MMA8451Q - Bare metal example project
Hi Everyone,
As I am frequently asked for a simple bare metal example code for the Xtrinsic MMA8451Q digital accelerometer, I would like to share here one of my examples I have created for this part while working with the Freescale FRDM-KL25Z platform.
This example illustrates:
1. Initialization of the MKL25Z128 MCU (mainly I2C and PORT modules).
2. Initialization of the accelerometer to achieve the highest resolution.
3. Simple offset calibration based on the AN4069.
4. Output data reading using an interrupt technique.
5. Conversion of the output values from registers 0x01 – 0x06 to real acceleration values in g’s.
6. Visualization of the output values in the FreeMASTER tool.
1. According to the schematic, the INT1 output of the MMA8451Q is connected to the PTA14 pin of the KL25Z MCU and both SCL and SDA lines are connected to the I2C0 module (PTE24 and PTE25 pins). The MCU is, therefore, configured as follows:
void MCU_Init(void)
     //I2C0 module initialization
     SIM_SCGC4 |= SIM_SCGC4_I2C0_MASK;        // Turn on clock to I2C0 module
     SIM_SCGC5 |= SIM_SCGC5_PORTE_MASK;       // Turn on clock to Port E module
     PORTE_PCR24 = PORT_PCR_MUX(5);           // PTE24 pin is I2C0 SCL line
     PORTE_PCR25 = PORT_PCR_MUX(5);           // PTE25 pin is I2C0 SDA line
     I2C0_F  = 0x14;                          // SDA hold time = 2.125us, SCL start hold time = 4.25us, SCL stop hold time = 5.125us *
     I2C0_C1 = I2C_C1_IICEN_MASK;             // Enable I2C0 module
        //Configure the PTA14 pin (connected to the INT1 of the MMA8451Q) for falling edge interrupts
     SIM_SCGC5 |= SIM_SCGC5_PORTA_MASK;       // Turn on clock to Port A module
     PORTA_PCR14 |= (0|PORT_PCR_ISF_MASK|     // Clear the interrupt flag
                       PORT_PCR_MUX(0x1)|     // PTA14 is configured as GPIO
                       PORT_PCR_IRQC(0xA));   // PTA14 is configured for falling edge interrupts
        //Enable PORTA interrupt on NVIC
     NVIC_ICPR |= 1 << ((INT_PORTA - 16)%32);
     NVIC_ISER |= 1 << ((INT_PORTA - 16)%32);
2. At the beginning of the initialization, all accelerometer registers are reset to their default values by setting the RST bit of the CTRL_REG2 register. The dynamic range is set to ±2g and to achieve the highest resolution, the LNOISE bit is set and the lowest ODR (1.56Hz) and the High Resolution mode are selected (more details in AN4075).
void Accelerometer_Init (void)
     unsigned char reg_val = 0;
     I2C_WriteRegister(MMA845x_I2C_ADDRESS, CTRL_REG2, 0x40);           // Reset all registers to POR values
         do            // Wait for the RST bit to clear
        reg_val = I2C_ReadRegister(MMA845x_I2C_ADDRESS, CTRL_REG2) & 0x40;
     }  while (reg_val);
     I2C_WriteRegister(MMA845x_I2C_ADDRESS, XYZ_DATA_CFG_REG, 0x00);    // +/-2g range -> 1g = 16384/4 = 4096 counts
     I2C_WriteRegister(MMA845x_I2C_ADDRESS, CTRL_REG2, 0x02);           // High Resolution mode
     I2C_WriteRegister(MMA845x_I2C_ADDRESS, CTRL_REG1, 0x3D);           // ODR = 1.56Hz, Reduced noise, Active mode
3. A simple offset calibration method is implemented according to the AN4069. At the end of the calibration routine, the DRDY interrupt is enabled and routed to the INT1 interrupt pin that is configured to be a push-pull, active-low output.
void Calibrate (void)
         while (!reg_val)           // Wait for a first set of data
        reg_val = I2C_ReadRegister(MMA845x_I2C_ADDRESS, STATUS_REG) & 0x08;
     I2C_ReadMultiRegisters(MMA845x_I2C_ADDRESS, OUT_X_MSB_REG, 6, AccData);           // Read data output registers 0x01-0x06
     Xout_14_bit = ((short) (AccData[0]<<8 | AccData[1])) >> 2;           // Compute 14-bit X-axis output value
     Yout_14_bit = ((short) (AccData[2]<<8 | AccData[3])) >> 2;           // Compute 14-bit Y-axis output value
     Zout_14_bit = ((short) (AccData[4]<<8 | AccData[5])) >> 2;           // Compute 14-bit Z-axis output value
     Xoffset = Xout_14_bit / 8 * (-1);        // Compute X-axis offset correction value
     Yoffset = Yout_14_bit / 8 * (-1);        // Compute Y-axis offset correction value
     Zoffset = (Zout_14_bit - SENSITIVITY_2G) / 8 * (-1);          // Compute Z-axis offset correction value
     I2C_WriteRegister(MMA845x_I2C_ADDRESS, CTRL_REG1, 0x00);             // Standby mode to allow writing to the offset registers
     I2C_WriteRegister(MMA845x_I2C_ADDRESS, OFF_X_REG, Xoffset);
     I2C_WriteRegister(MMA845x_I2C_ADDRESS, OFF_Y_REG, Yoffset);
     I2C_WriteRegister(MMA845x_I2C_ADDRESS, OFF_Z_REG, Zoffset);
     I2C_WriteRegister(MMA845x_I2C_ADDRESS, CTRL_REG3, 0x00);             // Push-pull, active low interrupt
     I2C_WriteRegister(MMA845x_I2C_ADDRESS, CTRL_REG4, 0x01);             // Enable DRDY interrupt
     I2C_WriteRegister(MMA845x_I2C_ADDRESS, CTRL_REG5, 0x01);             // DRDY interrupt routed to INT1 - PTA14
4. In the ISR, only the interrupt flag is cleared and the DataReady variable is set to indicate the arrival of new data.
void PORTA_IRQHandler()
     PORTA_PCR14 |= PORT_PCR_ISF_MASK;            // Clear the interrupt flag
     DataReady = 1;
5. The output values from accelerometer registers 0x01 – 0x06 are first converted to signed 14-bit values and afterwards to real values in g’s.
if (DataReady)             // Is a new set of data ready?
     DataReady = 0;
     Xout_g = ((float) Xout_14_bit) / SENSITIVITY_2G;              // Compute X-axis output value in g's
     Yout_g = ((float) Yout_14_bit) / SENSITIVITY_2G;              // Compute Y-axis output value in g's
     Zout_g = ((float) Zout_14_bit) / SENSITIVITY_2G;              // Compute Z-axis output value in g's
6. The calculated values can be watched in the "Variables" window on the top right of the Debug perspective or in the FreeMASTER application. To view both the 14-bit and real values in the FreeMASTER application, some USBDM drivers need to be first installed on your computer. They are available for download from SourceForge. Erich Styger described their installation in this tutorial. In addition to that, the USBDM_OpenSDA application that provides both debugging and a virtual serial port needs to be loaded into the MK20 debugger chip on the FRDM-KL25Z board. This installation follows the usual FRDM-KL25Z bootloader process:
  • Unplug the FRDM-KL25Z board.
  • Whilst holding the SW1/RST switch depressed plug in the FRDM-KL25Z board. The green LED should start blinking at a rate of about 1Hz.
  • Open a file explorer and locate the USB drive that has now appeared. It will have the drive name "BOOTLOADER".
  • Drag the file USBDM_OpenSDA.sx to the USB drive and wait a short while. The OpenSDA firmware on the FRDM-KL25Z board will program the USBDM firmware into the MK20 debugger chip on the board.
  • Remove and re-plug the FRDM-KL25Z board. The board will now appear as a USBDM device.
Attached you can find the complete source code written in the CW for MCU's v10.5 as well as the FreeMASTER project.
So make it, test it and keep in touch...
Tomas
附件
评论
I am using MMA8451Q in KL25Z board with Code Warrior 10.6 (processor expert). I have configured the board for transient detection but i was not able to generate the interrupt when the amplitude goes beyond threshold level. Is there any component that helps to write the ISR for the interrupt generated on PTA14.
Charan
Hi Charan,
You might find useful my example code for the embedded transient detection function that is available here.
I hope it helps.
Tomas
Hi Tomas,
thank you very much for your replay and It worked.
Charan
Hi Tomas,
I tried your code on board FRDM KL43z. The difference between it and KL25z is that the pin INT1 is the pin PTC5. I tested initially communicate, therefore I read WHOIAM register (0x0D), but returns me sign 0xFF, but interesting is that once function return correct character 0x1A, but after restart again return 0xFF. Where could be a problem?
Thanks.
Hi Martin,
Since the FRDM-KL43Z board does not have both the communication pins (PTE24 – I2C0 SCL and PTE25 – I2C0 SDA) easily accessible to see what is going on on the I2C bus, it is hard to say where the problem might be. The MKL43Z256 MCU is not supported in the CW for MCU’s v10.6, so I have created another project in KDS 3.0.0 using KSDK 1.2.0 and Processor Expert. You can find it attached above in my original post.
Hope it helps.
Tomas
Hi Tomas,
I´m not able to watch the variables at Freemaster (I´m new using this tool) and I don´t see its libraries, functions, etc. from your souce code, so how the application communicate with Freemaster and how to embedded in a new baremetal project?
Hi Tomas,
is there any chance you could upload your projects again as they're unfortunately deleted from NXP sites. Working on MMA8451Q with KL46Z and got hard stuck. Can't get ack after sending my address to I2C. I would really appreciate. I know it's been a long time since you posted this.
%3CLINGO-SUB%20id%3D%22lingo-sub-1127268%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMMA8451Q%E2%80%94%E2%80%94%E8%A3%B8%E6%9C%BA%E9%A1%B9%E7%9B%AE%E7%A4%BA%E4%BE%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1127268%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%A4%A7%E5%AE%B6%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%E7%94%B1%E4%BA%8E%E6%88%91%E7%BB%8F%E5%B8%B8%E8%A2%AB%E8%A6%81%E6%B1%82%E6%8F%90%E4%BE%9B%3CA%20href%3D%22http%3A%2F%2Fwww.freescale.com%2Fwebapp%2Fsps%2Fsite%2Fprod_summary.jsp%3Fcode%3DMMA8451Q%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EXtrinsic%20MMA8451Q%20%E6%95%B0%E5%AD%97%E5%8A%A0%E9%80%9F%E5%BA%A6%E8%AE%A1%3C%2FA%3E%E7%9A%84%E7%AE%80%E5%8D%95%E8%A3%B8%E6%9C%BA%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%EF%BC%8C%E5%9B%A0%E6%AD%A4%E6%88%91%E6%83%B3%E5%9C%A8%E8%BF%99%E9%87%8C%E5%88%86%E4%BA%AB%E6%88%91%E5%9C%A8%E4%BD%BF%E7%94%A8%20Freescale%20%3CA%20href%3D%22http%3A%2F%2Fwww.freescale.com%2Fwebapp%2Fsps%2Fsite%2Fprod_summary.jsp%3Fcode%3DFRDM-KL25Z%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EFRDM-KL25Z%20%E5%B9%B3%E5%8F%B0%3C%2FA%3E%E6%97%B6%E4%B8%BA%E6%AD%A4%E9%83%A8%E5%88%86%E5%88%9B%E5%BB%BA%E7%9A%84%E4%B8%80%E4%B8%AA%E7%A4%BA%E4%BE%8B%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%E6%AD%A4%E7%A4%BA%E4%BE%8B%E8%AF%B4%E6%98%8E%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E1.%20MKL25Z128%20MCU%20%E7%9A%84%E5%88%9D%E5%A7%8B%E5%8C%96%EF%BC%88%E4%B8%BB%E8%A6%81%E6%98%AF%20I2C%20%E5%92%8C%20PORT%20%E6%A8%A1%E5%9D%97%EF%BC%89%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E2.%20%E5%88%9D%E5%A7%8B%E5%8C%96%E5%8A%A0%E9%80%9F%E5%BA%A6%E8%AE%A1%E4%BB%A5%E5%AE%9E%E7%8E%B0%E6%9C%80%E9%AB%98%E5%88%86%E8%BE%A8%E7%8E%87%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E3.%E5%9F%BA%E4%BA%8E%3CA%20href%3D%22http%3A%2F%2Fwww.freescale.com%2Ffiles%2Fsensors%2Fdoc%2Fapp_note%2FAN4069.pdf%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EAN4069%3C%2FA%3E%E7%9A%84%E7%AE%80%E5%8D%95%E5%A4%B1%E8%B0%83%E6%A0%A1%E5%87%86%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E4.%E4%BD%BF%E7%94%A8%E4%B8%AD%E6%96%AD%E6%8A%80%E6%9C%AF%E8%BE%93%E5%87%BA%E6%95%B0%E6%8D%AE%E8%AF%BB%E5%8F%96%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E5.%20%E5%B0%86%E5%AF%84%E5%AD%98%E5%99%A8%200x01%20%E2%80%93%200x06%20%E7%9A%84%E8%BE%93%E5%87%BA%E5%80%BC%E8%BD%AC%E6%8D%A2%E4%B8%BA%20g%20%E4%B8%AD%E7%9A%84%E5%AE%9E%E9%99%85%E5%8A%A0%E9%80%9F%E5%BA%A6%E5%80%BC%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E6.%20%E5%9C%A8%3CA%20href%3D%22http%3A%2F%2Fwww.freescale.com%2Fwebapp%2Fsps%2Fsite%2Fprod_summary.jsp%3Fcode%3DFREEMASTER%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EFreeMASTER%20%E5%B7%A5%E5%85%B7%3C%2FA%3E%E4%B8%AD%E5%8F%AF%E8%A7%86%E5%8C%96%E8%BE%93%E5%87%BA%E5%80%BC%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E1.%E6%A0%B9%E6%8D%AE%3CA%20href%3D%22http%3A%2F%2Fcache.freescale.com%2Ffiles%2Fsoft_dev_tools%2Fhardware_tools%2Fschematics%2FFRDM-KL25Z_SCH_REV_E.pdf%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E5%8E%9F%E7%90%86%E5%9B%BE%3C%2FA%3E%EF%BC%8CMMA8451Q%20%E7%9A%84%20INT1%20%E8%BE%93%E5%87%BA%E8%BF%9E%E6%8E%A5%E5%88%B0%20KL25Z%20MCU%20%E7%9A%84%20PTA14%20%E5%BC%95%E8%84%9A%EF%BC%8CSCL%20%E5%92%8C%20SDA%20%E7%BA%BF%E9%83%BD%E8%BF%9E%E6%8E%A5%E5%88%B0%20I2C0%20%E6%A8%A1%E5%9D%97%EF%BC%88PTE24%20%E5%92%8C%20PTE25%20%E5%BC%95%E8%84%9A%EF%BC%89%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8CMCU%20%E9%85%8D%E7%BD%AE%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3Evoid%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%20%3CSTRONG%3EMCU_Init%3C%2FSTRONG%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3Evoid%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-family%3A%20Consolas%3B%20font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2FI2C0%20module%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-family%3A%20Consolas%3B%20font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3Einitialization%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3ESIM_SCGC4%20%7C%3D%20SIM_SCGC4_I2C0_MASK%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20%E6%89%93%E5%BC%80%20I2C0%20%E6%A8%A1%E5%9D%97%E7%9A%84%E6%97%B6%E9%92%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3ESIM_SCGC5%20%7C%3D%20SIM_SCGC5_PORTE_MASK%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20%E6%89%93%E5%BC%80%E7%AB%AF%E5%8F%A3%20E%20%E6%A8%A1%E5%9D%97%E7%9A%84%E6%97%B6%E9%92%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EPORTE_PCR24%20%3D%20PORT_PCR_MUX(5)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20PTE24%20%E5%BC%95%E8%84%9A%E4%B8%BA%20I2C0%20SCL%20%E7%BA%BF%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EPORTE_PCR25%20%3D%20PORT_PCR_MUX(5)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20PTE25%20%E5%BC%95%E8%84%9A%E4%B8%BA%20I2C0%20SDA%20%E7%BA%BF%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EI2C0_F%20%3D%200x14%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20SDA%20%E4%BF%9D%E6%8C%81%E6%97%B6%E9%97%B4%20%3D%202.125us%EF%BC%8CSCL%20%E5%90%AF%E5%8A%A8%E4%BF%9D%E6%8C%81%E6%97%B6%E9%97%B4%20%3D%204.25us%EF%BC%8CSCL%20%E5%81%9C%E6%AD%A2%E4%BF%9D%E6%8C%81%E6%97%B6%E9%97%B4%20%3D%205.125us%20*%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EI2C0_C1%20%3D%20I2C_C1_IICEN_MASK%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%E5%90%AF%E7%94%A8%20I2C0%20%E6%A8%A1%E5%9D%97%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%26nbsp%3B%20%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%E9%85%8D%E7%BD%AEPTA14%E5%BC%95%E8%84%9A%EF%BC%88%E8%BF%9E%E6%8E%A5%E5%88%B0MMA8451Q%E7%9A%84INT1%EF%BC%89%E7%94%A8%E4%BA%8E%E4%B8%8B%E9%99%8D%E6%B2%BF%E4%B8%AD%E6%96%AD%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3ESIM_SCGC5%20%7C%3D%20SIM_SCGC5_PORTA_MASK%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20%E6%89%93%E5%BC%80%E7%AB%AF%E5%8F%A3%20A%20%E6%A8%A1%E5%9D%97%E7%9A%84%E6%97%B6%E9%92%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EPORTA_PCR14%20%7C%3D%20(0%7CPORT_PCR_ISF_MASK%7C%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%E6%B8%85%E9%99%A4%E4%B8%AD%E6%96%AD%E6%A0%87%E5%BF%97%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EPORT_PCR_MUX(0x1)%7C%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20PTA14%20%E9%85%8D%E7%BD%AE%E4%B8%BA%20GPIO%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EPORT_PCR_IRQC(0xA))%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20PTA14%20%E9%85%8D%E7%BD%AE%E4%B8%BA%E4%B8%8B%E9%99%8D%E6%B2%BF%E4%B8%AD%E6%96%AD%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%26nbsp%3B%20%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%E5%9C%A8NVIC%E4%B8%8A%E5%90%AF%E7%94%A8PORTA%E4%B8%AD%E6%96%AD%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3ENVIC_ICPR%20%7C%3D%201%20%26lt%3B%26lt%3B%20((%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%230000c0%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CEM%3EINT_PORTA%3C%2FEM%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E-%2016)%2532)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3ENVIC_ISER%20%7C%3D%201%20%26lt%3B%26lt%3B%20((%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%230000c0%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CEM%3EINT_PORTA%3C%2FEM%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E-%2016)%2532)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E2.%20%E5%9C%A8%E5%88%9D%E5%A7%8B%E5%8C%96%E5%BC%80%E5%A7%8B%E6%97%B6%EF%BC%8C%E9%80%9A%E8%BF%87%E8%AE%BE%E7%BD%AE%20CTRL_REG2%20%E5%AF%84%E5%AD%98%E5%99%A8%E7%9A%84%20RST%20%E4%BD%8D%E5%B0%86%E6%89%80%E6%9C%89%E5%8A%A0%E9%80%9F%E5%BA%A6%E8%AE%A1%E5%AF%84%E5%AD%98%E5%99%A8%E9%87%8D%E7%BD%AE%E4%B8%BA%E5%85%B6%E9%BB%98%E8%AE%A4%E5%80%BC%E3%80%82%E5%8A%A8%E6%80%81%E8%8C%83%E5%9B%B4%E8%AE%BE%E7%BD%AE%E4%B8%BA%C2%B12g%EF%BC%8C%E4%B8%BA%E4%BA%86%E5%AE%9E%E7%8E%B0%E6%9C%80%E9%AB%98%E5%88%86%E8%BE%A8%E7%8E%87%EF%BC%8C%E8%AE%BE%E7%BD%AE%E4%BA%86LNOISE%E4%BD%8D%E5%B9%B6%E9%80%89%E6%8B%A9%E6%9C%80%E4%BD%8EODR%EF%BC%881.56Hz%EF%BC%89%E5%92%8C%E9%AB%98%E5%88%86%E8%BE%A8%E7%8E%87%E6%A8%A1%E5%BC%8F%EF%BC%88%E6%9B%B4%E5%A4%9A%E8%AF%A6%E7%BB%86%E4%BF%A1%E6%81%AF%E8%AF%B7%E5%8F%82%E8%A7%81%3CA%20href%3D%22http%3A%2F%2Fwww.freescale.com%2Ffiles%2Fsensors%2Fdoc%2Fapp_note%2FAN4075.pdf%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EAN4075%3C%2FA%3E%20%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3Evoid%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%20%3CSTRONG%3EAccelerometer_Init%3C%2FSTRONG%3E%20(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3Evoid%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3E%E6%97%A0%E7%AC%A6%E5%8F%B7%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3E%E5%AD%97%E7%AC%A6%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3Ereg_val%20%3D%200%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%26nbsp%3B%20%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EI2C_WriteRegister(MMA845x_I2C_ADDRESS%2C%20CTRL_REG2%2C%200x40)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20%E5%B0%86%E6%89%80%E6%9C%89%E5%AF%84%E5%AD%98%E5%99%A8%E9%87%8D%E7%BD%AE%E4%B8%BA%20POR%20%E5%80%BC%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3E%2F%2F%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%E7%AD%89%E5%BE%85RST%E4%BD%8D%E6%B8%85%E9%99%A4%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3Ereg_val%20%3D%20I2C_ReadRegister(MMA845x_I2C_ADDRESS%EF%BC%8CCTRL_REG2)%20%26amp%3B%200x40%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%7D)%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3E%E8%80%8C%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%EF%BC%88reg_val%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%26nbsp%3B%20%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EI2C_WriteRegister(MMA845x_I2C_ADDRESS%2C%20XYZ_DATA_CFG_REG%2C%200x00)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20%2B%2F-2g%20%E8%8C%83%E5%9B%B4%20-%26gt%3B%201g%20%3D%2016384%2F4%20%3D%204096%20%E4%B8%AA%E8%AE%A1%E6%95%B0%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EI2C_WriteRegister(MMA845x_I2C_ADDRESS%2C%20CTRL_REG2%2C%200x02)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%E9%AB%98%E5%88%86%E8%BE%A8%E7%8E%87%E6%A8%A1%E5%BC%8F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EI2C_WriteRegister(MMA845x_I2C_ADDRESS%2C%20%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20Consolas%3B%22%3ECTRL_REG%3C%2FSPAN%3E%201%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%2C%200x3D)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20ODR%20%3D%201.56Hz%EF%BC%8C%E9%99%8D%E4%BD%8E%E5%99%AA%E9%9F%B3%EF%BC%8C%E4%B8%BB%E5%8A%A8%E6%A8%A1%E5%BC%8F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E3.%E6%A0%B9%E6%8D%AE%3CA%20href%3D%22http%3A%2F%2Fwww.freescale.com%2Ffiles%2Fsensors%2Fdoc%2Fapp_note%2FAN4069.pdf%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EAN4069%3C%2FA%3E%E5%AE%9E%E7%8E%B0%E4%BA%86%E4%B8%80%E7%A7%8D%E7%AE%80%E5%8D%95%E7%9A%84%E5%A4%B1%E8%B0%83%E6%A0%A1%E5%87%86%E6%96%B9%E6%B3%95%E3%80%82%E5%9C%A8%E6%A0%A1%E5%87%86%E7%A8%8B%E5%BA%8F%E7%BB%93%E6%9D%9F%E6%97%B6%EF%BC%8CDRDY%20%E4%B8%AD%E6%96%AD%E8%A2%AB%E5%90%AF%E7%94%A8%E5%B9%B6%E8%B7%AF%E7%94%B1%E5%88%B0%E9%85%8D%E7%BD%AE%E4%B8%BA%E6%8E%A8%E6%8C%BD%E5%BC%8F%E3%80%81%E4%BD%8E%E7%94%B5%E5%B9%B3%E6%9C%89%E6%95%88%E8%BE%93%E5%87%BA%E7%9A%84%20INT1%20%E4%B8%AD%E6%96%AD%E5%BC%95%E8%84%9A%E3%80%82%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3Evoid%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%20%3CSTRONG%3ECalibrate%3C%2FSTRONG%3E%20(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3Evoid%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3E%E6%97%A0%E7%AC%A6%E5%8F%B7%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3E%E5%AD%97%E7%AC%A6%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3Ereg_val%20%3D%200%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%26nbsp%3B%20%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3Ewhile%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E(!reg_val)%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20%E7%AD%89%E5%BE%85%E7%AC%AC%E4%B8%80%E7%BB%84%E6%95%B0%E6%8D%AE%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3Ereg_val%20%3D%20I2C_ReadRegister(MMA845x_I2C_ADDRESS%EF%BC%8CSTATUS_REG)%20%26amp%3B%200x08%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EI2C_ReadMultiRegisters(MMA845x_I2C_ADDRESS%2C%20OUT_X_MSB_REG%2C%206%2C%20AccData)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%E8%AF%BB%E5%8F%96%E6%95%B0%E6%8D%AE%E8%BE%93%E5%87%BA%E5%AF%84%E5%AD%98%E5%99%A80x01-0x06%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EXout_14_bit%20%3D%20((%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3Eshort%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E)%20(AccData%5B0%5D%26lt%3B%26lt%3B8%20%7C%20AccData%5B1%5D))%20%26gt%3B%26gt%3B%202%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20%E8%AE%A1%E7%AE%97%2014%20%E4%BD%8D%20X%20%E8%BD%B4%E8%BE%93%E5%87%BA%E5%80%BC%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EYout_14_bit%20%3D%20((%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3Eshort%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E)%20(AccData%5B2%5D%26lt%3B%26lt%3B8%20%7C%20AccData%5B3%5D))%20%26gt%3B%26gt%3B%202%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20%E8%AE%A1%E7%AE%97%2014%20%E4%BD%8D%20Y%20%E8%BD%B4%E8%BE%93%E5%87%BA%E5%80%BC%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EZout_14_bit%20%3D%20((%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3Eshort%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E)%20(AccData%5B4%5D%26lt%3B%26lt%3B8%20%7C%20AccData%5B5%5D))%20%26gt%3B%26gt%3B%202%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20%E8%AE%A1%E7%AE%9714%E4%BD%8DZ%E8%BD%B4%E8%BE%93%E5%87%BA%E5%80%BC%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EXoffset%20%3D%20Xout_14_bit%20%2F%208%20*%20(-1)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%E8%AE%A1%E7%AE%97X%E8%BD%B4%E5%81%8F%E7%A7%BB%E6%A0%A1%E6%AD%A3%E5%80%BC%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EYoffset%20%3D%20Yout_14_bit%20%2F%208%20*%20(-1)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%E8%AE%A1%E7%AE%97Y%E8%BD%B4%E5%81%8F%E7%A7%BB%E6%A0%A1%E6%AD%A3%E5%80%BC%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EZoffset%20%3D%20(Zout_14_bit%20-%20SENSITIVITY_2G)%20%2F%208%20*%20(-1)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%E8%AE%A1%E7%AE%97Z%E8%BD%B4%E5%81%8F%E7%A7%BB%E6%A0%A1%E6%AD%A3%E5%80%BC%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EI2C_WriteRegister%EF%BC%88MMA845x_I2C_ADDRESS%EF%BC%8CCTRL_REG1%EF%BC%8C0x00%EF%BC%89%EF%BC%9B%3CSPAN%20style%3D%22color%3A%20%23ffffff%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20%E5%BE%85%E6%9C%BA%E6%A8%A1%E5%BC%8F%E5%85%81%E8%AE%B8%E5%86%99%E5%85%A5%E5%81%8F%E7%A7%BB%E5%AF%84%E5%AD%98%E5%99%A8%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EI2C_WriteRegister%EF%BC%88MMA845x_I2C_ADDRESS%EF%BC%8COFF_X_REG%EF%BC%8CXoffset%EF%BC%89%EF%BC%9B%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EI2C_WriteRegister%EF%BC%88MMA845x_I2C_ADDRESS%EF%BC%8COFF_Y_REG%EF%BC%8CY%E5%81%8F%E7%A7%BB%E9%87%8F%EF%BC%89%EF%BC%9B%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EI2C_WriteRegister%EF%BC%88MMA845x_I2C_ADDRESS%EF%BC%8COFF_Z_REG%EF%BC%8CZoffset%EF%BC%89%EF%BC%9B%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EI2C_WriteRegister(MMA845x_I2C_ADDRESS%2C%20CTRL_REG3%2C%200x00)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%E6%8E%A8%E6%8C%BD%EF%BC%8C%E4%BD%8E%E7%94%B5%E5%B9%B3%E6%9C%89%E6%95%88%E4%B8%AD%E6%96%AD%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EI2C_WriteRegister(MMA845x_I2C_ADDRESS%2C%20CTRL_REG4%2C%200x01)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%E5%90%AF%E7%94%A8DRDY%E4%B8%AD%E6%96%AD%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EI2C_WriteRegister(MMA845x_I2C_ADDRESS%2C%20CTRL_REG5%2C%200x01)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2FDRDY%E4%B8%AD%E6%96%AD%E8%B7%AF%E7%94%B1%E5%88%B0INT1%20-%20PTA14%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EI2C_WriteRegister(MMA845x_I2C_ADDRESS%2C%20CTRL_REG1%2C%200x3D)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20ODR%20%3D%201.56Hz%EF%BC%8C%E9%99%8D%E4%BD%8E%E5%99%AA%E9%9F%B3%EF%BC%8C%E4%B8%BB%E5%8A%A8%E6%A8%A1%E5%BC%8F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E4.%E5%9C%A8ISR%E4%B8%AD%EF%BC%8C%E4%BB%85%E6%B8%85%E9%99%A4%E4%B8%AD%E6%96%AD%E6%A0%87%E5%BF%97%E5%B9%B6%E8%AE%BE%E7%BD%AEDataReady%E5%8F%98%E9%87%8F%E4%BB%A5%E6%8C%87%E7%A4%BA%E6%96%B0%E6%95%B0%E6%8D%AE%E7%9A%84%E5%88%B0%E8%BE%BE%E3%80%82%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3E%E6%97%A0%E6%95%88%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%3CSTRONG%3EPORTA_IRQHandler%3C%2FSTRONG%3E%20%EF%BC%88%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EPORTA_PCR14%20%7C%3D%20PORT_PCR_ISF_MASK%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%E6%B8%85%E9%99%A4%E4%B8%AD%E6%96%AD%E6%A0%87%E5%BF%97%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%E6%95%B0%E6%8D%AE%E5%B0%B1%E7%BB%AA%3D1%EF%BC%9B%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E5.%20%E5%8A%A0%E9%80%9F%E5%BA%A6%E8%AE%A1%E5%AF%84%E5%AD%98%E5%99%A8%200x01%20%E2%80%93%200x06%20%E7%9A%84%E8%BE%93%E5%87%BA%E5%80%BC%E9%A6%96%E5%85%88%E8%BD%AC%E6%8D%A2%E4%B8%BA%E6%9C%89%E7%AC%A6%E5%8F%B7%E7%9A%84%2014%20%E4%BD%8D%E5%80%BC%EF%BC%8C%E7%84%B6%E5%90%8E%E8%BD%AC%E6%8D%A2%E4%B8%BA%20g%20%E7%9A%84%E5%AE%9E%E5%80%BC%E3%80%82%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3Eif%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E(DataReady)%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20%E6%96%B0%E7%9A%84%E4%B8%80%E7%BB%84%E6%95%B0%E6%8D%AE%E6%98%AF%E5%90%A6%E5%87%86%E5%A4%87%E5%A5%BD%E4%BA%86%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%7B%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%E6%95%B0%E6%8D%AE%E5%B0%B1%E7%BB%AA%3D0%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EI2C_ReadMultiRegisters(MMA845x_I2C_ADDRESS%2C%20OUT_X_MSB_REG%2C%206%2C%20AccData)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%E8%AF%BB%E5%8F%96%E6%95%B0%E6%8D%AE%E8%BE%93%E5%87%BA%E5%AF%84%E5%AD%98%E5%99%A80x01-0x06%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EXout_14_bit%20%3D%20((%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3Eshort%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E)%20(AccData%5B0%5D%26lt%3B%26lt%3B8%20%7C%20AccData%5B1%5D))%20%26gt%3B%26gt%3B%202%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20%E8%AE%A1%E7%AE%97%2014%20%E4%BD%8D%20X%20%E8%BD%B4%E8%BE%93%E5%87%BA%E5%80%BC%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EYout_14_bit%20%3D%20((%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3Eshort%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E)%20(AccData%5B2%5D%26lt%3B%26lt%3B8%20%7C%20AccData%5B3%5D))%20%26gt%3B%26gt%3B%202%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20%E8%AE%A1%E7%AE%97%2014%20%E4%BD%8D%20Y%20%E8%BD%B4%E8%BE%93%E5%87%BA%E5%80%BC%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EZout_14_bit%20%3D%20((%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3Eshort%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E)%20(AccData%5B4%5D%26lt%3B%26lt%3B8%20%7C%20AccData%5B5%5D))%20%26gt%3B%26gt%3B%202%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20%E8%AE%A1%E7%AE%9714%E4%BD%8DZ%E8%BD%B4%E8%BE%93%E5%87%BA%E5%80%BC%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EXout_g%20%3D%20((%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3Efloat%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E)%20Xout_14_bit)%20%2F%20SENSITIVITY_2G%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20%E8%AE%A1%E7%AE%97%20x%20%E8%BD%B4%E8%BE%93%E5%87%BA%E5%80%BC%EF%BC%88%E5%8D%95%E4%BD%8D%E4%B8%BA%20g%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EYout_g%20%3D%20((%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3Efloat%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E)%20Yout_14_bit)%20%2F%20%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20Consolas%3B%22%3ESENSITIVITY_2G%3C%2FSPAN%3E%20%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20%E8%AE%A1%E7%AE%97%20Y%20%E8%BD%B4%E8%BE%93%E5%87%BA%E5%80%BC%EF%BC%88%E5%8D%95%E4%BD%8D%E4%B8%BA%20g%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EZout_g%20%3D%20((%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3Efloat%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E)%20Zout_14_bit)%20%2F%20%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20Consolas%3B%22%3ESENSITIVITY_2G%3C%2FSPAN%3E%20%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20%E8%AE%A1%E7%AE%97%20g%20%E4%B8%AD%E7%9A%84%20Z%20%E8%BD%B4%E8%BE%93%E5%87%BA%E5%80%BC%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E6.%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%9C%A8%E8%B0%83%E8%AF%95%E8%A7%86%E8%A7%92%E5%8F%B3%E4%B8%8A%E8%A7%92%E7%9A%84%E2%80%9C%E5%8F%98%E9%87%8F%E2%80%9D%E7%AA%97%E5%8F%A3%E6%88%96%20FreeMASTER%20%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E4%B8%AD%E6%9F%A5%E7%9C%8B%E8%AE%A1%E7%AE%97%E5%87%BA%E7%9A%84%E5%80%BC%E3%80%82%E8%A6%81%E5%9C%A8%20FreeMASTER%20%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E4%B8%AD%E6%9F%A5%E7%9C%8B%2014%20%E4%BD%8D%E5%80%BC%E5%92%8C%E5%AE%9E%E9%99%85%E5%80%BC%EF%BC%8C%E9%A6%96%E5%85%88%E9%9C%80%E8%A6%81%E5%9C%A8%E6%82%A8%E7%9A%84%E8%AE%A1%E7%AE%97%E6%9C%BA%E4%B8%8A%E5%AE%89%E8%A3%85%E4%B8%80%E4%BA%9B%20USBDM%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E3%80%82%E5%AE%83%E4%BB%AC%E5%8F%AF%E4%BB%A5%E4%BB%8E%3CA%20href%3D%22http%3A%2F%2Fsourceforge.net%2Fprojects%2Fusbdm%2Ffiles%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3ESourceForge%3C%2FA%3E%E4%B8%8B%E8%BD%BD%E3%80%82Erich%20Styger%20%E5%9C%A8%3CA%20href%3D%22http%3A%2F%2Fmcuoneclipse.com%2F2013%2F04%2F27%2Fdebug-external-processors-with-usbdm-and-freedom-board%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E6%9C%AC%3C%2FA%3E%E6%95%99%E7%A8%8B%E4%B8%AD%E6%8F%8F%E8%BF%B0%E4%BA%86%E4%BB%96%E4%BB%AC%E7%9A%84%E5%AE%89%E8%A3%85%E3%80%82%E9%99%A4%E6%AD%A4%E4%B9%8B%E5%A4%96%EF%BC%8C%E9%9C%80%E8%A6%81%E5%B0%86%E6%8F%90%E4%BE%9B%E8%B0%83%E8%AF%95%E5%92%8C%E8%99%9A%E6%8B%9F%E4%B8%B2%E8%A1%8C%E7%AB%AF%E5%8F%A3%E7%9A%84USBDM_OpenSDA%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E5%8A%A0%E8%BD%BD%E5%88%B0FRDM-KL25Z%E6%9D%BF%E4%B8%8A%E7%9A%84MK20%E8%B0%83%E8%AF%95%E5%99%A8%E8%8A%AF%E7%89%87%E4%B8%AD%E3%80%82%E6%AD%A4%E5%AE%89%E8%A3%85%E9%81%B5%E5%BE%AA%E9%80%9A%E5%B8%B8%E7%9A%84FRDM-KL25Z%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E6%B5%81%E7%A8%8B%EF%BC%9A%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%E6%8B%94%E4%B8%8BFRDM-KL25Z%E6%9D%BF%E3%80%82%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%E6%8C%89%E4%BD%8F%20SW1%2FRST%20%E5%BC%80%E5%85%B3%EF%BC%8C%E6%8C%89%E4%B8%8B%20FRDM-KL25Z%20%E6%9D%BF%E4%B8%AD%E7%9A%84%E6%8F%92%E5%A4%B4%E3%80%82%E7%BB%BF%E8%89%B2%20LED%20%E5%BA%94%E5%BC%80%E5%A7%8B%E4%BB%A5%E5%A4%A7%E7%BA%A6%201Hz%20%E7%9A%84%E9%A2%91%E7%8E%87%E9%97%AA%E7%83%81%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%E6%89%93%E5%BC%80%E6%96%87%E4%BB%B6%E8%B5%84%E6%BA%90%E7%AE%A1%E7%90%86%E5%99%A8%E5%B9%B6%E6%89%BE%E5%88%B0%E7%8E%B0%E5%9C%A8%E5%87%BA%E7%8E%B0%E7%9A%84%20USB%20%E9%A9%B1%E5%8A%A8%E5%99%A8%E3%80%82%E5%AE%83%E7%9A%84%E9%A9%B1%E5%8A%A8%E5%99%A8%E5%90%8D%E7%A7%B0%E4%B8%BA%E2%80%9CBOOTLOADER%E2%80%9D%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%E5%B0%86%E6%96%87%E4%BB%B6%3CA%20href%3D%22http%3A%2F%2Fsourceforge.net%2Fprojects%2Fusbdm%2Ffiles%2FVersion%25204.10.4%2FInstallation%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EUSBDM_OpenSDA.sx%3C%2FA%3E%E6%8B%96%E5%88%B0%20USB%20%E9%A9%B1%E5%8A%A8%E5%99%A8%E5%B9%B6%E7%AD%89%E5%BE%85%E7%89%87%E5%88%BB%E3%80%82FRDM-KL25Z%20%E6%9D%BF%E4%B8%8A%E7%9A%84%20OpenSDA%20%E5%9B%BA%E4%BB%B6%E5%B0%86%E6%8A%8A%20USBDM%20%E5%9B%BA%E4%BB%B6%E7%BC%96%E7%A8%8B%E5%88%B0%E6%9D%BF%E4%B8%8A%E7%9A%84%20MK20%20%E8%B0%83%E8%AF%95%E5%99%A8%E8%8A%AF%E7%89%87%E4%B8%AD%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%22%3E%E7%A7%BB%E9%99%A4%E5%B9%B6%E9%87%8D%E6%96%B0%E6%8F%92%E5%85%A5%20FRDM-KL25Z%20%E6%9D%BF%E3%80%82%E8%AF%A5%E6%9D%BF%E7%8E%B0%E5%9C%A8%E5%B0%86%E6%98%BE%E7%A4%BA%E4%B8%BA%20USBDM%20%E8%AE%BE%E5%A4%87%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FRDM-KL25Z_MMA8451Q_BasicReadUsingInterrupt_HighResolution.JPG.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FRDM-KL25Z_MMA8451Q_BasicReadUsingInterrupt_HighResolution.JPG.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F111107i1CA47565276E10DB%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22FRDM-KL25Z_MMA8451Q_BasicReadUsingInterrupt_HighResolution.JPG.jpg%22%20alt%3D%22FRDM-KL25Z_MMA8451Q_BasicReadUsingInterrupt_HighResolution.JPG.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EFRDM-KL25Z_MMA8451Q_BasicReadUsingInterrupt_HighResolution.JPG.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FRDM-KL25Z_MMA8451Q_BasicReadUsingInterrupt_HighResolution_FreeMASTER.JPG.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FRDM-KL25Z_MMA8451Q_BasicReadUsingInterrupt_HighResolution_FreeMASTER.JPG.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F111108iE3BC30F1F001588A%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22FRDM-KL25Z_MMA8451Q_BasicReadUsingInterrupt_HighResolution_FreeMASTER.JPG.jpg%22%20alt%3D%22FRDM-KL25Z_MMA8451Q_BasicReadUsingInterrupt_HighResolution_FreeMASTER.JPG.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EFRDM-KL25Z_MMA8451Q_BasicReadUsingInterrupt_HighResolution_FreeMASTER.JPG.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E9%99%84%E4%BB%B6%E4%B8%AD%E6%82%A8%E5%8F%AF%E4%BB%A5%E6%89%BE%E5%88%B0%E7%94%A8%3C%2FSPAN%3E%3CA%20href%3D%22http%3A%2F%2Fwww.freescale.com%2Fwebapp%2Fsps%2Fsite%2Fprod_summary.jsp%3Fcode%3DCW-MCU10%22%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%20CW%20%E7%BC%96%E5%86%99%E7%9A%84%20MCU%20v10.5%3C%2FA%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%20%E4%BB%A5%E5%8F%8A%20FreeMASTER%20%E9%A1%B9%E7%9B%AE%E7%9A%84%20%E5%AE%8C%E6%95%B4%E6%BA%90%E4%BB%A3%E7%A0%81%20%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%E5%9B%A0%E6%AD%A4%EF%BC%8C%E8%AF%B7%E5%88%B6%E4%BD%9C%E5%AE%83%E3%80%81%E6%B5%8B%E8%AF%95%E5%AE%83%E5%B9%B6%E4%BF%9D%E6%8C%81%E8%81%94%E7%B3%BB...%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3ETomas%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1127268%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E5%8A%A0%E9%80%9F%E5%BA%A6%E4%BC%A0%E6%84%9F%E5%99%A8%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1127275%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AMMA8451Q%20-%20%E8%A3%B8%E6%9C%BA%E7%A4%BA%E4%BE%8B%E9%A1%B9%E7%9B%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1127275%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%97%A8%EF%BC%8C%E6%89%98%E9%A9%AC%E6%96%AF%EF%BC%8C%3CBR%20%2F%3E%E6%82%A8%E6%98%AF%E5%90%A6%E6%9C%89%E6%9C%BA%E4%BC%9A%E5%86%8D%E6%AC%A1%E4%B8%8A%E4%BC%A0%E6%82%A8%E7%9A%84%E9%A1%B9%E7%9B%AE%EF%BC%8C%E5%9B%A0%E4%B8%BA%E5%AE%83%E4%BB%AC%E4%B8%8D%E5%B9%B8%E4%BB%8E%20NXP%20%E7%BD%91%E7%AB%99%E4%B8%8A%E5%88%A0%E9%99%A4%E4%BA%86%E3%80%82%E4%BD%BF%E7%94%A8%20KL46Z%20%E5%9C%A8%20MMA8451Q%20%E4%B8%8A%E5%B7%A5%E4%BD%9C%E5%B9%B6%E9%81%87%E5%88%B0%E4%BA%86%E5%9B%B0%E9%9A%BE%E3%80%82%E5%B0%86%E6%88%91%E7%9A%84%E5%9C%B0%E5%9D%80%E5%8F%91%E9%80%81%E5%88%B0%20I2C%20%E5%90%8E%E6%97%A0%E6%B3%95%E6%94%B6%E5%88%B0%E7%A1%AE%E8%AE%A4%E3%80%82%E6%88%91%E5%B0%86%E9%9D%9E%E5%B8%B8%E6%84%9F%E6%BF%80%E3%80%82%E6%88%91%E7%9F%A5%E9%81%93%E6%82%A8%E5%8F%91%E5%B8%83%E8%BF%99%E7%AF%87%E6%96%87%E7%AB%A0%E5%B7%B2%E7%BB%8F%E5%BE%88%E4%B9%85%E4%BA%86%E3%80%82%3C%2FP%3E%3CH1%20style%3D%22color%3A%20%23646464%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20200%3B%20font-size%3A%202rem%3B%20margin%3A%200px%200px%2030px%3B%20padding%3A%200px%20300px%200px%200px%3B%22%20id%3D%22toc-hId-382542698%22%20id%3D%22toc-hId-1304035830%22%20id%3D%22toc-hId-1304035830%22%3E%3C%2FH1%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1127274%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AMMA8451Q%20-%20%E8%A3%B8%E6%9C%BA%E7%A4%BA%E4%BE%8B%E9%A1%B9%E7%9B%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1127274%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Tomas%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E6%97%A0%E6%B3%95%E8%A7%82%E5%AF%9F%20Freemaster%20%E4%B8%8A%E7%9A%84%E5%8F%98%E9%87%8F%EF%BC%88%E6%88%91%E6%98%AF%E8%BF%99%E4%B8%AA%E5%B7%A5%E5%85%B7%E7%9A%84%E6%96%B0%E6%89%8B%EF%BC%89%EF%BC%8C%E8%80%8C%E4%B8%94%E6%88%91%E6%B2%A1%E6%9C%89%E4%BB%8E%E4%BD%A0%E7%9A%84%E6%BA%90%E4%BB%A3%E7%A0%81%E4%B8%AD%E7%9C%8B%E5%88%B0%E5%AE%83%E7%9A%84%E5%BA%93%E3%80%81%E5%87%BD%E6%95%B0%E7%AD%89%EF%BC%8C%E9%82%A3%E4%B9%88%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E5%A6%82%E4%BD%95%E4%B8%8E%20Freemaster%20%E9%80%9A%E4%BF%A1%E4%BB%A5%E5%8F%8A%E5%A6%82%E4%BD%95%E5%B5%8C%E5%85%A5%E5%88%B0%E6%96%B0%E7%9A%84%E8%A3%B8%E6%9C%BA%E9%A1%B9%E7%9B%AE%E4%B8%AD%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1127273%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AMMA8451Q%20-%20%E8%A3%B8%E6%9C%BA%E7%A4%BA%E4%BE%8B%E9%A1%B9%E7%9B%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1127273%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%209pt%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%22%3EHi%20Martin%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%209pt%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%22%3E%E7%94%B1%E4%BA%8E%20FRDM-KL43Z%20%E6%9D%BF%E6%B2%A1%E6%9C%89%E4%B8%A4%E4%B8%AA%E9%80%9A%E4%BF%A1%E5%BC%95%E8%84%9A%EF%BC%88PTE24%20-%20I2C0%20SCL%20%E5%92%8C%20PTE25%20-%20I2C0%20SDA%EF%BC%89%E5%8F%AF%E4%BB%A5%E8%BD%BB%E6%9D%BE%E8%AE%BF%E9%97%AE%E4%BB%A5%E6%9F%A5%E7%9C%8B%3CSUP%3EI2C%3C%2FSUP%3E%E6%80%BB%E7%BA%BF%E4%B8%8A%E5%8F%91%E7%94%9F%E7%9A%84%E6%83%85%E5%86%B5%EF%BC%8C%E5%9B%A0%E6%AD%A4%E5%BE%88%E9%9A%BE%E8%AF%B4%E5%87%BA%E9%97%AE%E9%A2%98%E5%8F%AF%E8%83%BD%E5%87%BA%E5%9C%A8%E5%93%AA%E9%87%8C%E3%80%82MKL43Z256%20MCU%20%E5%9C%A8%20MCU%20v10.6%20%E7%9A%84%20CW%20%E4%B8%AD%E4%B8%8D%E5%8F%97%E6%94%AF%E6%8C%81%EF%BC%8C%E5%9B%A0%E6%AD%A4%E6%88%91%3CSPAN%20style%3D%22color%3A%20%23017bba%3B%20font-family%3A%20inherit%3B%20font-style%3A%20inherit%3B%22%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-106619%22%20target%3D%22_blank%22%3E%E4%BD%BF%E7%94%A8%20KSDK%201.2.0%20%E5%92%8C%20Processor%20Expert%20%E5%9C%A8%20KDS%203.0.0%3C%2FA%3E%E4%B8%AD%E5%88%9B%E5%BB%BA%E4%BA%86%E5%8F%A6%E4%B8%80%E4%B8%AA%E9%A1%B9%E7%9B%AE%E3%80%82%3C%2FSPAN%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%9C%A8%E6%88%91%E5%8E%9F%E6%9D%A5%E7%9A%84%E5%B8%96%E5%AD%90%E4%B8%8A%E9%9D%A2%E6%89%BE%E5%88%B0%E9%99%84%E4%BB%B6%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%209pt%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%22%3E%E5%B8%8C%E6%9C%9B%E6%9C%89%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%209pt%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%22%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%20color%3A%20%2351626f%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20inherit%3B%20font-size%3A%209pt%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%22%3ETomas%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1127272%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AMMA8451Q%20-%20%E8%A3%B8%E6%9C%BA%E7%A4%BA%E4%BE%8B%E9%A1%B9%E7%9B%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1127272%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Tomas%2C%3C%2FP%3E%3CP%3E%E6%88%91%E5%9C%A8%20FRDM%20KL43z%20%E4%B8%8A%E5%B0%9D%E8%AF%95%E4%BA%86%E6%82%A8%E7%9A%84%E4%BB%A3%E7%A0%81%E3%80%82%E5%AE%83%E5%92%8CKL25z%E7%9A%84%E5%8C%BA%E5%88%AB%E6%98%AF%E5%BC%95%E8%84%9AINT1%E6%98%AF%E5%BC%95%E8%84%9APTC5%E3%80%82%E6%88%91%E6%9C%80%E5%88%9D%E6%B5%8B%E8%AF%95%E4%BA%86%E9%80%9A%E4%BF%A1%EF%BC%8C%E5%9B%A0%E6%AD%A4%E6%88%91%E8%AF%BB%E5%8F%96%E4%BA%86%20WHOIAM%20%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%880x0D%EF%BC%89%EF%BC%8C%E4%BD%86%E8%BF%94%E5%9B%9E%E4%BA%86%E7%AC%A6%E5%8F%B7%200xFF%EF%BC%8C%E4%BD%86%E6%9C%89%E8%B6%A3%E7%9A%84%E6%98%AF%EF%BC%8C%E4%B8%80%E6%97%A6%E5%87%BD%E6%95%B0%E8%BF%94%E5%9B%9E%E6%AD%A3%E7%A1%AE%E7%9A%84%E5%AD%97%E7%AC%A6%200x1A%EF%BC%8C%E4%BD%86%E9%87%8D%E6%96%B0%E5%90%AF%E5%8A%A8%E5%90%8E%E5%86%8D%E6%AC%A1%E8%BF%94%E5%9B%9E%200xFF%E3%80%82%E5%93%AA%E9%87%8C%E5%8F%AF%E8%83%BD%E5%AD%98%E5%9C%A8%E9%97%AE%E9%A2%98%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1127271%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AMMA8451Q%20-%20%E8%A3%B8%E6%9C%BA%E7%A4%BA%E4%BE%8B%E9%A1%B9%E7%9B%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1127271%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Tomas%2C%3C%2FP%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%EF%BC%8C%E5%AE%83%E5%BE%88%E6%9C%89%E6%95%88%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%9F%A5%E5%85%B0%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1127270%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AMMA8451Q%20-%20%E8%A3%B8%E6%9C%BA%E7%A4%BA%E4%BE%8B%E9%A1%B9%E7%9B%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1127270%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8CCharan%EF%BC%8C%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E5%8F%AF%E8%83%BD%E4%BC%9A%E5%8F%91%E7%8E%B0%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fthread%2F317489%22%20target%3D%22_blank%22%3E%E6%AD%A4%E5%A4%84%3C%2FA%3E%E6%8F%90%E4%BE%9B%E7%9A%84%E5%B5%8C%E5%85%A5%E5%BC%8F%E7%9E%AC%E6%80%81%E6%A3%80%E6%B5%8B%E5%8A%9F%E8%83%BD%E7%9A%84%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%E5%BE%88%E6%9C%89%E7%94%A8%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%B8%8C%E6%9C%9B%E5%AF%B9%E6%82%A8%E6%9C%89%E6%89%80%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3ETomas%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1127269%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AMMA8451Q%20-%20%E8%A3%B8%E6%9C%BA%E7%A4%BA%E4%BE%8B%E9%A1%B9%E7%9B%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1127269%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%9C%A8%20KL25Z%20%E6%9D%BF%E4%B8%8A%E4%BD%BF%E7%94%A8%E5%B8%A6%E6%9C%89%20Code%20Warrior%2010.6%EF%BC%88%E5%A4%84%E7%90%86%E5%99%A8%E4%B8%93%E5%AE%B6%EF%BC%89%E7%9A%84%20MMA8451Q%E3%80%82%E6%88%91%E5%B7%B2%E7%BB%8F%E9%85%8D%E7%BD%AE%E4%BA%86%E7%9E%AC%E6%80%81%E6%A3%80%E6%B5%8B%E7%94%B5%E8%B7%AF%E6%9D%BF%EF%BC%8C%E4%BD%86%E5%BD%93%E6%8C%AF%E5%B9%85%E8%B6%85%E5%87%BA%E9%98%88%E5%80%BC%E6%B0%B4%E5%B9%B3%E6%97%B6%EF%BC%8C%E6%88%91%E6%97%A0%E6%B3%95%E4%BA%A7%E7%94%9F%E4%B8%AD%E6%96%AD%E3%80%82%E6%98%AF%E5%90%A6%E6%9C%89%E4%BB%BB%E4%BD%95%E7%BB%84%E4%BB%B6%E5%8F%AF%E4%BB%A5%E5%B8%AE%E5%8A%A9%E7%BC%96%E5%86%99%20PTA14%20%E4%B8%8A%E7%94%9F%E6%88%90%E7%9A%84%E4%B8%AD%E6%96%AD%E7%9A%84%20ISR%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%9F%A5%E5%85%B0%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎02-03-2026 05:19 PM
更新人:
