Oversampling - FXOS8700CQ
ekalyvio
What exactly is Oversampling Rate (OSR)? If for example I set an ODR of 100 Hz for the magnetometer at an OSR=7, does this mean that the magnetometer will gather 16 samples, process them somehow and of all these 16 samples will return 1 as an output? What kind of processing is happening? (eg. Is it used any kind of averaging function?) Is oversampling having some kind of latency in the data (meaning that for a movement, we have some kind of hysteresis until we detect it)?
Thank you very much
Labels (2)
TomasVaverka
Hello Efthymios,
The OSR determines the number of averaged samples. As you correctly stated, at an ODR of 100Hz and OSR = 7, 16 samples are gathered (the sampling rate is actually 1600Hz) and averaged. Table 203 summarizes all eight oversampling options which trade-off between resolution and current consumption at varying sample rates.
Tomas
%3CLINGO-SUB%20id%3D%22lingo-sub-703009%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EOversampling%20-%20FXOS8700CQ%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-703009%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EWhat%20exactly%20is%20Oversampling%20Rate%20(OSR)%3F%20If%20for%20example%20I%20set%20an%20ODR%20of%20100%20Hz%20for%20the%20magnetometer%20at%20an%20OSR%3D7%2C%20does%20this%20mean%20that%20the%20magnetometer%20will%20gather%2016%20samples%2C%20process%20them%20somehow%20and%20of%20all%20these%2016%20samples%20will%20return%201%20as%20an%20output%3F%20What%20kind%20of%20processing%20is%20happening%3F%20(eg.%20Is%20it%20used%20any%20kind%20of%20averaging%20function%3F)%20Is%20oversampling%20having%20some%20kind%20of%20latency%20in%20the%20data%20(meaning%20that%20for%20a%20movement%2C%20we%20have%20some%20kind%20of%20hysteresis%20until%20we%20detect%20it)%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThank%20you%20very%20much%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-703009%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EAccelerometers%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EMagnetic%20Sensors%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-703010%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Oversampling%20-%20FXOS8700CQ%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-703010%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20Efthymios%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThe%20OSR%20determines%20the%20number%20of%20averaged%20samples.%20As%20you%20correctly%20stated%2C%20at%20an%20ODR%20of%20100Hz%20and%20OSR%20%3D%207%2C%2016%20samples%20are%20gathered%20(the%20sampling%20rate%20is%20actually%201600Hz)%20and%20averaged.%20Table%20203%20summarizes%20all%20eight%20oversampling%20options%20which%20trade-off%20between%20resolution%20and%20current%20consumption%20at%20varying%20sample%20rates.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Table%20203.JPG%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Table%20203.JPG%22%20style%3D%22width%3A%20668px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F30099i72C6056FC6579D6A%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Table%20203.JPG%22%20alt%3D%22Table%20203.JPG%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBest%20regards%2C%3C%2FP%3E%3CP%3ETomas%3C%2FP%3E%3C%2FLINGO-BODY%3E
