MXP2300DT1 with Arduino
2,843 次查看
anniemm
I am doing a very basic project that integrates the sensor MXP2300DT1 with Arduino Adafruit feather M0 WiFI. On the Arduino IDE, I found only one library named: PRESSUREMPXNXP  which only defines the MPX500 series sensors. My question is:  Do you know if I can use this same library for the MXP2300DT1? Or is it any other library I can use?
Thanks is advance!
3 回复数
2,116 次查看
youthconnect
Because of my limited experience with the PRESSUREMPXNXP Arduino library, I suggest you ask your query on the official Arduino support forum.
The MXP2300DT1, on the other hand, is a non-amplified pressure sensor that produces a differential output voltage of only a few millivolts. Combining it with a differential amplifier is the standard method for increasing the single-ended output voltage. MaryKayInTouch
2,817 次查看
TomasVaverka
Hello Annie,
I am not very familiar with the PRESSUREMPXNXP Arduino library, I would recommend you to post your question on the Arduino forum.
However, the MXP2300DT1 is a non-amplified pressure sensor with a  differential output voltage in the range of few mV. It usually needs to be coupled with a differential amplifier to achieve a higher single ended output voltage.
Tomas
2,765 次查看
anniemm
Thanks for your answer. I figured out the Arduino part. But could you please tell me what would be the output of the sensor in mV for 40Kpa? Is it 3mV?
I already coupled it with an amplifier, but  I am not sure I am getting accurate data.
Do you have a recommendation for the type of amp I should use?
As of now, I have this one: https://www.amazon.com/gp/product/B07YHYSXR6/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
I set it up so 4mV ---> 2V, but when I am testing the sensor I get all sorts of random measurements and I do not have a reference of Kpa to compare.
%3CLINGO-SUB%20id%3D%22lingo-sub-1412713%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%B8%A6%20Arduino%20%E7%9A%84%20MXP2300DT1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1412713%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E5%81%9A%E4%B8%80%E4%B8%AA%E9%9D%9E%E5%B8%B8%E5%9F%BA%E6%9C%AC%E7%9A%84%E9%A1%B9%E7%9B%AE%EF%BC%8C%E5%AE%83%E5%B0%86%E4%BC%A0%E6%84%9F%E5%99%A8%20MXP2300DT1%20%E4%B8%8E%20Arduino%20Adafruit%20feather%20M0%20WiFi%20%E9%9B%86%E6%88%90%E5%9C%A8%E4%B8%80%E8%B5%B7%E3%80%82%E5%9C%A8%20Arduino%20IDE%20%E4%B8%8A%EF%BC%8C%E6%88%91%E5%8F%AA%E6%89%BE%E5%88%B0%E4%B8%80%E4%B8%AA%E5%90%8D%E4%B8%BAPRESSUREMPXNXP%20%E5%BA%93%EF%BC%8C%E5%AE%83%E5%8F%AA%E5%AE%9A%E4%B9%89%E4%BA%86%20MPX500%20%E7%B3%BB%E5%88%97%E4%BC%A0%E6%84%9F%E5%99%A8%E3%80%82%E6%88%91%E7%9A%84%E9%97%AE%E9%A2%98%E6%98%AF%20%20%E6%82%A8%E7%9F%A5%E9%81%93%E6%88%91%E6%98%AF%E5%90%A6%E5%8F%AF%E4%BB%A5%E5%B0%86%E6%AD%A4%E5%BA%93%E7%94%A8%E4%BA%8E%20MXP2300DT1%EF%BC%9F%E6%88%96%E8%80%85%E6%88%91%E8%BF%98%E8%83%BD%E4%BD%BF%E7%94%A8%E5%85%B6%E4%BB%96%E5%9B%BE%E4%B9%A6%E9%A6%86%E5%90%97%EF%BC%9F%20%3C%2FP%3E%3CP%3E%E5%85%88%E8%A1%8C%E8%87%B4%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1535310%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MXP2300DT1%20with%20Arduino%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1535310%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%94%B1%E4%BA%8E%E6%88%91%E4%BD%BF%E7%94%A8%20PRESSUREMPXNXP%20Arduino%20%E5%BA%93%E7%9A%84%E7%BB%8F%E9%AA%8C%E6%9C%89%E9%99%90%EF%BC%8C%E6%88%91%E5%BB%BA%E8%AE%AE%E6%82%A8%E5%9C%A8%20Arduino%20%E5%AE%98%E6%96%B9%E6%94%AF%E6%8C%81%E8%AE%BA%E5%9D%9B%E4%B8%8A%E6%8F%90%E5%87%BA%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%E5%8F%A6%E4%B8%80%E6%96%B9%E9%9D%A2%EF%BC%8CMXP2300DT1%20%E6%98%AF%E4%B8%80%E7%A7%8D%E9%9D%9E%E6%94%BE%E5%A4%A7%E5%8E%8B%E5%8A%9B%E4%BC%A0%E6%84%9F%E5%99%A8%EF%BC%8C%E5%AE%83%E4%BA%A7%E7%94%9F%E7%9A%84%E5%B7%AE%E5%88%86%E8%BE%93%E5%87%BA%E7%94%B5%E5%8E%8B%E5%8F%AA%E6%9C%89%E5%87%A0%E6%AF%AB%E4%BC%8F%E3%80%82%E5%B0%86%E5%85%B6%E4%B8%8E%E5%B7%AE%E5%88%86%E6%94%BE%E5%A4%A7%E5%99%A8%E7%9B%B8%E7%BB%93%E5%90%88%E6%98%AF%E6%8F%90%E9%AB%98%E5%8D%95%E7%AB%AF%E8%BE%93%E5%87%BA%E7%94%B5%E5%8E%8B%E7%9A%84%E6%A0%87%E5%87%86%E6%96%B9%E6%B3%95%E3%80%82%3CA%20href%3D%22https%3A%2F%2Fmarykayintouch.pics%2F%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EMaryKayInTouch%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1419319%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MXP2300DT1%20with%20Arduino%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1419319%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E7%AD%94%E3%80%82%E6%88%91%E6%83%B3%E5%87%BA%E4%BA%86%20Arduino%20%E7%9A%84%E9%83%A8%E5%88%86%E3%80%82%E4%BD%86%E8%83%BD%E5%90%A6%E8%AF%B7%E6%82%A8%E5%91%8A%E8%AF%89%E6%88%91%EF%BC%8C%E5%9C%A8%2040Kpa%20%E5%8E%8B%E5%8A%9B%E4%B8%8B%EF%BC%8C%E4%BC%A0%E6%84%9F%E5%99%A8%E7%9A%84%E8%BE%93%E5%87%BA%E5%8D%95%E4%BD%8D%E6%98%AF%E5%A4%9A%E5%B0%91%E6%AF%AB%E4%BC%8F%EF%BC%9F%E6%98%AF%203mV%20%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E5%B0%86%E5%AE%83%E4%B8%8E%E6%94%BE%E5%A4%A7%E5%99%A8%E8%80%A6%E5%90%88%EF%BC%8C%E4%BD%86%E6%88%91%E4%B8%8D%E7%A1%AE%E5%AE%9A%E6%98%AF%E5%90%A6%E8%83%BD%E8%8E%B7%E5%BE%97%E5%87%86%E7%A1%AE%E7%9A%84%E6%95%B0%E6%8D%AE%E3%80%82%3C%2FP%3E%3CP%3E%E5%AF%B9%E4%BA%8E%E6%88%91%E5%BA%94%E8%AF%A5%E4%BD%BF%E7%94%A8%E7%9A%84%E6%94%BE%E5%A4%A7%E5%99%A8%E7%B1%BB%E5%9E%8B%EF%BC%8C%E6%82%A8%E6%9C%89%E4%BB%80%E4%B9%88%E5%BB%BA%E8%AE%AE%E5%90%97%EF%BC%9F%20%3C%2FP%3E%3CP%3E%E7%9B%AE%E5%89%8D%EF%BC%8C%E6%88%91%E6%9C%89%E8%BF%99%E6%A0%B7%E4%B8%80%E4%B8%AA%3CA%20href%3D%22https%3A%2F%2Fwww.amazon.com%2Fgp%2Fproduct%2FB07YHYSXR6%2Fref%3Dppx_yo_dt_b_asin_title_o00_s00%3Fie%3DUTF8%26amp%3Bpsc%3D1%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%EF%BC%9A%20https%3A%2F%2Fwww.amazon.com%2Fgp%2Fproduct%2FB07YHYSXR6%2Fref%3Dppx_yo_dt_b_asin_title_o00_s00%3Fie%3DUTF8%26amp%3B%3C%2FA%3Epsc%3D1%3C%2FP%3E%3CP%3E%E6%88%91%E6%8A%8A%E5%AE%83%E8%AE%BE%E7%BD%AE%E4%B8%BA%204mV--%26gt%3B%202V%EF%BC%8C%E4%BD%86%E6%98%AF%E5%BD%93%E6%88%91%E6%B5%8B%E8%AF%95%E4%BC%A0%E6%84%9F%E5%99%A8%E6%97%B6%EF%BC%8C%E6%88%91%E4%BC%9A%E5%BE%97%E5%88%B0%E5%90%84%E7%A7%8D%E5%90%84%E6%A0%B7%E7%9A%84%E9%9A%8F%E6%9C%BA%E6%B5%8B%E9%87%8F%E7%BB%93%E6%9E%9C%EF%BC%8C%E8%80%8C%E4%B8%94%E6%88%91%E6%B2%A1%E6%9C%89%20Kpa%20%E7%9A%84%E5%8F%82%E8%80%83%E5%80%BC%E5%8F%AF%E4%BB%A5%E6%AF%94%E8%BE%83%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1413070%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MXP2300DT1%20with%20Arduino%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1413070%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E5%AE%89%E5%A6%AE%E3%80%81%3C%2FP%3E%0A%3CP%3E%E6%88%91%E5%AF%B9%20PRESSUREMPXNXP%20Arduino%20%E5%BA%93%E4%B8%8D%E6%98%AF%E5%BE%88%E7%86%9F%E6%82%89%EF%BC%8C%E5%BB%BA%E8%AE%AE%E6%82%A8%E5%9C%A8%20Arduino%20%E8%AE%BA%E5%9D%9B%E4%B8%8A%E6%8F%90%E9%97%AE%E3%80%82%3C%2FP%3E%0A%3CP%3E%E7%84%B6%E8%80%8C%EF%BC%8CMXP2300DT1%20%E6%98%AF%E4%B8%80%E7%A7%8D%E9%9D%9E%E6%94%BE%E5%A4%A7%E5%8E%8B%E5%8A%9B%E4%BC%A0%E6%84%9F%E5%99%A8%EF%BC%8C%E5%85%B6%E5%B7%AE%E5%88%86%E8%BE%93%E5%87%BA%E7%94%B5%E5%8E%8B%E8%8C%83%E5%9B%B4%E4%B8%BA%E5%87%A0%20mV%E3%80%82%E5%AE%83%E9%80%9A%E5%B8%B8%E9%9C%80%E8%A6%81%E4%B8%8E%E5%B7%AE%E5%88%86%E6%94%BE%E5%A4%A7%E5%99%A8%E8%80%A6%E5%90%88%EF%BC%8C%E4%BB%A5%E8%8E%B7%E5%BE%97%E6%9B%B4%E9%AB%98%E7%9A%84%E5%8D%95%E7%AB%AF%E8%BE%93%E5%87%BA%E7%94%B5%E5%8E%8B%E3%80%82%3C%2FP%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3E%E6%89%98%E9%A9%AC%E6%96%AF%3C%2FP%3E%3C%2FLINGO-BODY%3E
