MMA68XX initialization
shimasaadat
I’m new at working with MMA68xx. I work on a reverse engineering project and read the micro commands and sensor responses through a SPI interface on the other test board. The initial state commands and responses are as below:
16 Clock cycles
commands
responses
1st
0X4A00
0X0E00
2nd
0X4AC0
0X3E00
3rd
0XCA40
0X3E00
  Every command is sent in 16 -clock cycles and its response come from sensor in the next 16 clock cycles.
The first command is sent in the first 16 clock cycles according to the SPI interface the response message in this step must be 0X0000 but in first clock cycle I have a response which says Invalid register address….
Another question:
These 3 commands reset the device but to terminate the reset a read of DEVCTL register is needed (It is written in datasheet), but after these commands I can’t find this command…
reyes
Hi shima saadat,
Here is another thread from the Freescale Communities which might give you some clues.
It talks about configuring the MMA68xx.
MMA68xx initialization
And as mentioned in the communities thread: Information (hardware and source code) is available at Automotive Sensors Tower System Module Freescale
Refer driver for MMA6800.
Jose Reyes
%3CLINGO-SUB%20id%3D%22lingo-sub-367560%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMMA68XX%20initialization%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-367560%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3EI%E2%80%99m%20new%20at%20working%20with%20MMA68xx.%20I%20work%20on%20a%20reverse%20engineering%20project%20and%20read%20the%20micro%20commands%20and%20sensor%20responses%20through%20a%20SPI%20interface%20on%20the%20other%20test%20board.%20The%20initial%20state%20commands%20and%20responses%20are%20as%20below%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CTABLE%20border%3D%221%22%20cellpadding%3D%220%22%20cellspacing%3D%220%22%20style%3D%22border%3A%20none%3B%20width%3A%20638px%3B%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22214%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E16%20Clock%20cycles%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-left%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22238%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3Ecommands%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-left%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22186%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3Eresponses%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22214%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E1st%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22238%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0X4A00%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22186%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0X0E00%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22214%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E2nd%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22238%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0X4AC0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22186%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0X3E00%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22214%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E3rd%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22238%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0XCA40%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22186%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0X3E00%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%26nbsp%3B%20Every%20command%20is%20sent%20in%2016%20-clock%20cycles%20and%20its%20response%20come%20from%20sensor%20in%20the%20next%2016%20clock%20cycles.%3C%2FP%3E%3CP%3EThe%20first%20command%20is%20sent%20in%20the%20first%2016%20clock%20cycles%20according%20to%20the%20SPI%20interface%20the%20response%20message%20in%20this%20step%20must%20be%200X0000%20but%20in%20first%20clock%20cycle%20I%20have%20a%20response%20which%20says%20Invalid%20register%20address%E2%80%A6.%3C%2FP%3E%3CP%3EAnother%20question%3A%3C%2FP%3E%3CP%3EThese%203%20commands%20reset%20the%20device%20but%20to%20terminate%20the%20reset%20a%20read%20of%20DEVCTL%20register%20is%20needed%20(It%20is%20written%20in%20datasheet)%2C%20but%20after%20these%20commands%20I%20can%E2%80%99t%20find%20this%20command%E2%80%A6%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-367560%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EAccelerometers%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-367561%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MMA68XX%20initialization%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-367561%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20shima%20saadat%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EHere%20is%20another%20thread%20from%20the%20Freescale%20Communities%20which%20might%20give%20you%20some%20clues.%3C%2FP%3E%3CP%3EIt%20talks%20about%20configuring%20the%20MMA68xx.%3C%2FP%3E%3CP%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fthread%2F301952%22%20target%3D%22_blank%22%3EMMA68xx%20initialization%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EAnd%20as%20mentioned%20in%20the%20communities%20thread%3A%20Information%20(hardware%20and%20source%20code)%20is%20available%20at%20%3CA%20href%3D%22http%3A%2F%2Fwww.freescale.com%2Fwebapp%2Fsps%2Fsite%2Fprod_summary.jsp%3Fcode%3DTWR-SENSOR-PAK-AUTO%26amp%3Btid%3Dm32TWR%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%236a737b%3B%20font-style%3A%20inherit%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20'inherit'%2C'serif'%3B%20font-weight%3A%20inherit%3B%22%3EAutomotive%20Sensors%20Tower%20System%20Module%20Freescale%3C%2FSPAN%3E%3C%2FA%3E%3C%2FP%3E%3CP%3ERefer%20driver%20for%20MMA6800.%3C%2FP%3E%3CP%3E%3CBR%20%2F%3EHave%20a%20great%20day%2C%3CBR%20%2F%3EJose%20Reyes%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E-----------------------------------------------------------------------------------------------------------------------%3CBR%20%2F%3ENote%3A%20If%20this%20post%20answers%20your%20question%2C%20please%20click%20the%20Correct%20Answer%20button.%20Thank%20you!%3CBR%20%2F%3E-----------------------------------------------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E
