Error when flashing NTM88
nguyenhuy5997
IDE: code warrior 11.1
Chip: NTM88
Debugger: USBDM
When i flash NTM88, IDE throw the error in picture attached. Can you guide me what reason is, and how to fix it?
lukaszadrapa
I'm afraid I can't comment on this. I'm sure that Pemicro probe is supported. I already saw more complaints that USBDM does not work with this device but I can't help here as it is not our product.
Lukas
lukaszadrapa
did you follow this user manual to install the CodeWarrior and the patch?
https://www.nxp.com/webapp/Download?colCode=UM11325&location=null
It also says that P&E Micro USB Multilink Universal is needed. USBDM is not mentioned here.
Lukas
nguyenhuy5997
yes, i follow UM11325 step by step. The only diffient is debugger, im using USBDM.
When i plug USBDM, it detect wrong chip. I use NTM88 but USBDM detect FXTH87
lukaszadrapa
Lukas
nguyenhuy5997
Okie, thanks for your reply. NXP distributor is shipping me a sample and debugger. I hope that will work smoothly
