MPX5010DP reading error/accuracy
bruno_najder
I have MPX5010DP pressure sensor. What is the accuracy/error?
Here is the datasheet:
https://www.nxp.com/docs/en/data-sheet/MPX5010.pdf
Is this 5% of a reading (so it changes and is bigger for bigger readings) or is it 5% of VFSS (Voltage of Full Scale Span) which is 5% of 4.5V for 5V supply (so the error is the same for all readings). There is also error from transfer function depending on temperature and pressure. So should I add these 3 errors so I can obtain information on reading accuracy or choose one of the 3? It's written so unclearly
I've got this equation
Vout=Vs x (0.09 X P +0.04) +/- 5% Vfss
So total error should I calculate from pressure value error(bigger with bigger readings) and  vfss error(constant)? Or that +/- 5% Vfss is the only error (and we have only constant reading error)? Or should I should I just assume total error equal +/-5% of a reading (bigger with bigger readings)?
Tags (2)
TomasVaverka
Hi Bruno,
The worst accuracy is +/- 5% of Vfss, which is +/- 0.225V for a 5V supply.
So the transfer function for a 5V supply and temperature from 0°C to +85°C is:
Vout = 5 x (0.09 x P + 0.04) +/- 0.225V
Tomas
%3CLINGO-SUB%20id%3D%22lingo-sub-948247%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMPX5010DP%20reading%20error%2Faccuracy%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-948247%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3EI%20have%20MPX5010DP%20pressure%20sensor.%20What%20is%20the%20accuracy%2Ferror%3F%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3EHere%20is%20the%20datasheet%3A%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttps%253A%252F%252Fwww.nxp.com%252Fdocs%252Fen%252Fdata-sheet%252FMPX5010.pdf%22%20style%3D%22color%3A%20%232989c5%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20text-decoration%3A%20none%3B%20padding%3A%200px%20calc(12px%20%2B%200.35ex)%200px%200px%3B%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fdata-sheet%2FMPX5010.pdf%3C%2FA%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3EIs%20this%205%25%20of%20a%20reading%20(so%20it%20changes%20and%20is%20bigger%20for%20bigger%20readings)%20or%20is%20it%205%25%20of%20VFSS%20(Voltage%20of%20Full%20Scale%20Span)%20which%20is%205%25%20of%204.5V%20for%205V%20supply%20(so%20the%20error%20is%20the%20same%20for%20all%20readings).%20There%20is%20also%20error%20from%20transfer%20function%20depending%20on%20temperature%20and%20pressure.%20So%20should%20I%20add%20these%203%20errors%20so%20I%20can%20obtain%20information%20on%20reading%20accuracy%20or%20choose%20one%20of%20the%203%3F%20It's%20written%20so%20unclearly%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3EI've%20got%20this%20equation%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3EVout%3DVs%20x%20(0.09%20X%20P%20%2B0.04)%20%2B%2F-%205%25%20Vfss%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3ESo%20total%20error%20should%20I%20calculate%20from%20pressure%20value%20error(bigger%20with%20bigger%20readings)%20and%26nbsp%3B%20vfss%20error(constant)%3F%20Or%20that%20%2B%2F-%205%25%20Vfss%20is%20the%20only%20error%20(and%20we%20have%20only%20constant%20reading%20error)%3F%20Or%20should%20I%20should%20I%20just%20assume%20total%20error%20equal%20%2B%2F-5%25%20of%20a%20reading%20(%3CSPAN%3Ebigger%20with%20bigger%20readings)%3F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-948247%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EPressure%20Sensors%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-948248%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPX5010DP%20reading%20error%2Faccuracy%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-948248%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Bruno%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThe%20worst%20accuracy%20is%20%2B%2F-%205%25%20of%20Vfss%2C%20which%20is%20%2B%2F-%200.225V%20for%20a%205V%20supply.%26nbsp%3B%3C%2FP%3E%3CP%3ESo%20the%20transfer%20function%20for%20a%205V%20supply%20and%20temperature%20from%200%3CSPAN%3E%C2%B0C%3C%2FSPAN%3E%20to%20%2B85%C2%B0C%20is%3A%26nbsp%3B%3C%2FP%3E%3CP%3EVout%20%3D%205%20x%20(0.09%20x%20P%20%2B%200.04)%20%2B%2F-%200.225V%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBest%20regards%2C%3C%2FP%3E%3CP%3ETomas%3C%2FP%3E%3C%2FLINGO-BODY%3E
