[FXOS8700] Transient Detection troubles
2,380件の閲覧回数
Ruig25
Hello!
I know, that the sensor is a little bit old, but nevertheless.
I have one application case and I still cannot solve a problem with transient detection. Of course I have read all App. Notes.
Use case description:
  • Sensor board attached to the wrist so that x-axis is along the arm (if we stretch index finger - the x-axis and the finger are +/- parallel).
  • The arm is on the rest (Xg =~ -250mg). It is initial position.
  • Now the stretched arm will be rosen slightly above the head (Xg =~ 300-350mg).
    X and Z axes are ignored (out of interest).
  • I want to have an interrupt after hand was rosen as described above.
Here is described motion (ODR=100Hz)
My first idea was to use vector-magnitude detection. But I did't tried it because I don't have constant Gref (initial position may have some variiations...).
The second idea - motion or transient detection.
Code (abstract):
  1. software rest + 1ms wait
  2. Standby CTRL_REG1=0x0
  3. Fullscale 2g XYZ_DATA_CFG=0x0
  4. Clr debounce counter and set ths to 5 (5x63mg=315mg) TRANSIENT_THS=0b10000101
  5. TRANSIENT_COUNT=6
  6. X only + evt latching TRANSIENT_CFG=0b00010010
  7. Enable transient interrupt CTRL_REG4=0b0010000
  8. Route transient interrupt to int1 CTRL_REG5=0b00100000
  9. Active mode, ODR 12,5Hz, Low Noise CTRL_REG1=0b00101101
Interrupt event triggered non-stop. I tried many different values for 4) and 5).
uC input IO configured for neg. edge with enabled pull-up.
I tried to move 6) after 3) like here. No interrupt triggered at all.
I tested circuit enabling FIFO watermark interrupt. Works without problems.
Any ideas?
Or motion detection is more suitable in my case?
Many thanks in advance
タグ(1)
2 返答(返信)
2,324件の閲覧回数
JozefKozon
Hello Igor,
for your case, I think the best would be the "Acceleration vector-magnitude detection". Please refer to the section 12.10 in the FXOS8700CQ datasheet and to the AN4692.
With Best Regards,
Jozef
2,327件の閲覧回数
Ruig25
After 10h of investigation:
It seems that threshold set in TRANSIENT_THS is ignored. Therefore interrupt fired non-stop (fallback threshold 0mg?).
But after enabling a_ffmt_trans_ths_en=1 in A_FFMT_THS_Y_MSB the system started to work correctly.
Axis of interest is X.
And I didn't expect to use invidual thresholds per axis. But it works now.
%3CLINGO-SUB%20id%3D%22lingo-sub-1658766%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%5BFXOS8700%5D%20%E9%81%8E%E6%B8%A1%E7%8F%BE%E8%B1%A1%E6%A4%9C%E5%87%BA%E3%81%AE%E3%83%88%E3%83%A9%E3%83%96%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1658766%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%EF%BC%81%3C%2FP%3E%3CP%3E%E3%82%BB%E3%83%B3%E3%82%B5%E3%81%8C%E5%B0%91%E3%81%97%E5%8F%A4%E3%81%84%E3%81%AE%E3%81%AF%E3%82%8F%E3%81%8B%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A7%E3%82%82%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%B1%E3%83%BC%E3%82%B9%E3%81%8C%201%20%E3%81%A4%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E4%BE%9D%E7%84%B6%E3%81%A8%E3%81%97%E3%81%A6%E9%81%8E%E6%B8%A1%E6%A4%9C%E5%87%BA%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%82%82%E3%81%A1%E3%82%8D%E3%82%93%E3%82%A2%E3%83%97%E3%83%AA%E3%81%AF%E3%81%99%E3%81%B9%E3%81%A6%E8%AA%AD%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%B3%A8%E6%84%8F%E4%BA%8B%E9%A0%85%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSTRONG%3E%E3%83%A6%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%82%B9%E3%81%AE%E8%AA%AC%E6%98%8E%3A%3C%2FSTRONG%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AF%E3%80%81X%20%E8%BB%B8%E3%81%8CArm%E3%81%AB%E6%B2%BF%E3%81%86%E3%82%88%E3%81%86%E3%81%AB%E6%89%8B%E9%A6%96%E3%81%AB%E5%8F%96%E3%82%8A%E4%BB%98%E3%81%91%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20(%E4%BA%BA%E5%B7%AE%E3%81%97%E6%8C%87%E3%82%92%E4%BC%B8%E3%81%B0%E3%81%99%E3%81%A8%E3%80%81X%20%E8%BB%B8%E3%81%A8%E6%8C%87%E3%81%AF%20%2B%2F-%20%E5%B9%B3%E8%A1%8C%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99)%E3%80%82%3C%2FLI%3E%3CLI%3E%E8%85%95%E3%81%AF%E3%83%AC%E3%82%B9%E3%83%88%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%EF%BC%88Xg%20%3D%E3%80%9C%20-250mg%EF%BC%89%E3%80%82%E5%88%9D%E6%9C%9F%E4%BD%8D%E7%BD%AE%E3%81%A7%E3%81%99%E3%80%82%3C%2FLI%3E%3CLI%3E%E4%BC%B8%E3%81%B0%E3%81%97%E3%81%9F%E8%85%95%E3%81%AF%E9%A0%AD%E3%82%88%E3%82%8A%E5%B0%91%E3%81%97%E4%B8%8A%E3%81%AB%E4%B8%8A%E3%81%8C%E3%82%8A%E3%81%BE%E3%81%99%20(Xg%20%3D~%20300-350mg)%E3%80%82%3CBR%20%2F%3EX%20%E8%BB%B8%E3%81%A8%20Z%20%E8%BB%B8%E3%81%AF%E7%84%A1%E8%A6%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%20(%E8%88%88%E5%91%B3%E3%81%AE%E3%81%AA%E3%81%84%E7%90%86%E7%94%B1%E3%81%AB%E3%82%88%E3%82%8A)%E3%80%82%3C%2FLI%3E%3CLI%3E%E4%B8%8A%E8%A8%98%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E6%89%8B%E6%9C%AD%E3%81%8C%E4%B8%8A%E3%81%8C%E3%81%A3%E3%81%9F%E5%BE%8C%E3%81%AB%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%92%E3%81%97%E3%81%9F%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CBR%20%2F%3E%3CSTRONG%3E%E3%81%93%E3%81%93%E3%81%A7%E8%AA%AC%E6%98%8E%E3%81%99%E3%82%8B%E5%8B%95%E3%81%8D%EF%BC%88ODR%3D100Hz%EF%BC%89%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%222023-05-28%2022_15_16-Window.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222023-05-28%2022_15_16-Window.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F225108i08D3C1452B17097C%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%222023-05-28%2022_15_16-Window.png%22%20alt%3D%222023-05-28%2022_15_16-Window.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E7%A7%81%E3%81%AE%E6%9C%80%E5%88%9D%E3%81%AE%E3%82%A2%E3%82%A4%E3%83%87%E3%82%A2%E3%81%AF%E3%80%81%E3%83%99%E3%82%AF%E3%83%88%E3%83%AB%E6%8C%AF%E5%B9%85%E6%A4%9C%E5%87%BA%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%81%84%E3%81%86%E3%82%82%E3%81%AE%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E7%A7%81%E3%81%AF%E5%AE%9A%E6%95%B0%20Gref%20%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%AE%E3%81%A7%E3%80%81%E8%A9%A6%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%20(%E5%88%9D%E6%9C%9F%E4%BD%8D%E7%BD%AE%E3%81%AB%E3%81%AF%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E3%83%90%E3%83%AA%E3%82%A8%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E3%81%82%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99...)%E3%80%82%3C%2FP%3E%3CP%3E2%20%E7%95%AA%E7%9B%AE%E3%81%AE%E3%82%A2%E3%82%A4%E3%83%87%E3%82%A2%20-%20%E3%83%A2%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%BE%E3%81%9F%E3%81%AF%E9%81%8E%E6%B8%A1%E7%8F%BE%E8%B1%A1%E3%81%AE%E6%A4%9C%E5%87%BA%E3%80%82%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%3CSTRONG%3E%E3%82%B3%E3%83%BC%E3%83%89%EF%BC%88%E8%A6%81%E7%B4%84%EF%BC%89%3A%3C%2FSTRONG%3E%3C%2FP%3E%3COL%3E%3CLI%3E%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E4%BC%91%E6%AD%A2%20%2B%201ms%E5%BE%85%E6%A9%9F%3C%2FLI%3E%3CLI%3E%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%90%E3%82%A4%3CSPAN%3ECTRL_REG1%3D0x0%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3E%E3%83%95%E3%83%AB%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%202g%3C%2FSPAN%3E%20%3CSPAN%3EXYZ_DATA_CFG%3D0x0%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3E%E3%83%87%E3%83%90%E3%82%A6%E3%83%B3%E3%82%B9%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%82%92%E3%82%AF%E3%83%AA%E3%82%A2%E3%81%97%E3%80%81THS%E3%82%925%EF%BC%885x63mg%3D315mg%EF%BC%89%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82TRANSIENT_THS%3C%2FSPAN%3E%20%3CSPAN%3E%3D0b10000101%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3E%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B8%E3%82%A8%E3%83%B3%E3%83%88%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%3D6%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3EX%E3%81%AE%E3%81%BF%20%2B%20%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E3%83%A9%E3%83%83%E3%83%81%3C%2FSPAN%3E%3CSPAN%3ETRANSIENT_CFG%3D0b00010010%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3E%E4%B8%80%E6%99%82%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%3CSPAN%3ECTRL_REG4%3D0b0010000%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3E%3CSPAN%3E%E4%B8%80%E6%99%82%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%92int1%E3%81%AB%E3%83%AB%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%99%E3%82%8B%20CTRL_REG5%3D0b00100000%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3E%3CSPAN%3E%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E3%83%A2%E3%83%BC%E3%83%89%E3%80%81ODR%2012.5Hz%E3%80%81%E4%BD%8E%E3%83%8E%E3%82%A4%E3%82%BA%20CTRL_REG1%3D0b00101101%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3CSPAN%3E%3CSPAN%3E%E4%B8%AD%E6%96%AD%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E3%81%8C%E3%83%8E%E3%83%B3%E3%82%B9%E3%83%88%E3%83%83%E3%83%97%E3%81%A7%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%824)%20%E3%81%A8%205)%20%E3%81%AB%E3%81%AF%E3%81%95%E3%81%BE%E3%81%96%E3%81%BE%E3%81%AA%E5%80%A4%E3%82%92%E8%A9%A6%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EMCU%20%E5%85%A5%E5%8A%9B%20IO%20%E3%81%8C%E8%B2%A0%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%97%E3%83%AB%E3%82%A2%E3%83%83%E3%83%97%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AA%E3%82%A8%E3%83%83%E3%82%B8%E3%80%82%3C%2FP%3E%3CP%3E3)%20%E3%81%AE%E5%BE%8C%E3%81%AB%206)%20%E3%82%92%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FSensors%2FFXOS8700-accel-transient-threshold-resolution-in-per-axis-mode%2Fm-p%2F354855%2Fhighlight%2Ftrue%23M1047%22%20target%3D%22_self%22%3E%E3%81%93%E3%81%AE%3C%2FA%3E%E3%82%88%E3%81%86%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%81%AF%E3%81%BE%E3%81%A3%E3%81%9F%E3%81%8F%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3EFIFO%20%E3%82%A6%E3%82%A9%E3%83%BC%E3%82%BF%E3%83%BC%E3%83%9E%E3%83%BC%E3%82%AF%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E5%9B%9E%E8%B7%AF%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%8F%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E4%BD%95%E3%81%8B%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E7%A7%81%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%E3%83%A2%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E6%A4%9C%E5%87%BA%E3%81%AE%E6%96%B9%E3%81%8C%E9%81%A9%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1659105%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%5BFXOS8700%5D%20Transient%20Detection%20troubles%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1659105%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%82%A4%E3%82%B4%E3%83%BC%E3%83%AB%E3%81%95%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AECASE%E3%80%81%E3%80%8C%E5%8A%A0%E9%80%9F%E5%BA%A6%E3%83%99%E3%82%AF%E3%83%88%E3%83%AB-%E5%A4%A7%E3%81%8D%E3%81%95%E6%A4%9C%E5%87%BA%E3%80%8D%E3%81%8C%E6%9C%80%E9%81%A9%E3%81%A0%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fdata-sheet%2FFXOS8700CQ.pdf%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EFXOS8700CQ%20%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%3C%2FA%3E%E3%81%AE%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%2012.10%20%E3%81%8A%E3%82%88%E3%81%B3%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN4692.pdf%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EAN4692%3C%2FA%3E%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22JozefKozon_0-1685354985792.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JozefKozon_0-1685354985792.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F225200i4CF2C17BBD5E6EFB%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22JozefKozon_0-1685354985792.png%22%20alt%3D%22JozefKozon_0-1685354985792.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%95%AC%E5%85%B7%E3%80%81%3C%2FP%3E%0A%3CP%3E%E3%83%A8%E3%82%BC%E3%83%95%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1659023%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%5BFXOS8700%5D%20Transient%20Detection%20troubles%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1659023%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E10%E6%99%82%E9%96%93%E3%81%AE%E8%AA%BF%E6%9F%BB%E5%BE%8C%EF%BC%9A%3CBR%20%2F%3E%3CBR%20%2F%3E%20%3CSTRONG%3ETRANSIENT_THS%3C%2FSTRONG%3E%E3%81%A7%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%9F%E3%81%97%E3%81%8D%E3%81%84%E5%80%A4%E3%81%AF%E7%84%A1%E8%A6%96%E3%81%95%E3%82%8C%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%81%AF%E9%80%A3%E7%B6%9A%E3%81%97%E3%81%A6%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%20(%E3%83%95%E3%82%A9%E3%83%BC%E3%83%AB%E3%83%90%E3%83%83%E3%82%AF%E3%81%97%E3%81%8D%E3%81%84%E5%80%A4%200mg%3F)%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%3CSTRONG%3E%20A_FFMT_THS_Y_MSB%3C%2FSTRONG%3E%20%E3%81%A7%3CEM%3E%20a_ffmt_trans_ths_en%3D1%20%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%3C%2FEM%3E%20%E3%81%A8%E3%80%81%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E9%96%A2%E5%BF%83%E8%BB%B8%E3%81%AF%20X%20%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%81%BE%E3%81%9F%E3%80%81%E8%BB%B8%E3%81%94%E3%81%A8%E3%81%AB%E5%80%8B%E5%88%A5%E3%81%AE%E3%81%97%E3%81%8D%E3%81%84%E5%80%A4%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E6%83%B3%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E4%BB%8A%E3%81%AF%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
