Sensor Fusion Library Build 422 Pre-Release - Updated 20141107
The attached is a preview copy of build 422 of the sensor fusion library, which is currently being tested by the Freescale Sensor's team.
Please consult the docs/Release_Notes.txt file for changes from build 420, as well as known errata.
This version is released under the following license:
Freescale Sensor Fusion Library for Kinetis MCUs
  1. IMPORTANT. Read the following Freescale Software License Agreement (“Agreement”) completely.  By downloading this file, you indicate that you accept the terms of this Agreement and you also acknowledge that you have the authority, on behalf of your company, to bind your company to such terms.  You may then download or install the file.
FREESCALE END-USER SOFTWARE LICENSE AGREEMENT
Redistribution and use in source and binary forms, with or without modification, are permitted provided that the following conditions are met:
    * Redistributions of source code must retain the above copyright notice, this list of conditions and the following disclaimer.
    * Redistributions in binary form must reproduce the above copyright  notice, this list of conditions and the following disclaimer in the  documentation and/or other materials provided with the distribution.
    * Neither the name of Freescale Semiconductor, Inc. nor the  names of its contributors may be used to endorse or promote products derived from this software without specific prior written permission.
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL FREESCALE SEMICONDUCTOR, INC. BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
© 2004-2014 Freescale Semiconductor, Inc. All rights reserved.
%3CLINGO-SUB%20id%3D%22lingo-sub-1114560%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3ESensor%20Fusion%20Library%20Build%20422%20Pre-Release%20-%20Updated%2020141107%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114560%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3EThe%20attached%20is%20a%20preview%20copy%20of%20build%20422%20of%20the%20sensor%20fusion%20library%2C%20which%20is%20currently%20being%20tested%20by%20the%20Freescale%20Sensor's%20team.%3C%2FP%3E%3CP%3EPlease%20consult%20the%20docs%2FRelease_Notes.txt%20file%20for%20changes%20from%20build%20420%2C%20as%20well%20as%20known%20errata.%3C%2FP%3E%3CP%3EThis%20version%20is%20released%20under%20the%20following%20license%3A%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%2012.0pt%3B%20text-align%3A%20center%3B%22%3E%3CSPAN%20class%3D%22grame%22%20style%3D%22color%3A%20black%3B%20font-size%3A%2010.0pt%3B%22%3E%3CSTRONG%3EFreescale%20Sensor%20Fusion%20Library%20for%20Kinetis%20MCUs%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3COL%20style%3D%22list-style-type%3A%20upper-roman%3B%22%3E%3CLI%3E%3CSPAN%20class%3D%22grame%22%20style%3D%22color%3A%20black%3B%20font-size%3A%2010.0pt%3B%22%3E%3CSTRONG%3EIMPORTANT.%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E%3CSTRONG%3E%20Read%20the%20following%20Freescale%20Software%20License%20Agreement%20(%E2%80%9CAgreement%E2%80%9D)%20completely.%26nbsp%3B%20By%20downloading%20this%20file%2C%20you%20indicate%20that%20you%20accept%20the%20terms%20of%20this%20Agreement%20and%20you%20also%20acknowledge%20that%20you%20have%20the%20authority%2C%20on%20behalf%20of%20your%20company%2C%20to%20bind%20your%20company%20to%20such%20terms.%26nbsp%3B%20You%20may%20then%20download%20or%20install%20the%20file.%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%2012.0pt%3B%20text-align%3A%20center%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2010.0pt%3B%20text-decoration%3A%20underline%3B%20font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3EFREESCALE%20END-USER%20SOFTWARE%20LICENSE%20AGREEMENT%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%20color%3A%20black%3B%22%3ERedistribution%20and%20use%20in%20source%20and%20binary%20forms%2C%20with%20or%20without%20modification%2C%20are%20permitted%20provided%20that%20the%20following%20conditions%20are%20met%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%20color%3A%20black%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20*%20Redistributions%20of%20source%20code%20must%20retain%20the%20above%20copyright%20notice%2C%20this%20list%20of%20conditions%20and%20the%20following%20disclaimer.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%20color%3A%20black%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20*%20Redistributions%20in%20binary%20form%20must%20reproduce%20the%20above%20copyright%26nbsp%3B%20notice%2C%20this%20list%20of%20conditions%20and%20the%20following%20disclaimer%20in%20the%26nbsp%3B%20documentation%20and%2For%20other%20materials%20provided%20with%20the%20distribution.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%20color%3A%20black%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20*%20Neither%20the%20name%20of%20Freescale%20Semiconductor%2C%20Inc.%20nor%20the%26nbsp%3B%20names%20of%20its%20contributors%20may%20be%20used%20to%20endorse%20or%20promote%20products%20derived%20from%20this%20software%20without%20specific%20prior%20written%20permission.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%20color%3A%20black%3B%22%3ETHIS%20SOFTWARE%20IS%20PROVIDED%20BY%20THE%20COPYRIGHT%20HOLDERS%20AND%20CONTRIBUTORS%20%22AS%20IS%22%20AND%20ANY%20EXPRESS%20OR%20IMPLIED%20WARRANTIES%2C%20INCLUDING%2C%20BUT%20NOT%20LIMITED%20TO%2C%20THE%20IMPLIED%20WARRANTIES%20OF%20MERCHANTABILITY%20AND%20FITNESS%20FOR%20A%20PARTICULAR%20PURPOSE%20ARE%20DISCLAIMED.%20IN%20NO%20EVENT%20SHALL%20FREESCALE%20SEMICONDUCTOR%2C%20INC.%20BE%20LIABLE%20FOR%20ANY%20DIRECT%2C%20INDIRECT%2C%20INCIDENTAL%2C%20SPECIAL%2C%20EXEMPLARY%2C%20OR%20CONSEQUENTIAL%20DAMAGES%20(INCLUDING%2C%20BUT%20NOT%20LIMITED%20TO%2C%20PROCUREMENT%20OF%20SUBSTITUTE%20GOODS%20OR%20SERVICES%3B%20LOSS%20OF%20USE%2C%20DATA%2C%20OR%20PROFITS%3B%20OR%20BUSINESS%20INTERRUPTION)%20HOWEVER%20CAUSED%20AND%20ON%20ANY%20THEORY%20OF%20LIABILITY%2C%20WHETHER%20IN%20CONTRACT%2C%20STRICT%20LIABILITY%2C%20OR%20TORT%20(INCLUDING%20NEGLIGENCE%20OR%20OTHERWISE)%20ARISING%20IN%20ANY%20WAY%20OUT%20OF%20THE%20USE%20OF%20THIS%20SOFTWARE%2C%20EVEN%20IF%20ADVISED%20OF%20THE%20POSSIBILITY%20OF%20SUCH%20DAMAGE.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E%C2%A9%202004-2014%20Freescale%20Semiconductor%2C%20Inc.%20All%20rights%20reserved.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-TEASER%20id%3D%22lingo-teaser-1114560%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3EThe%20attached%20is%20a%20preview%20copy%20of%20build%20422%20of%20the%20sensor%20fusion%20library%2C%20which%20is%20currently%20being%20tested%20by%20the%20Freescale%20Sensor's%20team.%3C%2FP%3E%3CP%3EPlease%20consult%20the%20docs%2FRelease_Notes.txt%20file%20for%20changes%20from%20build%20420%2C%20as%20well%20as%20known%20errata.%3C%2FP%3E%3CP%3EThis%20version%20is%20released%20under%20the%20following%20license%3A%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%2012.0pt%3B%20text-align%3A%20center%3B%22%3E%3CSPAN%20class%3D%22grame%22%20style%3D%22color%3A%20black%3B%20font-size%3A%2010.0pt%3B%22%3E%3CSTRONG%3EFreescale%20Sensor%20Fusion%20Library%20for%20Kinetis%20MCUs%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3COL%20style%3D%22list-style-type%3A%20upper-roman%3B%22%3E%3CLI%3E%3CSPAN%20class%3D%22grame%22%20style%3D%22color%3A%20black%3B%20font-size%3A%2010.0pt%3B%22%3E%3CSTRONG%3EIMPORTANT.%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E%3CSTRONG%3E%20Read%20the%20following%20Freescale%20Software%20License%20Agreement%20(%E2%80%9CAgreement%E2%80%9D)%20completely.%26nbsp%3B%20By%20downloading%20this%20file%2C%20you%20indicate%20that%20you%20accept%20the%20terms%20of%20this%20Agreement%20and%20you%20also%20acknowledge%20that%20you%20have%20the%20authority%2C%20on%20behalf%20of%20your%20company%2C%20to%20bind%20your%20company%20to%20such%20terms.%26nbsp%3B%20You%20may%20then%20download%20or%20install%20the%20file.%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%2012.0pt%3B%20text-align%3A%20center%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2010.0pt%3B%20text-decoration%3A%20underline%3B%20font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3EFREESCALE%20END-USER%20SOFTWARE%20LICENSE%20AGREEMENT%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%20color%3A%20black%3B%22%3ERedistribution%20and%20use%20in%20source%20and%20binary%20forms%2C%20with%20or%20without%20modification%2C%20are%20permitted%20provided%20that%20the%20following%20conditions%20are%20met%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%20color%3A%20black%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20*%20Redistributions%20of%20source%20code%20must%20retain%20the%20above%20copyright%20notice%2C%20this%20list%20of%20conditions%20and%20the%20following%20disclaimer.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%20color%3A%20black%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20*%20Redistributions%20in%20binary%20form%20must%20reproduce%20the%20above%20copyright%26nbsp%3B%20notice%2C%20this%20list%20of%20conditions%20and%20the%20following%20disclaimer%20in%20the%26nbsp%3B%20documentation%20and%2For%20other%20materials%20provided%20with%20the%20distribution.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%20color%3A%20black%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20*%20Neither%20the%20name%20of%20Freescale%20Semiconductor%2C%20Inc.%20nor%20the%26nbsp%3B%20names%20of%20its%20contributors%20may%20be%20used%20to%20endorse%20or%20promote%20products%20derived%20from%20this%20software%20without%20specific%20prior%20written%20permission.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%20color%3A%20black%3B%22%3ETHIS%20SOFTWARE%20IS%20PROVIDED%20BY%20THE%20COPYRIGHT%20HOLDERS%20AND%20CONTRIBUTORS%20%22AS%20IS%22%20AND%20ANY%20EXPRESS%20OR%20IMPLIED%20WARRANTIES%2C%20INCLUDING%2C%20BUT%20NOT%20LIMITED%20TO%2C%20THE%20IMPLIED%20WARRANTIES%20OF%20MERCHANTABILITY%20AND%20FITNESS%20FOR%20A%20PARTICULAR%20PURPOSE%20ARE%20DISCLAIMED.%20IN%20NO%20EVENT%20SHALL%20FREESCALE%20SEMICONDUCTOR%2C%20INC.%20BE%20LIABLE%20FOR%20ANY%20DIRECT%2C%20INDIRECT%2C%20INCIDENTAL%2C%20SPECIAL%2C%20EXEMPLARY%2C%20OR%20CONSEQUENTIAL%20DAMAGES%20(INCLUDING%2C%20BUT%20NOT%20LIMITED%20TO%2C%20PROCUREMENT%20OF%20SUBSTITUTE%20GOODS%20OR%20SERVICES%3B%20LOSS%20OF%20USE%2C%20DATA%2C%20OR%20PROFITS%3B%20OR%20BUSINESS%20INTERRUPTION)%20HOWEVER%20CAUSED%20AND%20ON%20ANY%20THEORY%20OF%20LIABILITY%2C%20WHETHER%20IN%20CONTRACT%2C%20STRICT%20LIABILITY%2C%20OR%20TORT%20(INCLUDING%20NEGLIGENCE%20OR%20OTHERWISE)%20ARISING%20IN%20ANY%20WAY%20OUT%20OF%20THE%20USE%20OF%20THIS%20SOFTWARE%2C%20EVEN%20IF%20ADVISED%20OF%20THE%20POSSIBILITY%20OF%20SUCH%20DAMAGE.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E%C2%A9%202004-2014%20Freescale%20Semiconductor%2C%20Inc.%20All%20rights%20reserved.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-TEASER%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1114560%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CLINGO-LABEL%3ESensorFusion%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
No ratings
Version history
Last update:
‎02-03-2026 05:17 PM
Updated by:
