Clarification on Offset-Step Identification and Conversion for NTM88x12
4,584件の閲覧回数
Kafei42
I’m working with the NTM88x12 accelerometer in the extended range option (–175 g to +550 g) and have encountered a few points of confusion. I’ve attached the relevant datasheet table and application-note flowchart for reference.
  1. Implementing AN13614 Offset-Step Identification
    AN13614 shows an algorithm for finding the “starting offset step” and then updating it based on raw ADC readings when using standard ±g ranges. For the –175 g…+550 g option, the NTM88Jxx5S-DS datasheet’s Table 18 indicates that the offset steps are listed in reverse order. When I port the AN13614 logic to this range, should I simply invert the step index comparisons (i.e. decrement where the note increments and vice versa)?
  2. Conversion Formula Applicability
    AN13614 defines the acceleration-transfer function as:
    Can I apply this same formula unchanged for the –175 g…+550 g range—even though its offset steps are in inverted order—or must the formula itself be adjusted to account for the reversal?
  3. Usable Offset-Step Subset
    AN13614 mentions that “for certain models only offset steps 4…10 are usable, as indicated in the datasheet.” I did not find any step-range restriction in either the NTM88Jxx5S-DS or related datasheets. Which offset-step indices are officially supported for the all others variants, and where is it documented?
Thank you in advance for any guidance you can provide!
4 返答(返信)
4,535件の閲覧回数
Kafei42
Hello Jozef,
Thanks again for your clear answers!
I implemented the AN13614 algorithms exactly as described, using these macros:
// LSB limits for compensated value
#define LSB_A_MIN 2 // LSB
#define LSB_A_MAX 1022 // LSB
// Number of half-bands from AN13614
#define HALF_BANDS_A 17.0
// Visual proof:
//   bands:  |--0---|---2---|--4---|---6---|---8---|---10---|---12---|---14---|
//          Min |-1-|-2-|-3-|-4-|-5-|-6-|-7-|-8-|-9-|-10-|-11-|-12-|-13-|-14-|-15-|-16-|-17-| Max
//   bands:        |---1---|---3---|--5---|---7---|---9---|---11----|---13---|---15----|
// Band step size (G)
#define CALC_STEP(min, max) (float)((max - min) / HALF_BANDS_A)
// Lower bound of a band (G)
#define CALC_BAND_MIN(acc_min, band, step) (float)(acc_min + (band * step))
// Delta (G/LSB)
#define CALC_DELTA(step) (float)((2.0f * step) / (LSB_A_MAX - LSB_A_MIN))
// Offset (G)
#define CALC_OFFSET(band_min, delta) (float)(band_min - (LSB_A_MIN * delta))
typedef enum {
BAND_0 = 0,
BAND_1,
BAND_15
} accel_band_t;
For example, for –80 g…+90 g I did:
#define N80_90_MIN -80.0f
#define N80_90_MAX 90.0f
#define N80_90_STEP CALC_STEP(N80_90_MIN, N80_90_MAX)
#define N80_90_DELTA CALC_DELTA(N80_90_STEP)
#define N80_90_BAND0_MIN CALC_BAND_MIN(N80_90_MIN, BAND_0, N80_90_STEP) // –80.0 g
#define N80_90_BAND0_OFFSET CALC_OFFSET(N80_90_BAND0_MIN, N80_90_DELTA)
… (bands 1 through 15)
  • Result: For the –80…+90 g range, my computed band limits and offsets match the datasheet exactly.
  • Issue: For the other ranges (–360…+400 g, –120…+520 g, –175…+550 g, –400…+400 g), my values diverge significantly from those listed in their datasheets.
Question: Is there any NXP reference (application note, errata, or spreadsheet) that provides the full set of ΔA, proof-inertia (@Aₘᵢₙ) and offset values for all 16 steps of each of the five acceleration ranges? Having those tables or formulas would help me validate and correct my implementation.
Thanks in advance for any pointers or documents you can share!
-Kafei
4,565件の閲覧回数
JozefKozon
Hello Kafei42,
[A] Yes, for the extended range (–175 g to +550 g), the offset steps are listed in reverse order in Table 18 of the NTM88Jxx5S-DS datasheet. Therefore, when porting the AN13614 algorithm, you should invert the step index comparisons.
[A] The acceleration-transfer function defined in AN13614 can still be applied unchanged, even for the extended range. The formula itself is independent of the offset step order; it operates on the raw ADC values and offset step index.
[A] There is no documented restriction in the datasheet for the –175 g to +550 g variant. Unless otherwise specified in a future datasheet revision or errata, you may assume all offset steps are usable for this range.
With Best Regards,
Jozef
4,537件の閲覧回数
Kafei42
Hello Jozef,
#define HALF_BANDS_A 17.0f
#define CALC_STEP(min, max)      ( ((max) - (min)) / HALF_BANDS_A )
#define CALC_BAND_MIN(acc_min, band, step)  ( (acc_min) + ((band) * (step)) )
// Delta (G/LSB)
#define CALC_DELTA(step)         ( (2.0f * (step)) / (LSB_A_MAX - LSB_A_MIN) )
// Offset (G)
#define CALC_OFFSET(band_min, delta)        ( (band_min) - (LSB_A_MIN * (delta)) )
typedef enum {
    BAND_0 = 0,
    BAND_1,
    BAND_15
} accel_band_t;
#define N80_90_BAND0_MIN    CALC_BAND_MIN(N80_90_MIN, 0, N80_90_STEP)   // –80.0 g
— Kafei
4,501件の閲覧回数
JozefKozon
Hello Kafei42,
references that include the full set of ΔA (delta), offset, and proof-inertia values for all 16 offset steps across the five acceleration ranges supported by the NTM88 sensor family can be found in the AN13614, UM11227 and in the UM11145. Please see below.
AN13614
  • Formulas for ΔA and Offset:
    • ΔA=2⋅StepSizeLSBmax−LSBminΔA=LSBmax​−LSBmin​2⋅StepSize​
    • Offset=BandMin−(LSBmin⋅ΔA)Offset=BandMin−(LSBmin​⋅ΔA)
  • Step-by-step breakdown of how each offset step maps to a subrange of the full acceleration range.
  • Illustrative examples for ranges like –360 g to +400 g, showing how each step overlaps and transitions.
  • Proof-inertia calculation using:
    ΔAMAX–MIN=Proof Inertia @AMAX−Proof Inertia @AMINAMAX−AMINΔAMAX–MIN​=AMAX​−AMIN​Proof Inertia @AMAX​−Proof Inertia @AMIN​​
UM11145-https://www.nxp.com/docs/en/user-manual/UM11145.pdf
This guide explains how the firmware uses the ΔA and offset values during compensation:
  • Describes the Universal Uncompensated Measurement Array (UUMA) format.
  • Lists all compensation functions, including TPMS_COMP_ACCEL_X and TPMS_COMP_ACCEL_Z.
  • Confirms that compensation relies on factory-programmed trim coefficients, which are essential for accurate results.
For the –175 g to +550 g range, offset steps are listed in reverse order in the datasheet.
https://docs.nxp.com/bundle/UM11227/page/topics/optional_acceleration_measurements.html
With Best Regards,
Jozef
%3CLINGO-SUB%20id%3D%22lingo-sub-2127540%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ENTM88x12%E3%81%AE%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E8%AD%98%E5%88%A5%E3%81%A8%E5%A4%89%E6%8F%9B%E3%81%AE%E6%98%8E%E7%A2%BA%E5%8C%96%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2127540%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%80%81%E6%8B%A1%E5%BC%B5%E7%AF%84%E5%9B%B2%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%20(-175%20g%20%EF%BD%9E%20%2B550%20g)%20%E3%81%AE%20NTM88x12%20%E5%8A%A0%E9%80%9F%E5%BA%A6%E3%82%BB%E3%83%B3%E3%82%B5%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E6%B7%B7%E4%B9%B1%E3%81%99%E3%82%8B%E7%82%B9%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%8F%82%E8%80%83%E3%81%BE%E3%81%A7%E3%81%AB%E3%80%81%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E8%A1%A8%E3%81%A8%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%8E%E3%83%BC%E3%83%88%E3%81%AE%E3%83%95%E3%83%AD%E3%83%BC%E3%83%81%E3%83%A3%E3%83%BC%E3%83%88%E3%82%92%E6%B7%BB%E4%BB%98%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3COL%3E%3CLI%3E%3CSTRONG%3EAN13614%20%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E8%AD%98%E5%88%A5%E3%81%AE%E5%AE%9F%E8%A3%85%3C%2FSTRONG%3E%3CBR%20%2F%3EAN13614%20%E3%81%A7%E3%81%AF%E3%80%81%E6%A8%99%E6%BA%96%20%C2%B1g%20%E7%AF%84%E5%9B%B2%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%AB%E3%80%81%E3%80%8C%E9%96%8B%E5%A7%8B%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%20%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%80%8D%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%A6%E3%80%81%E7%94%9F%E3%81%AE%20ADC%20%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E5%80%A4%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%81%9D%E3%82%8C%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%82%A2%E3%83%AB%E3%82%B4%E3%83%AA%E3%82%BA%E3%83%A0%E3%82%92%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E2%80%93175%20g%E2%80%A6%2B550%20g%20%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81NTM88Jxx5S-DS%20%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%81%AE%E8%A1%A8%2018%20%E3%81%AB%E3%81%AF%E3%80%81%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%20%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%8C%E9%80%86%E3%81%AE%E9%A0%86%E5%BA%8F%E3%81%A7%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82AN13614%E3%83%AD%E3%82%B8%E3%83%83%E3%82%AF%E3%82%92%E3%81%93%E3%81%AE%E7%AF%84%E5%9B%B2%E3%81%AB%E7%A7%BB%E6%A4%8D%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%E3%81%AE%E6%AF%94%E8%BC%83%E3%82%92%E5%8D%98%E7%B4%94%E3%81%AB%E5%8F%8D%E8%BB%A2%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%88%E3%81%A4%E3%81%BE%E3%82%8A%E3%80%81%E3%83%8E%E3%83%BC%E3%83%88%E3%81%8C%E5%A2%97%E5%8A%A0%E3%81%99%E3%82%8B%E3%81%A8%E3%81%93%E3%82%8D%E3%81%A7%E3%83%8E%E3%83%BC%E3%83%88%E3%82%92%E6%B8%9B%E5%B0%91%E3%81%95%E3%81%9B%E3%80%81%E3%81%9D%E3%81%AE%E9%80%86%E3%82%82%E8%A1%8C%E3%81%86%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLI%3E%3CLI%3E%3CSTRONG%3E%E5%A4%89%E6%8F%9B%E5%BC%8F%E3%81%AE%E9%81%A9%E7%94%A8%E7%AF%84%E5%9B%B2%3CBR%20%2F%3E%3C%2FSTRONG%3EAN13614%20%E3%81%A7%E3%81%AF%E5%8A%A0%E9%80%9F%E5%BA%A6%E4%BC%9D%E9%81%94%E9%96%A2%E6%95%B0%E3%82%92%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%AE%9A%E7%BE%A9%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Kafei42_3-1751486506057.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kafei42_3-1751486506057.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F345835i76805EF5B39B99D9%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Kafei42_3-1751486506057.png%22%20alt%3D%22Kafei42_3-1751486506057.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%20%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%AE%E9%A0%86%E5%BA%8F%E3%81%8C%E9%80%86%E3%81%A7%E3%81%82%E3%81%A3%E3%81%A6%E3%82%82%E3%80%81%E3%81%93%E3%81%AE%E5%90%8C%E3%81%98%E5%BC%8F%E3%82%92%20%E2%80%93175%20g%E2%80%A6%2B550%20g%20%E3%81%AE%E7%AF%84%E5%9B%B2%E3%81%AB%E3%81%9D%E3%81%AE%E3%81%BE%E3%81%BE%E9%81%A9%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E3%80%81%E5%BC%8F%E8%87%AA%E4%BD%93%E3%82%92%E8%AA%BF%E6%95%B4%E3%81%97%E3%81%A6%E5%8F%8D%E8%BB%A2%E3%82%92%E8%80%83%E6%85%AE%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLI%3E%3CLI%3E%3CSTRONG%3E%E4%BD%BF%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AA%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%82%B5%E3%83%96%E3%82%BB%E3%83%83%E3%83%88%3CBR%20%2F%3E%3C%2FSTRONG%3EAN13614%20%E3%81%AB%E3%81%AF%E3%80%81%E3%80%8C%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%E7%89%B9%E5%AE%9A%E3%81%AE%E3%83%A2%E3%83%87%E3%83%AB%E3%81%A7%E3%81%AF%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%20%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%204%20%EF%BD%9E%2010%20%E3%81%AE%E3%81%BF%E3%81%8C%E4%BD%BF%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%80%8D%E3%81%A8%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82NTM88Jxx5S-DS%20%E3%81%BE%E3%81%9F%E3%81%AF%E9%96%A2%E9%80%A3%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%81%AE%E3%81%84%E3%81%9A%E3%82%8C%E3%81%AB%E3%82%82%E3%80%81%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E7%AF%84%E5%9B%B2%E3%81%AE%E5%88%B6%E9%99%90%E3%81%AF%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E4%BB%96%E3%81%AE%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%90%E3%83%AA%E3%82%A2%E3%83%B3%E3%83%88%E3%81%A7%E3%81%AF%E3%81%A9%E3%81%AE%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%20%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%20%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%E3%81%8C%E5%85%AC%E5%BC%8F%E3%81%AB%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%20%E3%81%BE%E3%81%9F%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AF%E3%81%A9%E3%81%93%E3%81%AB%E6%96%87%E6%9B%B8%E5%8C%96%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%E3%81%94%E6%8C%87%E5%B0%8E%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%82%8C%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Kafei42_2-1751486422379.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kafei42_2-1751486422379.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F345834i13996D17D085C611%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Kafei42_2-1751486422379.png%22%20alt%3D%22Kafei42_2-1751486422379.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Kafei42_0-1751486378196.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kafei42_0-1751486378196.png%22%20style%3D%22width%3A%20373px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F345833iF94D61931A922B6C%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Kafei42_0-1751486378196.png%22%20alt%3D%22Kafei42_0-1751486378196.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2127540%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E5%8A%A0%E9%80%9F%E5%BA%A6%E3%82%BB%E3%83%B3%E3%82%B5%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2130571%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Clarification%20on%20Offset-Step%20Identification%20and%20Conversion%20for%20NTM88x12%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2130571%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81Kafei42%E3%81%95%E3%82%93%3C%2FP%3E%0A%3CP%3ENTM88%20%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%20%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%81%A7%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%205%20%E3%81%A4%E3%81%AE%E5%8A%A0%E9%80%9F%E5%BA%A6%E7%AF%84%E5%9B%B2%E3%81%AB%E3%82%8F%E3%81%9F%E3%82%8B%2016%20%E3%81%AE%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%20%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AB%E5%AF%BE%E3%81%99%E3%82%8B%20%CE%94A%20(%E3%83%87%E3%83%AB%E3%82%BF)%E3%80%81%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%E6%85%A3%E6%80%A7%E8%A8%BC%E6%98%8E%E5%80%A4%E3%81%AE%E5%AE%8C%E5%85%A8%E3%81%AA%E3%82%BB%E3%83%83%E3%83%88%E3%82%92%E5%90%AB%E3%82%80%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%81%AF%E3%80%81AN13614%E3%80%81UM11227%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%20UM11145%20%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E4%BB%A5%E4%B8%8B%E3%82%92%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CH3%20id%3D%22toc-hId-1971828820%22%20id%3D%22toc-hId-2026528044%22%3EAN13614%3C%2FH3%3E%0A%3CUL%3E%0A%3CLI%3E%0A%3CP%3E%CE%94A%E3%81%A8%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%E3%81%AE%E8%A8%88%E7%AE%97%E5%BC%8F%3A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%3CSPAN%20class%3D%22math%20math-inline%22%3E%3CSPAN%20class%3D%22katex%22%3E%3CSPAN%20class%3D%22katex-mathml%22%3E%CE%94A%3D2%E2%8B%85%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%82%B5%E3%82%A4%E3%82%BALSBmax%E2%88%92LSBmin%3C%2FSPAN%3E%3CSPAN%20class%3D%22katex-html%22%3E%3CSPAN%20class%3D%22base%22%3E%3CSPAN%20class%3D%22mord%22%3E%20%CE%94%3C%2FSPAN%3E%3CSPAN%20class%3D%22mord%20mathnormal%22%3E%20A%3C%2FSPAN%3E%3CSPAN%20class%3D%22mrel%22%3E%20%3D%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22base%22%3E%3CSPAN%20class%3D%22mord%22%3E%3CSPAN%20class%3D%22mfrac%22%3E%3CSPAN%20class%3D%22vlist-t%20vlist-t2%22%3E%3CSPAN%20class%3D%22vlist-r%22%3E%3CSPAN%20class%3D%22vlist%22%3E%3CSPAN%20class%3D%22sizing%20reset-size6%20size3%20mtight%22%3E%3CSPAN%20class%3D%22mord%20mtight%22%3E%3CSPAN%20class%3D%22mord%20text%20mtight%22%3E%20LSB%3C%2FSPAN%3E%3CSPAN%20class%3D%22msupsub%22%3E%3CSPAN%20class%3D%22sizing%20reset-size3%20size1%20mtight%22%3E%3CSPAN%20class%3D%22mord%20text%20mtight%22%3E%20max%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22vlist-s%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22mbin%20mtight%22%3E%20%E2%88%92%3C%2FSPAN%3E%3CSPAN%20class%3D%22mord%20text%20mtight%22%3E%20LSB%3C%2FSPAN%3E%3CSPAN%20class%3D%22msupsub%22%3E%3CSPAN%20class%3D%22sizing%20reset-size3%20size1%20mtight%22%3E%3CSPAN%20class%3D%22mord%20text%20mtight%22%3E%20min%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22vlist-s%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22sizing%20reset-size6%20size3%20mtight%22%3E%3CSPAN%20class%3D%22mord%20mtight%22%3E%202%3CSPAN%20class%3D%22mbin%20mtight%22%3E%20%E2%8B%85%3C%2FSPAN%3E%3CSPAN%20class%3D%22mord%20text%20mtight%22%3E%20%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%82%B5%E3%82%A4%E3%82%BA%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22vlist-s%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E%3CSPAN%20class%3D%22math%20math-inline%22%3E%3CSPAN%20class%3D%22katex%22%3E%3CSPAN%20class%3D%22katex-mathml%22%3E%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%20%3D%20BandMin%E2%88%92(%20LSBmin%E2%8B%85%CE%94A)%3C%2FSPAN%3E%3CSPAN%20class%3D%22katex-html%22%3E%3CSPAN%20class%3D%22base%22%3E%3CSPAN%20class%3D%22mord%20text%22%3E%3CSPAN%20class%3D%22mord%22%3E%20%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22mrel%22%3E%20%3D%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22base%22%3E%3CSPAN%20class%3D%22mord%20text%22%3E%3CSPAN%20class%3D%22mord%22%3E%20BandMin%E2%88%92(%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22mbin%22%3E%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22base%22%3E%3CSPAN%20class%3D%22mopen%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22mord%22%3E%3CSPAN%20class%3D%22mord%20text%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22msupsub%22%3E%3CSPAN%20class%3D%22vlist-t%20vlist-t2%22%3E%3CSPAN%20class%3D%22vlist-r%22%3E%3CSPAN%20class%3D%22vlist%22%3E%3CSPAN%20class%3D%22sizing%20reset-size6%20size3%20mtight%22%3E%3CSPAN%20class%3D%22mord%20mtight%22%3E%3CSPAN%20class%3D%22mord%20text%20mtight%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22vlist-s%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22mbin%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22base%22%3E%3CSPAN%20class%3D%22mord%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22mord%20mathnormal%22%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22mclose%22%3ELSBmin%E2%8B%85%CE%94A)%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3CLI%3E%0A%3CP%3E%E5%90%84%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%20%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%8C%E5%85%A8%E5%8A%A0%E9%80%9F%E7%AF%84%E5%9B%B2%E3%81%AE%E3%82%B5%E3%83%96%E7%AF%84%E5%9B%B2%E3%81%AB%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%E3%81%95%E3%82%8C%E3%82%8B%E3%81%8B%E3%82%92%E6%AE%B5%E9%9A%8E%E7%9A%84%E3%81%AB%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3C%2FLI%3E%0A%3CLI%3E%0A%3CP%3E%E2%80%93360%20g%20%E3%81%8B%E3%82%89%20%2B400%20g%20%E3%81%AA%E3%81%A9%E3%81%AE%E7%AF%84%E5%9B%B2%E3%81%AE%E3%82%8F%E3%81%8B%E3%82%8A%E3%82%84%E3%81%99%E3%81%84%E4%BE%8B%E3%80%82%E5%90%84%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%8C%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E9%87%8D%E3%81%AA%E3%82%8A%E5%90%88%E3%81%A3%E3%81%A6%E9%81%B7%E7%A7%BB%E3%81%99%E3%82%8B%E3%81%8B%E3%82%92%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3C%2FLI%3E%0A%3CLI%3E%0A%3CP%3E%E4%BB%A5%E4%B8%8B%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E8%A8%BC%E6%98%8E%E6%85%A3%E6%80%A7%E8%A8%88%E7%AE%97%3A%3C%2FP%3E%0A%3CDIV%20class%3D%22math%20math-display%22%3E%3CSPAN%20class%3D%22katex-display%22%3E%3CSPAN%20class%3D%22katex%22%3E%3CSPAN%20class%3D%22katex-mathml%22%3E%CE%94AMAX%E2%80%93MIN%3D%E3%83%97%E3%83%AB%E3%83%BC%E3%83%95%E6%85%A3%E6%80%A7%40AMAX%E2%88%92%E3%83%97%E3%83%AB%E3%83%BC%E3%83%95%E6%85%A3%E6%80%A7%40AMINAMAX%E2%88%92AMIN%3C%2FSPAN%3E%3CSPAN%20class%3D%22katex-html%22%3E%3CSPAN%20class%3D%22base%22%3E%3CSPAN%20class%3D%22mord%22%3E%20%CE%94%3C%2FSPAN%3E%3CSPAN%20class%3D%22mord%22%3E%3CSPAN%20class%3D%22mord%20mathnormal%22%3E%20A%3C%2FSPAN%3E%3CSPAN%20class%3D%22msupsub%22%3E%3CSPAN%20class%3D%22vlist-t%20vlist-t2%22%3E%3CSPAN%20class%3D%22vlist-r%22%3E%3CSPAN%20class%3D%22vlist%22%3E%3CSPAN%20class%3D%22sizing%20reset-size6%20size3%20mtight%22%3E%3CSPAN%20class%3D%22mord%20mtight%22%3E%3CSPAN%20class%3D%22mord%20text%20mtight%22%3E%20MAX%E2%80%93MIN%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22vlist-s%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22mrel%22%3E%20%3D%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22base%22%3E%3CSPAN%20class%3D%22mord%22%3E%3CSPAN%20class%3D%22mfrac%22%3E%3CSPAN%20class%3D%22vlist-t%20vlist-t2%22%3E%3CSPAN%20class%3D%22vlist-r%22%3E%3CSPAN%20class%3D%22vlist%22%3E%3CSPAN%20class%3D%22mord%20mathnormal%22%3E%20A%3C%2FSPAN%3E%3CSPAN%20class%3D%22msupsub%22%3E%3CSPAN%20class%3D%22sizing%20reset-size6%20size3%20mtight%22%3E%3CSPAN%20class%3D%22mord%20mtight%22%3E%3CSPAN%20class%3D%22mord%20text%20mtight%22%3E%20MAX%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22vlist-s%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22mbin%22%3E%20%E2%88%92%3C%2FSPAN%3E%3CSPAN%20class%3D%22mord%20mathnormal%22%3E%20A%3C%2FSPAN%3E%3CSPAN%20class%3D%22msupsub%22%3E%3CSPAN%20class%3D%22sizing%20reset-size6%20size3%20mtight%22%3E%3CSPAN%20class%3D%22mord%20mtight%22%3E%3CSPAN%20class%3D%22mord%20text%20mtight%22%3E%20MIN%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22vlist-s%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22mord%20text%22%3E%20%E3%83%97%E3%83%AB%E3%83%BC%E3%83%95%20%E6%85%A3%E6%80%A7%40A%3C%2FSPAN%3E%3CSPAN%20class%3D%22msupsub%22%3E%3CSPAN%20class%3D%22sizing%20reset-size6%20size3%20mtight%22%3E%3CSPAN%20class%3D%22mord%20mtight%22%3E%3CSPAN%20class%3D%22mord%20text%20mtight%22%3E%20MAX%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22vlist-s%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22mbin%22%3E%20%E2%88%92%3C%2FSPAN%3E%3CSPAN%20class%3D%22mord%20text%22%3E%20%E3%83%97%E3%83%AB%E3%83%BC%E3%83%95%E6%85%A3%E6%80%A7%40A%3C%2FSPAN%3E%3CSPAN%20class%3D%22msupsub%22%3E%3CSPAN%20class%3D%22sizing%20reset-size6%20size3%20mtight%22%3E%3CSPAN%20class%3D%22mord%20mtight%22%3E%3CSPAN%20class%3D%22mord%20text%20mtight%22%3E%20MIN%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22vlist-s%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22vlist-s%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CH3%20id%3D%22toc-hId-164374357%22%20id%3D%22toc-hId-219073581%22%3EUM11145-https%3A%20%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fuser-manual%2FUM11145.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fuser-manual%2FUM11145.pdf%3C%2FA%3E%3C%2FH3%3E%0A%3CP%3E%E3%81%93%E3%81%AE%E3%82%AC%E3%82%A4%E3%83%89%E3%81%A7%E3%81%AF%E3%80%81%E8%A3%9C%E6%AD%A3%E4%B8%AD%E3%81%AB%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%8C%20%CE%94A%20%E3%81%A8%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%E5%80%A4%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3EUUMA%20(Universal%20Uncompensated%20Measurement%20Array)%20%E5%BD%A2%E5%BC%8F%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3CLI%3E%3CCODE%20translate%3D%22no%22%3ETPMS_COMP_ACCEL_X%3C%2FCODE%3E%E3%81%8A%E3%82%88%E3%81%B3%3CCODE%20translate%3D%22no%22%3ETPMS_COMP_ACCEL_Z%3C%2FCODE%3E%E3%82%92%E5%90%AB%E3%82%80%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E8%A3%9C%E6%AD%A3%E9%96%A2%E6%95%B0%E3%82%92%E4%B8%80%E8%A6%A7%E8%A1%A8%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3CLI%3E%E6%AD%A3%E7%A2%BA%E3%81%AA%E7%B5%90%E6%9E%9C%E3%82%92%E5%BE%97%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E4%B8%8D%E5%8F%AF%E6%AC%A0%E3%81%AA%E3%80%81%E5%B7%A5%E5%A0%B4%E3%81%A7%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%95%E3%82%8C%E3%81%9F%E3%83%88%E3%83%AA%E3%83%A0%E4%BF%82%E6%95%B0%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E8%A3%9C%E6%AD%A3%E3%81%8C%E8%A1%8C%E3%82%8F%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E2%80%93175%20g%20%EF%BD%9E%20%2B550%20g%20%E3%81%AE%E7%AF%84%E5%9B%B2%E3%81%A7%E3%81%AF%E3%80%81%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%E6%89%8B%E9%A0%86%E3%81%AF%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%81%AB%E9%80%86%E3%81%AE%E9%A0%86%E5%BA%8F%E3%81%A7%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fdocs.nxp.com%2Fbundle%2FUM11227%2Fpage%2Ftopics%2Foptional_acceleration_measurements.html%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fdocs.nxp.com%2Fbundle%2FUM11227%2Fpage%2Ftopics%2Foptional_acceleration_measurements.html%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22JozefKozon_0-1752036362796.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JozefKozon_0-1752036362796.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F346668i36554471971036C7%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22JozefKozon_0-1752036362796.png%22%20alt%3D%22JozefKozon_0-1752036362796.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%95%AC%E5%85%B7%E3%80%81%3C%2FP%3E%0A%3CP%3E%E3%83%A8%E3%82%BC%E3%83%95%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2129295%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Clarification%20on%20Offset-Step%20Identification%20and%20Conversion%20for%20NTM88x12%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2129295%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%83%A8%E3%82%BC%E3%83%95%E3%81%95%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E6%98%8E%E7%A2%BA%E3%81%AA%E3%81%94%E5%9B%9E%E7%AD%94%E3%82%92%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%81%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%83%9E%E3%82%AF%E3%83%AD%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81AN13614%20%E3%82%A2%E3%83%AB%E3%82%B4%E3%83%AA%E3%82%BA%E3%83%A0%E3%82%92%E8%AA%AC%E6%98%8E%E3%81%A9%E3%81%8A%E3%82%8A%E3%81%AB%E5%AE%9F%E8%A3%85%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3E%2F%2F%20LSB%20limits%20for%20compensated%20value%0A%23define%20LSB_A_MIN%20%20%20%20%202%20%20%20%20%2F%2F%20LSB%0A%23define%20LSB_A_MAX%20%20%201022%20%20%20%2F%2F%20LSB%0A%0A%2F%2F%20Number%20of%20half-bands%20from%20AN13614%0A%23define%20HALF_BANDS_A%2017.0f%20%20%0A%0A%2F%2F%20Band%20step%20size%20(G)%0A%23define%20CALC_STEP(min%2C%20max)%20%20%20%20%20%20(%20((max)%20-%20(min))%20%2F%20HALF_BANDS_A%20)%0A%0A%2F%2F%20Lower%20bound%20of%20a%20band%20(G)%0A%23define%20CALC_BAND_MIN(acc_min%2C%20band%2C%20step)%20%20(%20(acc_min)%20%2B%20((band)%20*%20(step))%20)%0A%0A%2F%2F%20Delta%20(G%2FLSB)%0A%23define%20CALC_DELTA(step)%20%20%20%20%20%20%20%20%20(%20(2.0f%20*%20(step))%20%2F%20(LSB_A_MAX%20-%20LSB_A_MIN)%20)%0A%0A%2F%2F%20Offset%20(G)%0A%23define%20CALC_OFFSET(band_min%2C%20delta)%20%20%20%20%20%20%20%20(%20(band_min)%20-%20(LSB_A_MIN%20*%20(delta))%20)%0A%0Atypedef%20enum%20%7B%0A%20%20%20%20BAND_0%20%3D%200%2C%0A%20%20%20%20BAND_1%2C%0A%20%20%20%20%E2%80%A6%2C%0A%20%20%20%20BAND_15%0A%7D%20accel_band_t%3B%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%E3%81%9F%E3%81%A8%E3%81%88%E3%81%B0%E3%80%81%20%3CSTRONG%3E-80%20g%E2%80%A6%2B90%20g%3C%2FSTRONG%3E%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3E%23define%20N80_90_MIN%20%20%20-80.0f%0A%23define%20N80_90_MAX%20%20%20%2090.0f%0A%23define%20N80_90_STEP%20%20%20CALC_STEP(N80_90_MIN%2C%20N80_90_MAX)%0A%23define%20N80_90_DELTA%20%20CALC_DELTA(N80_90_STEP)%0A%0A%23define%20N80_90_BAND0_MIN%20%20%20%20CALC_BAND_MIN(N80_90_MIN%2C%200%2C%20N80_90_STEP)%20%20%20%2F%2F%20%E2%80%9380.0%20g%0A%23define%20N80_90_BAND0_OFFSET%20CALC_OFFSET(N80_90_BAND0_MIN%2C%20N80_90_DELTA)%0A%E2%80%A6%20(bands%201%20through%2015)%3C%2FCODE%3E%3C%2FPRE%3E%3CUL%3E%3CLI%3E%3CP%3E%3CSTRONG%3E%E7%B5%90%E6%9E%9C%3A%3C%2FSTRONG%3E%20-80%E2%80%A6%2B90%20g%20%E3%81%AE%E7%AF%84%E5%9B%B2%E3%81%A7%E3%81%AF%E3%80%81%E8%A8%88%E7%AE%97%E3%81%97%E3%81%9F%E3%83%90%E3%83%B3%E3%83%89%E5%88%B6%E9%99%90%E3%81%A8%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%E3%81%AF%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%81%A8%E5%AE%8C%E5%85%A8%E3%81%AB%E4%B8%80%E8%87%B4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3E%E5%95%8F%E9%A1%8C%3A%3C%2FSTRONG%3E%E3%81%9D%E3%81%AE%E4%BB%96%E3%81%AE%E7%AF%84%E5%9B%B2%20(%E2%80%93360%E2%80%A6%2B400%20g%E3%80%81%E2%80%93120%E2%80%A6%2B520%20g%E3%80%81%E2%80%93175%E2%80%A6%2B550%20g%E3%80%81%E2%80%93400%E2%80%A6%2B400%20g)%20%E3%81%A7%E3%81%AF%E3%80%81%E5%80%A4%E3%81%8C%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%80%A4%E3%81%A8%E5%A4%A7%E3%81%8D%E3%81%8F%E7%95%B0%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSTRONG%3E%E8%B3%AA%E5%95%8F%3A%3C%2FSTRONG%3E%205%20%E3%81%A4%E3%81%AE%E5%8A%A0%E9%80%9F%E7%AF%84%E5%9B%B2%E3%81%9D%E3%82%8C%E3%81%9E%E3%82%8C%E3%81%AE%2016%20%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%80%81%CE%94A%E3%80%81%E8%A8%BC%E6%98%8E%E6%85%A3%E6%80%A7%20(%40A%E2%82%98%E1%B5%A2%E2%82%99)%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%E5%80%A4%E3%81%AE%E5%AE%8C%E5%85%A8%E3%81%AA%E3%82%BB%E3%83%83%E3%83%88%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%99%E3%82%8B%20NXP%20%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%20(%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20%E3%83%8E%E3%83%BC%E3%83%88%E3%80%81%E3%82%A8%E3%83%A9%E3%83%83%E3%82%BF%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E3%82%B9%E3%83%97%E3%83%AC%E3%83%83%E3%83%89%E3%82%B7%E3%83%BC%E3%83%88)%20%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E8%A1%A8%E3%82%84%E6%95%B0%E5%BC%8F%E3%81%8C%E3%81%82%E3%82%8C%E3%81%B0%E3%80%81%E5%AE%9F%E8%A3%85%E3%82%92%E6%A4%9C%E8%A8%BC%E3%81%97%E3%81%A6%E4%BF%AE%E6%AD%A3%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AB%E5%BD%B9%E7%AB%8B%E3%81%A1%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%82%8B%E3%83%92%E3%83%B3%E3%83%88%E3%82%84%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%8C%E3%81%82%E3%82%8C%E3%81%B0%E3%80%81%E3%81%9C%E3%81%B2%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E2%80%94%20%E3%82%AB%E3%83%BC%E3%83%95%E3%82%A7%E3%82%A4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2128727%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Clarification%20on%20Offset-Step%20Identification%20and%20Conversion%20for%20NTM88x12%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2128727%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%83%A8%E3%82%BC%E3%83%95%E3%81%95%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E6%98%8E%E7%A2%BA%E3%81%AA%E3%81%94%E5%9B%9E%E7%AD%94%E3%82%92%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%81%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%83%9E%E3%82%AF%E3%83%AD%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81AN13614%20%E3%82%A2%E3%83%AB%E3%82%B4%E3%83%AA%E3%82%BA%E3%83%A0%E3%82%92%E8%AA%AC%E6%98%8E%E3%81%A9%E3%81%8A%E3%82%8A%E3%81%AB%E5%AE%9F%E8%A3%85%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%3E%2F%2F%20%E8%A3%9C%E6%AD%A3%E5%80%A4%E3%81%AE%20LSB%20%E5%88%B6%E9%99%90%3CBR%20%2F%3E%23define%20LSB_A_MIN%202%20%2F%2F%20LSB%3CBR%20%2F%3E%20%23define%20LSB_A_MAX%201022%20%2F%2F%20LSB%3C%2FP%3E%3CP%3E%2F%2F%20AN13614%E3%81%8B%E3%82%89%E3%81%AE%E3%83%8F%E3%83%BC%E3%83%95%E3%83%90%E3%83%B3%E3%83%89%E3%81%AE%E6%95%B0%3CBR%20%2F%3E%23%E5%AE%9A%E7%BE%A9%20HALF_BANDS_A%2017.0%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3E%2F%2F%20%E8%A6%96%E8%A6%9A%E7%9A%84%E3%81%AA%E8%A8%BC%E6%8B%A0%3A%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%2F%2F%20%E3%83%90%E3%83%B3%E3%83%89%3A%20%7C--0---%7C---2---%7C--4---%7C---6---%7C---8---%7C---10---%7C---12---%7C---14---%7C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%2F%2F%20%E5%88%86%20%7C-1-%7C-2-%7C-3-%7C-4-%7C-5-%7C-6-%7C-7-%7C-8-%7C-9-%7C-10-%7C-11-%7C-12-%7C-13-%7C-14-%7C-15-%7C-16-%7C-17-%7C%E3%83%9E%E3%83%83%E3%82%AF%E3%82%B9%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%2F%2F%20%E3%83%90%E3%83%B3%E3%83%89%3A%20%7C---1---%7C---3---%7C--5---%7C---7---%7C---9---%7C---11----%7C---13---%7C---15----%7C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3CP%3E%2F%2F%20%E3%83%90%E3%83%B3%E3%83%89%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%82%B5%E3%82%A4%E3%82%BA%20(G)%3CBR%20%2F%3E%20%23define%20CALC_STEP(min%2C%20max)%20(float)((max%20-%20min)%20%2F%20HALF_BANDS_A)%3C%2FP%3E%3CP%3E%2F%2F%20%E3%83%90%E3%83%B3%E3%83%89%E3%81%AE%E4%B8%8B%E9%99%90%E5%80%A4%20(G)%3CBR%20%2F%3E%20%23define%20CALC_BAND_MIN(acc_min%2C%20band%2C%20step)%20(float)(acc_min%20%2B%20(band%20*%20step))%3C%2FP%3E%3CP%3E%2F%2F%20%E3%83%87%E3%83%AB%E3%82%BF%20(G%2FLSB)%3CBR%20%2F%3E%20%23define%20CALC_DELTA(step)%20(float)((2.0f*%20%E3%82%B9%E3%83%86%E3%83%83%E3%83%97)%20%2F%20(LSB_A_MAX%20-%20LSB_A_MIN))%3C%2FP%3E%3CP%3E%2F%2F%20%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%20(G)%3CBR%20%2F%3E%20%23define%20CALC_OFFSET(band_min%2C%20delta)%20(float)(band_min%20-%20(LSB_A_MIN%20*%20delta))%3C%2FP%3E%3CP%3Etypedef%E5%88%97%E6%8C%99%E5%9E%8B%20%7B%3CBR%20%2F%3E%E3%83%90%E3%83%B3%E3%83%890%20%3D%200%E3%80%81%3CBR%20%2F%3E%E3%83%90%E3%83%B3%E3%83%89_1%E3%80%81%3CBR%20%2F%3E%20%E2%80%A6%E3%80%81%3CBR%20%2F%3E%E3%83%90%E3%83%B3%E3%83%89_15%3CBR%20%2F%3E%20%7D%20accel_band_t%3B%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%E3%81%9F%E3%81%A8%E3%81%88%E3%81%B0%E3%80%81%20%3CSTRONG%3E-80%20g%E2%80%A6%2B90%20g%3C%2FSTRONG%3E%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CBLOCKQUOTE%3E%3CP%3E%23%E5%AE%9A%E7%BE%A9%20N80_90_MIN%20-80.0f%3CBR%20%2F%3E%20%23%E5%AE%9A%E7%BE%A9%20N80_90_MAX%2090.0f%3CBR%20%2F%3E%20%23N80_90_STEP%20CALC_STEP(N80_90_MIN%2C%20N80_90_MAX)%20%E3%82%92%E5%AE%9A%E7%BE%A9%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%23N80_90_DELTA%20CALC_DELTA(N80_90_STEP)%20%E3%82%92%E5%AE%9A%E7%BE%A9%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%23define%20N80_90_BAND0_MIN%20CALC_BAND_MIN(N80_90_MIN%2C%20BAND_0%2C%20N80_90_STEP)%20%2F%2F%20%E2%80%9380.0%20g%3CBR%20%2F%3E%20%23N80_90_BAND0_OFFSET%20CALC_OFFSET(N80_90_BAND0_MIN%2C%20N80_90_DELTA)%20%E3%82%92%E5%AE%9A%E7%BE%A9%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%E2%80%A6%EF%BC%88%E3%83%90%E3%83%B3%E3%83%891%EF%BD%9E15%EF%BC%89%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CUL%3E%3CLI%3E%3CP%3E%3CSTRONG%3E%E7%B5%90%E6%9E%9C%3A%3C%2FSTRONG%3E%20-80%E2%80%A6%2B90%20g%20%E3%81%AE%E7%AF%84%E5%9B%B2%E3%81%A7%E3%81%AF%E3%80%81%E8%A8%88%E7%AE%97%E3%81%97%E3%81%9F%E3%83%90%E3%83%B3%E3%83%89%E5%88%B6%E9%99%90%E3%81%A8%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%E3%81%AF%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%81%A8%E5%AE%8C%E5%85%A8%E3%81%AB%E4%B8%80%E8%87%B4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3E%E5%95%8F%E9%A1%8C%3A%3C%2FSTRONG%3E%E3%81%9D%E3%81%AE%E4%BB%96%E3%81%AE%E7%AF%84%E5%9B%B2%20(%E2%80%93360%E2%80%A6%2B400%20g%E3%80%81%E2%80%93120%E2%80%A6%2B520%20g%E3%80%81%E2%80%93175%E2%80%A6%2B550%20g%E3%80%81%E2%80%93400%E2%80%A6%2B400%20g)%20%E3%81%A7%E3%81%AF%E3%80%81%E5%80%A4%E3%81%8C%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%80%A4%E3%81%A8%E5%A4%A7%E3%81%8D%E3%81%8F%E7%95%B0%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSTRONG%3E%E8%B3%AA%E5%95%8F%3A%3C%2FSTRONG%3E%205%20%E3%81%A4%E3%81%AE%E5%8A%A0%E9%80%9F%E7%AF%84%E5%9B%B2%E3%81%9D%E3%82%8C%E3%81%9E%E3%82%8C%E3%81%AE%2016%20%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%80%81%CE%94A%E3%80%81%E8%A8%BC%E6%98%8E%E6%85%A3%E6%80%A7%20(%40A%E2%82%98%E1%B5%A2%E2%82%99)%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%E5%80%A4%E3%81%AE%E5%AE%8C%E5%85%A8%E3%81%AA%E3%82%BB%E3%83%83%E3%83%88%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%99%E3%82%8B%20NXP%20%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%20(%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20%E3%83%8E%E3%83%BC%E3%83%88%E3%80%81%E3%82%A8%E3%83%A9%E3%83%83%E3%82%BF%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E3%82%B9%E3%83%97%E3%83%AC%E3%83%83%E3%83%89%E3%82%B7%E3%83%BC%E3%83%88)%20%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E8%A1%A8%E3%82%84%E6%95%B0%E5%BC%8F%E3%81%8C%E3%81%82%E3%82%8C%E3%81%B0%E3%80%81%E5%AE%9F%E8%A3%85%E3%82%92%E6%A4%9C%E8%A8%BC%E3%81%97%E3%81%A6%E4%BF%AE%E6%AD%A3%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AB%E5%BD%B9%E7%AB%8B%E3%81%A1%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%82%8B%E3%83%92%E3%83%B3%E3%83%88%E3%82%84%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%8C%E3%81%82%E3%82%8C%E3%81%B0%E3%80%81%E3%81%9C%E3%81%B2%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E-%E3%82%AB%E3%83%BC%E3%83%95%E3%82%A7%E3%82%A4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2127764%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Clarification%20on%20Offset-Step%20Identification%20and%20Conversion%20for%20NTM88x12%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2127764%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81Kafei42%E3%81%95%E3%82%93%3C%2FP%3E%0A%3COL%3E%0A%3CLI%3E%3CSTRONG%3EAN13614%20%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E8%AD%98%E5%88%A5%E3%81%AE%E5%AE%9F%E8%A3%85%3C%2FSTRONG%3E%3CBR%20%2F%3EAN13614%20%E3%81%A7%E3%81%AF%E3%80%81%E6%A8%99%E6%BA%96%20%C2%B1g%20%E7%AF%84%E5%9B%B2%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%AB%E3%80%81%E3%80%8C%E9%96%8B%E5%A7%8B%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%20%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%80%8D%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%A6%E3%80%81%E7%94%9F%E3%81%AE%20ADC%20%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E5%80%A4%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%81%9D%E3%82%8C%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%82%A2%E3%83%AB%E3%82%B4%E3%83%AA%E3%82%BA%E3%83%A0%E3%82%92%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E2%80%93175%20g%E2%80%A6%2B550%20g%20%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81NTM88Jxx5S-DS%20%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%81%AE%E8%A1%A8%2018%20%E3%81%AB%E3%81%AF%E3%80%81%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%20%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%8C%E9%80%86%E3%81%AE%E9%A0%86%E5%BA%8F%E3%81%A7%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82AN13614%E3%83%AD%E3%82%B8%E3%83%83%E3%82%AF%E3%82%92%E3%81%93%E3%81%AE%E7%AF%84%E5%9B%B2%E3%81%AB%E7%A7%BB%E6%A4%8D%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%E3%81%AE%E6%AF%94%E8%BC%83%E3%82%92%E5%8D%98%E7%B4%94%E3%81%AB%E5%8F%8D%E8%BB%A2%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%88%E3%81%A4%E3%81%BE%E3%82%8A%E3%80%81%E3%83%8E%E3%83%BC%E3%83%88%E3%81%8C%E5%A2%97%E5%8A%A0%E3%81%99%E3%82%8B%E3%81%A8%E3%81%93%E3%82%8D%E3%81%A7%E3%83%8E%E3%83%BC%E3%83%88%E3%82%92%E6%B8%9B%E5%B0%91%E3%81%95%E3%81%9B%E3%80%81%E3%81%9D%E3%81%AE%E9%80%86%E3%82%82%E8%A1%8C%E3%81%86%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CP%3E%3CFONT%20color%3D%22%230000FF%22%3E%5BA%5D%20%E3%81%AF%E3%81%84%E3%80%81%E6%8B%A1%E5%BC%B5%E7%AF%84%E5%9B%B2%EF%BC%88-175%20g%20%EF%BD%9E%20%2B550%20g%EF%BC%89%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%AFNTM88Jxx5S-DS%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%81%AE%E8%A1%A818%E3%81%AB%E9%80%86%E3%81%AE%E9%A0%86%E5%BA%8F%E3%81%A7%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81AN13614%20%E3%82%A2%E3%83%AB%E3%82%B4%E3%83%AA%E3%82%BA%E3%83%A0%E3%82%92%E7%A7%BB%E6%A4%8D%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%20%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%E3%81%AE%E6%AF%94%E8%BC%83%E3%82%92%E5%8F%8D%E8%BB%A2%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E2.%20%E5%A4%89%E6%8F%9B%E5%BC%8F%E3%81%AE%E9%81%A9%E7%94%A8%E7%AF%84%E5%9B%B2%3CBR%20%2F%3E%3C%2FSTRONG%3EAN13614%20%E3%81%A7%E3%81%AF%E5%8A%A0%E9%80%9F%E5%BA%A6%E4%BC%9D%E9%81%94%E9%96%A2%E6%95%B0%E3%82%92%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%AE%9A%E7%BE%A9%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22JozefKozon_0-1751519409693.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JozefKozon_0-1751519409693.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F345899i4E9430C01513580D%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22JozefKozon_0-1751519409693.png%22%20alt%3D%22JozefKozon_0-1751519409693.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%20%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%AE%E9%A0%86%E5%BA%8F%E3%81%8C%E9%80%86%E3%81%A7%E3%81%82%E3%81%A3%E3%81%A6%E3%82%82%E3%80%81%E3%81%93%E3%81%AE%E5%90%8C%E3%81%98%E5%BC%8F%E3%82%92%20%E2%80%93175%20g%E2%80%A6%2B550%20g%20%E3%81%AE%E7%AF%84%E5%9B%B2%E3%81%AB%E3%81%9D%E3%81%AE%E3%81%BE%E3%81%BE%E9%81%A9%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E3%80%81%E5%BC%8F%E8%87%AA%E4%BD%93%E3%82%92%E8%AA%BF%E6%95%B4%E3%81%97%E3%81%A6%E5%8F%8D%E8%BB%A2%E3%82%92%E8%80%83%E6%85%AE%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3CBR%20%2F%3E%3CFONT%20color%3D%22%230000FF%22%3E%5BA%5D%20AN13614%E3%81%A7%E5%AE%9A%E7%BE%A9%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%8A%A0%E9%80%9F%E5%BA%A6%E4%BC%9D%E9%81%94%E9%96%A2%E6%95%B0%E3%81%AF%E3%80%81%E6%8B%A1%E5%BC%B5%E7%AF%84%E5%9B%B2%E3%81%A7%E3%82%82%E3%81%9D%E3%81%AE%E3%81%BE%E3%81%BE%E9%81%A9%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E5%BC%8F%E8%87%AA%E4%BD%93%E3%81%AF%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%AE%E9%A0%86%E5%BA%8F%E3%81%A8%E3%81%AF%E7%8B%AC%E7%AB%8B%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E7%94%9F%E3%81%AEADC%E5%80%A4%E3%81%A8%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E6%BC%94%E7%AE%97%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E3.%20%E4%BD%BF%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AA%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%82%B5%E3%83%96%E3%82%BB%E3%83%83%E3%83%88%3CBR%20%2F%3E%3C%2FSTRONG%3EAN13614%20%E3%81%AB%E3%81%AF%E3%80%81%E3%80%8C%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%E7%89%B9%E5%AE%9A%E3%81%AE%E3%83%A2%E3%83%87%E3%83%AB%E3%81%A7%E3%81%AF%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%20%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%204%20%EF%BD%9E%2010%20%E3%81%AE%E3%81%BF%E3%81%8C%E4%BD%BF%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%80%8D%E3%81%A8%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82NTM88Jxx5S-DS%20%E3%81%BE%E3%81%9F%E3%81%AF%E9%96%A2%E9%80%A3%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%81%AE%E3%81%84%E3%81%9A%E3%82%8C%E3%81%AB%E3%82%82%E3%80%81%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E7%AF%84%E5%9B%B2%E3%81%AE%E5%88%B6%E9%99%90%E3%81%AF%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E4%BB%96%E3%81%AE%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%90%E3%83%AA%E3%82%A2%E3%83%B3%E3%83%88%E3%81%A7%E3%81%AF%E3%81%A9%E3%81%AE%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%20%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%20%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%E3%81%8C%E5%85%AC%E5%BC%8F%E3%81%AB%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%20%E3%81%BE%E3%81%9F%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AF%E3%81%A9%E3%81%93%E3%81%AB%E6%96%87%E6%9B%B8%E5%8C%96%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22JozefKozon_1-1751519409618.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JozefKozon_1-1751519409618.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F345900iC3535A5B8F5206CE%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22JozefKozon_1-1751519409618.png%22%20alt%3D%22JozefKozon_1-1751519409618.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22JozefKozon_2-1751519409752.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JozefKozon_2-1751519409752.png%22%20style%3D%22width%3A%20373px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F345901i3BACCD726C87157F%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22JozefKozon_2-1751519409752.png%22%20alt%3D%22JozefKozon_2-1751519409752.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20color%3D%22%230000FF%22%3E%5BA%5D%20%E2%80%93175%20g%20%EF%BD%9E%20%2B550%20g%20%E3%81%AE%E3%83%90%E3%83%AA%E3%82%A2%E3%83%B3%E3%83%88%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%9F%E5%88%B6%E9%99%90%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E5%B0%86%E6%9D%A5%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E6%94%B9%E8%A8%82%E7%89%88%E3%81%BE%E3%81%9F%E3%81%AF%E6%AD%A3%E8%AA%A4%E8%A1%A8%E3%81%A7%E7%89%B9%E3%81%AB%E6%8C%87%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%AA%E3%81%84%E9%99%90%E3%82%8A%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%20%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%8C%E3%81%93%E3%81%AE%E7%AF%84%E5%9B%B2%E3%81%A7%E4%BD%BF%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%82%E3%82%8B%E3%81%A8%E6%83%B3%E5%AE%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%E6%95%AC%E5%85%B7%E3%80%81%3C%2FP%3E%0A%3CP%3E%E3%83%A8%E3%82%BC%E3%83%95%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
