MPL3115A2 - Altitude and temperature measuring
Hi Everyone,
I would like to share a simple example code/demo that reads both the altitude and temperature data from the Xtrinsic MPL3115A2 pressure sensor and visualizes them using the FreeMASTER tool via USBDM interface. I have used recently released Xtrinsic MEMS sensors board that features three types of Xtrinsic sensors including the MPL3115A2 and is fully compatible with the Freescale FRDM-KL25Z platform.
According to the User Manual, both interrupt pins of the MPL3115A2 are connected to the PTD3 pin of KL25Z MCU through a 4.7K pull-up resistor as well as both SCL and SDA lines that are connected to the I2C1 module (PTE1 and PTE0 pins) on the KL25Z. The MCU is, therefore, configured as follows:
void MCU_Init(void)
       //I2C1 module initialization
       SIM_SCGC4 |= SIM_SCGC4_I2C1_MASK;        // Turn on clock to I2C1 module
       SIM_SCGC5 |= SIM_SCGC5_PORTE_MASK;       // Turn on clock to Port E module
       PORTE_PCR1 = PORT_PCR_MUX(6);            // PTE1 pin is I2C1 SCL line
       PORTE_PCR0 = PORT_PCR_MUX(6);            // PTE0 pin is I2C1 SDA line
       I2C1_F  = 0x14;                          // SDA hold time = 2.125us, SCL start hold time = 4.25us, SCL stop hold time = 5.125us
       I2C1_C1 = I2C_C1_IICEN_MASK;             // Enable I2C1 module
       //Configure the PTD3 pin (connected to the INT2 of the MPL3115A2) for falling edge interrupt
       SIM_SCGC5 |= SIM_SCGC5_PORTD_MASK;       // Turn on clock to Port D module
       PORTD_PCR3 |= (0|PORT_PCR_ISF_MASK|      // Clear the interrupt flag
       PORT_PCR_MUX(0x1)|                       // PTD3 is configured as GPIO
       PORT_PCR_IRQC(0xA));                     // PTD3 is configured for falling edge interrupts
       //Enable PORTD interrupt on NVIC
       NVIC_ICPR |= 1 << ((INT_PORTD - 16)%32);
       NVIC_ISER |= 1 << ((INT_PORTD - 16)%32);
In the ISR, only the interrupt flag is cleared and the DataReady variable is set to indicate the arrival of new data.
void PORTD_IRQHandler()
       PORTD_PCR3 |= PORT_PCR_ISF_MASK;         // Clear the interrupt flag
       DataReady = 1;
At the beginning of the initialization, all MPL3115A2 registers are reset to their default values by setting the RST bit of the CTRL_REG1 register.The DRDY interrupt is enabled and routed to the INT2 pin that is configured to be an open-drain, active-low output. During the initialization of the MPL3115A2, the OSR ratio of 128 is selected and finally the part goes into Active Altimeter mode.
void MPL3115A2_Init (void)
       unsigned char reg_val = 0;
       I2C_WriteRegister(MPL3115A2_I2C_ADDRESS, CTRL_REG1, 0x04);                        // Reset all registers to POR values
            do            // Wait for the RST bit to clear
          reg_val = I2C_ReadRegister(MPL3115A2_I2C_ADDRESS, CTRL_REG1) & 0x04;
       }  while (reg_val);
       I2C_WriteRegister(MPL3115A2_I2C_ADDRESS, PT_DATA_CFG_REG, 0x07);                  // Enable data flags
       I2C_WriteRegister(MPL3115A2_I2C_ADDRESS, CTRL_REG3, 0x11);                        // Open drain, active low interrupts
       I2C_WriteRegister(MPL3115A2_I2C_ADDRESS, CTRL_REG4, 0x80);                        // Enable DRDY interrupt
       I2C_WriteRegister(MPL3115A2_I2C_ADDRESS, CTRL_REG5, 0x00);                        // DRDY interrupt routed to INT2 - PTD3
       I2C_WriteRegister(MPL3115A2_I2C_ADDRESS, CTRL_REG1, 0xB9);                        // Active altimeter mode, OSR = 128
In the main loop, the DataReady variable is periodically checked and if it is set, both altitude and temperature data are read and then calculated.
if (DataReady)          // Is a new set of data ready?
       DataReady = 0;
       OUT_P_MSB = I2C_ReadRegister(MPL3115A2_I2C_ADDRESS, OUT_P_MSB_REG);        // High byte of integer part of altitude,
       OUT_P_CSB = I2C_ReadRegister(MPL3115A2_I2C_ADDRESS, OUT_P_CSB_REG);        // Low byte of integer part of altitude
       OUT_P_LSB = I2C_ReadRegister(MPL3115A2_I2C_ADDRESS, OUT_P_LSB_REG);        // Decimal part of altitude in bits 7-4
       OUT_T_MSB = I2C_ReadRegister(MPL3115A2_I2C_ADDRESS, OUT_T_MSB_REG);        // Integer part of temperature
       OUT_T_LSB = I2C_ReadRegister(MPL3115A2_I2C_ADDRESS, OUT_T_LSB_REG);        // Decimal part of temperature in bits 7-4
            /* Get altitude, the 20-bit measurement in meters is comprised of a signed integer component and
       a fractional component. The signed 16-bit integer component is located in OUT_P_MSB and OUT_P_CSB.
       The fraction component is located in bits 7-4 of OUT_P_LSB. Bits 3-0 of OUT_P_LSB are not used */
           Altitude = (float) ((short) ((OUT_P_MSB << | OUT_P_CSB)) + (float) (OUT_P_LSB >> 4) * 0.0625;
             /* Get temperature, the 12-bit temperature measurement in °C is comprised of a signed integer component and
       a fractional component. The signed 8-bit integer component is located in OUT_T_MSB. The fractional component
       is located in bits 7-4 of OUT_T_LSB. Bits 3-0 of OUT_T_LSB are not used. */
            Temperature = (float) ((signed char) OUT_T_MSB) + (float) (OUT_T_LSB >> 4) * 0.0625;
The calculated values can be watched in the "Variables" window on the top right of the Debug perspective or in the FreeMASTER application.
Attached you can find the complete source code written in the CW 10.3 as well as the FreeMASTER project.
If there are any questions regarding this simple application, please feel free to ask below. Your feedback or suggestions are also welcome.
Tomas
Original Attachment has been moved to: FreeMASTER---XTRINSIC-SENSORS-EVK_MPL3115A2_BasicReadUsingInterrupt.zip
Original Attachment has been moved to: XTRINSIC-SENSORS-EVK_MPL3115A2_BasicReadUsingInterrupt.zip
评论
Hi Tomas. I'm using KITSTBMPL3115A2 EVB to connect with KL25Z-FRDM. Connection Pins is: PTE0 <-> SDA, PTE1 <-> SCL, Pin 8 <-> VREFH, PTD3 <-> INT1 & INT2. VDD&VDDIO <-> P 3V3. GND <-> GND.
Should I have more 4.7 K Ohm pull registers for this?
Currently, I2C can not sent out.
Hi Thach,
First, sorry for not replying sooner, I did not have access to the internet during the weekend.
Yes, it is necessary to populate both 4.7k pull-up resistors for the I2C bus on the KITSTBMPL3115A2 sensor board. There are also no pull-ups on the interrupt outputs, so you can either populate them or set the interrupt pins to be push-pull outputs. To do this, just modify the following instruction in the MPL3115A2_Init routine:
replace by:
I2C_WriteRegister(MPL3115A2_I2C_ADDRESS, CTRL_REG3, 0x00);          // Push-pull, active low interrupts
I hope it helps.
Tomas
Hi Tomas,
I had some strange readings from my mpl3115a2. First of all the sensor seems to work just fine, but now i'm getting 0xFF from P_MSB. So usly my altitude should be around 45meter but now im at -23meter.
is it shomthing that can be fixed or is the sensor broken. i read auto increment from 0x00 to 0x04 = P_msb to T_lsb, and the temperatur works just fine.
Hi Viggo,
If you are using a multiple-byte (burst) read, you should start from register OUT_P_MSB (0x01):
I2C_ReadMultiRegisters(MPL3115A2_I2C_ADDRESS, OUT_P_MSB_REG, 5, AltTempData);
I hope this helps.
Tomas
yes. is 0x01 to 0x05, i wrote wrong numbers.
I2C_RegWrite(MPL3115A2_ADDRESS,OUT_P_MSB,5);
this is my i2c reg Write methode. and it looks almost the same ass yours.
so it's not that. i have gone thrue my code and i cant find anything wrong. so i wonder is this a bug ?
Hi Viggo,
OK, I just wanted to make sure that you read correct registers.
The fact is that the MPL3115A2 is designed more for the scenario of going between two floors, or from one point to another and measuring this delta, than to be giving absolute position.
To adjust the most precise altitude, I recommend the following:
1. If you know your current position and the altitude using some external calibration point in meters, then adjust the OFF_H register (0x2D) to account for the discrepancy.
2. If you would like to adjust to weather changes, the BAR_IN_MSB (0x14) and BAR_IN_LSB (0x15) registers allow you to modify the pressure value that internally is used in the equation that converts pressure in Pascals to meters for altitude. So if there is a very stormy day and your local weather/airport gives the pressure normalized for sea level, this value should go into these registers. This should bring the height closer and additional will require the OFF_H adjustment.
Tomas
Hi Tomas,
I am having trouble using One-Shot-Mode(OST).  I am trying to have the pressure sensor initiate a measurement, poll the status register to see if (PTDR|PDR|TDR) are set, and once they are, read OUT_T_MSB, OUT_T_LSB, OUT_P_MSB,OUT_P_CSB, OUT_P_LSB and repeat forever.  First  I set ControlReg1 to 0x01 to clear the OST bit and immediately after I set the ControlReg1 to 0x03 to start a new measurement.  But the Data ready bits in the Status Register never seem to get set.  I found thaf if I dont check the Status register and  always read the OUT Registers then I get bad measurement results.  If I set a break point at the measurement read then I get good results, which I think is because I've given enough time for the measurements to complete.  Any ideas or suggestions would be greatly appreciated.
Justin
Hi Justin,
It sounds to me like the data ready bits (PTDR, PDR and TDR) are not enabled using the corresponding bits in the PT_DATA_CFG (0x13) register. Please try to write 0x07 to the PT_DATA_CFG register to enable all data ready bits.
I hope it helps.
Tomas
Hi Tomas,
Thanks for taking the time to help.  I initialize the MPL3115A2 with the following I2C writes:
    MPL3115A2_WriteReg(CTRL_REG1, 0);
    MPL3115A2_WriteReg(CTRL_REG2,2 );//ST_MASK
    MPL3115A2_WriteReg(CTRL_REG3, (PP_OD1_MASK | PP_OD2_MASK));
    MPL3115A2_WriteReg(CTRL_REG4, INT_EN_CLEAR);
    MPL3115A2_WriteReg(CTRL_REG5, INT_CFG_CLEAR);
    MPL3115A2_WriteReg(PT_DATA_CFG_REG, 7);//(DREM_MASK | PDEFE_MASK | TDEFE_MASK)
    MPL3115A2_WriteReg(F_SETUP_REG, 0);
Then I set to Active mode, and then Set the One-Shot:
    MPL3115A2_WriteReg(CTRL_REG1, ACTIVE_MASK);        //Set to Active
    MPL3115A2_WriteReg(CTRL_REG1, ACTIVE_SBYB_OST);        //Set OST Bit to Trigger Measurement
Then in the main loop I keep checking the Status Register:
            if(GetEventFlags() == 0x0E)
               //Pressure
              MPL3115A2_ReadReg(OUT_P_MSB_REG, &temp, 1);
              rawPressure->Byte.msbPressure = temp;
              MPL3115A2_ReadReg(OUT_P_CSB_REG, &temp, 1);
              rawPressure->Byte.csbPressure = temp;
              MPL3115A2_ReadReg(OUT_P_LSB_REG, &temp, 1);
              rawPressure->Byte.lsbPressure = temp;
               // Temp
             MPL3115A2_ReadReg(OUT_T_MSB_REG, &temp, 1);
             rawTemperature->hiTempByte = temp;
             MPL3115A2_ReadReg(OUT_T_LSB_REG, &temp, 1);
             rawTemperature->loTempByte = temp;
              MPL3115A2_WriteReg(CTRL_REG1, ACTIVE_MASK);        //Clear the previous One-Shot Bit
              MPL3115A2_WriteReg(CTRL_REG1, ACTIVE_SBYB_OST);        //Set OST Bit to Trigger another Measurement
          From what I understand, reading the OUT_P_MSB and OUT_T_MSB should clear the PDR and TDR bits correct?
          Am I just missing something, I had trouble earlier because I was using the KL25Z and I didn't know about the I2C errata that causes repeated start to not work, but I fixed the code and now I see the repeated start.
Thanks again.
Hi Tomas,
You were right, I was not setting the PT_DATA_CFG register.  It turned out that I was not giving the sensor enough time between STOP and START conditions according to tBUF spec in the data sheet.  I put a delay in my I2C read and write functions and now the sensor works great.
Thanks for your help.
Justin
OK, glad to hear you got it working, Justin.
Tomas
Hi Tomas,
I am seeing that the delay time required between stop and start is dependent upon the SCL clock frequency.  Specifically the lower the clock speed the greater the delay required.  If I'm running the SCL at 15KHz, it requires over 100uS delay but as I increase my clock speed I can decrease the delay and still get good communication with the sensor.  Can you confirm this or help me understand what is going on?
Justin
Hi Tomas,
We are looking at get the MPL3115A2 sensor with a number of different slave addresses for a medical device application.  We will have 3 MPL3115A2 sensors on a single clock and data line.  With other sensors, we have been able to re-program the slave address ourselves.  Can we do this with the MPL3115A2?  If not, how do we get different slave addresses from the factory?  Our application is large but we are still in the product validation stage.
Carl
Hi Carl,
Unfortunately the MPL3115A2 does not have address select pins and there is no way to re-program the slave address by user.
For small quantities, I would recommend using an I2C multiplexer such as the PCA9544A.
For big quantities, we might be able to change the slave address. Please send me a direct message with more information about your application, volumes, production data and what addresses you would like. I will forward the information to the product line and write you back once I get a response.
Tomas
Hi Tomas,
Thank you for your reply.
We would be looking at a high volume of sensors (in the 100,000+ range).
Who should we speak with to discuss our application?
Carl
On Wed, Jan 13, 2016 at 2:01 AM, TomasVaverka <[email protected]
Hi Carl,
I have informed both the product line manager and one of our local apps engineers who specializes in pressure sensors of your interest in the MPL3115A2. They will contact you soon via email.
Thanks again for your interest.
Tomas
Thank you Tomas,
We look forward to hearing from someone regarding our application.
Also, what is the sample rate for the MPL3115A2 sensor? We are having
difficulty sampling at a rate faster than 1 sec. Ideally, we would like to
sample at 1/10 second.
Carl Geisz
On Mon, Jan 18, 2016 at 2:53 AM, TomasVaverka <[email protected]
Carl,
You can increase the sample rate by utilizing One Shot Mode (OST). This is described in section 7.17.1 CTRL_REG1 on Table 58. OST mode gives you the ability to initiate a measurement immediately. The automated mode for the MPL3115A2 takes a measurement once a second. Let me know if you have any questions on OST mode.
I have passed your contact information to our sales team in St. Paul and someone should be contacting you shortly.
Miguel
%3CLINGO-SUB%20id%3D%22lingo-sub-1115987%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMPL3115A2%20-%20%E9%AB%98%E5%BA%A6%E5%92%8C%E6%B8%A9%E5%BA%A6%E6%B5%8B%E9%87%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1115987%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%E5%A4%A7%E5%AE%B6%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E6%88%91%E6%83%B3%E5%88%86%E4%BA%AB%E4%B8%80%E4%B8%AA%E7%AE%80%E5%8D%95%E7%9A%84%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%2F%E6%BC%94%E7%A4%BA%EF%BC%8C%E5%AE%83%E4%BB%8E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fwww.freescale.com%252Fwebapp%252Fsps%252Fsite%252Fprod_summary.jsp%253Fcode%253DMPL3115A2%22%20target%3D%22_blank%22%3E%20Xtrinsic%20MPL3115A2%20%E5%8E%8B%E5%8A%9B%E4%BC%A0%E6%84%9F%E5%99%A8%20%E8%AF%BB%E5%8F%96%E9%AB%98%E5%BA%A6%E5%92%8C%E6%B8%A9%E5%BA%A6%E6%95%B0%E6%8D%AE%EF%BC%8C%E5%B9%B6%E9%80%9A%E8%BF%87%3C%2FA%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fusbdm.sourceforge.net%252F%22%20target%3D%22_blank%22%3E%20USBDM%20%E6%8E%A5%E5%8F%A3%3C%2FA%3E%20%E4%BD%BF%E7%94%A8%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fwww.freescale.com%252Fwebapp%252Fsps%252Fsite%252Fprod_summary.jsp%253Fcode%253DFREEMASTER%22%20target%3D%22_blank%22%3E%20FreeMASTER%20%E5%B7%A5%E5%85%B7%3C%2FA%3E%20%E5%AF%B9%E5%85%B6%E8%BF%9B%E8%A1%8C%E5%8F%AF%E8%A7%86%E5%8C%96%E3%80%82%E6%88%91%E4%BD%BF%E7%94%A8%E4%BA%86%E6%9C%80%E8%BF%91%E5%8F%91%E5%B8%83%E7%9A%84%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fwww.element14.com%252Fcommunity%252Fcommunity%252Fknode%252Fdev_platforms_kits%252Felement14_dev_kits%252Ffreescale_xtrinsic_evk%22%20target%3D%22_blank%22%3EXtrinsic%20MEMS%20%E4%BC%A0%E6%84%9F%E5%99%A8%E6%9D%BF%3C%2FA%3E%EF%BC%8C%E5%AE%83%E5%85%B7%E6%9C%89%E4%B8%89%E7%A7%8D%E7%B1%BB%E5%9E%8B%E7%9A%84%20Xtrinsic%20%E4%BC%A0%E6%84%9F%E5%99%A8%EF%BC%8C%E5%8C%85%E6%8B%AC%20MPL3115A2%EF%BC%8C%E5%B9%B6%E4%B8%94%E4%B8%8E%20Freescale%20%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fwww.freescale.com%252Fwebapp%252Fsps%252Fsite%252Fprod_summary.jsp%253Fcode%253DFRDM-KL25Z%22%20target%3D%22_blank%22%3EFRDM-KL25Z%20%E5%B9%B3%E5%8F%B0%3C%2FA%3E%E5%AE%8C%E5%85%A8%E5%85%BC%E5%AE%B9%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%E6%A0%B9%E6%8D%AE%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fwww.element14.com%252Fcommunity%252Fdocs%252FDOC-54623%252Fl%252Felement14-user-guide-for-xtrinsic-sensors-evaluation-kit%22%20target%3D%22_blank%22%3E%E7%94%A8%E6%88%B7%E6%89%8B%E5%86%8C%3C%2FA%3E%EF%BC%8CMPL3115A2%20%E7%9A%84%E4%B8%A4%E4%B8%AA%E4%B8%AD%E6%96%AD%E5%BC%95%E8%84%9A%E9%80%9A%E8%BF%87%204.7K%20%E4%B8%8A%E6%8B%89%E7%94%B5%E9%98%BB%E8%BF%9E%E6%8E%A5%E5%88%B0%20KL25Z%20MCU%20%E7%9A%84%20PTD3%20%E5%BC%95%E8%84%9A%EF%BC%8C%E4%BB%A5%E5%8F%8A%E8%BF%9E%E6%8E%A5%E5%88%B0%20KL25Z%20%E4%B8%8A%E7%9A%84%20I2C1%20%E6%A8%A1%E5%9D%97%EF%BC%88PTE1%20%E5%92%8C%20PTE0%20%E5%BC%95%E8%84%9A%EF%BC%89%E7%9A%84%20SCL%20%E5%92%8C%20SDA%20%E7%BA%BF%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8CMCU%20%E9%85%8D%E7%BD%AE%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%20color%3A%20%23000000%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010pt%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CSTRONG%3Evoid%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%20%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CSTRONG%3EMCU_Init%3C%2FSTRONG%3E%3C%2FSPAN%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010pt%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CSTRONG%3Evoid%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2FI2C1%20module%20initialization%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3ESIM_SCGC4%20%7C%3D%20SIM_SCGC4_I2C1_MASK%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20%E6%89%93%E5%BC%80%20I2C1%20%E6%A8%A1%E5%9D%97%E7%9A%84%E6%97%B6%E9%92%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3ESIM_SCGC5%20%7C%3D%20SIM_SCGC5_PORTE_MASK%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20%E6%89%93%E5%BC%80%E7%AB%AF%E5%8F%A3%20E%20%E6%A8%A1%E5%9D%97%E7%9A%84%E6%97%B6%E9%92%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EPORTE_PCR1%20%3D%20PORT_PCR_MUX(6)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20PTE1%20%E5%BC%95%E8%84%9A%E4%B8%BA%20I2C1%20SCL%20%E7%BA%BF%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EPORTE_PCR0%20%3D%20PORT_PCR_MUX(6)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20PTE0%20%E5%BC%95%E8%84%9A%E4%B8%BA%20I2C1%20SDA%20%E7%BA%BF%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EI2C1_F%20%3D%200x14%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20SDA%E4%BF%9D%E6%8C%81%E6%97%B6%E9%97%B4%3D2.125us%EF%BC%8CSCL%E5%90%AF%E5%8A%A8%E4%BF%9D%E6%8C%81%E6%97%B6%E9%97%B4%3D4.25us%EF%BC%8CSCL%E5%81%9C%E6%AD%A2%E4%BF%9D%E6%8C%81%E6%97%B6%E9%97%B4%3D5.125us%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EI2C1_C1%20%3D%20I2C_C1_IICEN_MASK%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%E5%90%AF%E7%94%A8%20I2C1%20%E6%A8%A1%E5%9D%97%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%E9%85%8D%E7%BD%AE%20PTD3%20%E5%BC%95%E8%84%9A%EF%BC%88%E8%BF%9E%E6%8E%A5%E5%88%B0%20MPL3115A2%20%E7%9A%84%20INT2%EF%BC%89%E7%94%A8%E4%BA%8E%E4%B8%8B%E9%99%8D%E6%B2%BF%E4%B8%AD%E6%96%AD%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3ESIM_SCGC5%20%7C%3D%20SIM_SCGC5_PORTD_MASK%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20%E6%89%93%E5%BC%80%E7%AB%AF%E5%8F%A3%20D%20%E6%A8%A1%E5%9D%97%E7%9A%84%E6%97%B6%E9%92%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EPORTD_PCR3%20%7C%3D%20(0%7CPORT_PCR_ISF_MASK%7C%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%E6%B8%85%E9%99%A4%E4%B8%AD%E6%96%AD%E6%A0%87%E5%BF%97%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EPORT_PCR_MUX(0x1)%7C%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20PTD3%20%E9%85%8D%E7%BD%AE%E4%B8%BA%20GPIO%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EPORT_PCR_IRQC(0xA))%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20PTD3%20%E9%85%8D%E7%BD%AE%E4%B8%BA%E4%B8%8B%E9%99%8D%E6%B2%BF%E4%B8%AD%E6%96%AD%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%E5%9C%A8NVIC%E4%B8%8A%E5%90%AF%E7%94%A8PORTD%E4%B8%AD%E6%96%AD%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3ENVIC_ICPR%20%7C%3D%201%20%26lt%3B%26lt%3B%20((%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%230000c0%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CEM%3EINT_PORTD%3C%2FEM%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E-%2016)%2532)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3ENVIC_ISER%20%7C%3D%201%20%26lt%3B%26lt%3B%20((%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%230000c0%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CEM%3EINT_PORTD%3C%2FEM%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E-%2016)%2532)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-family%3A%20Consolas%3B%20font-size%3A%2010pt%3B%20font-style%3A%20inherit%3B%20line-height%3A%201.5em%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%E5%9C%A8ISR%E4%B8%AD%EF%BC%8C%E4%BB%85%E6%B8%85%E9%99%A4%E4%B8%AD%E6%96%AD%E6%A0%87%E5%BF%97%E5%B9%B6%E8%AE%BE%E7%BD%AEDataReady%E5%8F%98%E9%87%8F%E4%BB%A5%E6%8C%87%E7%A4%BA%E6%96%B0%E6%95%B0%E6%8D%AE%E7%9A%84%E5%88%B0%E8%BE%BE%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010pt%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CSTRONG%3Evoid%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%20%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CSTRONG%3EPORTD_IRQHandler%3C%2FSTRONG%3E%3C%2FSPAN%3E()%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EPORTD_PCR3%20%7C%3D%20PORT_PCR_ISF_MASK%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%E6%B8%85%E9%99%A4%E4%B8%AD%E6%96%AD%E6%A0%87%E5%BF%97%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%E6%95%B0%E6%8D%AE%E5%B0%B1%E7%BB%AA%3D1%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%E5%9C%A8%E5%88%9D%E5%A7%8B%E5%8C%96%E5%BC%80%E5%A7%8B%E6%97%B6%EF%BC%8C%E9%80%9A%E8%BF%87%E8%AE%BE%E7%BD%AE%20CTRL_REG1%20%E5%AF%84%E5%AD%98%E5%99%A8%E7%9A%84%20RST%20%E4%BD%8D%EF%BC%8C%E5%B0%86%E6%89%80%E6%9C%89%20MPL3115A2%20%E5%AF%84%E5%AD%98%E5%99%A8%E9%87%8D%E7%BD%AE%E4%B8%BA%E5%85%B6%E9%BB%98%E8%AE%A4%E5%80%BC%E3%80%82DRDY%20%E4%B8%AD%E6%96%AD%E8%A2%AB%E5%90%AF%E7%94%A8%E5%B9%B6%E8%B7%AF%E7%94%B1%E5%88%B0%E9%85%8D%E7%BD%AE%E4%B8%BA%E5%BC%80%E6%BC%8F%E3%80%81%E4%BD%8E%E7%94%B5%E5%B9%B3%E6%9C%89%E6%95%88%E8%BE%93%E5%87%BA%E7%9A%84%20INT2%20%E5%BC%95%E8%84%9A%E3%80%82%E5%9C%A8%20MPL3115A2%20%E5%88%9D%E5%A7%8B%E5%8C%96%E6%9C%9F%E9%97%B4%EF%BC%8C%E9%80%89%E6%8B%A9%20128%20%E7%9A%84%20OSR%20%E6%AF%94%E7%8E%87%EF%BC%8C%E6%9C%80%E5%90%8E%E8%AF%A5%E9%83%A8%E4%BB%B6%E8%BF%9B%E5%85%A5%E4%B8%BB%E5%8A%A8%E9%AB%98%E5%BA%A6%E8%AE%A1%E6%A8%A1%E5%BC%8F%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010pt%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CSTRONG%3Evoid%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%20%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CSTRONG%3EMPL3115A2_Init%3C%2FSTRONG%3E%3C%2FSPAN%3E%20(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010pt%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CSTRONG%3Evoid%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3E%E6%97%A0%E7%AC%A6%E5%8F%B7%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3E%E5%AD%97%E7%AC%A6%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3Ereg_val%20%3D%200%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EI2C_WriteRegister(MPL3115A2_I2C_ADDRESS%2C%20CTRL_REG1%2C%200x04)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%E5%B0%86%E6%89%80%E6%9C%89%E5%AF%84%E5%AD%98%E5%99%A8%E9%87%8D%E7%BD%AE%E4%B8%BAPOR%E5%80%BC%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3E%2F%2F%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%E7%AD%89%E5%BE%85RST%E4%BD%8D%E6%B8%85%E9%99%A4%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3Ereg_val%20%3D%20I2C_ReadRegister(MPL3115A2_I2C_ADDRESS%EF%BC%8CCTRL_REG1)%20%26amp%3B%200x04%3B%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%7D)%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3E%E8%80%8C%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%EF%BC%88reg_val%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EI2C_WriteRegister(MPL3115A2_I2C_ADDRESS%2C%20PT_DATA_CFG_REG%2C%200x07)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%E5%90%AF%E7%94%A8%E6%95%B0%E6%8D%AE%E6%A0%87%E5%BF%97%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EI2C_WriteRegister(MPL3115A2_I2C_ADDRESS%2C%20CTRL_REG3%2C%200x11)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%E5%BC%80%E6%BC%8F%EF%BC%8C%E4%BD%8E%E7%94%B5%E5%B9%B3%E6%9C%89%E6%95%88%E4%B8%AD%E6%96%AD%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EI2C_WriteRegister(MPL3115A2_I2C_ADDRESS%2C%20CTRL_REG4%2C%200x80)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%E5%90%AF%E7%94%A8DRDY%E4%B8%AD%E6%96%AD%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EI2C_WriteRegister(MPL3115A2_I2C_ADDRESS%2C%20CTRL_REG5%2C%200x00)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2FDRDY%E4%B8%AD%E6%96%AD%E8%B7%AF%E7%94%B1%E5%88%B0INT2%20-%20PTD3%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EI2C_WriteRegister(MPL3115A2_I2C_ADDRESS%2C%20CTRL_REG1%2C%200xB9)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20%E4%B8%BB%E5%8A%A8%E9%AB%98%E5%BA%A6%E8%AE%A1%E6%A8%A1%E5%BC%8F%EF%BC%8COSR%20%3D%20128%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%23000000%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%20color%3A%20%23000000%3B%22%3E%E5%9C%A8%E4%B8%BB%E5%BE%AA%E7%8E%AF%E4%B8%AD%EF%BC%8C%E5%AE%9A%E6%9C%9F%E6%A3%80%E6%9F%A5%20DataReady%20%E5%8F%98%E9%87%8F%EF%BC%8C%E5%A6%82%E6%9E%9C%E8%AE%BE%E7%BD%AE%E4%BA%86%E8%AF%A5%E5%8F%98%E9%87%8F%EF%BC%8C%E5%88%99%E8%AF%BB%E5%8F%96%E5%B9%B6%E8%AE%A1%E7%AE%97%E9%AB%98%E5%BA%A6%E5%92%8C%E6%B8%A9%E5%BA%A6%E6%95%B0%E6%8D%AE%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010pt%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%22%3E%3CSTRONG%3Eif%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E(DataReady)%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20%E6%96%B0%E7%9A%84%E4%B8%80%E7%BB%84%E6%95%B0%E6%8D%AE%E6%98%AF%E5%90%A6%E5%87%86%E5%A4%87%E5%A5%BD%E4%BA%86%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%7B%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20Consolas%3B%22%3E%E6%95%B0%E6%8D%AE%E5%B0%B1%E7%BB%AA%3D0%EF%BC%9B%3C%2FSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EOUT_P_MSB%20%3D%20I2C_ReadRegister(MPL3115A2_I2C_ADDRESS%2C%20OUT_P_MSB_REG)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%E9%AB%98%E5%BA%A6%E6%95%B4%E6%95%B0%E9%83%A8%E5%88%86%E7%9A%84%E9%AB%98%E5%AD%97%E8%8A%82%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EOUT_P_CSB%20%3D%20I2C_ReadRegister(MPL3115A2_I2C_ADDRESS%2C%20OUT_P_CSB_REG)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%E9%AB%98%E5%BA%A6%E6%95%B4%E6%95%B0%E9%83%A8%E5%88%86%E7%9A%84%E4%BD%8E%E5%AD%97%E8%8A%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EOUT_P_LSB%20%3D%20I2C_ReadRegister(MPL3115A2_I2C_ADDRESS%2C%20OUT_P_LSB_REG)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F7-4%E4%BD%8D%E9%AB%98%E5%BA%A6%E7%9A%84%E5%B0%8F%E6%95%B0%E9%83%A8%E5%88%86%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EOUT_T_MSB%20%3D%20I2C_ReadRegister(MPL3115A2_I2C_ADDRESS%2C%20OUT_T_MSB_REG)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%E6%B8%A9%E5%BA%A6%E7%9A%84%E6%95%B4%E6%95%B0%E9%83%A8%E5%88%86%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EOUT_T_LSB%20%3D%20I2C_ReadRegister(MPL3115A2_I2C_ADDRESS%2C%20OUT_T_LSB_REG)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F7-4%E4%BD%8D%E6%B8%A9%E5%BA%A6%E7%9A%84%E5%B0%8F%E6%95%B0%E9%83%A8%E5%88%86%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F*%20%E8%8E%B7%E5%8F%96%E9%AB%98%E5%BA%A6%EF%BC%8C%E4%BB%A5%E7%B1%B3%E4%B8%BA%E5%8D%95%E4%BD%8D%E7%9A%84%2020%20%E4%BD%8D%E6%B5%8B%E9%87%8F%E5%80%BC%E7%94%B1%E6%9C%89%E7%AC%A6%E5%8F%B7%E6%95%B4%E6%95%B0%E9%83%A8%E5%88%86%E5%92%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%E5%88%86%E6%95%B0%E9%83%A8%E5%88%86%E3%80%82%E6%9C%89%E7%AC%A6%E5%8F%B7%E7%9A%84%2016%20%E4%BD%8D%E6%95%B4%E6%95%B0%E9%83%A8%E5%88%86%E4%BD%8D%E4%BA%8E%20OUT_P_MSB%20%E5%92%8C%20OUT_P_CSB%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%E5%B0%8F%E6%95%B0%E9%83%A8%E5%88%86%E4%BD%8D%E4%BA%8E%20OUT_P_LSB%20%E7%9A%84%E4%BD%8D%207-4%E3%80%82OUT_P_LSB%20%E7%9A%84%E4%BD%8D%203-0%20%E6%9C%AA%E4%BD%BF%E7%94%A8%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%E9%AB%98%E5%BA%A6%20%3D%20%EF%BC%88%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3E%E6%B5%AE%E7%82%B9%E6%95%B0%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%EF%BC%89%EF%BC%88%EF%BC%88%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3E%E7%9F%AD%E6%95%B4%E5%9E%8B%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%EF%BC%89%EF%BC%88%EF%BC%88OUT_P_MSB%20%26lt%3B%26lt%3B%208%EF%BC%89%7C%20OUT_P_CSB%EF%BC%89%EF%BC%89%2B%EF%BC%88%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3E%E6%B5%AE%E7%82%B9%E6%95%B0%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%EF%BC%89%EF%BC%88OUT_P_LSB%20%26gt%3B%26gt%3B%204%EF%BC%89*%200.0625%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F*%20%E8%8E%B7%E5%8F%96%E6%B8%A9%E5%BA%A6%EF%BC%8C12%20%E4%BD%8D%E6%B8%A9%E5%BA%A6%E6%B5%8B%E9%87%8F%E5%80%BC%EF%BC%88%C2%B0C%EF%BC%89%E7%94%B1%E6%9C%89%E7%AC%A6%E5%8F%B7%E6%95%B4%E6%95%B0%E9%83%A8%E5%88%86%E5%92%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%E5%88%86%E6%95%B0%E9%83%A8%E5%88%86%E3%80%82%E6%9C%89%E7%AC%A6%E5%8F%B7%E7%9A%84%208%20%E4%BD%8D%E6%95%B4%E6%95%B0%E9%83%A8%E5%88%86%E4%BD%8D%E4%BA%8E%20OUT_T_MSB%E3%80%82%E5%B0%8F%E6%95%B0%E9%83%A8%E5%88%86%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%E4%BD%8D%E4%BA%8EOUT_T_LSB%E7%9A%84%E4%BD%8D7-4%E3%80%82OUT_T_LSB%20%E7%9A%84%E4%BD%8D%203-0%20%E6%9C%AA%E4%BD%BF%E7%94%A8%E3%80%82*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%E6%B8%A9%E5%BA%A6%20%3D%20%EF%BC%88%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3E%E6%B5%AE%E7%82%B9%E6%95%B0%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%EF%BC%89%EF%BC%88%EF%BC%88%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3E%E6%9C%89%E7%AC%A6%E5%8F%B7%E5%AD%97%E7%AC%A6%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%EF%BC%89OUT_T_MSB%EF%BC%89%2B%EF%BC%88%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3E%E6%B5%AE%E7%82%B9%E6%95%B0%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%EF%BC%89%EF%BC%88OUT_T_LSB%20%26gt%3B%26gt%3B%204%EF%BC%89*%200.0625%EF%BC%9B%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%7D%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%20color%3A%20%23000000%3B%22%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%9C%A8%E8%B0%83%E8%AF%95%E8%A7%86%E8%A7%92%E5%8F%B3%E4%B8%8A%E8%A7%92%E7%9A%84%E2%80%9C%E5%8F%98%E9%87%8F%E2%80%9D%E7%AA%97%E5%8F%A3%E6%88%96%20FreeMASTER%20%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E4%B8%AD%E6%9F%A5%E7%9C%8B%E8%AE%A1%E7%AE%97%E5%87%BA%E7%9A%84%E5%80%BC%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%20color%3A%20%23000000%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%20color%3A%20%23000000%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%225599_5599.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%225599_5599.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F118502i57A58BD768FC1501%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%225599_5599.jpg%22%20alt%3D%225599_5599.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E5599_5599.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MPL3115A2_Altitude%26amp%3BTemperature%20reading.JPG.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MPL3115A2_Altitude%26amp%3BTemperature%20reading.JPG.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F111641i094F06AE84951ED0%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22MPL3115A2_Altitude%26amp%3BTemperature%20reading.JPG.jpg%22%20alt%3D%22MPL3115A2_Altitude%26amp%3BTemperature%20reading.JPG.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EMPL3115A2_Altitude%26amp%3BTemperature%20reading.JPG.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%20color%3A%20%23000000%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%20color%3A%20%23000000%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%225603_5603.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%225603_5603.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F118503iD3642481C89AE789%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%225603_5603.jpg%22%20alt%3D%225603_5603.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E5603_5603.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MPL3115A2_FreeMASTER_Altitude%26amp%3BTemperature.JPG.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22MPL3115A2_FreeMASTER_Altitude%26amp%3BTemperature.JPG.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F111640i55742460045AEDBF%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22MPL3115A2_FreeMASTER_Altitude%26amp%3BTemperature.JPG.jpg%22%20alt%3D%22MPL3115A2_FreeMASTER_Altitude%26amp%3BTemperature.JPG.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EMPL3115A2_FreeMASTER_Altitude%26amp%3BTemperature.JPG.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%20color%3A%20%23000000%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%20color%3A%20%23000000%3B%22%3E%E9%99%84%E4%BB%B6%E4%B8%AD%E6%82%A8%E5%8F%AF%E4%BB%A5%E6%89%BE%E5%88%B0%E7%94%A8%20CW%2010.3%20%E4%BB%A5%E5%8F%8A%20FreeMASTER%20%E9%A1%B9%E7%9B%AE%E7%BC%96%E5%86%99%E7%9A%84%E5%AE%8C%E6%95%B4%E6%BA%90%E4%BB%A3%E7%A0%81%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%20color%3A%20%23000000%3B%22%3E%E5%A6%82%E6%9E%9C%E5%AF%B9%E8%BF%99%E4%B8%AA%E7%AE%80%E5%8D%95%E7%9A%84%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E6%9C%89%E4%BB%BB%E4%BD%95%E7%96%91%E9%97%AE%EF%BC%8C%E8%AF%B7%E9%9A%8F%E6%97%B6%E5%9C%A8%E4%B8%8B%E9%9D%A2%E6%8F%90%E9%97%AE%E3%80%82%E4%B9%9F%E6%AC%A2%E8%BF%8E%E6%82%A8%E6%8F%90%E4%BE%9B%E5%8F%8D%E9%A6%88%E6%88%96%E5%BB%BA%E8%AE%AE%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%20color%3A%20%23000000%3B%22%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20arial%2C%20helvetica%2C%20sans-serif%3B%20color%3A%20%23000000%3B%22%3ETomas%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E5%8E%9F%E5%A7%8B%E9%99%84%E4%BB%B6%E5%B7%B2%E7%A7%BB%E8%87%B3%EF%BC%9A%20%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-339255%22%20target%3D%22_blank%22%3EFreeMASTER---XTRINSIC-SENSORS-EVK_MPL3115A2_BasicReadUsingInterrupt.zip%3C%2FA%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E5%8E%9F%E5%A7%8B%E9%99%84%E4%BB%B6%E5%B7%B2%E7%A7%BB%E8%87%B3%EF%BC%9A%20%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-339255%22%20target%3D%22_blank%22%3EXTRINSIC-SENSORS-EVK_MPL3115A2_BasicReadUsingInterrupt.zip%3C%2FA%3E%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1115987%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E5%8E%8B%E5%8A%9B%E4%BC%A0%E6%84%9F%E5%99%A8%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116005%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AMPL3115A2%20-%20%E9%AB%98%E5%BA%A6%E5%92%8C%E6%B8%A9%E5%BA%A6%E6%B5%8B%E9%87%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116005%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%8D%A1%E5%B0%94%EF%BC%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%88%A9%E7%94%A8%E5%8D%95%E6%AC%A1%E6%A8%A1%E5%BC%8F%20(OST)%20%E6%9D%A5%E6%8F%90%E9%AB%98%E9%87%87%E6%A0%B7%E7%8E%87%E3%80%82%E8%A1%A8%2058%20%E4%B8%AD%E7%9A%84%207.17.1%20CTRL_REG1%20%E9%83%A8%E5%88%86%E5%AF%B9%E6%AD%A4%E8%BF%9B%E8%A1%8C%E4%BA%86%E6%8F%8F%E8%BF%B0%E3%80%82OST%20%E6%A8%A1%E5%BC%8F%E4%BD%BF%E6%82%A8%E8%83%BD%E5%A4%9F%E7%AB%8B%E5%8D%B3%E5%90%AF%E5%8A%A8%E6%B5%8B%E9%87%8F%E3%80%82MPL3115A2%20%E7%9A%84%E8%87%AA%E5%8A%A8%E6%A8%A1%E5%BC%8F%E6%AF%8F%E7%A7%92%E8%BF%9B%E8%A1%8C%E4%B8%80%E6%AC%A1%E6%B5%8B%E9%87%8F%E3%80%82%E5%A6%82%E6%9E%9C%E6%82%A8%E5%AF%B9%20OST%20%E6%A8%A1%E5%BC%8F%E6%9C%89%E4%BB%BB%E4%BD%95%E7%96%91%E9%97%AE%EF%BC%8C%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E3%80%82%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%B7%B2%E5%B0%86%E6%82%A8%E7%9A%84%E8%81%94%E7%B3%BB%E4%BF%A1%E6%81%AF%E8%BD%AC%E5%8F%91%E7%BB%99%E6%88%91%E4%BB%AC%E4%BD%8D%E4%BA%8E%E5%9C%A3%E4%BF%9D%E7%BD%97%E7%9A%84%E9%94%80%E5%94%AE%E5%9B%A2%E9%98%9F%EF%BC%8C%E5%BE%88%E5%BF%AB%E5%B0%B1%E4%BC%9A%E6%9C%89%E4%BA%BA%E4%B8%8E%E6%82%A8%E8%81%94%E7%B3%BB%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%B1%B3%E6%A0%BC%E5%B0%94%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116004%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AMPL3115A2%20-%20%E9%AB%98%E5%BA%A6%E5%92%8C%E6%B8%A9%E5%BA%A6%E6%B5%8B%E9%87%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116004%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%B0%A2%E8%B0%A2%E4%BD%A0%EF%BC%8C%E6%89%98%E9%A9%AC%E6%96%AF%EF%BC%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E6%9C%9F%E5%BE%85%E6%94%B6%E5%88%B0%E6%9C%89%E5%85%B3%E6%88%91%E4%BB%AC%E7%94%B3%E8%AF%B7%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%8F%A6%E5%A4%96%EF%BC%8CMPL3115A2%20%E4%BC%A0%E6%84%9F%E5%99%A8%E7%9A%84%E9%87%87%E6%A0%B7%E7%8E%87%E6%98%AF%E5%A4%9A%E5%B0%91%EF%BC%9F%E6%88%91%E4%BB%AC%E6%AD%A3%E5%9C%A8%3C%2FP%3E%3CP%3E%E4%BB%A5%E8%B6%85%E8%BF%87%201%20%E7%A7%92%E7%9A%84%E9%80%9F%E5%BA%A6%E9%87%87%E6%A0%B7%E5%BE%88%E5%9B%B0%E9%9A%BE%E3%80%82%E7%90%86%E6%83%B3%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8C%E6%88%91%E4%BB%AC%E5%B8%8C%E6%9C%9B%3C%2FP%3E%3CP%3E%E4%BB%A5%201%2F10%20%E7%A7%92%E7%9A%84%E9%80%9F%E5%BA%A6%E9%87%87%E6%A0%B7%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ECarl%20Geisz%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EOn%20Mon%2C%20Jan%2018%2C%202016%20at%202%3A53%20AM%2C%20TomasVaverka%20%3CADMIN%3E%3C%2FADMIN%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116003%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AMPL3115A2%20-%20%E9%AB%98%E5%BA%A6%E5%92%8C%E6%B8%A9%E5%BA%A6%E6%B5%8B%E9%87%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116003%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3C%2FLINGO-BODY%3E%3C%2FP%3E%3CP%3EHi%20Carl%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%20font-family%3A%20'Arial'%2Csans-serif%3B%20color%3A%20%2351626f%3B%22%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E5%B0%86%E6%82%A8%E5%AF%B9%20MPL3115A2%20%E7%9A%84%E5%85%B4%E8%B6%A3%E5%91%8A%E7%9F%A5%E4%BA%86%E4%BA%A7%E5%93%81%E7%BA%BF%E7%BB%8F%E7%90%86%E5%92%8C%E6%88%91%E4%BB%AC%E5%BD%93%E5%9C%B0%E4%B8%80%E4%BD%8D%E4%B8%93%E9%97%A8%E7%A0%94%E7%A9%B6%E5%8E%8B%E5%8A%9B%E4%BC%A0%E6%84%9F%E5%99%A8%E7%9A%84%E5%BA%94%E7%94%A8%E5%B7%A5%E7%A8%8B%E5%B8%88%E3%80%82%E4%BB%96%E4%BB%AC%E5%BE%88%E5%BF%AB%E5%B0%B1%E4%BC%9A%E9%80%9A%E8%BF%87%E7%94%B5%E5%AD%90%E9%82%AE%E4%BB%B6%E4%B8%8E%E6%82%A8%E8%81%94%E7%B3%BB%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%20font-family%3A%20'Arial'%2Csans-serif%3B%20color%3A%20%2351626f%3B%22%3E%E5%86%8D%E6%AC%A1%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%85%B3%E6%B3%A8%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%20font-family%3A%20'Arial'%2Csans-serif%3B%20color%3A%20%2351626f%3B%22%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22background%3A%20white%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%20font-family%3A%20'Arial'%2Csans-serif%3B%20color%3A%20%2351626f%3B%22%3ETomas%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116002%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AMPL3115A2%20-%20%E9%AB%98%E5%BA%A6%E5%92%8C%E6%B8%A9%E5%BA%A6%E6%B5%8B%E9%87%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116002%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Tomas%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E5%B0%86%E4%BC%9A%E7%9C%8B%E5%88%B0%E5%A4%A7%E9%87%8F%E7%9A%84%E4%BC%A0%E6%84%9F%E5%99%A8%EF%BC%88%E5%9C%A8%20100%2C000%2B%20%E4%B8%AA%E8%8C%83%E5%9B%B4%E5%86%85%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E5%BA%94%E8%AF%A5%E4%B8%8E%E8%B0%81%E8%AE%A8%E8%AE%BA%E6%88%91%E4%BB%AC%E7%9A%84%E7%94%B3%E8%AF%B7%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ECarl%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E2016%20%E5%B9%B4%201%20%E6%9C%88%2013%20%E6%97%A5%E6%98%9F%E6%9C%9F%E4%B8%89%E5%87%8C%E6%99%A8%202%3A01%EF%BC%8CTomasVaverka%20%3CADMIN%3E%3C%2FADMIN%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116001%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AMPL3115A2%20-%20%E9%AB%98%E5%BA%A6%E5%92%8C%E6%B8%A9%E5%BA%A6%E6%B5%8B%E9%87%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116001%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3C%2FLINGO-BODY%3E%3C%2FP%3E%3CP%3EHi%20Carl%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%20font-family%3A%20'Arial'%2Csans-serif%3B%20color%3A%20%2351626f%3B%20background%3A%20white%3B%22%3E%E4%B8%8D%E5%B9%B8%E7%9A%84%E6%98%AF%EF%BC%8CMPL3115A2%20%E6%B2%A1%E6%9C%89%E5%9C%B0%E5%9D%80%E9%80%89%E6%8B%A9%E5%BC%95%E8%84%9A%EF%BC%8C%E5%B9%B6%E4%B8%94%E7%94%A8%E6%88%B7%E6%97%A0%E6%B3%95%E9%87%8D%E6%96%B0%E7%BC%96%E7%A8%8B%E4%BB%8E%E5%B1%9E%E5%9C%B0%E5%9D%80%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%20font-family%3A%20'Arial'%2Csans-serif%3B%20color%3A%20%2351626f%3B%20background%3A%20white%3B%22%3E%E5%AF%B9%E4%BA%8E%E5%B0%91%E9%87%8F%EF%BC%8C%E6%88%91%E5%BB%BA%E8%AE%AE%E4%BD%BF%E7%94%A8%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%20font-family%3A%20'Arial'%2Csans-serif%3B%20color%3A%20%2351626f%3B%20background%3A%20white%3B%22%3EI%20%3CSUP%3E2%3C%2FSUP%3E%20C%3C%2FSPAN%3E%E5%A4%9A%E8%B7%AF%E5%A4%8D%E7%94%A8%E5%99%A8%EF%BC%8C%E4%BE%8B%E5%A6%82%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Fdocuments%2Fdata_sheet%2FPCA9544A.pdf%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EPCA9544A%3C%2FA%3E%20%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%20font-family%3A%20'Arial'%2Csans-serif%3B%20color%3A%20%2351626f%3B%20background%3A%20white%3B%22%3E%E5%AF%B9%E4%BA%8E%E5%A4%A7%E9%87%8F%E6%83%85%E5%86%B5%EF%BC%8C%E6%88%91%E4%BB%AC%E4%B9%9F%E8%AE%B8%E8%83%BD%E5%A4%9F%E6%94%B9%E5%8F%98%E4%BB%8E%E5%B1%9E%E5%9C%B0%E5%9D%80%E3%80%82%E8%AF%B7%E7%9B%B4%E6%8E%A5%E5%90%91%E6%88%91%E5%8F%91%E9%80%81%E6%B6%88%E6%81%AF%EF%BC%8C%E5%85%B6%E4%B8%AD%E5%8C%85%E5%90%AB%E6%9C%89%E5%85%B3%E6%82%A8%E7%9A%84%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E3%80%81%E6%95%B0%E9%87%8F%E3%80%81%E7%94%9F%E4%BA%A7%E6%95%B0%E6%8D%AE%E4%BB%A5%E5%8F%8A%E6%82%A8%E6%83%B3%E8%A6%81%E7%9A%84%E5%9C%B0%E5%9D%80%E7%9A%84%E6%9B%B4%E5%A4%9A%E4%BF%A1%E6%81%AF%E3%80%82%E6%88%91%E4%BC%9A%E5%B0%86%E4%BF%A1%E6%81%AF%E8%BD%AC%E5%8F%91%E7%BB%99%E4%BA%A7%E5%93%81%E7%BA%BF%EF%BC%8C%E5%B9%B6%E5%9C%A8%E6%94%B6%E5%88%B0%E5%9B%9E%E5%A4%8D%E5%90%8E%E5%9B%9E%E5%A4%8D%E6%82%A8%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%20font-family%3A%20'Arial'%2Csans-serif%3B%20color%3A%20%2351626f%3B%20background%3A%20white%3B%22%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.5pt%3B%20font-family%3A%20'Arial'%2Csans-serif%3B%20color%3A%20%2351626f%3B%20background%3A%20white%3B%22%3ETomas%20%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116000%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AMPL3115A2%20-%20%E9%AB%98%E5%BA%A6%E5%92%8C%E6%B8%A9%E5%BA%A6%E6%B5%8B%E9%87%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116000%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Tomas%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E6%AD%A3%E5%9C%A8%E7%A0%94%E7%A9%B6%E4%B8%BA%E5%8C%BB%E7%96%97%E8%AE%BE%E5%A4%87%E5%BA%94%E7%94%A8%E8%8E%B7%E5%8F%96%E5%85%B7%E6%9C%89%E5%A4%9A%E4%B8%AA%E4%B8%8D%E5%90%8C%E4%BB%8E%E5%B1%9E%E5%9C%B0%E5%9D%80%E7%9A%84%20MPL3115A2%20%E4%BC%A0%E6%84%9F%E5%99%A8%E3%80%82%E6%88%91%E4%BB%AC%E5%B0%86%E5%9C%A8%E5%8D%95%E4%B8%AA%E6%97%B6%E9%92%9F%E5%92%8C%E6%95%B0%E6%8D%AE%E7%BA%BF%E4%B8%8A%E5%AE%89%E8%A3%85%203%20%E4%B8%AA%20MPL3115A2%20%E4%BC%A0%E6%84%9F%E5%99%A8%E3%80%82%E5%88%A9%E7%94%A8%E5%85%B6%E4%BB%96%E4%BC%A0%E6%84%9F%E5%99%A8%EF%BC%8C%E6%88%91%E4%BB%AC%E8%83%BD%E5%A4%9F%E8%87%AA%E5%B7%B1%E9%87%8D%E6%96%B0%E7%BC%96%E7%A8%8B%E4%BB%8E%E5%B1%9E%E5%9C%B0%E5%9D%80%E3%80%82%E6%88%91%E4%BB%AC%E5%8F%AF%E4%BB%A5%E7%94%A8%20MPL3115A2%20%E5%81%9A%E5%88%B0%E8%BF%99%E4%B8%80%E7%82%B9%E5%90%97%EF%BC%9F%E5%A6%82%E6%9E%9C%E4%B8%8D%E6%98%AF%EF%BC%8C%E6%88%91%E4%BB%AC%E5%A6%82%E4%BD%95%E4%BB%8E%E5%B7%A5%E5%8E%82%E8%8E%B7%E5%BE%97%E4%B8%8D%E5%90%8C%E7%9A%84%E4%BB%8E%E5%B1%9E%E5%9C%B0%E5%9D%80%EF%BC%9F%E6%88%91%E4%BB%AC%E7%9A%84%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E5%BE%88%E5%A4%A7%EF%BC%8C%E4%BD%86%E6%88%91%E4%BB%AC%E4%BB%8D%E5%A4%84%E4%BA%8E%E4%BA%A7%E5%93%81%E9%AA%8C%E8%AF%81%E9%98%B6%E6%AE%B5%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ECarl%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1115999%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AMPL3115A2%20-%20%E9%AB%98%E5%BA%A6%E5%92%8C%E6%B8%A9%E5%BA%A6%E6%B5%8B%E9%87%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1115999%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Tomas%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%8F%91%E7%8E%B0%E5%81%9C%E6%AD%A2%E5%92%8C%E5%90%AF%E5%8A%A8%E4%B9%8B%E9%97%B4%E6%89%80%E9%9C%80%E7%9A%84%E5%BB%B6%E8%BF%9F%E6%97%B6%E9%97%B4%E5%8F%96%E5%86%B3%E4%BA%8E%20SCL%20%E6%97%B6%E9%92%9F%E9%A2%91%E7%8E%87%E3%80%82%E5%85%B7%E4%BD%93%E6%9D%A5%E8%AF%B4%EF%BC%8C%E6%97%B6%E9%92%9F%E9%80%9F%E5%BA%A6%E8%B6%8A%E4%BD%8E%EF%BC%8C%E6%89%80%E9%9C%80%E7%9A%84%E5%BB%B6%E8%BF%9F%E5%B0%B1%E8%B6%8A%E5%A4%A7%E3%80%82%E5%A6%82%E6%9E%9C%E6%88%91%E4%BB%A5%2015KHz%20%E8%BF%90%E8%A1%8C%20SCL%EF%BC%8C%E5%88%99%E9%9C%80%E8%A6%81%E8%B6%85%E8%BF%87%20100uS%20%E7%9A%84%E5%BB%B6%E8%BF%9F%EF%BC%8C%E4%BD%86%E9%9A%8F%E7%9D%80%E6%88%91%E5%A2%9E%E5%8A%A0%E6%97%B6%E9%92%9F%E9%80%9F%E5%BA%A6%EF%BC%8C%E6%88%91%E5%8F%AF%E4%BB%A5%E5%87%8F%E5%B0%91%E5%BB%B6%E8%BF%9F%E5%B9%B6%E4%BB%8D%E7%84%B6%E5%8F%AF%E4%BB%A5%E4%B8%8E%E4%BC%A0%E6%84%9F%E5%99%A8%E4%BF%9D%E6%8C%81%E8%89%AF%E5%A5%BD%E7%9A%84%E9%80%9A%E4%BF%A1%E3%80%82%E4%BD%A0%E8%83%BD%E7%A1%AE%E8%AE%A4%E8%BF%99%E4%B8%80%E7%82%B9%E6%88%96%E8%80%85%E5%B8%AE%E5%8A%A9%E6%88%91%E4%BA%86%E8%A7%A3%E5%8F%91%E7%94%9F%E4%BA%86%E4%BB%80%E4%B9%88%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E8%B0%A2%E8%B0%A2%E3%80%82%3C%2FP%3E%3CP%3E%E8%B4%BE%E6%96%AF%E6%B1%80%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1115998%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AMPL3115A2%20-%20%E9%AB%98%E5%BA%A6%E5%92%8C%E6%B8%A9%E5%BA%A6%E6%B5%8B%E9%87%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1115998%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%E5%A5%BD%E7%9A%84%EF%BC%8C%E5%BE%88%E9%AB%98%E5%85%B4%E5%90%AC%E5%88%B0%E4%BD%A0%E6%88%90%E5%8A%9F%E4%BA%86%EF%BC%8C%E8%B4%BE%E6%96%AF%E6%B1%80%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20lang%3D%22CS%22%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3ETomas%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1115997%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AMPL3115A2%20-%20%E9%AB%98%E5%BA%A6%E5%92%8C%E6%B8%A9%E5%BA%A6%E6%B5%8B%E9%87%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1115997%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Tomas%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BD%A0%E6%98%AF%E5%AF%B9%E7%9A%84%EF%BC%8C%E6%88%91%E6%B2%A1%E6%9C%89%E8%AE%BE%E7%BD%AE%20PT_DATA_CFG%20%E5%AF%84%E5%AD%98%E5%99%A8%E3%80%82%E4%BA%8B%E5%AE%9E%E8%AF%81%E6%98%8E%EF%BC%8C%E6%A0%B9%E6%8D%AE%E6%95%B0%E6%8D%AE%E8%A1%A8%E4%B8%AD%E7%9A%84%20tBUF%20%E8%A7%84%E8%8C%83%EF%BC%8C%E6%88%91%E6%B2%A1%E6%9C%89%E5%9C%A8%20STOP%20%E5%92%8C%20START%20%E6%9D%A1%E4%BB%B6%E4%B9%8B%E9%97%B4%E7%BB%99%E4%BC%A0%E6%84%9F%E5%99%A8%E8%B6%B3%E5%A4%9F%E7%9A%84%E6%97%B6%E9%97%B4%E3%80%82%E6%88%91%E5%9C%A8%20I2C%20%E8%AF%BB%E5%86%99%E5%8A%9F%E8%83%BD%E4%B8%AD%E8%AE%BE%E7%BD%AE%E4%BA%86%E5%BB%B6%E8%BF%9F%EF%BC%8C%E7%8E%B0%E5%9C%A8%E4%BC%A0%E6%84%9F%E5%99%A8%E5%B7%A5%E4%BD%9C%E6%AD%A3%E5%B8%B8%E3%80%82%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FP%3E%3CP%3E%E8%B4%BE%E6%96%AF%E6%B1%80%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1115996%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AMPL3115A2%20-%20%E9%AB%98%E5%BA%A6%E5%92%8C%E6%B8%A9%E5%BA%A6%E6%B5%8B%E9%87%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1115996%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Tomas%2C%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E6%8A%BD%E5%87%BA%E6%97%B6%E9%97%B4%E6%9D%A5%E6%8F%90%E4%BE%9B%E5%B8%AE%E5%8A%A9%E3%80%82%E6%88%91%E4%BD%BF%E7%94%A8%E4%BB%A5%E4%B8%8B%20I2C%20%E5%86%99%E5%85%A5%E5%88%9D%E5%A7%8B%E5%8C%96%20MPL3115A2%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSTRONG%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3EMPL3115A2_WriteReg%EF%BC%88CTRL_REG1%EF%BC%8C0%EF%BC%89%EF%BC%9B%3C%2FSTRONG%3E%3CBR%20%2F%3E%20%3CSTRONG%3EMPL3115A2_WriteReg(CTRL_REG2%2C2)%3B%2F%2FST_MASK%3C%2FSTRONG%3E%3CBR%20%2F%3E%20%3CSTRONG%3EMPL3115A2_WriteReg%EF%BC%88CTRL_REG3%EF%BC%8C%EF%BC%88PP_OD1_MASK%20%7C%20PP_OD2_MASK%EF%BC%89%EF%BC%89%EF%BC%9B%3C%2FSTRONG%3E%3CBR%20%2F%3E%20%3CSTRONG%3EMPL3115A2_WriteReg%EF%BC%88CTRL_REG4%EF%BC%8CINT_EN_CLEAR%EF%BC%89%EF%BC%9B%3C%2FSTRONG%3E%3CBR%20%2F%3E%20%3CSTRONG%3EMPL3115A2_WriteReg%EF%BC%88CTRL_REG5%EF%BC%8CINT_CFG_CLEAR%EF%BC%89%EF%BC%9B%3C%2FSTRONG%3E%3CBR%20%2F%3E%20%3CSTRONG%3EMPL3115A2_WriteReg%EF%BC%88PT_DATA_CFG_REG%EF%BC%8C7%EF%BC%89%EF%BC%9B%2F%2F%EF%BC%88DREM_MASK%20%7C%20PDEFE_MASK%20%7C%20TDEFE_MASK%EF%BC%89%3C%2FSTRONG%3E%3CBR%20%2F%3E%20%3CSTRONG%3EMPL3115A2_WriteReg%EF%BC%88F_SETUP_REG%EF%BC%8C0%EF%BC%89%EF%BC%9B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%84%B6%E5%90%8E%E6%88%91%E8%AE%BE%E7%BD%AE%E4%B8%BA%E6%B4%BB%E5%8A%A8%E6%A8%A1%E5%BC%8F%EF%BC%8C%E7%84%B6%E5%90%8E%E8%AE%BE%E7%BD%AE%E4%B8%80%E6%AC%A1%E6%80%A7%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3EMPL3115A2_WriteReg%EF%BC%88CTRL_REG1%EF%BC%8CACTIVE_MASK%EF%BC%89%EF%BC%9B%2F%2F%E8%AE%BE%E7%BD%AE%E4%B8%BA%E6%B4%BB%E5%8A%A8%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3EMPL3115A2_WriteReg(CTRL_REG1%2C%20ACTIVE_SBYB_OST)%3B%20%2F%2F%E8%AE%BE%E7%BD%AEOST%E4%BD%8D%E4%BB%A5%E8%A7%A6%E5%8F%91%E6%B5%8B%E9%87%8F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E7%84%B6%E5%90%8E%E5%9C%A8%E4%B8%BB%E5%BE%AA%E7%8E%AF%E4%B8%AD%E6%88%91%E7%BB%A7%E7%BB%AD%E6%A3%80%E6%9F%A5%E7%8A%B6%E6%80%81%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20if(GetEventFlags()%20%3D%3D%200x0E)%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%7B%20%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%2F%2F%E5%8E%8B%E5%8A%9B%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3EMPL3115A2_ReadReg%EF%BC%88OUT_P_MSB_REG%EF%BC%8C%E6%B8%A9%E5%BA%A6%EF%BC%8C1%EF%BC%89%EF%BC%9B%3C%2FSTRONG%3E%3CBR%20%2F%3E%20%3CSTRONG%3ErawPressure-%26gt%3B%E5%AD%97%E8%8A%82.msbPressure%20%3D%20%E6%B8%A9%E5%BA%A6%EF%BC%9B%3C%2FSTRONG%3E%3CBR%20%2F%3E%20%3CSTRONG%3EMPL3115A2_ReadReg%EF%BC%88%E8%BE%93%E5%87%BA_P_CSB_REG%EF%BC%8C%E6%B8%A9%E5%BA%A6%EF%BC%8C1%EF%BC%89%EF%BC%9B%3C%2FSTRONG%3E%3CBR%20%2F%3E%20%3CSTRONG%3ErawPressure-%26gt%3B%E5%AD%97%E8%8A%82.csbPressure%20%3D%20%E6%B8%A9%E5%BA%A6%EF%BC%9B%3C%2FSTRONG%3E%3CBR%20%2F%3E%20%3CSTRONG%3EMPL3115A2_ReadReg%EF%BC%88%E8%BE%93%E5%87%BA_P_LSB_REG%EF%BC%8C%E6%B8%A9%E5%BA%A6%EF%BC%8C1%EF%BC%89%EF%BC%9B%3C%2FSTRONG%3E%3CBR%20%2F%3E%20%3CSTRONG%3ErawPressure-%26gt%3B%E5%AD%97%E8%8A%82.lsbPressure%20%3D%20%E6%B8%A9%E5%BA%A6%EF%BC%9B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2F%20Temp%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MPL3115A2_ReadReg(OUT_T_MSB_REG%2C%20%26amp%3Btemp%2C%201)%3B%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20rawTemperature-%26gt%3BhiTempByte%20%3D%20temp%3B%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MPL3115A2_ReadReg(OUT_T_LSB_REG%2C%20%26amp%3Btemp%2C%201)%3B%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20rawTemperature-%26gt%3BloTempByte%20%3D%20temp%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3EMPL3115A2_WriteReg(CTRL_REG1%2C%20ACTIVE_MASK)%3B%20%2F%2F%E6%B8%85%E9%99%A4%E5%89%8D%E4%B8%80%E4%B8%AA%E5%8D%95%E6%AC%A1%E8%A7%A6%E5%8F%91%E4%BD%8D%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3EMPL3115A2_WriteReg(CTRL_REG1%2C%20ACTIVE_SBYB_OST)%3B%20%2F%2F%E8%AE%BE%E7%BD%AEOST%E4%BD%8D%E4%BB%A5%E8%A7%A6%E5%8F%91%E5%8F%A6%E4%B8%80%E6%AC%A1%E6%B5%8B%E9%87%8F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%8D%AE%E6%88%91%E4%BA%86%E8%A7%A3%EF%BC%8C%E8%AF%BB%E5%8F%96%20OUT_P_MSB%20%E5%92%8C%20OUT_T_MSB%20%E5%BA%94%E8%AF%A5%E6%B8%85%E9%99%A4%20PDR%20%E5%92%8C%20TDR%20%E4%BD%8D%EF%BC%8C%E5%AF%B9%E5%90%97%EF%BC%9F%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E6%98%AF%E4%B8%8D%E6%98%AF%E9%81%97%E6%BC%8F%E4%BA%86%E4%BB%80%E4%B9%88%EF%BC%8C%E4%B9%8B%E5%89%8D%E6%88%91%E9%81%87%E5%88%B0%E4%BA%86%E9%BA%BB%E7%83%A6%EF%BC%8C%E5%9B%A0%E4%B8%BA%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20KL25Z%EF%BC%8C%E6%88%91%E4%B8%8D%E7%9F%A5%E9%81%93%E5%AF%BC%E8%87%B4%E9%87%8D%E5%A4%8D%E5%90%AF%E5%8A%A8%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%E7%9A%84%20I2C%20%E5%8B%98%E8%AF%AF%E8%A1%A8%EF%BC%8C%E4%BD%86%E6%88%91%E4%BF%AE%E5%A4%8D%E4%BA%86%E4%BB%A3%E7%A0%81%EF%BC%8C%E7%8E%B0%E5%9C%A8%E6%88%91%E7%9C%8B%E5%88%B0%E4%BA%86%E9%87%8D%E5%A4%8D%E5%90%AF%E5%8A%A8%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%86%8D%E6%AC%A1%E6%84%9F%E8%B0%A2%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1115995%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AMPL3115A2%20-%20%E9%AB%98%E5%BA%A6%E5%92%8C%E6%B8%A9%E5%BA%A6%E6%B5%8B%E9%87%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1115995%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%97%A8%EF%BC%8C%E8%B4%BE%E6%96%AF%E6%B1%80%EF%BC%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9C%A8%E6%88%91%E7%9C%8B%E6%9D%A5%EF%BC%8C%E6%95%B0%E6%8D%AE%E5%B0%B1%E7%BB%AA%E4%BD%8D%EF%BC%88PTDR%E3%80%81PDR%20%E5%92%8C%20TDR%EF%BC%89%E6%B2%A1%E6%9C%89%E4%BD%BF%E7%94%A8%20PT_DATA_CFG%EF%BC%880x13%EF%BC%89%E5%AF%84%E5%AD%98%E5%99%A8%E4%B8%AD%E7%9A%84%E7%9B%B8%E5%BA%94%E4%BD%8D%E5%90%AF%E7%94%A8%E3%80%82%E8%AF%B7%E5%B0%9D%E8%AF%95%E5%B0%86%200x07%20%E5%86%99%E5%85%A5%20PT_DATA_CFG%20%E5%AF%84%E5%AD%98%E5%99%A8%E4%BB%A5%E5%90%AF%E7%94%A8%E6%89%80%E6%9C%89%E6%95%B0%E6%8D%AE%E5%B0%B1%E7%BB%AA%E4%BD%8D%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%B8%8C%E6%9C%9B%E5%AF%B9%E6%82%A8%E6%9C%89%E6%89%80%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3ETomas%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1115994%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AMPL3115A2%20-%20%E9%AB%98%E5%BA%A6%E5%92%8C%E6%B8%A9%E5%BA%A6%E6%B5%8B%E9%87%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1115994%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Tomas%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%9C%A8%E4%BD%BF%E7%94%A8%E5%8D%95%E6%AC%A1%E6%A8%A1%E5%BC%8F%EF%BC%88OST%EF%BC%89%E6%97%B6%E9%81%87%E5%88%B0%E4%BA%86%E9%97%AE%E9%A2%98%E3%80%82%E6%88%91%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E8%AE%A9%E5%8E%8B%E5%8A%9B%E4%BC%A0%E6%84%9F%E5%99%A8%E5%90%AF%E5%8A%A8%E6%B5%8B%E9%87%8F%EF%BC%8C%E8%BD%AE%E8%AF%A2%E7%8A%B6%E6%80%81%E5%AF%84%E5%AD%98%E5%99%A8%E4%BB%A5%E6%9F%A5%E7%9C%8B%E6%98%AF%E5%90%A6%E8%AE%BE%E7%BD%AE%E4%BA%86%EF%BC%88PTDR%7CPDR%7CTDR%EF%BC%89%EF%BC%8C%E4%B8%80%E6%97%A6%E8%AE%BE%E7%BD%AE%EF%BC%8C%E5%B0%B1%E8%AF%BB%E5%8F%96%20OUT_T_MSB%20%3CSTRONG%3E%E3%80%81%3C%2FSTRONG%3E%20OUT_T_LSB%E3%80%81OUT_P_MSB%E3%80%81OUT_P_CSB%E3%80%81OUT_P_LSB%20%E5%B9%B6%E6%B0%B8%E8%BF%9C%E9%87%8D%E5%A4%8D%E3%80%82%E9%A6%96%E5%85%88%EF%BC%8C%E6%88%91%E5%B0%86%20ControlReg1%20%E8%AE%BE%E7%BD%AE%E4%B8%BA%200x01%20%E4%BB%A5%E6%B8%85%E9%99%A4%20OST%20%E4%BD%8D%EF%BC%8C%E7%84%B6%E5%90%8E%E7%AB%8B%E5%8D%B3%E5%B0%86%20ControlReg1%20%E8%AE%BE%E7%BD%AE%E4%B8%BA%200x03%20%E4%BB%A5%E5%BC%80%E5%A7%8B%E6%96%B0%E7%9A%84%E6%B5%8B%E9%87%8F%E3%80%82%E4%BD%86%E7%8A%B6%E6%80%81%E5%AF%84%E5%AD%98%E5%99%A8%E4%B8%AD%E7%9A%84%E6%95%B0%E6%8D%AE%E5%B0%B1%E7%BB%AA%E4%BD%8D%E4%BC%BC%E4%B9%8E%E4%BB%8E%E6%9C%AA%E8%A2%AB%E8%AE%BE%E7%BD%AE%E3%80%82%E6%88%91%E5%8F%91%E7%8E%B0%E5%A6%82%E6%9E%9C%E6%88%91%E4%B8%8D%E6%A3%80%E6%9F%A5%E7%8A%B6%E6%80%81%E5%AF%84%E5%AD%98%E5%99%A8%E5%B9%B6%E4%B8%94%E6%80%BB%E6%98%AF%E8%AF%BB%E5%8F%96%E8%BE%93%E5%87%BA%E5%AF%84%E5%AD%98%E5%99%A8%E9%82%A3%E4%B9%88%E6%88%91%E4%BC%9A%E5%BE%97%E5%88%B0%E9%94%99%E8%AF%AF%E7%9A%84%E6%B5%8B%E9%87%8F%E7%BB%93%E6%9E%9C%E3%80%82%E5%A6%82%E6%9E%9C%E6%88%91%E5%9C%A8%E6%B5%8B%E9%87%8F%E8%AF%BB%E6%95%B0%E5%A4%84%E8%AE%BE%E7%BD%AE%E4%B8%80%E4%B8%AA%E6%96%AD%E7%82%B9%EF%BC%8C%E9%82%A3%E4%B9%88%E6%88%91%E4%BC%9A%E5%BE%97%E5%88%B0%E8%89%AF%E5%A5%BD%E7%9A%84%E7%BB%93%E6%9E%9C%EF%BC%8C%E6%88%91%E8%AE%A4%E4%B8%BA%E8%BF%99%E6%98%AF%E5%9B%A0%E4%B8%BA%E6%88%91%E5%B7%B2%E7%BB%8F%E7%BB%99%E4%BA%86%E8%B6%B3%E5%A4%9F%E7%9A%84%E6%97%B6%E9%97%B4%E6%9D%A5%E5%AE%8C%E6%88%90%E6%B5%8B%E9%87%8F%E3%80%82%E4%BB%BB%E4%BD%95%E6%83%B3%E6%B3%95%E6%88%96%E5%BB%BA%E8%AE%AE%E9%83%BD%E5%B0%86%E4%B8%8D%E8%83%9C%E6%84%9F%E6%BF%80%E3%80%82%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E8%B4%BE%E6%96%AF%E6%B1%80%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1115993%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AMPL3115A2%20-%20%E9%AB%98%E5%BA%A6%E5%92%8C%E6%B8%A9%E5%BA%A6%E6%B5%8B%E9%87%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1115993%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Viggo%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%E5%A5%BD%E7%9A%84%EF%BC%8C%E6%88%91%E5%8F%AA%E6%98%AF%E6%83%B3%E7%A1%AE%E4%BF%9D%E6%82%A8%E8%AF%BB%E5%8F%96%E4%BA%86%E6%AD%A3%E7%A1%AE%E7%9A%84%E5%AF%84%E5%AD%98%E5%99%A8%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%E4%BA%8B%E5%AE%9E%E4%B8%8A%EF%BC%8CMPL3115A2%20%E7%9A%84%E8%AE%BE%E8%AE%A1%E6%9B%B4%E5%A4%9A%E5%9C%B0%E6%98%AF%E4%B8%BA%E4%BA%86%E5%9C%A8%E4%B8%A4%E5%B1%82%E6%A5%BC%E4%B9%8B%E9%97%B4%E6%88%96%E4%BB%8E%E4%B8%80%E4%B8%AA%E7%82%B9%E5%88%B0%E5%8F%A6%E4%B8%80%E4%B8%AA%E7%82%B9%E4%B9%8B%E9%97%B4%E7%A7%BB%E5%8A%A8%E5%B9%B6%E6%B5%8B%E9%87%8F%E8%BF%99%E4%B8%AA%E5%A2%9E%E9%87%8F%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%E6%8F%90%E4%BE%9B%E7%BB%9D%E5%AF%B9%E4%BD%8D%E7%BD%AE%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%E4%B8%BA%E4%BA%86%E8%B0%83%E6%95%B4%E6%9C%80%E7%B2%BE%E7%A1%AE%E7%9A%84%E9%AB%98%E5%BA%A6%EF%BC%8C%E6%88%91%E5%BB%BA%E8%AE%AE%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E1.%E5%A6%82%E6%9E%9C%E6%82%A8%E7%9F%A5%E9%81%93%E6%82%A8%E5%BD%93%E5%89%8D%E7%9A%84%E4%BD%8D%E7%BD%AE%E5%92%8C%E9%AB%98%E5%BA%A6%EF%BC%8C%E5%B9%B6%E4%BD%BF%E7%94%A8%E4%B8%80%E4%BA%9B%E5%A4%96%E9%83%A8%E6%A0%A1%E5%87%86%E7%82%B9%EF%BC%88%E4%BB%A5%E7%B1%B3%E4%B8%BA%E5%8D%95%E4%BD%8D%EF%BC%89%EF%BC%8C%E5%88%99%E8%B0%83%E6%95%B4%20OFF_H%20%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%880x2D%EF%BC%89%E4%BB%A5%E8%A7%A3%E5%86%B3%E5%B7%AE%E5%BC%82%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E2.%20%E5%A6%82%E6%9E%9C%E6%82%A8%E6%83%B3%E9%80%82%E5%BA%94%E5%A4%A9%E6%B0%94%E5%8F%98%E5%8C%96%EF%BC%8CBAR_IN_MSB%20(0x14)%20%E5%92%8C%20BAR_IN_LSB%20(0x15)%20%E5%AF%84%E5%AD%98%E5%99%A8%E5%85%81%E8%AE%B8%E6%82%A8%E4%BF%AE%E6%94%B9%E5%9C%A8%E5%B0%86%E5%B8%95%E6%96%AF%E5%8D%A1%E5%8E%8B%E5%8A%9B%E8%BD%AC%E6%8D%A2%E4%B8%BA%E6%B5%B7%E6%8B%94%E7%B1%B3%E7%9A%84%E6%96%B9%E7%A8%8B%E5%BC%8F%E4%B8%AD%E5%86%85%E9%83%A8%E4%BD%BF%E7%94%A8%E7%9A%84%E5%8E%8B%E5%8A%9B%E5%80%BC%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8C%E5%A6%82%E6%9E%9C%E9%81%87%E5%88%B0%E6%9A%B4%E9%A3%8E%E9%9B%A8%E5%A4%A9%E6%B0%94%EF%BC%8C%E5%B9%B6%E4%B8%94%E6%82%A8%E5%BD%93%E5%9C%B0%E7%9A%84%E5%A4%A9%E6%B0%94%2F%E6%9C%BA%E5%9C%BA%E7%BB%99%E5%87%BA%E7%9A%84%E6%B5%B7%E5%B9%B3%E9%9D%A2%E6%A0%87%E5%87%86%E5%8C%96%E5%8E%8B%E5%8A%9B%EF%BC%8C%E5%88%99%E8%AF%A5%E5%80%BC%E5%BA%94%E8%BF%9B%E5%85%A5%E8%BF%99%E4%BA%9B%E5%AF%84%E5%AD%98%E5%99%A8%E3%80%82%E8%BF%99%E5%BA%94%E8%AF%A5%E4%BC%9A%E4%BD%BF%E9%AB%98%E5%BA%A6%E6%9B%B4%E6%8E%A5%E8%BF%91%E5%B9%B6%E4%B8%94%E8%BF%98%E9%9C%80%E8%A6%81%20OFF_H%20%E8%B0%83%E6%95%B4%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3ETomas%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1115992%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AMPL3115A2%20-%20%E9%AB%98%E5%BA%A6%E5%92%8C%E6%B8%A9%E5%BA%A6%E6%B5%8B%E9%87%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1115992%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%98%AF%E7%9A%84%E3%80%82%E6%98%AF%200x01%20%E5%88%B0%200x05%EF%BC%8C%E6%88%91%E5%86%99%E9%94%99%E4%BA%86%E6%95%B0%E5%AD%97%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI2C_RegWrite%EF%BC%88MPL3115A2_%E5%9C%B0%E5%9D%80%EF%BC%8COUT_P_MSB%EF%BC%8C5%EF%BC%89%EF%BC%9B%3C%2FP%3E%3CP%3E%E8%BF%99%E6%98%AF%E6%88%91%E7%9A%84%20i2c%20reg%20%E5%86%99%E5%85%A5%E6%96%B9%E6%B3%95%E3%80%82%E5%AE%83%E7%9C%8B%E8%B5%B7%E6%9D%A5%E5%92%8C%E4%BD%A0%E7%9A%84%E5%87%A0%E4%B9%8E%E4%B8%80%E6%A8%A1%E4%B8%80%E6%A0%B7%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%89%80%E4%BB%A5%E4%BA%8B%E5%AE%9E%E5%B9%B6%E9%9D%9E%E5%A6%82%E6%AD%A4%E3%80%82%E6%88%91%E5%B7%B2%E7%BB%8F%E6%A3%80%E6%9F%A5%E8%BF%87%E6%88%91%E7%9A%84%E4%BB%A3%E7%A0%81%EF%BC%8C%E6%B2%A1%E6%9C%89%E5%8F%91%E7%8E%B0%E4%BB%BB%E4%BD%95%E9%94%99%E8%AF%AF%E3%80%82%E6%89%80%E4%BB%A5%E6%88%91%E6%83%B3%E7%9F%A5%E9%81%93%E8%BF%99%E6%98%AF%E4%B8%80%E4%B8%AA%E9%94%99%E8%AF%AF%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1115991%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AMPL3115A2%20-%20%E9%AB%98%E5%BA%A6%E5%92%8C%E6%B8%A9%E5%BA%A6%E6%B5%8B%E9%87%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1115991%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Viggo%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E4%BD%BF%E7%94%A8%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%E5%A4%9A%E5%AD%97%E8%8A%82%EF%BC%88%E7%AA%81%E5%8F%91%EF%BC%89%E8%AF%BB%E5%8F%96%3C%2FSPAN%3E%EF%BC%8C%E5%88%99%E5%BA%94%E4%BB%8E%E5%AF%84%E5%AD%98%E5%99%A8%20OUT_P_MSB%20(0x01)%20%E5%BC%80%E5%A7%8B%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20Consolas%3B%22%3EI2C_ReadMultiRegisters%EF%BC%88%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20Consolas%3B%22%3EMPL3115A2_I2C_%E5%9C%B0%E5%9D%80%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20Consolas%3B%22%3E%EF%BC%8C%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20Consolas%3B%22%3EOUT_P_MSB_REG%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20Consolas%3B%22%3E%EF%BC%8C5%EF%BC%8CAltTempData%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%B8%8C%E6%9C%9B%E8%BF%99%E6%9C%89%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3ETomas%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1115990%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AMPL3115A2%20-%20%E9%AB%98%E5%BA%A6%E5%92%8C%E6%B8%A9%E5%BA%A6%E6%B5%8B%E9%87%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1115990%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Tomas%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E7%9A%84%20mpl3115a2%20%E8%AF%BB%E6%95%B0%E6%9C%89%E4%BA%9B%E5%A5%87%E6%80%AA%E3%80%82%E9%A6%96%E5%85%88%EF%BC%8C%E4%BC%A0%E6%84%9F%E5%99%A8%E4%BC%BC%E4%B9%8E%E5%B7%A5%E4%BD%9C%E6%AD%A3%E5%B8%B8%EF%BC%8C%E4%BD%86%E7%8E%B0%E5%9C%A8%E6%88%91%E4%BB%8E%20P_MSB%20%E8%8E%B7%E5%BE%97%E4%BA%86%200xFF%E3%80%82%E6%89%80%E4%BB%A5%E6%88%91%E7%9A%84%E6%B5%B7%E6%8B%94%E9%AB%98%E5%BA%A6%E5%BA%94%E8%AF%A5%E5%9C%A8%2045%20%E7%B1%B3%E5%B7%A6%E5%8F%B3%EF%BC%8C%E4%BD%86%E7%8E%B0%E5%9C%A8%E6%88%91%E5%9C%A8%20-23%20%E7%B1%B3%E3%80%82%3C%2FP%3E%3CP%3E%E8%BF%99%E6%98%AF%E5%8F%AF%E4%BB%A5%E4%BF%AE%E5%A4%8D%E7%9A%84%E4%B8%9C%E8%A5%BF%E5%90%97%EF%BC%9F%E6%88%96%E8%80%85%E4%BC%A0%E6%84%9F%E5%99%A8%E5%9D%8F%E4%BA%86%E3%80%82%E6%88%91%E8%AF%BB%E5%8F%96%E4%BB%8E%200x00%20%E5%88%B0%200x04%20%E7%9A%84%E8%87%AA%E5%8A%A8%E5%A2%9E%E9%87%8F%20%3D%20P_msb%20%E5%88%B0%20T_lsb%EF%BC%8C%E5%B9%B6%E4%B8%94%E6%B8%A9%E5%BA%A6%E5%B7%A5%E4%BD%9C%E6%AD%A3%E5%B8%B8%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1115989%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AMPL3115A2%20-%20%E9%AB%98%E5%BA%A6%E5%92%8C%E6%B8%A9%E5%BA%A6%E6%B5%8B%E9%87%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1115989%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8CThach%EF%BC%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%E9%A6%96%E5%85%88%EF%BC%8C%E5%BE%88%E6%8A%B1%E6%AD%89%E6%B2%A1%E6%9C%89%E6%97%A9%E7%82%B9%E5%9B%9E%E5%A4%8D%EF%BC%8C%E5%91%A8%E6%9C%AB%E6%88%91%E6%97%A0%E6%B3%95%E4%B8%8A%E7%BD%91%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E9%9C%80%E8%A6%81%E5%9C%A8%20KITSTBMPL3115A2%20%E4%BC%A0%E6%84%9F%E5%99%A8%E6%9D%BF%E4%B8%8A%E4%B8%BA%20I2C%20%E6%80%BB%E7%BA%BF%E5%A1%AB%E5%85%85%E4%B8%A4%E4%B8%AA%204.7k%20%E4%B8%8A%E6%8B%89%E7%94%B5%E9%98%BB%E3%80%82%E4%B8%AD%E6%96%AD%E8%BE%93%E5%87%BA%E4%B8%8A%E4%B9%9F%E6%B2%A1%E6%9C%89%E4%B8%8A%E6%8B%89%E7%94%B5%E9%98%BB%EF%BC%8C%E5%9B%A0%E6%AD%A4%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%A1%AB%E5%85%85%E5%AE%83%E4%BB%AC%E6%88%96%E5%B0%86%E4%B8%AD%E6%96%AD%E5%BC%95%E8%84%9A%E8%AE%BE%E7%BD%AE%E4%B8%BA%E6%8E%A8%E6%8C%BD%E8%BE%93%E5%87%BA%E3%80%82%E4%B8%BA%E6%AD%A4%EF%BC%8C%E5%8F%AA%E9%9C%80%E4%BF%AE%E6%94%B9%20MPL3115A2_Init%20%E4%BE%8B%E7%A8%8B%E4%B8%AD%E7%9A%84%E4%BB%A5%E4%B8%8B%E6%8C%87%E4%BB%A4%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EI2C_WriteRegister(MPL3115A2_I2C_ADDRESS%2C%20CTRL_REG3%2C%200x11)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%E5%BC%80%E6%BC%8F%EF%BC%8C%E4%BD%8E%E7%94%B5%E5%B9%B3%E6%9C%89%E6%95%88%E4%B8%AD%E6%96%AD%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%E6%9B%BF%E6%8D%A2%E4%B8%BA%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2010pt%3B%20font-style%3A%20inherit%3B%20font-family%3A%20Consolas%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EI2C_WriteRegister(MPL3115A2_I2C_ADDRESS%2C%20CTRL_REG3%2C%200x00)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%E6%8E%A8%E6%8C%BD%EF%BC%8C%E4%BD%8E%E7%94%B5%E5%B9%B3%E6%9C%89%E6%95%88%E4%B8%AD%E6%96%AD%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%E5%B8%8C%E6%9C%9B%E5%AF%B9%E6%82%A8%E6%9C%89%E6%89%80%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3ETomas%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1115988%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AMPL3115A2%20-%20%E9%AB%98%E5%BA%A6%E5%92%8C%E6%B8%A9%E5%BA%A6%E6%B5%8B%E9%87%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1115988%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E6%89%98%E9%A9%AC%E6%96%AF%E3%80%82%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20KITSTBMPL3115A2%20EVB%20%E8%BF%9E%E6%8E%A5%20KL25Z-FRDM%E3%80%82%E8%BF%9E%E6%8E%A5%E5%BC%95%E8%84%9A%E4%B8%BA%EF%BC%9APTE0%20%26lt%3B-%26gt%3B%20SDA%E3%80%81PTE1%20%26lt%3B-%26gt%3B%20SCL%E3%80%81%E5%BC%95%E8%84%9A%208%20%26lt%3B-%26gt%3B%20VREFH%E3%80%81PTD3%20%26lt%3B-%26gt%3B%20INT1%20%E5%92%8C%20INT2%E3%80%82VDD%26amp%3BVDDIO%20%26lt%3B-%26gt%3B%20P%203V3%E3%80%82GND%26lt%3B-%26gt%3BGND%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E6%98%AF%E5%90%A6%E5%BA%94%E8%AF%A5%E4%B8%BA%E6%AD%A4%E9%85%8D%E5%A4%87%E6%9B%B4%E5%A4%9A%204.7%20K%20Ohm%20%E6%8B%89%E5%8A%9B%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%9F%3C%2FP%3E%3CP%3E%E7%9B%AE%E5%89%8DI2C%E8%BF%98%E4%B8%8D%E8%83%BD%E5%8F%91%E9%80%81%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎02-03-2026 05:19 PM
更新人:
