MPR121 PCB Layout
MPR121 PCB Layout
2dom
Hi all,
I created what I thought is a very simple design of a MPR121 touch button matrix. But for some reason I cannot get it to register any touches. Any help would be highly appreciated. (See board and schematics attached)
Dom
2dom
I am using the standard arduino mpr121 library with auto configuration and some debug output:
08:36:16.760 -> send soft reset.. 08:36:16.760 - read: MPR121_CONFIG2 24
08:36:16.760 - write Configuration to sensor ...
08:36:16.826 - MPR121 found!
08:36:16.924 - Initial CDC/CDT values:
08:36:16.924 - ========================================
08:36:16.924 - CHAN 00 01 02 03 04 05 06 07 08 09 10 11
08:36:16.924 - -- -- -- -- -- -- -- -- -- -- -- --
08:36:16.924 - CDC: 0 0 0 0 0 0 0 0 0 0 0 0
08:36:16.924 - CDT: 0 0 0 0 0 0 0 0 0 0 0 0
TomasVaverka
Hello Dominic,
The MPR121 is no longer manufactured and supported by NXP.
Resurgent Semiconductor (Flip Electronics) has received the manufacturing rights for the MPR121 and I recommend reaching out to their technical support:
https://www.flipelectronics.com/Product/MPR121QR2-53295
Thank you for your understanding.
BRs, Tomas
2dom
Thanks for letting me know. I think I found the problem - the MPR121 appears to be rather sensitive to high soldering temperatures. The hot air gun simply cooked the chip. Using a temperature controlled hot plate for soldering did the trick.
%3CLINGO-SUB%20id%3D%22lingo-sub-2173052%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMPR121%20PCB%20Layout%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2173052%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20all%2C%3C%2FP%3E%3CP%3EI%20created%20what%20I%20thought%20is%20a%20very%20simple%20design%20of%20a%20MPR121%20touch%20button%20matrix.%20But%20for%20some%20reason%20I%20cannot%20get%20it%20to%20register%20any%20touches.%20Any%20help%20would%20be%20highly%20appreciated.%20(See%20board%20and%20schematics%20attached)%3C%2FP%3E%3CP%3EDom%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2173052%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3ETouch%20Sensors%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2176113%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPR121%20PCB%20Layout%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2176113%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThanks%20for%20letting%20me%20know.%20I%20think%20I%20found%20the%20problem%20-%26nbsp%3Bthe%20MPR121%20appears%20to%20be%20rather%20sensitive%20to%20high%20soldering%20temperatures.%20The%20hot%20air%20gun%20simply%20cooked%20the%20chip.%20Using%20a%20temperature%20controlled%20hot%20plate%20for%20soldering%20did%20the%20trick.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2173327%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPR121%20PCB%20Layout%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2173327%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20Dominic%2C%3C%2FP%3E%0A%3CP%3EThe%20MPR121%20is%20no%20longer%20manufactured%20and%20supported%20by%20NXP.%3C%2FP%3E%0A%3CP%3EResurgent%20Semiconductor%20(Flip%20Electronics)%20has%20received%20the%20manufacturing%20rights%20for%20the%20MPR121%20and%20I%20recommend%20reaching%20out%20to%20their%20technical%20support%3A%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fwww.flipelectronics.com%2FProduct%2FMPR121QR2-53295%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.flipelectronics.com%2FProduct%2FMPR121QR2-53295%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EThank%20you%20for%20your%20understanding.%3C%2FP%3E%0A%3CP%3EBRs%2C%20Tomas%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2173060%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPR121%20PCB%20Layout%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2173060%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20am%20using%20the%20standard%20arduino%20mpr121%20library%20with%20auto%20configuration%20and%20some%20debug%20output%3A%3C%2FP%3E%3CP%3E08%3A36%3A16.760%20-%26gt%3B%20send%20soft%20reset..%2008%3A36%3A16.760%20-%20read%3A%20MPR121_CONFIG2%2024%3CBR%20%2F%3E08%3A36%3A16.760%20-%20write%20Configuration%20to%20sensor%20...%3CBR%20%2F%3E08%3A36%3A16.826%20-%20MPR121%20found!%3CBR%20%2F%3E08%3A36%3A16.924%20-%20Initial%20CDC%2FCDT%20values%3A%3CBR%20%2F%3E08%3A36%3A16.924%20-%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3CBR%20%2F%3E08%3A36%3A16.924%20-%20CHAN%2000%2001%2002%2003%2004%2005%2006%2007%2008%2009%2010%2011%3CBR%20%2F%3E08%3A36%3A16.924%20-%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%20--%3CBR%20%2F%3E08%3A36%3A16.924%20-%20CDC%3A%200%200%200%200%200%200%200%200%200%200%200%200%3CBR%20%2F%3E08%3A36%3A16.924%20-%20CDT%3A%200%200%200%200%200%200%200%200%200%200%200%200%3CBR%20%2F%3E08%3A36%3A16.924%20-%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FP%3E%3C%2FLINGO-BODY%3E
