MPX2102AP AND MPX2102GP
ZIMO
原设计了一款适合于AP系列的压力传感器电路,利用它输出的两个电压的压差去计算压力,现在想直接用GP系列去替换,电路上不做任何修改,现在发现输出的压差很小,电路设计上无法满足。然后想问下,GP在使用电路设计上与AP系列有什么区别,也是利用它的两个输出压差去作为压力计算吗?
guoweisun
Hi ZIMO
请看他们的区别:
The differential voltage output of the sensor is directly
proportional to the differential pressure applied.
The absolute sensor has a built-in reference vacuum. The
output voltage will decrease as vacuum, relative to ambient,
is drawn on the pressure (P1) side.
The output voltage of the differential or gauge sensor
increases with increasing pressure applied to the pressure
希望能帮到您!
多谢!
ZIMO
在电路使用上呢,比如说我将传感器输出的两个电压先放大,在相减,如果不考虑代码上的差异,电路上有需要修改的地方吗
guoweisun
请看你的新的ticket回复的:
Re: HOW TO USE THE MPX2202GP - NXP Community
%3CLINGO-SUB%20id%3D%22lingo-sub-2006445%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3Empx2102ap%20and%20mpx2102gp%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2006445%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EI%20designed%20a%20pressure%20sensor%20circuit%20for%20the%20AP%20series%20and%20used%20the%20difference%20between%20its%20two%20output%20voltages%20to%20calculate%20pressure%2C%20but%20now%20I%20want%20to%20replace%20it%20with%20the%20GP%20series%20without%20any%20modification%20to%20the%20circuit%2C%20and%20now%20I%20realize%20that%20the%20output%20pressure%20difference%20is%20so%20small%20that%20the%20circuit%20design%20is%20not%20satisfactory.%20Then%20I%20would%20like%20to%20ask%2C%20what%20is%20the%20difference%20between%20the%20GP%20and%20AP%20series%20in%20terms%20of%20circuit%20design%2C%20and%20is%20it%20also%20utilizing%20the%20difference%20between%20its%20two%20output%20voltages%20for%20pressure%20calculation%3F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2008785%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPX2102AP%20AND%20MPX2102GP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2008785%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3EPlease%20see%20your%20new%20ticket%20reply's%3A%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FSensors%2FHOW-TO-USE-THE-MPX2202GP%2Fm-p%2F2007931%23M8599%22%20target%3D%22_blank%22%3ERe%3A%20HOW%20TO%20USE%20THE%20MPX2202GP%20-%20NXP%20Community%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2006837%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPX2102AP%20AND%20MPX2102GP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2006837%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3EWhat%20about%20circuit%20usage%2C%20for%20example%2C%20if%20I%20amplify%20the%20two%20voltages%20from%20the%20sensor%20output%20and%20subtract%20them%20in%20phase%2C%20are%20there%20any%20modifications%20that%20need%20to%20be%20made%20to%20the%20circuit%20without%20taking%20into%20account%20the%20differences%20in%20code%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2006776%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPX2102AP%20AND%20MPX2102GP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2006776%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20ZIMO%3C%2FP%3E%0A%3CP%3ESee%20the%20difference%20between%20them%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22guoweisun_0-1733299405727.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22guoweisun_0-1733299405727.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F313970i6C2DDB5D72EDD8F4%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22guoweisun_0-1733299405727.png%22%20alt%3D%22guoweisun_0-1733299405727.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EThe%20differential%20voltage%20output%20of%20the%20sensor%20is%20directly%20%3CBR%20%2F%3Eproportional%20to%20the%20differential%20pressure%20applied.%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3EThe%20absolute%20sensor%20has%20a%20built-in%20reference%20vacuum.%20The%20%3CBR%20%2F%3Eoutput%20voltage%20will%20decrease%20as%20vacuum%2C%20relative%20to%20ambient%2C%20%3CBR%20%2F%3Eis%20drawn%20on%20the%20pressure%20(P1)%20side.%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3EThe%20output%20voltage%20of%20the%20differential%20or%20gauge%20sensor%20%3CBR%20%2F%3Eincreases%20with%20increasing%20pressure%20applied%20to%20the%20pressure%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EI%20hope%20this%20helps!%3C%2FP%3E%0A%3CP%3EThanks%20a%20lot!%3C%2FP%3E%3C%2FLINGO-BODY%3E
