MMA8652FC - Auto-WAKE/SLEEP mode
Hello Community,
One of the main features of the NXP accelerometers is the Auto-WAKE/SLEEP mode.
I would like to share this project in order to demonstrate the feasibility of using the Low-power and auto-WAKE/SLEEP modes for reducing current consumption in the different NXP accelerometers such as the MMA845x and MMA865x series.
I created this project using the FRDM-KL25Z platform and the MMA8652FC accelerometer (You may find the breakout board files here). The complete source code is written in CodeWarrior v10.x IDE.
This document gives you an introduction of the MMA8652FC accelerometer as well as the different power consumptions and guides you through the initialization process and how to appreciate the demonstration:
  1. Initialization of the MKL25Z128 MCU.
  2. Initialization of the MMA8652FC.
  3. Auto-WAKE/SLEEP mode.
  4. MMA8652FC Embedded functions.
  5. Interrupt handlers.
  6. Evaluation of the interrupt source.
  7. Summarizing the application and Macros definition.
  8. Visualization of the current consumption.
1. As you can see in the FRDM-KL25Z schematic and the image below, the I2C signals are routed to the I2C1 module (PTC1 and PTC2 pins) of the KL25Z MCU and the INT1 and INT2 outputs are connected to the PTD5 and PTA5 pins. The INT1 and INT2 outputs of the MMA8652FC are configured as a push-pull active-low outputs, so the corresponding PTD5 and PTA5 pins configuration are GPIOs with an interrupt on falling edge.
The MCU is, therefore, configured as follows:
     /* I2C1 module initialization */
     SIM_SCGC4 |= SIM_SCGC4_I2C1_MASK;        // Turn on clock to I2C1 module
     SIM_SCGC5 |= SIM_SCGC5_PORTC_MASK;       // Turn on clock to Port C module
     PORTC_PCR1 |= PORT_PCR_MUX(0x2);         // PTC1 pin is I2C1 SCL line
     PORTC_PCR2 |= PORT_PCR_MUX(0x2);         // PTC2 pin is I2C1 SDA line
     I2C1_F  |= I2C_F_ICR(0x14);              // SDA hold time = 2.125us, SCL start hold time = 4.25us, SCL stop hold time = 5.125us
     I2C1_C1 |= I2C_C1_IICEN_MASK;            // Enable I2C1 module
     /*Configure the PTD5 and PTA5 pin (connected to the INT1 and INT2 of the MMA8652FC) for falling edge interrupts */
     SIM_SCGC5 |= SIM_SCGC5_PORTD_MASK;       // Turn on clock to Port D module
     PORTD_PCR5 |= (0|PORT_PCR_ISF_MASK|      // Clear the interrupt flag
                          PORT_PCR_MUX(0x1)|  // PTD5 is configured as GPIO
                          PORT_PCR_IRQC(0xA));// PTD5 is configured for falling edge interrupts
     SIM_SCGC5 |= SIM_SCGC5_PORTA_MASK;       // Turn on clock to Port A module
     PORTA_PCR5 |= (0|PORT_PCR_ISF_MASK|      // Clear the interrupt flag
                          PORT_PCR_MUX(0x1)|  // PTA5 is configured as GPIO
                          PORT_PCR_IRQC(0xA));// PTA5 is configured for falling edge interrupts
     /* Enable PORTD interrupt on NVIC */
     NVIC_ICPR |= 1 << ((INT_PORTD - 16)%32);
     NVIC_ISER |= 1 << ((INT_PORTD - 16)%32);
     /* Enable PORTA interrupt on NVIC */
     NVIC_ICPR |= 1 << ((INT_PORTA - 16)%32);
     NVIC_ISER |= 1 << ((INT_PORTA - 16)%32);
2. The MMA8652FC is an intelligent, low-power, three-axis, capacitive micromachined accelerometer with 12 bits of resolution.
At the beginning of the initialization, all registers are reset to their default values by setting the RST bit of the CTRL_REG2 register. The Normal and Low Power modes are set in the same register. The MODS[1:0] bits select which Oversampling mode is to be used. The Oversampling modes are available in both WAKE Mode MOD[1:0] and also in the SLEEP Mode SMOD[1:0].
Then the MMA8652FC is initialized as shown below:
     I2C_WriteRegister(MMA8652FC_I2C_ADDRESS, CTRL_REG2, 0x40);        // Reset all registers to POR values
     Pause(0x631);        // ~1ms delay
     I2C_WriteRegister(MMA8652FC_I2C_ADDRESS, XYZ_DATA_CFG_REG, 0x00); // +/-2g range with ~0.977mg/LSB
     /* Power Mode Configuration */
     If LOW power mode is selected:
     I2C_WriteRegister(MMA8652FC_I2C_ADDRESS, CTRL_REG2, 0x1B);        // Low Power mode
     If NORMAL power mode is selected:
     I2C_WriteRegister(MMA8652FC_I2C_ADDRESS, CTRL_REG2, 0x00);        // Normal mode
3. As I mentioned, one of the main features of the MMA8652FC is the Auto-WAKE/SLEEP mode.
The advantage of using the Auto-WAKE/SLEEP is that the system can automatically transition to a higher sample rate (higher current consumption) when needed, but spends the majority of the time in the SLEEP mode (lower current) when the device does not require higher sampling rates.
• Auto-WAKE refers to the device being triggered by one of the interrupt functions to transition to a higher sample rate. This may also interrupt the processor to transition from a SLEEP mode to a higher power mode.
• SLEEP mode occurs after the accelerometer has not detected an interrupt for longer than the user-definable timeout period.
At the ASLP_COUNT register, you can set the minimum time period of inactivity required to switch the part between Wake and Sleep status, in this case, 5 seconds.
The Auto-WAKE/SLEEP mode, therefore, is configured as follow:
     read_reg = I2C_ReadRegister(MMA8652FC_I2C_ADDRESS, CTRL_REG2);
     I2C_WriteRegister(MMA8652FC_I2C_ADDRESS, CTRL_REG2, read_reg|0x04);  // Auto-SLEEP enable
     I2C_WriteRegister(MMA8652FC_I2C_ADDRESS, ASLP_COUNT_REG, 0x10);      // 5 seconds (16 * 320ms)
     read_reg = I2C_ReadRegister(MMA8652FC_I2C_ADDRESS, CTRL_REG4);
     I2C_WriteRegister(MMA8652FC_I2C_ADDRESS, CTRL_REG4, read_reg|0x80);  // Enable AutoSleep interrupt, INT2 - PTD5
     I2C_WriteRegister(MMA8652FC_I2C_ADDRESS, CTRL_REG1, 0xC1);           // ODR=800Hz and Sleep mode ODR=1.56Hz, Active mode
4. The device can be configured to generate inertial wake-up interrupt signals from any combination of the configurable embedded functions, enabling the MMA8652FC to monitor inertial events while remaining in a low-power mode during periods of inactivity.
The Interrupts that can WAKE the device from SLEEP are:
Tap Detection, Orientation Detection, Motion/Freefall, and Transient Detection.
In this project, the TAP (Pulse) or Transient interrupts are used to wake up the device from the SLEEP. In order to get more information about the TAP detection, please click here.
The MMA8652FC is configured as below:
     If Transient interrupt is selected:
     I2C_WriteRegister(MMA8652FC_I2C_ADDRESS, TRANSIENT_THS_REG, 0x84);         // Set threshold to 252mg (4 x 63mg )
     I2C_WriteRegister(MMA8652FC_I2C_ADDRESS, TRANSIENT_COUNT_REG, 0x02);       // Set debounce timer period to 40ms (low power mode) / 2.5ms (normal mode)-Table 66
     I2C_WriteRegister(MMA8652FC_I2C_ADDRESS, TRANSIENT_CFG_REG, 0x17);         // Enable transient detection for X and Y axis, latch enabled
     I2C_WriteRegister(MMA8652FC_I2C_ADDRESS, CTRL_REG3, 0x40);                 // Wake from Transient interrupt, Push-pull, active low interrupt
     I2C_WriteRegister(MMA8652FC_I2C_ADDRESS, CTRL_REG4, 0x20);                 // Enable Transient detection interrupt
     I2C_WriteRegister(MMA8652FC_I2C_ADDRESS, CTRL_REG5, 0x20);                 // Transient interrupt routed to INT1 - PTA5
     If TAP interrupt is selected:
     I2C_WriteRegister(MMA8652FC_I2C_ADDRESS, PULSE_CFG_REG, 0x15);             // Enable X, Y and Z Single Pulse
     I2C_WriteRegister(MMA8652FC_I2C_ADDRESS, PULSE_THSX_REG, 0x20);            // Set X Threshold to 2.016g
     I2C_WriteRegister(MMA8652FC_I2C_ADDRESS, PULSE_THSY_REG, 0x20);            // Set Y Threshold to 2.016g
     I2C_WriteRegister(MMA8652FC_I2C_ADDRESS, PULSE_THSZ_REG, 0x2A);            // Set Z Threshold to 2.646g
     I2C_WriteRegister(MMA8652FC_I2C_ADDRESS, PULSE_TMLT_REG, 0x28);            // Set Time Limit for Tap Detection to 25 ms
     I2C_WriteRegister(MMA8652FC_I2C_ADDRESS, PULSE_LTCY_REG, 0x28);            // Set Latency Time to 50 ms. During this time interval, all pulses are ignored
     I2C_WriteRegister(MMA8652FC_I2C_ADDRESS, CTRL_REG3, 0x10);                 // Wake from Pulse interrupt, Push-pull, active low interrupt
     I2C_WriteRegister(MMA8652FC_I2C_ADDRESS, CTRL_REG4, 0x08);                 // Pulse detection interrupt enabled
     I2C_WriteRegister(MMA8652FC_I2C_ADDRESS, CTRL_REG5, 0x08);                 // Pulse interrupt routed to INT1 - PTA5
5. As I mentioned above, the TAP (Pulse) or Transient interrupts are used to wake up the device from the SLEEP. Besides, if Auto-SLEEP interrupt is enabled, then transitioning from ACTIVE mode to Auto-SLEEP mode (or vice versa) generates an interrupt.
In this project, the Auto-SLEEP, the TAP (Pulse) or the Transient interrupts are enable. The MKL25Z128 responds to these interrupts reading the INT_SOURCE (0x0C) register, in order to determine the appropriate sources of the interrupt.
Every source of interrupt has its own way to clear the interrupt flag. Please refer to the comments of each ISR:
     Transient interrupt handler
     void PORTA_IRQHandler()
        PORTA_PCR5 |= PORT_PCR_ISF_MASK;                // Clear the PTC interrupt
        int_source = I2C_ReadRegister(MMA8652FC_I2C_ADDRESS, INT_SOURCE_REG); // Clear interrupt Source Register
          if(int_source&0x20)  // Transient interrupt ?
           i = I2C_ReadRegister(MMA8652FC_I2C_ADDRESS, TRANSIENT_SRC_REG); // Read the TRANSIENT_SRC register to clear the SRC_TRANS flag in the INT_SOURCE register
           transient_int = 1;
     TAP interrupt handler
        PORTA_PCR5 |= PORT_PCR_ISF_MASK;                // Clear the PTC interrupt flag
           if(int_source&0x08)  // Pulse interrupt ?
           i = I2C_ReadRegister(MMA8652FC_I2C_ADDRESS, PULSE_SRC_REG); // Read the PULSE_SRC register to clear the SRC_TRANS flag in the INT_SOURCE register
           pulse_int = 1;
     Auto WAKE/SLEEP interrupt handler
     void PORTD_IRQHandler()
         PORTD_PCR5 |= PORT_PCR_ISF_MASK;                // Clear the PTD interrupt flag
            if (int_source&0x80) // Auto Sleep/Wake interrupt ?
            i = I2C_ReadRegister(MMA8652FC_I2C_ADDRESS, SYSMOD_REG);      // Read the SYSMOD register to clear the SRC_ASLP flag in the INT_SOURCE register
            sleep_int = 1;
6. At this point, the configuration of the MCU and the accelerometer is done.
The RGB LED contained on the FRDM-KL25Z board is configured in order to help showing the behavior of the application. This behavior is configured as follow:
     #if TRANSIENT_DETECTION
                   if (transient_int){
                transient_int = 0;
                TURN_BLUE_ON(); TURN_RED_OFF();}
     #elif TAP_DETECTION
                   if (pulse_int){
                pulse_int = 0;
     #endif
                   if (sleep_int){
                 sleep_int = 0;
                 TURN_RED_ON(); TURN_BLUE_OFF();}
7. In summary, the FRDM-KL25Z will be interfacing with the MMA8652FC. The power mode will be set and the interrupts will be enabled.
The macros at the top of the source code will allow us to select between the different power modes, the different embedded functions and to select the Auto-WAKE/SLEEP function.
If the Auto-WAKE/SLEEP function is enabled, the MMA8652FC will go into the SLEEP mode (ODR=1.56Hz) after 5 seconds of inactivity. The RED LED will be set.
When an interrupt from the embedded functions is generated, the MMA8652FC will be awakened (ODR=800Hz) and so on. The BLUE LED will be set.
     /* Select the Power Mode - Table 101 from datasheet */
     #define NORMAL_MODE        1
     #define LOW_POWER_MODE     0
     /* Select the Embedded Function */
     #define TRANSIENT_DETECTION       1
     #define TAP_DETECTION             0
     /* Auto-WAKE/SLEEP Function */
     #define AUTO_SLEEP   1
8. The Table 5 from the datasheet shows the expected current consumption in regard with the power mode and ODR selected:
As I mentioned before, the Sleep mode allow us to change between different Output Data Rates (ODR) dynamically so we can reduce the current consumption.
In order to verify if the accelerometer is consuming the current mentioned on the datasheet, I measured the MMA8652FC current consumption using the project mentioned.
Please refer to the results below:
9. The advantage of using the Auto-WAKE/SLEEP mode is that the system can automatically transition to a higher sample rate (higher current consumption) when needed, but spends the majority of the time in the SLEEP mode (lower current) when the device does not require higher sampling rates.
In the manner we have come to expect of the MMA8652FC, the current consumption decreases when the ODR is changed from 800Hz to 1.56Hz, in both normal and low power mode.
The information mentioned on the datasheet is now confirmed.
Please find attached the complete source code.
I hope you find useful and funny this sample project. Any suggestion will be appreciated.
You are invited to take part of the NXP community where you can post all your questions and you may find useful material for your projects.
David
附件
评论
iot
Helo! Can you help me with my issue, please!
We try to use MMA8652FC as a pulse counter. It works but not exactly as we expect. We can't get an interval when pulses are ignored.
We work with the next configuration:
XYZ_DATA_CFG  = 0x10;// 2g mode
HP_FILTER_CUTOFF
 = 0;// high-pass filter on, low-pass filter off
CTRL_REG1 = 0x69;//ASLP rate 12.5 Hz, data-rate - 12.5 Hz
CTRL_REG2 = 0x1F;//smod - low power, auto-sleep enable, mod - low-power
CTRL_REG3 = 0x11;//wake-pulse
CTRL_REG4 = 0x08;//pulse inrerrupt enabled
PULSE_CFG = 0x10;//single-pulse Z-zxis
PULSE_THSX = 0x20;//
PULSE_THSY = 0x20;//
PULSE_THSZ = 0x2A;//
PULSE_TMLT = 0x03;//3 * 40 = 120 ms (as we understant - this is the maximal pulse width)
PULSE_LTCY = 0xFF;//80 * 255 = 20.4 s
ASLP_COUNT = 0x01;//
We really get the pulse interrupts, but we don't have this 20.4-second inactivity between pulses.
What is wrong?
Thank you in advance for your help
iot
And an additional question. Can I get the INT1 interrupt in this configuration if there is no pulse detected? I see that I receive interrupts on the INT1 pin. And when I read registers INT_SOURCE and PULSE_SRC right after the received interrupt these registers are both empty from time to time. These interrupts I receive when I try to get PULSE.
iot
I've found out the cause of these issues - it is an auto-sleep. When the accelerometer went to sleep the INT_SOURCE and PULSE_SRC are cleared and possibly the latency counter is turning off.
%3CLINGO-SUB%20id%3D%22lingo-sub-1122239%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMMA8652FC%20-%20%E8%87%AA%E5%8A%A8%E5%94%A4%E9%86%92%2F%E7%9D%A1%E7%9C%A0%E6%A8%A1%E5%BC%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122239%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%20style%3D%22text-align%3A%20justify%3B%22%3E%E5%A4%A7%E5%AE%B6%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%20text-align%3A%20justify%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20justify%3B%22%3ENXP%20%E5%8A%A0%E9%80%9F%E5%BA%A6%E8%AE%A1%E7%9A%84%E4%B8%BB%E8%A6%81%E5%8A%9F%E8%83%BD%E4%B9%8B%E4%B8%80%E6%98%AF%E8%87%AA%E5%8A%A8%E5%94%A4%E9%86%92%2F%E7%9D%A1%E7%9C%A0%E6%A8%A1%E5%BC%8F%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%20text-align%3A%20justify%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20justify%3B%22%3E%E6%88%91%E6%83%B3%E5%88%86%E4%BA%AB%E8%BF%99%E4%B8%AA%E9%A1%B9%E7%9B%AE%EF%BC%8C%E4%BB%A5%E8%AF%81%E6%98%8E%E4%BD%BF%E7%94%A8%3CSTRONG%3E%E4%BD%8E%E5%8A%9F%E8%80%97%3C%2FSTRONG%3E%E5%92%8C%3CSTRONG%3E%E8%87%AA%E5%8A%A8%E5%94%A4%E9%86%92%2F%E7%9D%A1%E7%9C%A0%3C%2FSTRONG%3E%E6%A8%A1%E5%BC%8F%E6%9D%A5%3CSTRONG%3E%E9%99%8D%E4%BD%8E%E4%B8%8D%E5%90%8C%20NXP%20%E5%8A%A0%E9%80%9F%E5%BA%A6%E8%AE%A1%EF%BC%88%E5%A6%82%20MMA845x%20%E5%92%8C%20MMA865x%20%E7%B3%BB%E5%88%97%EF%BC%89%E7%9A%84%E7%94%B5%E6%B5%81%E6%B6%88%E8%80%97%3C%2FSTRONG%3E%E7%9A%84%E5%8F%AF%E8%A1%8C%E6%80%A7%E3%80%82%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20justify%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22158750_158750.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22158750_158750.jpg%22%20style%3D%22width%3A%20290px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117973i11D01923D5EFD861%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22158750_158750.jpg%22%20alt%3D%22158750_158750.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%228652.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%228652.jpg%22%20style%3D%22width%3A%20290px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F2504i0A1728531164B4B8%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%228652.jpg%22%20alt%3D%228652.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20justify%3B%22%3E%E6%88%91%E4%BD%BF%E7%94%A8%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fwww.nxp.com%2Fproducts%2Fsoftware-and-tools%2Fhardware-development-tools%2Ffreedom-development-boards%2Ffreedom-development-platform-for-kinetis-kl14-kl15-kl24-kl25-mcus%3AFRDM-KL25Z%3Flang_cd%3Den%22%20target%3D%22_blank%22%3EFRDM-KL25Z%3C%2FA%3E%E5%B9%B3%E5%8F%B0%E5%92%8C%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fwww.nxp.com%2Fproducts%2Fsensors%2Faccelerometers%2F3-axis-accelerometers%2F2g-4g-8g-low-g-12-bit-digital-accelerometer%3AMMA8652FC%3Flang_cd%3Den%22%20target%3D%22_blank%22%3EMMA8652FC%3C%2FA%3E%E5%8A%A0%E9%80%9F%E5%BA%A6%E8%AE%A1%E5%88%9B%E5%BB%BA%E4%BA%86%E8%BF%99%E4%B8%AA%E9%A1%B9%E7%9B%AE%EF%BC%88%E6%82%A8%E5%8F%AF%E4%BB%A5%3CA%20_jive_internal%3D%22true%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-103427%22%20target%3D%22_blank%22%3E%E5%9C%A8%E8%BF%99%E9%87%8C%3C%2FA%3E%E6%89%BE%E5%88%B0%E5%88%86%E7%BA%BF%E6%9D%BF%E6%96%87%E4%BB%B6%EF%BC%89%E3%80%82%E5%AE%8C%E6%95%B4%E7%9A%84%E6%BA%90%E4%BB%A3%E7%A0%81%E6%98%AF%E7%94%A8CodeWarrior%20v10.x%E7%BC%96%E5%86%99%E7%9A%84%E9%9B%86%E6%88%90%E5%BC%80%E5%8F%91%E7%8E%AF%E5%A2%83%20(IDE)%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%20text-align%3A%20justify%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20justify%3B%22%3E%E6%9C%AC%E6%96%87%E6%A1%A3%E4%BB%8B%E7%BB%8D%E4%BA%86MMA8652FC%E5%8A%A0%E9%80%9F%E5%BA%A6%E8%AE%A1%E4%BB%A5%E5%8F%8A%E4%B8%8D%E5%90%8C%E7%9A%84%E5%8A%9F%E8%80%97%EF%BC%8C%E5%B9%B6%E6%8C%87%E5%AF%BC%E6%82%A8%E5%AE%8C%E6%88%90%E5%88%9D%E5%A7%8B%E5%8C%96%E8%BF%87%E7%A8%8B%E4%BB%A5%E5%8F%8A%E5%A6%82%E4%BD%95%E6%AC%A3%E8%B5%8F%E6%BC%94%E7%A4%BA%EF%BC%9A%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%20text-align%3A%20justify%3B%22%3E%26nbsp%3B%3C%2FP%3E%3COL%20style%3D%22list-style-type%3A%20decimal%3B%22%3E%3CLI%3EMKL25Z128%20MCU%20%E7%9A%84%E5%88%9D%E5%A7%8B%E5%8C%96%E3%80%82%3C%2FLI%3E%3CLI%3EMMA8652FC%20%E7%9A%84%E5%88%9D%E5%A7%8B%E5%8C%96%E3%80%82%3C%2FLI%3E%3CLI%3E%E8%87%AA%E5%8A%A8%E5%94%A4%E9%86%92%2F%E7%9D%A1%E7%9C%A0%E6%A8%A1%E5%BC%8F%E3%80%82%3C%2FLI%3E%3CLI%3EMMA8652FC%20%E5%B5%8C%E5%85%A5%E5%BC%8F%E5%8A%9F%E8%83%BD%E3%80%82%3C%2FLI%3E%3CLI%3E%E4%B8%AD%E6%96%AD%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%E3%80%82%3C%2FLI%3E%3CLI%3E%E4%B8%AD%E6%96%AD%E6%BA%90%E7%9A%84%E8%AF%84%E4%BC%B0%E3%80%82%3C%2FLI%3E%3CLI%3E%E6%80%BB%E7%BB%93%E5%BA%94%E7%94%A8%E5%92%8C%E5%AE%8F%E5%AE%9A%E4%B9%89%E3%80%82%3C%2FLI%3E%3CLI%3E%E5%BD%93%E5%89%8D%E6%B6%88%E8%80%97%E7%9A%84%E5%8F%AF%E8%A7%86%E5%8C%96%E3%80%82%3C%2FLI%3E%3C%2FOL%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%20text-align%3A%20justify%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E1.%E6%AD%A3%E5%A6%82%E6%82%A8%E5%9C%A8%20FRDM-KL25Z%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fcache.nxp.com%2Ffiles%2Fsoft_dev_tools%2Fhardware_tools%2Fschematics%2FFRDM-KL25Z_SCH_REV_E.pdf%3Ffpsp%3D1%26amp%3BWT_TYPE%3DSchematics%26amp%3BWT_VENDOR%3DFREESCALE%26amp%3BWT_FILE_FORMAT%3Dpdf%26amp%3BWT_ASSET%3DDownloads%26amp%3BfileExt%3D.pdf%22%20target%3D%22_blank%22%3E%E5%8E%9F%E7%90%86%E5%9B%BE%3C%2FA%3E%E5%92%8C%E4%B8%8B%E5%9B%BE%E4%B8%AD%E6%89%80%E7%9C%8B%E5%88%B0%E7%9A%84%EF%BC%8CI2C%20%E4%BF%A1%E5%8F%B7%E8%A2%AB%E8%B7%AF%E7%94%B1%E5%88%B0%20KL25Z%20MCU%20%E7%9A%84%20I2C1%20%E6%A8%A1%E5%9D%97%EF%BC%88PTC1%20%E5%92%8C%20PTC2%20%E5%BC%95%E8%84%9A%EF%BC%89%EF%BC%8C%E5%B9%B6%E4%B8%94%20INT1%20%E5%92%8C%20INT2%20%E8%BE%93%E5%87%BA%E8%BF%9E%E6%8E%A5%E5%88%B0%20PTD5%20%E5%92%8C%20PTA5%20%E5%BC%95%E8%84%9A%E3%80%82MMA8652FC%20%E7%9A%84%20INT1%20%E5%92%8C%20INT2%20%E8%BE%93%E5%87%BA%E9%85%8D%E7%BD%AE%E4%B8%BA%E6%8E%A8%E6%8C%BD%E5%BC%8F%E4%BD%8E%E7%94%B5%E5%B9%B3%E6%9C%89%E6%95%88%E8%BE%93%E5%87%BA%EF%BC%8C%E5%9B%A0%E6%AD%A4%E7%9B%B8%E5%BA%94%E7%9A%84%20PTD5%20%E5%92%8C%20PTA5%20%E5%BC%95%E8%84%9A%E9%85%8D%E7%BD%AE%E4%B8%BA%E4%B8%8B%E9%99%8D%E6%B2%BF%E4%B8%AD%E6%96%AD%E7%9A%84%20GPIO%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22158751_158751.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22158751_158751.jpg%22%20style%3D%22width%3A%20573px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117974i99D00B4707FB1E0F%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22158751_158751.jpg%22%20alt%3D%22158751_158751.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22frdm.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22frdm.jpg%22%20style%3D%22width%3A%20573px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F2609i7401438F405906D2%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22frdm.jpg%22%20alt%3D%22frdm.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20justify%3B%22%3E%E5%9B%A0%E6%AD%A4%EF%BC%8CMCU%20%E9%85%8D%E7%BD%AE%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F*%20I2C1%E6%A8%A1%E5%9D%97%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%E5%88%9D%E5%A7%8B%E5%8C%96%3C%2FSPAN%3E*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3ESIM_SCGC4%20%7C%3D%20SIM_SCGC4_I2C1_MASK%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20%E6%89%93%E5%BC%80%20I2C1%20%E6%A8%A1%E5%9D%97%E7%9A%84%E6%97%B6%E9%92%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3ESIM_SCGC5%20%7C%3D%20SIM_SCGC5_PORTC_MASK%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20%E6%89%93%E5%BC%80%E7%AB%AF%E5%8F%A3%20C%20%E6%A8%A1%E5%9D%97%E7%9A%84%E6%97%B6%E9%92%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EPORTC_PCR1%20%7C%3D%20PORT_PCR_MUX(0x2)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20PTC1%20%E5%BC%95%E8%84%9A%E4%B8%BA%20I2C1%20SCL%20%E7%BA%BF%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EPORTC_PCR2%20%7C%3D%20PORT_PCR_MUX(0x2)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20PTC2%20%E5%BC%95%E8%84%9A%E4%B8%BA%20I2C1%20SDA%20%E7%BA%BF%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EI2C1_F%20%7C%3D%20I2C_F_ICR(0x14)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20SDA%20%E4%BF%9D%E6%8C%81%E6%97%B6%E9%97%B4%20%3D%202.125us%EF%BC%8CSCL%20%E5%90%AF%E5%8A%A8%E4%BF%9D%E6%8C%81%E6%97%B6%E9%97%B4%20%3D%204.25us%EF%BC%8CSCL%20%E5%81%9C%E6%AD%A2%E4%BF%9D%E6%8C%81%E6%97%B6%E9%97%B4%20%3D%205.125us%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EI2C1_C1%20%7C%3D%20I2C_C1_IICEN_MASK%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20%E5%90%AF%E7%94%A8%20I2C1%20%E6%A8%A1%E5%9D%97%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%20margin-bottom%3A%200.0001pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F*%E9%85%8D%E7%BD%AEPTD5%E5%92%8CPTA5%E5%BC%95%E8%84%9A%EF%BC%88%E8%BF%9E%E6%8E%A5%E5%88%B0MMA8652FC%E7%9A%84INT1%E5%92%8CINT2%EF%BC%89%E7%94%A8%E4%BA%8E%E4%B8%8B%E9%99%8D%E6%B2%BF%E4%B8%AD%E6%96%AD*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3ESIM_SCGC5%20%7C%3D%20SIM_SCGC5_PORTD_MASK%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20%E6%89%93%E5%BC%80%E7%AB%AF%E5%8F%A3%20D%20%E6%A8%A1%E5%9D%97%E7%9A%84%E6%97%B6%E9%92%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EPORTD_PCR5%20%7C%3D%20(0%7CPORT_PCR_ISF_MASK%7C%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%E6%B8%85%E9%99%A4%E4%B8%AD%E6%96%AD%E6%A0%87%E5%BF%97%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EPORT_PCR_MUX(0x1)%7C%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20PTD5%20%E9%85%8D%E7%BD%AE%E4%B8%BA%20GPIO%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EPORT_PCR_IRQC(0xA))%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20PTD5%20%E9%85%8D%E7%BD%AE%E4%B8%BA%E4%B8%8B%E9%99%8D%E6%B2%BF%E4%B8%AD%E6%96%AD%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3ESIM_SCGC5%20%7C%3D%20SIM_SCGC5_PORTA_MASK%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20%E6%89%93%E5%BC%80%E7%AB%AF%E5%8F%A3%20A%20%E6%A8%A1%E5%9D%97%E7%9A%84%E6%97%B6%E9%92%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EPORTA_PCR5%20%7C%3D%20(0%7CPORT_PCR_ISF_MASK%7C%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%E6%B8%85%E9%99%A4%E4%B8%AD%E6%96%AD%E6%A0%87%E5%BF%97%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EPORT_PCR_MUX(0x1)%7C%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20PTA5%20%E9%85%8D%E7%BD%AE%E4%B8%BA%20GPIO%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EPORT_PCR_IRQC(0xA))%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20PTA5%20%E9%85%8D%E7%BD%AE%E4%B8%BA%E4%B8%8B%E9%99%8D%E6%B2%BF%E4%B8%AD%E6%96%AD%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F*%20%E5%9C%A8%20NVIC%20%E4%B8%8A%E5%90%AF%E7%94%A8%20PORTD%20%E4%B8%AD%E6%96%AD%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3ENVIC_ICPR%20%7C%3D%201%20%26lt%3B%26lt%3B%20((%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%230000c0%3B%20font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CEM%3EINT_PORTD%3C%2FEM%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E-%2016)%2532)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3ENVIC_ISER%20%7C%3D%201%20%26lt%3B%26lt%3B%20((%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%230000c0%3B%20font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CEM%3EINT_PORTD%3C%2FEM%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E-%2016)%2532)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F*%20%E5%9C%A8%20NVIC%20%E4%B8%8A%E5%90%AF%E7%94%A8%20PORTA%20%E4%B8%AD%E6%96%AD%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3ENVIC_ICPR%20%7C%3D%201%20%26lt%3B%26lt%3B%20((%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%230000c0%3B%20font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CEM%3EINT_PORTA%3C%2FEM%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E-%2016)%2532)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3ENVIC_ISER%20%7C%3D%201%20%26lt%3B%26lt%3B%20((%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%230000c0%3B%20font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CEM%3EINT_PORTA%3C%2FEM%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E-%2016)%2532)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E2.%20MMA8652FC%20%E6%98%AF%E4%B8%80%E6%AC%BE%E6%99%BA%E8%83%BD%E3%80%81%E4%BD%8E%E5%8A%9F%E8%80%97%E3%80%81%E4%B8%89%E8%BD%B4%E3%80%81%E7%94%B5%E5%AE%B9%E5%BC%8F%E5%BE%AE%E6%9C%BA%E6%A2%B0%E5%8A%A0%E9%80%9F%E5%BA%A6%E8%AE%A1%EF%BC%8C%E5%88%86%E8%BE%A8%E7%8E%87%E4%B8%BA%2012%20%E4%BD%8D%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20justify%3B%22%3E%E5%9C%A8%E5%88%9D%E5%A7%8B%E5%8C%96%E5%BC%80%E5%A7%8B%E6%97%B6%EF%BC%8C%E9%80%9A%E8%BF%87%E8%AE%BE%E7%BD%AE%20CTRL_REG2%20%E5%AF%84%E5%AD%98%E5%99%A8%E7%9A%84%20RST%20%E4%BD%8D%E5%B0%86%E6%89%80%E6%9C%89%E5%AF%84%E5%AD%98%E5%99%A8%E9%87%8D%E7%BD%AE%E4%B8%BA%E5%85%B6%E9%BB%98%E8%AE%A4%E5%80%BC%E3%80%82%3CSTRONG%3E%E6%AD%A3%E5%B8%B8%3C%2FSTRONG%3E%E5%92%8C%3CSTRONG%3E%E4%BD%8E%E5%8A%9F%E8%80%97%3C%2FSTRONG%3E%E6%A8%A1%E5%BC%8F%E5%9C%A8%E5%90%8C%E4%B8%80%E4%B8%AA%E5%AF%84%E5%AD%98%E5%99%A8%E4%B8%AD%E8%AE%BE%E7%BD%AE%E3%80%82MODS%5B1%3A0%5D%E4%BD%8D%E9%80%89%E6%8B%A9%E4%BD%BF%E7%94%A8%E5%93%AA%E7%A7%8D%E8%BF%87%E9%87%87%E6%A0%B7%E6%A8%A1%E5%BC%8F%E3%80%82%E8%BF%87%E9%87%87%E6%A0%B7%E6%A8%A1%E5%BC%8F%E5%9C%A8%E5%94%A4%E9%86%92%E6%A8%A1%E5%BC%8F%20MOD%5B1%3A0%5D%20%E5%92%8C%E7%9D%A1%E7%9C%A0%E6%A8%A1%E5%BC%8F%20SMOD%5B1%3A0%5D%20%E4%B8%AD%E5%9D%87%E5%8F%AF%E7%94%A8%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%20text-align%3A%20justify%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20justify%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22158752_158752.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22158752_158752.jpg%22%20style%3D%22width%3A%20455px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117975i289A6A0C3C74B03E%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22158752_158752.jpg%22%20alt%3D%22158752_158752.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mods.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mods.jpg%22%20style%3D%22width%3A%20455px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F108023iC4480AF91762C6AD%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22mods.jpg%22%20alt%3D%22mods.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20justify%3B%22%3E%E7%84%B6%E5%90%8EMMA8652FC%E5%88%9D%E5%A7%8B%E5%8C%96%E5%A6%82%E4%B8%8B%E5%9B%BE%E6%89%80%E7%A4%BA%EF%BC%9A%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EI2C_WriteRegister(MMA8652FC_I2C_ADDRESS%2C%20CTRL_REG2%2C%200x40)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20%E5%B0%86%E6%89%80%E6%9C%89%E5%AF%84%E5%AD%98%E5%99%A8%E9%87%8D%E7%BD%AE%E4%B8%BA%20POR%20%E5%80%BC%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%E6%9A%82%E5%81%9C%EF%BC%880x631%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%E5%BB%B6%E8%BF%9F%E7%BA%A6%201%20%E6%AF%AB%E7%A7%92%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EI2C_WriteRegister(MMA8652FC_I2C_ADDRESS%2C%20XYZ_DATA_CFG_REG%2C%200x00)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20%2B%2F-2g%20%E8%8C%83%E5%9B%B4%EF%BC%8C~0.977mg%2FLSB%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%20margin-bottom%3A%200.0001pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F*%20%E7%94%B5%E6%BA%90%E6%A8%A1%E5%BC%8F%E9%85%8D%E7%BD%AE%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSTRONG%3E%E5%A6%82%E6%9E%9C%E9%80%89%E6%8B%A9%E4%BD%8E%E5%8A%9F%E8%80%97%E6%A8%A1%E5%BC%8F%EF%BC%9A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3EI2C_WriteRegister(MMA8652FC_I2C_ADDRESS%2C%20CTRL_REG2%2C%200x1B)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%20background%3A%20white%3B%22%3E%2F%2F%E4%BD%8E%E5%8A%9F%E8%80%97%E6%A8%A1%E5%BC%8F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%20margin-bottom%3A%200.0001pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSTRONG%3E%E5%A6%82%E6%9E%9C%E9%80%89%E6%8B%A9%E4%BA%86%E6%AD%A3%E5%B8%B8%E5%8A%9F%E7%8E%87%E6%A8%A1%E5%BC%8F%EF%BC%9A%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EI2C_WriteRegister(MMA8652FC_I2C_ADDRESS%2C%20CTRL_REG2%2C%200x00)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%E6%AD%A3%E5%B8%B8%E6%A8%A1%E5%BC%8F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E3.%20%E6%AD%A3%E5%A6%82%E6%88%91%E6%89%80%E6%8F%90%E5%88%B0%E7%9A%84%EF%BC%8CMMA8652FC%20%E7%9A%84%E4%B8%BB%E8%A6%81%E5%8A%9F%E8%83%BD%E4%B9%8B%E4%B8%80%E6%98%AF%E8%87%AA%E5%8A%A8%E5%94%A4%E9%86%92%2F%E7%9D%A1%E7%9C%A0%E6%A8%A1%E5%BC%8F%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E4%BD%BF%E7%94%A8%E8%87%AA%E5%8A%A8%E5%94%A4%E9%86%92%2F%E7%9D%A1%E7%9C%A0%E6%A8%A1%E5%BC%8F%E7%9A%84%E4%BC%98%E7%82%B9%E6%98%AF%EF%BC%8C%E7%B3%BB%E7%BB%9F%E5%8F%AF%E4%BB%A5%E5%9C%A8%E9%9C%80%E8%A6%81%E6%97%B6%E8%87%AA%E5%8A%A8%E8%BD%AC%E6%8D%A2%E5%88%B0%E6%9B%B4%E9%AB%98%E7%9A%84%E9%87%87%E6%A0%B7%E7%8E%87%EF%BC%88%E6%9B%B4%E9%AB%98%E7%9A%84%E7%94%B5%E6%B5%81%E6%B6%88%E8%80%97%EF%BC%89%EF%BC%8C%E4%BD%86%E5%BD%93%E8%AE%BE%E5%A4%87%E4%B8%8D%E9%9C%80%E8%A6%81%E6%9B%B4%E9%AB%98%E7%9A%84%E9%87%87%E6%A0%B7%E7%8E%87%E6%97%B6%EF%BC%8C%E5%A4%A7%E9%83%A8%E5%88%86%E6%97%B6%E9%97%B4%E9%83%BD%E5%A4%84%E4%BA%8E%E7%9D%A1%E7%9C%A0%E6%A8%A1%E5%BC%8F%EF%BC%88%E8%BE%83%E4%BD%8E%E7%9A%84%E7%94%B5%E6%B5%81%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%20margin-left%3A%200.5in%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%200.5in%3B%22%3E%E2%80%A2%3CSTRONG%3E%E8%87%AA%E5%8A%A8%E5%94%A4%E9%86%92%3C%2FSTRONG%3E%E6%98%AF%E6%8C%87%E8%AE%BE%E5%A4%87%E7%94%B1%E6%9F%90%E4%B8%AA%E4%B8%AD%E6%96%AD%E5%8A%9F%E8%83%BD%E8%A7%A6%E5%8F%91%EF%BC%8C%E8%BD%AC%E6%8D%A2%E5%88%B0%E6%9B%B4%E9%AB%98%E7%9A%84%E9%87%87%E6%A0%B7%E7%8E%87%E3%80%82%E8%BF%99%E4%B9%9F%E5%8F%AF%E8%83%BD%E4%BC%9A%E4%B8%AD%E6%96%AD%E5%A4%84%E7%90%86%E5%99%A8%E4%BB%8E%E7%9D%A1%E7%9C%A0%E6%A8%A1%E5%BC%8F%E8%BD%AC%E6%8D%A2%E5%88%B0%E6%9B%B4%E9%AB%98%E5%8A%9F%E7%8E%87%E6%A8%A1%E5%BC%8F%E3%80%82%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%200.5in%3B%22%3E%E2%80%A2%20%E5%BD%93%E5%8A%A0%E9%80%9F%E5%BA%A6%E8%AE%A1%E5%9C%A8%E8%B6%85%E8%BF%87%E7%94%A8%E6%88%B7%E5%AE%9A%E4%B9%89%E7%9A%84%E8%B6%85%E6%97%B6%E6%97%B6%E9%97%B4%E5%90%8E%E4%BB%8D%E6%9C%AA%E6%A3%80%E6%B5%8B%E5%88%B0%E4%B8%AD%E6%96%AD%E6%97%B6%EF%BC%8C%E5%B0%86%E8%BF%9B%E5%85%A5%3CSTRONG%3E%E7%9D%A1%E7%9C%A0%E6%A8%A1%E5%BC%8F%3C%2FSTRONG%3E%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%20margin-left%3A%200.5in%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%20margin-left%3A%200.5in%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22margin-left%3A%200.5in%3B%20text-align%3A%20center%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22159611_159611.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22159611_159611.jpg%22%20style%3D%22width%3A%20639px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117976i16F70BA0ADCE07B5%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22159611_159611.jpg%22%20alt%3D%22159611_159611.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sleep.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sleep.jpg%22%20style%3D%22width%3A%20639px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F1631i37893566F343B815%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22sleep.jpg%22%20alt%3D%22sleep.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E5%9C%A8%20ASLP_COUNT%20%E5%AF%84%E5%AD%98%E5%99%A8%E4%B8%AD%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E8%AE%BE%E7%BD%AE%E5%9C%A8%E5%94%A4%E9%86%92%E5%92%8C%E7%9D%A1%E7%9C%A0%E7%8A%B6%E6%80%81%E4%B9%8B%E9%97%B4%E5%88%87%E6%8D%A2%E9%83%A8%E4%BB%B6%E6%89%80%E9%9C%80%E7%9A%84%E6%9C%80%E7%9F%AD%E4%B8%8D%E6%B4%BB%E5%8A%A8%E6%97%B6%E9%97%B4%E6%AE%B5%EF%BC%8C%E5%9C%A8%E6%9C%AC%E4%BE%8B%E4%B8%AD%E4%B8%BA%205%20%E7%A7%92%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E5%9B%A0%E6%AD%A4%EF%BC%8C%E8%87%AA%E5%8A%A8%E5%94%A4%E9%86%92%2F%E7%9D%A1%E7%9C%A0%E6%A8%A1%E5%BC%8F%E9%85%8D%E7%BD%AE%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%E8%AF%BB%E5%8F%96%E5%AF%84%E5%AD%98%E5%99%A8%20%3D%20I2C_ReadRegister(MMA8652FC_I2C_ADDRESS%EF%BC%8CCTRL_REG2)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EI2C_WriteRegister(MMA8652FC_I2C_ADDRESS%2C%20CTRL_REG2%2C%20read_reg%7C0x04)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%E8%87%AA%E5%8A%A8%E7%9D%A1%E7%9C%A0%E5%90%AF%E7%94%A8%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EI2C_WriteRegister(MMA8652FC_I2C_ADDRESS%EF%BC%8CASLP_COUNT_REG%EF%BC%8C0x10)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%205%E7%A7%92%EF%BC%8816%20*%20320ms%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%E8%AF%BB%E5%8F%96%E5%AF%84%E5%AD%98%E5%99%A8%20%3D%20I2C_ReadRegister(MMA8652FC_I2C_ADDRESS%EF%BC%8CCTRL_REG4)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EI2C_WriteRegister(MMA8652FC_I2C_ADDRESS%2C%20CTRL_REG4%2C%20read_reg%7C0x80)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%E5%90%AF%E7%94%A8%E8%87%AA%E5%8A%A8%E7%9D%A1%E7%9C%A0%E4%B8%AD%E6%96%AD%EF%BC%8CINT2%20-%20PTD5%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EI2C_WriteRegister(MMA8652FC_I2C_ADDRESS%2C%20CTRL_REG1%2C%200xC1)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20ODR%3D800Hz%EF%BC%8C%E7%9D%A1%E7%9C%A0%E6%A8%A1%E5%BC%8F%20ODR%3D1.56Hz%EF%BC%8C%E6%B4%BB%E5%8A%A8%E6%A8%A1%E5%BC%8F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%20margin-bottom%3A%200.0001pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E4.%20%E8%AF%A5%E8%AE%BE%E5%A4%87%E5%8F%AF%E4%BB%A5%E9%85%8D%E7%BD%AE%E4%B8%BA%E4%BB%8E%E5%8F%AF%E9%85%8D%E7%BD%AE%E5%B5%8C%E5%85%A5%E5%BC%8F%E5%8A%9F%E8%83%BD%E7%9A%84%E4%BB%BB%E6%84%8F%E7%BB%84%E5%90%88%E7%94%9F%E6%88%90%E6%83%AF%E6%80%A7%E5%94%A4%E9%86%92%E4%B8%AD%E6%96%AD%E4%BF%A1%E5%8F%B7%EF%BC%8C%E4%BB%8E%E8%80%8C%E4%BD%BFMMA8652FC%E8%83%BD%E5%A4%9F%E7%9B%91%E8%A7%86%E6%83%AF%E6%80%A7%E4%BA%8B%E4%BB%B6%EF%BC%8C%E5%90%8C%E6%97%B6%E5%9C%A8%E9%9D%9E%E6%B4%BB%E5%8A%A8%E6%9C%9F%E9%97%B4%E4%BF%9D%E6%8C%81%E4%BD%8E%E5%8A%9F%E8%80%97%E6%A8%A1%E5%BC%8F%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E5%8F%AF%E4%BB%A5%E5%B0%86%E8%AE%BE%E5%A4%87%E4%BB%8E%E7%9D%A1%E7%9C%A0%E7%8A%B6%E6%80%81%E5%94%A4%E9%86%92%E7%9A%84%E4%B8%AD%E6%96%AD%E6%9C%89%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E7%82%B9%E5%87%BB%E6%A3%80%E6%B5%8B%E3%80%81%E6%96%B9%E5%90%91%E6%A3%80%E6%B5%8B%E3%80%81%E8%BF%90%E5%8A%A8%2F%E8%87%AA%E7%94%B1%E8%90%BD%E4%BD%93%E5%92%8C%E7%9E%AC%E6%80%81%E6%A3%80%E6%B5%8B%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22159612_159612.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22159612_159612.jpg%22%20style%3D%22width%3A%20668px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117977iA896F607C621B783%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22159612_159612.jpg%22%20alt%3D%22159612_159612.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22interrupts.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22interrupts.jpg%22%20style%3D%22width%3A%20668px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F1685i4A0FC37A4DDE0525%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22interrupts.jpg%22%20alt%3D%22interrupts.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E5%9C%A8%E8%BF%99%E4%B8%AA%E9%A1%B9%E7%9B%AE%E4%B8%AD%EF%BC%8CTAP%EF%BC%88%E8%84%89%E5%86%B2%EF%BC%89%E6%88%96%E7%9E%AC%E6%80%81%E4%B8%AD%E6%96%AD%E7%94%A8%E4%BA%8E%E5%B0%86%E8%AE%BE%E5%A4%87%E4%BB%8E%E7%9D%A1%E7%9C%A0%E7%8A%B6%E6%80%81%E5%94%A4%E9%86%92%E3%80%82%E4%B8%BA%E4%BA%86%E8%8E%B7%E5%BE%97%E6%9C%89%E5%85%B3%20TAP%20%E6%A3%80%E6%B5%8B%E7%9A%84%E6%9B%B4%E5%A4%9A%E4%BF%A1%E6%81%AF%EF%BC%8C%E8%AF%B7%E5%8D%95%E5%87%BB%3CA%20_jive_internal%3D%22true%22%20data-objecttype%3D%22102%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-329888%22%20target%3D%22_blank%22%3E%E6%AD%A4%E5%A4%84%3C%2FA%3E%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3EMMA8652FC%E9%85%8D%E7%BD%AE%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSTRONG%3E%E5%A6%82%E6%9E%9C%E9%80%89%E6%8B%A9%E7%9E%AC%E6%80%81%E4%B8%AD%E6%96%AD%EF%BC%9A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EI2C_WriteRegister(MMA8652FC_I2C_ADDRESS%2C%20TRANSIENT_THS_REG%2C%200x84)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20%E5%B0%86%E9%98%88%E5%80%BC%E8%AE%BE%E7%BD%AE%E4%B8%BA%20252mg%20(4%20x%2063mg)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EI2C_WriteRegister(MMA8652FC_I2C_ADDRESS%2C%20TRANSIENT_COUNT_REG%2C%200x02)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%E5%B0%86%E5%8E%BB%E6%8A%96%E5%8A%A8%3C%2FSPAN%3E%E5%AE%9A%E6%97%B6%E5%99%A8%E5%91%A8%E6%9C%9F%E8%AE%BE%E7%BD%AE%E4%B8%BA%2040ms%EF%BC%88%E4%BD%8E%E5%8A%9F%E8%80%97%E6%A8%A1%E5%BC%8F%EF%BC%89%2F%202.5ms%EF%BC%88%E6%AD%A3%E5%B8%B8%E6%A8%A1%E5%BC%8F%EF%BC%89-%E8%A1%A8%2066%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EI2C_WriteRegister(MMA8652FC_I2C_ADDRESS%2C%20TRANSIENT_CFG_REG%2C%200x17)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20%E5%90%AF%E7%94%A8%20X%20%E8%BD%B4%E5%92%8C%20Y%20%E8%BD%B4%E7%9A%84%E7%9E%AC%E6%80%81%E6%A3%80%E6%B5%8B%EF%BC%8C%E9%94%81%E5%AD%98%E5%99%A8%E5%90%AF%E7%94%A8%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EI2C_WriteRegister(MMA8652FC_I2C_ADDRESS%2C%20CTRL_REG3%2C%200x40)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20%E4%BB%8E%E7%9E%AC%E6%80%81%E4%B8%AD%E6%96%AD%E3%80%81%E6%8E%A8%E6%8C%BD%E3%80%81%E4%BD%8E%E7%94%B5%E5%B9%B3%E6%9C%89%E6%95%88%E4%B8%AD%E6%96%AD%E5%94%A4%E9%86%92%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EI2C_WriteRegister(MMA8652FC_I2C_ADDRESS%2C%20CTRL_REG4%2C%200x20)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%E5%90%AF%E7%94%A8%E7%9E%AC%E6%80%81%E6%A3%80%E6%B5%8B%E4%B8%AD%E6%96%AD%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EI2C_WriteRegister(MMA8652FC_I2C_ADDRESS%2C%20CTRL_REG5%2C%200x20)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%E7%9E%AC%E6%80%81%E4%B8%AD%E6%96%AD%E8%B7%AF%E7%94%B1%E5%88%B0INT1%20-%20PTA5%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSTRONG%3E%E5%A6%82%E6%9E%9C%E9%80%89%E6%8B%A9TAP%E4%B8%AD%E6%96%AD%EF%BC%9A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3EI2C_WriteRegister(MMA8652FC_I2C_ADDRESS%2C%20PULSE_CFG_REG%2C%200x15)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%20background%3A%20white%3B%22%3E%2F%2F%E5%90%AF%E7%94%A8X%E3%80%81Y%E5%92%8CZ%E5%8D%95%E8%84%89%E5%86%B2%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3EI2C_WriteRegister(MMA8652FC_I2C_ADDRESS%2C%20PULSE_THSX_REG%2C%200x20)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%20background%3A%20white%3B%22%3E%2F%2F%20%E5%B0%86X%E9%98%88%E5%80%BC%E8%AE%BE%E7%BD%AE%E4%B8%BA2.016g%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3EI2C_WriteRegister(MMA8652FC_I2C_ADDRESS%2C%20PULSE_THSY_REG%2C%200x20)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%20background%3A%20white%3B%22%3E%2F%2F%20%E5%B0%86Y%E9%98%88%E5%80%BC%E8%AE%BE%E7%BD%AE%E4%B8%BA2.016g%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3EI2C_WriteRegister(MMA8652FC_I2C_ADDRESS%2C%20PULSE_THSZ_REG%2C%200x2A)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%20background%3A%20white%3B%22%3E%2F%2F%20%E5%B0%86Z%E9%98%88%E5%80%BC%E8%AE%BE%E7%BD%AE%E4%B8%BA2.646g%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3EI2C_WriteRegister(MMA8652FC_I2C_ADDRESS%2C%20PULSE_TMLT_REG%2C%200x28)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%20background%3A%20white%3B%22%3E%2F%2F%20%E5%B0%86%E7%82%B9%E5%87%BB%E6%A3%80%E6%B5%8B%E7%9A%84%E6%97%B6%E9%97%B4%E9%99%90%E5%88%B6%E8%AE%BE%E7%BD%AE%E4%B8%BA%2025%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%E6%AF%AB%E7%A7%92%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3EI2C_WriteRegister(MMA8652FC_I2C_ADDRESS%2C%20PULSE_LTCY_REG%2C%200x28)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%20background%3A%20white%3B%22%3E%2F%2F%20%E5%B0%86%E5%BB%B6%E8%BF%9F%E6%97%B6%E9%97%B4%E8%AE%BE%E7%BD%AE%E4%B8%BA%2050%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%E6%AF%AB%E7%A7%92%3C%2FSPAN%3E%E3%80%82%E5%9C%A8%E6%AD%A4%E6%97%B6%E9%97%B4%E9%97%B4%E9%9A%94%E5%86%85%EF%BC%8C%E6%89%80%E6%9C%89%E8%84%89%E5%86%B2%E9%83%BD%E5%B0%86%E8%A2%AB%E5%BF%BD%E7%95%A5%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3EI2C_WriteRegister(MMA8652FC_I2C_ADDRESS%2C%20CTRL_REG3%2C%200x10)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%20background%3A%20white%3B%22%3E%2F%2F%20%E4%BB%8E%E8%84%89%E5%86%B2%E4%B8%AD%E6%96%AD%E5%94%A4%E9%86%92%EF%BC%8C%E6%8E%A8%E6%8C%BD%EF%BC%8C%E4%BD%8E%E7%94%B5%E5%B9%B3%E6%9C%89%E6%95%88%E4%B8%AD%E6%96%AD%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3EI2C_WriteRegister(MMA8652FC_I2C_ADDRESS%2C%20CTRL_REG4%2C%200x08)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%20background%3A%20white%3B%22%3E%2F%2F%E8%84%89%E5%86%B2%E6%A3%80%E6%B5%8B%E4%B8%AD%E6%96%AD%E4%BD%BF%E8%83%BD%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3EI2C_WriteRegister(MMA8652FC_I2C_ADDRESS%2C%20CTRL_REG5%2C%200x08)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%20background%3A%20white%3B%22%3E%2F%2F%E8%84%89%E5%86%B2%E4%B8%AD%E6%96%AD%E8%B7%AF%E7%94%B1%E5%88%B0INT1%20-%20PTA5%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E5.%20%E6%AD%A3%E5%A6%82%E6%88%91%E4%B8%8A%E9%9D%A2%E6%8F%90%E5%88%B0%E7%9A%84%EF%BC%8CTAP%EF%BC%88%E8%84%89%E5%86%B2%EF%BC%89%E6%88%96%E7%9E%AC%E6%80%81%E4%B8%AD%E6%96%AD%E7%94%A8%E4%BA%8E%E5%B0%86%E8%AE%BE%E5%A4%87%E4%BB%8E%E7%9D%A1%E7%9C%A0%E7%8A%B6%E6%80%81%E5%94%A4%E9%86%92%E3%80%82%E6%AD%A4%E5%A4%96%EF%BC%8C%E5%A6%82%E6%9E%9C%E5%90%AF%E7%94%A8%E4%BA%86%E8%87%AA%E5%8A%A8%E7%9D%A1%E7%9C%A0%E4%B8%AD%E6%96%AD%EF%BC%8C%E5%88%99%E4%BB%8E%E6%B4%BB%E5%8A%A8%E6%A8%A1%E5%BC%8F%E8%BD%AC%E6%8D%A2%E4%B8%BA%E8%87%AA%E5%8A%A8%E7%9D%A1%E7%9C%A0%E6%A8%A1%E5%BC%8F%EF%BC%88%E6%88%96%E5%8F%8D%E4%B9%8B%E4%BA%A6%E7%84%B6%EF%BC%89%E4%BC%9A%E4%BA%A7%E7%94%9F%E4%B8%AD%E6%96%AD%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20justify%3B%22%3E%E5%9C%A8%E8%BF%99%E4%B8%AA%E9%A1%B9%E7%9B%AE%E4%B8%AD%EF%BC%8C%E8%87%AA%E5%8A%A8%E7%9D%A1%E7%9C%A0%E3%80%81TAP%EF%BC%88%E8%84%89%E5%86%B2%EF%BC%89%E6%88%96%E7%9E%AC%E6%80%81%E4%B8%AD%E6%96%AD%E6%98%AF%E5%90%AF%E7%94%A8%E7%9A%84%E3%80%82MKL25Z128%20%E9%80%9A%E8%BF%87%E8%AF%BB%E5%8F%96%20INT_SOURCE%20(0x0C)%20%E5%AF%84%E5%AD%98%E5%99%A8%E6%9D%A5%E5%93%8D%E5%BA%94%E8%BF%99%E4%BA%9B%E4%B8%AD%E6%96%AD%EF%BC%8C%E4%BB%A5%E7%A1%AE%E5%AE%9A%E9%80%82%E5%BD%93%E7%9A%84%E4%B8%AD%E6%96%AD%E6%BA%90%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%20text-align%3A%20justify%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20justify%3B%22%3E%E6%AF%8F%E4%B8%AA%E4%B8%AD%E6%96%AD%E6%BA%90%E9%83%BD%E6%9C%89%E8%87%AA%E5%B7%B1%E7%9A%84%E6%B8%85%E9%99%A4%E4%B8%AD%E6%96%AD%E6%A0%87%E5%BF%97%E7%9A%84%E6%96%B9%E6%B3%95%E3%80%82%E8%AF%B7%E5%8F%82%E8%80%83%E6%AF%8F%E4%B8%AAISR%E7%9A%84%E6%B3%A8%E9%87%8A%EF%BC%9A%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%20text-align%3A%20justify%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20justify%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSTRONG%3E%E7%9E%AC%E6%80%81%E4%B8%AD%E6%96%AD%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3E%E6%97%A0%E6%95%88%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EPORTA_IRQHandler%EF%BC%88%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EPORTA_PCR5%20%7C%3D%20PORT_PCR_ISF_MASK%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%E6%B8%85%E9%99%A4PTC%E4%B8%AD%E6%96%AD%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3Eint_source%20%3D%20I2C_ReadRegister(MMA8652FC_I2C_ADDRESS%2C%20INT_SOURCE_REG)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%E6%B8%85%E9%99%A4%E4%B8%AD%E6%96%AD%E6%BA%90%E5%AF%84%E5%AD%98%E5%99%A8%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3Eif%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E(int_source%26amp%3B0x20)%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%E7%9E%AC%E6%80%81%E4%B8%AD%E6%96%AD%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3Ei%20%3D%20I2C_ReadRegister(MMA8652FC_I2C_ADDRESS%2C%20TRANSIENT_SRC_REG)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%E8%AF%BB%E5%8F%96TRANSIENT_SRC%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%8C%E6%B8%85%E9%99%A4INT_SOURCE%E5%AF%84%E5%AD%98%E5%99%A8%E4%B8%AD%E7%9A%84SRC_TRANS%E6%A0%87%E5%BF%97%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20transient_int%20%3D%201%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20justify%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CSTRONG%3ETAP%20%E4%B8%AD%E6%96%AD%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20background%3A%20white%3B%20font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3E%E6%97%A0%E6%95%88%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3EPORTA_IRQHandler%EF%BC%88%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3EPORTA_PCR5%20%7C%3D%20PORT_PCR_ISF_MASK%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%20background%3A%20white%3B%22%3E%2F%2F%E6%B8%85%E9%99%A4PTC%E4%B8%AD%E6%96%AD%E6%A0%87%E5%BF%97%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3Eint_source%20%3D%20I2C_ReadRegister(MMA8652FC_I2C_ADDRESS%2C%20INT_SOURCE_REG)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%20background%3A%20white%3B%22%3E%2F%2F%E6%B8%85%E9%99%A4%E4%B8%AD%E6%96%AD%E6%BA%90%E5%AF%84%E5%AD%98%E5%99%A8%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20background%3A%20white%3B%20font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3Eif%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3E(int_source%26amp%3B0x08)%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%20background%3A%20white%3B%22%3E%2F%2F%E8%84%89%E5%86%B2%E4%B8%AD%E6%96%AD%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3Ei%20%3D%20I2C_ReadRegister(MMA8652FC_I2C_ADDRESS%2C%20PULSE_SRC_REG)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%20background%3A%20white%3B%22%3E%2F%2F%E8%AF%BB%E5%8F%96PULSE_SRC%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%8C%E6%B8%85%E9%99%A4INT_SOURCE%E5%AF%84%E5%AD%98%E5%99%A8%E4%B8%AD%E7%9A%84SRC_TRANS%E6%A0%87%E5%BF%97%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20pulse_int%20%3D%201%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E8%87%AA%E5%8A%A8%E5%94%A4%E9%86%92%2F%E7%9D%A1%E7%9C%A0%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%E4%B8%AD%E6%96%AD%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20void%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EPORTD_IRQHandler()%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EPORTD_PCR5%20%7C%3D%20PORT_PCR_ISF_MASK%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%E6%B8%85%E9%99%A4PTD%E4%B8%AD%E6%96%AD%E6%A0%87%E5%BF%97%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3Eint_source%20%3D%20I2C_ReadRegister(MMA8652FC_I2C_ADDRESS%2C%20INT_SOURCE_REG)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%E6%B8%85%E9%99%A4%E4%B8%AD%E6%96%AD%E6%BA%90%E5%AF%84%E5%AD%98%E5%99%A8%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3Eif%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E(int_source%26amp%3B0x80)%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%E8%87%AA%E5%8A%A8%E7%9D%A1%E7%9C%A0%2F%E5%94%A4%E9%86%92%E4%B8%AD%E6%96%AD%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3Ei%20%3D%20I2C_ReadRegister(MMA8652FC_I2C_ADDRESS%2C%20SYSMOD_REG)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%E8%AF%BB%E5%8F%96SYSMOD%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%8C%E6%B8%85%E9%99%A4INT_SOURCE%E5%AF%84%E5%AD%98%E5%99%A8%E4%B8%AD%E7%9A%84SRC_ASLP%E6%A0%87%E5%BF%97%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20sleep_int%20%3D%201%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E6.%E8%87%B3%E6%AD%A4%EF%BC%8CMCU%E5%92%8C%E5%8A%A0%E9%80%9F%E5%BA%A6%E8%AE%A1%E7%9A%84%E9%85%8D%E7%BD%AE%E5%B0%B1%E5%AE%8C%E6%88%90%E4%BA%86%E3%80%82%3C%2FP%3E%3CP%3EFRDM-KL25Z%20%E6%9D%BF%E4%B8%8A%E7%9A%84%20RGB%20LED%20%E7%BB%8F%E8%BF%87%E9%85%8D%E7%BD%AE%EF%BC%8C%E6%9C%89%E5%8A%A9%E4%BA%8E%E6%98%BE%E7%A4%BA%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E7%9A%84%E8%A1%8C%E4%B8%BA%E3%80%82%E6%AD%A4%E8%A1%8C%E4%B8%BA%E9%85%8D%E7%BD%AE%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23if%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3ETRANSIENT_DETECTION%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3E%E5%A6%82%E6%9E%9C%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%EF%BC%88transient_int%EF%BC%89%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20transient_int%20%3D%200%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20TURN_BLUE_ON()%3B%20TURN_RED_OFF()%3B%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20background%3A%20white%3B%20font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3E%23elif%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3E%E7%82%B9%E5%87%BB%E6%A3%80%E6%B5%8B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20background%3A%20white%3B%20font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3E%E5%A6%82%E6%9E%9C%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3E%EF%BC%88pulse_int%EF%BC%89%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20pulse_int%20%3D%200%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20TURN_BLUE_ON()%3B%20TURN_RED_OFF()%3B%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20background%3A%20white%3B%20font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23endif%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3E%E5%A6%82%E6%9E%9C%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%EF%BC%88%E7%9D%A1%E7%9C%A0%E6%95%B4%E6%95%B0%EF%BC%89%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20sleep_int%20%3D%200%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%200.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20TURN_RED_ON()%3B%20TURN_BLUE_OFF()%3B%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%20margin-bottom%3A%200.0001pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E7.%E6%80%BB%E4%B9%8B%EF%BC%8CFRDM-KL25Z%20%E5%B0%86%E4%B8%8E%20MMA8652FC%20%E8%BF%9E%E6%8E%A5%E3%80%82%E5%B0%86%E8%AE%BE%E7%BD%AE%E7%94%B5%E6%BA%90%E6%A8%A1%E5%BC%8F%E5%B9%B6%E5%90%AF%E7%94%A8%E4%B8%AD%E6%96%AD%E3%80%82%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20justify%3B%22%3E%E6%BA%90%E4%BB%A3%E7%A0%81%E9%A1%B6%E9%83%A8%E7%9A%84%3CEM%3E%E5%AE%8F%3C%2FEM%3E%E5%B0%86%E5%85%81%E8%AE%B8%E6%88%91%E4%BB%AC%E5%9C%A8%E4%B8%8D%E5%90%8C%E7%9A%84%E7%94%B5%E6%BA%90%E6%A8%A1%E5%BC%8F%E3%80%81%E4%B8%8D%E5%90%8C%E7%9A%84%E5%B5%8C%E5%85%A5%E5%8A%9F%E8%83%BD%E4%B9%8B%E9%97%B4%E8%BF%9B%E8%A1%8C%E9%80%89%E6%8B%A9%EF%BC%8C%E5%B9%B6%E9%80%89%E6%8B%A9%E8%87%AA%E5%8A%A8%E5%94%A4%E9%86%92%2F%E7%9D%A1%E7%9C%A0%E5%8A%9F%E8%83%BD%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20justify%3B%22%3E%E5%A6%82%E6%9E%9C%E5%90%AF%E7%94%A8%E8%87%AA%E5%8A%A8%E5%94%A4%E9%86%92%2F%E7%9D%A1%E7%9C%A0%E5%8A%9F%E8%83%BD%EF%BC%8CMMA8652FC%20%E5%B0%86%E8%BF%9B%E5%85%A5%E7%9D%A1%E7%9C%A0%E6%A8%A1%E5%BC%8F%EF%BC%88ODR%3D1.56Hz%EF%BC%895%E7%A7%92%E4%B8%8D%E6%B4%BB%E5%8A%A8%E5%90%8E%E3%80%82%E7%BA%A2%E8%89%B2%20LED%20%E5%B0%86%E8%A2%AB%E8%AE%BE%E7%BD%AE%E3%80%82%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20justify%3B%22%3E%E5%BD%93%E5%B5%8C%E5%85%A5%E5%BC%8F%E5%8A%9F%E8%83%BD%E4%BA%A7%E7%94%9F%E4%B8%AD%E6%96%AD%E6%97%B6%EF%BC%8CMMA8652FC%E5%B0%86%E8%A2%AB%E5%94%A4%E9%86%92%EF%BC%88ODR%3D800Hz%EF%BC%89%E7%AD%89%E7%AD%89%E3%80%82%E8%93%9D%E8%89%B2%20LED%20%E5%B0%86%E8%A2%AB%E8%AE%BE%E7%BD%AE%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F*%20%E9%80%89%E6%8B%A9%E7%94%B5%E6%BA%90%E6%A8%A1%E5%BC%8F%20-%20%E6%95%B0%E6%8D%AE%E8%A1%A8%E4%B8%AD%E7%9A%84%E8%A1%A8%20101%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3E%23%E5%AE%9A%E4%B9%89%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%E6%AD%A3%E5%B8%B8%E6%A8%A1%E5%BC%8F%201%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3E%23%E5%AE%9A%E4%B9%89%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%E4%BD%8E%E5%8A%9F%E8%80%97%E6%A8%A1%E5%BC%8F%200%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F*%20%E9%80%89%E6%8B%A9%E5%B5%8C%E5%85%A5%E5%87%BD%E6%95%B0%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3E%23%E5%AE%9A%E4%B9%89%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%E7%9E%AC%E6%80%81%E6%A3%80%E6%B5%8B%201%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3E%23%E5%AE%9A%E4%B9%89%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3ETAP_DETECTION%200%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F*%20%E8%87%AA%E5%8A%A8%E5%94%A4%E9%86%92%2F%E7%9D%A1%E7%9C%A0%E5%8A%9F%E8%83%BD%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3E%23%E5%AE%9A%E4%B9%89%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EAUTO_SLEEP%201%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E8.%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fcache.nxp.com%2Ffiles%2Fsensors%2Fdoc%2Fdata_sheet%2FMMA8652FC.pdf%3Fpspll%3D1%22%20target%3D%22_blank%22%3E%20%E6%95%B0%E6%8D%AE%E8%A1%A8%3C%2FA%3E%20%E4%B8%AD%E7%9A%84%3CSTRONG%3E%20%E8%A1%A8%205%3C%2FSTRONG%3E%20%E6%98%BE%E7%A4%BA%E4%BA%86%E4%B8%8E%E6%89%80%E9%80%89%E7%94%B5%E6%BA%90%E6%A8%A1%E5%BC%8F%E5%92%8C%20ODR%20%E7%9B%B8%E5%85%B3%E7%9A%84%E9%A2%84%E6%9C%9F%E7%94%B5%E6%B5%81%E6%B6%88%E8%80%97%EF%BC%9A%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22159613_159613.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22159613_159613.jpg%22%20style%3D%22width%3A%20987px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117978i55D600F23C402069%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22159613_159613.jpg%22%20alt%3D%22159613_159613.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lowpowertable.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lowpowertable.jpg%22%20style%3D%22width%3A%20987px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F1720iB85F3798779EE3E7%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22lowpowertable.jpg%22%20alt%3D%22lowpowertable.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20justify%3B%22%3E%E6%AD%A3%E5%A6%82%E6%88%91%E4%B9%8B%E5%89%8D%E6%8F%90%E5%88%B0%E7%9A%84%EF%BC%8C%E7%9D%A1%E7%9C%A0%E6%A8%A1%E5%BC%8F%E5%85%81%E8%AE%B8%E6%88%91%E4%BB%AC%E5%8A%A8%E6%80%81%E5%9C%B0%E5%9C%A8%E4%B8%8D%E5%90%8C%E7%9A%84%E8%BE%93%E5%87%BA%E6%95%B0%E6%8D%AE%E9%80%9F%E7%8E%87%EF%BC%88ODR%EF%BC%89%E4%B9%8B%E9%97%B4%E5%88%87%E6%8D%A2%EF%BC%8C%E4%BB%8E%E8%80%8C%E5%8F%AF%E4%BB%A5%E9%99%8D%E4%BD%8E%E7%94%B5%E6%B5%81%E6%B6%88%E8%80%97%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%20text-align%3A%20justify%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20justify%3B%22%3E%E4%B8%BA%E4%BA%86%E9%AA%8C%E8%AF%81%E5%8A%A0%E9%80%9F%E5%BA%A6%E8%AE%A1%E6%98%AF%E5%90%A6%E6%B6%88%E8%80%97%E6%95%B0%E6%8D%AE%E8%A1%A8%E4%B8%AD%E6%8F%90%E5%88%B0%E7%9A%84%E7%94%B5%E6%B5%81%EF%BC%8C%E6%88%91%E4%BD%BF%E7%94%A8%E6%8F%90%E5%88%B0%E7%9A%84%E9%A1%B9%E7%9B%AE%E6%B5%8B%E9%87%8F%E4%BA%86%20MMA8652FC%20%E7%9A%84%E7%94%B5%E6%B5%81%E6%B6%88%E8%80%97%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%20text-align%3A%20justify%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20justify%3B%22%3E%E8%AF%B7%E5%8F%82%E8%80%83%E4%BB%A5%E4%B8%8B%E7%BB%93%E6%9E%9C%EF%BC%9A%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22159614_159614.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22159614_159614.jpg%22%20style%3D%22width%3A%20843px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117979i18A77B87153C05C7%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22159614_159614.jpg%22%20alt%3D%22159614_159614.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22normalmode.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22normalmode.jpg%22%20style%3D%22width%3A%20843px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F108032iC5769C084A511CC1%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22normalmode.jpg%22%20alt%3D%22normalmode.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22159615_159615.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22159615_159615.jpg%22%20style%3D%22width%3A%20834px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117980i7779BE722514BCA8%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22159615_159615.jpg%22%20alt%3D%22159615_159615.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lowpowermode.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lowpowermode.jpg%22%20style%3D%22width%3A%20834px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F17105i7A7897850EE3F72D%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22lowpowermode.jpg%22%20alt%3D%22lowpowermode.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E9.%20%E4%BD%BF%E7%94%A8%E8%87%AA%E5%8A%A8%E5%94%A4%E9%86%92%2F%E7%9D%A1%E7%9C%A0%E6%A8%A1%E5%BC%8F%E7%9A%84%E4%BC%98%E7%82%B9%E6%98%AF%E7%B3%BB%E7%BB%9F%E5%8F%AF%E4%BB%A5%E5%9C%A8%E9%9C%80%E8%A6%81%E6%97%B6%E8%87%AA%E5%8A%A8%E8%BD%AC%E6%8D%A2%E5%88%B0%E6%9B%B4%E9%AB%98%E7%9A%84%E9%87%87%E6%A0%B7%E7%8E%87%EF%BC%88%E6%9B%B4%E9%AB%98%E7%9A%84%E7%94%B5%E6%B5%81%E6%B6%88%E8%80%97%EF%BC%89%EF%BC%8C%E4%BD%86%E5%BD%93%E8%AE%BE%E5%A4%87%E4%B8%8D%E9%9C%80%E8%A6%81%E6%9B%B4%E9%AB%98%E7%9A%84%E9%87%87%E6%A0%B7%E7%8E%87%E6%97%B6%EF%BC%8C%E5%A4%A7%E9%83%A8%E5%88%86%E6%97%B6%E9%97%B4%E9%83%BD%E5%A4%84%E4%BA%8E%E7%9D%A1%E7%9C%A0%E6%A8%A1%E5%BC%8F%EF%BC%88%E8%BE%83%E4%BD%8E%E7%9A%84%E7%94%B5%E6%B5%81%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%20text-align%3A%20justify%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20justify%3B%22%3E%E6%AD%A3%E5%A6%82%E6%88%91%E4%BB%AC%E5%AF%B9%20MMA8652FC%20%E7%9A%84%E6%9C%9F%E6%9C%9B%E4%B8%80%E6%A0%B7%EF%BC%8C%E5%BD%93%20ODR%20%E4%BB%8E%20800Hz%20%E5%8F%98%E4%B8%BA%201.56Hz%20%E6%97%B6%EF%BC%8C%E6%97%A0%E8%AE%BA%E6%98%AF%E5%9C%A8%E6%AD%A3%E5%B8%B8%E6%A8%A1%E5%BC%8F%E8%BF%98%E6%98%AF%E4%BD%8E%E5%8A%9F%E8%80%97%E6%A8%A1%E5%BC%8F%E4%B8%8B%EF%BC%8C%E7%94%B5%E6%B5%81%E6%B6%88%E8%80%97%E9%83%BD%E4%BC%9A%E9%99%8D%E4%BD%8E%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%20text-align%3A%20justify%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20justify%3B%22%3E%E6%95%B0%E6%8D%AE%E8%A1%A8%E4%B8%8A%E6%8F%90%E5%88%B0%E7%9A%84%E4%BF%A1%E6%81%AF%E7%8E%B0%E5%B7%B2%E7%A1%AE%E8%AE%A4%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20justify%3B%22%3E%E8%AF%B7%E5%8F%82%E9%98%85%E9%99%84%E4%BB%B6%E4%B8%AD%E7%9A%84%E5%AE%8C%E6%95%B4%E6%BA%90%E4%BB%A3%E7%A0%81%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20justify%3B%22%3E%E6%88%91%E5%B8%8C%E6%9C%9B%E6%82%A8%E5%8F%91%E7%8E%B0%E8%BF%99%E4%B8%AA%E7%A4%BA%E4%BE%8B%E9%A1%B9%E7%9B%AE%E6%9C%89%E7%94%A8%E4%B8%94%E6%9C%89%E8%B6%A3%E3%80%82%E4%BB%BB%E4%BD%95%E5%BB%BA%E8%AE%AE%E9%83%BD%E5%B0%86%E5%8F%97%E5%88%B0%E8%B5%9E%E8%B5%8F%E3%80%82%3CSPAN%20class%3D%22emoticon_happy%20emoticon-inline%22%20style%3D%22height%3A%2016px%3B%20width%3A%2016px%3B%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20justify%3B%22%3E%E6%AC%A2%E8%BF%8E%E6%82%A8%E5%8A%A0%E5%85%A5%20NXP%20%E7%A4%BE%E5%8C%BA%EF%BC%8C%E5%9C%A8%E8%BF%99%E9%87%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%8F%91%E5%B8%83%E6%89%80%E6%9C%89%E9%97%AE%E9%A2%98%EF%BC%8C%E5%B9%B6%E6%89%BE%E5%88%B0%E5%AF%B9%E6%82%A8%E7%9A%84%E9%A1%B9%E7%9B%AE%E6%9C%89%E7%94%A8%E7%9A%84%E6%9D%90%E6%96%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20justify%3B%22%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20justify%3B%22%3EDavid%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1122239%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E5%8A%A0%E9%80%9F%E5%BA%A6%E4%BC%A0%E6%84%9F%E5%99%A8%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1122242%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AMMA8652FC%20-%20%E8%87%AA%E5%8A%A8%E5%94%A4%E9%86%92%2F%E7%9D%A1%E7%9C%A0%E6%A8%A1%E5%BC%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122242%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E5%8F%91%E7%8E%B0%E4%BA%86%E8%BF%99%E4%BA%9B%E9%97%AE%E9%A2%98%E7%9A%84%E5%8E%9F%E5%9B%A0%E2%80%94%E2%80%94%E8%87%AA%E5%8A%A8%E7%9D%A1%E7%9C%A0%E3%80%82%E5%BD%93%E5%8A%A0%E9%80%9F%E5%BA%A6%E8%AE%A1%E8%BF%9B%E5%85%A5%E7%9D%A1%E7%9C%A0%E7%8A%B6%E6%80%81%E6%97%B6%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%EF%BC%8CINT_SOURCE%20%E5%92%8C%20PULSE_SRC%20%E4%BC%9A%E8%A2%AB%E6%B8%85%E9%99%A4%EF%BC%8C%E5%B9%B6%E4%B8%94%E5%BB%B6%E8%BF%9F%E8%AE%A1%E6%95%B0%E5%99%A8%E5%8F%AF%E8%83%BD%E4%BC%9A%E5%85%B3%E9%97%AD%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1122241%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AMMA8652FC%20-%20%E8%87%AA%E5%8A%A8%E5%94%A4%E9%86%92%2F%E7%9D%A1%E7%9C%A0%E6%A8%A1%E5%BC%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122241%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%BF%98%E6%9C%89%E4%B8%80%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%E5%A6%82%E6%9E%9C%E6%B2%A1%E6%9C%89%E6%A3%80%E6%B5%8B%E5%88%B0%E8%84%89%E5%86%B2%EF%BC%8C%E6%88%91%E5%8F%AF%E4%BB%A5%E5%9C%A8%E8%BF%99%E7%A7%8D%E9%85%8D%E7%BD%AE%E4%B8%AD%E8%8E%B7%E5%BE%97%20INT1%20%E4%B8%AD%E6%96%AD%E5%90%97%EF%BC%9F%E6%88%91%E5%8F%91%E7%8E%B0%E6%88%91%E5%9C%A8%20INT1%20%E5%BC%95%E8%84%9A%E4%B8%8A%E6%8E%A5%E6%94%B6%E5%88%B0%E4%B8%AD%E6%96%AD%E3%80%82%E5%BD%93%E6%88%91%E5%9C%A8%E6%8E%A5%E6%94%B6%E5%88%B0%E4%B8%AD%E6%96%AD%E5%90%8E%E7%AB%8B%E5%8D%B3%E8%AF%BB%E5%8F%96%E5%AF%84%E5%AD%98%E5%99%A8%20INT_SOURCE%20%E5%92%8C%20PULSE_SRC%20%E6%97%B6%EF%BC%8C%E8%BF%99%E4%BA%9B%E5%AF%84%E5%AD%98%E5%99%A8%E6%9C%89%E6%97%B6%E9%83%BD%E6%98%AF%E7%A9%BA%E7%9A%84%E3%80%82%E5%BD%93%E6%88%91%E5%B0%9D%E8%AF%95%E8%8E%B7%E5%8F%96%20PULSE%20%E6%97%B6%EF%BC%8C%E6%88%91%E4%BC%9A%E6%94%B6%E5%88%B0%E8%BF%99%E4%BA%9B%E4%B8%AD%E6%96%AD%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1122240%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AMMA8652FC%20-%20%E8%87%AA%E5%8A%A8%E5%94%A4%E9%86%92%2F%E7%9D%A1%E7%9C%A0%E6%A8%A1%E5%BC%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1122240%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%81%E8%83%BD%E5%B8%AE%E6%88%91%E8%A7%A3%E5%86%B3%E4%B8%80%E4%B8%8B%E6%88%91%E7%9A%84%E9%97%AE%E9%A2%98%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3EMMA8652FC%E4%BD%9C%E4%B8%BA%E8%84%89%E5%86%B2%E8%AE%A1%E6%95%B0%E5%99%A8%E3%80%82%E5%AE%83%E8%83%BD%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%EF%BC%8C%E4%BD%86%E5%B9%B6%E4%B8%8D%E5%AE%8C%E5%85%A8%E7%AC%A6%E5%90%88%E6%88%91%E4%BB%AC%E7%9A%84%E9%A2%84%E6%9C%9F%E3%80%82%E6%88%91%E4%BB%AC%E6%97%A0%E6%B3%95%E8%8E%B7%E5%BE%97%E5%BF%BD%E7%95%A5%E8%84%89%E5%86%B2%E7%9A%84%E9%97%B4%E9%9A%94%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E6%88%91%E4%BB%AC%E9%87%87%E7%94%A8%E4%BB%A5%E4%B8%8B%E9%85%8D%E7%BD%AE%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%20class%3D%22%22%3EXYZ_DATA_CFG%3C%2FSPAN%3E%20%3D%200x10%3B%2F%2F%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E2g%E6%A8%A1%E5%BC%8F%3CSPAN%20class%3D%22%22%3E%3CBR%20%2F%3EHP_FILTER_CUTOFF%3C%2FSPAN%3E%20%3D%200%3B%2F%2F%20%E9%AB%98%E9%80%9A%E6%BB%A4%E6%B3%A2%E5%99%A8%E6%89%93%E5%BC%80%EF%BC%8C%E4%BD%8E%E9%80%9A%E6%BB%A4%E6%B3%A2%E5%99%A8%E5%85%B3%E9%97%AD%3CBR%20style%3D%22font-weight%3A%20normal%3B%22%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%20%3CSPAN%20class%3D%22%22%3ECTRL_REG1%3C%2FSPAN%3E%20%3D%200x69%3B%2F%2FASLP%E9%80%9F%E7%8E%8712.5%20Hz%EF%BC%8C%E6%95%B0%E6%8D%AE%E9%80%9F%E7%8E%87-12.5%20Hz%3CBR%20style%3D%22font-weight%3A%20normal%3B%22%20%2F%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%20class%3D%22%22%3ECTRL_REG2%3C%2FSPAN%3E%20%3CSPAN%3E%3D%200x1F%3B%2F%2Fsmod%20-%20%E4%BD%8E%E5%8A%9F%E8%80%97%EF%BC%8C%E8%87%AA%E5%8A%A8%E7%9D%A1%E7%9C%A0%E5%90%AF%E7%94%A8%EF%BC%8Cmod%20-%20%E4%BD%8E%E5%8A%9F%E8%80%97%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3E%3CSPAN%20class%3D%22%22%3ECTRL_REG3%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3E%3D%200x11%3B%2F%2F%E5%94%A4%E9%86%92%E8%84%89%E5%86%B2%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%20class%3D%22%22%3ECTRL_REG4%3C%2FSPAN%3E%20%3CSPAN%3E%3D%200x08%3B%2F%2F%E8%84%89%E5%86%B2%E4%B8%AD%E6%96%AD%E4%BD%BF%E8%83%BD%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3E%20%3CSPAN%20class%3D%22%22%3EPULSE_CFG%3C%2FSPAN%3E%20%3D%200x10%3B%2F%2F%E5%8D%95%E8%84%89%E5%86%B2Z-zxis%3CBR%20style%3D%22font-weight%3A%20normal%3B%22%20%2F%3E%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3E%20%3CSPAN%20class%3D%22%22%3EPULSE_THSX%20%3D%200x20%3B%2F%2F%3C%2FSPAN%3E%3CBR%20style%3D%22font-weight%3A%20normal%3B%22%20%2F%3E%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3E%3CSPAN%20class%3D%22%22%3EPULSE_THSY%20%3D%200x20%3B%2F%2F%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3E%3CSPAN%20class%3D%22%22%3EPULSE_THSZ%20%3D%200x2A%3B%2F%2F%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3CSPAN%20class%3D%22%22%3EPULSE_TMLT%3C%2FSPAN%3E%20%3D%200x03%3B%2F%2F3%20*%2040%20%3D%20120%20ms%EF%BC%88%E6%AD%A3%E5%A6%82%E6%88%91%E4%BB%AC%E6%89%80%E7%90%86%E8%A7%A3%E7%9A%84%20-%20%E8%BF%99%E6%98%AF%E6%9C%80%E5%A4%A7%E8%84%89%E5%86%B2%E5%AE%BD%E5%BA%A6%EF%BC%89%3CBR%20style%3D%22font-weight%3A%20normal%3B%22%20%2F%3E%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3CSPAN%20class%3D%22%22%3EPULSE_LTCY%3C%2FSPAN%3E%20%3D%200xFF%3B%2F%2F80%20*%20255%20%3D%2020.4%E7%A7%92%3CBR%20style%3D%22font-weight%3A%20normal%3B%22%20%2F%3E%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3E%3CSPAN%20class%3D%22%22%3E%20%3CSPAN%20class%3D%22%22%3EASLP_COUNT%3C%2FSPAN%3E%20%3D%200x01%3B%2F%2F%3CBR%20style%3D%22font-weight%3A%20normal%3B%22%20%2F%3E%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3E%3CSPAN%20class%3D%22%22%3E%E6%88%91%E4%BB%AC%E7%A1%AE%E5%AE%9E%E5%BE%97%E5%88%B0%E4%BA%86%E8%84%89%E5%86%B2%E4%B8%AD%E6%96%AD%EF%BC%8C%E4%BD%86%E6%88%91%E4%BB%AC%E6%B2%A1%E6%9C%89%E8%BF%99%E4%B8%AA%2020.4%20%E7%A7%92%E8%84%89%E5%86%B2%E4%B9%8B%E9%97%B4%E4%B8%8D%E6%B4%BB%E5%8A%A8%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3E%3CSPAN%20class%3D%22%22%3E%E6%80%8E%E4%B9%88%E4%BA%86%EF%BC%9F%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%8F%90%E5%89%8D%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%B8%AE%E5%8A%A9%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎02-03-2026 05:19 PM
更新人:
