Looking for NXP PART NUMBER PRESSURE GAUGE
david_oreardon
Hi Team
I'm looking for NXP part for the following product
Product INFO: SENSOR PRES 100PSI GAUG 3.3V SMT
Description : Pressure Sensor 100PSI (689.48kPa) Vented Gauge Male - 0.19" (4.93mm) Tube 12 b 8-SMD, J-Lead, Top Port
ApplicationsBoard Mount
Pressure TypeVented Gauge
Operating Pressure100PSI (689.48kPa)
Output TypeI²C
Output12 b
Accuracy±0.25%
Voltage - Supply3V ~ 3.6V
Port SizeMale - 0.19" (4.93mm) Tube
Port StyleBarbed
FeaturesAmplified Output, Temperature Compensated
Termination StyleSMD (SMT) Tab
Maximum Pressure250PSI (1723.69kPa)
Operating Temperature-40°C ~ 85°C
Package / Case8-SMD, J-Lead, Top Port
Supplier Device Package8-SMT
Any help would be appreciated
reyes
The only gauge type pressure sensors in our portfolio capable of measure pressure up to 700kPa are the MPX5700GP/MPX5700GP1 (MPX5700GP1 has 90 degree lead form).
These are single ported (male vented) sensor, but in unibody package and 0.19" (4.93mm) Tube, barbed port.
Analog output from 0.25V (@0kPa) to 4.75V (@700kPa) in linear response.
Accuracy of +/-2.5%VFss
5V supply voltage (can be supplied with 3.3V and output will be ratiometric).`
Operating temperature range from -40C to +125C
MPX5700GP datasheet: https://www.nxp.com/docs/en/data-sheet/MPX5700.pdf
Jose
NXP Semiconductors
