MPR121 Autoconfiguration
ソリューションへジャンプ
3,812件の閲覧回数
markthedark
I have some questions about the MPR121 Touch Sensor Auto configuration sequence that is not explained well in the Reference Manual or Application Notes.
1. What is the purpose of the Target Level register?
2. How can I tell when the Auto-complete sequence is complete?
3. Is there source code or a flow chart of how the Auto-complete should be coded?
Thanks in advance.
2,945件の閲覧回数
Joshevelle
Hello Mark,
I noticed that you entered SR#1-948472563 for this inquiry and we already sent you a response.
However, I thought that the suggested initialization code might be useful for you:
#define TouchThre 10   //15//30//10
#define ReleaThre 6   //8//25//8
void MPR121_init(void)
  //Reset MPR121 if not reset correctly
  IIC_ByteWrite(0x80,0x63);  //Soft reset
  IIC_ByteWrite(0x5E,0x00);  //Stop mode
  //touch pad baseline filter
  //rising
  IIC_ByteWrite(0x2B,0x01); // MAX HALF DELTA Rising
  IIC_ByteWrite(0x2C,0x01); // NOISE HALF DELTA Rising
  IIC_ByteWrite(0x2D,0x0E); // NOISE COUNT LIMIT Rising
  IIC_ByteWrite(0x2E,0x00); // DELAY LIMIT Rising
  //falling
  IIC_ByteWrite(0x2F,0x01); // MAX HALF DELTA Falling
  IIC_ByteWrite(0x30,0x05); // NOISE HALF DELTA Falling
  IIC_ByteWrite(0x31,0x01); // NOISE COUNT LIMIT Falling
  IIC_ByteWrite(0x32,0x00); // DELAY LIMIT Falling
  //touched
  IIC_ByteWrite(0x33,0x00); // Noise half delta touched
  IIC_ByteWrite(0x34,0x00); // Noise counts touched
  IIC_ByteWrite(0x35,0x00); // Filter delay touched
  //Touch pad threshold
  IIC_ByteWrite(0x41,TouchThre); // ELE0 TOUCH THRESHOLD
  IIC_ByteWrite(0x42,ReleaThre); // ELE0 RELEASE THRESHOLD
  IIC_ByteWrite(0x43,TouchThre); // ELE1 TOUCH THRESHOLD
  IIC_ByteWrite(0x44,ReleaThre); // ELE1 RELEASE THRESHOLD
  IIC_ByteWrite(0x45,TouchThre); // ELE2 TOUCH THRESHOLD
  IIC_ByteWrite(0x46,ReleaThre); // ELE2 RELEASE THRESHOLD
  IIC_ByteWrite(0x47,TouchThre); // ELE3 TOUCH THRESHOLD
  IIC_ByteWrite(0x48,ReleaThre); // ELE3 RELEASE THRESHOLD
  IIC_ByteWrite(0x49,TouchThre); // ELE4 TOUCH THRESHOLD
  IIC_ByteWrite(0x4A,ReleaThre); // ELE4 RELEASE THRESHOLD
  IIC_ByteWrite(0x4B,TouchThre); // ELE5 TOUCH THRESHOLD
  IIC_ByteWrite(0x4C,ReleaThre); // ELE5 RELEASE THRESHOLD
  IIC_ByteWrite(0x4D,TouchThre); // ELE6 TOUCH THRESHOLD
  IIC_ByteWrite(0x4E,ReleaThre); // ELE6 RELEASE THRESHOLD
  IIC_ByteWrite(0x4F,TouchThre); // ELE7 TOUCH THRESHOLD
  IIC_ByteWrite(0x50,ReleaThre); // ELE7 RELEASE THRESHOLD
  IIC_ByteWrite(0x51,TouchThre); // ELE8 TOUCH THRESHOLD
  IIC_ByteWrite(0x52,ReleaThre); // ELE8 RELEASE THRESHOLD
  IIC_ByteWrite(0x53,TouchThre); // ELE9 TOUCH THRESHOLD
  IIC_ByteWrite(0x54,ReleaThre); // ELE9 RELEASE THRESHOLD
  IIC_ByteWrite(0x55,TouchThre); // ELE10 TOUCH THRESHOLD
  IIC_ByteWrite(0x56,ReleaThre); // ELE10 RELEASE THRESHOLD
  IIC_ByteWrite(0x57,TouchThre); // ELE11 TOUCH THRESHOLD
  IIC_ByteWrite(0x58,ReleaThre); // ELE11 RELEASE THRESHOLD
  //touch /release debounce
  IIC_ByteWrite(0x5B,0x00);
  // response time = SFI(10) X ESI(8ms) = 80ms
  IIC_ByteWrite(0x5D,0x13);
  //FFI=18
  IIC_ByteWrite(0x5C,0x80);
  //Auto configuration
  IIC_ByteWrite(0x7B,0x8F);
  // charge to 70% of Vdd , high sensitivity
  IIC_ByteWrite(0x7D,0xE4);
  IIC_ByteWrite(0x7E,0x94);
  IIC_ByteWrite(0x7F,0xCD);
  // 12 electrodes enabled
  IIC_ByteWrite(0x5E,0xCC);
...hope it helps! =)
Josh
2 返答(返信)
2,945件の閲覧回数
Janosch
i would be still very interested in #2 of the original question:
Is there any way to determine, or at least to take a good guess, when the auto-calibration of the sensor is completed?
Janos
2,946件の閲覧回数
Joshevelle
Hello Mark,
  //rising
  //falling
  //touched
  //FFI=18
Josh
