MPL115A2 Coefficients
4,656 次查看
beng_
I've just started experimenting with the MPL115A2 Digital Barometer.
Maybe I’m having a bad day – but I can’t understand how to convert the Coefficient integers / binary values into numbers.
The data sheet doesn’t seem to make sense. For example a0 is defined as
a0 Signed, Integer Bits = 12, Fractional Bits = 3 : Coeff a0 = S I11 I10 I9 I8 I7 I6 I5 I4 I3 I2 I1 I0 . F2 F1 F0
Later the data sheet uses the example a0 = 0x3ECE = 2009.75
Maskign out - bits I11 to I0 gives 2009 - but the last 3 bits (the fractional bits) are 0x06 - I can't see how that taken to be 0.75?
Are there any examples of how to take these Coefficients in binary/hex form and convert them into actual numbers?
标记 (2)
4,485 次查看
TomasVaverka
Hi Ben,
As for the fractional part, F2 = 0.5, F1 = 0.25 and F0 = 0.125.
Considering our example, the fractional part is 0b110 = 1 x 0.5 + 1 x 0.25 + 0 x 0.125 = 0.75
You may find useful David's example project, have a look at MPL115A1.c file.
I hope it helps.
Tomas
4 回复数
4,486 次查看
TomasVaverka
Hi Ben,
I hope it helps.
Tomas
4,485 次查看
beng_
That works for the first Co-effeicent a0 - but not the next one b1. In the data-sheet:
0xB3F9 = -2.37585
0xB3F9 = 1011 0011 1111 1001
There's one sign bit - 1 - so the number is negative
Two Integer bits - 01 - so the integer portion is 1 (not 2 according to the datasheet)
13 Fraction bits - 1 0011 1111 1001 - (this is 0.5 + 0.0625 + 0.03125 + 0.015625 0.007815 etc...) so the integer portion is 0.62414551 (not 0.37585 according to the datasheet).
4,485 次查看
beng_
Never mind got it - there's a later note in the data sheets that says:
NOTE: Negative coefficients are coded in 2’s complement notation.
Taking the bit inverse of all bits gives me the correct answer
4,485 次查看
beng_
Ah ha - thanks - that makes sense!
%3CLINGO-SUB%20id%3D%22lingo-sub-873472%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMPL115A2%20%E7%B3%BB%E6%95%B0%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-873472%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E5%88%9A%E5%BC%80%E5%A7%8B%E8%AF%95%E7%94%A8%20MPL115A2%20%E6%95%B0%E5%AD%97%E6%B0%94%E5%8E%8B%E8%AE%A1%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%B9%9F%E8%AE%B8%E6%88%91%E4%BB%8A%E5%A4%A9%E8%BF%87%E5%BE%97%E5%BE%88%E7%B3%9F%E7%B3%95%E2%80%94%E2%80%94%E4%BD%86%E6%88%91%E4%B8%8D%E6%98%8E%E7%99%BD%E5%A6%82%E4%BD%95%E5%B0%86%E7%B3%BB%E6%95%B0%E6%95%B4%E6%95%B0%2F%E4%BA%8C%E8%BF%9B%E5%88%B6%E5%80%BC%E8%BD%AC%E6%8D%A2%E4%B8%BA%E6%95%B0%E5%AD%97%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%95%B0%E6%8D%AE%E8%A1%A8%E4%BC%BC%E4%B9%8E%E6%B2%A1%E6%9C%89%E6%84%8F%E4%B9%89%E3%80%82%E4%BE%8B%E5%A6%82%EF%BC%8Ca0%20%E7%9A%84%E5%AE%9A%E4%B9%89%E6%98%AF%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3Ea0%20%E6%9C%89%E7%AC%A6%E5%8F%B7%EF%BC%8C%E6%95%B4%E6%95%B0%E4%BD%8D%20%3D%2012%EF%BC%8C%E5%B0%8F%E6%95%B0%E4%BD%8D%20%3D%203%20%3A%20Coeff%20a0%20%3D%20S%3CSPAN%20style%3D%22font-size%3A%2011px%3B%22%3EI11%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011px%3B%22%3EI10%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011px%3B%22%3EI9%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011px%3B%22%3EI8%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011px%3B%22%3EI7%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011px%3B%22%3EI6%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011px%3B%22%3EI5%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011px%3B%22%3EI4%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011px%3B%22%3EI3%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011px%3B%22%3EI2%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011px%3B%22%3EI1%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011px%3B%22%3EI0%3C%2FSPAN%3E.%3CSPAN%20style%3D%22font-size%3A%2011px%3B%22%3EF2%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011px%3B%22%3EF1%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2011px%3B%22%3EF0%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%9A%8F%E5%90%8E%EF%BC%8C%E6%95%B0%E6%8D%AE%E8%A1%A8%E4%BD%BF%E7%94%A8%E4%BA%86%20a0%20%3D%200x3ECE%20%3D%202009.75%20%E7%9A%84%E7%A4%BA%E4%BE%8B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%B1%8F%E8%94%BD%E6%8E%89%20-%3CSPAN%20style%3D%22font-size%3A%2011px%3B%22%3EI11%3C%2FSPAN%3E%E8%87%B3%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-size%3A%2011px%3B%22%3EI0%3C%2FSPAN%3E%E4%BD%8D%E4%B8%BA%202009%20-%20%E4%BD%86%E6%9C%80%E5%90%8E%203%20%E4%BD%8D%EF%BC%88%E5%B0%8F%E6%95%B0%E4%BD%8D%EF%BC%89%E4%B8%BA%200x06%20-%20%E6%88%91%E4%B8%8D%E6%98%8E%E7%99%BD%E8%BF%99%E6%80%8E%E4%B9%88%E4%BC%9A%E6%98%AF%200.75%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%9C%89%E6%B2%A1%E6%9C%89%E4%BE%8B%E5%AD%90%E8%AF%B4%E6%98%8E%E5%A6%82%E4%BD%95%E5%B0%86%E8%BF%99%E4%BA%9B%E7%B3%BB%E6%95%B0%E4%BB%A5%E4%BA%8C%E8%BF%9B%E5%88%B6%2F%E5%8D%81%E5%85%AD%E8%BF%9B%E5%88%B6%E5%BD%A2%E5%BC%8F%E8%BD%AC%E6%8D%A2%E4%B8%BA%E5%AE%9E%E9%99%85%E6%95%B0%E5%AD%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-873472%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E5%8E%8B%E5%8A%9B%E4%BC%A0%E6%84%9F%E5%99%A8%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-873476%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL115A2%20Coefficients%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-873476%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%B2%A1%E5%85%B3%E7%B3%BB%EF%BC%8C%E6%88%91%E5%B7%B2%E7%BB%8F%E6%8B%BF%E5%88%B0%E4%BA%86%20-%20%E6%95%B0%E6%8D%AE%E8%A1%A8%E4%B8%AD%E5%90%8E%E6%9D%A5%E6%9C%89%E4%B8%80%E9%A1%B9%E8%AF%B4%E6%98%8E%EF%BC%9A%3C%2FP%3E%3CP%3E%3CEM%3E%3CSTRONG%3E%E6%B3%A8%3C%2FSTRONG%3E%EF%BC%9A%E8%B4%9F%E7%B3%BB%E6%95%B0%E7%94%A8%202%20%E7%9A%84%E8%A1%A5%E7%A0%81%E8%A1%A8%E7%A4%BA%E3%80%82%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%B1%82%E6%89%80%E6%9C%89%E6%AF%94%E7%89%B9%E7%9A%84%E6%AF%94%E7%89%B9%E5%8F%8D%EF%BC%8C%E5%B0%B1%E5%BE%97%E5%88%B0%E4%BA%86%E6%AD%A3%E7%A1%AE%E7%AD%94%E6%A1%88%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-873475%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL115A2%20Coefficients%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-873475%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%BF%99%E5%AF%B9%E7%AC%AC%E4%B8%80%E4%B8%AA%E5%85%B1%E6%98%BE%E5%AD%90%20a0%20%E6%9C%89%E6%95%88%EF%BC%8C%E4%BD%86%E5%AF%B9%E4%B8%8B%E4%B8%80%E4%B8%AA%E5%85%B1%E6%98%BE%E5%AD%90%20b1%20%E6%97%A0%E6%95%88%E3%80%82%E5%9C%A8%E6%95%B0%E6%8D%AE%E8%A1%A8%E4%B8%AD%3C%2FP%3E%3CP%3E0xB3F9%20%3D%20-2.37585%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E0xB3F9%20%3D%20%3CSTRONG%3E%3CSPAN%20style%3D%22color%3A%20%23ff00ff%3B%22%3E1%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000080%3B%22%3E01%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23339966%3B%22%3E1%200011%201111%201001%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E6%9C%89%E4%B8%80%E4%B8%AA%E7%AC%A6%E5%8F%B7%E4%BD%8D%20-%3CSTRONG%20style%3D%22color%3A%20%23ff00ff%3B%20%22%3E1%3C%2FSTRONG%3E-%20%E6%89%80%E4%BB%A5%E6%95%B0%E5%AD%97%E6%98%AF%E8%B4%9F%E6%95%B0%3C%2FP%3E%3CP%3E%E4%B8%A4%E4%B8%AA%E6%95%B4%E6%95%B0%E4%BD%8D%20-%3CSTRONG%20style%3D%22color%3A%20%23000080%3B%20%22%3E01%3C%2FSTRONG%3E-%20%E5%9B%A0%E6%AD%A4%E6%95%B4%E6%95%B0%E9%83%A8%E5%88%86%E6%98%AF%201%EF%BC%88%E6%95%B0%E6%8D%AE%E8%A1%A8%E6%98%BE%E7%A4%BA%E4%B8%8D%E6%98%AF%202%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E13%20%E4%B8%AA%E5%88%86%E6%95%B0%E4%BD%8D%20-%3CSTRONG%20style%3D%22color%3A%20%23339966%3B%20%22%3E1%200011%201111%201001%3C%2FSTRONG%3E-%20%EF%BC%88%E8%BF%99%E6%98%AF%200.5%20%2B%200.0625%20%2B%200.03125%20%2B%200.015625%200.007815%20%E7%AD%89......%EF%BC%89%EF%BC%8C%E5%9B%A0%E6%AD%A4%E6%95%B4%E6%95%B0%E9%83%A8%E5%88%86%E6%98%AF%200.62414551%EF%BC%88%E6%95%B0%E6%8D%AE%E8%A1%A8%E6%98%BE%E7%A4%BA%E4%B8%8D%E6%98%AF%200.37585%EF%BC%89%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-873474%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL115A2%20Coefficients%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-873474%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%95%8A%E5%93%88-%E8%B0%A2%E8%B0%A2-%E8%BF%99%E5%BE%88%E6%9C%89%E9%81%93%E7%90%86%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-873473%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MPL115A2%20Coefficients%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-873473%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%97%A8%EF%BC%8C%E6%9C%AC%E3%80%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%87%B3%E4%BA%8E%E5%88%86%E6%95%B0%E9%83%A8%E5%88%86%EF%BC%8CF2%20%3D%200.5%EF%BC%8CF1%20%3D%200.25%EF%BC%8CF0%20%3D%200.125%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%A5%E6%88%91%E4%BB%AC%E7%9A%84%E4%BE%8B%E5%AD%90%E4%B8%BA%E4%BE%8B%EF%BC%8C%E5%B0%8F%E6%95%B0%E9%83%A8%E5%88%86%E4%B8%BA%200b110%20%3D%201%20x%200.5%20%2B%201%20x%200.25%20%2B%200%20x%200.125%20%3D%200.75%3C%2FP%3E%3CP%3E%E6%82%A8%E5%8F%AF%E8%83%BD%E4%BC%9A%E5%8F%91%E7%8E%B0%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-335542%22%20target%3D%22_blank%22%3EDavid%20%E7%9A%84%E7%A4%BA%E4%BE%8B%E9%A1%B9%E7%9B%AE%3C%2FA%3E%E9%9D%9E%E5%B8%B8%E6%9C%89%E7%94%A8%EF%BC%8C%E8%AF%B7%E6%9F%A5%E7%9C%8B%20MPL115A1.c%E9%94%89%E5%88%80%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%B8%8C%E6%9C%9B%E5%AF%B9%E6%82%A8%E6%9C%89%E6%89%80%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3CP%3E%E6%89%98%E9%A9%AC%E6%96%AF%3C%2FP%3E%3C%2FLINGO-BODY%3E
