FXPS7115DS4T1
FXPS7115DS4T1
2,557件の閲覧回数
Fast
Contributor V
Can anyone share SPI messages with calculated CRC. To start and read pressure and temperature?
3 返答(返信)
2,546件の閲覧回数
Fast
Contributor V
Thank you Jozef, I have looked at that but I do not need CRC and it is desperately slow to live calculate. I will attempt to use online tool to calculate CRC. Surely someone has a real example, not a code example? Perhaps it will get supported with SPIGen.exe, which is very useful tool.
2,489件の閲覧回数
Fast
Contributor V
No examples only code. I'll look at the Infineon and ST offerings
2,541件の閲覧回数
JozefKozon
Dear Richard,
unfortunately I didn't find the FXPS7115D SPI messages (perhaps somebody else will share them) in older cases, but I have found a description for CRC calculation from an application engineer. Please see below.
In order to build CRC checksum on the SPI command, you can take ”8-bit crc” fields as either ‘0000 0000’ or ‘1111 1111’ to complete the total 32-bit command. Calculate 8-bit CRC using the default polynomial on the 32-bit command and then replace calculated 8-bit CRC value in the ”8-bit crc” fields before sending the command. If the calculated CRC does not match the transmitted CRC, the command is ignored and the device responds with the SPI error response.
I have also found FXPS7xxx SW examples. Please find it attached.
With Best Regards,
Jozef
%3CLINGO-SUB%20id%3D%22lingo-sub-2067681%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFXPS7115DS4T1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2067681%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%A8%88%E7%AE%97%E3%81%95%E3%82%8C%E3%81%9F%20CRC%20%E3%82%92%E5%90%AB%E3%82%80%20SPI%20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%92%E5%85%B1%E6%9C%89%E3%81%A7%E3%81%8D%E3%82%8B%E4%BA%BA%E3%81%AF%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%A6%E5%9C%A7%E5%8A%9B%E3%81%A8%E6%B8%A9%E5%BA%A6%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%E3%81%AB%E3%81%AF%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2072803%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FXPS7115DS4T1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2072803%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BE%8B%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E3%81%BF%E3%81%A7%E3%81%99%E3%80%82%E3%82%A4%E3%83%B3%E3%83%95%E3%82%A3%E3%83%8B%E3%82%AA%E3%83%B3%E3%81%A8ST%E3%81%AE%E8%A3%BD%E5%93%81%E3%82%92%E8%A6%8B%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%82%87%E3%81%86%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2067733%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FXPS7115DS4T1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2067733%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%81Jozef%E3%80%82%E7%A7%81%E3%81%AF%E3%81%9D%E3%82%8C%E3%82%92%E8%AA%BF%E3%81%B9%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81CRC%20%E3%81%AF%E5%BF%85%E8%A6%81%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%97%E3%80%81%E3%83%A9%E3%82%A4%E3%83%96%E8%A8%88%E7%AE%97%E3%81%8C%E9%9D%9E%E5%B8%B8%E3%81%AB%E9%81%85%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%E3%82%AA%E3%83%B3%E3%83%A9%E3%82%A4%E3%83%B3%20%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20CRC%20%E3%82%92%E8%A8%88%E7%AE%97%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%99%E3%80%82%E3%82%B3%E3%83%BC%E3%83%89%E4%BE%8B%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81%E5%AE%9F%E9%9A%9B%E3%81%AE%E4%BE%8B%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E4%BA%BA%E3%81%AF%E3%81%84%E3%82%8B%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%E3%81%8A%E3%81%9D%E3%82%89%E3%81%8FSPIGen.exe%E3%81%A7%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%82%8B%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E9%9D%9E%E5%B8%B8%E3%81%AB%E4%BE%BF%E5%88%A9%E3%81%AA%E3%83%84%E3%83%BC%E3%83%AB%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2067713%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FXPS7115DS4T1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2067713%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%83%AA%E3%83%81%E3%83%A3%E3%83%BC%E3%83%89%E6%A7%98%3C%2FP%3E%0A%3CP%3E%E6%AE%8B%E5%BF%B5%E3%81%AA%E3%81%8C%E3%82%89%E3%80%81%E5%8F%A4%E3%81%84%E3%82%B1%E3%83%BC%E3%82%B9%E3%81%A7%E3%81%AF%20FXPS7115D%20SPI%20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AF%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%20(%E3%81%8A%E3%81%9D%E3%82%89%E3%81%8F%E4%BB%96%E3%81%AE%E8%AA%B0%E3%81%8B%E3%81%8C%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%8F%E3%82%8C%E3%82%8B%E3%81%A7%E3%81%97%E3%82%87%E3%81%86)%20%E3%81%8C%E3%80%81%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20%E3%82%A8%E3%83%B3%E3%82%B8%E3%83%8B%E3%82%A2%E3%81%AB%E3%82%88%E3%82%8B%20CRC%20%E8%A8%88%E7%AE%97%E3%81%AE%E8%AA%AC%E6%98%8E%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E4%BB%A5%E4%B8%8B%E3%82%92%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CEM%3ESPI%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%A7%20CRC%20%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%82%B5%E3%83%A0%E3%82%92%E6%A7%8B%E7%AF%89%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E3%80%8C8%20%E3%83%93%E3%83%83%E3%83%88%20CRC%E3%80%8D%E3%83%95%E3%82%A3%E3%83%BC%E3%83%AB%E3%83%89%E3%82%92%E3%80%8C0000%200000%E3%80%8D%E3%81%BE%E3%81%9F%E3%81%AF%E3%80%8C1111%201111%E3%80%8D%E3%81%AE%E3%81%84%E3%81%9A%E3%82%8C%E3%81%8B%E3%81%A8%E3%81%97%E3%81%A6%E5%8F%96%E5%BE%97%E3%81%97%E3%80%81%E5%90%88%E8%A8%88%2032%20%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%AE%8C%E6%88%90%E3%81%95%E3%81%9B%E3%81%BE%E3%81%99%E3%80%8232%20%E3%83%93%E3%83%83%E3%83%88%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AE%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E5%A4%9A%E9%A0%85%E5%BC%8F%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%208%20%E3%83%93%E3%83%83%E3%83%88%20CRC%20%E3%82%92%E8%A8%88%E7%AE%97%E3%81%97%E3%80%81%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E9%80%81%E4%BF%A1%E3%81%99%E3%82%8B%E5%89%8D%E3%81%AB%E3%80%81%E8%A8%88%E7%AE%97%E3%81%95%E3%82%8C%E3%81%9F%208%20%E3%83%93%E3%83%83%E3%83%88%20CRC%20%E5%80%A4%E3%82%92%E3%80%8C8%20%E3%83%93%E3%83%83%E3%83%88%20CRC%E3%80%8D%E3%83%95%E3%82%A3%E3%83%BC%E3%83%AB%E3%83%89%E3%81%AB%E7%BD%AE%E3%81%8D%E6%8F%9B%E3%81%88%E3%81%BE%E3%81%99%E3%80%82%E8%A8%88%E7%AE%97%E3%81%95%E3%82%8C%E3%81%9F%20CRC%20%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%9F%20CRC%20%E3%81%A8%E4%B8%80%E8%87%B4%E3%81%97%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%80%81%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AF%E7%84%A1%E8%A6%96%E3%81%95%E3%82%8C%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AF%20SPI%20%E3%82%A8%E3%83%A9%E3%83%BC%E5%BF%9C%E7%AD%94%E3%81%A7%E5%BF%9C%E7%AD%94%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FEM%3E%3C%2FP%3E%0A%3CP%3EFXPS7xxx%20SW%E3%81%AE%E4%BE%8B%E3%82%82%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%B7%BB%E4%BB%98%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%81%BE%E3%81%99%E3%81%AE%E3%81%A7%E3%81%94%E7%A2%BA%E8%AA%8D%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%95%AC%E5%85%B7%E3%80%81%3C%2FP%3E%0A%3CP%3E%E3%83%A8%E3%82%BC%E3%83%95%3C%2FP%3E%3C%2FLINGO-BODY%3E
