37.54%3C%2FSPAN%3E%20%E3%80%81%20-34.23%3CSPAN%20class%3D%22SH_BUILTIN%22%3E%E2%80%8B%3C%2FSPAN%3E%3CSPAN%20class%3D%22SH_BUILTIN%22%3E%E2%80%8B%3C%2FSPAN%3E%3CSPAN%20class%3D%22SH_BUILTIN%22%3E%E2%80%8B%3C%2FSPAN%3E%3CSPAN%20class%3D%22SH_BUILTIN%22%3E%E2%80%8B%3C%2FSPAN%3E%3CSPAN%20class%3D%22SH_BUILTIN%22%3E%E2%80%8B%3C%2FSPAN%3E%3CSPAN%20class%3D%22SH_BUILTIN%22%3E%E2%80%8B%3C%2FSPAN%3E%3CSPAN%20class%3D%22SH_BUILTIN%22%3E%E2%80%8B%3C%2FSPAN%3E%3CSPAN%20class%3D%22SH_BUILTIN%22%3E%E2%80%8B%3C%2FSPAN%3E%3CSPAN%20class%3D%22SH_BUILTIN%22%3E%E2%80%8B%3C%2FSPAN%3E%3CSPAN%20class%3D%22SH_BUILTIN%22%3E%E2%80%8B%3C%2FSPAN%3E%3CSPAN%20class%3D%22SH_BUILTIN%22%3E%E2%80%8B%3C%2FSPAN%3E%3CSPAN%20class%3D%22SH_BUILTIN%22%3E%E2%80%8B%3C%2FSPAN%3E%3CSPAN%20class%3D%22SH_BUILTIN%22%3E%E2%80%8B%3C%2FSPAN%3E%3CSPAN%20class%3D%22SH_BUILTIN%22%3E%E2%80%8B%3C%2FSPAN%3E%3CSPAN%20class%3D%22SH_BUILTIN%22%3E%E2%80%8B%3C%2FSPAN%3E%3CSPAN%20class%3D%22SH_BUILTIN%22%3E%E2%80%8B%3C%2FSPAN%3E%3CSPAN%20class%3D%22SH_BUILTIN%22%3E%E2%80%8B%3C%2FSPAN%3E%3CSPAN%20class%3D%22SH_BUILTIN%22%3E%E2%80%8B%3C%2FSPAN%3E%3CSPAN%20class%3D%22SH_BUILTIN%22%3E%E2%80%8B%3C%2FSPAN%3E%3CSPAN%20class%3D%22SH_BUILTIN%22%3E%E2%80%8B%3C%2FSPAN%3E%20%E3%80%81%20%3CSPAN%20class%3D%22SH_BUILTIN%22%3E-31.04%3C%2FSPAN%3E%20%E3%80%81%20%3CSPAN%20class%3D%22SH_BUILTIN%22%3E-27.95%3C%2FSPAN%3E%20%E3%80%81%20%3CSPAN%20class%3D%22SH_BUILTIN%22%3E-24.95%3C%2FSPAN%3E%20%E3%80%81%20%3CSPAN%20class%3D%22SH_BUILTIN%22%3E-22.02%3C%2FSPAN%3E%20%E3%80%81%20%3CSPAN%20class%3D%22SH_BUILTIN%22%3E-19.16%3C%2FSPAN%3E%20%E3%80%81%20%3CSPAN%20class%3D%22SH_BUILTIN%22%3E-16.33%3C%2FSPAN%3E%20%E3%80%81%20%3CSPAN%20class%3D%22SH_BUILTIN%22%3E-13.55%3C%2FSPAN%3E%20%E3%80%81%20%3CSPAN%20class%3D%22SH_BUILTIN%22%3E-10.81%3C%2FSPAN%3E%20%E3%80%81%20%3CSPAN%20class%3D%22SH_BUILTIN%22%3E-8.08%3C%2FSPAN%3E%20%E3%80%81%20%3CSPAN%20class%3D%22SH_BUILTIN%22%3E-5.38%3C%2FSPAN%3E%20%E3%80%81%20%3CSPAN%20class%3D%22SH_BUILTIN%22%3E-2.69%3C%2FSPAN%3E%20%7D%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eint%20%E3%83%A1%E3%82%A4%E3%83%B3()%3C%2FP%3E%3CP%3E%7B%3C%2FP%3E%3CP%3E%E7%AC%A6%E5%8F%B7%E3%81%AA%E3%81%97char%20x%3B%3C%2FP%3E%3CP%3E%E3%83%95%E3%83%AD%E3%83%BC%E3%83%88%E8%A7%92%E5%BA%A6X%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%2F%2F%3CSPAN%20class%3D%22SH_COMMENT%22%20style%3D%22color%3A%20%23008000%3B%22%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22SH_COMMENT%22%20style%3D%22color%3A%20%23008000%3B%22%3E%3CSPAN%20class%3D%22SH_COMMENT%22%20style%3D%22color%3A%20%23008000%3B%22%3E%2F%2F%20reg00%20%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Ex%20%3D%20MMA7660_GetResult(%20%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%22%3Ereg00%3C%2FSPAN%3E%20)%3B%3C%2FP%3E%3CP%3E%2F%2F%20%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3EX%E8%BB%B8%E3%81%AE%E8%A7%92%E5%BA%A6%E3%82%92%E5%8F%96%E5%BE%97%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23008000%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%22%3E%E8%A7%92%E5%BA%A6X%20%3D%20TILT_XY%5B%20%3CSPAN%20style%3D%22color%3A%20%23ff0000%3B%22%3Ex%3C%2FSPAN%3E%20%5D%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%7D%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-359970%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Question%20On%20MMA7660%20Offset%20Calibration%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-359970%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A3%E8%A7%A3%E3%81%A7%E3%81%99%E3%80%82%20%3CSPAN%20style%3D%22color%3A%20black%3B%22%3E%E3%80%8C(64%E5%9B%9E%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E5%90%88%E8%A8%88)%2F64%E3%80%8D%E3%81%AF%E3%80%81REG00%E3%81%AE64%E5%9B%9E%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%AE%E5%B9%B3%E5%9D%87%E5%80%A4%E3%82%92%E5%8F%96%E5%BE%97%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E7%AD%89%E3%81%97%E3%81%84%E3%81%A7%E3%81%99%EF%BC%88X_Shift%E3%81%AE%E4%BE%8B%EF%BC%89%E3%80%82%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81%3C%2FSPAN%3E%E3%81%9F%E3%81%A8%E3%81%88%E3%81%B0%E3%80%81X_Shift%E3%81%AFREG00%E3%82%9264%E5%9B%9E%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%80%81*-2%E3%81%AE%E5%B9%B3%E5%9D%87%E5%80%A4%E3%81%AE%E7%B5%90%E6%9E%9C%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%82%82%E8%80%83%E3%81%88%E3%82%89%E3%82%8C%E3%81%BE%E3%81%99%3A%3C%2FP%3E%3CP%3EX_Shift%20%3D%20(REG00%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E5%9B%9E%E6%95%B064%E5%9B%9E%E3%81%AE%E5%90%88%E8%A8%88)%2F64*-2%3C%2FP%3E%3CP%3EY_Shift%20%3D%20(REG01%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E5%9B%9E%E6%95%B064%E5%9B%9E%E3%81%AE%E5%90%88%E8%A8%88)%2F64*-2%3C%2FP%3E%3CP%3EZ_Shift%20%3D%20((REG02%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E5%9B%9E%E6%95%B064%E5%9B%9E%E3%81%AE%E5%90%88%E8%A8%88)%2F64-21)*-2%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%A7%E6%84%8F%E5%91%B3%E3%81%8C%E5%88%86%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%EF%BC%9F%E3%81%9D%E3%82%8C%E3%81%A7%E3%82%82%E4%B8%8D%E6%98%8E%E3%81%AA%E7%82%B9%E3%81%8C%E3%81%82%E3%82%8C%E3%81%B0%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E3%81%99%E3%81%A6%E3%81%8D%E3%81%AA%E4%B8%80%E6%97%A5%E3%82%92%E3%80%81%3CBR%20%2F%3E%E3%83%9B%E3%82%BB%E3%83%BB%E3%83%AC%E3%82%A4%E3%82%A8%E3%82%B9%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E-----------------------------------------------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%3A%20%E3%81%93%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%A7%E8%B3%AA%E5%95%8F%E3%81%8C%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%80%8C%E6%AD%A3%E8%A7%A3%E3%80%8D%E3%83%9C%E3%82%BF%E3%83%B3%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%EF%BC%81%3CBR%20%2F%3E%20-----------------------------------------------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E
