Running FRDM 6DOF Bare Board eCompass using the FRDM-K22
The following video shows how to run the FRDM 6DOF Bare Board eCompass using the FRDM-K22.
This algorithm uses the FXOS8700 contained on the Freedom Board.
In order to get more information about the Sensor Fusion Library for Kinetis MCU's 5.0, please refer to the following link:
Sensor Fusion|Freescale
I hope this material will be useful for you.
David
%3CLINGO-SUB%20id%3D%22lingo-sub-1115142%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3ERunning%20FRDM%206DOF%20Bare%20Board%20eCompass%20using%20the%20FRDM-K22%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1115142%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3EThe%20following%20video%20shows%20how%20to%20run%20the%20%3CSTRONG%3EFRDM%206DOF%20Bare%20Board%20eCompass%3C%2FSTRONG%3E%20using%20the%3CSTRONG%3E%20FRDM-K22%3C%2FSTRONG%3E.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThis%20algorithm%20uses%20the%20%3CSTRONG%3EFXOS8700%3C%2FSTRONG%3E%20contained%20on%20the%20Freedom%20Board.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EIn%20order%20to%20get%20more%20information%20about%20the%20%3CSTRONG%3ESensor%20Fusion%20Library%20for%20Kinetis%20MCU's%205.0%3C%2FSTRONG%3E%2C%20please%20refer%20to%20the%20following%20link%3A%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fwww.freescale.com%2Fproducts%2Fsensors%2Ffreescale-sensor-fusion%3AXTRSICSNSTLBOX%3Ffsrch%3D1%26amp%3Bsr%3D1%26amp%3BpageNum%3D1%22%20title%3D%22http%3A%2F%2Fwww.freescale.com%2Fproducts%2Fsensors%2Ffreescale-sensor-fusion%3AXTRSICSNSTLBOX%3Ffsrch%3D1%26amp%3Bsr%3D1%26amp%3BpageNum%3D1%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ESensor%20Fusion%7CFreescale%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20hope%20this%20material%20will%20be%20useful%20for%20you.%3C%2FP%3E%3CP%3EDavid%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-TEASER%20id%3D%22lingo-teaser-1115142%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3EThe%20following%20video%20shows%20how%20to%20run%20the%20%3CSTRONG%3EFRDM%206DOF%20Bare%20Board%20eCompass%3C%2FSTRONG%3E%20using%20the%3CSTRONG%3E%20FRDM-K22%3C%2FSTRONG%3E.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThis%20algorithm%20uses%20the%20%3CSTRONG%3EFXOS8700%3C%2FSTRONG%3E%20contained%20on%20the%20Freedom%20Board.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EIn%20order%20to%20get%20more%20information%20about%20the%20%3CSTRONG%3ESensor%20Fusion%20Library%20for%20Kinetis%20MCU's%205.0%3C%2FSTRONG%3E%2C%20please%20refer%20to%20the%20following%20link%3A%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fwww.freescale.com%2Fproducts%2Fsensors%2Ffreescale-sensor-fusion%3AXTRSICSNSTLBOX%3Ffsrch%3D1%26amp%3Bsr%3D1%26amp%3BpageNum%3D1%22%20title%3D%22http%3A%2F%2Fwww.freescale.com%2Fproducts%2Fsensors%2Ffreescale-sensor-fusion%3AXTRSICSNSTLBOX%3Ffsrch%3D1%26amp%3Bsr%3D1%26amp%3BpageNum%3D1%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3ESensor%20Fusion%7CFreescale%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20hope%20this%20material%20will%20be%20useful%20for%20you.%3C%2FP%3E%3CP%3EDavid%3C%2FP%3E%3C%2FLINGO-TEASER%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1115142%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CLINGO-LABEL%3EAccelerometers%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EMagnetic%20Sensors%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ESensing%20Platforms%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
No ratings
Version history
Last update:
‎02-03-2026 05:17 PM
Updated by:
