Having Issue with Free Fall Detection in MMA8451Q accelerometer sensor
1,984件の閲覧回数
punitchotaliya
I am using the nRF51822 MCU  and MMA8451Q Accelerometer sensor to detect free fall, I have referred Application note and I am able to detect a free fall if I drop a sensor from a particular height,  also I am getting free-fall interrupt when I tilt the sensor around X-axis.  I have also disabled free fall along the x-axis and y-axis  from FF_MD_CONFIG Register ;
I need free-fall detection only when I drop a sensor from a height, not when I tilt the sensor around the x-axis
here is my free-fall detection configuration settings
free_fall_init()
uint8_t data[2];
uint8_t temp;
//Put the device in standby mode
uint8_t CTRL_REG1 = 0x2A;
data[0]= CTRL_REG1;
data[1]= 0x20;
send(data);
//freefall/motion configuration register
uint8_t FF_MD_CONFIG = 0x15;
data[0]= FF_MD_CONFIG;
data[1]= 0xA0;
send(data);
// setting threshould
uint8_t THR_REGISTER = 0x17;
data[0]= THR_REGISTER;
data[1]= 0x03;
send(data);
// setting debounce counter
uint8_t DEBOUNCE_REGISTER = 0x18;
data[0]= DEBOUNCE_REGISTER;
data[1]= 0x06;
send(data);
// Enable motion/freefall interrupt function
uint8_t INT_ENABLE = 0x2D;
data[0]= INT_ENABLE;
data[1]=0x04;
send(data);
//Route the Motion/Freefall Interrupt to INT2 hardware pin
uint8_t INT_2 = 0x2E;
data[0]= INT_2;
data[1]= 0x00;
send(data);
//put the device in active mode
temp = read(&CTRL_REG1);
temp |= 0x01;
data[0]=CTRL_REG1;
data[1]= temp;
send(data);
here is my Interrupt handler
void Interrupt2_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action)
nrf_gpiote_event_clear(NRF_GPIOTE_EVENTS_IN_0); // clearing interrupt flag
uint8_t system_interrupt  = read(&SYSTEM_INT); // register 0x0C
status = read(&FF_STATUS); // reading FF_MD_STATUS register to enable next interrupt
dropped = 0x01;
accelerometer_dropped_update(&m_acc,dropped); // notifying client through notification
i dont want free fall detection interrupt when i tilt the sensor along  x axis
does any one hase solution for this problem ?
thank you
1,913件の閲覧回数
TomasVaverka
Hi Punit,
If you have only the Z-axis enabled and rotate the sensor along the X or Y-axis, then you always get a state when the Z-axis acceleration value is lower than the threshold value.
In order to avoid generating the freefall interrupt in such a case, you need to enable also the X and Y-axis (FF_MT_CFG = 0xB8).
Hope it helps!
Tomas
PS: If my answer helps to solve your question, please mark it as "Correct" or “Helpful”. Thank you.
%3CLINGO-SUB%20id%3D%22lingo-sub-1001573%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMMA8451Q%E5%8A%A0%E9%80%9F%E5%BA%A6%E3%82%BB%E3%83%B3%E3%82%B5%E3%81%AE%E8%87%AA%E7%94%B1%E8%90%BD%E4%B8%8B%E6%A4%9C%E5%87%BA%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1001573%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E8%87%AA%E7%94%B1%E8%90%BD%E4%B8%8B%E3%82%92%E6%A4%9C%E5%87%BA%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%20nRF51822%20MCU%20%E3%81%A8%20MMA8451Q%20%E5%8A%A0%E9%80%9F%E5%BA%A6%E3%82%BB%E3%83%B3%E3%82%B5%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%8E%E3%83%BC%E3%83%88%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%80%81%3CSTRONG%3E%E7%89%B9%E5%AE%9A%E3%81%AE%E9%AB%98%E3%81%95%E3%81%8B%E3%82%89%E3%82%BB%E3%83%B3%E3%82%B5%E3%82%92%E8%90%BD%E3%81%A8%E3%81%99%E3%81%A8%E8%87%AA%E7%94%B1%E8%90%BD%E4%B8%8B%E3%82%92%E6%A4%9C%E5%87%BA%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSTRONG%3E%E3%81%BE%E3%81%9F%E3%80%81%E3%82%BB%E3%83%B3%E3%82%B5%E3%82%92%20X%20%E8%BB%B8%E3%82%92%E4%B8%AD%E5%BF%83%E3%81%AB%E5%82%BE%E3%81%91%E3%82%8B%E3%81%A8%E8%87%AA%E7%94%B1%E8%90%BD%E4%B8%8B%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81%20%3CSTRONG%3EFF_MD_CONFIG%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%8B%E3%82%89%20x%20%E8%BB%B8%E3%81%A8%20y%20%E8%BB%B8%E3%81%AB%E6%B2%BF%E3%81%A3%E3%81%9F%E8%87%AA%E7%94%B1%E8%90%BD%E4%B8%8B%E3%82%92%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%87%AA%E7%94%B1%E8%90%BD%E4%B8%8B%E6%A4%9C%E5%87%BA%E3%81%AF%E3%80%81%E3%82%BB%E3%83%B3%E3%82%B5%E3%82%92%E9%AB%98%E6%89%80%E3%81%8B%E3%82%89%E8%90%BD%E3%81%A8%E3%81%97%E3%81%9F%E3%81%A8%E3%81%8D%E3%81%AE%E3%81%BF%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81X%E8%BB%B8%E3%82%92%E4%B8%AD%E5%BF%83%E3%81%AB%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%82%92%E5%82%BE%E3%81%91%E3%81%9F%E3%81%A8%E3%81%8D%E3%81%AF%E5%BF%85%E8%A6%81%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E3%81%93%E3%82%8C%E3%81%8C%E7%A7%81%E3%81%AE%E8%87%AA%E7%94%B1%E8%90%BD%E4%B8%8B%E6%A4%9C%E5%87%BA%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%99%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%95%E3%83%AA%E3%83%BC%E3%83%95%E3%82%A9%E3%83%BC%E3%83%AB%E5%88%9D%E6%9C%9F%E5%8C%96()%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%20uint8_t%20%E3%83%87%E3%83%BC%E3%82%BF%5B2%5D%3B%3CBR%20%2F%3E%20uint8_t%20%E6%B8%A9%E5%BA%A6%3B%3CBR%20%2F%3E%20%2F%2F%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%90%E3%82%A4%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E3%81%99%E3%82%8B%3CBR%20%2F%3Euint8_t%20CTRL_REG1%20%3D%200x2A%3B%3CBR%20%2F%3E%E3%83%87%E3%83%BC%E3%82%BF%5B0%5D%20%3D%20CTRL_REG1%3B%3CBR%20%2F%3E%E3%83%87%E3%83%BC%E3%82%BF%5B1%5D%3D%200x20%3B%3CBR%20%2F%3E%E9%80%81%E4%BF%A1(%E3%83%87%E3%83%BC%E3%82%BF)%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%2F%2Ffreefall%2Fmotion%20%E8%A8%AD%E5%AE%9A%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%3CBR%20%2F%3Euint8_t%20FF_MD_CONFIG%20%3D%200x15%3B%3CBR%20%2F%3E%E3%83%87%E3%83%BC%E3%82%BF%5B0%5D%20%3D%20FF_MD_CONFIG%3B%3CBR%20%2F%3E%E3%83%87%E3%83%BC%E3%82%BF%5B1%5D%20%3D%200xA0%3B%3CBR%20%2F%3E%E9%80%81%E4%BF%A1(%E3%83%87%E3%83%BC%E3%82%BF)%3B%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%2F%2F%20%E3%81%97%E3%81%8D%E3%81%84%E5%80%A4%E3%81%AE%E8%A8%AD%E5%AE%9A%3CBR%20%2F%3Euint8_t%20THR_REGISTER%20%3D%200x17%3B%3CBR%20%2F%3E%E3%83%87%E3%83%BC%E3%82%BF%5B0%5D%20%3D%20THR_REGISTER%3B%3CBR%20%2F%3E%E3%83%87%E3%83%BC%E3%82%BF%5B1%5D%3D%200x03%3B%3CBR%20%2F%3E%E9%80%81%E4%BF%A1(%E3%83%87%E3%83%BC%E3%82%BF)%3B%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%2F%2F%20%E3%83%87%E3%83%90%E3%82%A6%E3%83%B3%E3%82%B9%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%E3%81%AE%E8%A8%AD%E5%AE%9A%3CBR%20%2F%3Euint8_t%20%E3%83%87%E3%83%90%E3%82%A6%E3%83%B3%E3%82%B9%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%20%3D%200x18%3B%3CBR%20%2F%3E%E3%83%87%E3%83%BC%E3%82%BF%5B0%5D%20%3D%20DEBOUNCE_REGISTER%3B%3CBR%20%2F%3E%E3%83%87%E3%83%BC%E3%82%BF%5B1%5D%3D%200x06%3B%3CBR%20%2F%3E%E9%80%81%E4%BF%A1(%E3%83%87%E3%83%BC%E3%82%BF)%3B%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%2F%2F%20%E3%83%A2%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%2F%E8%87%AA%E7%94%B1%E8%90%BD%E4%B8%8B%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E6%A9%9F%E8%83%BD%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%3CBR%20%2F%3Euint8_t%20INT_ENABLE%20%3D%200x2D%3B%3CBR%20%2F%3E%E3%83%87%E3%83%BC%E3%82%BF%5B0%5D%20%3D%20INT_ENABLE%3B%3CBR%20%2F%3E%E3%83%87%E3%83%BC%E3%82%BF%5B1%5D%3D0x04%3B%3CBR%20%2F%3E%E9%80%81%E4%BF%A1(%E3%83%87%E3%83%BC%E3%82%BF)%3B%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%2F%2F%E3%83%A2%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%2F%E8%87%AA%E7%94%B1%E8%90%BD%E4%B8%8B%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%92INT2%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%94%E3%83%B3%E3%81%AB%E3%83%AB%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%99%E3%82%8B%3CBR%20%2F%3Euint8_t%20INT_2%20%3D%200x2E%3B%3CBR%20%2F%3E%E3%83%87%E3%83%BC%E3%82%BF%5B0%5D%20%3D%20INT_2%3B%3CBR%20%2F%3E%E3%83%87%E3%83%BC%E3%82%BF%5B1%5D%3D%200x00%3B%3CBR%20%2F%3E%E9%80%81%E4%BF%A1(%E3%83%87%E3%83%BC%E3%82%BF)%3B%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%2F%2F%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E3%81%99%E3%82%8B%3CBR%20%2F%3Etemp%20%3D%20read(%26amp%3BCTRL_REG1)%3B%3CBR%20%2F%3E%E6%B8%A9%E5%BA%A6%20%7C%3D%200x01%3B%3CBR%20%2F%3E%E3%83%87%E3%83%BC%E3%82%BF%5B0%5D%3DCTRL_REG1%3B%3CBR%20%2F%3E%E3%83%87%E3%83%BC%E3%82%BF%5B1%5D%3D%20temp%3B%3CBR%20%2F%3E%E9%80%81%E4%BF%A1(%E3%83%87%E3%83%BC%E3%82%BF)%3B%3CBR%20%2F%3E%20%7D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E3%81%93%E3%82%8C%E3%81%8C%E7%A7%81%E3%81%AE%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%81%A7%E3%81%99%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Evoid%20Interrupt2_handler(nrf_drv_gpiote_pin_t%20%E3%83%94%E3%83%B3%E3%80%81nrf_gpiote_polarity_t%20%E3%82%A2%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3)%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%20nrf_gpiote_event_clear(NRF_GPIOTE_EVENTS_IN_0)%3B%20%2F%2F%20%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%83%95%E3%83%A9%E3%82%B0%E3%82%92%E3%82%AF%E3%83%AA%E3%82%A2%E3%81%99%E3%82%8B%3CBR%20%2F%3Euint8_t%20system_interrupt%20%3D%20read(%26amp%3BSYSTEM_INT)%3B%20%2F%2F%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%200x0C%3CBR%20%2F%3E%20status%20%3D%20read(%26amp%3BFF_STATUS)%3B%20%2F%2F%20%E6%AC%A1%E3%81%AE%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%ABFF_MD_STATUS%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E8%AA%AD%E3%81%BF%E5%87%BA%E3%81%99%3CBR%20%2F%3E%E3%83%89%E3%83%AD%E3%83%83%E3%83%97%20%3D%200x01%3B%3CBR%20%2F%3E%20accelerometer_dropped_update(%26amp%3Bm_acc%2Cdropped)%3B%20%2F%2F%20%E9%80%9A%E7%9F%A5%E3%82%92%E9%80%9A%E3%81%98%E3%81%A6%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%81%AB%E9%80%9A%E7%9F%A5%E3%81%99%E3%82%8B%3CBR%20%2F%3E%7D%3C%2FP%3E%3CP%3E%E3%82%BB%E3%83%B3%E3%82%B5%E3%82%92X%E8%BB%B8%E3%81%AB%E6%B2%BF%E3%81%A3%E3%81%A6%E5%82%BE%E3%81%91%E3%81%9F%E3%81%A8%E3%81%8D%E3%81%AB%E8%87%AA%E7%94%B1%E8%90%BD%E4%B8%8B%E6%A4%9C%E5%87%BA%E3%81%8C%E4%B8%AD%E6%96%AD%E3%81%95%E3%82%8C%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%AB%E3%81%97%E3%81%9F%E3%81%84%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AE%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E4%BA%BA%E3%81%AF%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1001574%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Having%20Issue%20with%20Free%20Fall%20Detection%20in%20MMA8451Q%20accelerometer%20sensor%20%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1001574%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%83%97%E3%83%8B%E3%83%83%E3%83%88%E3%81%95%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EZ%20%E8%BB%B8%E3%81%AE%E3%81%BF%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%A6%E3%80%81%E3%82%BB%E3%83%B3%E3%82%B5%E3%82%92%20X%20%E8%BB%B8%E3%81%BE%E3%81%9F%E3%81%AF%20Y%20%E8%BB%B8%E3%81%AB%E6%B2%BF%E3%81%A3%E3%81%A6%E5%9B%9E%E8%BB%A2%E3%81%95%E3%81%9B%E3%82%8B%E3%81%A8%E3%80%81Z%20%E8%BB%B8%E3%81%AE%E5%8A%A0%E9%80%9F%E5%BA%A6%E5%80%A4%E3%81%8C%E3%81%97%E3%81%8D%E3%81%84%E5%80%A4%E3%82%88%E3%82%8A%E3%82%82%E4%BD%8E%E3%81%84%E7%8A%B6%E6%85%8B%E3%81%8C%E5%B8%B8%E3%81%AB%E5%BE%97%E3%82%89%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E5%A0%B4%E5%90%88%E3%81%AB%E8%87%AA%E7%94%B1%E8%90%BD%E4%B8%8B%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%AB%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81X%20%E8%BB%B8%E3%81%A8%20Y%20%E8%BB%B8%E3%82%82%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%20(FF_MT_CFG%20%3D%200xB8)%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%8A%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A6%E3%82%8C%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%EF%BC%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%88%E3%83%BC%E3%83%9E%E3%82%B9%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CEM%20style%3D%22border%3A%201pt%20none%20windowtext%3B%20font-weight%3A%20inherit%3B%20font-size%3A%209pt%3B%20padding%3A%200in%3B%22%3E%E8%BF%BD%E4%BC%B8%3A%20%E7%A7%81%E3%81%AE%E5%9B%9E%E7%AD%94%E3%81%8C%E8%B3%AA%E5%95%8F%E3%81%AE%E8%A7%A3%E6%B1%BA%E3%81%AB%E5%BD%B9%E7%AB%8B%E3%81%A3%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%80%8C%E6%AD%A3%E8%A7%A3%E3%80%8D%E3%81%BE%E3%81%9F%E3%81%AF%E3%80%8C%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A3%E3%81%9F%E3%80%8D%E3%81%A8%E3%83%9E%E3%83%BC%E3%82%AF%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%82%3C%2FEM%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
