8451 interrupts
8451 interrupts
3,234件の閲覧回数
JBM
Contributor V
I am trying to get tap detection working using an MMA8451QR1 and a Kinetis K22.  I have used this combination in a number of other products and haven't had any problems.  This is the first time I'm trying to get tap detection working.
I am running the MEMS at 200 Hz, trying to get interrupts for data and tap detection.  I get interrupts for data, and the first one for tap detection, but after that, nothing.
Unfortunately, I can't post all my code, so I'll try to show what is going on.
I have a number of structs which are unions of bit fields and "Byte" data.  Here is my configuration of the MEMS:
void mma8451qr1_configure_tap(void)
  MMA_CTRL_REG1 ctrl_reg1;
  MMA_CTRL_REG2 ctrl_reg2;
  MMA_CTRL_REG3 ctrl_reg3;
  MMA_CTRL_REG4 ctrl_reg4;
  MMA_CTRL_REG5 ctrl_reg5;
  MMA_XYZDATACFG ctrl_reg_xyz_data_cfg;
  MMA_PULSE_CFG pulse_cfg;
  MMA_PULSE_THSX pulse_thsx;
  MMA_PULSE_THSY pulse_thsy;
  MMA_PULSE_THSZ pulse_thsz;
  MMA_PULSE_TMLT pulse_tmlt;
  MMA_PULSE_LTCY pulse_ltcy;
  MMA_PULSE_WIND pulse_wind;
  ctrl_reg2.Bits.RST = true;
  mma8451qr1_set_register(MMA8451QR1_REG_CTRL_REG2, ctrl_reg2.Byte);
  do
    ctrl_reg2.Byte = mma8451qr1_get_register(MMA8451QR1_REG_CTRL_REG2);
  } while (ctrl_reg2.Bits.RST);
  /* CTRL_REG1 */
  ctrl_reg1.Byte = mma8451qr1_get_register(MMA8451QR1_REG_CTRL_REG1);
  ctrl_reg1.Bits.DATA_RATE = MMA8451QR1_DATA_RATE_200;
  mma8451qr1_set_register(MMA8451QR1_REG_CTRL_REG1, ctrl_reg1.Byte);
  ctrl_reg_xyz_data_cfg.Bits.FS = MMA8451QR1_FSRANGE_2G;
  mma8451qr1_set_register(MMA8451QR1_REG_XYZ_DATA_CFG, ctrl_reg_xyz_data_cfg.Byte);
  /* CTRL_REG2 */
  ctrl_reg2.Bits.MODS = MMA8451QR1_OVS_MODE_HRES;
  /* CTRL_REG4 */
  ctrl_reg4.Byte = mma8451qr1_get_register(MMA8451QR1_REG_CTRL_REG4);
  ctrl_reg4.Bits.INT_EN_PULSE = true;
  ctrl_reg4.Bits.INT_EN_DRDY  = true;
  mma8451qr1_set_register(MMA8451QR1_REG_CTRL_REG4, ctrl_reg4.Byte);
  /* CTRL_REG5 */
  ctrl_reg5.Byte = mma8451qr1_get_register(MMA8451QR1_REG_CTRL_REG5);
  ctrl_reg5.Bits.INT_CFG_PULSE = false;   /* false == INT2 */
  ctrl_reg5.Bits.INT_CFG_DRDY  = false;
  mma8451qr1_set_register(MMA8451QR1_REG_CTRL_REG5, ctrl_reg5.Byte);
  pulse_cfg.Bits.XSPEFE = 1;
  pulse_cfg.Bits.XDPEFE = 0;
  pulse_cfg.Bits.YSPEFE = 1;
  pulse_cfg.Bits.YDPEFE = 0;
  pulse_cfg.Bits.ZSPEFE = 1;
  pulse_cfg.Bits.ZDPEFE = 0;
  pulse_cfg.Bits.ELE    = 1;
  pulse_cfg.Bits.DPA    = 0;
  mma8451qr1_set_register(MMA8451QR1_REG_PULSE_CFG, pulse_cfg.Byte);
  pulse_thsx.Byte = 0x20;
  mma8451qr1_set_register(MMA8451QR1_REG_PULSE_THSX, pulse_thsx.Byte);
  pulse_thsy.Byte = 0x20;
  mma8451qr1_set_register(MMA8451QR1_REG_PULSE_THSY, pulse_thsy.Byte);
  pulse_thsz.Byte = 0x2A;
  mma8451qr1_set_register(MMA8451QR1_REG_PULSE_THSZ, pulse_thsz.Byte);
  pulse_tmlt.Byte = 0x28;
  mma8451qr1_set_register(MMA8451QR1_REG_PULSE_TMLT, pulse_tmlt.Byte);
  pulse_ltcy.Byte = 0x28;
  mma8451qr1_set_register(MMA8451QR1_REG_PULSE_LTCY, pulse_ltcy.Byte);
  pulse_wind.Byte = 0x0F;
  mma8451qr1_set_register(MMA8451QR1_REG_PULSE_WIND, pulse_wind.Byte);
  mma8451qr1_set_active();
I have the INT1 and INT2 connected to two pins on the K22 and the interrupts work.   The pins on the K22 are configured as GPIO, with interrupts.  The handler is here:
void PORTD_IRQHandler(void)
  if (PORTD_PCR4 & PORT_PCR_ISF_MASK)
    g_main_event_flags.bits.do_mems = true;
    PORTD_PCR4 |= PORT_PCR_ISF_MASK;
  if (PORTD_PCR6 & PORT_PCR_ISF_MASK)
    PORTD_PCR6 |= PORT_PCR_ISF_MASK;
The g_main_event_flags struct is also a union and declared globally.
In my main processing loop (main.c), I have the following:
     * Handle MEMS events
    if (g_main_event_flags.bits.do_mems)
      MMA_INT_SOURCE int_src;
      MMA_PULSE_SRC pulse_src;
      int_src.Byte = mma8451qr1_get_int_source();
      if (int_src.Bits.SRC_PULSE)
        pulse_src.Byte = mma8451qr1_read_pulse();
        ports_led(true);
      if (int_src.Bits.SRC_DRDY)
        mma8451qr1_read_data();
      g_main_event_flags.bits.do_mems = false;
My understanding from reading the spec is that I should read the SRC_PULSE register to clear the interrupt and read the data from the MEMS to clear the SRC_DRDY interrupt.  All the routines appear to work, I just never get a second interrupt.  It makes me think I'm not clearing something I should.
ports_led() sets a GPIO to turn on an LED.  It also sets a clock counter to keep it on for about 200 ms (interrupt driven) so that I can see the taps and then the LED is turned off.
I have gotten as many as three taps before it stops working.  I can pause the debugger and it the K22 is not frozen (still executes my main event loop).
Thanks for the help.
7 返答(返信)
2,947件の閲覧回数
JBM
Contributor V
I saw that page.  I finally disabled the DRDY interrupt and I have it working. That seems a bit extreme though.  Shouldn't I be able to get both interrupts (PULSE and DRDY) so that I can use the data and get taps?
Thanks!
2,947件の閲覧回数
david_diaz
Hello James,
I am glad to know your application works properly.
Indeed, you can enable both interrupt sources at the CTRL_REG4 register.
I recommend reading the INT_SOURCE register once an interrupt is triggered in order to know the source of the interrupt. Please note that the bits are set by a low to high transition and are cleared by reading the appropriate interrupt source register.
Please let me know if this information helps.
David
2,947件の閲覧回数
JBM
Contributor V
I did that.  Please note that it is not working properly.  If I enable the DRDY interrupt, I only get a few tap interrupts.  This is what I stated above and showed in the initial code.  As I said later, the tapping only works if I disable the DRDY interrupt.
2,947件の閲覧回数
david_diaz
Hello James,
I noticed that you are using an ODR of 200Hz. It means that every 5ms an interrupt will be triggered due to a new set of data is ready (DRDY interrupt).
I assume that is the reason you are not able to generate a PULSE interrupt.
In this case, I recommend using a slower ODR in order to have enough time between the every new set of data.
Please let me know your results.
David
2,947件の閲覧回数
JBM
Contributor V
I tried it at a slower rate and it worked better, but not completely.
I removed the calls to read the INT_SOURCE register and just set my flags based on the interrupts (INT1 for pulse and INT2 for data) and it appears to work fine.  Not sure why reading the INT_SOURCE register makes things not work, I'm sure it's something I'm doing somewhere, but I can't find it.
I can read data at 200 Hz and get tap interrupts.  I don't think that 5 ms is a short time for my interrupts considering all I'm doing is setting a flag.  This is running on a K22 at 40 MHz.  Just to verify, I stepped the speed up to 800 Hz and it still works (without reading the INT_SOURCE register).
Thanks for the help everybody!
2,947件の閲覧回数
david_diaz
Hello James,
Thank you very much for writing.
In this case, I recommend to use the example project below as a reference for your application.
MMA8451Q -Single Tap Detection Bare metal example project
The Kinetis KL25Z is used in the project mentioned but it is useful for you. Please refer to the registers configuration.
Please let me know if you have any further question and I will be glad to help.
David
2,947件の閲覧回数
JBM
Contributor V
I've done a little more experimenting.  If I turn off interrupts for data ready (INT_EN_DRDY = 0), it works.  I find it hard to believe that you can't do both at once, so it must be something I'm doing.
%3CLINGO-SUB%20id%3D%22lingo-sub-654874%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E8451%E5%9B%9E%E3%81%AE%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-654874%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EMMA8451QR1%20%E3%81%A8%20Kinetis%20K22%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%BF%E3%83%83%E3%83%97%E6%A4%9C%E5%87%BA%E3%82%92%E6%A9%9F%E8%83%BD%E3%81%95%E3%81%9B%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%AF%E3%81%93%E3%81%AE%E7%B5%84%E3%81%BF%E5%90%88%E3%82%8F%E3%81%9B%E3%82%92%E4%BB%96%E3%81%AE%E5%A4%9A%E3%81%8F%E3%81%AE%E8%A3%BD%E5%93%81%E3%81%A7%E3%82%82%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E5%95%8F%E9%A1%8C%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E3%82%BF%E3%83%83%E3%83%97%E6%A4%9C%E5%87%BA%E3%82%92%E6%A9%9F%E8%83%BD%E3%81%95%E3%81%9B%E3%82%88%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AF%E4%BB%8A%E5%9B%9E%E3%81%8C%E5%88%9D%E3%82%81%E3%81%A6%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%20MEMS%20%E3%82%92%20200%20Hz%20%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%97%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%E3%81%A8%E3%82%BF%E3%83%83%E3%83%97%E6%A4%9C%E5%87%BA%E3%81%AE%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AB%E5%AF%BE%E3%81%99%E3%82%8B%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%81%A8%E3%80%81%E3%82%BF%E3%83%83%E3%83%97%E6%A4%9C%E5%87%BA%E3%81%AB%E5%AF%BE%E3%81%99%E3%82%8B%E6%9C%80%E5%88%9D%E3%81%AE%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%92%E5%8F%97%E3%81%91%E5%8F%96%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%9D%E3%81%AE%E5%BE%8C%E3%81%AF%E4%BD%95%E3%82%82%E8%B5%B7%E3%81%93%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AE%8B%E5%BF%B5%E3%81%AA%E3%81%8C%E3%82%89%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E6%8A%95%E7%A8%BF%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%81%AE%E3%81%A7%E3%80%81%E4%BD%95%E3%81%8C%E8%B5%B7%E3%81%93%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%8B%E3%82%92%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%BF%E3%81%9F%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%93%E3%83%83%E3%83%88%20%E3%83%95%E3%82%A3%E3%83%BC%E3%83%AB%E3%83%89%E3%81%A8%E3%80%8C%E3%83%90%E3%82%A4%E3%83%88%E3%80%8D%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AE%E7%B5%90%E5%90%88%E4%BD%93%E3%81%A7%E3%81%82%E3%82%8B%E6%A7%8B%E9%80%A0%E4%BD%93%E3%81%8C%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82MEMS%20%E3%81%AE%E6%A7%8B%E6%88%90%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CSTRONG%3Evoid%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSTRONG%3Emma8451qr1_configure_tap%3C%2FSTRONG%3E%20(%20%3CSPAN%20class%3D%22%22%3E%3CSTRONG%3Evoid%3C%2FSTRONG%3E%3C%2FSPAN%3E%20)%3C%2FP%3E%3CP%20class%3D%22%22%3E%7B%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3EMMA_CTRL_REG1%20%3CSPAN%20class%3D%22%22%3Ectrl_reg1%3C%2FSPAN%3E%20%3B%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3EMMA_CTRL_REG2%20%3CSPAN%20class%3D%22%22%3Ectrl_reg2%3C%2FSPAN%3E%20%3B%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3EMMA_CTRL_REG3%20%3CSPAN%20class%3D%22%22%3Ectrl_reg3%3C%2FSPAN%3E%20%3B%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3EMMA_CTRL_REG4%20%3CSPAN%20class%3D%22%22%3Ectrl_reg4%3C%2FSPAN%3E%20%3B%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3EMMA_CTRL_REG5%20%3CSPAN%20class%3D%22%22%3Ectrl_reg5%3C%2FSPAN%3E%20%3B%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3EMMA_XYZDATACFG%3C%2FSPAN%3E%20ctrl_reg_xyz_data_cfg%20%3CSPAN%20class%3D%22%22%3E%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3EMMA_PULSE_CFG%3CSPAN%20class%3D%22%22%3E%E3%83%91%E3%83%AB%E3%82%B9_cfg%3C%2FSPAN%3E%20%3B%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3EMMA_PULSE_THSX%3CSPAN%20class%3D%22%22%3E%E3%83%91%E3%83%AB%E3%82%B9_thsx%3C%2FSPAN%3E%20%3B%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3EMMA_PULSE_THSY%3CSPAN%20class%3D%22%22%3E%E3%83%91%E3%83%AB%E3%82%B9_thsy%3C%2FSPAN%3E%20%3B%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3EMMA_PULSE_THSZ%3CSPAN%20class%3D%22%22%3E%E3%83%91%E3%83%AB%E3%82%B9_thsz%3C%2FSPAN%3E%20%3B%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3EMMA_PULSE_TMLT%3CSPAN%20class%3D%22%22%3E%E3%83%91%E3%83%AB%E3%82%B9_tmlt%3C%2FSPAN%3E%20%3B%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3EMMA_PULSE_LTCY%3CSPAN%20class%3D%22%22%3E%E3%83%91%E3%83%AB%E3%82%B9_ltcy%3C%2FSPAN%3E%20%3B%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3EMMA_PULSE_WIND%3CSPAN%20class%3D%22%22%3E%E3%83%91%E3%83%AB%E3%82%B9%E9%A2%A8%3C%2FSPAN%3E%3B%3C%2FP%3E%3CP%20class%3D%22%22%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3Ectrl_reg2%20%3CSPAN%20class%3D%22%22%3E.%3C%2FSPAN%3E%E3%83%93%E3%83%83%E3%83%88%3CSPAN%20class%3D%22%22%3E.%3C%2FSPAN%3E%20RST%20%3CSPAN%20class%3D%22%22%3E%3D%20true%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSTRONG%3Emma8451qr1_set_register%3C%2FSTRONG%3E%20(MMA8451QR1_REG_CTRL_REG2%E3%80%81%20%3CSPAN%20class%3D%22%22%3Ectrl_reg2%3C%2FSPAN%3E%20%E3%80%82%3CSPAN%20class%3D%22%22%3E%E3%83%90%E3%82%A4%E3%83%88%3C%2FSPAN%3E)%3B%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSTRONG%3E%E3%81%99%E3%82%8B%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%7B%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Ectrl_reg2%3C%2FSPAN%3E%20.%3CSPAN%20class%3D%22%22%3E%E3%83%90%E3%82%A4%E3%83%88%3C%2FSPAN%3E%3D%20%3CSTRONG%3Emma8451qr1_get_register%3C%2FSTRONG%3E%20(MMA8451QR1_REG_CTRL_REG2)%3B%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E%3CSTRONG%3Ewhile%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E(%3C%2FSPAN%3E%20ctrl_reg2%20%3CSPAN%20class%3D%22%22%3E.%3C%2FSPAN%3E%20Bits%20%3CSPAN%20class%3D%22%22%3E.%3C%2FSPAN%3E%20RST%20%3CSPAN%20class%3D%22%22%3E)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3E%2F*%20CTRL_REG1%20*%2F%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Ectrl_reg1%3C%2FSPAN%3E%20.%3CSPAN%20class%3D%22%22%3E%E3%83%90%E3%82%A4%E3%83%88%3C%2FSPAN%3E%3D%20%3CSTRONG%3Emma8451qr1_get_register%3C%2FSTRONG%3E%20(MMA8451QR1_REG_CTRL_REG1)%3B%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Ectrl_reg1%3C%2FSPAN%3E%20.%3CSPAN%20class%3D%22%22%3E%E3%83%93%E3%83%83%E3%83%88%3C%2FSPAN%3E.%20%3CSPAN%20class%3D%22%22%3EDATA_RATE%3C%2FSPAN%3E%20%3D%20MMA8451QR1_DATA_RATE_200%3B%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSTRONG%3Emma8451qr1_set_register%3C%2FSTRONG%3E%20(MMA8451QR1_REG_CTRL_REG1%E3%80%81%20%3CSPAN%20class%3D%22%22%3Ectrl_reg1%3C%2FSPAN%3E%20%E3%80%82%3CSPAN%20class%3D%22%22%3E%E3%83%90%E3%82%A4%E3%83%88%3C%2FSPAN%3E)%3B%3C%2FP%3E%3CP%20class%3D%22%22%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Ectrl_reg_xyz_data_cfg%3C%2FSPAN%3E%20.%3CSPAN%20class%3D%22%22%3E%E3%83%93%E3%83%83%E3%83%88%3C%2FSPAN%3E.%20%3CSPAN%20class%3D%22%22%3EFS%3C%2FSPAN%3E%20%3D%20MMA8451QR1_FSRANGE_2G%3B%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSTRONG%3Emma8451qr1_set_register%3C%2FSTRONG%3E%20(MMA8451QR1_REG_XYZ_DATA_CFG%E3%80%81%20%3CSPAN%20class%3D%22%22%3Ectrl_reg_xyz_data_cfg%3C%2FSPAN%3E%20%E3%80%82%3CSPAN%20class%3D%22%22%3E%E3%83%90%E3%82%A4%E3%83%88%3C%2FSPAN%3E)%3B%3C%2FP%3E%3CP%20class%3D%22%22%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3E%2F*%20CTRL_REG2%20*%2F%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Ectrl_reg2%3C%2FSPAN%3E%20.%3CSPAN%20class%3D%22%22%3E%E3%83%90%E3%82%A4%E3%83%88%3C%2FSPAN%3E%3D%20%3CSTRONG%3Emma8451qr1_get_register%3C%2FSTRONG%3E%20(MMA8451QR1_REG_CTRL_REG2)%3B%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Ectrl_reg2%3C%2FSPAN%3E%20.%3CSPAN%20class%3D%22%22%3E%E3%83%93%E3%83%83%E3%83%88%3C%2FSPAN%3E.%20%3CSPAN%20class%3D%22%22%3EMODS%3C%2FSPAN%3E%20%3D%20MMA8451QR1_OVS_MODE_HRES%3B%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSTRONG%3Emma8451qr1_set_register%3C%2FSTRONG%3E%20(MMA8451QR1_REG_CTRL_REG2%E3%80%81%20%3CSPAN%20class%3D%22%22%3Ectrl_reg2%3C%2FSPAN%3E%20%E3%80%82%3CSPAN%20class%3D%22%22%3E%E3%83%90%E3%82%A4%E3%83%88%3C%2FSPAN%3E)%3B%3C%2FP%3E%3CP%20class%3D%22%22%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3E%2F*%20CTRL_REG4%20*%2F%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Ectrl_reg4%3C%2FSPAN%3E%20.%3CSPAN%20class%3D%22%22%3E%E3%83%90%E3%82%A4%E3%83%88%3C%2FSPAN%3E%3D%20%3CSTRONG%3Emma8451qr1_get_register%3C%2FSTRONG%3E%20(MMA8451QR1_REG_CTRL_REG4)%3B%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3Ectrl_reg4%20%3CSPAN%20class%3D%22%22%3E.%3C%2FSPAN%3E%E3%83%93%E3%83%83%E3%83%88%3CSPAN%20class%3D%22%22%3E.%3C%2FSPAN%3E%20INT_EN_PULSE%20%3CSPAN%20class%3D%22%22%3E%3D%20true%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3Ectrl_reg4%20%3CSPAN%20class%3D%22%22%3E.%3C%2FSPAN%3E%E3%83%93%E3%83%83%E3%83%88%3CSPAN%20class%3D%22%22%3E.%3C%2FSPAN%3E%20INT_EN_DRDY%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3D%20%E7%9C%9F%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSTRONG%3Emma8451qr1_set_register%3C%2FSTRONG%3E%20(MMA8451QR1_REG_CTRL_REG4%E3%80%81%20%3CSPAN%20class%3D%22%22%3Ectrl_reg4%3C%2FSPAN%3E%20%E3%80%82%3CSPAN%20class%3D%22%22%3E%E3%83%90%E3%82%A4%E3%83%88%3C%2FSPAN%3E)%3B%3C%2FP%3E%3CP%20class%3D%22%22%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3E%2F*%20CTRL_REG5%20*%2F%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Ectrl_reg5%3C%2FSPAN%3E%20.%3CSPAN%20class%3D%22%22%3E%E3%83%90%E3%82%A4%E3%83%88%3C%2FSPAN%3E%3D%20%3CSTRONG%3Emma8451qr1_get_register%3C%2FSTRONG%3E%20(MMA8451QR1_REG_CTRL_REG5)%3B%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3Ectrl_reg5%20%3CSPAN%20class%3D%22%22%3E.%3C%2FSPAN%3E%E3%83%93%E3%83%83%E3%83%88%3CSPAN%20class%3D%22%22%3E.%3C%2FSPAN%3E%20INT_CFG_PULSE%20%3CSPAN%20class%3D%22%22%3E%3D%20false%3B%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%2F*%20%E5%81%BD%20%3D%3D%20INT2%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3Ectrl_reg5%20%3CSPAN%20class%3D%22%22%3E.%3C%2FSPAN%3E%E3%83%93%E3%83%83%E3%83%88%3CSPAN%20class%3D%22%22%3E.%3C%2FSPAN%3E%20INT_CFG_DRDY%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3D%20%E5%81%BD%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSTRONG%3Emma8451qr1_set_register%3C%2FSTRONG%3E%20(MMA8451QR1_REG_CTRL_REG5%E3%80%81%20%3CSPAN%20class%3D%22%22%3Ectrl_reg5%3C%2FSPAN%3E%20%E3%80%82%3CSPAN%20class%3D%22%22%3E%E3%83%90%E3%82%A4%E3%83%88%3C%2FSPAN%3E)%3B%3C%2FP%3E%3CP%20class%3D%22%22%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3Epulse_cfg%20%3CSPAN%20class%3D%22%22%3E.%3C%2FSPAN%3E%E3%83%93%E3%83%83%E3%83%88%3CSPAN%20class%3D%22%22%3E.%3C%2FSPAN%3E%20XSPEFE%20%3CSPAN%20class%3D%22%22%3E%3D%201%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3Epulse_cfg%20%3CSPAN%20class%3D%22%22%3E.%3C%2FSPAN%3E%E3%83%93%E3%83%83%E3%83%88%3CSPAN%20class%3D%22%22%3E.%3C%2FSPAN%3E%20XDPEFE%20%3CSPAN%20class%3D%22%22%3E%3D%200%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3Epulse_cfg%20%3CSPAN%20class%3D%22%22%3E.%3C%2FSPAN%3E%E3%83%93%E3%83%83%E3%83%88%3CSPAN%20class%3D%22%22%3E.%3C%2FSPAN%3E%20YSPEFE%20%3CSPAN%20class%3D%22%22%3E%3D%201%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3Epulse_cfg%20%3CSPAN%20class%3D%22%22%3E.%3C%2FSPAN%3E%E3%83%93%E3%83%83%E3%83%88%3CSPAN%20class%3D%22%22%3E.%3C%2FSPAN%3E%20YDPEFE%20%3CSPAN%20class%3D%22%22%3E%3D%200%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3Epulse_cfg%20%3CSPAN%20class%3D%22%22%3E.%3C%2FSPAN%3E%E3%83%93%E3%83%83%E3%83%88%3CSPAN%20class%3D%22%22%3E.%3C%2FSPAN%3E%20ZSPEFE%20%3CSPAN%20class%3D%22%22%3E%3D%201%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3Epulse_cfg%20%3CSPAN%20class%3D%22%22%3E.%3C%2FSPAN%3E%E3%83%93%E3%83%83%E3%83%88%3CSPAN%20class%3D%22%22%3E.%3C%2FSPAN%3E%20ZDPEFE%20%3CSPAN%20class%3D%22%22%3E%3D%200%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3Epulse_cfg%20%3CSPAN%20class%3D%22%22%3E.%3C%2FSPAN%3E%E3%83%93%E3%83%83%E3%83%88%3CSPAN%20class%3D%22%22%3E.%3C%2FSPAN%3E%20ELE%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3D%201%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3Epulse_cfg%20%3CSPAN%20class%3D%22%22%3E.%3C%2FSPAN%3E%E3%83%93%E3%83%83%E3%83%88%3CSPAN%20class%3D%22%22%3E.%3C%2FSPAN%3E%20DPA%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3D%200%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSTRONG%3Emma8451qr1_set_register%3C%2FSTRONG%3E%20(MMA8451QR1_REG_PULSE_CFG%E3%80%81%20%3CSPAN%20class%3D%22%22%3Epulse_cfg%3C%2FSPAN%3E%20%E3%80%82%3CSPAN%20class%3D%22%22%3E%E3%83%90%E3%82%A4%E3%83%88%3C%2FSPAN%3E)%3B%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3Epulse_thsx%20%3CSPAN%20class%3D%22%22%3E.%3C%2FSPAN%3E%E3%83%90%E3%82%A4%E3%83%88%3CSPAN%20class%3D%22%22%3E%3D%200x20%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSTRONG%3Emma8451qr1_set_register%3C%2FSTRONG%3E%20(MMA8451QR1_REG_PULSE_THSX%E3%80%81%20%3CSPAN%20class%3D%22%22%3Epulse_thsx%3C%2FSPAN%3E%20%E3%80%82%3CSPAN%20class%3D%22%22%3E%E3%83%90%E3%82%A4%E3%83%88%3C%2FSPAN%3E)%3B%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3Epulse_thsy%20%3CSPAN%20class%3D%22%22%3E.%3C%2FSPAN%3E%E3%83%90%E3%82%A4%E3%83%88%3CSPAN%20class%3D%22%22%3E%3D%200x20%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSTRONG%3Emma8451qr1_set_register%3C%2FSTRONG%3E%20(MMA8451QR1_REG_PULSE_THSY%E3%80%81%20%3CSPAN%20class%3D%22%22%3Epulse_thsy%3C%2FSPAN%3E%20%E3%80%82%3CSPAN%20class%3D%22%22%3E%E3%83%90%E3%82%A4%E3%83%88%3C%2FSPAN%3E)%3B%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3Epulse_thsz%20%3CSPAN%20class%3D%22%22%3E.%3C%2FSPAN%3E%E3%83%90%E3%82%A4%E3%83%88%3CSPAN%20class%3D%22%22%3E%3D%200x2A%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSTRONG%3Emma8451qr1_set_register%3C%2FSTRONG%3E%20(MMA8451QR1_REG_PULSE_THSZ%E3%80%81%20%3CSPAN%20class%3D%22%22%3Epulse_thsz%3C%2FSPAN%3E%20%E3%80%82%3CSPAN%20class%3D%22%22%3E%E3%83%90%E3%82%A4%E3%83%88%3C%2FSPAN%3E)%3B%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3Epulse_tmlt%20%3CSPAN%20class%3D%22%22%3E.%3C%2FSPAN%3E%E3%83%90%E3%82%A4%E3%83%88%3CSPAN%20class%3D%22%22%3E%3D%200x28%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSTRONG%3Emma8451qr1_set_register%3C%2FSTRONG%3E%20(MMA8451QR1_REG_PULSE_TMLT%E3%80%81%20%3CSPAN%20class%3D%22%22%3Epulse_tmlt%3C%2FSPAN%3E%20%E3%80%82%3CSPAN%20class%3D%22%22%3E%E3%83%90%E3%82%A4%E3%83%88%3C%2FSPAN%3E)%3B%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3Epulse_ltcy%20%3CSPAN%20class%3D%22%22%3E.%3C%2FSPAN%3E%E3%83%90%E3%82%A4%E3%83%88%3CSPAN%20class%3D%22%22%3E%3D%200x28%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSTRONG%3Emma8451qr1_set_register%3C%2FSTRONG%3E%20(MMA8451QR1_REG_PULSE_LTCY%E3%80%81%20%3CSPAN%20class%3D%22%22%3Epulse_ltcy%3C%2FSPAN%3E%20%E3%80%82%3CSPAN%20class%3D%22%22%3E%E3%83%90%E3%82%A4%E3%83%88%3C%2FSPAN%3E)%3B%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3Epulse_wind%20%3CSPAN%20class%3D%22%22%3E.%3C%2FSPAN%3E%E3%83%90%E3%82%A4%E3%83%88%3CSPAN%20class%3D%22%22%3E%3D%200x0F%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSTRONG%3Emma8451qr1_set_register%3C%2FSTRONG%3E%20(MMA8451QR1_REG_PULSE_WIND%E3%80%81%20%3CSPAN%20class%3D%22%22%3Epulse_wind%3C%2FSPAN%3E%20.%3CSPAN%20class%3D%22%22%3E%E3%83%90%E3%82%A4%E3%83%88%3C%2FSPAN%3E)%3B%3C%2FP%3E%3CP%20class%3D%22%22%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%3CSTRONG%3Emma8451qr1_set_active%3C%2FSTRONG%3E%20()%3B%3C%2FP%3E%3CP%20class%3D%22%22%3E%7D%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3EINT1%20%E3%81%A8%20INT2%20%E3%82%92%20K22%20%E3%81%AE%202%20%E3%81%A4%E3%81%AE%E3%83%94%E3%83%B3%E3%81%AB%E3%82%B3%E3%83%8D%E3%82%AF%E3%83%86%E3%83%83%E3%83%89%E3%81%97%E3%80%81%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%81%8C%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%99%E3%80%82K22%20%E3%81%AE%E3%83%94%E3%83%B3%E3%81%AF%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E4%BB%98%E3%81%8D%E3%81%AE%20GPIO%20%E3%81%A8%E3%81%97%E3%81%A6%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%83%BC%E3%81%AF%E6%AC%A1%E3%81%AE%E5%A0%B4%E6%89%80%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3A%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CSTRONG%3Evoid%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSTRONG%3EPORTD_IRQHandler%3C%2FSTRONG%3E%20(%20%3CSPAN%20class%3D%22%22%3E%3CSTRONG%3Evoid%3C%2FSTRONG%3E%3C%2FSPAN%3E%20)%3C%2FP%3E%3CP%20class%3D%22%22%3E%7B%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3E(PORTD_PCR4%20%26amp%3B%20PORT_PCR_ISF_MASK)%3CSPAN%20class%3D%22%22%3E%3CSTRONG%3E%E3%81%AE%E5%A0%B4%E5%90%88%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%7B%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3C%2FSPAN%3Eg_main_event_flags.%3CSPAN%20class%3D%22%22%3E%E3%83%93%E3%83%83%E3%83%88%3C%2FSPAN%3E.%20%3CSPAN%20class%3D%22%22%3Edo_mems%3C%2FSPAN%3E%3D%20%E7%9C%9F%3B%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3EPORTD_PCR4%20%7C%3D%20PORT_PCR_ISF_MASK%3B%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FP%3E%3CP%20class%3D%22%22%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3E(PORTD_PCR6%20%26amp%3B%20PORT_PCR_ISF_MASK)%3CSPAN%20class%3D%22%22%3E%3CSTRONG%3E%E3%81%AE%E5%A0%B4%E5%90%88%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%7B%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3Eg_main_event_flags.%3CSPAN%20class%3D%22%22%3E%E3%83%93%E3%83%83%E3%83%88%3C%2FSPAN%3E.%20%3CSPAN%20class%3D%22%22%3Edo_mems%3C%2FSPAN%3E%3D%20%E7%9C%9F%3B%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3EPORTD_PCR6%20%7C%3D%20PORT_PCR_ISF_MASK%3B%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FP%3E%3CP%20class%3D%22%22%3E%7D%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3Eg_main_event_flags%20%E6%A7%8B%E9%80%A0%E4%BD%93%E3%82%82%E5%85%B1%E7%94%A8%E4%BD%93%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E3%82%B0%E3%83%AD%E3%83%BC%E3%83%90%E3%83%AB%E3%81%AB%E5%AE%A3%E8%A8%80%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AE%E3%83%A1%E3%82%A4%E3%83%B3%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97%EF%BC%88main.c%EF%BC%89%E3%81%A7%E3%81%AF%E3%80%81%E7%A7%81%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%82%E3%81%AE%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%2F*%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E*%20MEMS%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%E3%82%92%E5%87%A6%E7%90%86%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E*%2F%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSTRONG%3Eif%3C%2FSTRONG%3E%3C%2FSPAN%3E%20(g_main_event_flags.%20%3CSPAN%20class%3D%22%22%3Ebits%3C%2FSPAN%3E%20.%20%3CSPAN%20class%3D%22%22%3Edo_mems%3C%2FSPAN%3E%20)%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%7B%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3EMMA_INT_SOURCE%20%3CSPAN%20class%3D%22%22%3Eint_src%3C%2FSPAN%3E%20%3B%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3EMMA_PULSE_SRC%3CSPAN%20class%3D%22%22%3E%E3%83%91%E3%83%AB%E3%82%B9%E3%82%BD%E3%83%BC%E3%82%B9%3C%2FSPAN%3E%3B%3C%2FP%3E%3CP%20class%3D%22%22%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Eint_src%3C%2FSPAN%3E%20.%3CSPAN%20class%3D%22%22%3E%E3%83%90%E3%82%A4%E3%83%88%3C%2FSPAN%3E%3D%20%3CSTRONG%3Emma8451qr1_get_int_source%3C%2FSTRONG%3E%20()%3B%3C%2FP%3E%3CP%20class%3D%22%22%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSTRONG%3Eif%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E(%3C%2FSPAN%3E%20int_src%20%3CSPAN%20class%3D%22%22%3E.%3C%2FSPAN%3E%20Bits%20%3CSPAN%20class%3D%22%22%3E.%3C%2FSPAN%3E%20SRC_PULSE%20%3CSPAN%20class%3D%22%22%3E)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%7B%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Epulse_src%3C%2FSPAN%3E%20.%3CSPAN%20class%3D%22%22%3E%E3%83%90%E3%82%A4%E3%83%88%3C%2FSPAN%3E%3D%20%3CSTRONG%3Emma8451qr1_read_pulse%3C%2FSTRONG%3E%20()%3B%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSTRONG%3Eports_led%3C%2FSTRONG%3E%20(true)%3B%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FP%3E%3CP%20class%3D%22%22%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3E%3CSTRONG%3Eif%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E(%3C%2FSPAN%3E%20int_src%20%3CSPAN%20class%3D%22%22%3E.%3C%2FSPAN%3E%20Bits%20%3CSPAN%20class%3D%22%22%3E.%3C%2FSPAN%3E%20SRC_DRDY%20%3CSPAN%20class%3D%22%22%3E)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%7B%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSTRONG%3Emma8451qr1_read_data%3C%2FSTRONG%3E%20()%3B%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FP%3E%3CP%20class%3D%22%22%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22%22%3Eint_src%3C%2FSPAN%3E%20.%3CSPAN%20class%3D%22%22%3E%E3%83%90%E3%82%A4%E3%83%88%3C%2FSPAN%3E%3D%20%3CSTRONG%3Emma8451qr1_get_int_source%3C%2FSTRONG%3E%20()%3B%3C%2FP%3E%3CP%20class%3D%22%22%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3Eg_main_event_flags.%3CSPAN%20class%3D%22%22%3E%E3%83%93%E3%83%83%E3%83%88%3C%2FSPAN%3E.%20%3CSPAN%20class%3D%22%22%3Edo_mems%3C%2FSPAN%3E%3D%20%E5%81%BD%3B%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%7D%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%E4%BB%95%E6%A7%98%E3%82%92%E8%AA%AD%E3%82%93%E3%81%A0%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%92%E3%82%AF%E3%83%AA%E3%82%A2%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%20SRC_PULSE%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%80%81SRC_DRDY%20%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%92%E3%82%AF%E3%83%AA%E3%82%A2%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%20MEMS%20%E3%81%8B%E3%82%89%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%AB%E3%83%BC%E3%83%81%E3%83%B3%E3%81%AF%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E8%A6%8B%E3%81%88%E3%81%BE%E3%81%99%E3%81%8C%E3%80%812%20%E7%95%AA%E7%9B%AE%E3%81%AE%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%82%AF%E3%83%AA%E3%82%A2%E3%81%99%E3%81%B9%E3%81%8D%E3%81%93%E3%81%A8%E3%82%92%E3%82%AF%E3%83%AA%E3%82%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E6%B0%97%E3%81%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eports_led()%20%E3%81%AF%E3%80%81LED%20%E3%82%92%E3%82%AA%E3%83%B3%E3%81%AB%E3%81%99%E3%82%8B%20GPIO%20%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%20%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E7%B4%84%20200%20%E3%83%9F%E3%83%AA%E7%A7%92%E9%96%93%E3%82%AA%E3%83%B3%E3%81%AE%E3%81%BE%E3%81%BE%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%20(%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E9%A7%86%E5%8B%95)%E3%80%82%E3%81%93%E3%82%8C%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81%E3%82%BF%E3%83%83%E3%83%97%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8B%E3%82%89%20LED%20%E3%81%8C%E3%82%AA%E3%83%95%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E3%20%E5%9B%9E%E3%81%BB%E3%81%A9%E3%82%BF%E3%83%83%E3%83%97%E3%81%99%E3%82%8B%E3%81%A8%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%AA%E3%81%8F%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%83%BC%E3%82%92%E4%B8%80%E6%99%82%E5%81%9C%E6%AD%A2%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%80%81K22%20%E3%81%AF%E3%83%95%E3%83%AA%E3%83%BC%E3%82%BA%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%20(%E3%83%A1%E3%82%A4%E3%83%B3%20%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%20%E3%83%AB%E3%83%BC%E3%83%97%E3%81%AF%E5%BC%95%E3%81%8D%E7%B6%9A%E3%81%8D%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99)%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%8A%A9%E3%81%91%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%A3%E3%81%A6%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-654881%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%208451%20interrupts%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-654881%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%82%88%E3%82%8A%E9%81%85%E3%81%84%E9%80%9F%E5%BA%A6%E3%81%A7%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81%E3%81%86%E3%81%BE%E3%81%8F%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E5%AE%8C%E5%85%A8%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EINT_SOURCE%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%80%81%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%83%95%E3%83%A9%E3%82%B0%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%20(%E3%83%91%E3%83%AB%E3%82%B9%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%20INT1%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%20INT2)%E3%80%81%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E8%A6%8B%E3%81%88%E3%81%BE%E3%81%99%E3%80%82INT_SOURCE%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%E3%81%A8%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%AA%E3%81%8F%E3%81%AA%E3%82%8B%E7%90%86%E7%94%B1%E3%81%8C%E3%82%88%E3%81%8F%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%A9%E3%81%93%E3%81%8B%E3%81%A7%E4%BD%95%E3%81%8B%E3%82%84%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E7%A2%BA%E3%81%8B%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E200%20Hz%20%E3%81%A7%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%80%81%E3%82%BF%E3%83%83%E3%83%97%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%92%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%8C%E3%82%84%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%83%95%E3%83%A9%E3%82%B0%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A0%E3%81%91%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E8%80%83%E6%85%AE%E3%81%99%E3%82%8B%E3%81%A8%E3%80%815%20%E3%83%9F%E3%83%AA%E7%A7%92%E3%81%AF%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%81%A8%E3%81%97%E3%81%A6%E3%81%AF%E7%9F%AD%E3%81%84%E6%99%82%E9%96%93%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%2040%20MHz%20%E3%81%AE%20K22%20%E4%B8%8A%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E7%A2%BA%E8%AA%8D%E3%81%AE%E3%81%9F%E3%82%81%E3%80%81%E9%80%9F%E5%BA%A6%E3%82%92%20800%20Hz%20%E3%81%BE%E3%81%A7%E4%B8%8A%E3%81%92%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%BE%E3%81%A0%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%20(INT_SOURCE%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%89%E3%81%9A%E3%81%AB)%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%9A%86%E3%81%95%E3%82%93%E5%8A%A9%E3%81%91%E3%81%A6%E3%81%8F%E3%82%8C%E3%81%A6%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-654880%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%208451%20interrupts%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-654880%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%82%B8%E3%82%A7%E3%83%BC%E3%83%A0%E3%82%BA%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E200Hz%20%E3%81%AE%20ODR%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E6%B0%97%E4%BB%98%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E6%96%B0%E3%81%97%E3%81%84%E3%83%87%E3%83%BC%E3%82%BF%E3%82%BB%E3%83%83%E3%83%88%E3%81%8C%E6%BA%96%E5%82%99%E3%81%95%E3%82%8C%E3%81%9F%E3%81%9F%E3%82%81%E3%81%AB%205%20%E3%83%9F%E3%83%AA%E7%A7%92%E3%81%94%E3%81%A8%E3%81%AB%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%81%8C%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%E3%81%95%E3%82%8C%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E6%84%8F%E5%91%B3%E3%81%97%E3%81%BE%E3%81%99%20(DRDY%20%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF)%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%8C%20PULSE%20%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%92%E7%94%9F%E6%88%90%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E7%90%86%E7%94%B1%E3%81%A0%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%93%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E6%96%B0%E3%81%97%E3%81%84%E3%83%87%E3%83%BC%E3%82%BF%20%E3%82%BB%E3%83%83%E3%83%88%E3%81%AE%E9%96%93%E3%81%AB%E5%8D%81%E5%88%86%E3%81%AA%E6%99%82%E9%96%93%E3%82%92%E7%A2%BA%E4%BF%9D%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E3%82%88%E3%82%8A%E4%BD%8E%E9%80%9F%E3%81%AE%20ODR%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%B5%90%E6%9E%9C%E3%82%92%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%93%E3%83%83%E3%83%89%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-654879%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%208451%20interrupts%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-654879%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%9D%E3%82%8C%E3%82%92%E3%82%84%E3%81%A3%E3%81%9F%E3%82%88%E3%80%82%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%81%AE%E3%81%A7%E3%81%94%E6%B3%A8%E6%84%8F%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82DRDY%20%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%82%BF%E3%83%83%E3%83%97%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%81%8C%E6%95%B0%E5%9B%9E%E3%81%AE%E3%81%BF%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E7%A7%81%E3%81%8C%E4%B8%8A%E3%81%A7%E8%BF%B0%E3%81%B9%E3%80%81%E6%9C%80%E5%88%9D%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A7%E7%A4%BA%E3%81%97%E3%81%9F%E5%86%85%E5%AE%B9%E3%81%A7%E3%81%99%E3%80%82%E5%BE%8C%E3%81%A7%E8%BF%B0%E3%81%B9%E3%81%9F%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%E3%82%BF%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%E3%81%AF%20DRDY%20%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%92%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AB%E3%81%AE%E3%81%BF%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-654878%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%208451%20interrupts%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-654878%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%82%B8%E3%82%A7%E3%83%BC%E3%83%A0%E3%82%BA%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%81%A3%E3%81%A6%E5%AC%89%E3%81%97%E3%81%8F%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%AE%9F%E9%9A%9B%E3%80%81%20%3CSTRONG%3ECTRL_REG4%3C%2FSTRONG%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%A7%E4%B8%A1%E6%96%B9%E3%81%AE%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%81%8C%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%E3%81%95%E3%82%8C%E3%81%9F%E3%82%89%E3%80%81%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%3CSTRONG%3EINT_SOURCE%3C%2FSTRONG%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%83%93%E3%83%83%E3%83%88%E3%81%AF%E3%83%AD%E3%83%BC%E3%81%8B%E3%82%89%E3%83%8F%E3%82%A4%E3%81%B8%E3%81%AE%E9%81%B7%E7%A7%BB%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%80%81%E9%81%A9%E5%88%87%E3%81%AA%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%BD%E3%83%BC%E3%82%B9%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E3%82%AF%E3%83%AA%E3%82%A2%E3%81%95%E3%82%8C%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E6%B3%A8%E6%84%8F%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E6%83%85%E5%A0%B1%E3%81%8C%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A4%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%93%E3%83%83%E3%83%89%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-654877%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%208451%20interrupts%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-654877%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%A7%81%E3%81%AF%E3%81%9D%E3%81%AE%E3%83%9A%E3%83%BC%E3%82%B8%E3%82%92%E8%A6%8B%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%9C%80%E7%B5%82%E7%9A%84%E3%81%AB%20DRDY%20%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%92%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%A6%E3%80%81%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%9D%E3%82%8C%E3%81%AF%E3%81%A1%E3%82%87%E3%81%A3%E3%81%A8%E6%A5%B5%E7%AB%AF%E3%81%99%E3%81%8E%E3%82%8B%E6%B0%97%E3%81%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%BF%E3%83%83%E3%83%97%E3%82%92%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%E4%B8%A1%E6%96%B9%E3%81%AE%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%20(PULSE%20%E3%81%A8%20DRDY)%20%E3%82%92%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-654876%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%208451%20interrupts%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-654876%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%82%B8%E3%82%A7%E3%83%BC%E3%83%A0%E3%82%BA%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%94%E9%80%A3%E7%B5%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CSPAN%20style%3D%22color%3A%20red%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-329888%22%20target%3D%22_blank%22%3EMMA8451Q%20-%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%AB%E3%82%BF%E3%83%83%E3%83%97%E6%A4%9C%E5%87%BA%E3%83%99%E3%82%A2%E3%83%A1%E3%82%BF%E3%83%AB%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EKinetis%20KL25Z%20%E3%81%AF%E5%89%8D%E8%BF%B0%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AB%E3%81%A8%E3%81%A3%E3%81%A6%E3%82%82%E5%BD%B9%E7%AB%8B%E3%81%A1%E3%81%BE%E3%81%99%E3%80%82%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E8%A8%AD%E5%AE%9A%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BB%96%E3%81%AB%E3%81%94%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%82%89%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E5%96%9C%E3%82%93%E3%81%A7%E3%81%8A%E6%89%8B%E4%BC%9D%E3%81%84%E3%81%95%E3%81%9B%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%99%E3%81%A6%E3%81%8D%E3%81%AA%E4%B8%80%E6%97%A5%E3%82%92%E3%80%81%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%93%E3%83%83%E3%83%89%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-654875%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%208451%20interrupts%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-654875%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%82%82%E3%81%86%E5%B0%91%E3%81%97%E5%AE%9F%E9%A8%93%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%87%E3%83%BC%E3%82%BF%E6%BA%96%E5%82%99%E3%81%AE%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%92%E3%82%AA%E3%83%95%E3%81%AB%E3%81%99%E3%82%8B%E3%81%A8%20(INT_EN_DRDY%20%3D%200)%E3%80%81%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E4%B8%A1%E6%96%B9%E3%82%92%E5%90%8C%E6%99%82%E3%81%AB%E8%A1%8C%E3%81%86%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%81%AA%E3%82%93%E3%81%A6%E4%BF%A1%E3%81%98%E3%82%89%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%A0%E3%81%8B%E3%82%89%E3%80%81%E7%A7%81%E3%81%8C%E3%82%84%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E4%BD%95%E3%81%8B%E9%81%95%E3%81%86%E3%81%AB%E9%81%95%E3%81%84%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
