Pressure sensor selection
2,051件の閲覧回数
jeffrickard
I'd like help selection an air pressure sensor chip for a new product. I'll give a summary of our requirements here:
- Size: Not critical, but we're looking for a PCB-mount chip to measure the air pressure at the chip.
- Pressure range: Normal ambient pressures at normal ground altitudes.
- Operating temperature range: Preferably at least 0-60 Celsius.
- Interface: For design simplicity, an I2C or SPI interface would be highly desirable.
- Sample rate: We need accurate data at about 10Hz, so allowing for noise I expect we need about 100Hz or higher.
- Voltage: Preferably 3.3V, but we can probably design around 1.8V or 5V.
- Power: Fairly important, preferably in the Milliampere range, but we can make allowances for more power if necessary.
- Cost: Around a couple of dollars per chip.
- Accuracy: This is critical. We do not need absolute accuracy or temperature stability, but we need to accurately measure pressure differences over a period of seconds with a resolution of 1Pa (0.001 kPa). We're well aware that this will be beyond the specifications of any chip we choose, but I believe that over a period of seconds with no need for temperature stability or stability over longer periods of time, and appropriately filtering the data to remove noise, we should be able to achieve a 1Pa resolution for measuring pressure difference at about a 10Hz rate.
2 返答(返信)
1,901件の閲覧回数
TomasVaverka
Hello Jeff,
Thank you for your interest in NXP pressure sensors.
Based on your requirements, I would recommend considering the MPL3115A2.
- Size: 3 x 5 x 1.25mm 8-pin LGA package
- Calibrated pressure range: 50kPa to 110kPa absolute pressure
- Operating temperature range: −40°C to +85°C
- Interface: I2C only
- Sample rate: Depending on OS[2:0] bits, more in Table 46 of MPL3115 datasheet
- Voltage: 3.3V is OK (1.95V – 3.6V)
- Power: Depending on OS[2:0] bits, more in Table 6 of MPL3115 datasheet, the max current during acquisition and conversion is 2mA
- Cost: 1K @ US$1.69
- Accuracy/Resolution: Depending on OS[2:0] bits, theoretically 1.5Pa @ max OS[2:0] = 0b111, a quick test on my desk:
To evaluate the MPL3115A2, we can offer a complete demo kit, an Arduino/Freedom compatible shield board or just a breakout board - MPL3115A2 Pressure Sensor Development Boards|NXP.
If you have any further questions, please let me know.
Tomas
PS: If my answer helps to solve your question, please mark it as "Correct". Thank you.
1,901件の閲覧回数
jeffrickard
Hi Tomas,
Thanks for your help. I'll order a couple, attach it to our current
prototype, and see how it performs. Based on the datasheet it looks like
the accuracy may only just manage to fit our requirements - a bit faster
and a bit more accurate would be better - but there's a good chance that in
real-world conditions we'll have more problems with accuracy due to the
housing (porting, vibration) than due to the sensor. We'll soon find out!
Jeff
On 19 September 2016 at 12:20, TomasVaverka <[email protected]>
%3CLINGO-SUB%20id%3D%22lingo-sub-626900%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9C%A7%E5%8A%9B%E3%82%BB%E3%83%B3%E3%82%B5%E3%81%AE%E9%81%B8%E6%8A%9E%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-626900%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3E%E6%96%B0%E8%A3%BD%E5%93%81%E7%94%A8%E3%81%AE%E7%A9%BA%E6%B0%97%E5%9C%A7%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%83%81%E3%83%83%E3%83%97%E3%81%AE%E9%81%B8%E6%8A%9E%E3%82%92%E6%89%8B%E4%BC%9D%E3%81%A3%E3%81%A6%E3%81%BB%E3%81%97%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%81%93%E3%81%A7%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AE%E8%A6%81%E4%BB%B6%E3%82%92%E8%A6%81%E7%B4%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E-%20%E3%82%B5%E3%82%A4%E3%82%BA%3A%20%E9%87%8D%E8%A6%81%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E3%83%81%E3%83%83%E3%83%97%E3%81%AE%E7%A9%BA%E6%B0%97%E5%9C%A7%E3%82%92%E6%B8%AC%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%20PCB%20%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%20%E3%83%81%E3%83%83%E3%83%97%E3%82%92%E6%8E%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E-%20%E5%9C%A7%E5%8A%9B%E7%AF%84%E5%9B%B2%3A%20%E9%80%9A%E5%B8%B8%E3%81%AE%E5%9C%B0%E4%B8%8A%E9%AB%98%E5%BA%A6%E3%81%AB%E3%81%8A%E3%81%91%E3%82%8B%E9%80%9A%E5%B8%B8%E3%81%AE%E5%91%A8%E5%9B%B2%E5%9C%A7%E5%8A%9B%E3%80%82%3C%2FP%3E%3CP%3E-%20%E5%8B%95%E4%BD%9C%E6%B8%A9%E5%BA%A6%E7%AF%84%E5%9B%B2%3A%20%E5%B0%91%E3%81%AA%E3%81%8F%E3%81%A8%E3%82%82%200%20%EF%BD%9E%2060%20%E2%84%83%20%E3%81%8C%E6%9C%9B%E3%81%BE%E3%81%97%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E-%20%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%3A%20%E8%A8%AD%E8%A8%88%E3%82%92%E7%B0%A1%E7%B4%A0%E5%8C%96%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81I2C%20%E3%81%BE%E3%81%9F%E3%81%AF%20SPI%20%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%8C%E9%9D%9E%E5%B8%B8%E3%81%AB%E6%9C%9B%E3%81%BE%E3%81%97%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%80%82%3C%2FP%3E%3CP%3E-%20%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%20%E3%83%AC%E3%83%BC%E3%83%88%3A%20%E7%B4%84%2010Hz%20%E3%81%AE%E6%AD%A3%E7%A2%BA%E3%81%AA%E3%83%87%E3%83%BC%E3%82%BF%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AA%E3%81%AE%E3%81%A7%E3%80%81%E3%83%8E%E3%82%A4%E3%82%BA%E3%82%92%E8%80%83%E6%85%AE%E3%81%99%E3%82%8B%E3%81%A8%E7%B4%84%20100Hz%20%E4%BB%A5%E4%B8%8A%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AB%E3%81%AA%E3%82%8B%E3%81%A8%E4%BA%88%E6%83%B3%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E-%20%E9%9B%BB%E5%9C%A7%3A%203.3V%20%E3%81%8C%E6%9C%9B%E3%81%BE%E3%81%97%E3%81%84%E3%81%A7%E3%81%99%E3%81%8C%E3%80%811.8V%20%E3%81%BE%E3%81%9F%E3%81%AF%205V%20%E7%A8%8B%E5%BA%A6%E3%81%A7%E8%A8%AD%E8%A8%88%E3%81%A7%E3%81%8D%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E-%20%E9%9B%BB%E5%8A%9B%3A%20%E3%81%8B%E3%81%AA%E3%82%8A%E9%87%8D%E8%A6%81%E3%81%A7%E3%80%81%E3%83%9F%E3%83%AA%E3%82%A2%E3%83%B3%E3%83%9A%E3%82%A2%E3%81%AE%E7%AF%84%E5%9B%B2%E3%81%8C%E6%9C%9B%E3%81%BE%E3%81%97%E3%81%84%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E5%BF%85%E8%A6%81%E3%81%AB%E5%BF%9C%E3%81%98%E3%81%A6%E3%81%95%E3%82%89%E3%81%AB%E9%AB%98%E3%81%84%E9%9B%BB%E5%8A%9B%E3%82%92%E8%80%83%E6%85%AE%E3%81%AB%E5%85%A5%E3%82%8C%E3%82%8B%E3%81%93%E3%81%A8%E3%82%82%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E-%20%E3%82%B3%E3%82%B9%E3%83%88%3A%20%E3%83%81%E3%83%83%E3%83%97%201%20%E5%80%8B%E3%81%82%E3%81%9F%E3%82%8A%E7%B4%84%202%20%E3%83%89%E3%83%AB%E3%80%82%3C%2FP%3E%3CP%3E-%20%E6%AD%A3%E7%A2%BA%E3%81%95%3A%20%E3%81%93%E3%82%8C%E3%81%AF%E9%9D%9E%E5%B8%B8%E3%81%AB%E9%87%8D%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%E7%B5%B6%E5%AF%BE%E7%9A%84%E3%81%AA%E7%B2%BE%E5%BA%A6%E3%82%84%E6%B8%A9%E5%BA%A6%E5%AE%89%E5%AE%9A%E6%80%A7%E3%81%AF%E5%BF%85%E8%A6%81%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%811Pa%20(0.001%20kPa)%20%E3%81%AE%E5%88%86%E8%A7%A3%E8%83%BD%E3%81%A7%E6%95%B0%E7%A7%92%E9%96%93%E3%81%AE%E5%9C%A7%E5%8A%9B%E5%B7%AE%E3%82%92%E6%AD%A3%E7%A2%BA%E3%81%AB%E6%B8%AC%E5%AE%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%8C%E9%81%B8%E6%8A%9E%E3%81%99%E3%82%8B%E3%83%81%E3%83%83%E3%83%97%E3%81%AE%E4%BB%95%E6%A7%98%E3%82%92%E8%B6%85%E3%81%88%E3%82%8B%E3%82%82%E3%81%AE%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E9%87%8D%E3%80%85%E6%89%BF%E7%9F%A5%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E6%B8%A9%E5%BA%A6%E5%AE%89%E5%AE%9A%E6%80%A7%E3%82%84%E9%95%B7%E6%99%82%E9%96%93%E5%AE%89%E5%AE%9A%E6%80%A7%E3%82%92%E5%BF%85%E8%A6%81%E3%81%A8%E3%81%9B%E3%81%9A%E3%80%81%E6%95%B0%E7%A7%92%E9%96%93%E3%81%A7%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E9%81%A9%E5%88%87%E3%81%AB%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BF%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%97%E3%81%A6%E3%83%8E%E3%82%A4%E3%82%BA%E3%82%92%E9%99%A4%E5%8E%BB%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%80%81%E7%B4%84%2010Hz%20%E3%81%AE%E9%80%9F%E5%BA%A6%E3%81%A7%E5%9C%A7%E5%8A%9B%E5%B7%AE%E3%82%92%E6%B8%AC%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%201Pa%20%E3%81%AE%E8%A7%A3%E5%83%8F%E5%BA%A6%E3%82%92%E9%81%94%E6%88%90%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%A8%E8%80%83%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-626900%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E5%9C%A7%E5%8A%9B%E3%82%BB%E3%83%B3%E3%82%B5%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-626902%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Pressure%20sensor%20selection%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-626902%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%83%88%E3%83%BC%E3%83%9E%E3%82%B9%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%94%E5%8D%94%E5%8A%9B%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E6%B3%A8%E6%96%87%E3%81%97%E3%81%A6%E3%80%81%E7%8F%BE%E5%9C%A8%E3%81%AE%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%AD%E3%83%88%E3%82%BF%E3%82%A4%E3%83%97%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%A6%E3%80%81%E3%83%91%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%B3%E3%82%B9%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%81%AB%E3%82%88%E3%82%8B%E3%81%A8%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E7%B2%BE%E5%BA%A6%E3%81%AF%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AE%E8%A6%81%E4%BB%B6%E3%82%92%E6%BA%80%E3%81%9F%E3%81%99%E7%A8%8B%E5%BA%A6%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%AA%E3%81%84%E3%81%8C%E3%80%81%E5%B0%91%E3%81%97%E9%80%9F%E3%81%84%3C%2FP%3E%3CP%3E%E3%82%82%E3%81%86%E5%B0%91%E3%81%97%E6%AD%A3%E7%A2%BA%E3%81%A7%E3%81%82%E3%82%8C%E3%81%B0%E3%82%82%E3%81%A3%E3%81%A8%E8%89%AF%E3%81%84%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%3C%2FP%3E%3CP%3E%E7%8F%BE%E5%AE%9F%E4%B8%96%E7%95%8C%E3%81%AE%E7%8A%B6%E6%B3%81%E3%81%A7%E3%81%AF%E3%80%81%E7%B2%BE%E5%BA%A6%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%95%E3%82%89%E3%81%AB%E5%A4%A7%E3%81%8D%E3%81%8F%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%BB%E3%83%B3%E3%82%B5%E3%81%AB%E3%82%88%E3%82%8B%E3%82%82%E3%81%AE%E3%82%88%E3%82%8A%E3%82%82%E3%83%8F%E3%82%A6%E3%82%B8%E3%83%B3%E3%82%B0%EF%BC%88%E3%83%9D%E3%83%BC%E3%83%88%E3%80%81%E6%8C%AF%E5%8B%95%EF%BC%89%E3%81%AB%E3%82%88%E3%82%8B%E3%82%82%E3%81%AE%E3%81%AE%E6%96%B9%E3%81%8C%E5%A4%A7%E3%81%8D%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%E3%81%99%E3%81%90%E3%81%AB%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%82%88%EF%BC%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%B8%E3%82%A7%E3%83%95%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E2016%E5%B9%B49%E6%9C%8819%E6%97%A5%2012%3A20%E3%80%81TomasVaverka%20%3CADMIN%3E%3C%2FADMIN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-626901%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Pressure%20sensor%20selection%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-626901%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%82%B8%E3%82%A7%E3%83%95%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ENXP%20%E5%9C%A7%E5%8A%9B%E3%82%BB%E3%83%B3%E3%82%B5%E3%81%AB%E3%81%94%E8%88%88%E5%91%B3%E3%82%92%E3%81%8A%E6%8C%81%E3%81%A1%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AE%E8%A6%81%E4%BB%B6%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%80%81%20%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Fproducts%2Fsensors%2Fpressure-sensors%2Fbarometric-pressure-15-to-115-kpa%2F20-to-110kpa-absolute-digital-pressure-sensor%3AMPL3115A2%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EMPL3115A2%20%E3%82%92%3C%2FA%3E%E6%A4%9C%E8%A8%8E%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E-%20%E3%82%B5%E3%82%A4%E3%82%BA%3A%203%20x%205%20x%201.25mm%208%E3%83%94%E3%83%B3LGA%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%3C%2FP%3E%3CP%3E-%20%E6%A0%A1%E6%AD%A3%E5%9C%A7%E5%8A%9B%E7%AF%84%E5%9B%B2%EF%BC%9A50kPa%EF%BD%9E110kPa%E7%B5%B6%E5%AF%BE%E5%9C%A7%3C%2FP%3E%3CP%3E-%20%E5%8B%95%E4%BD%9C%E6%B8%A9%E5%BA%A6%E7%AF%84%E5%9B%B2%3A%20%E2%88%9240%C2%B0C%EF%BD%9E%2B85%C2%B0C%3C%2FP%3E%3CP%3E-%20%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%3A%20I2C%E3%81%AE%E3%81%BF%3C%2FP%3E%3CP%3E-%20%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%83%AC%E3%83%BC%E3%83%88%3A%20OS%5B2%3A0%5D%E3%83%93%E3%83%83%E3%83%88%E3%81%AB%E4%BE%9D%E5%AD%98%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E8%A9%B3%E7%B4%B0%E3%81%AF%3CA%20href%3D%22http%3A%2F%2Fcache.nxp.com%2Ffiles%2Fsensors%2Fdoc%2Fdata_sheet%2FMPL3115A2.pdf%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EMPL3115%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%3C%2FA%3E%E3%81%AE%E8%A1%A846%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E-%20%E9%9B%BB%E5%9C%A7%3A%203.3V%20%E3%81%AF%E6%AD%A3%E5%B8%B8%20(1.95V%20%E2%80%93%203.6V)%3C%2FP%3E%3CP%3E-%20%E9%9B%BB%E5%8A%9B%3A%20OS%5B2%3A0%5D%E3%83%93%E3%83%83%E3%83%88%E3%81%AB%E4%BE%9D%E5%AD%98%E3%81%97%E3%80%81MPL3115%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%81%AE%E8%A1%A86%E3%81%AB%E8%A9%B3%E7%B4%B0%E3%81%8C%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8C%E3%80%81%E5%8F%96%E5%BE%97%E3%81%8A%E3%82%88%E3%81%B3%E5%A4%89%E6%8F%9B%E4%B8%AD%E3%81%AE%E6%9C%80%E5%A4%A7%E9%9B%BB%E6%B5%81%E3%81%AF2mA%E3%81%A7%E3%81%82%E3%82%8B%E3%80%82%3C%2FP%3E%3CP%3E-%20%E6%96%99%E9%87%91%3A%201K%20%40%201.69%E7%B1%B3%E3%83%89%E3%83%AB%3C%2FP%3E%3CP%3E-%20%E7%B2%BE%E5%BA%A6%2F%E8%A7%A3%E5%83%8F%E5%BA%A6%3A%20OS%5B2%3A0%5D%E3%83%93%E3%83%83%E3%83%88%E3%81%AB%E4%BE%9D%E5%AD%98%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E7%90%86%E8%AB%96%E7%9A%84%E3%81%AB%E3%81%AF%E6%9C%80%E5%A4%A71.5Pa%20%40%20OS%5B2%3A0%5D%20%3D%200b111%E3%80%81%E7%A7%81%E3%81%AE%E6%9C%BA%E4%B8%8A%E3%81%A7%E3%81%AE%E7%B0%A1%E5%8D%98%E3%81%AA%E3%83%86%E3%82%B9%E3%83%88%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pressure1.JPG%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pressure1.JPG%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F6347i8E681D7551C936BB%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pressure1.JPG%22%20alt%3D%22pressure1.JPG%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EMPL3115A2%20%E3%82%92%E8%A9%95%E4%BE%A1%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E5%AE%8C%E5%85%A8%E3%81%AA%E3%83%87%E3%83%A2%20%E3%82%AD%E3%83%83%E3%83%88%E3%80%81Arduino%2FFreedom%20%E4%BA%92%E6%8F%9B%E3%81%AE%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%20%E3%83%9C%E3%83%BC%E3%83%89%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%96%E3%83%AC%E3%82%A4%E3%82%AF%E3%82%A2%E3%82%A6%E3%83%88%20%E3%83%9C%E3%83%BC%E3%83%89%20(%20%3CA%20class%3D%22link-titled%22%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Fproducts%2Fsoftware-and-tools%2Fhardware-development-tools%2Ffreedom-development-boards%2Fsensor-toolbox-development-platform-for-mpl3115a2-pressure-altimeter-sensor%3AFRDMSTBC-P3115%22%20title%3D%22http%3A%2F%2Fwww.nxp.com%2Fproducts%2Fsoftware-and-tools%2Fhardware-development-tools%2Ffreedom-development-boards%2Fsensor-toolbox-development-platform-for-mpl3115a2-pressure-altimeter-sensor%3AFRDMSTBC-P3115%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EMPL3115A2%20%E5%9C%A7%E5%8A%9B%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E9%96%8B%E7%99%BA%E3%83%9C%E3%83%BC%E3%83%89%20%7C%20NXP)%20%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BB%96%E3%81%AB%E3%81%94%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%82%89%E3%80%81%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%88%E3%83%BC%E3%83%9E%E3%82%B9%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CEM%20style%3D%22margin%3A%200px%3B%20padding%3A%200px%3B%20border%3A%200px%3B%20font-weight%3A%20normal%3B%20font-style%3A%20italic%3B%20font-size%3A%2011px%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20vertical-align%3A%20baseline%3B%20color%3A%20%2351626f%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20left%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20white-space%3A%20normal%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20line-height%3A%2019.03px%3B%20background-color%3A%20%23ffffff%3B%22%3E%E8%BF%BD%E4%BC%B8%3A%20%E7%A7%81%E3%81%AE%E5%9B%9E%E7%AD%94%E3%81%8C%E8%B3%AA%E5%95%8F%E3%81%AE%E8%A7%A3%E6%B1%BA%E3%81%AB%E5%BD%B9%E7%AB%8B%E3%81%A3%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%80%8C%E6%AD%A3%E8%A7%A3%E3%80%8D%E3%81%A8%E3%83%9E%E3%83%BC%E3%82%AF%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%82%3C%2FEM%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
