Can we use (MPX5010DP) for dynamic pressure analysis ?
omaryousry
We are working on analysis pressure change across an airfoil; the changes would be highly dynamic to the unsteadiness of our problem. Would that device be able to capture the dynamic changes ?
miguelsalhuana
Omar,
Depending on the sampling frequency of your system you should be able to implement this sensor for your application.
regards,
Miguel
