MPX5010DP offset and sensitivity strange values
jlvassent
I have a MPX5010DP pressure sensor connected to an Arduino Uno.
Pin 1 (with the mark) on the MPX5010DP is connected to Pin A0, Pin 2 is connected to Ground and Pin 3 to 5V on the Arduino.
Without any pressure applied, the offset value is about 1.58 V.
The sensitivity is about 2.43 mV/mm H2O. These values does not match the datasheet values : 0.2 V for the offset, 4.413 mV/mm H2O for the sensitivity.
I can't see anything wrong with my setup.
Has anyone ever observed this kind of problem?
ErikaC
These devices are very sensitive. To ensure optimal performance, we recommend implementing auto-zero according to the application note linked below:
Implementing Auto-Zero for Integrated Pressure Sensors
Hope this helps.
ErikaC
Hope this helps.
%3CLINGO-SUB%20id%3D%22lingo-sub-1939305%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3EMPX5010DP%20offset%20and%20sensitivity%20strange%20values%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1939305%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3EI%20have%20a%20MPX5010DP%20pressure%20sensor%20connected%20to%20an%20Arduino%20Uno.%3CBR%20%2F%3EPin%201%20(with%20the%20mark)%20on%20the%26nbsp%3BMPX5010DP%20is%20connected%20to%20Pin%20A0%2C%20Pin%202%20is%20connected%20to%20Ground%20and%20Pin%203%20to%205V%20on%20the%20Arduino.%26nbsp%3B%3CBR%20%2F%3EWithout%20any%20pressure%20applied%2C%20the%20offset%20value%20is%20about%201.58%20V.%3CBR%20%2F%3EThe%20sensitivity%20is%20about%202.43%20mV%2Fmm%20H2O.%20These%20values%20does%20not%20match%20the%20datasheet%20values%20%3A%200.2%20V%20for%20the%20offset%2C%204.413%20mV%2Fmm%20H2O%20for%20the%20sensitivity.%3CBR%20%2F%3EI%20can't%20see%20anything%20wrong%20with%20my%20setup.%3C%2FP%3E%3CP%3EHas%20anyone%20ever%20observed%20this%20kind%20of%20problem%3F%3C%2FP%3E%3CP%3EThanks%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1939305%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CLINGO-LABEL%3EPressure%20Sensors%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1940673%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20MPX5010DP%20offset%20and%20sensitivity%20strange%20values%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1940673%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%0A%3CP%3EThese%20devices%20are%20very%20sensitive.%20To%20ensure%20optimal%20performance%2C%20we%20recommend%20implementing%20auto-zero%20according%20to%20the%20application%20note%20linked%20below%3A%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN1636.pdf%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EImplementing%20Auto-Zero%20for%20Integrated%20Pressure%20Sensors%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EHope%20this%20helps.%3C%2FP%3E%3C%2FLINGO-BODY%3E
