FXOS8700 PL interrupt sometimes does not clear
2,107 次查看
robertogomes
I've worked in a project based on STM32 and FXOS8700.
Some information:
I2C @400kHz
auto-sleep enable (but not interrupt)
Hybrid mode
Just int_en_lndprt is enable in CTRL_REG4 and  int_cfg_lndprt in CTRL_REG5
The sensor is set to generate interrupt (INT1) when orientation is changed. In interrupt code I read  PL_STATUS and I can check which (Portait/Landscape/front/back) movement happened.
However, sometimes after read PL_STATUS the pin INT1 is not clear. As this interrupt can not be "unlatched" like freefall or vectormag interrupt, when this happens I can not restore the idle state anymore.
Anybody used this function and worked well?
1,874 次查看
anthonyduhamel
Hello Robertos,
I suggest you to use the debounce counter just to be sure that the INT1 is not setted again due to another event. (use a big value to add a dead time before the next event).
If the interrupt is still high, there is an issue to clear the flag. If it goes down a time (debounce time), it is a threshold problem.
Try it and let-me know.
Anthony
1,874 次查看
robertogomes
Hi Anthony,
I did what you said and it seems work. But I will wait some days more because the problem was random. It was very hard to reproduce. whether everything to be fine until tomorrow , i'll need reduce the debounce counter because the response time to orientation movement increase a lot( almost 1.5 s).
I will let you know about my tests.
Roberto
1,874 次查看
anthonyduhamel
Hi Roberto,
Increasing the debounce counter is not really the solution. It was just to be sure there is not a quasi-permanent interrupt. It allows to filter a bit the interrupt. But if the trigger condition is still valid, the interrupt will came back to high level after clearing the flag + debounce time.
You can take a look at the application note AN4068​.
I'm waiting your tests. Let me know your progress!
Anthony
%3CLINGO-SUB%20id%3D%22lingo-sub-477219%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFXOS8700%20PL%20%E4%B8%AD%E6%96%AD%E6%9C%89%E6%97%B6%E6%97%A0%E6%B3%95%E6%B8%85%E9%99%A4%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-477219%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E6%9B%BE%E5%8F%82%E4%B8%8E%E8%BF%87%E4%B8%80%E4%B8%AA%E5%9F%BA%E4%BA%8E%20STM32%20%E5%92%8C%20FXOS8700%20%E7%9A%84%E9%A1%B9%E7%9B%AE%E3%80%82%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%B8%80%E4%BA%9B%E4%BF%A1%E6%81%AF%3C%2FP%3E%3CP%3EI2C%20%40400kHz%3C%2FP%3E%3CP%3E%E5%90%AF%E7%94%A8%E8%87%AA%E5%8A%A8%E4%BC%91%E7%9C%A0%EF%BC%88%E4%BD%86%E4%B8%8D%E4%B8%AD%E6%96%AD%EF%BC%89%3C%2FP%3E%3CP%3E%E6%B7%B7%E5%90%88%E6%A8%A1%E5%BC%8F%3C%2FP%3E%3CP%3E%E4%BB%85%E5%9C%A8%20CTRL_REG4%20%E4%B8%AD%E5%90%AF%E7%94%A8%20int_en_lndprt%EF%BC%8C%E5%9C%A8%20CTRL_REG5%20%E4%B8%AD%E5%90%AF%E7%94%A8%20int_cfg_lndprt%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BC%A0%E6%84%9F%E5%99%A8%E8%AE%BE%E7%BD%AE%E4%B8%BA%E5%9C%A8%E6%94%B9%E5%8F%98%E6%96%B9%E5%90%91%E6%97%B6%E4%BA%A7%E7%94%9F%E4%B8%AD%E6%96%AD%20(INT1)%E3%80%82%E5%9C%A8%E4%B8%AD%E6%96%AD%E4%BB%A3%E7%A0%81%E4%B8%AD%EF%BC%8C%E6%88%91%E8%AF%BB%E5%8F%96%E4%BA%86%20PL_STATUS%EF%BC%8C%E5%B9%B6%E5%8F%AF%E4%BB%A5%E6%A3%80%E6%9F%A5%E5%8F%91%E7%94%9F%E4%BA%86%E5%93%AA%E4%B8%AA%EF%BC%88%E7%AB%AF%E5%8F%A3%2F%E6%99%AF%E8%A7%82%2F%E5%89%8D%E6%96%B9%2F%E5%90%8E%E6%96%B9%EF%BC%89%E7%A7%BB%E5%8A%A8%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%86%E6%98%AF%EF%BC%8C%E6%9C%89%E6%97%B6%E5%9C%A8%E8%AF%BB%E5%8F%96%20PL_STATUS%20%E4%B9%8B%E5%90%8E%EF%BC%8CINT1%20%E5%BC%95%E8%84%9A%E5%B9%B6%E6%B2%A1%E6%9C%89%E6%B8%85%E9%9B%B6%E3%80%82%E7%94%B1%E4%BA%8E%E8%BF%99%E4%B8%AA%E4%B8%AD%E6%96%AD%E4%B8%8D%E5%8F%AF%E8%83%BD%E5%83%8F%20freefall%20%E6%88%96%20vectormag%20%E4%B8%AD%E6%96%AD%E9%82%A3%E6%A0%B7%20%22%20unlatched%20%22%EF%BC%8C%E6%89%80%E4%BB%A5%E5%BD%93%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%E5%8F%91%E7%94%9F%E6%97%B6%E6%88%91%E6%97%A0%E6%B3%95%E5%86%8D%E6%81%A2%E5%A4%8DIDLE%E7%8A%B6%E6%80%81%E4%BA%86%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%9C%89%E4%BA%BA%E4%BD%BF%E7%94%A8%E8%BF%87%E8%BF%99%E9%A1%B9%E5%8A%9F%E8%83%BD%E5%B9%B6%E4%B8%94%E6%95%88%E6%9E%9C%E8%89%AF%E5%A5%BD%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-477219%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E5%8A%A0%E9%80%9F%E5%BA%A6%E4%BC%A0%E6%84%9F%E5%99%A8%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-477222%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FXOS8700%20PL%20interrupt%20sometimes%20does%20not%20clear%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-477222%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E7%BD%97%E4%BC%AF%E6%89%98%E3%80%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%A2%9E%E5%8A%A0%E6%B6%88%E6%8A%96%E8%AE%A1%E6%95%B0%E5%99%A8%E5%B9%B6%E4%B8%8D%E6%98%AF%E7%9C%9F%E6%AD%A3%E7%9A%84%E8%A7%A3%E5%86%B3%E5%8A%9E%E6%B3%95%E3%80%82%E8%BF%99%E5%8F%AA%E6%98%AF%E4%B8%BA%E4%BA%86%E7%A1%AE%E4%BF%9D%E4%B8%8D%E4%BC%9A%E5%87%BA%E7%8E%B0%E5%87%86%E6%B0%B8%E4%B9%85%E6%80%A7%E4%B8%AD%E6%96%AD%E3%80%82%E5%AE%83%E5%8F%AF%E4%BB%A5%E8%BF%87%E6%BB%A4%E4%B8%80%E4%B8%8B%E4%B8%AD%E6%96%AD%E3%80%82%E4%BD%86%E6%98%AF%EF%BC%8C%E5%A6%82%E6%9E%9C%E8%A7%A6%E5%8F%91%E6%9D%A1%E4%BB%B6%E4%BB%8D%E7%84%B6%E6%9C%89%E6%95%88%EF%BC%8C%E5%88%99%E5%9C%A8%E6%B8%85%E9%99%A4%20flag%20%2B%20debounce%20%E6%97%B6%E9%97%B4%E5%90%8E%EF%BC%8C%E4%B8%AD%E6%96%AD%E5%B0%86%E6%81%A2%E5%A4%8D%E5%88%B0%E8%BE%83%E9%AB%98%E6%B0%B4%E5%B9%B3%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%A0%E5%8F%AF%E4%BB%A5%E7%9C%8B%E7%9C%8B%E5%BA%94%E7%94%A8%E7%AC%94%E8%AE%B0%20%3CA%20href%3D%22http%3A%2F%2Fcache.nxp.com%2Ffiles%2Fsensors%2Fdoc%2Fapp_note%2FAN4068.pdf%3Ffsrch%3D1%26amp%3Bsr%3D1%26amp%3BpageNum%3D1%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EAN4068%3C%2FA%3E%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%9C%A8%E7%AD%89%E4%BD%A0%E7%9A%84%E6%B5%8B%E8%AF%95%E3%80%82%E8%AE%A9%E6%88%91%E7%9F%A5%E9%81%93%E4%BD%A0%E7%9A%84%E8%BF%9B%E5%B1%95%EF%BC%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3E%E5%AE%89%E4%B8%9C%E5%B0%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-477221%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FXOS8700%20PL%20interrupt%20sometimes%20does%20not%20clear%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-477221%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%97%A8%EF%BC%8C%E5%AE%89%E4%B8%9C%E5%B0%BC%E3%80%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E7%85%A7%E4%BD%A0%E8%AF%B4%E7%9A%84%E5%81%9A%E4%BA%86%EF%BC%8C%E7%9C%8B%E8%B5%B7%E6%9D%A5%E8%BF%98%E8%A1%8C%E3%80%82%E4%BD%86%E6%88%91%E4%BC%9A%E5%86%8D%E7%AD%89%E5%87%A0%E5%A4%A9%EF%BC%8C%E5%9B%A0%E4%B8%BA%E9%97%AE%E9%A2%98%E6%98%AF%E9%9A%8F%E6%9C%BA%E5%87%BA%E7%8E%B0%E7%9A%84%E3%80%82%E8%BF%99%E5%BE%88%E9%9A%BE%E5%86%8D%E7%8E%B0%E3%80%82%E6%97%A0%E8%AE%BA%E6%98%8E%E5%A4%A9%E4%B9%8B%E5%89%8D%E6%98%AF%E5%90%A6%E4%B8%80%E5%88%87%E6%AD%A3%E5%B8%B8%EF%BC%8C%E6%88%91%E9%83%BD%E9%9C%80%E8%A6%81%E5%87%8F%E5%B0%91%E6%B6%88%E6%8A%96%E8%AE%A1%E6%95%B0%E5%99%A8%EF%BC%8C%E5%9B%A0%E4%B8%BA%E6%96%B9%E5%90%91%E7%A7%BB%E5%8A%A8%E7%9A%84%E5%93%8D%E5%BA%94%E6%97%B6%E9%97%B4%E5%A2%9E%E5%8A%A0%E4%BA%86%E5%BE%88%E5%A4%9A%EF%BC%88%E5%B0%86%E8%BF%91%201.5%20%E7%A7%92%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E4%BC%9A%E8%AE%A9%E4%BD%A0%E7%9F%A5%E9%81%93%E6%88%91%E7%9A%84%E6%B5%8B%E8%AF%95%E7%BB%93%E6%9E%9C%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3E%E7%BD%97%E4%BC%AF%E6%89%98%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-477220%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FXOS8700%20PL%20interrupt%20sometimes%20does%20not%20clear%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-477220%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E7%BD%97%E4%BC%AF%E6%89%98%E6%96%AF%E3%80%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%BB%BA%E8%AE%AE%E6%82%A8%E4%BD%BF%E7%94%A8%E6%B6%88%E6%8A%96%E8%AE%A1%E6%95%B0%E5%99%A8%EF%BC%8C%E4%BB%A5%E7%A1%AE%E4%BF%9D%20INT1%20%E4%B8%8D%E4%BC%9A%E5%9B%A0%E5%85%B6%E4%BB%96%E4%BA%8B%E4%BB%B6%E8%80%8C%E5%86%8D%E6%AC%A1%E8%A2%AB%E8%AE%BE%E7%BD%AE%E3%80%82(%E4%BD%BF%E7%94%A8%E5%A4%A7%E5%80%BC%E6%9D%A5%E5%A2%9E%E5%8A%A0%E4%B8%8B%E4%B8%80%E4%B8%AA%E4%BA%8B%E4%BB%B6%E5%8F%91%E7%94%9F%E5%89%8D%E7%9A%84%E6%AD%BB%E5%8C%BA%E6%97%B6%E9%97%B4%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E4%B8%AD%E6%96%AD%E4%BB%8D%E4%B8%BA%E9%AB%98%E7%94%B5%E5%B9%B3%EF%BC%8C%E5%88%99%E9%9C%80%E8%A6%81%E6%B8%85%E9%99%A4%E6%A0%87%E8%AE%B0%E3%80%82%E5%A6%82%E6%9E%9C%E4%B8%8B%E9%99%8D%E4%BA%86%E4%B8%80%E6%AE%B5%E6%97%B6%E9%97%B4%EF%BC%88%E5%8E%BB%E6%8A%96%E6%97%B6%E9%97%B4%EF%BC%89%EF%BC%8C%E5%88%99%E6%98%AF%E9%98%88%E5%80%BC%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%AF%95%E8%AF%95%E7%9C%8B%EF%BC%8C%E7%84%B6%E5%90%8E%E5%91%8A%E8%AF%89%E6%88%91%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3E%E5%AE%89%E4%B8%9C%E5%B0%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E
