FXOS8700 SPI question
2,738件の閲覧回数
warr1
I am want to use the FXOS8700 in SPI mode. I set the parameters of the SPI bus according to the FXOS8700 data sheet.
In order to get the FXOS into SPI mode, I tri-state the MISO pin before toggling the reset pin, and waiting the required time for the auto detection circuit to put the device into SPI mode.
void FXOS8700_GPIO_Init(void)
GPIO_InitTypeDef GPIO_InitStruct = {0};
__HAL_RCC_GPIOA_CLK_ENABLE();
GPIO_InitStruct.Pin = GPIO_PIN_MISO;
GPIO_InitStruct.Mode = GPIO_MODE_INPUT;
GPIO_InitStruct.Pull = GPIO_NOPULL;
GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
HAL_Delay(10);
GPIO_InitStruct.Pin = GPIO_PIN_RST;
GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
HAL_GPIO_WritePin(GPIOA, GPIO_PIN_RST, GPIO_PIN_SET);
HAL_Delay(1);
HAL_GPIO_WritePin(GPIOA, GPIO_PIN_RST, GPIO_PIN_RESET);
HAL_Delay(1);
 Next, initialize the SPI bus.
void MX_SPI1_Init(void)
hspi1.Instance = SPI1;
hspi1.Init.Mode = SPI_MODE_MASTER;
hspi1.Init.Direction = SPI_DIRECTION_2LINES;
hspi1.Init.DataSize = SPI_DATASIZE_8BIT;
hspi1.Init.CLKPolarity = SPI_POLARITY_LOW;
hspi1.Init.CLKPhase = SPI_PHASE_1EDGE;
hspi1.Init.NSS = SPI_NSS_SOFT;
hspi1.Init.BaudRatePrescaler = SPI_BAUDRATEPRESCALER_128;
hspi1.Init.FirstBit = SPI_FIRSTBIT_MSB;
hspi1.Init.TIMode = SPI_TIMODE_DISABLE;
hspi1.Init.CRCCalculation = SPI_CRCCALCULATION_DISABLE;
hspi1.Init.CRCPolynomial = 10;
if (HAL_SPI_Init(&hspi1) != HAL_OK)
Error_Handler();
My STM32 only connects to the FXOS8700. Therefore, the cs_b of FXOS8700 is directly grounded. During the reading process, cs_b remains at a low voltage, so it is not operated in the code. I then attempt to read the WHO_AM_I register and get the value 0xff instead of 0xff which is what I would expect.
Below is the code I am using to reset the device and read the WHO_AM_I register:
unsigned char FXOS8700CQ_ReadRegister(uint8_t RegisterAddress)
uint8_t tx_data[3];
unsigned char rx_data[3];
tx_data[0] = (RegisterAddress & 0x7F);
tx_data[1] = (RegisterAddress & 0x80);
tx_data[2] = 0x00;
if (HAL_SPI_TransmitReceive(&hspi1, tx_data, rx_data, 3, HAL_MAX_DELAY) != HAL_OK)
return 0x01;
return rx_data;
The final result is below:
rx_data[0] = 0xFF
rx_data[1] = 0xFF
rx_data[2] = 0xFF
Anybody else getting this problem?
タグ(2)
3 返答(返信)
2,715件の閲覧回数
TomasVaverka
First of all, please note that the FXOS8700CQ is EOL and not recommended for new designs.
Based on description, the first thing I would recommend to try is to toggle the CS_B pin between low and high to latch data during SPI communication. Grounding the CS_B pin directly may not work.
Next, as I am not familiar with STM MCUs, I cannot check your SPI initialization. Please double check that it matches the FXOS8700 requirements:
Clock Polarity (CPOL): 0 (idle low)
Clock Phase (CPHA): 0 (data captured on the leading edge of the clock)
Your read a register seems to be correct.
Do you have a logic analyzer or an oscilloscope to see what is going on the bus?
BRs, Tomas
2,695件の閲覧回数
warr1
During the reset process of FXOS8700, I set SA0 to a high impedance state. After resetting, int1 was detected and a reset signal can be detected. Is there any way to detect if FXOS8700 has switched to SPI mode?
2,701件の閲覧回数
warr1
Hi Tomas,I have revised CS_S according to your suggestion, and now it is completely controlled by the MCU. I still haven't received the correct signal yet. I captured the signal through a logic analyzer as follows:1734664688299.png
%3CLINGO-SUB%20id%3D%22lingo-sub-2017186%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFXOS8700%20SPI%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E8%B3%AA%E5%95%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2017186%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EFXOS8700%E3%82%92SPI%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E8%80%83%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82FXOS8700%20%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%20SPI%20%E3%83%90%E3%82%B9%E3%81%AE%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EFXOS%20%E3%82%92%20SPI%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%20%E3%83%94%E3%83%B3%E3%82%92%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%82%8B%E5%89%8D%E3%81%AB%20MISO%20%E3%83%94%E3%83%B3%E3%82%92%E3%83%88%E3%83%A9%E3%82%A4%E3%82%B9%E3%83%86%E3%83%BC%E3%83%88%E3%81%AB%E3%81%97%E3%81%A6%E3%80%81%E8%87%AA%E5%8B%95%E6%A4%9C%E5%87%BA%E5%9B%9E%E8%B7%AF%E3%81%8C%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%20SPI%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AA%E6%99%82%E9%96%93%E3%82%92%E5%BE%85%E6%A9%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CPRE%20translate%3D%22no%22%3E%3CSPAN%3Evoid%20FXOS8700_GPIO_Init(void)%3CBR%20%2F%3E%7B%3CBR%20%2F%3EGPIO_InitTypeDef%20GPIO_InitStruct%20%3D%20%7B0%7D%3B%3CBR%20%2F%3E__HAL_RCC_GPIOA_CLK_ENABLE()%3B%3CBR%20%2F%3E%3C%2FSPAN%3EGPIO_InitStruct%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EPin%3C%2FSPAN%3E%3CSPAN%3E%20%3D%20GPIO_PIN_MISO%3B%3CBR%20%2F%3E%3C%2FSPAN%3EGPIO_InitStruct%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EMode%3C%2FSPAN%3E%3CSPAN%3E%20%3D%20GPIO_MODE_INPUT%3B%3CBR%20%2F%3E%3C%2FSPAN%3EGPIO_InitStruct%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EPull%3C%2FSPAN%3E%3CSPAN%3E%20%3D%20GPIO_NOPULL%3B%3CBR%20%2F%3E%3C%2FSPAN%3EGPIO_InitStruct%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3ESpeed%3C%2FSPAN%3E%3CSPAN%3E%20%3D%20GPIO_SPEED_FREQ_LOW%3B%3CBR%20%2F%3E%3C%2FSPAN%3EHAL_GPIO_Init(GPIOA%2C%20%26amp%3B%3CSPAN%3EGPIO_InitStruct%3C%2FSPAN%3E%3CSPAN%3E)%3B%3CBR%20%2F%3E%3CSPAN%3EHAL_Delay(10)%3B%3C%2FSPAN%3E%3CBR%20%2F%3E%3C%2FSPAN%3EGPIO_InitStruct%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EPin%3C%2FSPAN%3E%3CSPAN%3E%20%3D%20GPIO_PIN_RST%3B%3CBR%20%2F%3E%3C%2FSPAN%3EGPIO_InitStruct%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EMode%3C%2FSPAN%3E%3CSPAN%3E%20%3D%20GPIO_MODE_OUTPUT_PP%3B%3CBR%20%2F%3E%3C%2FSPAN%3EGPIO_InitStruct%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EPull%3C%2FSPAN%3E%3CSPAN%3E%20%3D%20GPIO_NOPULL%3B%3CBR%20%2F%3E%3C%2FSPAN%3EGPIO_InitStruct%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3ESpeed%3C%2FSPAN%3E%3CSPAN%3E%20%3D%20GPIO_SPEED_FREQ_LOW%3B%3CBR%20%2F%3E%3C%2FSPAN%3EHAL_GPIO_Init(GPIOA%2C%20%26amp%3B%3CSPAN%3EGPIO_InitStruct%3C%2FSPAN%3E%3CSPAN%3E)%3B%3CBR%20%2F%3E%3C%2FSPAN%3EHAL_GPIO_WritePin(GPIOA%2C%20GPIO_PIN_RST%2C%20%3CSPAN%3EGPIO_PIN_SET%3C%2FSPAN%3E%3CSPAN%3E)%3B%3CBR%20%2F%3E%3C%2FSPAN%3EHAL_Delay(1)%3B%3CBR%20%2F%3EHAL_GPIO_WritePin(GPIOA%2C%20GPIO_PIN_RST%2C%20%3CSPAN%3EGPIO_PIN_RESET%3C%2FSPAN%3E%3CSPAN%3E)%3B%3CBR%20%2F%3E%3C%2FSPAN%3EHAL_Delay(1)%3B%3CBR%20%2F%3E%3CSPAN%3E%7D%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FPRE%3E%3CDIV%3E%3CDIV%3E%3CP%3E%E6%AC%A1%E3%81%AB%E3%80%81SPI%20%E3%83%90%E3%82%B9%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CPRE%20translate%3D%22no%22%3E%3CSPAN%3Evoid%20MX_SPI1_Init(void)%3CBR%20%2F%3E%3C%2FSPAN%3E%7B%3CBR%20%2F%3Ehspi1.%3CSPAN%3EInstance%3C%2FSPAN%3E%3CSPAN%3E%20%3D%20SPI1%3B%3CBR%20%2F%3E%3C%2FSPAN%3Ehspi1.%3CSPAN%3EInit%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EMode%3C%2FSPAN%3E%3CSPAN%3E%20%3D%20SPI_MODE_MASTER%3B%3CBR%20%2F%3E%3C%2FSPAN%3Ehspi1.%3CSPAN%3EInit%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EDirection%3C%2FSPAN%3E%3CSPAN%3E%20%3D%20SPI_DIRECTION_2LINES%3B%3CBR%20%2F%3E%3C%2FSPAN%3Ehspi1.%3CSPAN%3EInit%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EDataSize%3C%2FSPAN%3E%3CSPAN%3E%20%3D%20SPI_DATASIZE_8BIT%3B%3CBR%20%2F%3E%3C%2FSPAN%3Ehspi1.%3CSPAN%3EInit%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3ECLKPolarity%3C%2FSPAN%3E%3CSPAN%3E%20%3D%20SPI_POLARITY_LOW%3B%3CBR%20%2F%3E%3C%2FSPAN%3Ehspi1.%3CSPAN%3EInit%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3ECLKPhase%3C%2FSPAN%3E%3CSPAN%3E%20%3D%20SPI_PHASE_1EDGE%3B%3CBR%20%2F%3E%3C%2FSPAN%3Ehspi1.%3CSPAN%3EInit%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3ENSS%3C%2FSPAN%3E%3CSPAN%3E%20%3D%20SPI_NSS_SOFT%3B%3CBR%20%2F%3E%3C%2FSPAN%3Ehspi1.%3CSPAN%3EInit%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EBaudRatePrescaler%3C%2FSPAN%3E%3CSPAN%3E%20%3D%20SPI_BAUDRATEPRESCALER_128%3B%3CBR%20%2F%3E%3C%2FSPAN%3Ehspi1.%3CSPAN%3EInit%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3EFirstBit%3C%2FSPAN%3E%3CSPAN%3E%20%3D%20SPI_FIRSTBIT_MSB%3B%3CBR%20%2F%3E%3C%2FSPAN%3Ehspi1.%3CSPAN%3EInit%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3ETIMode%3C%2FSPAN%3E%3CSPAN%3E%20%3D%20SPI_TIMODE_DISABLE%3B%3CBR%20%2F%3E%3C%2FSPAN%3Ehspi1.%3CSPAN%3EInit%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3ECRCCalculation%3C%2FSPAN%3E%3CSPAN%3E%20%3D%20SPI_CRCCALCULATION_DISABLE%3B%3CBR%20%2F%3E%3C%2FSPAN%3Ehspi1.%3CSPAN%3EInit%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3ECRCPolynomial%3C%2FSPAN%3E%3CSPAN%3E%20%3D%2010%3B%3CBR%20%2F%3E%3C%2FSPAN%3Eif%3CSPAN%3E%20(HAL_SPI_Init(%26amp%3Bhspi1)%20!%3D%20%3C%2FSPAN%3E%3CSPAN%3EHAL_OK%3C%2FSPAN%3E%3CSPAN%3E)%3CBR%20%2F%3E%3C%2FSPAN%3E%7B%3CBR%20%2F%3EError_Handler()%3B%3CBR%20%2F%3E%7D%3CBR%20%2F%3E%7D%3C%2FPRE%3E%3CDIV%3E%3CDIV%3E%3CP%3E%3CSPAN%3E%3CSPAN%20class%3D%22%22%3E%E7%A7%81%E3%81%AE%20STM32%20%E3%81%AF%20FXOS8700%20%E3%81%AB%E3%81%AE%E3%81%BF%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%81%AE%E3%81%9F%E3%82%81%E3%80%81FXOS8700%E3%81%AEcs_b%E3%81%AF%E7%9B%B4%E6%8E%A5%E6%8E%A5%E5%9C%B0%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E4%B8%AD%E3%80%81cs_b%20%E3%81%AF%E4%BD%8E%E9%9B%BB%E5%9C%A7%E3%81%AE%E3%81%BE%E3%81%BE%E3%80%81SO%E3%80%81%E3%82%B3%E3%83%BC%E3%83%89%E5%86%85%E3%81%A7%E3%81%AF%E6%93%8D%E4%BD%9C%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E6%AC%A1%E3%81%AB%E3%80%81WHO_AM_I%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8D%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E4%BA%88%E6%83%B3%E3%81%A9%E3%81%8A%E3%82%8A%200xff%20%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%200xff%20%E3%81%A8%E3%81%84%E3%81%86%E5%80%A4%E3%81%8C%E8%BF%94%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CSPAN%20class%3D%22%22%3E%E4%BB%A5%E4%B8%8B%E3%81%AF%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%97%E3%80%81WHO_AM_I%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CPRE%20translate%3D%22no%22%3E%3CSPAN%3Eunsigned%20char%20FXOS8700CQ_ReadRegister(uint8_t%20RegisterAddress)%3CBR%20%2F%3E%3C%2FSPAN%3E%7B%3CBR%20%2F%3Euint8_t%3CSPAN%3E%20tx_data%5B3%5D%3B%3CBR%20%2F%3E%3C%2FSPAN%3Eunsigned%20%3CSPAN%3Echar%3C%2FSPAN%3E%3CSPAN%3E%20rx_data%5B3%5D%3B%3CBR%20%2F%3E%3C%2FSPAN%3Etx_data%5B0%5D%20%3D%20(RegisterAddress%20%26amp%3B%200x7F)%3B%3CBR%20%2F%3Etx_data%5B1%5D%20%3D%20(RegisterAddress%20%26amp%3B%200x80)%3B%3CBR%20%2F%3Etx_data%5B2%5D%20%3D%200x00%3B%3CBR%20%2F%3Eif%3CSPAN%3E%20(HAL_SPI_TransmitReceive(%26amp%3Bhspi1%2C%20tx_data%2C%20rx_data%2C%203%2C%20HAL_MAX_DELAY)%20!%3D%20%3C%2FSPAN%3E%3CSPAN%3EHAL_OK%3C%2FSPAN%3E%3CSPAN%3E)%3CBR%20%2F%3E%3C%2FSPAN%3E%7B%3CBR%20%2F%3Ereturn%3CSPAN%3E%200x01%3B%20%3CBR%20%2F%3E%3C%2FSPAN%3E%7D%3CBR%20%2F%3Ereturn%3CSPAN%3E%20rx_data%3B%3CBR%20%2F%3E%3C%2FSPAN%3E%7D%3C%2FPRE%3E%3CP%3E%E6%9C%80%E7%B5%82%E7%B5%90%E6%9E%9C%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E9%80%9A%E3%82%8A%E3%81%A7%E3%81%99%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%3Erx_data%3C%2FSPAN%3E%20%5B0%5D%20%3D%200xFF%3CBR%20%2F%3E%20%3CSPAN%3Erx_data%3C%2FSPAN%3E%20%5B1%5D%20%3D%200xFF%3CBR%20%2F%3E%20%3CSPAN%3Erx_data%3C%2FSPAN%3E%20%5B2%5D%20%3D%200xFF%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3E%E4%BB%96%E3%81%AB%E3%82%82%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E9%81%AD%E9%81%87%E3%81%97%E3%81%9F%E4%BA%BA%E3%81%AF%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2017186%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E7%A3%81%E6%B0%97%E3%82%BB%E3%83%B3%E3%82%B5%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2017587%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FXOS8700%20SPI%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2017587%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EFXOS8700%20%E3%81%AE%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E4%B8%AD%E3%81%AB%E3%80%81SA0%20%E3%82%92%E3%83%8F%E3%82%A4%E3%82%A4%E3%83%B3%E3%83%94%E3%83%BC%E3%83%80%E3%83%B3%E3%82%B9%E7%8A%B6%E6%85%8B%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E5%BE%8C%E3%80%81int1%E3%81%8C%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%80%81%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E4%BF%A1%E5%8F%B7%E3%82%92%E6%A4%9C%E5%87%BA%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82FXOS8700%20%E3%81%8C%20SPI%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E5%88%87%E3%82%8A%E6%9B%BF%E3%82%8F%E3%81%A3%E3%81%9F%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E6%A4%9C%E5%87%BA%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2017580%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FXOS8700%20SPI%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2017580%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81Tomas%E3%81%95%E3%82%93%E3%80%82%E3%81%94%E6%8F%90%E6%A1%88%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6CS_S%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%82%8C%E3%81%A7MCU%E3%81%AB%E3%82%88%E3%82%8B%E5%88%B6%E5%BE%A1%E3%81%8C%E5%AE%8C%E5%85%A8%E3%81%AB%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%BE%E3%81%A0%E6%AD%A3%E3%81%97%E3%81%84%E4%BF%A1%E5%8F%B7%E3%82%92%E5%8F%97%E4%BF%A1%E3%81%A7%E3%81%8D%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%83%AD%E3%82%B8%E3%83%83%E3%82%AF%20%E3%82%A2%E3%83%8A%E3%83%A9%E3%82%A4%E3%82%B6%E3%83%BC%E3%81%A7%E4%BF%A1%E5%8F%B7%E3%82%92%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%221734664688299.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221734664688299.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F316786i3F7EDCA246C8269B%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%221734664688299.png%22%20alt%3D%221734664688299.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2017342%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FXOS8700%20SPI%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2017342%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CP%3E%E3%81%BE%E3%81%9A%E3%80%81FXOS8700CQ%20%E3%81%AF%20EOL%20%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E6%96%B0%E3%81%97%E3%81%84%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%81%AB%E3%81%AF%E6%8E%A8%E5%A5%A8%E3%81%95%E3%82%8C%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%81%AB%E6%B3%A8%E6%84%8F%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%AA%AC%E6%98%8E%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%80%81%E6%9C%80%E5%88%9D%E3%81%AB%E8%A9%A6%E3%81%99%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%81%AE%E3%81%AF%E3%80%81SPI%20%E9%80%9A%E4%BF%A1%E4%B8%AD%E3%81%AB%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E3%83%A9%E3%83%83%E3%83%81%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%20CS_B%20%E3%83%94%E3%83%B3%E3%82%92%E3%83%AD%E3%83%BC%E3%81%A8%E3%83%8F%E3%82%A4%E3%81%AE%E9%96%93%E3%81%A7%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82CS_B%20%E3%83%94%E3%83%B3%E3%82%92%E7%9B%B4%E6%8E%A5%E6%8E%A5%E5%9C%B0%E3%81%97%E3%81%A6%E3%82%82%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%AA%E3%81%84%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%AC%A1%E3%81%AB%E3%80%81%E7%A7%81%E3%81%AF%20STM%20MCU%20%E3%81%AB%E7%B2%BE%E9%80%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81SPI%20%E5%88%9D%E6%9C%9F%E5%8C%96%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82FXOS8700%20%E3%81%AE%E8%A6%81%E4%BB%B6%E3%82%92%E6%BA%80%E3%81%9F%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E5%86%8D%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E6%A5%B5%E6%80%A7%EF%BC%88CPOL%EF%BC%89%EF%BC%9A0%EF%BC%88%E3%82%A2%E3%82%A4%E3%83%89%E3%83%AB%E4%BD%8E%EF%BC%89%3CBR%20%2F%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E4%BD%8D%E7%9B%B8%EF%BC%88CPHA%EF%BC%89%EF%BC%9A0%EF%BC%88%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AE%E5%85%88%E7%AB%AF%E3%81%A7%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%81%95%E3%82%8C%E3%81%9F%E3%83%87%E3%83%BC%E3%82%BF%EF%BC%89%3C%2FP%3E%0A%3CP%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%90%E3%82%B9%E4%B8%8A%E3%81%A7%E4%BD%95%E3%81%8C%E8%B5%B7%E3%81%93%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%83%AD%E3%82%B8%E3%83%83%E3%82%AF%20%E3%82%A2%E3%83%8A%E3%83%A9%E3%82%A4%E3%82%B6%E3%83%BC%E3%81%BE%E3%81%9F%E3%81%AF%E3%82%AA%E3%82%B7%E3%83%AD%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%97%E3%82%92%E3%81%8A%E6%8C%81%E3%81%A1%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3EBRs%E3%80%81%E3%83%88%E3%83%BC%E3%83%9E%E3%82%B9%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
