Freescale Sensor Fusion Pre-Release
The attached is a PRE-RELEASE copy of the next version of the Freescale Sensor Fusion Library for Kinetis MCUs.  It is a pre-release because we are still working to update the datasheet and userguide to accomodate new changes.  The datasheet and user guides included in this copy are identical to the current production versions found at http://www.freescale.com/sensorfusion.  This is the first release of the library which provides ALL SOURCE CODE.  The software license is unchanged from the prior release, and is re-produced at the end of this posting.  Please do not download the file if you can't agree to these license terms.
In order to get around virus filter on the community, I've had to create a simple zip file of the fusion toolkit.  There's no installer.  Just unzip it in your directory of choice.
Pre-Release Notes for Freescale Sensor Fusion Library for Kinetis MCUs
Previous production release: build 417
This release: build 420
This is a pre-release kit.  The included datasheet and user guide relate to the previous version (build 417).  Updates are in progress and will be published shortly.
In the meantime, changes (at a high level) are listed below.
Changes:
1.  Removed all license checking functions
2.  Fusion and magnetic calibration libraries are now included in source form.    libFusion.a is now gone.  It has been replaced by additional files in the Sources directory.
3.  Added template projects for Kinetis Design Studio
4.  Added KL46Z board support
5.  Community supported at https://community.freescale.com/community/sensors/sensorfusion
6.  The datasheet has been updated with simulated fusion metrics, code sizes and systick counts
7.  "FLASH_EU" target names have been changed to "FLASH"
8.  Changed branding from "Xtrinsic" to "Freescale".  This resulted in project prefixes  being changed from "XSFK_" to "FSFK_".
9.  Removed the Accelerometer + Magnetometer 6-axis Kalman filter (the eCompass implementation  is more efficient)
10. Debug packets are now on by default.  This enables the Sensor Fusion Toolkit for Android to startup with the correct board display on powerup.
11. The following source files have been renamed:
    FSL_utils.c/.h are now drivers.c/.h
    tasks_func.c/.h are now tasks.c/.h
    proj_config.h is now build.h
    ProcessorExpert.c is now main.c
    baranski_kalman.h is now kalman.h
12. license.h has been removed
13. Added bare metal eCompass implementation for KL46Z (no MQXLite)
14. This version will not include run configurations for all KDS projects. There are too many permutations, and the tools are being regularly updated.
Errata:
1.  Newer K64F Freedom boards can utilize several different versions of the OpenSDA interface.  The MBED drivers do not deal properly with flash security and can temporarily "brick" a board.  In order for the download function to work properly, the value of the NV_FSEC portion of the CPU_FLASH_CONFIG_FIELD within file name Generated_Files/CPU_Config.h must have a value of 0xFE.  Processor Expert (which generates this file) does not currently support that value.  You must make the change manually after running Processor Expert.
2.  When compiling for the first time in KDS, the tool may generate the following error message: "writing to APSR without specifying a bitmask".  This is an invalid error. Simply build a second time and the error will disappear.
3.  MQXLite 1.1.0 created via Processor Expert incorrectly handles contexts switches for the  floating point unit on the K64F.  As shipped, this does not present a problem because  floating point computations are normally completed within one sample period.  However if you add additional code to that project template, such that computations extend beyond one sample period, you will get incorrect results (there is no warning!). MQXLite 1.1.1 fixes this issue.  Check the MQX1 settings in Processor Expert to see which  version you are using.
4.  I2C transmission speeds are configured for 300KHz to 400KHz.   During the build process, it is normal to see the following:
    "Warning: The device is designed to operate up to 100kHz! (SCL frequency)".
    The development team routinely operates at higher I2C frequencies, although these are not necessarily guaranteed in the device datasheets.  Other warnings arise from the  MQXLite code generated by Processor Expert.  The actual fusion library is believed to be clean.
Xtrinsic Sensor Fusion Library for Kinetis MCUs
License: LA_OPT50 Version 20 January 2014
  1. IMPORTANT. Read the following Freescale Software License Agreement (“Agreement”) completely.  By selecting the “I Agree” button at the end of this page, you indicate that you accept the terms of this Agreement and you also acknowledge that you have the authority, on behalf of your company, to bind your company to such terms.  You may then download or install the file.
FREESCALE END-USER SOFTWARE LICENSE AGREEMENT
This is a license agreement between you (either as an individual or as an authorized representative acting on behalf of your employer) and Freescale Semiconductor, Inc. (“Freescale”). It concerns your rights to use software package and any accompanying written materials (the “Software”). The Software includes any updates or error corrections or documentation relating to the Software provided to you by Freescale under this License. In consideration for Freescale allowing you to access the Software, you are agreeing to be bound by the terms of this Agreement. If you do not agree to all of the terms of this Agreement, do not download or install the Software. If you change your mind later, stop using the Software and delete all copies of the Software in your possession or control. Any copies of the Software that you have already distributed, where permitted, and do not destroy will continue to be governed by this Agreement. Your prior use will also continue to be governed by this Agreement.
  1. 1.         LICENSE GRANT. Exclusively in conjunction with Licensee’s development and sale of a product containing Freescale Xtrinsic sensor solutions (e.g., an accelerometer, magnetometer, and a gyroscope in any discrete or combined form factor) supplied directly or indirectly from Freescale (“Freescale System”), or education programs relating to the use of a Freescale System, Freescale grants to you, free of charge, the non-exclusive, non-transferable right (1) to use the Software, (2) to reproduce the Software, (3) to prepare derivative works of the Software, (4) to distribute the Software and derivative works thereof in object (machine-readable) form as part of a Freescale System, and (5) to sublicense to others the right to use the distributed Software as included within the Freescale System. If you violate any of the terms or restrictions of this Agreement, Freescale may immediately terminate this Agreement, and require that you stop using and delete all copies of the Software in your possession or control.   Any license granted above only extends to Freescale’s intellectual property rights that would be necessarily infringed by the Software as provided to you by Freescale and as used within the scope of the licenses granted.  You must advise Freescale of any results obtained including any problems or suggested improvements thereof.  Freescale retains the right to use such results and related information in any manner it deems appropriate.
  2. 2.         OTHER RESTRICTIONS.  Subject to the license grant above, the following restrictions apply:
  3. a.         Freescale reserves all rights not expressly granted herein.
  4. b.         You may not rent, lease, sublicense, lend or encumber the Software, unless otherwise expressly agreed to within this Agreement
  5. c.         You may not distribute, manufacture, have manufactured, sublicense or otherwise reproduce the Software for purposes other than intended in this Agreement.
  6. d.         You may not remove or alter any proprietary legends, notices, or trademarks contained in the Licensed Software,
  7. e.         The terms and conditions of this Agreement will apply to any Software updates, provided to you at Freescale’s discretion, that replace and/or supplement the original Software, unless such update contains a separate license.
  8. f.          You may not translate, reverse engineer, decompile, or disassemble the Software provided to you solely in object code format (machine readable) except to the extent applicable law specifically prohibits such restriction.  You will prohibit your sublicensees from translating, reverse engineering, decompiling, or disassembling the Software except to the extent applicable law specifically prohibits such restriction.
  9. 3.         OPEN SOURCE.  Any open source software included in the Software licensed herein is not licensed under the terms of this Agreement, but is instead licensed under the terms of applicable open source license(s), such as the BSD License, Apache License or the Lesser GNU General Public License.  Your use of such open source software is subject to the terms of each applicable license.  You must agree to the terms of each such applicable license, or you should not use the open source software.
  10. 4.         COPYRIGHT.  The Software is licensed to you, not sold.  Freescale owns the Software, and United States copyright laws and international treaty provisions protect the Software. Therefore, you must treat the Software like any other copyrighted material (e.g. a book or musical recording). You may not use or copy the Software for any other purpose than what is described in this Agreement. Except as expressly provided herein, Freescale does not grant to you any express or implied rights under any Freescale or third party patents, copyrights, trademarks, or trade secrets. Additionally, you must reproduce and apply any copyright or other proprietary rights notices included on or embedded in the Software to any copies made thereof, in whole or in part, if any.  You may not remove any copyright notices of Freescale incorporated in the Software.
  11. 5.         TERM AND TERMINATION.   The term of this Agreement shall commence on the date of installation or download and shall be continue until terminated in accordance with this Agreement. Freescale has the right to terminate this Agreement without notice and require that you stop using and delete all copies of the Software in your possession or control if you violate any of the terms or restrictions of this Agreement.  Freescale may terminate this Agreement should any of the Software become, or in Freescale's reasonable opinion is likely to become, the subject of a claim of intellectual infringement or trade secret misappropriation.  Upon termination, you must cease use of and destroy, the Software and confirm compliance in writing to Freescale. Upon termination, the license granted pursuant to this Agreement immediately terminates and the provisions of Sections 4 through 18 will survive any termination of this Agreement.
  12. 6.         SUPPORT.  Freescale is NOT obligated to provide any support, upgrades or new releases of the Software. If you wish, you may contact Freescale and report problems and provide suggestions regarding the Software. Freescale has no obligation whatsoever to respond in any way to such a problem report or suggestion. Freescale may make changes to the Software at any time, without any obligation to notify or provide updated versions of the Software to you.
  13. 7.         NO WARRANTY.  TO THE MAXIMUM EXTENT PERMITTED BY LAW, FREESCALE EXPRESSLY DISCLAIMS ANY WARRANTY FOR THE SOFTWARE. THE SOFTWARE IS PROVIDED “AS IS”, WITHOUT WARRANTY OF ANY KIND, EITHER EXPRESS OR IMPLIED, INCLUDING, WITHOUT LIMITATION, THE IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE, OR NON-INFRINGEMENT. YOU ASSUME THE ENTIRE RISK ARISING OUT OF THE USE OR PERFORMANCE OF THE SOFTWARE, OR ANY SYSTEMS YOU DESIGN USING THE SOFTWARE (IF ANY). NOTHING IN THIS AGREEMENT MAY BE CONSTRUED AS A WARRANTY OR REPRESENTATION BY FREESCALE THAT THE SOFTWARE OR ANY DERIVATIVE WORK DEVELOPED WITH OR INCORPORATING THE SOFTWARE WILL BE FREE FROM INFRINGEMENT OF THE INTELLECTUAL PROPERTY RIGHTS OF THIRD PARTIES.
  14. 8.         INDEMNITY. You agree to fully defend and indemnify Freescale from any and all claims, liabilities, and costs (including reasonable attorney’s fees) related to (1) your use (including your sublicensee’s use, if permitted) of the Software or (2) your violation of the terms and conditions of this Agreement.
  15. 9.         LIMITATION OF LIABILITY.  IN NO EVENT WILL FREESCALE BE LIABLE, WHETHER IN CONTRACT, TORT, OR OTHERWISE, FOR ANY INCIDENTAL, SPECIAL, INDIRECT, CONSEQUENTIAL OR PUNITIVE DAMAGES, INCLUDING, BUT NOT LIMITED TO, DAMAGES FOR ANY LOSS OF USE, LOSS OF TIME, INCONVENIENCE, COMMERCIAL LOSS, OR LOST PROFITS, SAVINGS, OR REVENUES TO THE FULL EXTENT SUCH MAY BE DISCLAIMED BY LAW EVEN IF INFORMED IN ADVANCE OF THE POSSIBILITY OF SUCH DAMAGES.  FREESCALE’S LIABILITY WILL IN ANY EVENT AND UNDER ANY THEORY OF RECOVERY BE LIMITED TO THE TOTAL AMOUNT RECEIVED BY FREESCALE UNDER THIS AGREEMENT.
  16. 10.       COMPLIANCE WITH LAWS; EXPORT RESTRICTIONS. You must not resell, re-export, or provide, directly or indirectly, the licensed software or direct product thereof, in any form without obtaining appropriate export or re-export licenses from the United States Government and from the country from which the export or re-export is to occur.  An export occurs when products, technology, or software is transferred from one country to another by any means, including physical shipments, FTP file transfers, E-mails, faxes, remote server access, conversations, and the like.  An export also occurs when technology or software is transferred to a foreign national in the United States, or foreign national of the country in which the business activity is taking place.  A foreign national is any person who is neither a citizen nor permanent resident of the United States, or the country in which the business activity is taking place. Furthermore, if an export/import license, permit or other government required authority (collectively referred to as “government authorization”) is required to transfer technology, software, hardware or other Freescale property to non- Freescale party(ies) and is not approved, then Freescale is not obligated to transfer the Software under this Agreement until such “government authorization” is granted..
  17. 11.       GOVERNMENT RIGHTS.  The Licensed Software is a “Commercial Item” as defined in 48 C.F.R. §2.101, consisting of “Commercial Computer Software” and “Commercial Computer Software Documentation,” as such terms are used in 48 C.F.R. § 12.212 or 48 C.F.R. §227.7202, as applicable and are only licensed to U.S. Government end users with the rights as are set forth herein..
  18. 12.       HIGH RISK ACTIVITIES.  You acknowledge that the Software is not fault tolerant and is not designed, manufactured or intended by Freescale for incorporation into products intended for use or resale in on-line control equipment in hazardous, dangerous to life or potentially life-threatening environments requiring fail-safe performance, such as in the operation of nuclear facilities, aircraft navigation or communication systems, air traffic control, direct life support machines or weapons systems, in which the failure of products could lead directly to death, personal injury or severe physical or environmental damage (“High Risk Activities”). You specifically represent and warrant that you will not use the Software or any derivative work of the Software for High Risk Activities.
  19. 13.       CHOICE OF LAW; VENUE; LIMITATIONS.  You agree that the statutes and laws of the United States and the State of Texas, USA, without regard to conflicts of laws principles, will apply to all matters relating to this Agreement or the Software, and you agree that any litigation will be subject to the exclusive jurisdiction of the state or federal courts in Texas, USA.  You agree that regardless of any statute or law to the contrary, any claim or cause of action arising out of or related to this Agreement or the Software must be filed within one (1) year after such claim or cause of action arose or be forever barred.
  20. 14.       CONFIDENTIAL INFORMATION.  You must treat the Software as confidential information and you agree to retain the Software in confidence perpetually, with respect to Software in source code form (human readable), or for a period of five (5) years from the date of termination of this Agreement, with respect to all other parts of the Software.  During this period you may not disclose any part of the Software to anyone other than employees who have a need to know of the Software and who have executed written agreements obligating them to protect such Licensed Software to at least the same degree of care as in this Agreement.  You agree to use the same degree of care, but no less than a reasonable degree of care, with the Software as you do with your own confidential information. You may disclose Software to the extent required by a court or under operation of law or order provided that you notify Freescale of such requirement prior to disclosure, which you only disclose information required, and that you allow Freescale the opportunity to object to such court or other legal body requiring such disclosure.
  21. 15.       PRODUCT LABELING.  You are not authorized to use any Freescale trademarks, brand names, or logos.
  22. 16.       ENTIRE AGREEMENT.  This Agreement constitutes the entire agreement between you and Freescale regarding the subject matter of this Agreement, and supersedes all prior communications, negotiations, understandings, agreements or representations, either written or oral, if any.  This Agreement may only be amended in written form, executed by you and Freescale.
  23. 17.       SEVERABILITY.  If any provision of this Agreement is held for any reason to be invalid or unenforceable, then the remaining provisions of this Agreement will be unimpaired and, unless a modification or replacement of the invalid or unenforceable provision is further held to deprive you or Freescale of a material benefit, in which case the Agreement will immediately terminate, the invalid or unenforceable provision will be replaced with a provision that is valid and enforceable and that comes closest to the intention underlying the invalid or unenforceable provision.
  24. 18.       NO WAIVER.  The waiver by Freescale of any breach of any provision of this Agreement will not operate or be construed as a waiver of any other or a subsequent breach of the same or a different provision.
    © 2004-2014 Freescale Semiconductor, Inc. All rights reserved.
添付
コメント
Are there plans for releasing the library for Non-Windows KDS implemetations?
%3CLINGO-SUB%20id%3D%22lingo-sub-1107197%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%83%BB%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BB%E3%83%95%E3%83%A5%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%83%BB%E3%83%97%E3%83%AC%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1107197%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%B7%BB%E4%BB%98%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%AF%E3%80%81Kinetis%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E7%94%A8%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%83%BB%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BB%E3%83%95%E3%83%A5%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%83%BB%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%AE%E6%AC%A1%E6%9C%9F%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AE%E3%83%97%E3%83%AC%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E7%89%88%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%83%97%E3%83%AC%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E7%89%88%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E6%96%B0%E3%81%97%E3%81%84%E5%A4%89%E6%9B%B4%E3%81%AB%E5%AF%BE%E5%BF%9C%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%81%A8%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%AC%E3%82%A4%E3%83%89%E3%81%AE%E6%9B%B4%E6%96%B0%E3%81%AB%E3%81%BE%E3%81%A0%E5%8F%96%E3%82%8A%E7%B5%84%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%82%B3%E3%83%94%E3%83%BC%E3%81%AB%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%81%A8%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%AC%E3%82%A4%E3%83%89%E3%81%AF%E3%80%81%20%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fhttp%3A%2F%2Fwww.freescale.com%2Fsensorfusion%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwww.freescale.com%2Fsensorfusion%3C%2FA%3E%20%E3%81%AB%E3%81%82%E3%82%8B%E7%8F%BE%E5%9C%A8%E3%81%AE%E8%A3%BD%E5%93%81%E7%89%88%E3%81%A8%E5%90%8C%E3%81%98%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%99%E3%82%8B%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%AE%E6%9C%80%E5%88%9D%E3%81%AE%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%A7%E3%81%99%E3%80%82%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%81%AF%E4%BB%A5%E5%89%8D%E3%81%AE%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%8B%E3%82%89%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%81%A6%E3%81%8A%E3%82%89%E3%81%9A%E3%80%81%E3%81%93%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%AE%E6%9C%80%E5%BE%8C%E3%81%AB%E5%86%8D%E7%94%9F%E7%94%A3%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E6%9D%A1%E9%A0%85%E3%81%AB%E5%90%8C%E6%84%8F%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%AA%E3%81%84%E3%81%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%E3%81%AE%E3%82%A6%E3%82%A4%E3%83%AB%E3%82%B9%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BF%E3%83%BC%E3%82%92%E5%9B%9E%E9%81%BF%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E7%A7%81%E3%81%AF%E3%83%95%E3%83%A5%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%83%84%E3%83%BC%E3%83%AB%E3%82%AD%E3%83%83%E3%83%88%E3%81%AE%E7%B0%A1%E5%8D%98%E3%81%AAzip%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%A9%E3%83%BC%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%9F%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AB%E8%A7%A3%E5%87%8D%E3%81%99%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSTRONG%3EKinetis%20MCU%E5%90%91%E3%81%91%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%83%BB%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BB%E3%83%95%E3%83%A5%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%83%BB%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%AE%E3%83%97%E3%83%AC%E3%83%BB%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%83%BB%E3%83%8E%E3%83%BC%E3%83%88%3C%2FSTRONG%3E%3CBR%20%2F%3E%E4%BB%A5%E5%89%8D%E3%81%AE%E8%A3%BD%E5%93%81%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%3A%20%E3%83%93%E3%83%AB%E3%83%89%20417%3CBR%20%2F%3E%E3%81%93%E3%81%AE%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%3A%20%E3%83%93%E3%83%AB%E3%83%89%20420%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%A1%E3%82%89%E3%81%AF%E3%83%97%E3%83%AC%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%AD%E3%83%83%E3%83%88%E3%81%A7%E3%81%99%E3%80%82%E4%BB%98%E5%B1%9E%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%81%A8%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%20%E3%82%AC%E3%82%A4%E3%83%89%E3%81%AF%E3%80%81%E4%BB%A5%E5%89%8D%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%20(%E3%83%93%E3%83%AB%E3%83%89%20417)%20%E3%81%AB%E9%96%A2%E9%80%A3%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E6%9B%B4%E6%96%B0%E3%81%AF%E9%80%B2%E8%A1%8C%E4%B8%AD%E3%81%A7%E3%80%81%E3%81%BE%E3%82%82%E3%81%AA%E3%81%8F%E5%85%AC%E9%96%8B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%81%9D%E3%82%8C%E3%81%BE%E3%81%A7%E3%81%AE%E9%96%93%E3%80%81(%E5%A4%A7%E3%81%BE%E3%81%8B%E3%81%AB)%E5%A4%89%E6%9B%B4%E7%82%B9%E3%82%92%E4%BB%A5%E4%B8%8B%E3%81%AB%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E5%A4%89%E9%81%B7%EF%BC%9A%3CBR%20%2F%3E1.%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E6%A9%9F%E8%83%BD%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E2.%20Fusion%E3%81%8A%E3%82%88%E3%81%B3%E7%A3%81%E6%B0%97%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%8C%E3%82%BD%E3%83%BC%E3%82%B9%E5%BD%A2%E5%BC%8F%E3%81%AB%E5%90%AB%E3%81%BE%E3%82%8C%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82libFusion.a%20%E3%81%AF%E3%81%AA%E3%81%8F%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81Sources%20%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E5%86%85%E3%81%AE%E8%BF%BD%E5%8A%A0%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E7%BD%AE%E3%81%8D%E6%8F%9B%E3%81%88%E3%82%89%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E3.%20Kinetis%20Design%20Studio%E3%81%AE%E3%83%86%E3%83%B3%E3%83%97%E3%83%AC%E3%83%BC%E3%83%88%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E8%BF%BD%E5%8A%A0%3CBR%20%2F%3E4.%20KL46Z%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E8%BF%BD%E5%8A%A0%3CBR%20%2F%3E5.%20%3CA%20_jive_internal%3D%22true%22%20class%3D%22jivecontainerTT-hover-container%20jive-link-community-small%22%20data-containerid%3D%2211146%22%20data-containertype%3D%2214%22%20data-objectid%3D%2211236%22%20data-objecttype%3D%2214%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fcommunity%2Fsensors%2Fsensorfusion%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fcommunity%2Fsensors%2Fsensorfusion%3C%2FA%3E%20%E3%81%A7%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%82%8B%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%3CBR%20%2F%3E6.%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%81%8C%E6%9B%B4%E6%96%B0%E3%81%95%E3%82%8C%E3%80%81%E3%82%B7%E3%83%9F%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%95%E3%82%8C%E3%81%9F%E3%83%95%E3%83%A5%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%83%A1%E3%83%88%E3%83%AA%E3%82%AF%E3%82%B9%E3%80%81%E3%82%B3%E3%83%BC%E3%83%89%E3%82%B5%E3%82%A4%E3%82%BA%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%E3%82%B5%E3%82%A4%E3%82%B9%E3%83%86%E3%82%A3%E3%83%83%E3%82%AF%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%E3%81%8C%E8%BF%BD%E5%8A%A0%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E7.%20%E3%80%8CFLASH_EU%E3%80%8D%E3%81%AE%E5%AF%BE%E8%B1%A1%E5%90%8D%E3%82%92%E3%80%8CFLASH%E3%80%8D%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E8.%20%E3%83%96%E3%83%A9%E3%83%B3%E3%83%89%E3%82%92%E3%80%8CXtrinsic%E3%80%8D%E3%81%8B%E3%82%89%E3%80%8CFreescale%E3%80%8D%E3%81%AB%E5%A4%89%E6%9B%B4%E3%80%82%E3%81%93%E3%82%8C%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AE%E6%8E%A5%E9%A0%AD%E8%BE%9E%E3%81%8C%20%22XSFK_%22%20%E3%81%8B%E3%82%89%20%22FSFK_%22%20%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E9.%E5%8A%A0%E9%80%9F%E5%BA%A6%E8%A8%88%2B%E7%A3%81%E5%8A%9B%E8%A8%88%E3%81%AE6%E8%BB%B8%E3%82%AB%E3%83%AB%E3%83%9E%E3%83%B3%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BF%E3%83%BC%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F(eCompass%E3%81%AE%E5%AE%9F%E8%A3%85%E3%81%AF%E3%82%88%E3%82%8A%E5%8A%B9%E7%8E%87%E7%9A%84%E3%81%A7%E3%81%99)%3CBR%20%2F%3E10.%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%83%91%E3%82%B1%E3%83%83%E3%83%88%E3%81%8C%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%A7%E3%82%AA%E3%83%B3%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%82%8C%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81Sensor%20Fusion%20Toolkit%20for%20Android%20%E3%81%AF%E3%80%81%E9%9B%BB%E6%BA%90%E6%8A%95%E5%85%A5%E6%99%82%E3%81%AB%E6%AD%A3%E3%81%97%E3%81%84%E3%83%9C%E3%83%BC%E3%83%89%20%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%A7%E8%B5%B7%E5%8B%95%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E11.%E6%AC%A1%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E5%90%8D%E5%89%8D%E3%81%8C%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3EFSL_utils.c%2F.h%20%E3%81%AF%20drivers.c%2F.h%20%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Etasks_func.c%2F.h%20%E3%81%AF%20tasks.c%2F.h%20%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Eproj_config.h%20%E3%81%AF%20build.h%20%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3BProcessorExpert.c%20%E3%81%AF%20main.c%20%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3Bbaranski_kalman.h%20%E3%81%AF%20kalman.h%20%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E12.%20%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9.h%E5%89%8A%E9%99%A4%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E13.KL46Z%E7%94%A8%E3%81%AE%E3%83%99%E3%82%A2%E3%83%A1%E3%82%BF%E3%83%ABeCompass%E5%AE%9F%E8%A3%85%E3%82%92%E8%BF%BD%E5%8A%A0(MQXLite%E3%81%AA%E3%81%97)%3CBR%20%2F%3E14.%E3%81%93%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AB%E3%81%AF%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%20KDS%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AE%E5%AE%9F%E8%A1%8C%E6%A7%8B%E6%88%90%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%8F%E3%81%91%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E9%A0%86%E5%88%97%E3%81%8C%E5%A4%9A%E3%81%99%E3%81%8E%E3%81%A6%E3%80%81%E3%83%84%E3%83%BC%E3%83%AB%E3%81%AF%E5%AE%9A%E6%9C%9F%E7%9A%84%E3%81%AB%E6%9B%B4%E6%96%B0%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E6%AD%A3%E8%AA%A4%E8%A1%A8%EF%BC%9A%3CBR%20%2F%3E1.%20%E6%96%B0%E3%81%97%E3%81%84K64F%20Freedom%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AF%E3%80%81OpenSDA%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%AE%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E7%95%B0%E3%81%AA%E3%82%8B%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E5%88%A9%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82MBED%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AF%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%E3%82%BB%E3%82%AD%E3%83%A5%E3%83%AA%E3%83%86%E3%82%A3%E3%82%92%E9%81%A9%E5%88%87%E3%81%AB%E5%87%A6%E7%90%86%E3%81%9B%E3%81%9A%E3%80%81%E4%B8%80%E6%99%82%E7%9A%84%E3%81%AB%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%20%22%E3%83%96%E3%83%AA%E3%83%83%E3%82%AF%22%20%E3%81%99%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E6%A9%9F%E8%83%BD%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E6%A9%9F%E8%83%BD%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%81%AF%E3%80%81%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E5%90%8D%20Generated_Files%2FCPU_Config.h%20%E5%86%85%E3%81%AECPU_FLASH_CONFIG_FIELD%E3%81%AE%20NV_FSEC%20%E9%83%A8%E5%88%86%E3%81%AE%E5%80%A4%E3%81%8C%200xFE%20%E3%81%A7%E3%81%82%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82Processor%20Expert%20(%E3%81%93%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E7%94%9F%E6%88%90%E3%81%99%E3%82%8B)%20%E3%81%AF%E3%80%81%E7%8F%BE%E5%9C%A8%E3%81%9D%E3%81%AE%E5%80%A4%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82Processor%20Expert%20%E3%81%AE%E5%AE%9F%E8%A1%8C%E5%BE%8C%E3%81%AB%E3%80%81%E6%89%8B%E5%8B%95%E3%81%A7%E5%A4%89%E6%9B%B4%E3%82%92%E8%A1%8C%E3%81%86%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E2.%20KDS%20%E3%81%A7%E5%88%9D%E3%82%81%E3%81%A6%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%80%8C%E3%83%93%E3%83%83%E3%83%88%E3%83%9E%E3%82%B9%E3%82%AF%E3%82%92%E6%8C%87%E5%AE%9A%E3%81%9B%E3%81%9A%E3%81%AB%20APSR%20%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%E3%80%8D%E3%81%A8%E3%81%84%E3%81%86%E3%82%A8%E3%83%A9%E3%83%BC%20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E7%84%A1%E5%8A%B9%E3%81%AA%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%A7%E3%81%99%E3%80%822%E5%9B%9E%E7%9B%AE%E3%81%AB%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AF%E6%B6%88%E3%81%88%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E3.%20MQXLite%201.1.0Processor%20Expert%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E4%BD%9C%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%E3%80%81K64F%E3%81%AE%E6%B5%AE%E5%8B%95%E5%B0%8F%E6%95%B0%E7%82%B9%E3%83%A6%E3%83%8B%E3%83%83%E3%83%88%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%86%E3%82%AD%E3%82%B9%E3%83%88%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E5%87%A6%E7%90%86%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E5%87%BA%E8%8D%B7%E6%99%82%E3%81%AB%E3%81%AF%E3%80%81%E6%B5%AE%E5%8B%95%E5%B0%8F%E6%95%B0%E7%82%B9%E8%A8%88%E7%AE%97%E3%81%AF%E9%80%9A%E5%B8%B8%201%20%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E6%9C%9F%E9%96%93%E5%86%85%E3%81%AB%E5%AE%8C%E4%BA%86%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E5%95%8F%E9%A1%8C%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E3%81%9D%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%20%E3%83%86%E3%83%B3%E3%83%97%E3%83%AC%E3%83%BC%E3%83%88%E3%81%AB%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%A6%E3%80%81%E8%A8%88%E7%AE%97%E3%81%8C%201%20%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E6%9C%9F%E9%96%93%E3%82%92%E8%B6%85%E3%81%88%E3%82%8B%E3%81%A8%E3%80%81%E8%AA%A4%E3%81%A3%E3%81%9F%E7%B5%90%E6%9E%9C%E3%81%8C%E5%BE%97%E3%82%89%E3%82%8C%E3%81%BE%E3%81%99%20(%E8%AD%A6%E5%91%8A%E3%81%AF%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93)%E3%80%82MQXLite%201.1.1%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82Processor%20Expert%E3%81%AEMQX1%E8%A8%AD%E5%AE%9A%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%80%81%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E4.%20I2C%E4%BC%9D%E9%80%81%E9%80%9F%E5%BA%A6%E3%81%AF300KHz%E3%81%8B%E3%82%89400KHz%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%93%E3%83%AB%E3%83%89%20%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E4%B8%AD%E3%81%AB%E3%80%81%E6%AC%A1%E3%81%AE%E7%82%B9%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%82%8B%E3%81%AE%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%80%8C%E8%AD%A6%E5%91%8A%3A%E3%81%93%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AF%E6%9C%80%E5%A4%A7100kHz%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E8%A8%AD%E8%A8%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82(SCL%E5%91%A8%E6%B3%A2%E6%95%B0)%E3%80%8D%E3%80%82%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%E9%96%8B%E7%99%BA%E3%83%81%E3%83%BC%E3%83%A0%E3%81%AF%E6%97%A5%E5%B8%B8%E7%9A%84%E3%81%AB%E3%82%88%E3%82%8A%E9%AB%98%E3%81%84I2C%E5%91%A8%E6%B3%A2%E6%95%B0%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AF%E5%BF%85%E3%81%9A%E3%81%97%E3%82%82%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%81%A7%E4%BF%9D%E8%A8%BC%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%8F%E3%81%91%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%9D%E3%81%AE%E4%BB%96%E3%81%AE%E8%AD%A6%E5%91%8A%E3%81%AF%E3%80%81Processor%20Expert%20%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%20MQXLite%20%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8B%E3%82%89%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E5%AE%9F%E9%9A%9B%E3%81%AE%E8%9E%8D%E5%90%88%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%AF%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%81%A7%E3%81%82%E3%82%8B%E3%81%A8%E8%80%83%E3%81%88%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20align%3D%22center%22%20style%3D%22text-align%3A%20center%3B%20margin-bottom%3A%2012pt%3B%22%3E%3CSPAN%20class%3D%22grame%22%20style%3D%22color%3A%20black%3B%20font-size%3A%2010pt%3B%22%3E%3CSTRONG%3EKinetis%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E7%94%A8Xtrinsic%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BB%E3%83%95%E3%83%A5%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%83%BB%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%2012pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2010pt%3B%22%3E%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%3A%20LA_OPT50%20Version%2020%20January%202014%3C%2FSPAN%3E%3C%2FP%3E%3COL%20style%3D%22list-style-type%3A%20upper-roman%3B%22%3E%3CLI%3E%3CSPAN%20class%3D%22grame%22%20style%3D%22color%3A%20black%3B%20font-size%3A%2010pt%3B%22%3E%3CSTRONG%3E%E5%A4%A7%E4%BA%8B%E3%81%AA%E3%80%82%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2010pt%3B%20font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E%3CSTRONG%3E%20%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%83%BB%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%BB%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E5%A5%91%E7%B4%84%20(%E4%BB%A5%E4%B8%8B%E3%80%8C%E6%9C%AC%E5%A5%91%E7%B4%84%E3%80%8D)%20%E3%82%92%E3%82%88%E3%81%8F%E3%81%8A%E8%AA%AD%E3%81%BF%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%20%E3%81%93%E3%81%AE%E3%83%9A%E3%83%BC%E3%82%B8%E3%81%AE%E6%9C%80%E5%BE%8C%E3%81%AB%E3%81%82%E3%82%8B%E3%80%8C%E5%90%8C%E6%84%8F%E3%81%99%E3%82%8B%E3%80%8D%E3%83%9C%E3%82%BF%E3%83%B3%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AF%E6%9C%AC%E5%A5%91%E7%B4%84%E3%81%AE%E6%9D%A1%E4%BB%B6%E3%81%AB%E5%90%8C%E6%84%8F%E3%81%97%E3%80%81%E3%81%BE%E3%81%9F%E3%80%81%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AE%E4%BC%9A%E7%A4%BE%E3%82%92%E4%BB%A3%E8%A1%A8%E3%81%97%E3%81%A6%E3%80%81%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AE%E4%BC%9A%E7%A4%BE%E3%82%92%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E6%9D%A1%E4%BB%B6%E3%81%AB%E6%8B%98%E6%9D%9F%E3%81%99%E3%82%8B%E6%A8%A9%E9%99%90%E3%82%92%E6%9C%89%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E8%AA%8D%E3%82%81%E3%81%9F%E3%81%93%E3%81%A8%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%20%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%BE%E3%81%9F%E3%81%AF%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%20align%3D%22center%22%20style%3D%22text-align%3A%20center%3B%20margin-bottom%3A%2012pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2010pt%3B%20text-decoration%3A%20underline%3B%20font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%83%BB%E3%82%A8%E3%83%B3%E3%83%89%E3%83%BB%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BB%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%BB%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E5%A5%91%E7%B4%84%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%2012pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%20color%3A%20black%3B%20font-size%3A%2010pt%3B%22%3E%E6%9C%AC%E5%A5%91%E7%B4%84%E3%81%AF%E3%80%81%E3%81%8A%E5%AE%A2%E6%A7%98%20(%E5%80%8B%E4%BA%BA%E3%81%BE%E3%81%9F%E3%81%AF%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AE%E9%9B%87%E7%94%A8%E4%B8%BB%E3%81%AE%E4%BB%A3%E7%90%86%E4%BA%BA)%20%E3%81%A8%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%83%BB%E3%82%BB%E3%83%9F%E3%82%B3%E3%83%B3%E3%83%80%E3%82%AF%E3%82%BF%E3%83%BC%E3%83%BB%E3%82%A4%E3%83%B3%E3%82%AF%20(%E4%BB%A5%E4%B8%8B%E3%80%8C%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%80%8D)%20%E3%81%A8%E3%81%AE%E9%96%93%E3%81%A7%E7%B7%A0%E7%B5%90%E3%81%95%E3%82%8C%E3%82%8B%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E5%A5%91%E7%B4%84%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%8A%E3%82%88%E3%81%B3%E4%BB%98%E9%9A%8F%E3%81%99%E3%82%8B%E6%9B%B8%E9%9D%A2%E8%B3%87%E6%96%99(%E4%BB%A5%E4%B8%8B%E3%80%8C%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%80%8D)%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AE%E6%A8%A9%E5%88%A9%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E3%82%82%E3%81%AE%E3%81%A7%E3%81%99%E3%80%82%E6%9C%AC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AB%E3%81%AF%E3%80%81%E6%9C%AC%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%8B%E3%82%89%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AB%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%82%8B%E6%9C%AC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AB%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E6%9B%B4%E6%96%B0%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%E4%BF%AE%E6%AD%A3%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%8C%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AB%E6%9C%AC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%B8%E3%81%AE%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%82%92%E8%A8%B1%E5%8F%AF%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E8%80%83%E6%85%AE%E3%81%97%E3%81%A6%E3%80%81%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AF%E6%9C%AC%E5%A5%91%E7%B4%84%E3%81%AE%E6%9D%A1%E9%A0%85%E3%81%AB%E6%8B%98%E6%9D%9F%E3%81%95%E3%82%8C%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E5%90%8C%E6%84%8F%E3%81%99%E3%82%8B%E3%82%82%E3%81%AE%E3%81%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E6%9C%AC%E5%A5%91%E7%B4%84%E3%81%AE%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E6%9D%A1%E9%A0%85%E3%81%AB%E5%90%8C%E6%84%8F%E3%81%97%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E6%9C%AC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%BE%E3%81%9F%E3%81%AF%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%20%3CSPAN%20class%3D%22grame%22%3E%E3%81%97%E3%81%AA%E3%81%84%E3%81%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FSPAN%3E%20%E3%80%82%E5%BE%8C%E3%81%A7%E6%B0%97%E3%81%8C%E5%A4%89%E3%82%8F%E3%81%A3%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E4%BD%BF%E7%94%A8%E3%82%92%E4%B8%AD%E6%AD%A2%E3%81%97%E3%80%81%E6%89%80%E6%9C%89%E3%81%BE%E3%81%9F%E3%81%AF%E7%AE%A1%E7%90%86%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%B3%E3%83%94%E3%83%BC%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%8C%E6%97%A2%E3%81%AB%E9%85%8D%E5%B8%83%E3%81%97%E3%80%81%E8%A8%B1%E5%8F%AF%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E7%A0%B4%E6%A3%84%E3%81%97%E3%81%AA%E3%81%84%E6%9C%AC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E3%82%B3%E3%83%94%E3%83%BC%E3%81%AF%E3%80%81%E5%BC%95%E3%81%8D%E7%B6%9A%E3%81%8D%E6%9C%AC%E5%A5%91%E7%B4%84%E3%81%AB%E6%BA%96%E6%8B%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AE%E5%BE%93%E5%89%8D%E3%81%AE%E4%BD%BF%E7%94%A8%E3%82%82%E3%80%81%E5%BC%95%E3%81%8D%E7%B6%9A%E3%81%8D%E6%9C%AC%E5%A5%91%E7%B4%84%E3%81%AB%E6%BA%96%E6%8B%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3COL%20style%3D%22list-style-type%3A%20decimal%3B%22%3E%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%20font-size%3A%2010pt%3B%22%3E1.%20%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%81%AE%E4%BB%98%E4%B8%8E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%E3%80%82%3C%2FSPAN%3E%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B7%E3%83%BC%E3%81%8C%E3%80%81%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%8B%E3%82%89%E7%9B%B4%E6%8E%A5%E7%9A%84%E3%81%BE%E3%81%9F%E3%81%AF%E9%96%93%E6%8E%A5%E7%9A%84%E3%81%AB%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%82%8B%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%20%3CSPAN%20class%3D%22spelle%22%3E%E3%81%AEXtrinsic%3C%2FSPAN%3E%20%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BB%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20(%E5%8A%A0%E9%80%9F%E5%BA%A6%E8%A8%88%E3%80%81%E7%A3%81%E5%8A%9B%E8%A8%88%E3%80%81%E3%83%87%E3%82%A3%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%88%E3%81%BE%E3%81%9F%E3%81%AF%E8%A4%87%E5%90%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%83%BB%E3%83%95%E3%82%A1%E3%82%AF%E3%82%BF%E3%81%AE%E3%82%B8%E3%83%A3%E3%82%A4%E3%83%AD%E3%83%BB%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%97%E3%81%AA%E3%81%A9)%20%E3%82%92%E5%90%AB%E3%82%80%E8%A3%BD%E5%93%81%20(%E4%BB%A5%E4%B8%8B%E3%80%8C%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%83%BB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%80%8D%E3%81%A8%E3%81%84%E3%81%84%E3%81%BE%E3%81%99)%20%E3%82%92%E9%96%8B%E7%99%BA%E3%81%8A%E3%82%88%E3%81%B3%E8%B2%A9%E5%A3%B2%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%83%BB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AE%E4%BD%BF%E7%94%A8%E3%81%AB%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%E6%95%99%E8%82%B2%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%AE%E9%96%8B%E7%99%BA%E3%81%8A%E3%82%88%E3%81%B3%E8%B2%A9%E5%A3%B2%E3%81%AB%E9%96%A2%E9%80%A3%E3%81%97%E3%81%A6%E3%80%81%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AF%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AB%E7%84%A1%E5%84%9F%E3%81%A7%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%81%93%E3%81%A8%E3%82%92%E8%A8%B1%E8%AB%BE%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%20(1)%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E4%BD%BF%E7%94%A8%E3%80%81(2)%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E8%A4%87%E8%A3%BD%E3%80%81(3)%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E6%B4%BE%E7%94%9F%E7%89%A9%E3%81%AE%E4%BD%9C%E6%88%90%E3%80%81(4)%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%8A%E3%82%88%E3%81%B3%E3%81%9D%E3%81%AE%E6%B4%BE%E7%94%9F%E7%89%A9%E3%82%92%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%83%BB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AE%E4%B8%80%E9%83%A8%E3%81%A8%E3%81%97%E3%81%A6%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88(%E6%A9%9F%E6%A2%B0%E5%8F%AF%E8%AA%AD)%E5%BD%A2%E5%BC%8F%E3%81%A7%E9%85%8D%E5%B8%83%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3(5)%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%83%BB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AB%E5%90%AB%E3%81%BE%E3%82%8C%E3%82%8B%E9%85%8D%E5%B8%83%E3%81%95%E3%82%8C%E3%81%9F%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E6%A8%A9%E5%88%A9%E3%82%92%E4%BB%96%E8%80%85%E3%81%AB%E3%82%B5%E3%83%96%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%81%99%E3%82%8B%E3%80%81%E9%9D%9E%E7%8B%AC%E5%8D%A0%E7%9A%84%E3%81%8B%E3%81%A4%E8%AD%B2%E6%B8%A1%E4%B8%8D%E8%83%BD%E3%81%AA%E6%A8%A9%E5%88%A9%E3%80%82%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%8C%E6%9C%AC%E5%A5%91%E7%B4%84%E3%81%AE%E3%81%84%E3%81%9A%E3%82%8C%E3%81%8B%E3%81%AE%E6%9D%A1%E9%A0%85%E3%81%BE%E3%81%9F%E3%81%AF%E5%88%B6%E9%99%90%E3%81%AB%E9%81%95%E5%8F%8D%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AF%E6%9C%AC%E5%A5%91%E7%B4%84%E3%82%92%E7%9B%B4%E3%81%A1%E3%81%AB%E7%B5%82%E4%BA%86%E3%81%97%E3%80%81%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%8C%E6%89%80%E6%9C%89%E3%81%BE%E3%81%9F%E3%81%AF%E7%AE%A1%E7%90%86%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E6%9C%AC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E4%BD%BF%E7%94%A8%E3%82%92%E4%B8%AD%E6%AD%A2%E3%81%97%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%B3%E3%83%94%E3%83%BC%E3%82%92%E5%89%8A%E9%99%A4%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E8%A6%81%E6%B1%82%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E4%B8%8A%E8%A8%98%E3%81%A7%E4%BB%98%E4%B8%8E%E3%81%95%E3%82%8C%E3%81%9F%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%81%AF%E3%80%81%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%8C%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AB%E6%8F%90%E4%BE%9B%E3%81%97%E3%80%81%E4%BB%98%E4%B8%8E%E3%81%95%E3%82%8C%E3%81%9F%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%81%AE%E7%AF%84%E5%9B%B2%E5%86%85%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8B%E6%9C%AC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E5%BF%85%E7%84%B6%E7%9A%84%E3%81%AB%E4%BE%B5%E5%AE%B3%E3%81%95%E3%82%8C%E3%82%8B%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AE%E7%9F%A5%E7%9A%84%E8%B2%A1%E7%94%A3%E6%A8%A9%E3%81%AB%E3%81%AE%E3%81%BF%E9%81%A9%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AF%E3%80%81%E5%95%8F%E9%A1%8C%E3%82%84%E3%81%9D%E3%81%AE%E6%94%B9%E5%96%84%E6%8F%90%E6%A1%88%E3%82%92%E5%90%AB%E3%82%81%E3%80%81%E5%BE%97%E3%82%89%E3%82%8C%E3%81%9F%E7%B5%90%E6%9E%9C%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AB%E9%80%9A%E7%9F%A5%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AF%E3%80%81%E9%81%A9%E5%88%87%E3%81%A8%E6%80%9D%E3%82%8F%E3%82%8C%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%A7%E3%80%81%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E7%B5%90%E6%9E%9C%E3%81%8A%E3%82%88%E3%81%B3%E9%96%A2%E9%80%A3%E6%83%85%E5%A0%B1%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E6%A8%A9%E5%88%A9%E3%82%92%E7%95%99%E4%BF%9D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%20color%3A%20black%3B%20font-size%3A%2010pt%3B%22%3E2.%20%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%E3%81%9D%E3%81%AE%E4%BB%96%E3%81%AE%E5%88%B6%E9%99%90%3C%2FSTRONG%3E%3C%2FSPAN%3E%E3%80%82%E4%B8%8A%E8%A8%98%E3%81%AE%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E4%BB%98%E4%B8%8E%E3%82%92%E6%9D%A1%E4%BB%B6%E3%81%A8%E3%81%97%E3%81%A6%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E5%88%B6%E9%99%90%E3%81%8C%E9%81%A9%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%20color%3A%20black%3B%20font-size%3A%2010pt%3B%22%3E%E3%81%82%E3%82%8B%E3%80%82%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AF%E3%80%81%E6%9C%AC%E5%A5%91%E7%B4%84%E3%81%A7%E6%98%8E%E7%A4%BA%E7%9A%84%E3%81%AB%E4%BB%98%E4%B8%8E%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E6%A8%A9%E5%88%A9%E3%82%92%E7%95%99%E4%BF%9D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%20color%3A%20black%3B%20font-size%3A%2010pt%3B%22%3Eb.%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AF%E3%80%81%E6%9C%AC%E5%A5%91%E7%B4%84%E5%86%85%E3%81%A7%E6%98%8E%E7%A4%BA%E7%9A%84%E3%81%AB%E5%90%8C%E6%84%8F%E3%81%97%E3%81%AA%E3%81%84%E9%99%90%E3%82%8A%E3%80%81%E6%9C%AC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E3%83%AC%E3%83%B3%E3%82%BF%E3%83%AB%E3%80%81%E3%83%AA%E3%83%BC%E3%82%B9%E3%80%81%E3%82%B5%E3%83%96%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%80%81%E8%B2%B8%E4%B8%8E%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E6%8B%85%E4%BF%9D%E3%81%AB%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%20color%3A%20black%3B%20font-size%3A%2010pt%3B%22%3Ec.%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AF%E3%80%81%E6%9C%AC%E5%A5%91%E7%B4%84%E3%81%A7%E6%84%8F%E5%9B%B3%E3%81%95%E3%82%8C%E3%81%9F%E4%BB%A5%E5%A4%96%E3%81%AE%E7%9B%AE%E7%9A%84%E3%81%A7%E3%80%81%E6%9C%AC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E9%85%8D%E5%B8%83%E3%80%81%E8%A3%BD%E9%80%A0%E3%80%81%E8%A3%BD%E9%80%A0%E3%80%81%E3%82%B5%E3%83%96%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E3%81%9D%E3%81%AE%E4%BB%96%E3%81%AE%E6%96%B9%E6%B3%95%E3%81%A7%E8%A4%87%E8%A3%BD%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%20color%3A%20black%3B%20font-size%3A%2010pt%3B%22%3Ed.%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AB%E5%90%AB%E3%81%BE%E3%82%8C%E3%82%8B%E6%89%80%E6%9C%89%E6%A8%A9%E3%81%AE%E5%87%A1%E4%BE%8B%E3%80%81%E9%80%9A%E7%9F%A5%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E5%95%86%E6%A8%99%E3%82%92%E5%89%8A%E9%99%A4%E3%81%BE%E3%81%9F%E3%81%AF%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%20color%3A%20black%3B%20font-size%3A%2010pt%3B%22%3Ee.%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E6%9C%AC%E5%A5%91%E7%B4%84%E3%81%AE%E6%9D%A1%E9%A0%85%E3%81%AF%E3%80%81%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AE%E8%A3%81%E9%87%8F%E3%81%AB%E3%82%88%E3%82%8A%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AB%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%82%8B%E3%80%81%E5%85%83%E3%81%AE%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E7%BD%AE%E3%81%8D%E6%8F%9B%E3%81%88%E3%81%9F%E3%82%8A%E8%A3%9C%E8%B6%B3%E3%81%97%E3%81%9F%E3%82%8A%E3%81%99%E3%82%8B%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%BB%E3%82%A2%E3%83%83%E3%83%97%E3%83%87%E3%83%BC%E3%83%88%E3%81%AB%E9%81%A9%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E5%BD%93%E8%A9%B2%E3%82%A2%E3%83%83%E3%83%97%E3%83%87%E3%83%BC%E3%83%88%E3%81%AB%E5%88%A5%E5%80%8B%E3%81%AE%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%82%92%E9%99%A4%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%20color%3A%20black%3B%20font-size%3A%2010pt%3B%22%3Ef.%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AF%E3%80%81%E9%81%A9%E7%94%A8%E6%B3%95%E3%81%8C%E7%89%B9%E3%81%AB%E5%88%B6%E9%99%90%E3%82%92%E7%A6%81%E3%81%98%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%82%92%E9%99%A4%E3%81%8D%E3%80%81%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%81%9F%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%B3%E3%83%BC%E3%83%89%E5%BD%A2%E5%BC%8F(%E6%A9%9F%E6%A2%B0%E5%8F%AF%E8%AA%AD)%E3%81%AE%E3%81%BF%E3%81%A7%E7%BF%BB%E8%A8%B3%E3%80%81%E3%83%AA%E3%83%90%E3%83%BC%E3%82%B9%E3%82%A8%E3%83%B3%E3%82%B8%E3%83%8B%E3%82%A2%E3%83%AA%E3%83%B3%E3%82%B0%E3%80%81%E9%80%86%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E9%80%86%E3%82%A2%E3%82%BB%E3%83%B3%E3%83%96%E3%83%AB%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AF%E3%80%81%E9%81%A9%E7%94%A8%E6%B3%95%E3%81%8C%E7%89%B9%E3%81%AB%E5%88%B6%E9%99%90%E3%82%92%E7%A6%81%E3%81%98%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%82%92%E9%99%A4%E3%81%8D%E3%80%81%20%3CSPAN%20class%3D%22spelle%22%3E%E3%82%B5%E3%83%96%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B7%E3%83%BC%3C%2FSPAN%3E%20%E3%81%8C%E6%9C%AC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E7%BF%BB%E8%A8%B3%E3%80%81%E3%83%AA%E3%83%90%E3%83%BC%E3%82%B9%E3%82%A8%E3%83%B3%E3%82%B8%E3%83%8B%E3%82%A2%E3%83%AA%E3%83%B3%E3%82%B0%E3%80%81%E9%80%86%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E9%80%86%E3%82%A2%E3%82%BB%E3%83%B3%E3%83%96%E3%83%AB%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A6%81%E6%AD%A2%E3%81%99%E3%82%8B%E3%82%82%E3%81%AE%E3%81%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%20color%3A%20black%3B%20font-size%3A%2010pt%3B%22%3E3.%20%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%E3%82%AA%E3%83%BC%E3%83%97%E3%83%B3%E3%82%BD%E3%83%BC%E3%82%B9%3C%2FSTRONG%3E%3C%2FSPAN%3E%E3%80%82%E6%9C%AC%E5%A5%91%E7%B4%84%E3%81%A7%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%81%95%E3%82%8C%E3%81%9F%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AB%E5%90%AB%E3%81%BE%E3%82%8C%E3%82%8B%E3%82%AA%E3%83%BC%E3%83%97%E3%83%B3%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AF%E3%80%81%E6%9C%AC%E5%A5%91%E7%B4%84%E3%81%AE%E6%9D%A1%E9%A0%85%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81BSD%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%80%81Apache%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%80%81Lesser%20GNU%20General%20Public%20License%E3%81%AA%E3%81%A9%E3%81%AE%E8%A9%B2%E5%BD%93%E3%81%99%E3%82%8B%E3%82%AA%E3%83%BC%E3%83%97%E3%83%B3%E3%82%BD%E3%83%BC%E3%82%B9%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%81%AE%E6%9D%A1%E4%BB%B6%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%82%AA%E3%83%BC%E3%83%97%E3%83%B3%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E4%BD%BF%E7%94%A8%E3%81%AB%E3%81%AF%E3%80%81%E8%A9%B2%E5%BD%93%E3%81%99%E3%82%8B%E5%90%84%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%81%AE%E6%9D%A1%E4%BB%B6%E3%81%8C%E9%81%A9%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AF%E3%80%81%E8%A9%B2%E5%BD%93%E3%81%99%E3%82%8B%E5%90%84%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%81%AE%E6%9D%A1%E4%BB%B6%E3%81%AB%E5%90%8C%E6%84%8F%E3%81%97%E3%81%AA%E3%81%91%E3%82%8C%E3%81%B0%E3%81%AA%E3%82%89%E3%81%9A%E3%80%81%E3%81%9D%E3%81%86%E3%81%A7%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%82%AA%E3%83%BC%E3%83%97%E3%83%B3%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%AA%E3%81%84%E3%81%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%20%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%20color%3A%20black%3B%20font-size%3A%2010pt%3B%22%3E4.%20%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%E8%91%97%E4%BD%9C%E6%A8%A9%3C%2FSTRONG%3E%3C%2FSPAN%3E%E3%80%82%E6%9C%AC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AF%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AB%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E4%BE%9B%E4%B8%8E%E3%81%95%E3%82%8C%E3%82%8B%E3%82%82%E3%81%AE%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E8%B2%A9%E5%A3%B2%E3%81%95%E3%82%8C%E3%82%8B%E3%82%82%E3%81%AE%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E6%9C%AC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AF%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%8C%E6%89%80%E6%9C%89%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E7%B1%B3%E5%9B%BD%E3%81%AE%E8%91%97%E4%BD%9C%E6%A8%A9%E6%B3%95%E3%81%8A%E3%82%88%E3%81%B3%E5%9B%BD%E9%9A%9B%E6%9D%A1%E7%B4%84%E3%81%AE%E8%A6%8F%E5%AE%9A%E3%81%AB%E3%82%88%E3%82%8A%E6%9C%AC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%8C%E4%BF%9D%E8%AD%B7%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AF%E3%80%81%E6%9C%AC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E4%BB%96%E3%81%AE%E8%91%97%E4%BD%9C%E7%89%A9(%E6%9B%B8%E7%B1%8D%E3%82%84%E9%9F%B3%E6%A5%BD%E9%8C%B2%E9%9F%B3%3CEM%3E%E3%81%AA%E3%81%A9%20%3C%2FEM%3E)%E3%81%A8%E5%90%8C%E6%A7%98%E3%81%AB%E6%89%B1%E3%81%86%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AF%E3%80%81%E6%9C%AC%E5%A5%91%E7%B4%84%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E4%BB%A5%E5%A4%96%E3%81%AE%E7%9B%AE%E7%9A%84%E3%81%A7%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%BE%E3%81%9F%E3%81%AF%E3%82%B3%E3%83%94%E3%83%BC%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E6%9C%AC%E5%A5%91%E7%B4%84%E3%81%AB%E6%98%8E%E7%A4%BA%E7%9A%84%E3%81%AB%E8%A6%8F%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%82%92%E9%99%A4%E3%81%8D%E3%80%81%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AF%E3%80%81%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%BE%E3%81%9F%E3%81%AF%E7%AC%AC%E4%B8%89%E8%80%85%E3%81%AE%E7%89%B9%E8%A8%B1%E3%80%81%E8%91%97%E4%BD%9C%E6%A8%A9%E3%80%81%E5%95%86%E6%A8%99%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E4%BC%81%E6%A5%AD%E7%A7%98%E5%AF%86%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%8F%E6%98%8E%E7%A4%BA%E7%9A%84%E3%81%BE%E3%81%9F%E3%81%AF%E9%BB%99%E7%A4%BA%E7%9A%84%E3%81%AA%E6%A8%A9%E5%88%A9%E3%82%92%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AB%E4%BB%98%E4%B8%8E%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%95%E3%82%89%E3%81%AB%E3%80%81%E6%9C%AC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AB%E5%90%AB%E3%81%BE%E3%82%8C%E3%82%8B%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E6%9C%AC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AB%E5%9F%8B%E3%82%81%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E8%91%97%E4%BD%9C%E6%A8%A9%E3%81%BE%E3%81%9F%E3%81%AF%E3%81%9D%E3%81%AE%E4%BB%96%E3%81%AE%E6%89%80%E6%9C%89%E6%A8%A9%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E9%80%9A%E7%9F%A5%E3%81%AF%E3%80%81%E3%81%9D%E3%81%AE%E5%85%A8%E9%83%A8%E3%81%BE%E3%81%9F%E3%81%AF%E4%B8%80%E9%83%A8%E3%81%8C%E4%BD%9C%E6%88%90%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%81%9D%E3%81%AE%E3%82%B3%E3%83%94%E3%83%BC%E3%81%AB%E8%A4%87%E8%A3%BD%E3%81%97%E3%81%A6%E9%81%A9%E7%94%A8%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AF%E3%80%81%E6%9C%AC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AB%E7%B5%84%E3%81%BF%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AE%E8%91%97%E4%BD%9C%E6%A8%A9%E8%A1%A8%E7%A4%BA%E3%82%92%E5%89%8A%E9%99%A4%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%20color%3A%20black%3B%20font-size%3A%2010pt%3B%22%3E5.%20%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%E6%9C%9F%E9%96%93%E3%81%8A%E3%82%88%E3%81%B3%E7%B5%82%E4%BA%86%3C%2FSTRONG%3E%3C%2FSPAN%3E%E3%80%82%E6%9C%AC%E5%A5%91%E7%B4%84%E3%81%AE%E6%9C%9F%E9%96%93%E3%81%AF%E3%80%81%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%AE%E6%97%A5%E3%81%AB%E9%96%8B%E5%A7%8B%E3%81%97%E3%80%81%E6%9C%AC%E5%A5%91%E7%B4%84%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E7%B5%82%E4%BA%86%E3%81%99%E3%82%8B%E3%81%BE%E3%81%A7%E7%B6%99%E7%B6%9A%E3%81%99%E3%82%8B%E3%82%82%E3%81%AE%E3%81%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AF%E3%80%81%E6%9C%AC%E5%A5%91%E7%B4%84%E3%82%92%E4%BA%88%E5%91%8A%E3%81%AA%E3%81%97%E3%81%AB%E7%B5%82%E4%BA%86%E3%81%99%E3%82%8B%E6%A8%A9%E5%88%A9%E3%82%92%E6%9C%89%E3%81%97%E3%80%81%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%8C%E6%9C%AC%E5%A5%91%E7%B4%84%E3%81%AE%E6%9D%A1%E9%A0%85%E3%81%BE%E3%81%9F%E3%81%AF%E5%88%B6%E9%99%90%E3%81%AB%E9%81%95%E5%8F%8D%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%8C%E6%89%80%E6%9C%89%E3%81%BE%E3%81%9F%E3%81%AF%E7%AE%A1%E7%90%86%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E6%9C%AC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%B3%E3%83%94%E3%83%BC%E3%82%92%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AB%E4%BD%BF%E7%94%A8%E3%82%92%E4%B8%AD%E6%AD%A2%E3%81%97%E3%80%81%E5%89%8A%E9%99%A4%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E8%A6%81%E6%B1%82%E3%81%99%E3%82%8B%E6%A8%A9%E5%88%A9%E3%82%92%E6%9C%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AF%E3%80%81%E6%9C%AC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E3%81%84%E3%81%9A%E3%82%8C%E3%81%8B%E3%81%8C%E7%9F%A5%E7%9A%84%E4%BE%B5%E5%AE%B3%E3%81%BE%E3%81%9F%E3%81%AF%E4%BC%81%E6%A5%AD%E7%A7%98%E5%AF%86%E3%81%AE%E4%B8%8D%E6%AD%A3%E6%B5%81%E7%94%A8%E3%81%AB%E5%AF%BE%E3%81%99%E3%82%8B%E7%94%B3%E3%81%97%E7%AB%8B%E3%81%A6%E3%81%AE%E5%AF%BE%E8%B1%A1%E3%81%A8%E3%81%AA%E3%81%A3%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AE%E5%90%88%E7%90%86%E7%9A%84%E3%81%AA%E5%88%A4%E6%96%AD%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81%E6%9C%AC%E5%A5%91%E7%B4%84%E3%82%92%E7%B5%82%E4%BA%86%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E5%A5%91%E7%B4%84%E7%B5%82%E4%BA%86%E6%99%82%E3%81%AB%E3%81%AF%E3%80%81%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E4%BD%BF%E7%94%A8%E3%82%92%E4%B8%AD%E6%AD%A2%E3%81%97%E3%80%81%E7%A0%B4%E6%A3%84%E3%81%97%E3%80%81%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6%E6%9B%B8%E9%9D%A2%E3%81%A7%E9%81%B5%E5%AE%88%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E5%A5%91%E7%B4%84%E3%81%8C%E7%B5%82%E4%BA%86%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E6%9C%AC%E5%A5%91%E7%B4%84%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E4%BB%98%E4%B8%8E%E3%81%95%E3%82%8C%E3%81%9F%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%81%AF%E7%9B%B4%E3%81%A1%E3%81%AB%E7%B5%82%E4%BA%86%E3%81%97%E3%80%81%E7%AC%AC4%E6%9D%A1%E3%81%8B%E3%82%89%E7%AC%AC18%E6%9D%A1%E3%81%BE%E3%81%A7%E3%81%AE%E8%A6%8F%E5%AE%9A%E3%81%AF%E3%80%81%E6%9C%AC%E5%A5%91%E7%B4%84%E3%81%AE%E7%B5%82%E4%BA%86%E5%BE%8C%E3%82%82%E5%AD%98%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%20color%3A%20black%3B%20font-size%3A%2010pt%3B%22%3E6.%20%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%3C%2FSTRONG%3E%3C%2FSPAN%3E%E3%80%82%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AF%E3%80%81%E6%9C%AC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%80%81%E3%82%A2%E3%83%83%E3%83%97%E3%82%B0%E3%83%AC%E3%83%BC%E3%83%89%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E6%96%B0%E8%A6%8F%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%99%E3%82%8B%E7%BE%A9%E5%8B%99%E3%82%92%E8%B2%A0%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%94%E5%B8%8C%E6%9C%9B%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AB%E3%81%94%E9%80%A3%E7%B5%A1%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%80%81%E6%9C%AC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E5%95%8F%E9%A1%8C%E3%82%92%E5%A0%B1%E5%91%8A%E3%81%97%E3%80%81%E3%81%94%E6%8F%90%E6%A1%88%E3%82%92%E3%81%8A%E9%80%81%E3%82%8A%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AF%E3%80%81%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E5%95%8F%E9%A1%8C%E5%A0%B1%E5%91%8A%E3%81%BE%E3%81%9F%E3%81%AF%E6%8F%90%E6%A1%88%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6%E3%80%81%E3%81%84%E3%81%8B%E3%81%AA%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%A7%E3%82%82%E5%AF%BE%E5%BF%9C%E3%81%99%E3%82%8B%E7%BE%A9%E5%8B%99%E3%82%92%E4%B8%80%E5%88%87%E8%B2%A0%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AF%E3%80%81%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E6%9B%B4%E6%96%B0%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AB%E9%80%9A%E7%9F%A5%E3%81%BE%E3%81%9F%E3%81%AF%E6%8F%90%E4%BE%9B%E3%81%99%E3%82%8B%E7%BE%A9%E5%8B%99%E3%82%92%E8%B2%A0%E3%81%86%E3%81%93%E3%81%A8%E3%81%AA%E3%81%8F%E3%80%81%E3%81%84%E3%81%A4%E3%81%A7%E3%82%82%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AB%E5%A4%89%E6%9B%B4%E3%82%92%E5%8A%A0%E3%81%88%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%20color%3A%20black%3B%20font-size%3A%2010pt%3B%22%3E7.%20%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%E7%84%A1%E4%BF%9D%E8%A8%BC%3C%2FSTRONG%3E%3C%2FSPAN%3E%E3%80%82%E6%B3%95%E5%BE%8B%E3%81%A7%E8%AA%8D%E3%82%81%E3%82%89%E3%82%8C%E3%82%8B%E6%9C%80%E5%A4%A7%E9%99%90%E3%81%AE%E7%AF%84%E5%9B%B2%E3%81%A7%E3%80%81%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AF%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AB%E5%AF%BE%E3%81%99%E3%82%8B%E3%81%84%E3%81%8B%E3%81%AA%E3%82%8B%E4%BF%9D%E8%A8%BC%E3%82%82%E6%98%8E%E7%A4%BA%E7%9A%84%E3%81%AB%E5%90%A6%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E6%9C%AC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AF%E3%80%8C%E7%8F%BE%E7%8A%B6%E3%81%AE%E3%81%BE%E3%81%BE%E3%80%8D%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%80%81%E5%95%86%E5%93%81%E6%80%A7%E3%80%81%E7%89%B9%E5%AE%9A%E7%9B%AE%E7%9A%84%E3%81%B8%E3%81%AE%E9%81%A9%E5%90%88%E6%80%A7%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E9%9D%9E%E4%BE%B5%E5%AE%B3%E3%81%AE%E9%BB%99%E7%A4%BA%E3%81%AE%E4%BF%9D%E8%A8%BC%E3%82%92%E5%90%AB%E3%82%80%E3%81%8C%E3%81%93%E3%82%8C%E3%82%89%E3%81%AB%E9%99%90%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%AA%E3%81%84%E3%80%81%E6%98%8E%E7%A4%BA%E3%81%BE%E3%81%9F%E3%81%AF%E9%BB%99%E7%A4%BA%E3%81%AE%E3%81%84%E3%81%8B%E3%81%AA%E3%82%8B%E7%A8%AE%E9%A1%9E%E3%81%AE%E4%BF%9D%E8%A8%BC%E3%82%82%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AF%E3%80%81%E6%9C%AC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E6%9C%AC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E8%A8%AD%E8%A8%88%E3%81%97%E3%81%9F%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0(%E5%AD%98%E5%9C%A8%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88)%E3%81%AE%E4%BD%BF%E7%94%A8%E3%81%BE%E3%81%9F%E3%81%AF%E6%80%A7%E8%83%BD%E3%81%8B%E3%82%89%E7%94%9F%E3%81%98%E3%82%8B%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%AA%E3%82%B9%E3%82%AF%E3%82%92%E8%B2%A0%E3%81%86%E3%82%82%E3%81%AE%E3%81%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E6%9C%AC%E5%A5%91%E7%B4%84%E3%81%AE%E3%81%84%E3%81%8B%E3%81%AA%E3%82%8B%E6%9D%A1%E9%A0%85%E3%82%82%E3%80%81%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%8C%E3%80%81%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%BE%E3%81%9F%E3%81%AF%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%A8%E3%81%A8%E3%82%82%E3%81%AB%E9%96%8B%E7%99%BA%E3%81%95%E3%82%8C%E3%81%9F%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E7%B5%84%E3%81%BF%E8%BE%BC%E3%82%93%E3%81%A0%E4%BA%8C%E6%AC%A1%E7%9A%84%E8%91%97%E4%BD%9C%E7%89%A9%E3%81%8C%E7%AC%AC%E4%B8%89%E8%80%85%E3%81%AE%E7%9F%A5%E7%9A%84%E8%B2%A1%E7%94%A3%E6%A8%A9%E3%82%92%E4%BE%B5%E5%AE%B3%E3%81%97%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E4%BF%9D%E8%A8%BC%E3%81%BE%E3%81%9F%E3%81%AF%E8%A1%A8%E6%98%8E%E3%81%99%E3%82%8B%E3%82%82%E3%81%AE%E3%81%A8%E8%A7%A3%E9%87%88%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%20color%3A%20black%3B%20font-size%3A%2010pt%3B%22%3E8.%20%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%E6%90%8D%E5%AE%B3%E8%B3%A0%E5%84%9F%3C%2FSTRONG%3E%3C%2FSPAN%3E%E3%80%82%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AF%E3%80%81(1)%20%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AB%E3%82%88%E3%82%8B%E6%9C%AC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E4%BD%BF%E7%94%A8%20(%E3%82%B5%E3%83%96%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B7%E3%83%BC%E3%81%AE%E4%BD%BF%E7%94%A8%E3%81%8C%E8%A8%B1%E5%8F%AF%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AB%E3%81%AF%E3%80%81%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AE%20%3CSPAN%20class%3D%22spelle%22%3E%E3%82%B5%E3%83%96%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B7%E3%83%BC%E3%81%AB%E3%82%88%E3%82%8B%3C%2FSPAN%3E%20%E4%BD%BF%E7%94%A8%E3%82%92%E5%90%AB%E3%82%80)%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%20(2)%20%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AB%E3%82%88%E3%82%8B%E6%9C%AC%E5%A5%91%E7%B4%84%E3%81%AE%E6%9D%A1%E9%A0%85%E3%81%AE%E9%81%95%E5%8F%8D%E3%81%AB%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E8%AB%8B%E6%B1%82%E3%80%81%E8%B2%AC%E4%BB%BB%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%E8%B2%BB%E7%94%A8%20(%E5%90%88%E7%90%86%E7%9A%84%E3%81%AA%E5%BC%81%E8%AD%B7%E5%A3%AB%E8%B2%BB%E7%94%A8%E3%82%92%E5%90%AB%E3%82%80)%20%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%80%81%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%92%E5%AE%8C%E5%85%A8%E3%81%AB%E9%98%B2%E5%BE%A1%E3%81%97%E3%80%81%E8%A3%9C%E5%84%9F%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E5%90%8C%E6%84%8F%E3%81%99%E3%82%8B%E3%82%82%E3%81%AE%E3%81%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%20color%3A%20black%3B%20font-size%3A%2010pt%3B%22%3E9.%20%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%E8%B2%AC%E4%BB%BB%E3%81%AE%E5%88%B6%E9%99%90%3C%2FSTRONG%3E%3C%2FSPAN%3E%E3%80%82%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AF%E3%80%81%E5%A5%91%E7%B4%84%E3%80%81%E4%B8%8D%E6%B3%95%E8%A1%8C%E7%82%BA%E3%80%81%E3%81%9D%E3%81%AE%E4%BB%96%E3%82%92%E5%95%8F%E3%82%8F%E3%81%9A%E3%80%81%E5%81%B6%E7%99%BA%E7%9A%84%E3%80%81%E7%89%B9%E5%88%A5%E3%80%81%E9%96%93%E6%8E%A5%E7%9A%84%E3%80%81%E7%B5%90%E6%9E%9C%E7%9A%84%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E6%87%B2%E7%BD%B0%E7%9A%84%E3%81%AA%E6%90%8D%E5%AE%B3%20(%E4%BD%BF%E7%94%A8%E3%81%AE%E6%90%8D%E5%A4%B1%E3%80%81%E6%99%82%E9%96%93%E3%81%AE%E6%90%8D%E5%A4%B1%E3%80%81%E4%B8%8D%E4%BE%BF%E3%80%81%E5%95%86%E6%A5%AD%E7%9A%84%E6%90%8D%E5%A4%B1%E3%80%81%E5%88%A9%E7%9B%8A%E3%80%81%E8%B2%AF%E8%93%84%E3%80%81%E5%8F%8E%E7%9B%8A%E3%81%AE%E6%90%8D%E5%A4%B1%E3%81%AB%E3%82%88%E3%82%8B%E6%90%8D%E5%AE%B3%E3%82%92%E5%90%AB%E3%81%BF%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AB%E9%99%90%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93)%20%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%80%81%E6%B3%95%E5%BE%8B%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E4%BA%8B%E5%89%8D%E3%81%AB%E9%80%9A%E7%9F%A5%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%A7%E3%81%82%E3%81%A3%E3%81%A6%E3%82%82%E3%80%81%E6%B3%95%E5%BE%8B%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E5%90%A6%E8%AA%8D%E3%81%95%E3%82%8C%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%AE%E3%81%82%E3%82%8B%E6%90%8D%E5%AE%B3%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%80%81%E4%B8%80%E5%88%87%E3%81%AE%E8%B2%AC%E4%BB%BB%E3%82%92%E8%B2%A0%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AE%E8%B2%AC%E4%BB%BB%E3%81%AF%E3%80%81%E3%81%84%E3%81%8B%E3%81%AA%E3%82%8B%E5%A0%B4%E5%90%88%E3%82%82%E3%80%81%E3%81%BE%E3%81%9F%E3%81%84%E3%81%8B%E3%81%AA%E3%82%8B%E5%9B%9E%E5%BE%A9%E6%B3%95%E7%90%86%E3%81%AB%E3%81%8A%E3%81%84%E3%81%A6%E3%82%82%E3%80%81%E6%9C%AC%E5%A5%91%E7%B4%84%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%8C%E5%8F%97%E9%A0%98%E3%81%97%E3%81%9F%E7%B7%8F%E9%A1%8D%E3%81%AB%E9%99%90%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%20color%3A%20black%3B%20font-size%3A%2010pt%3B%22%3E10.%20%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%E6%B3%95%E4%BB%A4%E3%81%AE%E9%81%B5%E5%AE%88%E8%BC%B8%E5%87%BA%E5%88%B6%E9%99%90%3C%2FSTRONG%3E%3C%2FSPAN%3E%E3%80%82%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AF%E3%80%81%E7%B1%B3%E5%9B%BD%E6%94%BF%E5%BA%9C%E3%81%8A%E3%82%88%E3%81%B3%E8%BC%B8%E5%87%BA%E3%81%BE%E3%81%9F%E3%81%AF%E5%86%8D%E8%BC%B8%E5%87%BA%E3%81%8C%E8%A1%8C%E3%82%8F%E3%82%8C%E3%82%8B%E5%9B%BD%E3%81%8B%E3%82%89%E9%81%A9%E5%88%87%E3%81%AA%E8%BC%B8%E5%87%BA%E3%81%BE%E3%81%9F%E3%81%AF%E5%86%8D%E8%BC%B8%E5%87%BA%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%82%92%E5%8F%96%E5%BE%97%E3%81%9B%E3%81%9A%E3%81%AB%E3%80%81%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%81%95%E3%82%8C%E3%81%9F%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%BE%E3%81%9F%E3%81%AF%E3%81%9D%E3%81%AE%E7%9B%B4%E6%8E%A5%E8%A3%BD%E5%93%81%E3%82%92%E3%80%81%E3%81%84%E3%81%8B%E3%81%AA%E3%82%8B%E5%BD%A2%E5%BC%8F%E3%81%A7%E3%82%82%E5%86%8D%E8%B2%A9%E5%A3%B2%E3%80%81%E5%86%8D%E8%BC%B8%E5%87%BA%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E7%9B%B4%E6%8E%A5%E7%9A%84%E3%81%BE%E3%81%9F%E3%81%AF%E9%96%93%E6%8E%A5%E7%9A%84%E3%81%AB%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%A6%E3%81%AF%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E8%BC%B8%E5%87%BA%E3%81%AF%E3%80%81%E8%A3%BD%E5%93%81%E3%80%81%E6%8A%80%E8%A1%93%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%8C%E3%80%81%E7%89%A9%E7%90%86%E7%9A%84%E3%81%AA%E5%87%BA%E8%8D%B7%E3%80%81FTP%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E8%BB%A2%E9%80%81%E3%80%81%E9%9B%BB%E5%AD%90%E3%83%A1%E3%83%BC%E3%83%AB%E3%80%81%E3%83%95%E3%82%A1%E3%83%83%E3%82%AF%E3%82%B9%E3%80%81%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%80%81%E4%BC%9A%E8%A9%B1%E3%81%AA%E3%81%A9%E3%80%81%E4%BD%95%E3%82%89%E3%81%8B%E3%81%AE%E6%89%8B%E6%AE%B5%E3%81%A7%E3%81%82%E3%82%8B%E5%9B%BD%E3%81%8B%E3%82%89%E5%88%A5%E3%81%AE%E5%9B%BD%E3%81%AB%E8%BB%A2%E9%80%81%E3%81%95%E3%82%8C%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%AB%20%3CSPAN%20class%3D%22grame%22%3E%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%20%E3%80%82%E8%BC%B8%E5%87%BA%E3%81%AF%E3%80%81%E6%8A%80%E8%A1%93%E3%81%BE%E3%81%9F%E3%81%AF%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%8C%E7%B1%B3%E5%9B%BD%E5%86%85%E3%81%AE%E5%A4%96%E5%9B%BD%E4%BA%BA%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E4%BA%8B%E6%A5%AD%E6%B4%BB%E5%8B%95%E3%81%8C%E8%A1%8C%E3%82%8F%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%9B%BD%E3%81%AE%E5%A4%96%E5%9B%BD%E4%BA%BA%E3%81%AB%E8%AD%B2%E6%B8%A1%E3%81%95%E3%82%8C%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AB%E3%82%82%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E5%A4%96%E5%9B%BD%E4%BA%BA%E3%81%A8%E3%81%AF%E3%80%81%E7%B1%B3%E5%9B%BD%E3%81%BE%E3%81%9F%E3%81%AF%E4%BA%8B%E6%A5%AD%E6%B4%BB%E5%8B%95%E3%81%8C%E8%A1%8C%E3%82%8F%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%9B%BD%E3%81%AE%E5%B8%82%E6%B0%91%E3%81%A7%E3%82%82%E6%B0%B8%E4%BD%8F%E8%80%85%E3%81%A7%E3%82%82%E3%81%AA%E3%81%84%E4%BA%BA%E3%81%A7%E3%81%99%E3%80%82%E3%81%95%E3%82%89%E3%81%AB%E3%80%81%E6%8A%80%E8%A1%93%E3%80%81%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%80%81%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E3%81%9D%E3%81%AE%E4%BB%96%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AE%E8%B3%87%E7%94%A3%E3%82%92%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E4%BB%A5%E5%A4%96%E3%81%AE%E5%BD%93%E4%BA%8B%E8%80%85%E3%81%AB%E8%AD%B2%E6%B8%A1%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E8%BC%B8%E5%87%BA%E5%85%A5%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%80%81%E8%A8%B1%E5%8F%AF%E8%A8%BC%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E3%81%9D%E3%81%AE%E4%BB%96%E3%81%AE%E6%94%BF%E5%BA%9C%E3%81%AB%E3%82%88%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%AA%E6%A8%A9%E9%99%90(%E4%BB%A5%E4%B8%8B%E3%80%81%E7%B7%8F%E7%A7%B0%E3%81%97%E3%81%A6%E3%80%8C%E6%94%BF%E5%BA%9C%E3%81%AB%E3%82%88%E3%82%8B%E8%AA%8D%E5%8F%AF%E3%80%8D%E3%81%A8%E3%81%84%E3%81%84%E3%81%BE%E3%81%99%3CSPAN%20class%3D%22spelle%22%3E%3C%2FSPAN%3E)%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A8%E3%81%95%E3%82%8C%E3%80%81%E6%89%BF%E8%AA%8D%E3%81%95%E3%82%8C%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AF%E3%80%81%E3%81%8B%E3%81%8B%E3%82%8B%E3%80%8C%E6%94%BF%E5%BA%9C%E3%81%AB%E3%82%88%E3%82%8B%E8%AA%8D%E5%8F%AF%E3%80%8D%E3%81%8C%E4%BB%98%E4%B8%8E%E3%81%95%E3%82%8C%E3%82%8B%E3%81%BE%E3%81%A7%E3%80%81%E6%9C%AC%E5%A5%91%E7%B4%84%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%8F%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E8%AD%B2%E6%B8%A1%E3%81%99%E3%82%8B%E7%BE%A9%E5%8B%99%E3%82%92%E8%B2%A0%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%20color%3A%20black%3B%20font-size%3A%2010pt%3B%22%3E11.%20%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%E6%94%BF%E5%BA%9C%E3%81%AE%E6%A8%A9%E5%88%A9%3C%2FSTRONG%3E%3C%2FSPAN%3E%E3%80%82%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AF%E3%80%8148%20C.F.R.%20%C2%A72.101%20%E3%81%AB%E5%AE%9A%E7%BE%A9%E3%81%95%E3%82%8C%E3%82%8B%E3%80%8C%E5%95%86%E7%94%A8%E3%82%A2%E3%82%A4%E3%83%86%E3%83%A0%E3%80%8D%E3%81%A7%E3%81%82%E3%82%8A%E3%80%8148%20C.F.R.%20%C2%A7%2012.212%20%E3%81%BE%E3%81%9F%E3%81%AF%2048%20C.F.R.%20%C2%A7227.7202%20(%E8%A9%B2%E5%BD%93%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88)%20%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8B%E3%80%8C%E5%95%86%E7%94%A8%E3%82%B3%E3%83%B3%E3%83%94%E3%83%A5%E3%83%BC%E3%82%BF%20%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%80%8D%E3%81%8A%E3%82%88%E3%81%B3%E3%80%8C%E5%95%86%E7%94%A8%E3%82%B3%E3%83%B3%E3%83%94%E3%83%A5%E3%83%BC%E3%82%BF%20%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%20%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%86%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%80%8D%E3%81%A7%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%80%81%E6%9C%AC%E5%A5%91%E7%B4%84%E3%81%AB%E8%A6%8F%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E6%A8%A9%E5%88%A9%E3%82%92%E6%8C%81%E3%81%A4%E7%B1%B3%E5%9B%BD%E6%94%BF%E5%BA%9C%E3%81%AE%E3%82%A8%E3%83%B3%E3%83%89%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%81%AB%E3%81%AE%E3%81%BF%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E4%BE%9B%E4%B8%8E%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%20color%3A%20black%3B%20font-size%3A%2010pt%3B%22%3E12.%20%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%E3%83%AA%E3%82%B9%E3%82%AF%E3%81%AE%E9%AB%98%E3%81%84%E6%B4%BB%E5%8B%95%3C%2FSTRONG%3E%3C%2FSPAN%3E%E3%80%82%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AF%E3%80%81%E6%9C%AC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%8C%E3%83%95%E3%82%A9%E3%83%BC%E3%83%AB%E3%83%88%E3%83%BB%E3%83%88%E3%83%AC%E3%83%A9%E3%83%B3%E3%83%88%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81%E5%8E%9F%E5%AD%90%E5%8A%9B%E6%96%BD%E8%A8%AD%E3%80%81%E8%88%AA%E7%A9%BA%E6%A9%9F%E3%81%AE%E3%83%8A%E3%83%93%E3%82%B2%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%80%81%E9%80%9A%E4%BF%A1%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AE%E9%81%8B%E7%94%A8%E3%81%AA%E3%81%A9%E3%80%81%E5%8D%B1%E9%99%BA%E3%80%81%E7%94%9F%E5%91%BD%E3%81%AB%E5%8D%B1%E9%99%BA%E3%82%92%E5%8F%8A%E3%81%BC%E3%81%99%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E7%94%9F%E5%91%BD%E3%82%92%E8%84%85%E3%81%8B%E3%81%99%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%AE%E3%81%82%E3%82%8B%E7%92%B0%E5%A2%83%E3%81%AB%E3%81%8A%E3%81%84%E3%81%A6%E3%80%81%E3%82%AA%E3%83%B3%E3%83%A9%E3%82%A4%E3%83%B3%E5%88%B6%E5%BE%A1%E6%A9%9F%E5%99%A8%E3%81%A7%E3%81%AE%E4%BD%BF%E7%94%A8%E3%81%BE%E3%81%9F%E3%81%AF%E5%86%8D%E8%B2%A9%E3%82%92%E7%9B%AE%E7%9A%84%E3%81%A8%E3%81%97%E3%81%9F%E8%A3%BD%E5%93%81%E3%81%AB%E7%B5%84%E3%81%BF%E8%BE%BC%E3%82%80%E3%81%93%E3%81%A8%E3%82%92%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%8C%E8%A8%AD%E8%A8%88%E3%80%81%E8%A3%BD%E9%80%A0%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E6%84%8F%E5%9B%B3%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E8%AA%8D%E3%82%81%E3%81%BE%E3%81%99%E3%80%82%20%E8%88%AA%E7%A9%BA%E7%AE%A1%E5%88%B6%E3%80%81%E7%9B%B4%E6%8E%A5%E7%94%9F%E5%91%BD%E7%B6%AD%E6%8C%81%E8%A3%85%E7%BD%AE%E3%81%BE%E3%81%9F%E3%81%AF%E5%85%B5%E5%99%A8%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AA%E3%81%A9%E3%80%81%E8%A3%BD%E5%93%81%E3%81%AE%E6%95%85%E9%9A%9C%E3%81%8C%E7%9B%B4%E6%8E%A5%E6%AD%BB%E4%BA%A1%E3%80%81%E4%BA%BA%E8%BA%AB%E5%82%B7%E5%AE%B3%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E6%B7%B1%E5%88%BB%E3%81%AA%E7%89%A9%E7%90%86%E7%9A%84%E3%81%BE%E3%81%9F%E3%81%AF%E7%92%B0%E5%A2%83%E7%9A%84%E6%90%8D%E5%AE%B3%E3%81%AB%E3%81%A4%E3%81%AA%E3%81%8C%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%AE%E3%81%82%E3%82%8B%E3%82%82%E3%81%AE(%E4%BB%A5%E4%B8%8B%E3%80%8C%E9%AB%98%E3%83%AA%E3%82%B9%E3%82%AF%E6%B4%BB%E5%8B%95%E3%80%8D%E3%81%A8%E3%81%84%E3%81%84%E3%81%BE%E3%81%99)%E3%80%82%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AF%E3%80%81%E6%9C%AC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%BE%E3%81%9F%E3%81%AF%E6%9C%AC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E6%B4%BE%E7%94%9F%E7%89%A9%E3%82%92%E9%AB%98%E3%83%AA%E3%82%B9%E3%82%AF%E6%B4%BB%E5%8B%95%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E6%98%8E%E7%A2%BA%E3%81%AB%E8%A1%A8%E6%98%8E%E3%81%97%E3%80%81%E4%BF%9D%E8%A8%BC%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%20color%3A%20black%3B%20font-size%3A%2010pt%3B%22%3E13.%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%E6%B3%95%E5%BE%8B%E3%81%AE%E9%81%B8%E6%8A%9E%E3%80%82%E4%BC%9A%E5%A0%B4%3B%E5%88%B6%E9%99%90%E4%BA%8B%E9%A0%85%E3%80%82%3C%2FSTRONG%3E%3C%2FSPAN%3E%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AF%E3%80%81%E6%8A%B5%E8%A7%A6%E6%B3%95%E3%81%AE%E5%8E%9F%E5%89%87%E3%81%AB%E3%81%8B%E3%81%8B%E3%82%8F%E3%82%89%E3%81%9A%E3%80%81%E6%9C%AC%E5%A5%91%E7%B4%84%E3%81%BE%E3%81%9F%E3%81%AF%E6%9C%AC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AB%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E4%BA%8B%E9%A0%85%E3%81%AB%E7%B1%B3%E5%9B%BD%E3%81%8A%E3%82%88%E3%81%B3%E7%B1%B3%E5%9B%BD%E3%83%86%E3%82%AD%E3%82%B5%E3%82%B9%E5%B7%9E%E3%81%AE%E6%B3%95%E4%BB%A4%E3%81%8A%E3%82%88%E3%81%B3%E6%B3%95%E5%BE%8B%E3%81%8C%E9%81%A9%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E5%90%8C%E6%84%8F%E3%81%97%E3%80%81%E3%81%BE%E3%81%9F%E3%80%81%E8%A8%B4%E8%A8%9F%E3%81%AF%E3%83%86%E3%82%AD%E3%82%B5%E3%82%B9%E5%B7%9E%E3%81%AE%E5%B7%9E%E8%A3%81%E5%88%A4%E6%89%80%E3%81%BE%E3%81%9F%E3%81%AF%E9%80%A3%E9%82%A6%E8%A3%81%E5%88%A4%E6%89%80%E3%81%AE%E5%B0%82%E5%B1%9E%E7%AE%A1%E8%BD%84%E6%A8%A9%E3%81%AB%E5%BE%93%E3%81%86%E3%81%93%E3%81%A8%E3%81%AB%E5%90%8C%E6%84%8F%E3%81%99%E3%82%8B%E3%82%82%E3%81%AE%E3%81%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%20%E7%B1%B3%E5%9B%BD%E3%80%82%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AF%E3%80%81%E3%81%93%E3%82%8C%E3%81%AB%E5%8F%8D%E3%81%99%E3%82%8B%E6%B3%95%E4%BB%A4%E3%81%BE%E3%81%9F%E3%81%AF%E6%B3%95%E5%BE%8B%E3%81%AB%E3%81%8B%E3%81%8B%E3%82%8F%E3%82%89%E3%81%9A%E3%80%81%E6%9C%AC%E5%A5%91%E7%B4%84%E3%81%BE%E3%81%9F%E3%81%AF%E6%9C%AC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AB%E8%B5%B7%E5%9B%A0%E3%81%BE%E3%81%9F%E3%81%AF%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%E8%AB%8B%E6%B1%82%E3%81%BE%E3%81%9F%E3%81%AF%E8%A8%B4%E8%A8%9F%E5%8E%9F%E5%9B%A0%E3%81%AF%E3%80%81%E5%BD%93%E8%A9%B2%E8%AB%8B%E6%B1%82%E3%81%BE%E3%81%9F%E3%81%AF%E8%A8%B4%E8%A8%9F%E5%8E%9F%E5%9B%A0%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%8B%E3%82%891%E5%B9%B4%E4%BB%A5%E5%86%85%E3%81%AB%E6%8F%90%E8%B5%B7%E3%81%95%E3%82%8C%E3%81%AA%E3%81%91%E3%82%8C%E3%81%B0%E3%81%AA%E3%82%89%E3%81%9A%E3%80%81%E6%8F%90%E8%B5%B7%E3%81%95%E3%82%8C%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E6%B0%B8%E4%B9%85%E3%81%AB%E7%A6%81%E6%AD%A2%E3%81%95%E3%82%8C%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E5%90%8C%E6%84%8F%E3%81%99%E3%82%8B%E3%82%82%E3%81%AE%E3%81%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%20color%3A%20black%3B%20font-size%3A%2010pt%3B%22%3E14.%20%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%E6%A9%9F%E5%AF%86%E6%83%85%E5%A0%B1%3C%2FSTRONG%3E%3C%2FSPAN%3E%E3%80%82%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AF%E3%80%81%E6%9C%AC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E6%A9%9F%E5%AF%86%E6%83%85%E5%A0%B1%E3%81%A8%E3%81%97%E3%81%A6%E6%89%B1%E3%81%86%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E5%BD%A2%E5%BC%8F(%E4%BA%BA%E9%96%93%E3%81%8C%E8%AA%AD%E3%82%81%E3%82%8B%E5%BD%A2%E5%BC%8F)%E3%81%AE%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AB%E9%96%A2%E3%81%97%E3%81%A6%E3%81%AF%E3%80%81%E6%9C%AC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E6%B0%B8%E4%B9%85%E3%81%AB%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E6%9C%AC%E5%A5%91%E7%B4%84%E3%81%AE%E7%B5%82%E4%BA%86%E6%97%A5%E3%81%8B%E3%82%895%E5%B9%B4%E9%96%93%E3%80%81%E6%9C%AC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E4%BB%96%E3%81%AE%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E9%83%A8%E5%88%86%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E7%A7%98%E5%AF%86%E4%BF%9D%E6%8C%81%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E5%90%8C%E6%84%8F%E3%81%99%E3%82%8B%E3%82%82%E3%81%AE%E3%81%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E6%9C%9F%E9%96%93%E4%B8%AD%E3%80%81%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AF%E3%80%81%E6%9C%AC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E7%9F%A5%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81%E6%9C%AC%E5%A5%91%E7%B4%84%E3%81%A8%E5%B0%91%E3%81%AA%E3%81%8F%E3%81%A8%E3%82%82%E5%90%8C%E7%A8%8B%E5%BA%A6%E3%81%AE%E6%B3%A8%E6%84%8F%E3%82%92%E6%89%95%E3%81%A3%E3%81%A6%E5%BD%93%E8%A9%B2%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E4%BF%9D%E8%AD%B7%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%BE%A9%E5%8B%99%E4%BB%98%E3%81%91%E3%82%8B%E6%9B%B8%E9%9D%A2%E3%81%AB%E3%82%88%E3%82%8B%E5%A5%91%E7%B4%84%E3%82%92%E7%B7%A0%E7%B5%90%E3%81%97%E3%81%9F%E5%BE%93%E6%A5%AD%E5%93%A1%E4%BB%A5%E5%A4%96%E3%81%AE%E5%BE%93%E6%A5%AD%E5%93%A1%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6%E3%80%81%E6%9C%AC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E3%81%84%E3%81%8B%E3%81%AA%E3%82%8B%E9%83%A8%E5%88%86%E3%82%82%E9%96%8B%E7%A4%BA%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AF%E3%80%81%E6%9C%AC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%80%81%E3%81%8A%E5%AE%A2%E6%A7%98%E8%87%AA%E8%BA%AB%E3%81%AE%E6%A9%9F%E5%AF%86%E6%83%85%E5%A0%B1%E3%81%A8%E5%90%8C%E7%A8%8B%E5%BA%A6%E3%81%AE%E6%B3%A8%E6%84%8F%E3%82%92%E6%89%95%E3%82%8F%E3%81%AA%E3%81%91%E3%82%8C%E3%81%B0%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E5%90%88%E7%90%86%E7%9A%84%E3%81%AA%E7%A8%8B%E5%BA%A6%E4%BB%A5%E4%B8%8A%E3%81%AE%E6%B3%A8%E6%84%8F%E3%82%92%E6%89%95%E3%81%86%E3%81%93%E3%81%A8%E3%81%AB%E5%90%8C%E6%84%8F%E3%81%99%E3%82%8B%E3%82%82%E3%81%AE%E3%81%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AF%E3%80%81%E8%A3%81%E5%88%A4%E6%89%80%E3%81%8C%E8%A6%81%E6%B1%82%E3%81%99%E3%82%8B%E7%AF%84%E5%9B%B2%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E6%B3%95%E5%BE%8B%E3%81%BE%E3%81%9F%E3%81%AF%E5%91%BD%E4%BB%A4%E3%81%AE%E9%81%8B%E7%94%A8%E3%81%AE%E4%B8%8B%E3%81%A7%E3%80%81%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E9%96%8B%E7%A4%BA%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E9%96%8B%E7%A4%BA%E5%89%8D%E3%81%AB%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AB%E5%BD%93%E8%A9%B2%E8%A6%81%E4%BB%B6%E3%82%92%E9%80%9A%E7%9F%A5%E3%81%97%E3%80%81%E5%BF%85%E8%A6%81%E3%81%AA%E6%83%85%E5%A0%B1%E3%81%AE%E3%81%BF%E3%82%92%E9%96%8B%E7%A4%BA%E3%81%97%E3%80%81%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%8C%E5%BD%93%E8%A9%B2%E9%96%8B%E7%A4%BA%E3%82%92%E8%A6%81%E6%B1%82%E3%81%99%E3%82%8B%E8%A3%81%E5%88%A4%E6%89%80%E3%81%BE%E3%81%9F%E3%81%AF%E3%81%9D%E3%81%AE%E4%BB%96%E3%81%AE%E6%B3%95%E7%9A%84%E6%A9%9F%E9%96%A2%E3%81%AB%E7%95%B0%E8%AD%B0%E3%82%92%E5%94%B1%E3%81%88%E3%82%8B%E6%A9%9F%E4%BC%9A%E3%82%92%E4%B8%8E%E3%81%88%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E6%9D%A1%E4%BB%B6%E3%81%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%20color%3A%20black%3B%20font-size%3A%2010pt%3B%22%3E15.%20%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%E8%A3%BD%E5%93%81%E3%81%AE%E3%83%A9%E3%83%99%E3%83%AB%E4%BB%98%E3%81%91%3C%2FSTRONG%3E%3C%2FSPAN%3E%E3%80%82%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AE%E5%95%86%E6%A8%99%E3%80%81%E3%83%96%E3%83%A9%E3%83%B3%E3%83%89%E5%90%8D%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%AD%E3%82%B4%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E8%A8%B1%E5%8F%AF%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%20color%3A%20black%3B%20font-size%3A%2010pt%3B%22%3E16.%20%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%E5%AE%8C%E5%85%A8%E5%90%88%E6%84%8F%3C%2FSTRONG%3E%3C%2FSPAN%3E%E3%80%82%E6%9C%AC%E5%A5%91%E7%B4%84%E3%81%AF%E3%80%81%E6%9C%AC%E5%A5%91%E7%B4%84%E3%81%AE%E4%B8%BB%E9%A1%8C%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%A8%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%A8%E3%81%AE%E9%96%93%E3%81%AE%E5%AE%8C%E5%85%A8%E3%81%AA%E5%90%88%E6%84%8F%E3%82%92%E6%A7%8B%E6%88%90%E3%81%97%E3%80%81%E6%9B%B8%E9%9D%A2%E3%81%BE%E3%81%9F%E3%81%AF%E5%8F%A3%E9%A0%AD%E3%81%AB%E3%82%88%E3%82%8B%E5%BE%93%E5%89%8D%E3%81%AE%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E9%80%9A%E4%BF%A1%E3%80%81%E4%BA%A4%E6%B8%89%E3%80%81%E7%90%86%E8%A7%A3%E3%80%81%E5%90%88%E6%84%8F%E3%81%BE%E3%81%9F%E3%81%AF%E8%A1%A8%E6%98%8E(%E5%AD%98%E5%9C%A8%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88)%E3%81%AB%E5%84%AA%E5%85%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E6%9C%AC%E5%A5%91%E7%B4%84%E3%81%AF%E3%80%81%E6%9B%B8%E9%9D%A2%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E3%81%AE%E3%81%BF%E4%BF%AE%E6%AD%A3%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%80%81%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%A8%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%8C%E7%B7%A0%E7%B5%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%20color%3A%20black%3B%20font-size%3A%2010pt%3B%22%3E17.%20%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%E5%88%86%E9%9B%A2%E5%8F%AF%E8%83%BD%E6%80%A7%3C%2FSTRONG%3E%3C%2FSPAN%3E%E3%80%82%E6%9C%AC%E5%A5%91%E7%B4%84%E3%81%AE%E3%81%84%E3%81%9A%E3%82%8C%E3%81%8B%E3%81%AE%E6%9D%A1%E9%A0%85%E3%81%8C%E4%BD%95%E3%82%89%E3%81%8B%E3%81%AE%E7%90%86%E7%94%B1%E3%81%A7%E7%84%A1%E5%8A%B9%E3%81%BE%E3%81%9F%E3%81%AF%E5%9F%B7%E8%A1%8C%E4%B8%8D%E8%83%BD%E3%81%A8%E5%88%A4%E6%96%AD%E3%81%95%E3%82%8C%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81%E6%9C%AC%E5%A5%91%E7%B4%84%E3%81%AE%E6%AE%8B%E3%82%8A%E3%81%AE%E6%9D%A1%E9%A0%85%E3%81%AF%E6%90%8D%E3%81%AA%E3%82%8F%E3%82%8C%E3%81%9A%E3%80%81%E7%84%A1%E5%8A%B9%E3%81%BE%E3%81%9F%E3%81%AF%E5%9F%B7%E8%A1%8C%E4%B8%8D%E8%83%BD%E3%81%AA%E6%9D%A1%E9%A0%85%E3%81%AE%E5%A4%89%E6%9B%B4%E3%81%BE%E3%81%9F%E3%81%AF%E7%BD%AE%E6%8F%9B%E3%81%AB%E3%82%88%E3%82%8A%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AE%E9%87%8D%E5%A4%A7%E3%81%AA%E5%88%A9%E7%9B%8A%E3%81%8C%E3%81%95%E3%82%89%E3%81%AB%E5%A5%AA%E3%82%8F%E3%82%8C%E3%82%8B%E3%81%A8%E5%88%A4%E6%96%AD%E3%81%95%E3%82%8C%E3%81%AA%E3%81%84%E9%99%90%E3%82%8A%E3%80%81%E6%9C%AC%E5%A5%91%E7%B4%84%E3%81%AF%E7%9B%B4%E3%81%A1%E3%81%AB%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%20%E7%84%A1%E5%8A%B9%E3%81%BE%E3%81%9F%E3%81%AF%E5%9F%B7%E8%A1%8C%E4%B8%8D%E8%83%BD%E3%81%AA%E6%9D%A1%E9%A0%85%E3%81%AF%E3%80%81%E6%9C%89%E5%8A%B9%E3%81%8B%E3%81%A4%E5%9F%B7%E8%A1%8C%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E7%84%A1%E5%8A%B9%E3%81%BE%E3%81%9F%E3%81%AF%E5%9F%B7%E8%A1%8C%E4%B8%8D%E8%83%BD%E3%81%AA%E6%9D%A1%E9%A0%85%E3%81%AE%E6%A0%B9%E5%BA%95%E3%81%AB%E3%81%82%E3%82%8B%E6%84%8F%E5%9B%B3%E3%81%AB%E6%9C%80%E3%82%82%E8%BF%91%E3%81%84%E6%9D%A1%E9%A0%85%E3%81%AB%E7%BD%AE%E3%81%8D%E6%8F%9B%E3%81%88%E3%82%89%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%20color%3A%20black%3B%20font-size%3A%2010pt%3B%22%3E18.%20%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%E6%A8%A9%E5%88%A9%E6%94%BE%E6%A3%84%E3%81%AA%E3%81%97%3C%2FSTRONG%3E%3C%2FSPAN%3E%E3%80%82%E6%9C%AC%E5%A5%91%E7%B4%84%E3%81%AE%E3%81%84%E3%81%9A%E3%82%8C%E3%81%8B%E3%81%AE%E6%9D%A1%E9%A0%85%E3%81%AE%E9%81%95%E5%8F%8D%E3%81%AB%E5%AF%BE%E3%81%99%E3%82%8B%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AB%E3%82%88%E3%82%8B%E6%A8%A9%E5%88%A9%E6%94%BE%E6%A3%84%E3%81%AF%E3%80%81%E5%90%8C%E4%B8%80%E3%81%BE%E3%81%9F%E3%81%AF%E7%95%B0%E3%81%AA%E3%82%8B%E6%9D%A1%E9%A0%85%E3%81%AE%E3%81%9D%E3%81%AE%E4%BB%96%E3%81%AE%E9%81%95%E5%8F%8D%E3%81%BE%E3%81%9F%E3%81%AF%E3%81%9D%E3%81%AE%E5%BE%8C%E3%81%AE%E9%81%95%E5%8F%8D%E3%81%AB%E5%AF%BE%E3%81%99%E3%82%8B%E6%A8%A9%E5%88%A9%E6%94%BE%E6%A3%84%E3%81%A8%E3%81%AF%E8%A7%A3%E9%87%88%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%20style%3D%22margin-top%3A%20auto%3B%20margin-bottom%3A%20auto%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%20font-size%3A%2010pt%3B%22%3E%C2%A9%202004-2014%20%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%BB%E3%83%9F%E3%82%B3%E3%83%B3%E3%83%80%E3%82%AF%E3%82%BF%E3%83%BC%E6%A0%AA%E5%BC%8F%E4%BC%9A%E7%A4%BE%E5%85%A8%E8%91%97%E4%BD%9C%E6%A8%A9%E6%89%80%E6%9C%89%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-TEASER%20id%3D%22lingo-teaser-1107197%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%B7%BB%E4%BB%98%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%AF%E3%80%81Kinetis%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E7%94%A8%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%83%BB%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BB%E3%83%95%E3%83%A5%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%83%BB%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%AE%E6%AC%A1%E6%9C%9F%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AE%E3%83%97%E3%83%AC%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E7%89%88%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%83%97%E3%83%AC%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E7%89%88%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E6%96%B0%E3%81%97%E3%81%84%E5%A4%89%E6%9B%B4%E3%81%AB%E5%AF%BE%E5%BF%9C%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%81%A8%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%AC%E3%82%A4%E3%83%89%E3%81%AE%E6%9B%B4%E6%96%B0%E3%81%AB%E3%81%BE%E3%81%A0%E5%8F%96%E3%82%8A%E7%B5%84%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%82%B3%E3%83%94%E3%83%BC%E3%81%AB%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%81%A8%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%AC%E3%82%A4%E3%83%89%E3%81%AF%E3%80%81%20%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fhttp%3A%2F%2Fwww.freescale.com%2Fsensorfusion%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwww.freescale.com%2Fsensorfusion%3C%2FA%3E%20%E3%81%AB%E3%81%82%E3%82%8B%E7%8F%BE%E5%9C%A8%E3%81%AE%E8%A3%BD%E5%93%81%E7%89%88%E3%81%A8%E5%90%8C%E3%81%98%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%99%E3%82%8B%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%AE%E6%9C%80%E5%88%9D%E3%81%AE%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%A7%E3%81%99%E3%80%82%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%81%AF%E4%BB%A5%E5%89%8D%E3%81%AE%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%8B%E3%82%89%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%81%A6%E3%81%8A%E3%82%89%E3%81%9A%E3%80%81%E3%81%93%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%AE%E6%9C%80%E5%BE%8C%E3%81%AB%E5%86%8D%E7%94%9F%E7%94%A3%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E6%9D%A1%E9%A0%85%E3%81%AB%E5%90%8C%E6%84%8F%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%AA%E3%81%84%E3%81%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%E3%81%AE%E3%82%A6%E3%82%A4%E3%83%AB%E3%82%B9%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BF%E3%83%BC%E3%82%92%E5%9B%9E%E9%81%BF%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E7%A7%81%E3%81%AF%E3%83%95%E3%83%A5%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%83%84%E3%83%BC%E3%83%AB%E3%82%AD%E3%83%83%E3%83%88%E3%81%AE%E7%B0%A1%E5%8D%98%E3%81%AAzip%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%A9%E3%83%BC%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%9F%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AB%E8%A7%A3%E5%87%8D%E3%81%99%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSTRONG%3EKinetis%20MCU%E5%90%91%E3%81%91%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%83%BB%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BB%E3%83%95%E3%83%A5%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%83%BB%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%AE%E3%83%97%E3%83%AC%E3%83%BB%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%83%BB%E3%83%8E%E3%83%BC%E3%83%88%3C%2FSTRONG%3E%3CBR%20%2F%3E%E4%BB%A5%E5%89%8D%E3%81%AE%E8%A3%BD%E5%93%81%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%3A%20%E3%83%93%E3%83%AB%E3%83%89%20417%3CBR%20%2F%3E%E3%81%93%E3%81%AE%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%3A%20%E3%83%93%E3%83%AB%E3%83%89%20420%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%A1%E3%82%89%E3%81%AF%E3%83%97%E3%83%AC%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%AD%E3%83%83%E3%83%88%E3%81%A7%E3%81%99%E3%80%82%E4%BB%98%E5%B1%9E%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%81%A8%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%20%E3%82%AC%E3%82%A4%E3%83%89%E3%81%AF%E3%80%81%E4%BB%A5%E5%89%8D%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%20(%E3%83%93%E3%83%AB%E3%83%89%20417)%20%E3%81%AB%E9%96%A2%E9%80%A3%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E6%9B%B4%E6%96%B0%E3%81%AF%E9%80%B2%E8%A1%8C%E4%B8%AD%E3%81%A7%E3%80%81%E3%81%BE%E3%82%82%E3%81%AA%E3%81%8F%E5%85%AC%E9%96%8B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%81%9D%E3%82%8C%E3%81%BE%E3%81%A7%E3%81%AE%E9%96%93%E3%80%81(%E5%A4%A7%E3%81%BE%E3%81%8B%E3%81%AB)%E5%A4%89%E6%9B%B4%E7%82%B9%E3%82%92%E4%BB%A5%E4%B8%8B%E3%81%AB%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E5%A4%89%E9%81%B7%EF%BC%9A%3CBR%20%2F%3E1.%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E6%A9%9F%E8%83%BD%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E2.%20Fusion%E3%81%8A%E3%82%88%E3%81%B3%E7%A3%81%E6%B0%97%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%8C%E3%82%BD%E3%83%BC%E3%82%B9%E5%BD%A2%E5%BC%8F%E3%81%AB%E5%90%AB%E3%81%BE%E3%82%8C%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82libFusion.a%20%E3%81%AF%E3%81%AA%E3%81%8F%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81Sources%20%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E5%86%85%E3%81%AE%E8%BF%BD%E5%8A%A0%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E7%BD%AE%E3%81%8D%E6%8F%9B%E3%81%88%E3%82%89%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E3.%20Kinetis%20Design%20Studio%E3%81%AE%E3%83%86%E3%83%B3%E3%83%97%E3%83%AC%E3%83%BC%E3%83%88%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E8%BF%BD%E5%8A%A0%3CBR%20%2F%3E4.%20KL46Z%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E8%BF%BD%E5%8A%A0%3CBR%20%2F%3E5.%20%3CA%20_jive_internal%3D%22true%22%20class%3D%22jivecontainerTT-hover-container%20jive-link-community-small%22%20data-containerid%3D%2211146%22%20data-containertype%3D%2214%22%20data-objectid%3D%2211236%22%20data-objecttype%3D%2214%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fcommunity%2Fsensors%2Fsensorfusion%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fcommunity%2Fsensors%2Fsensorfusion%3C%2FA%3E%20%E3%81%A7%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%82%8B%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%3CBR%20%2F%3E6.%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%81%8C%E6%9B%B4%E6%96%B0%E3%81%95%E3%82%8C%E3%80%81%E3%82%B7%E3%83%9F%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%95%E3%82%8C%E3%81%9F%E3%83%95%E3%83%A5%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%83%A1%E3%83%88%E3%83%AA%E3%82%AF%E3%82%B9%E3%80%81%E3%82%B3%E3%83%BC%E3%83%89%E3%82%B5%E3%82%A4%E3%82%BA%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%E3%82%B5%E3%82%A4%E3%82%B9%E3%83%86%E3%82%A3%E3%83%83%E3%82%AF%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%E3%81%8C%E8%BF%BD%E5%8A%A0%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E7.%20%E3%80%8CFLASH_EU%E3%80%8D%E3%81%AE%E5%AF%BE%E8%B1%A1%E5%90%8D%E3%82%92%E3%80%8CFLASH%E3%80%8D%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E8.%20%E3%83%96%E3%83%A9%E3%83%B3%E3%83%89%E3%82%92%E3%80%8CXtrinsic%E3%80%8D%E3%81%8B%E3%82%89%E3%80%8CFreescale%E3%80%8D%E3%81%AB%E5%A4%89%E6%9B%B4%E3%80%82%E3%81%93%E3%82%8C%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AE%E6%8E%A5%E9%A0%AD%E8%BE%9E%E3%81%8C%20%22XSFK_%22%20%E3%81%8B%E3%82%89%20%22FSFK_%22%20%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E9.%E5%8A%A0%E9%80%9F%E5%BA%A6%E8%A8%88%2B%E7%A3%81%E5%8A%9B%E8%A8%88%E3%81%AE6%E8%BB%B8%E3%82%AB%E3%83%AB%E3%83%9E%E3%83%B3%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BF%E3%83%BC%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F(eCompass%E3%81%AE%E5%AE%9F%E8%A3%85%E3%81%AF%E3%82%88%E3%82%8A%E5%8A%B9%E7%8E%87%E7%9A%84%E3%81%A7%E3%81%99)%3CBR%20%2F%3E10.%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%83%91%E3%82%B1%E3%83%83%E3%83%88%E3%81%8C%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%A7%E3%82%AA%E3%83%B3%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%82%8C%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81Sensor%20Fusion%20Toolkit%20for%20Android%20%E3%81%AF%E3%80%81%E9%9B%BB%E6%BA%90%E6%8A%95%E5%85%A5%E6%99%82%E3%81%AB%E6%AD%A3%E3%81%97%E3%81%84%E3%83%9C%E3%83%BC%E3%83%89%20%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%A7%E8%B5%B7%E5%8B%95%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E11.%E6%AC%A1%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E5%90%8D%E5%89%8D%E3%81%8C%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3EFSL_utils.c%2F.h%20%E3%81%AF%20drivers.c%2F.h%20%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Etasks_func.c%2F.h%20%E3%81%AF%20tasks.c%2F.h%20%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Eproj_config.h%20%E3%81%AF%20build.h%20%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3BProcessorExpert.c%20%E3%81%AF%20main.c%20%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3Bbaranski_kalman.h%20%E3%81%AF%20kalman.h%20%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E12.%20%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9.h%E5%89%8A%E9%99%A4%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E13.KL46Z%E7%94%A8%E3%81%AE%E3%83%99%E3%82%A2%E3%83%A1%E3%82%BF%E3%83%ABeCompass%E5%AE%9F%E8%A3%85%E3%82%92%E8%BF%BD%E5%8A%A0(MQXLite%E3%81%AA%E3%81%97)%3CBR%20%2F%3E14.%E3%81%93%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AB%E3%81%AF%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%20KDS%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AE%E5%AE%9F%E8%A1%8C%E6%A7%8B%E6%88%90%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%8F%E3%81%91%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E9%A0%86%E5%88%97%E3%81%8C%E5%A4%9A%E3%81%99%E3%81%8E%E3%81%A6%E3%80%81%E3%83%84%E3%83%BC%E3%83%AB%E3%81%AF%E5%AE%9A%E6%9C%9F%E7%9A%84%E3%81%AB%E6%9B%B4%E6%96%B0%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E6%AD%A3%E8%AA%A4%E8%A1%A8%EF%BC%9A%3CBR%20%2F%3E1.%20%E6%96%B0%E3%81%97%E3%81%84K64F%20Freedom%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AF%E3%80%81OpenSDA%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%AE%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E7%95%B0%E3%81%AA%E3%82%8B%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E5%88%A9%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82MBED%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AF%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%E3%82%BB%E3%82%AD%E3%83%A5%E3%83%AA%E3%83%86%E3%82%A3%E3%82%92%E9%81%A9%E5%88%87%E3%81%AB%E5%87%A6%E7%90%86%E3%81%9B%E3%81%9A%E3%80%81%E4%B8%80%E6%99%82%E7%9A%84%E3%81%AB%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%20%22%E3%83%96%E3%83%AA%E3%83%83%E3%82%AF%22%20%E3%81%99%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E6%A9%9F%E8%83%BD%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E6%A9%9F%E8%83%BD%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%81%AF%E3%80%81%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E5%90%8D%20Generated_Files%2FCPU_Config.h%20%E5%86%85%E3%81%AECPU_FLASH_CONFIG_FIELD%E3%81%AE%20NV_FSEC%20%E9%83%A8%E5%88%86%E3%81%AE%E5%80%A4%E3%81%8C%200xFE%20%E3%81%A7%E3%81%82%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82Processor%20Expert%20(%E3%81%93%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E7%94%9F%E6%88%90%E3%81%99%E3%82%8B)%20%E3%81%AF%E3%80%81%E7%8F%BE%E5%9C%A8%E3%81%9D%E3%81%AE%E5%80%A4%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82Processor%20Expert%20%E3%81%AE%E5%AE%9F%E8%A1%8C%E5%BE%8C%E3%81%AB%E3%80%81%E6%89%8B%E5%8B%95%E3%81%A7%E5%A4%89%E6%9B%B4%E3%82%92%E8%A1%8C%E3%81%86%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E2.%20KDS%20%E3%81%A7%E5%88%9D%E3%82%81%E3%81%A6%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%80%8C%E3%83%93%E3%83%83%E3%83%88%E3%83%9E%E3%82%B9%E3%82%AF%E3%82%92%E6%8C%87%E5%AE%9A%E3%81%9B%E3%81%9A%E3%81%AB%20APSR%20%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%E3%80%8D%E3%81%A8%E3%81%84%E3%81%86%E3%82%A8%E3%83%A9%E3%83%BC%20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E7%84%A1%E5%8A%B9%E3%81%AA%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%A7%E3%81%99%E3%80%822%E5%9B%9E%E7%9B%AE%E3%81%AB%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AF%E6%B6%88%E3%81%88%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E3.%20MQXLite%201.1.0Processor%20Expert%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E4%BD%9C%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%E3%80%81K64F%E3%81%AE%E6%B5%AE%E5%8B%95%E5%B0%8F%E6%95%B0%E7%82%B9%E3%83%A6%E3%83%8B%E3%83%83%E3%83%88%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%86%E3%82%AD%E3%82%B9%E3%83%88%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E5%87%A6%E7%90%86%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E5%87%BA%E8%8D%B7%E6%99%82%E3%81%AB%E3%81%AF%E3%80%81%E6%B5%AE%E5%8B%95%E5%B0%8F%E6%95%B0%E7%82%B9%E8%A8%88%E7%AE%97%E3%81%AF%E9%80%9A%E5%B8%B8%201%20%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E6%9C%9F%E9%96%93%E5%86%85%E3%81%AB%E5%AE%8C%E4%BA%86%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E5%95%8F%E9%A1%8C%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E3%81%9D%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%20%E3%83%86%E3%83%B3%E3%83%97%E3%83%AC%E3%83%BC%E3%83%88%E3%81%AB%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%A6%E3%80%81%E8%A8%88%E7%AE%97%E3%81%8C%201%20%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E6%9C%9F%E9%96%93%E3%82%92%E8%B6%85%E3%81%88%E3%82%8B%E3%81%A8%E3%80%81%E8%AA%A4%E3%81%A3%E3%81%9F%E7%B5%90%E6%9E%9C%E3%81%8C%E5%BE%97%E3%82%89%E3%82%8C%E3%81%BE%E3%81%99%20(%E8%AD%A6%E5%91%8A%E3%81%AF%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93)%E3%80%82MQXLite%201.1.1%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82Processor%20Expert%E3%81%AEMQX1%E8%A8%AD%E5%AE%9A%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%80%81%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E4.%20I2C%E4%BC%9D%E9%80%81%E9%80%9F%E5%BA%A6%E3%81%AF300KHz%E3%81%8B%E3%82%89400KHz%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%93%E3%83%AB%E3%83%89%20%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E4%B8%AD%E3%81%AB%E3%80%81%E6%AC%A1%E3%81%AE%E7%82%B9%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%82%8B%E3%81%AE%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%80%8C%E8%AD%A6%E5%91%8A%3A%E3%81%93%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AF%E6%9C%80%E5%A4%A7100kHz%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E8%A8%AD%E8%A8%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82(SCL%E5%91%A8%E6%B3%A2%E6%95%B0)%E3%80%8D%E3%80%82%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%E9%96%8B%E7%99%BA%E3%83%81%E3%83%BC%E3%83%A0%E3%81%AF%E6%97%A5%E5%B8%B8%E7%9A%84%E3%81%AB%E3%82%88%E3%82%8A%E9%AB%98%E3%81%84I2C%E5%91%A8%E6%B3%A2%E6%95%B0%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AF%E5%BF%85%E3%81%9A%E3%81%97%E3%82%82%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%81%A7%E4%BF%9D%E8%A8%BC%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%8F%E3%81%91%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%9D%E3%81%AE%E4%BB%96%E3%81%AE%E8%AD%A6%E5%91%8A%E3%81%AF%E3%80%81Processor%20Expert%20%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%20MQXLite%20%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8B%E3%82%89%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E5%AE%9F%E9%9A%9B%E3%81%AE%E8%9E%8D%E5%90%88%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%AF%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%81%A7%E3%81%82%E3%82%8B%E3%81%A8%E8%80%83%E3%81%88%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20align%3D%22center%22%20style%3D%22text-align%3A%20center%3B%20margin-bottom%3A%2012pt%3B%22%3E%3CSPAN%20class%3D%22grame%22%20style%3D%22color%3A%20black%3B%20font-size%3A%2010pt%3B%22%3E%3CSTRONG%3EKinetis%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E7%94%A8Xtrinsic%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BB%E3%83%95%E3%83%A5%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%83%BB%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%2012pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2010pt%3B%22%3E%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%3A%20LA_OPT50%20Version%2020%20January%202014%3C%2FSPAN%3E%3C%2FP%3E%3COL%20style%3D%22list-style-type%3A%20upper-roman%3B%22%3E%3CLI%3E%3CSPAN%20class%3D%22grame%22%20style%3D%22color%3A%20black%3B%20font-size%3A%2010pt%3B%22%3E%3CSTRONG%3E%E5%A4%A7%E4%BA%8B%E3%81%AA%E3%80%82%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2010pt%3B%20font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E%3CSTRONG%3E%20%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%83%BB%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%BB%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E5%A5%91%E7%B4%84%20(%E4%BB%A5%E4%B8%8B%E3%80%8C%E6%9C%AC%E5%A5%91%E7%B4%84%E3%80%8D)%20%E3%82%92%E3%82%88%E3%81%8F%E3%81%8A%E8%AA%AD%E3%81%BF%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%20%E3%81%93%E3%81%AE%E3%83%9A%E3%83%BC%E3%82%B8%E3%81%AE%E6%9C%80%E5%BE%8C%E3%81%AB%E3%81%82%E3%82%8B%E3%80%8C%E5%90%8C%E6%84%8F%E3%81%99%E3%82%8B%E3%80%8D%E3%83%9C%E3%82%BF%E3%83%B3%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AF%E6%9C%AC%E5%A5%91%E7%B4%84%E3%81%AE%E6%9D%A1%E4%BB%B6%E3%81%AB%E5%90%8C%E6%84%8F%E3%81%97%E3%80%81%E3%81%BE%E3%81%9F%E3%80%81%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AE%E4%BC%9A%E7%A4%BE%E3%82%92%E4%BB%A3%E8%A1%A8%E3%81%97%E3%81%A6%E3%80%81%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AE%E4%BC%9A%E7%A4%BE%E3%82%92%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E6%9D%A1%E4%BB%B6%E3%81%AB%E6%8B%98%E6%9D%9F%E3%81%99%E3%82%8B%E6%A8%A9%E9%99%90%E3%82%92%E6%9C%89%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E8%AA%8D%E3%82%81%E3%81%9F%E3%81%93%E3%81%A8%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%20%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%BE%E3%81%9F%E3%81%AF%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%20align%3D%22center%22%20style%3D%22text-align%3A%20center%3B%20margin-bottom%3A%2012pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-size%3A%2010pt%3B%20text-decoration%3A%20underline%3B%20font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%83%BB%E3%82%A8%E3%83%B3%E3%83%89%E3%83%BB%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BB%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%BB%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E5%A5%91%E7%B4%84%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%2012pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%20color%3A%20black%3B%20font-size%3A%2010pt%3B%22%3E%E6%9C%AC%E5%A5%91%E7%B4%84%E3%81%AF%E3%80%81%E3%81%8A%E5%AE%A2%E6%A7%98%20(%E5%80%8B%E4%BA%BA%E3%81%BE%E3%81%9F%E3%81%AF%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AE%E9%9B%87%E7%94%A8%E4%B8%BB%E3%81%AE%E4%BB%A3%E7%90%86%E4%BA%BA)%20%E3%81%A8%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%83%BB%E3%82%BB%E3%83%9F%E3%82%B3%E3%83%B3%E3%83%80%E3%82%AF%E3%82%BF%E3%83%BC%E3%83%BB%E3%82%A4%E3%83%B3%E3%82%AF%20(%E4%BB%A5%E4%B8%8B%E3%80%8C%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%80%8D)%20%E3%81%A8%E3%81%AE%E9%96%93%E3%81%A7%E7%B7%A0%E7%B5%90%E3%81%95%E3%82%8C%E3%82%8B%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E5%A5%91%E7%B4%84%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%8A%E3%82%88%E3%81%B3%E4%BB%98%E9%9A%8F%E3%81%99%E3%82%8B%E6%9B%B8%E9%9D%A2%E8%B3%87%E6%96%99(%E4%BB%A5%E4%B8%8B%E3%80%8C%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%80%8D)%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AE%E6%A8%A9%E5%88%A9%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E3%82%82%E3%81%AE%E3%81%A7%E3%81%99%E3%80%82%E6%9C%AC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AB%E3%81%AF%E3%80%81%E6%9C%AC%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%8B%E3%82%89%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AB%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%82%8B%E6%9C%AC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AB%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E6%9B%B4%E6%96%B0%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%E4%BF%AE%E6%AD%A3%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%8C%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AB%E6%9C%AC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%B8%E3%81%AE%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%82%92%E8%A8%B1%E5%8F%AF%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E8%80%83%E6%85%AE%E3%81%97%E3%81%A6%E3%80%81%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AF%E6%9C%AC%E5%A5%91%E7%B4%84%E3%81%AE%E6%9D%A1%E9%A0%85%E3%81%AB%E6%8B%98%E6%9D%9F%E3%81%95%E3%82%8C%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E5%90%8C%E6%84%8F%E3%81%99%E3%82%8B%E3%82%82%E3%81%AE%E3%81%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E6%9C%AC%E5%A5%91%E7%B4%84%E3%81%AE%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E6%9D%A1%E9%A0%85%E3%81%AB%E5%90%8C%E6%84%8F%E3%81%97%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E6%9C%AC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%BE%E3%81%9F%E3%81%AF%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%20%3CSPAN%20class%3D%22grame%22%3E%E3%81%97%E3%81%AA%E3%81%84%E3%81%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FSPAN%3E%20%E3%80%82%E5%BE%8C%E3%81%A7%E6%B0%97%E3%81%8C%E5%A4%89%E3%82%8F%E3%81%A3%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E4%BD%BF%E7%94%A8%E3%82%92%E4%B8%AD%E6%AD%A2%E3%81%97%E3%80%81%E6%89%80%E6%9C%89%E3%81%BE%E3%81%9F%E3%81%AF%E7%AE%A1%E7%90%86%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%B3%E3%83%94%E3%83%BC%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%8C%E6%97%A2%E3%81%AB%E9%85%8D%E5%B8%83%E3%81%97%E3%80%81%E8%A8%B1%E5%8F%AF%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E7%A0%B4%E6%A3%84%E3%81%97%E3%81%AA%E3%81%84%E6%9C%AC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E3%82%B3%E3%83%94%E3%83%BC%E3%81%AF%E3%80%81%E5%BC%95%E3%81%8D%E7%B6%9A%E3%81%8D%E6%9C%AC%E5%A5%91%E7%B4%84%E3%81%AB%E6%BA%96%E6%8B%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AE%E5%BE%93%E5%89%8D%E3%81%AE%E4%BD%BF%E7%94%A8%E3%82%82%E3%80%81%E5%BC%95%E3%81%8D%E7%B6%9A%E3%81%8D%E6%9C%AC%E5%A5%91%E7%B4%84%E3%81%AB%E6%BA%96%E6%8B%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3COL%20style%3D%22list-style-type%3A%20decimal%3B%22%3E%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%20font-size%3A%2010pt%3B%22%3E1.%20%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%81%AE%E4%BB%98%E4%B8%8E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%E3%80%82%3C%2FSPAN%3E%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B7%E3%83%BC%E3%81%8C%E3%80%81%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%8B%E3%82%89%E7%9B%B4%E6%8E%A5%E7%9A%84%E3%81%BE%E3%81%9F%E3%81%AF%E9%96%93%E6%8E%A5%E7%9A%84%E3%81%AB%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%82%8B%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%20%3CSPAN%20class%3D%22spelle%22%3E%E3%81%AEXtrinsic%3C%2FSPAN%3E%20%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BB%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20(%E5%8A%A0%E9%80%9F%E5%BA%A6%E8%A8%88%E3%80%81%E7%A3%81%E5%8A%9B%E8%A8%88%E3%80%81%E3%83%87%E3%82%A3%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%88%E3%81%BE%E3%81%9F%E3%81%AF%E8%A4%87%E5%90%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%83%BB%E3%83%95%E3%82%A1%E3%82%AF%E3%82%BF%E3%81%AE%E3%82%B8%E3%83%A3%E3%82%A4%E3%83%AD%E3%83%BB%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%97%E3%81%AA%E3%81%A9)%20%E3%82%92%E5%90%AB%E3%82%80%E8%A3%BD%E5%93%81%20(%E4%BB%A5%E4%B8%8B%E3%80%8C%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%83%BB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%80%8D%E3%81%A8%E3%81%84%E3%81%84%E3%81%BE%E3%81%99)%20%E3%82%92%E9%96%8B%E7%99%BA%E3%81%8A%E3%82%88%E3%81%B3%E8%B2%A9%E5%A3%B2%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%83%BB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AE%E4%BD%BF%E7%94%A8%E3%81%AB%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%E6%95%99%E8%82%B2%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%AE%E9%96%8B%E7%99%BA%E3%81%8A%E3%82%88%E3%81%B3%E8%B2%A9%E5%A3%B2%E3%81%AB%E9%96%A2%E9%80%A3%E3%81%97%E3%81%A6%E3%80%81%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AF%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AB%E7%84%A1%E5%84%9F%E3%81%A7%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%81%93%E3%81%A8%E3%82%92%E8%A8%B1%E8%AB%BE%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%20(1)%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E4%BD%BF%E7%94%A8%E3%80%81(2)%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E8%A4%87%E8%A3%BD%E3%80%81(3)%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E6%B4%BE%E7%94%9F%E7%89%A9%E3%81%AE%E4%BD%9C%E6%88%90%E3%80%81(4)%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%8A%E3%82%88%E3%81%B3%E3%81%9D%E3%81%AE%E6%B4%BE%E7%94%9F%E7%89%A9%E3%82%92%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%83%BB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AE%E4%B8%80%E9%83%A8%E3%81%A8%E3%81%97%E3%81%A6%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88(%E6%A9%9F%E6%A2%B0%E5%8F%AF%E8%AA%AD)%E5%BD%A2%E5%BC%8F%E3%81%A7%E9%85%8D%E5%B8%83%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3(5)%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%83%BB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AB%E5%90%AB%E3%81%BE%E3%82%8C%E3%82%8B%E9%85%8D%E5%B8%83%E3%81%95%E3%82%8C%E3%81%9F%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E6%A8%A9%E5%88%A9%E3%82%92%E4%BB%96%E8%80%85%E3%81%AB%E3%82%B5%E3%83%96%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%81%99%E3%82%8B%E3%80%81%E9%9D%9E%E7%8B%AC%E5%8D%A0%E7%9A%84%E3%81%8B%E3%81%A4%E8%AD%B2%E6%B8%A1%E4%B8%8D%E8%83%BD%E3%81%AA%E6%A8%A9%E5%88%A9%E3%80%82%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%8C%E6%9C%AC%E5%A5%91%E7%B4%84%E3%81%AE%E3%81%84%E3%81%9A%E3%82%8C%E3%81%8B%E3%81%AE%E6%9D%A1%E9%A0%85%E3%81%BE%E3%81%9F%E3%81%AF%E5%88%B6%E9%99%90%E3%81%AB%E9%81%95%E5%8F%8D%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AF%E6%9C%AC%E5%A5%91%E7%B4%84%E3%82%92%E7%9B%B4%E3%81%A1%E3%81%AB%E7%B5%82%E4%BA%86%E3%81%97%E3%80%81%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%8C%E6%89%80%E6%9C%89%E3%81%BE%E3%81%9F%E3%81%AF%E7%AE%A1%E7%90%86%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E6%9C%AC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E4%BD%BF%E7%94%A8%E3%82%92%E4%B8%AD%E6%AD%A2%E3%81%97%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%B3%E3%83%94%E3%83%BC%E3%82%92%E5%89%8A%E9%99%A4%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E8%A6%81%E6%B1%82%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E4%B8%8A%E8%A8%98%E3%81%A7%E4%BB%98%E4%B8%8E%E3%81%95%E3%82%8C%E3%81%9F%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%81%AF%E3%80%81%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%8C%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AB%E6%8F%90%E4%BE%9B%E3%81%97%E3%80%81%E4%BB%98%E4%B8%8E%E3%81%95%E3%82%8C%E3%81%9F%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%81%AE%E7%AF%84%E5%9B%B2%E5%86%85%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8B%E6%9C%AC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E5%BF%85%E7%84%B6%E7%9A%84%E3%81%AB%E4%BE%B5%E5%AE%B3%E3%81%95%E3%82%8C%E3%82%8B%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AE%E7%9F%A5%E7%9A%84%E8%B2%A1%E7%94%A3%E6%A8%A9%E3%81%AB%E3%81%AE%E3%81%BF%E9%81%A9%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AF%E3%80%81%E5%95%8F%E9%A1%8C%E3%82%84%E3%81%9D%E3%81%AE%E6%94%B9%E5%96%84%E6%8F%90%E6%A1%88%E3%82%92%E5%90%AB%E3%82%81%E3%80%81%E5%BE%97%E3%82%89%E3%82%8C%E3%81%9F%E7%B5%90%E6%9E%9C%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AB%E9%80%9A%E7%9F%A5%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AF%E3%80%81%E9%81%A9%E5%88%87%E3%81%A8%E6%80%9D%E3%82%8F%E3%82%8C%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%A7%E3%80%81%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E7%B5%90%E6%9E%9C%E3%81%8A%E3%82%88%E3%81%B3%E9%96%A2%E9%80%A3%E6%83%85%E5%A0%B1%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E6%A8%A9%E5%88%A9%E3%82%92%E7%95%99%E4%BF%9D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%20color%3A%20black%3B%20font-size%3A%2010pt%3B%22%3E2.%20%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%E3%81%9D%E3%81%AE%E4%BB%96%E3%81%AE%E5%88%B6%E9%99%90%3C%2FSTRONG%3E%3C%2FSPAN%3E%E3%80%82%E4%B8%8A%E8%A8%98%E3%81%AE%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E4%BB%98%E4%B8%8E%E3%82%92%E6%9D%A1%E4%BB%B6%E3%81%A8%E3%81%97%E3%81%A6%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E5%88%B6%E9%99%90%E3%81%8C%E9%81%A9%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%20color%3A%20black%3B%20font-size%3A%2010pt%3B%22%3E%E3%81%82%E3%82%8B%E3%80%82%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AF%E3%80%81%E6%9C%AC%E5%A5%91%E7%B4%84%E3%81%A7%E6%98%8E%E7%A4%BA%E7%9A%84%E3%81%AB%E4%BB%98%E4%B8%8E%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E6%A8%A9%E5%88%A9%E3%82%92%E7%95%99%E4%BF%9D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%20color%3A%20black%3B%20font-size%3A%2010pt%3B%22%3Eb.%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AF%E3%80%81%E6%9C%AC%E5%A5%91%E7%B4%84%E5%86%85%E3%81%A7%E6%98%8E%E7%A4%BA%E7%9A%84%E3%81%AB%E5%90%8C%E6%84%8F%E3%81%97%E3%81%AA%E3%81%84%E9%99%90%E3%82%8A%E3%80%81%E6%9C%AC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E3%83%AC%E3%83%B3%E3%82%BF%E3%83%AB%E3%80%81%E3%83%AA%E3%83%BC%E3%82%B9%E3%80%81%E3%82%B5%E3%83%96%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%80%81%E8%B2%B8%E4%B8%8E%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E6%8B%85%E4%BF%9D%E3%81%AB%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%20color%3A%20black%3B%20font-size%3A%2010pt%3B%22%3Ec.%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AF%E3%80%81%E6%9C%AC%E5%A5%91%E7%B4%84%E3%81%A7%E6%84%8F%E5%9B%B3%E3%81%95%E3%82%8C%E3%81%9F%E4%BB%A5%E5%A4%96%E3%81%AE%E7%9B%AE%E7%9A%84%E3%81%A7%E3%80%81%E6%9C%AC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E9%85%8D%E5%B8%83%E3%80%81%E8%A3%BD%E9%80%A0%E3%80%81%E8%A3%BD%E9%80%A0%E3%80%81%E3%82%B5%E3%83%96%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E3%81%9D%E3%81%AE%E4%BB%96%E3%81%AE%E6%96%B9%E6%B3%95%E3%81%A7%E8%A4%87%E8%A3%BD%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%20color%3A%20black%3B%20font-size%3A%2010pt%3B%22%3Ed.%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AB%E5%90%AB%E3%81%BE%E3%82%8C%E3%82%8B%E6%89%80%E6%9C%89%E6%A8%A9%E3%81%AE%E5%87%A1%E4%BE%8B%E3%80%81%E9%80%9A%E7%9F%A5%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E5%95%86%E6%A8%99%E3%82%92%E5%89%8A%E9%99%A4%E3%81%BE%E3%81%9F%E3%81%AF%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%20color%3A%20black%3B%20font-size%3A%2010pt%3B%22%3Ee.%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E6%9C%AC%E5%A5%91%E7%B4%84%E3%81%AE%E6%9D%A1%E9%A0%85%E3%81%AF%E3%80%81%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AE%E8%A3%81%E9%87%8F%E3%81%AB%E3%82%88%E3%82%8A%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AB%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%82%8B%E3%80%81%E5%85%83%E3%81%AE%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E7%BD%AE%E3%81%8D%E6%8F%9B%E3%81%88%E3%81%9F%E3%82%8A%E8%A3%9C%E8%B6%B3%E3%81%97%E3%81%9F%E3%82%8A%E3%81%99%E3%82%8B%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%BB%E3%82%A2%E3%83%83%E3%83%97%E3%83%87%E3%83%BC%E3%83%88%E3%81%AB%E9%81%A9%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E5%BD%93%E8%A9%B2%E3%82%A2%E3%83%83%E3%83%97%E3%83%87%E3%83%BC%E3%83%88%E3%81%AB%E5%88%A5%E5%80%8B%E3%81%AE%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%82%92%E9%99%A4%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%20color%3A%20black%3B%20font-size%3A%2010pt%3B%22%3Ef.%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AF%E3%80%81%E9%81%A9%E7%94%A8%E6%B3%95%E3%81%8C%E7%89%B9%E3%81%AB%E5%88%B6%E9%99%90%E3%82%92%E7%A6%81%E3%81%98%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%82%92%E9%99%A4%E3%81%8D%E3%80%81%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%81%9F%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E3%82%AA%E3%83%96%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%B3%E3%83%BC%E3%83%89%E5%BD%A2%E5%BC%8F(%E6%A9%9F%E6%A2%B0%E5%8F%AF%E8%AA%AD)%E3%81%AE%E3%81%BF%E3%81%A7%E7%BF%BB%E8%A8%B3%E3%80%81%E3%83%AA%E3%83%90%E3%83%BC%E3%82%B9%E3%82%A8%E3%83%B3%E3%82%B8%E3%83%8B%E3%82%A2%E3%83%AA%E3%83%B3%E3%82%B0%E3%80%81%E9%80%86%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E9%80%86%E3%82%A2%E3%82%BB%E3%83%B3%E3%83%96%E3%83%AB%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AF%E3%80%81%E9%81%A9%E7%94%A8%E6%B3%95%E3%81%8C%E7%89%B9%E3%81%AB%E5%88%B6%E9%99%90%E3%82%92%E7%A6%81%E3%81%98%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%82%92%E9%99%A4%E3%81%8D%E3%80%81%20%3CSPAN%20class%3D%22spelle%22%3E%E3%82%B5%E3%83%96%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B7%E3%83%BC%3C%2FSPAN%3E%20%E3%81%8C%E6%9C%AC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E7%BF%BB%E8%A8%B3%E3%80%81%E3%83%AA%E3%83%90%E3%83%BC%E3%82%B9%E3%82%A8%E3%83%B3%E3%82%B8%E3%83%8B%E3%82%A2%E3%83%AA%E3%83%B3%E3%82%B0%E3%80%81%E9%80%86%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E9%80%86%E3%82%A2%E3%82%BB%E3%83%B3%E3%83%96%E3%83%AB%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A6%81%E6%AD%A2%E3%81%99%E3%82%8B%E3%82%82%E3%81%AE%E3%81%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%20color%3A%20black%3B%20font-size%3A%2010pt%3B%22%3E3.%20%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%E3%82%AA%E3%83%BC%E3%83%97%E3%83%B3%E3%82%BD%E3%83%BC%E3%82%B9%3C%2FSTRONG%3E%3C%2FSPAN%3E%E3%80%82%E6%9C%AC%E5%A5%91%E7%B4%84%E3%81%A7%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%81%95%E3%82%8C%E3%81%9F%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AB%E5%90%AB%E3%81%BE%E3%82%8C%E3%82%8B%E3%82%AA%E3%83%BC%E3%83%97%E3%83%B3%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AF%E3%80%81%E6%9C%AC%E5%A5%91%E7%B4%84%E3%81%AE%E6%9D%A1%E9%A0%85%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81BSD%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%80%81Apache%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%80%81Lesser%20GNU%20General%20Public%20License%E3%81%AA%E3%81%A9%E3%81%AE%E8%A9%B2%E5%BD%93%E3%81%99%E3%82%8B%E3%82%AA%E3%83%BC%E3%83%97%E3%83%B3%E3%82%BD%E3%83%BC%E3%82%B9%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%81%AE%E6%9D%A1%E4%BB%B6%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%82%AA%E3%83%BC%E3%83%97%E3%83%B3%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E4%BD%BF%E7%94%A8%E3%81%AB%E3%81%AF%E3%80%81%E8%A9%B2%E5%BD%93%E3%81%99%E3%82%8B%E5%90%84%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%81%AE%E6%9D%A1%E4%BB%B6%E3%81%8C%E9%81%A9%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AF%E3%80%81%E8%A9%B2%E5%BD%93%E3%81%99%E3%82%8B%E5%90%84%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%81%AE%E6%9D%A1%E4%BB%B6%E3%81%AB%E5%90%8C%E6%84%8F%E3%81%97%E3%81%AA%E3%81%91%E3%82%8C%E3%81%B0%E3%81%AA%E3%82%89%E3%81%9A%E3%80%81%E3%81%9D%E3%81%86%E3%81%A7%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%82%AA%E3%83%BC%E3%83%97%E3%83%B3%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%AA%E3%81%84%E3%81%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%20%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%20color%3A%20black%3B%20font-size%3A%2010pt%3B%22%3E4.%20%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%E8%91%97%E4%BD%9C%E6%A8%A9%3C%2FSTRONG%3E%3C%2FSPAN%3E%E3%80%82%E6%9C%AC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AF%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AB%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E4%BE%9B%E4%B8%8E%E3%81%95%E3%82%8C%E3%82%8B%E3%82%82%E3%81%AE%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E8%B2%A9%E5%A3%B2%E3%81%95%E3%82%8C%E3%82%8B%E3%82%82%E3%81%AE%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E6%9C%AC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AF%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%8C%E6%89%80%E6%9C%89%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E7%B1%B3%E5%9B%BD%E3%81%AE%E8%91%97%E4%BD%9C%E6%A8%A9%E6%B3%95%E3%81%8A%E3%82%88%E3%81%B3%E5%9B%BD%E9%9A%9B%E6%9D%A1%E7%B4%84%E3%81%AE%E8%A6%8F%E5%AE%9A%E3%81%AB%E3%82%88%E3%82%8A%E6%9C%AC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%8C%E4%BF%9D%E8%AD%B7%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AF%E3%80%81%E6%9C%AC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E4%BB%96%E3%81%AE%E8%91%97%E4%BD%9C%E7%89%A9(%E6%9B%B8%E7%B1%8D%E3%82%84%E9%9F%B3%E6%A5%BD%E9%8C%B2%E9%9F%B3%3CEM%3E%E3%81%AA%E3%81%A9%20%3C%2FEM%3E)%E3%81%A8%E5%90%8C%E6%A7%98%E3%81%AB%E6%89%B1%E3%81%86%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AF%E3%80%81%E6%9C%AC%E5%A5%91%E7%B4%84%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E4%BB%A5%E5%A4%96%E3%81%AE%E7%9B%AE%E7%9A%84%E3%81%A7%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%BE%E3%81%9F%E3%81%AF%E3%82%B3%E3%83%94%E3%83%BC%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E6%9C%AC%E5%A5%91%E7%B4%84%E3%81%AB%E6%98%8E%E7%A4%BA%E7%9A%84%E3%81%AB%E8%A6%8F%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%82%92%E9%99%A4%E3%81%8D%E3%80%81%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AF%E3%80%81%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%BE%E3%81%9F%E3%81%AF%E7%AC%AC%E4%B8%89%E8%80%85%E3%81%AE%E7%89%B9%E8%A8%B1%E3%80%81%E8%91%97%E4%BD%9C%E6%A8%A9%E3%80%81%E5%95%86%E6%A8%99%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E4%BC%81%E6%A5%AD%E7%A7%98%E5%AF%86%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%8F%E6%98%8E%E7%A4%BA%E7%9A%84%E3%81%BE%E3%81%9F%E3%81%AF%E9%BB%99%E7%A4%BA%E7%9A%84%E3%81%AA%E6%A8%A9%E5%88%A9%E3%82%92%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AB%E4%BB%98%E4%B8%8E%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%95%E3%82%89%E3%81%AB%E3%80%81%E6%9C%AC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AB%E5%90%AB%E3%81%BE%E3%82%8C%E3%82%8B%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E6%9C%AC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AB%E5%9F%8B%E3%82%81%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E8%91%97%E4%BD%9C%E6%A8%A9%E3%81%BE%E3%81%9F%E3%81%AF%E3%81%9D%E3%81%AE%E4%BB%96%E3%81%AE%E6%89%80%E6%9C%89%E6%A8%A9%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E9%80%9A%E7%9F%A5%E3%81%AF%E3%80%81%E3%81%9D%E3%81%AE%E5%85%A8%E9%83%A8%E3%81%BE%E3%81%9F%E3%81%AF%E4%B8%80%E9%83%A8%E3%81%8C%E4%BD%9C%E6%88%90%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%81%9D%E3%81%AE%E3%82%B3%E3%83%94%E3%83%BC%E3%81%AB%E8%A4%87%E8%A3%BD%E3%81%97%E3%81%A6%E9%81%A9%E7%94%A8%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AF%E3%80%81%E6%9C%AC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AB%E7%B5%84%E3%81%BF%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AE%E8%91%97%E4%BD%9C%E6%A8%A9%E8%A1%A8%E7%A4%BA%E3%82%92%E5%89%8A%E9%99%A4%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%20color%3A%20black%3B%20font-size%3A%2010pt%3B%22%3E5.%20%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%E6%9C%9F%E9%96%93%E3%81%8A%E3%82%88%E3%81%B3%E7%B5%82%E4%BA%86%3C%2FSTRONG%3E%3C%2FSPAN%3E%E3%80%82%E6%9C%AC%E5%A5%91%E7%B4%84%E3%81%AE%E6%9C%9F%E9%96%93%E3%81%AF%E3%80%81%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%AE%E6%97%A5%E3%81%AB%E9%96%8B%E5%A7%8B%E3%81%97%E3%80%81%E6%9C%AC%E5%A5%91%E7%B4%84%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E7%B5%82%E4%BA%86%E3%81%99%E3%82%8B%E3%81%BE%E3%81%A7%E7%B6%99%E7%B6%9A%E3%81%99%E3%82%8B%E3%82%82%E3%81%AE%E3%81%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AF%E3%80%81%E6%9C%AC%E5%A5%91%E7%B4%84%E3%82%92%E4%BA%88%E5%91%8A%E3%81%AA%E3%81%97%E3%81%AB%E7%B5%82%E4%BA%86%E3%81%99%E3%82%8B%E6%A8%A9%E5%88%A9%E3%82%92%E6%9C%89%E3%81%97%E3%80%81%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%8C%E6%9C%AC%E5%A5%91%E7%B4%84%E3%81%AE%E6%9D%A1%E9%A0%85%E3%81%BE%E3%81%9F%E3%81%AF%E5%88%B6%E9%99%90%E3%81%AB%E9%81%95%E5%8F%8D%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%8C%E6%89%80%E6%9C%89%E3%81%BE%E3%81%9F%E3%81%AF%E7%AE%A1%E7%90%86%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E6%9C%AC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%B3%E3%83%94%E3%83%BC%E3%82%92%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AB%E4%BD%BF%E7%94%A8%E3%82%92%E4%B8%AD%E6%AD%A2%E3%81%97%E3%80%81%E5%89%8A%E9%99%A4%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E8%A6%81%E6%B1%82%E3%81%99%E3%82%8B%E6%A8%A9%E5%88%A9%E3%82%92%E6%9C%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AF%E3%80%81%E6%9C%AC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E3%81%84%E3%81%9A%E3%82%8C%E3%81%8B%E3%81%8C%E7%9F%A5%E7%9A%84%E4%BE%B5%E5%AE%B3%E3%81%BE%E3%81%9F%E3%81%AF%E4%BC%81%E6%A5%AD%E7%A7%98%E5%AF%86%E3%81%AE%E4%B8%8D%E6%AD%A3%E6%B5%81%E7%94%A8%E3%81%AB%E5%AF%BE%E3%81%99%E3%82%8B%E7%94%B3%E3%81%97%E7%AB%8B%E3%81%A6%E3%81%AE%E5%AF%BE%E8%B1%A1%E3%81%A8%E3%81%AA%E3%81%A3%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AE%E5%90%88%E7%90%86%E7%9A%84%E3%81%AA%E5%88%A4%E6%96%AD%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81%E6%9C%AC%E5%A5%91%E7%B4%84%E3%82%92%E7%B5%82%E4%BA%86%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E5%A5%91%E7%B4%84%E7%B5%82%E4%BA%86%E6%99%82%E3%81%AB%E3%81%AF%E3%80%81%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E4%BD%BF%E7%94%A8%E3%82%92%E4%B8%AD%E6%AD%A2%E3%81%97%E3%80%81%E7%A0%B4%E6%A3%84%E3%81%97%E3%80%81%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6%E6%9B%B8%E9%9D%A2%E3%81%A7%E9%81%B5%E5%AE%88%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E5%A5%91%E7%B4%84%E3%81%8C%E7%B5%82%E4%BA%86%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E6%9C%AC%E5%A5%91%E7%B4%84%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E4%BB%98%E4%B8%8E%E3%81%95%E3%82%8C%E3%81%9F%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%81%AF%E7%9B%B4%E3%81%A1%E3%81%AB%E7%B5%82%E4%BA%86%E3%81%97%E3%80%81%E7%AC%AC4%E6%9D%A1%E3%81%8B%E3%82%89%E7%AC%AC18%E6%9D%A1%E3%81%BE%E3%81%A7%E3%81%AE%E8%A6%8F%E5%AE%9A%E3%81%AF%E3%80%81%E6%9C%AC%E5%A5%91%E7%B4%84%E3%81%AE%E7%B5%82%E4%BA%86%E5%BE%8C%E3%82%82%E5%AD%98%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%20color%3A%20black%3B%20font-size%3A%2010pt%3B%22%3E6.%20%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%3C%2FSTRONG%3E%3C%2FSPAN%3E%E3%80%82%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AF%E3%80%81%E6%9C%AC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%80%81%E3%82%A2%E3%83%83%E3%83%97%E3%82%B0%E3%83%AC%E3%83%BC%E3%83%89%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E6%96%B0%E8%A6%8F%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%99%E3%82%8B%E7%BE%A9%E5%8B%99%E3%82%92%E8%B2%A0%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%94%E5%B8%8C%E6%9C%9B%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AB%E3%81%94%E9%80%A3%E7%B5%A1%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%80%81%E6%9C%AC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E5%95%8F%E9%A1%8C%E3%82%92%E5%A0%B1%E5%91%8A%E3%81%97%E3%80%81%E3%81%94%E6%8F%90%E6%A1%88%E3%82%92%E3%81%8A%E9%80%81%E3%82%8A%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AF%E3%80%81%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E5%95%8F%E9%A1%8C%E5%A0%B1%E5%91%8A%E3%81%BE%E3%81%9F%E3%81%AF%E6%8F%90%E6%A1%88%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6%E3%80%81%E3%81%84%E3%81%8B%E3%81%AA%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%A7%E3%82%82%E5%AF%BE%E5%BF%9C%E3%81%99%E3%82%8B%E7%BE%A9%E5%8B%99%E3%82%92%E4%B8%80%E5%88%87%E8%B2%A0%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AF%E3%80%81%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E6%9B%B4%E6%96%B0%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AB%E9%80%9A%E7%9F%A5%E3%81%BE%E3%81%9F%E3%81%AF%E6%8F%90%E4%BE%9B%E3%81%99%E3%82%8B%E7%BE%A9%E5%8B%99%E3%82%92%E8%B2%A0%E3%81%86%E3%81%93%E3%81%A8%E3%81%AA%E3%81%8F%E3%80%81%E3%81%84%E3%81%A4%E3%81%A7%E3%82%82%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AB%E5%A4%89%E6%9B%B4%E3%82%92%E5%8A%A0%E3%81%88%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%20color%3A%20black%3B%20font-size%3A%2010pt%3B%22%3E7.%20%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%E7%84%A1%E4%BF%9D%E8%A8%BC%3C%2FSTRONG%3E%3C%2FSPAN%3E%E3%80%82%E6%B3%95%E5%BE%8B%E3%81%A7%E8%AA%8D%E3%82%81%E3%82%89%E3%82%8C%E3%82%8B%E6%9C%80%E5%A4%A7%E9%99%90%E3%81%AE%E7%AF%84%E5%9B%B2%E3%81%A7%E3%80%81%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AF%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AB%E5%AF%BE%E3%81%99%E3%82%8B%E3%81%84%E3%81%8B%E3%81%AA%E3%82%8B%E4%BF%9D%E8%A8%BC%E3%82%82%E6%98%8E%E7%A4%BA%E7%9A%84%E3%81%AB%E5%90%A6%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E6%9C%AC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AF%E3%80%8C%E7%8F%BE%E7%8A%B6%E3%81%AE%E3%81%BE%E3%81%BE%E3%80%8D%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%80%81%E5%95%86%E5%93%81%E6%80%A7%E3%80%81%E7%89%B9%E5%AE%9A%E7%9B%AE%E7%9A%84%E3%81%B8%E3%81%AE%E9%81%A9%E5%90%88%E6%80%A7%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E9%9D%9E%E4%BE%B5%E5%AE%B3%E3%81%AE%E9%BB%99%E7%A4%BA%E3%81%AE%E4%BF%9D%E8%A8%BC%E3%82%92%E5%90%AB%E3%82%80%E3%81%8C%E3%81%93%E3%82%8C%E3%82%89%E3%81%AB%E9%99%90%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%AA%E3%81%84%E3%80%81%E6%98%8E%E7%A4%BA%E3%81%BE%E3%81%9F%E3%81%AF%E9%BB%99%E7%A4%BA%E3%81%AE%E3%81%84%E3%81%8B%E3%81%AA%E3%82%8B%E7%A8%AE%E9%A1%9E%E3%81%AE%E4%BF%9D%E8%A8%BC%E3%82%82%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AF%E3%80%81%E6%9C%AC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E6%9C%AC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E8%A8%AD%E8%A8%88%E3%81%97%E3%81%9F%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0(%E5%AD%98%E5%9C%A8%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88)%E3%81%AE%E4%BD%BF%E7%94%A8%E3%81%BE%E3%81%9F%E3%81%AF%E6%80%A7%E8%83%BD%E3%81%8B%E3%82%89%E7%94%9F%E3%81%98%E3%82%8B%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%AA%E3%82%B9%E3%82%AF%E3%82%92%E8%B2%A0%E3%81%86%E3%82%82%E3%81%AE%E3%81%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E6%9C%AC%E5%A5%91%E7%B4%84%E3%81%AE%E3%81%84%E3%81%8B%E3%81%AA%E3%82%8B%E6%9D%A1%E9%A0%85%E3%82%82%E3%80%81%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%8C%E3%80%81%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%BE%E3%81%9F%E3%81%AF%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%A8%E3%81%A8%E3%82%82%E3%81%AB%E9%96%8B%E7%99%BA%E3%81%95%E3%82%8C%E3%81%9F%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E7%B5%84%E3%81%BF%E8%BE%BC%E3%82%93%E3%81%A0%E4%BA%8C%E6%AC%A1%E7%9A%84%E8%91%97%E4%BD%9C%E7%89%A9%E3%81%8C%E7%AC%AC%E4%B8%89%E8%80%85%E3%81%AE%E7%9F%A5%E7%9A%84%E8%B2%A1%E7%94%A3%E6%A8%A9%E3%82%92%E4%BE%B5%E5%AE%B3%E3%81%97%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E4%BF%9D%E8%A8%BC%E3%81%BE%E3%81%9F%E3%81%AF%E8%A1%A8%E6%98%8E%E3%81%99%E3%82%8B%E3%82%82%E3%81%AE%E3%81%A8%E8%A7%A3%E9%87%88%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%20color%3A%20black%3B%20font-size%3A%2010pt%3B%22%3E8.%20%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%E6%90%8D%E5%AE%B3%E8%B3%A0%E5%84%9F%3C%2FSTRONG%3E%3C%2FSPAN%3E%E3%80%82%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AF%E3%80%81(1)%20%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AB%E3%82%88%E3%82%8B%E6%9C%AC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E4%BD%BF%E7%94%A8%20(%E3%82%B5%E3%83%96%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B7%E3%83%BC%E3%81%AE%E4%BD%BF%E7%94%A8%E3%81%8C%E8%A8%B1%E5%8F%AF%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AB%E3%81%AF%E3%80%81%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AE%20%3CSPAN%20class%3D%22spelle%22%3E%E3%82%B5%E3%83%96%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B7%E3%83%BC%E3%81%AB%E3%82%88%E3%82%8B%3C%2FSPAN%3E%20%E4%BD%BF%E7%94%A8%E3%82%92%E5%90%AB%E3%82%80)%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%20(2)%20%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AB%E3%82%88%E3%82%8B%E6%9C%AC%E5%A5%91%E7%B4%84%E3%81%AE%E6%9D%A1%E9%A0%85%E3%81%AE%E9%81%95%E5%8F%8D%E3%81%AB%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E8%AB%8B%E6%B1%82%E3%80%81%E8%B2%AC%E4%BB%BB%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%E8%B2%BB%E7%94%A8%20(%E5%90%88%E7%90%86%E7%9A%84%E3%81%AA%E5%BC%81%E8%AD%B7%E5%A3%AB%E8%B2%BB%E7%94%A8%E3%82%92%E5%90%AB%E3%82%80)%20%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%80%81%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%92%E5%AE%8C%E5%85%A8%E3%81%AB%E9%98%B2%E5%BE%A1%E3%81%97%E3%80%81%E8%A3%9C%E5%84%9F%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E5%90%8C%E6%84%8F%E3%81%99%E3%82%8B%E3%82%82%E3%81%AE%E3%81%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%20color%3A%20black%3B%20font-size%3A%2010pt%3B%22%3E9.%20%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%E8%B2%AC%E4%BB%BB%E3%81%AE%E5%88%B6%E9%99%90%3C%2FSTRONG%3E%3C%2FSPAN%3E%E3%80%82%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AF%E3%80%81%E5%A5%91%E7%B4%84%E3%80%81%E4%B8%8D%E6%B3%95%E8%A1%8C%E7%82%BA%E3%80%81%E3%81%9D%E3%81%AE%E4%BB%96%E3%82%92%E5%95%8F%E3%82%8F%E3%81%9A%E3%80%81%E5%81%B6%E7%99%BA%E7%9A%84%E3%80%81%E7%89%B9%E5%88%A5%E3%80%81%E9%96%93%E6%8E%A5%E7%9A%84%E3%80%81%E7%B5%90%E6%9E%9C%E7%9A%84%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E6%87%B2%E7%BD%B0%E7%9A%84%E3%81%AA%E6%90%8D%E5%AE%B3%20(%E4%BD%BF%E7%94%A8%E3%81%AE%E6%90%8D%E5%A4%B1%E3%80%81%E6%99%82%E9%96%93%E3%81%AE%E6%90%8D%E5%A4%B1%E3%80%81%E4%B8%8D%E4%BE%BF%E3%80%81%E5%95%86%E6%A5%AD%E7%9A%84%E6%90%8D%E5%A4%B1%E3%80%81%E5%88%A9%E7%9B%8A%E3%80%81%E8%B2%AF%E8%93%84%E3%80%81%E5%8F%8E%E7%9B%8A%E3%81%AE%E6%90%8D%E5%A4%B1%E3%81%AB%E3%82%88%E3%82%8B%E6%90%8D%E5%AE%B3%E3%82%92%E5%90%AB%E3%81%BF%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AB%E9%99%90%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93)%20%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%80%81%E6%B3%95%E5%BE%8B%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E4%BA%8B%E5%89%8D%E3%81%AB%E9%80%9A%E7%9F%A5%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%A7%E3%81%82%E3%81%A3%E3%81%A6%E3%82%82%E3%80%81%E6%B3%95%E5%BE%8B%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E5%90%A6%E8%AA%8D%E3%81%95%E3%82%8C%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%AE%E3%81%82%E3%82%8B%E6%90%8D%E5%AE%B3%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%80%81%E4%B8%80%E5%88%87%E3%81%AE%E8%B2%AC%E4%BB%BB%E3%82%92%E8%B2%A0%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AE%E8%B2%AC%E4%BB%BB%E3%81%AF%E3%80%81%E3%81%84%E3%81%8B%E3%81%AA%E3%82%8B%E5%A0%B4%E5%90%88%E3%82%82%E3%80%81%E3%81%BE%E3%81%9F%E3%81%84%E3%81%8B%E3%81%AA%E3%82%8B%E5%9B%9E%E5%BE%A9%E6%B3%95%E7%90%86%E3%81%AB%E3%81%8A%E3%81%84%E3%81%A6%E3%82%82%E3%80%81%E6%9C%AC%E5%A5%91%E7%B4%84%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%8C%E5%8F%97%E9%A0%98%E3%81%97%E3%81%9F%E7%B7%8F%E9%A1%8D%E3%81%AB%E9%99%90%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%20color%3A%20black%3B%20font-size%3A%2010pt%3B%22%3E10.%20%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%E6%B3%95%E4%BB%A4%E3%81%AE%E9%81%B5%E5%AE%88%E8%BC%B8%E5%87%BA%E5%88%B6%E9%99%90%3C%2FSTRONG%3E%3C%2FSPAN%3E%E3%80%82%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AF%E3%80%81%E7%B1%B3%E5%9B%BD%E6%94%BF%E5%BA%9C%E3%81%8A%E3%82%88%E3%81%B3%E8%BC%B8%E5%87%BA%E3%81%BE%E3%81%9F%E3%81%AF%E5%86%8D%E8%BC%B8%E5%87%BA%E3%81%8C%E8%A1%8C%E3%82%8F%E3%82%8C%E3%82%8B%E5%9B%BD%E3%81%8B%E3%82%89%E9%81%A9%E5%88%87%E3%81%AA%E8%BC%B8%E5%87%BA%E3%81%BE%E3%81%9F%E3%81%AF%E5%86%8D%E8%BC%B8%E5%87%BA%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%82%92%E5%8F%96%E5%BE%97%E3%81%9B%E3%81%9A%E3%81%AB%E3%80%81%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%81%95%E3%82%8C%E3%81%9F%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%BE%E3%81%9F%E3%81%AF%E3%81%9D%E3%81%AE%E7%9B%B4%E6%8E%A5%E8%A3%BD%E5%93%81%E3%82%92%E3%80%81%E3%81%84%E3%81%8B%E3%81%AA%E3%82%8B%E5%BD%A2%E5%BC%8F%E3%81%A7%E3%82%82%E5%86%8D%E8%B2%A9%E5%A3%B2%E3%80%81%E5%86%8D%E8%BC%B8%E5%87%BA%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E7%9B%B4%E6%8E%A5%E7%9A%84%E3%81%BE%E3%81%9F%E3%81%AF%E9%96%93%E6%8E%A5%E7%9A%84%E3%81%AB%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%A6%E3%81%AF%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E8%BC%B8%E5%87%BA%E3%81%AF%E3%80%81%E8%A3%BD%E5%93%81%E3%80%81%E6%8A%80%E8%A1%93%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%8C%E3%80%81%E7%89%A9%E7%90%86%E7%9A%84%E3%81%AA%E5%87%BA%E8%8D%B7%E3%80%81FTP%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E8%BB%A2%E9%80%81%E3%80%81%E9%9B%BB%E5%AD%90%E3%83%A1%E3%83%BC%E3%83%AB%E3%80%81%E3%83%95%E3%82%A1%E3%83%83%E3%82%AF%E3%82%B9%E3%80%81%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%80%81%E4%BC%9A%E8%A9%B1%E3%81%AA%E3%81%A9%E3%80%81%E4%BD%95%E3%82%89%E3%81%8B%E3%81%AE%E6%89%8B%E6%AE%B5%E3%81%A7%E3%81%82%E3%82%8B%E5%9B%BD%E3%81%8B%E3%82%89%E5%88%A5%E3%81%AE%E5%9B%BD%E3%81%AB%E8%BB%A2%E9%80%81%E3%81%95%E3%82%8C%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%AB%20%3CSPAN%20class%3D%22grame%22%3E%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%20%E3%80%82%E8%BC%B8%E5%87%BA%E3%81%AF%E3%80%81%E6%8A%80%E8%A1%93%E3%81%BE%E3%81%9F%E3%81%AF%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%8C%E7%B1%B3%E5%9B%BD%E5%86%85%E3%81%AE%E5%A4%96%E5%9B%BD%E4%BA%BA%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E4%BA%8B%E6%A5%AD%E6%B4%BB%E5%8B%95%E3%81%8C%E8%A1%8C%E3%82%8F%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%9B%BD%E3%81%AE%E5%A4%96%E5%9B%BD%E4%BA%BA%E3%81%AB%E8%AD%B2%E6%B8%A1%E3%81%95%E3%82%8C%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AB%E3%82%82%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E5%A4%96%E5%9B%BD%E4%BA%BA%E3%81%A8%E3%81%AF%E3%80%81%E7%B1%B3%E5%9B%BD%E3%81%BE%E3%81%9F%E3%81%AF%E4%BA%8B%E6%A5%AD%E6%B4%BB%E5%8B%95%E3%81%8C%E8%A1%8C%E3%82%8F%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%9B%BD%E3%81%AE%E5%B8%82%E6%B0%91%E3%81%A7%E3%82%82%E6%B0%B8%E4%BD%8F%E8%80%85%E3%81%A7%E3%82%82%E3%81%AA%E3%81%84%E4%BA%BA%E3%81%A7%E3%81%99%E3%80%82%E3%81%95%E3%82%89%E3%81%AB%E3%80%81%E6%8A%80%E8%A1%93%E3%80%81%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%80%81%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E3%81%9D%E3%81%AE%E4%BB%96%E3%81%AE%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AE%E8%B3%87%E7%94%A3%E3%82%92%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E4%BB%A5%E5%A4%96%E3%81%AE%E5%BD%93%E4%BA%8B%E8%80%85%E3%81%AB%E8%AD%B2%E6%B8%A1%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E8%BC%B8%E5%87%BA%E5%85%A5%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%80%81%E8%A8%B1%E5%8F%AF%E8%A8%BC%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E3%81%9D%E3%81%AE%E4%BB%96%E3%81%AE%E6%94%BF%E5%BA%9C%E3%81%AB%E3%82%88%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%AA%E6%A8%A9%E9%99%90(%E4%BB%A5%E4%B8%8B%E3%80%81%E7%B7%8F%E7%A7%B0%E3%81%97%E3%81%A6%E3%80%8C%E6%94%BF%E5%BA%9C%E3%81%AB%E3%82%88%E3%82%8B%E8%AA%8D%E5%8F%AF%E3%80%8D%E3%81%A8%E3%81%84%E3%81%84%E3%81%BE%E3%81%99%3CSPAN%20class%3D%22spelle%22%3E%3C%2FSPAN%3E)%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A8%E3%81%95%E3%82%8C%E3%80%81%E6%89%BF%E8%AA%8D%E3%81%95%E3%82%8C%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AF%E3%80%81%E3%81%8B%E3%81%8B%E3%82%8B%E3%80%8C%E6%94%BF%E5%BA%9C%E3%81%AB%E3%82%88%E3%82%8B%E8%AA%8D%E5%8F%AF%E3%80%8D%E3%81%8C%E4%BB%98%E4%B8%8E%E3%81%95%E3%82%8C%E3%82%8B%E3%81%BE%E3%81%A7%E3%80%81%E6%9C%AC%E5%A5%91%E7%B4%84%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%8F%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E8%AD%B2%E6%B8%A1%E3%81%99%E3%82%8B%E7%BE%A9%E5%8B%99%E3%82%92%E8%B2%A0%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%20color%3A%20black%3B%20font-size%3A%2010pt%3B%22%3E11.%20%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%E6%94%BF%E5%BA%9C%E3%81%AE%E6%A8%A9%E5%88%A9%3C%2FSTRONG%3E%3C%2FSPAN%3E%E3%80%82%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AF%E3%80%8148%20C.F.R.%20%C2%A72.101%20%E3%81%AB%E5%AE%9A%E7%BE%A9%E3%81%95%E3%82%8C%E3%82%8B%E3%80%8C%E5%95%86%E7%94%A8%E3%82%A2%E3%82%A4%E3%83%86%E3%83%A0%E3%80%8D%E3%81%A7%E3%81%82%E3%82%8A%E3%80%8148%20C.F.R.%20%C2%A7%2012.212%20%E3%81%BE%E3%81%9F%E3%81%AF%2048%20C.F.R.%20%C2%A7227.7202%20(%E8%A9%B2%E5%BD%93%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88)%20%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8B%E3%80%8C%E5%95%86%E7%94%A8%E3%82%B3%E3%83%B3%E3%83%94%E3%83%A5%E3%83%BC%E3%82%BF%20%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%80%8D%E3%81%8A%E3%82%88%E3%81%B3%E3%80%8C%E5%95%86%E7%94%A8%E3%82%B3%E3%83%B3%E3%83%94%E3%83%A5%E3%83%BC%E3%82%BF%20%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%20%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%86%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%80%8D%E3%81%A7%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%80%81%E6%9C%AC%E5%A5%91%E7%B4%84%E3%81%AB%E8%A6%8F%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E6%A8%A9%E5%88%A9%E3%82%92%E6%8C%81%E3%81%A4%E7%B1%B3%E5%9B%BD%E6%94%BF%E5%BA%9C%E3%81%AE%E3%82%A8%E3%83%B3%E3%83%89%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%81%AB%E3%81%AE%E3%81%BF%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E4%BE%9B%E4%B8%8E%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%20color%3A%20black%3B%20font-size%3A%2010pt%3B%22%3E12.%20%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%E3%83%AA%E3%82%B9%E3%82%AF%E3%81%AE%E9%AB%98%E3%81%84%E6%B4%BB%E5%8B%95%3C%2FSTRONG%3E%3C%2FSPAN%3E%E3%80%82%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AF%E3%80%81%E6%9C%AC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%8C%E3%83%95%E3%82%A9%E3%83%BC%E3%83%AB%E3%83%88%E3%83%BB%E3%83%88%E3%83%AC%E3%83%A9%E3%83%B3%E3%83%88%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81%E5%8E%9F%E5%AD%90%E5%8A%9B%E6%96%BD%E8%A8%AD%E3%80%81%E8%88%AA%E7%A9%BA%E6%A9%9F%E3%81%AE%E3%83%8A%E3%83%93%E3%82%B2%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%80%81%E9%80%9A%E4%BF%A1%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AE%E9%81%8B%E7%94%A8%E3%81%AA%E3%81%A9%E3%80%81%E5%8D%B1%E9%99%BA%E3%80%81%E7%94%9F%E5%91%BD%E3%81%AB%E5%8D%B1%E9%99%BA%E3%82%92%E5%8F%8A%E3%81%BC%E3%81%99%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E7%94%9F%E5%91%BD%E3%82%92%E8%84%85%E3%81%8B%E3%81%99%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%AE%E3%81%82%E3%82%8B%E7%92%B0%E5%A2%83%E3%81%AB%E3%81%8A%E3%81%84%E3%81%A6%E3%80%81%E3%82%AA%E3%83%B3%E3%83%A9%E3%82%A4%E3%83%B3%E5%88%B6%E5%BE%A1%E6%A9%9F%E5%99%A8%E3%81%A7%E3%81%AE%E4%BD%BF%E7%94%A8%E3%81%BE%E3%81%9F%E3%81%AF%E5%86%8D%E8%B2%A9%E3%82%92%E7%9B%AE%E7%9A%84%E3%81%A8%E3%81%97%E3%81%9F%E8%A3%BD%E5%93%81%E3%81%AB%E7%B5%84%E3%81%BF%E8%BE%BC%E3%82%80%E3%81%93%E3%81%A8%E3%82%92%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%8C%E8%A8%AD%E8%A8%88%E3%80%81%E8%A3%BD%E9%80%A0%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E6%84%8F%E5%9B%B3%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E8%AA%8D%E3%82%81%E3%81%BE%E3%81%99%E3%80%82%20%E8%88%AA%E7%A9%BA%E7%AE%A1%E5%88%B6%E3%80%81%E7%9B%B4%E6%8E%A5%E7%94%9F%E5%91%BD%E7%B6%AD%E6%8C%81%E8%A3%85%E7%BD%AE%E3%81%BE%E3%81%9F%E3%81%AF%E5%85%B5%E5%99%A8%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AA%E3%81%A9%E3%80%81%E8%A3%BD%E5%93%81%E3%81%AE%E6%95%85%E9%9A%9C%E3%81%8C%E7%9B%B4%E6%8E%A5%E6%AD%BB%E4%BA%A1%E3%80%81%E4%BA%BA%E8%BA%AB%E5%82%B7%E5%AE%B3%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E6%B7%B1%E5%88%BB%E3%81%AA%E7%89%A9%E7%90%86%E7%9A%84%E3%81%BE%E3%81%9F%E3%81%AF%E7%92%B0%E5%A2%83%E7%9A%84%E6%90%8D%E5%AE%B3%E3%81%AB%E3%81%A4%E3%81%AA%E3%81%8C%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%AE%E3%81%82%E3%82%8B%E3%82%82%E3%81%AE(%E4%BB%A5%E4%B8%8B%E3%80%8C%E9%AB%98%E3%83%AA%E3%82%B9%E3%82%AF%E6%B4%BB%E5%8B%95%E3%80%8D%E3%81%A8%E3%81%84%E3%81%84%E3%81%BE%E3%81%99)%E3%80%82%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AF%E3%80%81%E6%9C%AC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%BE%E3%81%9F%E3%81%AF%E6%9C%AC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E6%B4%BE%E7%94%9F%E7%89%A9%E3%82%92%E9%AB%98%E3%83%AA%E3%82%B9%E3%82%AF%E6%B4%BB%E5%8B%95%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E6%98%8E%E7%A2%BA%E3%81%AB%E8%A1%A8%E6%98%8E%E3%81%97%E3%80%81%E4%BF%9D%E8%A8%BC%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%20color%3A%20black%3B%20font-size%3A%2010pt%3B%22%3E13.%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%E6%B3%95%E5%BE%8B%E3%81%AE%E9%81%B8%E6%8A%9E%E3%80%82%E4%BC%9A%E5%A0%B4%3B%E5%88%B6%E9%99%90%E4%BA%8B%E9%A0%85%E3%80%82%3C%2FSTRONG%3E%3C%2FSPAN%3E%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AF%E3%80%81%E6%8A%B5%E8%A7%A6%E6%B3%95%E3%81%AE%E5%8E%9F%E5%89%87%E3%81%AB%E3%81%8B%E3%81%8B%E3%82%8F%E3%82%89%E3%81%9A%E3%80%81%E6%9C%AC%E5%A5%91%E7%B4%84%E3%81%BE%E3%81%9F%E3%81%AF%E6%9C%AC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AB%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E4%BA%8B%E9%A0%85%E3%81%AB%E7%B1%B3%E5%9B%BD%E3%81%8A%E3%82%88%E3%81%B3%E7%B1%B3%E5%9B%BD%E3%83%86%E3%82%AD%E3%82%B5%E3%82%B9%E5%B7%9E%E3%81%AE%E6%B3%95%E4%BB%A4%E3%81%8A%E3%82%88%E3%81%B3%E6%B3%95%E5%BE%8B%E3%81%8C%E9%81%A9%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E5%90%8C%E6%84%8F%E3%81%97%E3%80%81%E3%81%BE%E3%81%9F%E3%80%81%E8%A8%B4%E8%A8%9F%E3%81%AF%E3%83%86%E3%82%AD%E3%82%B5%E3%82%B9%E5%B7%9E%E3%81%AE%E5%B7%9E%E8%A3%81%E5%88%A4%E6%89%80%E3%81%BE%E3%81%9F%E3%81%AF%E9%80%A3%E9%82%A6%E8%A3%81%E5%88%A4%E6%89%80%E3%81%AE%E5%B0%82%E5%B1%9E%E7%AE%A1%E8%BD%84%E6%A8%A9%E3%81%AB%E5%BE%93%E3%81%86%E3%81%93%E3%81%A8%E3%81%AB%E5%90%8C%E6%84%8F%E3%81%99%E3%82%8B%E3%82%82%E3%81%AE%E3%81%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%20%E7%B1%B3%E5%9B%BD%E3%80%82%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AF%E3%80%81%E3%81%93%E3%82%8C%E3%81%AB%E5%8F%8D%E3%81%99%E3%82%8B%E6%B3%95%E4%BB%A4%E3%81%BE%E3%81%9F%E3%81%AF%E6%B3%95%E5%BE%8B%E3%81%AB%E3%81%8B%E3%81%8B%E3%82%8F%E3%82%89%E3%81%9A%E3%80%81%E6%9C%AC%E5%A5%91%E7%B4%84%E3%81%BE%E3%81%9F%E3%81%AF%E6%9C%AC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AB%E8%B5%B7%E5%9B%A0%E3%81%BE%E3%81%9F%E3%81%AF%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%E8%AB%8B%E6%B1%82%E3%81%BE%E3%81%9F%E3%81%AF%E8%A8%B4%E8%A8%9F%E5%8E%9F%E5%9B%A0%E3%81%AF%E3%80%81%E5%BD%93%E8%A9%B2%E8%AB%8B%E6%B1%82%E3%81%BE%E3%81%9F%E3%81%AF%E8%A8%B4%E8%A8%9F%E5%8E%9F%E5%9B%A0%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%8B%E3%82%891%E5%B9%B4%E4%BB%A5%E5%86%85%E3%81%AB%E6%8F%90%E8%B5%B7%E3%81%95%E3%82%8C%E3%81%AA%E3%81%91%E3%82%8C%E3%81%B0%E3%81%AA%E3%82%89%E3%81%9A%E3%80%81%E6%8F%90%E8%B5%B7%E3%81%95%E3%82%8C%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E6%B0%B8%E4%B9%85%E3%81%AB%E7%A6%81%E6%AD%A2%E3%81%95%E3%82%8C%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E5%90%8C%E6%84%8F%E3%81%99%E3%82%8B%E3%82%82%E3%81%AE%E3%81%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%20color%3A%20black%3B%20font-size%3A%2010pt%3B%22%3E14.%20%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%E6%A9%9F%E5%AF%86%E6%83%85%E5%A0%B1%3C%2FSTRONG%3E%3C%2FSPAN%3E%E3%80%82%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AF%E3%80%81%E6%9C%AC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E6%A9%9F%E5%AF%86%E6%83%85%E5%A0%B1%E3%81%A8%E3%81%97%E3%81%A6%E6%89%B1%E3%81%86%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E5%BD%A2%E5%BC%8F(%E4%BA%BA%E9%96%93%E3%81%8C%E8%AA%AD%E3%82%81%E3%82%8B%E5%BD%A2%E5%BC%8F)%E3%81%AE%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AB%E9%96%A2%E3%81%97%E3%81%A6%E3%81%AF%E3%80%81%E6%9C%AC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E6%B0%B8%E4%B9%85%E3%81%AB%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E6%9C%AC%E5%A5%91%E7%B4%84%E3%81%AE%E7%B5%82%E4%BA%86%E6%97%A5%E3%81%8B%E3%82%895%E5%B9%B4%E9%96%93%E3%80%81%E6%9C%AC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E4%BB%96%E3%81%AE%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E9%83%A8%E5%88%86%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E7%A7%98%E5%AF%86%E4%BF%9D%E6%8C%81%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E5%90%8C%E6%84%8F%E3%81%99%E3%82%8B%E3%82%82%E3%81%AE%E3%81%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E6%9C%9F%E9%96%93%E4%B8%AD%E3%80%81%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AF%E3%80%81%E6%9C%AC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E7%9F%A5%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81%E6%9C%AC%E5%A5%91%E7%B4%84%E3%81%A8%E5%B0%91%E3%81%AA%E3%81%8F%E3%81%A8%E3%82%82%E5%90%8C%E7%A8%8B%E5%BA%A6%E3%81%AE%E6%B3%A8%E6%84%8F%E3%82%92%E6%89%95%E3%81%A3%E3%81%A6%E5%BD%93%E8%A9%B2%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E4%BF%9D%E8%AD%B7%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%BE%A9%E5%8B%99%E4%BB%98%E3%81%91%E3%82%8B%E6%9B%B8%E9%9D%A2%E3%81%AB%E3%82%88%E3%82%8B%E5%A5%91%E7%B4%84%E3%82%92%E7%B7%A0%E7%B5%90%E3%81%97%E3%81%9F%E5%BE%93%E6%A5%AD%E5%93%A1%E4%BB%A5%E5%A4%96%E3%81%AE%E5%BE%93%E6%A5%AD%E5%93%A1%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6%E3%80%81%E6%9C%AC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E3%81%84%E3%81%8B%E3%81%AA%E3%82%8B%E9%83%A8%E5%88%86%E3%82%82%E9%96%8B%E7%A4%BA%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AF%E3%80%81%E6%9C%AC%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%80%81%E3%81%8A%E5%AE%A2%E6%A7%98%E8%87%AA%E8%BA%AB%E3%81%AE%E6%A9%9F%E5%AF%86%E6%83%85%E5%A0%B1%E3%81%A8%E5%90%8C%E7%A8%8B%E5%BA%A6%E3%81%AE%E6%B3%A8%E6%84%8F%E3%82%92%E6%89%95%E3%82%8F%E3%81%AA%E3%81%91%E3%82%8C%E3%81%B0%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E5%90%88%E7%90%86%E7%9A%84%E3%81%AA%E7%A8%8B%E5%BA%A6%E4%BB%A5%E4%B8%8A%E3%81%AE%E6%B3%A8%E6%84%8F%E3%82%92%E6%89%95%E3%81%86%E3%81%93%E3%81%A8%E3%81%AB%E5%90%8C%E6%84%8F%E3%81%99%E3%82%8B%E3%82%82%E3%81%AE%E3%81%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AF%E3%80%81%E8%A3%81%E5%88%A4%E6%89%80%E3%81%8C%E8%A6%81%E6%B1%82%E3%81%99%E3%82%8B%E7%AF%84%E5%9B%B2%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E6%B3%95%E5%BE%8B%E3%81%BE%E3%81%9F%E3%81%AF%E5%91%BD%E4%BB%A4%E3%81%AE%E9%81%8B%E7%94%A8%E3%81%AE%E4%B8%8B%E3%81%A7%E3%80%81%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E9%96%8B%E7%A4%BA%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E9%96%8B%E7%A4%BA%E5%89%8D%E3%81%AB%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AB%E5%BD%93%E8%A9%B2%E8%A6%81%E4%BB%B6%E3%82%92%E9%80%9A%E7%9F%A5%E3%81%97%E3%80%81%E5%BF%85%E8%A6%81%E3%81%AA%E6%83%85%E5%A0%B1%E3%81%AE%E3%81%BF%E3%82%92%E9%96%8B%E7%A4%BA%E3%81%97%E3%80%81%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%8C%E5%BD%93%E8%A9%B2%E9%96%8B%E7%A4%BA%E3%82%92%E8%A6%81%E6%B1%82%E3%81%99%E3%82%8B%E8%A3%81%E5%88%A4%E6%89%80%E3%81%BE%E3%81%9F%E3%81%AF%E3%81%9D%E3%81%AE%E4%BB%96%E3%81%AE%E6%B3%95%E7%9A%84%E6%A9%9F%E9%96%A2%E3%81%AB%E7%95%B0%E8%AD%B0%E3%82%92%E5%94%B1%E3%81%88%E3%82%8B%E6%A9%9F%E4%BC%9A%E3%82%92%E4%B8%8E%E3%81%88%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E6%9D%A1%E4%BB%B6%E3%81%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%20color%3A%20black%3B%20font-size%3A%2010pt%3B%22%3E15.%20%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%E8%A3%BD%E5%93%81%E3%81%AE%E3%83%A9%E3%83%99%E3%83%AB%E4%BB%98%E3%81%91%3C%2FSTRONG%3E%3C%2FSPAN%3E%E3%80%82%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AE%E5%95%86%E6%A8%99%E3%80%81%E3%83%96%E3%83%A9%E3%83%B3%E3%83%89%E5%90%8D%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%AD%E3%82%B4%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E8%A8%B1%E5%8F%AF%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%20color%3A%20black%3B%20font-size%3A%2010pt%3B%22%3E16.%20%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%E5%AE%8C%E5%85%A8%E5%90%88%E6%84%8F%3C%2FSTRONG%3E%3C%2FSPAN%3E%E3%80%82%E6%9C%AC%E5%A5%91%E7%B4%84%E3%81%AF%E3%80%81%E6%9C%AC%E5%A5%91%E7%B4%84%E3%81%AE%E4%B8%BB%E9%A1%8C%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%A8%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%A8%E3%81%AE%E9%96%93%E3%81%AE%E5%AE%8C%E5%85%A8%E3%81%AA%E5%90%88%E6%84%8F%E3%82%92%E6%A7%8B%E6%88%90%E3%81%97%E3%80%81%E6%9B%B8%E9%9D%A2%E3%81%BE%E3%81%9F%E3%81%AF%E5%8F%A3%E9%A0%AD%E3%81%AB%E3%82%88%E3%82%8B%E5%BE%93%E5%89%8D%E3%81%AE%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E9%80%9A%E4%BF%A1%E3%80%81%E4%BA%A4%E6%B8%89%E3%80%81%E7%90%86%E8%A7%A3%E3%80%81%E5%90%88%E6%84%8F%E3%81%BE%E3%81%9F%E3%81%AF%E8%A1%A8%E6%98%8E(%E5%AD%98%E5%9C%A8%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88)%E3%81%AB%E5%84%AA%E5%85%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E6%9C%AC%E5%A5%91%E7%B4%84%E3%81%AF%E3%80%81%E6%9B%B8%E9%9D%A2%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E3%81%AE%E3%81%BF%E4%BF%AE%E6%AD%A3%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%80%81%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%A8%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%8C%E7%B7%A0%E7%B5%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%20color%3A%20black%3B%20font-size%3A%2010pt%3B%22%3E17.%20%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%E5%88%86%E9%9B%A2%E5%8F%AF%E8%83%BD%E6%80%A7%3C%2FSTRONG%3E%3C%2FSPAN%3E%E3%80%82%E6%9C%AC%E5%A5%91%E7%B4%84%E3%81%AE%E3%81%84%E3%81%9A%E3%82%8C%E3%81%8B%E3%81%AE%E6%9D%A1%E9%A0%85%E3%81%8C%E4%BD%95%E3%82%89%E3%81%8B%E3%81%AE%E7%90%86%E7%94%B1%E3%81%A7%E7%84%A1%E5%8A%B9%E3%81%BE%E3%81%9F%E3%81%AF%E5%9F%B7%E8%A1%8C%E4%B8%8D%E8%83%BD%E3%81%A8%E5%88%A4%E6%96%AD%E3%81%95%E3%82%8C%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81%E6%9C%AC%E5%A5%91%E7%B4%84%E3%81%AE%E6%AE%8B%E3%82%8A%E3%81%AE%E6%9D%A1%E9%A0%85%E3%81%AF%E6%90%8D%E3%81%AA%E3%82%8F%E3%82%8C%E3%81%9A%E3%80%81%E7%84%A1%E5%8A%B9%E3%81%BE%E3%81%9F%E3%81%AF%E5%9F%B7%E8%A1%8C%E4%B8%8D%E8%83%BD%E3%81%AA%E6%9D%A1%E9%A0%85%E3%81%AE%E5%A4%89%E6%9B%B4%E3%81%BE%E3%81%9F%E3%81%AF%E7%BD%AE%E6%8F%9B%E3%81%AB%E3%82%88%E3%82%8A%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AE%E9%87%8D%E5%A4%A7%E3%81%AA%E5%88%A9%E7%9B%8A%E3%81%8C%E3%81%95%E3%82%89%E3%81%AB%E5%A5%AA%E3%82%8F%E3%82%8C%E3%82%8B%E3%81%A8%E5%88%A4%E6%96%AD%E3%81%95%E3%82%8C%E3%81%AA%E3%81%84%E9%99%90%E3%82%8A%E3%80%81%E6%9C%AC%E5%A5%91%E7%B4%84%E3%81%AF%E7%9B%B4%E3%81%A1%E3%81%AB%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%20%E7%84%A1%E5%8A%B9%E3%81%BE%E3%81%9F%E3%81%AF%E5%9F%B7%E8%A1%8C%E4%B8%8D%E8%83%BD%E3%81%AA%E6%9D%A1%E9%A0%85%E3%81%AF%E3%80%81%E6%9C%89%E5%8A%B9%E3%81%8B%E3%81%A4%E5%9F%B7%E8%A1%8C%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E7%84%A1%E5%8A%B9%E3%81%BE%E3%81%9F%E3%81%AF%E5%9F%B7%E8%A1%8C%E4%B8%8D%E8%83%BD%E3%81%AA%E6%9D%A1%E9%A0%85%E3%81%AE%E6%A0%B9%E5%BA%95%E3%81%AB%E3%81%82%E3%82%8B%E6%84%8F%E5%9B%B3%E3%81%AB%E6%9C%80%E3%82%82%E8%BF%91%E3%81%84%E6%9D%A1%E9%A0%85%E3%81%AB%E7%BD%AE%E3%81%8D%E6%8F%9B%E3%81%88%E3%82%89%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%20color%3A%20black%3B%20font-size%3A%2010pt%3B%22%3E18.%20%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%3CSTRONG%3E%E6%A8%A9%E5%88%A9%E6%94%BE%E6%A3%84%E3%81%AA%E3%81%97%3C%2FSTRONG%3E%3C%2FSPAN%3E%E3%80%82%E6%9C%AC%E5%A5%91%E7%B4%84%E3%81%AE%E3%81%84%E3%81%9A%E3%82%8C%E3%81%8B%E3%81%AE%E6%9D%A1%E9%A0%85%E3%81%AE%E9%81%95%E5%8F%8D%E3%81%AB%E5%AF%BE%E3%81%99%E3%82%8B%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AB%E3%82%88%E3%82%8B%E6%A8%A9%E5%88%A9%E6%94%BE%E6%A3%84%E3%81%AF%E3%80%81%E5%90%8C%E4%B8%80%E3%81%BE%E3%81%9F%E3%81%AF%E7%95%B0%E3%81%AA%E3%82%8B%E6%9D%A1%E9%A0%85%E3%81%AE%E3%81%9D%E3%81%AE%E4%BB%96%E3%81%AE%E9%81%95%E5%8F%8D%E3%81%BE%E3%81%9F%E3%81%AF%E3%81%9D%E3%81%AE%E5%BE%8C%E3%81%AE%E9%81%95%E5%8F%8D%E3%81%AB%E5%AF%BE%E3%81%99%E3%82%8B%E6%A8%A9%E5%88%A9%E6%94%BE%E6%A3%84%E3%81%A8%E3%81%AF%E8%A7%A3%E9%87%88%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%20style%3D%22margin-top%3A%20auto%3B%20margin-bottom%3A%20auto%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%20font-size%3A%2010pt%3B%22%3E%C2%A9%202004-2014%20%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%82%BB%E3%83%9F%E3%82%B3%E3%83%B3%E3%83%80%E3%82%AF%E3%82%BF%E3%83%BC%E6%A0%AA%E5%BC%8F%E4%BC%9A%E7%A4%BE%E5%85%A8%E8%91%97%E4%BD%9C%E6%A8%A9%E6%89%80%E6%9C%89%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-TEASER%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1107197%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BB%E3%83%95%E3%83%A5%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1107198%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%83%BB%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BB%E3%83%95%E3%83%A5%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%83%BB%E3%83%97%E3%83%AC%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1107198%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EWindows%20%E4%BB%A5%E5%A4%96%E3%81%AE%20KDS%20%E5%AE%9F%E8%A3%85%E7%94%A8%E3%81%AE%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%82%92%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%99%E3%82%8B%E4%BA%88%E5%AE%9A%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎02-03-2026 05:14 PM
更新者:
