HI,
I am using MPR121 touch controller. It is taking 10 seconds time to detect touch, while GPIO control is happening immediate after power on. I din't see anywhere in datasheet about start up time for MPR121 to detect touch.
Is there possibility to reduce this 10 seconds time by changing some config ??
已解决! 转到解答。
Hi Chaitanya,
This initial delay is caused by a large time constant of the baseline tracking filtering system. To reduce it, set both the CL (0x5E register) and BVA (0x7B register) bits to 0b10 or 0b11.
I hope it helps.
Tomas
PS: If my answer helps to solve your question, please mark it as "Correct" or “Helpful”. Thank you.
Hi Chaitanya,
I hope it helps.
Tomas
