MPXV7007 diff pressure sensor issues
lachlanpedersen
I am trying to use a MPXV7007 differential pressure sensor controlled  by an Arduino UNO microcontroller. When I connect the sensor with style 2 from the data sheet including the suggested decoupling circuit and provide Vs with 5v, I get a reading of about 4.95v from Vout. This does not make sense as with no differential pressure I should get the minimum 0.5v at Vout. When I tried connecting another sensor as style 1 I did not get any reading between Vout+ and Vout- so I assume it needs to be style 2. Any help would be much appreciated, Thanks!
Joshevelle
Senior Contributor I
Lachlan,
Most likely the sensor is already damaged due to the incorrect wring connections.
-Josh
Joshevelle
Hello Lachlan,
Please disregard the "Styles" shown in the datasheet, the correct pinout is in page 3, figure 1:
http://cache.freescale.com/files/sensors/doc/data_sheet/MPXV7007.pdf
Hope it helps.
Josh
lachlanpedersen
Thanks for the quick reply.
I have the sensor configured with the pinout on page 3 with:
Vs - 2
GND - 3
Vout - 4
But I am still getting a high voltage readout (4.95v) when there is nothing connected to the two sensing ports. I have a gauge pressure sensor of the same package hooked up the same way and it is giving me a reasonable readout of 0.2v with nothing connected and responds to pressure changes. I don't understand why the two are acting differently or why I am getting such a high voltage at Vout.
Joshevelle
Lachlan,
-Josh
%3CLINGO-SUB%20id%3D%22lingo-sub-331065%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMPXV7007%20diff%20pressure%20sensor%20issues%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-331065%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20am%20trying%20to%20use%20a%20MPXV7007%20differential%20pressure%20sensor%20controlled%26nbsp%3B%20by%20an%20Arduino%20UNO%20microcontroller.%20When%20I%20connect%20the%20sensor%20with%20style%202%20from%20the%20data%20sheet%20including%20the%20suggested%20decoupling%20circuit%20and%20provide%20Vs%20with%205v%2C%20I%20get%20a%20reading%20of%20about%204.95v%20from%20Vout.%20This%20does%20not%20make%20sense%20as%20with%20no%20differential%20pressure%20I%20should%20get%20the%20minimum%200.5v%20at%20Vout.%20When%20I%20tried%20connecting%20another%20sensor%20as%20style%201%20I%20did%20not%20get%20any%20reading%20between%20Vout%2B%20and%20Vout-%20so%20I%20assume%20it%20needs%20to%20be%20style%202.%20Any%20help%20would%20be%20much%20appreciated%2C%20Thanks!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-331065%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EPressure%20Sensors%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-331068%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPXV7007%20diff%20pressure%20sensor%20issues%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-331068%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ELachlan%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EMost%20likely%20the%20sensor%20is%20already%20damaged%20due%20to%20the%20incorrect%20wring%20connections.%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E-Josh%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-331067%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPXV7007%20diff%20pressure%20sensor%20issues%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-331067%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThanks%20for%20the%20quick%20reply.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20have%20the%20sensor%20configured%20with%20the%20pinout%20on%20page%203%20with%3A%3CBR%20%2F%3EVs%20-%202%3CBR%20%2F%3EGND%20-%203%3CBR%20%2F%3EVout%20-%204%3C%2FP%3E%3CP%3EBut%20I%20am%20still%20getting%20a%20high%20voltage%20readout%20(4.95v)%20when%20there%20is%20nothing%20connected%20to%20the%20two%20sensing%20ports.%20I%20have%20a%20gauge%20pressure%20sensor%20of%20the%20same%20package%20hooked%20up%20the%20same%20way%20and%20it%20is%20giving%20me%20a%20reasonable%20readout%20of%200.2v%20with%20nothing%20connected%20and%20responds%20to%20pressure%20changes.%20I%20don't%20understand%20why%20the%20two%20are%20acting%20differently%20or%20why%20I%20am%20getting%20such%20a%20high%20voltage%20at%20Vout.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-331066%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPXV7007%20diff%20pressure%20sensor%20issues%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-331066%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20Lachlan%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EPlease%20disregard%20the%20%22Styles%22%20shown%20in%20the%20datasheet%2C%20the%20correct%20pinout%20is%20in%20page%203%2C%20figure%201%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fcache.freescale.com%2Ffiles%2Fsensors%2Fdoc%2Fdata_sheet%2FMPXV7007.pdf%22%20title%3D%22http%3A%2F%2Fcache.freescale.com%2Ffiles%2Fsensors%2Fdoc%2Fdata_sheet%2FMPXV7007.pdf%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fcache.freescale.com%2Ffiles%2Fsensors%2Fdoc%2Fdata_sheet%2FMPXV7007.pdf%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EHope%20it%20helps.%3C%2FP%3E%3CP%3EJosh%3C%2FP%3E%3C%2FLINGO-BODY%3E
