MC33771C CRC
MC33771C CRC
2,316 次查看
alessandro_piazza
Hi, can anyone send me sample code for crc calculation? I have some problem in generating correct crc...
2,307 次查看
TomasVaverka
Hi Alessandro,
Attached you can find the CRC calculation software implemented in our KL25Z MCU.
BR, Tomas
4 回复数
1,941 次查看
Patrick_Pavle
Hi @TomasVaverka
Why is 0x42 used as the seed value in the code? Shouldn´t it be 0FF?
2,308 次查看
TomasVaverka
Hi Alessandro,
BR, Tomas
2,295 次查看
alessandro_piazza
Hi Tomas, Thanks!
I've just tried it but it doesn't function (I used the sample messages on the datasheet to test crc result).
I think they use a different polynomial (0x2F), also seed is different.
2,292 次查看
alessandro_piazza
Hi Tomas, I'm sorry it was correct!
