MMA8652FC & Transients
已解决
跳至解决方案
3,598 次查看
haroldmccabe
This accelerometer on my prototype board detects transient interrupts OK. But when I read the transient source reg (0x1E) I often see 0x00; at other times I see the event flag and other axis/polarity bits set as expected.
Why do I get a transient interrupt but the transient source reg = 0x00?
I tried setting the ELE bit in the transient config reg (0x1D) but then, once I get a transient interrupt I cannot clear it and the accelerometer interrupts continually.
My initialization is as follows:
// Reset and pause at least 1 ms
SMB_Write(&accel_write_reset); // reg 0x2B <- 0x40
stop_time = (U8)ticks + 2;
while ((U8)ticks < stop_time) ;
// Transient configuration register
SMB_Write(&accel_write_trans_cfg_reg); // reg 0x1D <- 0x1E
// Transient threshold register
SMB_Write(&accel_write_trans_thresh_reg); // reg 0x1F <- 0x90
// Time threshold (width) of transient
SMB_Write(&accel_write_trans_count_reg); // reg 0x20 <- 0x01
// Use high-pass filter
SMB_Write(&accel_write_xyz_data_config); // reg 0x0E <- 0x10
SMB_Write(&accel_write_hpf);
// Configure interrupt as open drain
SMB_Write(&accel_write_control_reg_3); // reg 0x2C <- 0x01
// Write portrait/landscape config
SMB_Write(&accel_write_pl_config); // reg 0x11 <- 0x40
// Write debounce count
SMB_Write(&accel_write_pl_count); // reg 0x12 <- 0xFF
// Take defaults for PL_BF_ZCOMP and PL_THS_REG
// Route interrupts
SMB_Write(&accel_write_control_reg_5); // reg 0x2E <- 0x30
// Enable interrupts
SMB_Write(&accel_write_control_reg_4); // reg 0x2D <- 0x30
// Write to control register 1: active, ODR, fast read mode
SMB_Write(&accel_write_control_reg_1); // reg 0x2A <- 0x0B
标签 (1)
1 解答
3,305 次查看
TomasVaverka
Hi Harold,
It looks like you have both transient and orientation interrupts enabled and routed to the same INT1 pin. Are you reading first the INT_SOURCE register to distinguish between the transient and orientation interrupt and then only an appropriate event source register (either PL_STATUS or TRANSIENT_SRC) as illustrated below?
IntSource = I2C_ReadRegister(MMA845x_I2C_ADDRESS, INT_SOURCE_REG);
if (IntSource & 0x20)      // Transient interrupt?
TransientSource = I2C_ReadRegister(MMA865x_I2C_ADDRESS, TRANSIENT_SRC_REG);     // Service and clear the transient interrupt
if (IntSource & 0x10)      // Orientation interrupt?
PLStatus = I2C_ReadRegister(MMA865x_I2C_ADDRESS, PL_STATUS_SRC);      // Service and clear the orientation interrupt
Tomas
PS: If my answer helps to solve your question, please mark it as "Correct" or “Helpful”. Thank you.
在原帖中查看解决方案
2 回复数
3,306 次查看
TomasVaverka
Hi Harold,
Tomas
3,305 次查看
haroldmccabe
Yes, both transient and orientation interrupts were enabled and going to the same pin.
I found the ELE bit in the transient config reg must be set to latch the transient axis/polarity info into the transient source reg. Otherwise the axis/polarity info may change between when the transient interrupt is asserted and when the transient source reg is read.
Earlier, I was not actually getting continual interrupts with ELE set: I was mislead by my debug setup.
Thank you, Tomas.
%3CLINGO-SUB%20id%3D%22lingo-sub-375060%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMMA8652FC%26amp%3B%20%E7%9E%AC%E6%80%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-375060%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E7%9A%84%E5%8E%9F%E5%9E%8B%E6%9D%BF%E4%B8%8A%E7%9A%84%E8%BF%99%E4%B8%AA%E5%8A%A0%E9%80%9F%E5%BA%A6%E8%AE%A1%E5%8F%AF%E4%BB%A5%E6%A3%80%E6%B5%8B%E5%88%B0%E7%9E%AC%E6%80%81%E4%B8%AD%E6%96%AD%E3%80%82%E4%BD%86%E6%98%AF%EF%BC%8C%E5%BD%93%E6%88%91%E8%AF%BB%E5%8F%96%E7%9E%AC%E6%80%81%E6%BA%90%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%880x1E%EF%BC%89%E6%97%B6%EF%BC%8C%E7%BB%8F%E5%B8%B8%E4%BC%9A%E7%9C%8B%E5%88%B0%200x00%EF%BC%9B%E8%80%8C%E5%9C%A8%E5%85%B6%E4%BB%96%E6%97%B6%E5%80%99%EF%BC%8C%E6%88%91%E7%9C%8B%E5%88%B0%E4%BA%8B%E4%BB%B6%E6%A0%87%E5%BF%97%E5%92%8C%E5%85%B6%E4%BB%96%E8%BD%B4%2F%E6%9E%81%E6%80%A7%E4%BD%8D%E5%9D%87%E6%8C%89%E9%A2%84%E6%9C%9F%E8%AE%BE%E7%BD%AE%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%B8%BA%E4%BB%80%E4%B9%88%E4%BC%9A%E5%87%BA%E7%8E%B0%E7%9E%AC%E6%97%B6%E4%B8%AD%E6%96%AD%EF%BC%8C%E4%BD%86%E7%9E%AC%E6%97%B6%E6%BA%90%E6%B3%A8%E5%86%8C%20%3D%200x00%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E8%AF%95%E7%9D%80%E5%9C%A8%E7%9E%AC%E6%80%81%E9%85%8D%E7%BD%AE%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%880x1D%EF%BC%89%E4%B8%AD%E8%AE%BE%E7%BD%AE%20ELE%20%E4%BD%8D%EF%BC%8C%E4%BD%86%E4%B8%80%E6%97%A6%E5%87%BA%E7%8E%B0%E7%9E%AC%E6%80%81%E4%B8%AD%E6%96%AD%EF%BC%8C%E5%B0%B1%E6%97%A0%E6%B3%95%E6%B8%85%E9%99%A4%E5%AE%83%EF%BC%8C%E5%8A%A0%E9%80%9F%E5%BA%A6%E8%AE%A1%E5%B0%B1%E4%BC%9A%E6%8C%81%E7%BB%AD%E4%B8%AD%E6%96%AD%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E7%9A%84%E5%88%9D%E5%A7%8B%E5%8C%96%E8%BF%87%E7%A8%8B%E5%A6%82%E4%B8%8B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%2F%2FRESET%E5%B9%B6%E6%9A%82%E5%81%9C%E8%87%B3%E5%B0%91%201%20%E6%AF%AB%E7%A7%92%3C%2FP%3E%3CP%3ESMB_Write(%26amp%3Baccel_write_reset)%3B%20%2F%2F%20reg%200x2B%26lt%3B-%200x40%3C%2FP%3E%3CP%3Estop_time%20%3D%20(U8)ticks%20%2B%202%EF%BC%9B%3C%2FP%3E%3CP%3Ewhile%20((U8)ticks%26lt%3B%20stop_time)%20%EF%BC%9B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%2F%2F%20%E7%9E%AC%E6%80%81%E9%85%8D%E7%BD%AE%E5%AF%84%E5%AD%98%E5%99%A8%3C%2FP%3E%3CP%3ESMB_Write(%26amp%3Baccel_write_trans_cfg_reg)%3B%20%2F%2F%20reg%200x1D%26lt%3B-%200x1E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%2F%2F%20%E7%9E%AC%E6%80%81%E9%98%88%E5%80%BC%E5%AF%84%E5%AD%98%E5%99%A8%3C%2FP%3E%3CP%3ESMB_Write(%26amp%3Baccel_write_trans_thresh_reg)%3B%20%2F%2F%20reg%200x1F%26lt%3B-%200x90%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%2F%2F%20%E7%9E%AC%E6%80%81%E7%9A%84%E6%97%B6%E9%97%B4%E9%98%88%E5%80%BC%EF%BC%88%E5%AE%BD%E5%BA%A6%3C%2FP%3E%3CP%3ESMB_Write(%26amp%3Baccel_write_trans_count_reg)%3B%20%2F%2F%20reg%200x20%26lt%3B-%200x01%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%2F%2F%20%E4%BD%BF%E7%94%A8%E9%AB%98%E9%80%9A%E6%BB%A4%E6%B3%A2%E5%99%A8%3C%2FP%3E%3CP%3ESMB_Write(%26amp%3Baccel_write_xyz_data_config)%3B%20%2F%2F%20reg%200x0E%26lt%3B-%200x10%3C%2FP%3E%3CP%3ESMB_Write(%26amp%3Baccel_write_hhpf)%EF%BC%9B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%2F%2F%20%E5%B0%86%E4%B8%AD%E6%96%AD%E9%85%8D%E7%BD%AE%E4%B8%BA%E6%BC%8F%E6%9E%81%E5%BC%80%E8%B7%AF%3C%2FP%3E%3CP%3ESMB_Write(%26amp%3Baccel_write_control_reg_3)%3B%20%2F%2F%20reg%200x2C%26lt%3B-%200x01%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%2F%2F%20%E5%86%99%E5%85%A5%E8%82%96%E5%83%8F%2F%E9%A3%8E%E6%99%AF%E9%85%8D%E7%BD%AE%3C%2FP%3E%3CP%3ESMB_Write(%26amp%3Baccel_write_pl_config)%3B%20%2F%2F%20reg%200x11%26lt%3B-%200x40%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%2F%2F%20%E5%86%99%E5%85%A5%E5%8E%BB%E6%8A%96%E5%8A%A8%E8%AE%A1%E6%95%B0%3C%2FP%3E%3CP%3ESMB_Write(%26amp%3Baccel_write_pl_count)%3B%20%2F%2F%20reg%200x12%26lt%3B-%200xFF%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%2F%2F%20%E9%87%87%E7%94%A8%20PL_BF_ZCOMP%20%E5%92%8C%20PL_THS_REG%20%E7%9A%84%E9%BB%98%E8%AE%A4%E5%80%BC%3C%2FP%3E%3CP%3E%2F%2F%20%E8%B7%AF%E7%94%B1%E4%B8%AD%E6%96%AD%3C%2FP%3E%3CP%3ESMB_Write(%26amp%3Baccel_write_control_reg_5)%3B%20%2F%2F%20reg%200x2E%26lt%3B-%200x30%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%2F%2F%20%E5%90%AF%E7%94%A8%E4%B8%AD%E6%96%AD%3C%2FP%3E%3CP%3ESMB_Write(%26amp%3Baccel_write_control_reg_4)%3B%20%2F%2F%20reg%200x2D%26lt%3B-%200x30%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%2F%2F%20%E5%86%99%E5%85%A5%E6%8E%A7%E5%88%B6%E5%AF%84%E5%AD%98%E5%99%A8%201%EF%BC%9A%E6%BF%80%E6%B4%BB%EF%BC%8CODR%EF%BC%8C%E5%BF%AB%E9%80%9F%E8%AF%BB%E5%8F%96%E6%A8%A1%E5%BC%8F%3C%2FP%3E%3CP%3ESMB_Write(%26amp%3Baccel_write_control_reg_1)%3B%20%2F%2F%20reg%200x2A%26lt%3B-%200x0B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-375060%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E5%8A%A0%E9%80%9F%E5%BA%A6%E4%BC%A0%E6%84%9F%E5%99%A8%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-375062%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MMA8652FC%20%26amp%3B%20Transients%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-375062%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E7%9E%AC%E6%80%81%E4%B8%AD%E6%96%AD%E5%92%8C%E5%AE%9A%E5%90%91%E4%B8%AD%E6%96%AD%E9%83%BD%E5%B7%B2%E5%90%AF%E7%94%A8%EF%BC%8C%E5%B9%B6%E8%BF%9B%E5%85%A5%E5%90%8C%E4%B8%80%E5%BC%95%E8%84%9A%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%8F%91%E7%8E%B0%E5%BF%85%E9%A1%BB%E8%AE%BE%E7%BD%AE%E7%9E%AC%E6%80%81%E9%85%8D%E7%BD%AE%E5%AF%84%E5%AD%98%E5%99%A8%E4%B8%AD%E7%9A%84%20ELE%20%E4%BD%8D%EF%BC%8C%E6%89%8D%E8%83%BD%E5%B0%86%E7%9E%AC%E6%80%81%E8%BD%B4%2F%E6%9E%81%E6%80%A7%E4%BF%A1%E6%81%AF%E9%94%81%E5%AD%98%E5%88%B0%E7%9E%AC%E6%80%81%E6%BA%90%E5%AF%84%E5%AD%98%E5%99%A8%E4%B8%AD%E3%80%82%E5%90%A6%E5%88%99%EF%BC%8C%E5%9C%A8%E9%92%B3%E4%BD%8D%E7%9E%AC%E6%80%81%E4%B8%AD%E6%96%AD%E5%92%8C%E8%AF%BB%E5%8F%96%E7%9E%AC%E6%80%81%E6%BA%90%E6%B3%A8%E5%86%8C%E8%A1%A8%E4%B9%8B%E9%97%B4%EF%BC%8C%E8%BD%B4%2F%E6%9E%81%E6%80%A7%E4%BF%A1%E6%81%AF%E5%8F%AF%E8%83%BD%E4%BC%9A%E5%8F%91%E7%94%9F%E5%8F%98%E5%8C%96%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%97%A9%E4%BA%9B%E6%97%B6%E5%80%99%EF%BC%8C%E5%9C%A8%E8%AE%BE%E7%BD%AE%E4%BA%86%20ELE%20%E5%90%8E%EF%BC%8C%E6%88%91%E5%AE%9E%E9%99%85%E4%B8%8A%E5%B9%B6%E6%B2%A1%E6%9C%89%E8%8E%B7%E5%BE%97%E6%8C%81%E7%BB%AD%E7%9A%84%E4%B8%AD%E6%96%AD%EF%BC%9A%E6%88%91%E7%9A%84%E8%B0%83%E8%AF%95%E8%AE%BE%E7%BD%AE%E8%AF%AF%E5%AF%BC%E4%BA%86%E6%88%91%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E4%BD%A0%EF%BC%8C%E6%89%98%E9%A9%AC%E6%96%AF%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-375061%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MMA8652FC%20%26amp%3B%20Transients%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-375061%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%97%A8%EF%BC%8C%E5%93%88%E7%BD%97%E5%BE%B7%E3%80%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%E7%9C%8B%E8%B5%B7%E6%9D%A5%E6%82%A8%E5%90%8C%E6%97%B6%E5%90%AF%E7%94%A8%E4%BA%86%E7%9E%AC%E6%80%81%E4%B8%AD%E6%96%AD%E5%92%8C%E5%AE%9A%E5%90%91%E4%B8%AD%E6%96%AD%EF%BC%8C%E5%B9%B6%E5%B0%86%E5%85%B6%E8%B7%AF%E7%94%B1%E5%88%B0%E5%90%8C%E4%B8%80%E4%B8%AA%20INT1%20%E5%BC%95%E8%84%9A%E3%80%82%E6%82%A8%E6%98%AF%E5%90%A6%E9%A6%96%E5%85%88%E8%AF%BB%E5%8F%96%20INT_SOURCE%20%E5%AF%84%E5%AD%98%E5%99%A8%E4%BB%A5%E5%8C%BA%E5%88%86%E7%9E%AC%E6%80%81%E4%B8%AD%E6%96%AD%E5%92%8C%E5%AE%9A%E5%90%91%E4%B8%AD%E6%96%AD%EF%BC%8C%E7%84%B6%E5%90%8E%E6%89%8D%E8%AF%BB%E5%8F%96%E9%80%82%E5%BD%93%E7%9A%84%E4%BA%8B%E4%BB%B6%E6%BA%90%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%88PL_STATUS%20%E6%88%96%20TRANSIENT_SRC%EF%BC%89%EF%BC%8C%E5%A6%82%E4%B8%8B%E5%9B%BE%E6%89%80%E7%A4%BA%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EIntSource%20%3D%20I2C_ReadRegister(MMA845x_I2C_ADDRESS%EF%BC%8CINT_SOURCE_REG)%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%3CSTRONG%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%E5%A6%82%E6%9E%9C%3C%2FSTRONG%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E(IntSource%26amp%3B%200x20)%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20%E7%9E%AC%E6%97%B6%E4%B8%AD%E6%96%AD%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-indent%3A%20.5in%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3ETransientSource%20%3D%20I2C_ReadRegister(MMA865x_I2C_ADDRESS%EF%BC%8CTRANSIENT_SRC_REG)%EF%BC%9B%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20%E6%9C%8D%E5%8A%A1%E5%B9%B6%E6%B8%85%E9%99%A4%E7%9E%AC%E6%80%81%E4%B8%AD%E6%96%AD%20%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%E5%A6%82%E6%9E%9C%3C%2FSTRONG%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E(IntSource%26amp%3B%200x10)%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20%E5%AE%9A%E5%90%91%E4%B8%AD%E6%96%AD%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-indent%3A%20.5in%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EPLStatus%20%3D%20I2C_ReadRegister(MMA865x_I2C_ADDRESS%EF%BC%8CPL_STATUS_SRC)%EF%BC%9B%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20%E6%9C%8D%E5%8A%A1%E5%B9%B6%E6%B8%85%E9%99%A4%E5%AE%9A%E5%90%91%E4%B8%AD%E6%96%AD%20%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%89%98%E9%A9%AC%E6%96%AF%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CEM%20style%3D%22font-size%3A%2013.3333320617676px%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20color%3A%20%23333333%3B%22%3E%3CSPAN%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-size%3A%2011px%3B%20font-family%3A%20inherit%3B%20color%3A%20%233d3d3d%3B%22%3E%3CEM%20style%3D%22font-weight%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3EPS%EF%BC%9A%3CSPAN%20class%3D%22Apple-converted-space%22%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CSPAN%20class%3D%22Apple-converted-space%22%3E%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-size%3A%2011px%3B%20font-family%3A%20inherit%3B%20color%3A%20%233d3d3d%3B%22%3E%E5%A6%82%E6%9E%9C%E6%88%91%E7%9A%84%E5%9B%9E%E7%AD%94%E6%9C%89%E5%8A%A9%E4%BA%8E%E8%A7%A3%E5%86%B3%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E6%A0%87%E8%AE%B0%E4%B8%BA%22%E6%AD%A3%E7%A1%AE%22%20%E6%88%96%20%22%E6%9C%89%E5%B8%AE%E5%8A%A9%22%E3%80%82%E8%B0%A2%E8%B0%A2%E3%80%82%3C%2FSPAN%3E%3C%2FEM%3E%20%3C%2FP%3E%3C%2FLINGO-BODY%3E
