FXOS8700CQ - Bare metal example project
Hi Everyone,
As I am often asked for a simple bare metal example code for the Xtrinsic FXOS8700CQ 6-axis sensor, I would like to share here one of my examples I have created for this part while working with the Freescale FRDM-KL25Z platform and FRDM-FXS-MULTI(-B) sensor expansion board that features many of the Xtrinsic sensors including the FXOS8700CQ. The FreeMASTER tool is used to visualize both the acceleration and magnetic data that are read from the FXOS8700CQ using an interrupt technique through the I2C interface.
This example illustrates:
1. Initialization of the MKL25Z128 MCU (mainly I2C and PORT modules).
2. I2C data write and read operations.
3. Initialization of the FXOS8700CQ.
4. Simple accelerometer offset calibration based on the AN4069.
5. Simple magnetic hard-iron offset calibration.
6. Output data reading using an interrupt technique.
7. Conversion of the output values from registers 0x01 – 0x06 and 0x33 – 0x38 to real values in g’s and µT and simple heading angle calculation.
8. Visualization of the calculated values in the FreeMASTER tool.
1. As you can see in the FRDM-FXS-MULTI(-B)/FRDM-KL25Z schematics and the image below, I2C signals are routed to the I2C1 module (PTC1 and PTC2 pins) of the KL25Z MCU and the INT1 output is connected to the PTD4 pin (make sure that pins 1-2 of J3 on the sensor expansion board are connected together using a jumper). The INT1 output of the FXOS8700CQ is configured as a push-pull active-low output, so the corresponding PTD4 pin configuration is GPIO with an interrupt on falling edge.
The MCU is, therefore, configured as follows.
void MCU_Init(void)
     //I2C1 module initialization
     SIM_SCGC4 |= SIM_SCGC4_I2C1_MASK;        // Turn on clock to I2C1 module
     SIM_SCGC5 |= SIM_SCGC5_PORTC_MASK;       // Turn on clock to Port C module
     PORTC_PCR1 |= PORT_PCR_MUX(0x2);         // PTC1 pin is I2C1 SCL line
     PORTC_PCR2 |= PORT_PCR_MUX(0x2);         // PTC2 pin is I2C1 SDA line
     I2C1_F  |= I2C_F_ICR(0x14);              // SDA hold time = 2.125us, SCL start hold time = 4.25us, SCL stop hold time = 5.125us
     I2C1_C1 |= I2C_C1_IICEN_MASK;            // Enable I2C0 module
     //Configure the PTD4 pin (connected to the INT1 of the FXOS8700CQ) for falling edge interrupts
     SIM_SCGC5 |= SIM_SCGC5_PORTD_MASK;       // Turn on clock to Port A module
     PORTD_PCR4 |= (0|PORT_PCR_ISF_MASK|      // Clear the interrupt flag
                     PORT_PCR_MUX(0x1)|       // PTD4 is configured as GPIO
                     PORT_PCR_IRQC(0xA));     // PTD4 is configured for falling edge interrupts
         //Enable PORTD interrupt on NVIC
     NVIC_ICPR |= 1 << ((INT_PORTD - 16)%32);
     NVIC_ISER |= 1 << ((INT_PORTD - 16)%32);
2. The 7-bit I2C address of the FXOS8700CQ is 0x1E since both SA0 and SA1 lines are shorted to GND using jumpers J21 and J23 on the sensor board. As shown above, the SCL line is connected to the PTC1 pin and SDA line to the PTC2 pin. The I2C clock frequency is 125 kHz.
The screenshot below shows the write operation which writes the value 0x35 to the CTRL_REG1 (0x2A).
And here is the single byte read from the WHO_AM_I register 0x0D. As you can see, it returns the correct value 0xC7.
Multiple bytes of data can be read from sequential registers after each FXOS8700CQ acknowledgment (AK) is received until a no acknowledge (NAK) occurs from the KL25Z followed by a stop condition (SP) signaling an end of transmission. A burst read of 6 bytes from registers 0x33 to 0x38, that is performed in the calibration routine “FXOS8700CQ_Mag_Calibration()”, is shown below. It also shows when the INT1 pin is automatically cleared.
3. At the beginning of the initialization, all registers are reset to their default values by setting the RST bit of the CTRL_REG2 register. Then the FXOS8700CQ is initialized as shown below.
void FXOS8700CQ_Init (void)
     I2C_WriteRegister(FXOS8700CQ_I2C_ADDRESS, CTRL_REG2, 0x40);          // Reset all registers to POR values
     Pause(0x631);        // ~1ms delay
     I2C_WriteRegister(FXOS8700CQ_I2C_ADDRESS, XYZ_DATA_CFG_REG, 0x00);   // +/-2g range with 0.244mg/LSB
     I2C_WriteRegister(FXOS8700CQ_I2C_ADDRESS, M_CTRL_REG1, 0x1F);        // Hybrid mode (accelerometer + magnetometer), max OSR
     I2C_WriteRegister(FXOS8700CQ_I2C_ADDRESS, M_CTRL_REG2, 0x20);        // M_OUT_X_MSB register 0x33 follows the OUT_Z_LSB register 0x06 (used for burst read)
     I2C_WriteRegister(FXOS8700CQ_I2C_ADDRESS, CTRL_REG2, 0x02);          // High Resolution mode
     I2C_WriteRegister(FXOS8700CQ_I2C_ADDRESS, CTRL_REG3, 0x00);          // Push-pull, active low interrupt
     I2C_WriteRegister(FXOS8700CQ_I2C_ADDRESS, CTRL_REG4, 0x01);          // Enable DRDY interrupt
     I2C_WriteRegister(FXOS8700CQ_I2C_ADDRESS, CTRL_REG5, 0x01);          // DRDY interrupt routed to INT1 - PTD4
     I2C_WriteRegister(FXOS8700CQ_I2C_ADDRESS, CTRL_REG1, 0x35);          // ODR = 3.125Hz, Reduced noise, Active mode
4. A simple accelerometer offset calibration method is implemented according to the AN4069.
void FXOS8700CQ_Accel_Calibration (void)
     char X_Accel_offset, Y_Accel_offset, Z_Accel_offset;
     DataReady = 0;
         while (!DataReady){}       // Is a first set of data ready?
     DataReady = 0;
     I2C_WriteRegister(FXOS8700CQ_I2C_ADDRESS, CTRL_REG1, 0x00);          // Standby mode
     I2C_ReadMultiRegisters(FXOS8700CQ_I2C_ADDRESS, OUT_X_MSB_REG, 6, AccelMagData);          // Read data output registers 0x01-0x06
     Xout_Accel_14_bit = ((short) (AccelMagData[0]<<8 | AccelMagData[1])) >> 2;        // Compute 14-bit X-axis acceleration output value
     Yout_Accel_14_bit = ((short) (AccelMagData[2]<<8 | AccelMagData[3])) >> 2;        // Compute 14-bit Y-axis acceleration output value
     Zout_Accel_14_bit = ((short) (AccelMagData[4]<<8 | AccelMagData[5])) >> 2;        // Compute 14-bit Z-axis acceleration output value
     X_Accel_offset = Xout_Accel_14_bit / 8 * (-1);         // Compute X-axis offset correction value
     Y_Accel_offset = Yout_Accel_14_bit / 8 * (-1);         // Compute Y-axis offset correction value
     Z_Accel_offset = (Zout_Accel_14_bit - SENSITIVITY_2G) / 8 * (-1);          // Compute Z-axis offset correction value
     I2C_WriteRegister(FXOS8700CQ_I2C_ADDRESS, OFF_X_REG, X_Accel_offset);
     I2C_WriteRegister(FXOS8700CQ_I2C_ADDRESS, OFF_Y_REG, Y_Accel_offset);
     I2C_WriteRegister(FXOS8700CQ_I2C_ADDRESS, OFF_Z_REG, Z_Accel_offset);
     I2C_WriteRegister(FXOS8700CQ_I2C_ADDRESS, CTRL_REG1, 0x35);          // Active mode again
5. A simple software calibration of magnetic hard-iron offset consists of recording the minimum and maximum magnetometer readings while rotating the board horizontally and vertically and then computing the calibration values from their average. The calibration time is defined by the number of samples taken during calibration (local variable “i” in the while loop) and selected ODR. In my example I use 94 samples at 3.125Hz, so the calibration routine takes 30s.
void FXOS8700CQ_Mag_Calibration (void)
     short Xout_Mag_16_bit_avg, Yout_Mag_16_bit_avg, Zout_Mag_16_bit_avg;
         short Xout_Mag_16_bit_max, Yout_Mag_16_bit_max, Zout_Mag_16_bit_max;
         short Xout_Mag_16_bit_min, Yout_Mag_16_bit_min, Zout_Mag_16_bit_min;
     char i = 0;
     DataReady = 0;
         while (i < 94)             // This takes ~30s (94 samples * 1/3.125)
              if (DataReady)             // Is a new set of data ready?
             DataReady = 0;
             I2C_ReadMultiRegisters(FXOS8700CQ_I2C_ADDRESS, MOUT_X_MSB_REG, 6, AccelMagData);         // Read data output registers 0x33 - 0x38
             Xout_Mag_16_bit = (short) (AccelMagData[0]<<8 | AccelMagData[1]);        // Compute 16-bit X-axis magnetic output value
             Yout_Mag_16_bit = (short) (AccelMagData[2]<<8 | AccelMagData[3]);        // Compute 16-bit Y-axis magnetic output value
             Zout_Mag_16_bit = (short) (AccelMagData[4]<<8 | AccelMagData[5]);        // Compute 16-bit Z-axis magnetic output value
                       // Assign first sample to maximum and minimum values
                       if (i == 0)
                  Xout_Mag_16_bit_max = Xout_Mag_16_bit;
                  Xout_Mag_16_bit_min = Xout_Mag_16_bit;
                  Yout_Mag_16_bit_max = Yout_Mag_16_bit;
                  Yout_Mag_16_bit_min = Yout_Mag_16_bit;
                  Zout_Mag_16_bit_max = Zout_Mag_16_bit;
                  Zout_Mag_16_bit_min = Zout_Mag_16_bit;
                      // Check to see if current sample is the maximum or minimum X-axis value
                      if (Xout_Mag_16_bit > Xout_Mag_16_bit_max)    {Xout_Mag_16_bit_max = Xout_Mag_16_bit;}
                      if (Xout_Mag_16_bit < Xout_Mag_16_bit_min)    {Xout_Mag_16_bit_min = Xout_Mag_16_bit;}
                      // Check to see if current sample is the maximum or minimum Y-axis value
                      if (Yout_Mag_16_bit > Yout_Mag_16_bit_max)    {Yout_Mag_16_bit_max = Yout_Mag_16_bit;}
                      if (Yout_Mag_16_bit < Yout_Mag_16_bit_min)    {Yout_Mag_16_bit_min = Yout_Mag_16_bit;}
                      // Check to see if current sample is the maximum or minimum Z-axis value
                      if (Zout_Mag_16_bit > Zout_Mag_16_bit_max)    {Zout_Mag_16_bit_max = Zout_Mag_16_bit;}
                      if (Zout_Mag_16_bit < Zout_Mag_16_bit_min)    {Zout_Mag_16_bit_min = Zout_Mag_16_bit;}
             i++;
     Xout_Mag_16_bit_avg = (Xout_Mag_16_bit_max + Xout_Mag_16_bit_min) / 2;            // X-axis hard-iron offset
     Yout_Mag_16_bit_avg = (Yout_Mag_16_bit_max + Yout_Mag_16_bit_min) / 2;            // Y-axis hard-iron offset
     Zout_Mag_16_bit_avg = (Zout_Mag_16_bit_max + Zout_Mag_16_bit_min) / 2;            // Z-axis hard-iron offset
     // Left-shift by one as magnetometer offset registers are 15-bit only, left justified
     Xout_Mag_16_bit_avg <<= 1;
     Yout_Mag_16_bit_avg <<= 1;
      Zout_Mag_16_bit_avg <<= 1;
     I2C_WriteRegister(FXOS8700CQ_I2C_ADDRESS, CTRL_REG1, 0x00);          // Standby mode to allow writing to the offset registers
     I2C_WriteRegister(FXOS8700CQ_I2C_ADDRESS, MOFF_X_LSB_REG, (char) (Xout_Mag_16_bit_avg & 0xFF));
     I2C_WriteRegister(FXOS8700CQ_I2C_ADDRESS, MOFF_X_MSB_REG, (char) ((Xout_Mag_16_bit_avg >> & 0xFF));
     I2C_WriteRegister(FXOS8700CQ_I2C_ADDRESS, MOFF_Y_LSB_REG, (char) (Yout_Mag_16_bit_avg & 0xFF));
     I2C_WriteRegister(FXOS8700CQ_I2C_ADDRESS, MOFF_Y_MSB_REG, (char) ((Yout_Mag_16_bit_avg >> & 0xFF));
     I2C_WriteRegister(FXOS8700CQ_I2C_ADDRESS, MOFF_Z_LSB_REG, (char) (Zout_Mag_16_bit_avg & 0xFF));
     I2C_WriteRegister(FXOS8700CQ_I2C_ADDRESS, MOFF_Z_MSB_REG, (char) ((Zout_Mag_16_bit_avg >> & 0xFF));
6. In the ISR, only the interrupt flag is cleared and the DataReady variable is set to indicate the arrival of new data.
void PORTD_IRQHandler()
     PORTD_PCR4 |= PORT_PCR_ISF_MASK;                // Clear the interrupt flag
     DataReady = 1;
7. The output values from accelerometer registers 0x01 – 0x06 are first converted to signed 14-bit integer values and afterwards to real values in g’s. Similarly, the output values from magnetometer registers 0x33 – 0x38 are first converted to signed 16-bit integer values and afterwards to real values in microtesla (µT).
If the board remains flat, then the compass heading can be simply computed from the arctangent of the ratio of the two horizontal magnetic field components. I have used the atan2 function which returns the result in radians (-π and π), so I multiply it by 180/π to end up with degrees.
If you are interested in more complex algorithms for a tilt-compensated e-compass with soft-iron calibration, please refer to our eCompass software.
     DataReady = 0;
     I2C_ReadMultiRegisters(FXOS8700CQ_I2C_ADDRESS, OUT_X_MSB_REG, 12, AccelMagData);         // Read data output registers 0x01-0x06 and 0x33 - 0x38
         // 14-bit accelerometer data
         // Accelerometer data converted to g's
     Xout_g = ((float) Xout_Accel_14_bit) / SENSITIVITY_2G;        // Compute X-axis output value in g's
     Yout_g = ((float) Yout_Accel_14_bit) / SENSITIVITY_2G;        // Compute Y-axis output value in g's
     Zout_g = ((float) Zout_Accel_14_bit) / SENSITIVITY_2G;        // Compute Z-axis output value in g's
         // 16-bit magnetometer data
     Xout_Mag_16_bit = (short) (AccelMagData[6]<<8 | AccelMagData[7]);          // Compute 16-bit X-axis magnetic output value
     Yout_Mag_16_bit = (short) (AccelMagData[8]<<8 | AccelMagData[9]);          // Compute 16-bit Y-axis magnetic output value
     Zout_Mag_16_bit = (short) (AccelMagData[10]<<8 | AccelMagData[11]);        // Compute 16-bit Z-axis magnetic output value
         // Magnetometer data converted to microteslas
     Xout_uT = (float) (Xout_Mag_16_bit) / SENSITIVITY_MAG;        // Compute X-axis output magnetic value in uT
     Yout_uT = (float) (Yout_Mag_16_bit) / SENSITIVITY_MAG;        // Compute Y-axis output magnetic value in uT
     Zout_uT = (float) (Zout_Mag_16_bit) / SENSITIVITY_MAG;        // Compute Z-axis output magnetic value in uT
     Heading = atan2 (Yout_uT, Xout_uT) * 180 / PI;         // Compute Yaw angle
8. The calculated values can be watched in the "Variables" window on the top right of the Debug perspective or in the FreeMASTER application. To open and run the FreeMASTER project, install the FreeMASTER 1.4 application and FreeMASTER Communication Driver.
Attached you can find the complete source code written in the CW for MCU's v10.5 including the FreeMASTER project.
If there are any questions regarding this simple application, please feel free to ask below. Your feedback or suggestions are also welcome.
Tomas
Original Attachment has been moved to: FRDM-KL25Z-FXOS8700CQ-Basic-read-using-I2C-and-interrupt.zip
Original Attachment has been moved to: FreeMASTER---FRDM-KL25Z-FXOS8700CQ-Basic-read-using-I2C-and-interrupt.zip
标签 (2)
评论
Hi Tomas,
Thanks for posting this project! I want to make a similar project using the FXOS8700CQ that is on the FRDM K64F board and with MQX. Do you know if somebody has done this?
David
Hi David,
Please try contacting Mike Stanley ([email protected]), he and his team have been working on the Xtrinsic sensor fusion library for Kinetis MCUs that is based on MQX Lite RTOS and they recently added support for the FRDM-K64F board.
Tomas
I am new to these devices. I have been given the task of setting up the FXOS8700CQ on one of our projects. I only intend on using the magnetometer side of the device. I would like to use the interrupt to update a funcation when data is available so it can go and get some data.
If i am using the magnetometer side only, what registers do i need to configure. How do i do a calibration of the magnetometer and general reading of the data from the magnetometer?
Luke
Hi David;
Any chance that you got that to work?
I am working on a graduate project and need the same K64f board to work.
Thanks :smileyhappy:
Hi Mustafa,
Have a look at this example code or this post. Hope it helps.
Tomas
Hi Tomas,
With the real g’s and µT data, is there an algorithm to calculate the real position?
Tommy
Hi Tommy,
What is the values for SENSITIVITY_MAG=??? & SENSITIVITY_2G=??
anil
Hi Thomas,
I am just adding
SENSITIVITY_2G = 0.244 (mg)
SENSITIVITY_MAG = 0.1 (uT)
applying the above values in the code. Is it right? or any other values need to specify.
anil
Hi Anil,
This is defined in the FXOS8700CQ.h file (Project_Headers/FXOS8700CQ.h).
//FXOS8700CQ Sensitivity
#define SENSITIVITY_2G 4096
#define SENSITIVITY_4G 2048
#define SENSITIVITY_8G 1024
#define SENSITIVITY_MAG 10
Tomas
Hi Thomas,
After converted the Raw values and getting the heading angle shows in between -180 to +180.
How to covert from -180 to +180  to 0 to 360 angle.
Anil
Hi Anil,
I believe it should be pretty simple:
Heading = 180 + atan2 (Yout_uT, Xout_uT) * 180 / PI;
Tomas
In accelerometer calibration on 2g sensitivity is used this equation:
My question is, and when do I use sensitivity 4g and 8g?
Remains the same equation? The number 8, which divided the first part of the equation, is always this value, either for 2g, 4g or 8g?
In my project, I need change the sensitivity and I want calibrate for this new sensitivity.
Thank for help.
Regards.
Alexandre
Hi Alexandre,
SENSITIVITY_2G corresponds to fs[1:0] = 0b00, SENSITIVITY_4G to fs[1:0] = 0b01 and SENSITIVITY_8G to fs[1:0] = 0b10.
Note that the resolution of OFF_X(YZ) registers is 2mg per LSB, that is why I use the number 8 for 2g. For 4g the number is 4 and for 8g it is 2. For more information please refer to the AN4069.
Tomas
Hi Tomas,
   I'm a greenhand to these devises, I'm try to apply the accelerometer FXOS8700CQ in FRDM-K66F board. I'd like to learn to  how to activate the FXOS8700CQ sensor in FRDM-K66F. May I know where can I get some learning materials such as example codes.
Yue.
%3CLINGO-SUB%20id%3D%22lingo-sub-1103701%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFXOS8700CQ%E2%80%94%E2%80%94%E8%A3%B8%E6%9C%BA%E9%A1%B9%E7%9B%AE%E7%A4%BA%E4%BE%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103701%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%A4%A7%E5%AE%B6%E5%A5%BD%EF%BC%8C%3C%2FP%3E%0A%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%E7%94%B1%E4%BA%8E%E6%88%91%E7%BB%8F%E5%B8%B8%E8%A2%AB%E8%A6%81%E6%B1%82%E6%8F%90%E4%BE%9B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fwww.freescale.com%252Fwebapp%252Fsps%252Fsite%252Fprod_summary.jsp%253Fcode%253DFXOS8700CQ%22%20target%3D%22_blank%22%3EXtrinsic%20FXOS8700CQ%206%20%E8%BD%B4%E4%BC%A0%E6%84%9F%E5%99%A8%3C%2FA%3E%E7%9A%84%E7%AE%80%E5%8D%95%E8%A3%B8%E6%9C%BA%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%EF%BC%8C%E5%9B%A0%E6%AD%A4%E6%88%91%E6%83%B3%E5%9C%A8%E8%BF%99%E9%87%8C%E5%88%86%E4%BA%AB%E6%88%91%E4%B8%BA%E6%AD%A4%E9%83%A8%E5%88%86%E5%88%9B%E5%BB%BA%E7%9A%84%E4%B8%80%E4%B8%AA%E7%A4%BA%E4%BE%8B%EF%BC%8C%E5%90%8C%E6%97%B6%E4%BD%BF%E7%94%A8%20Freescale%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fwww.freescale.com%252Fwebapp%252Fsps%252Fsite%252Fprod_summary.jsp%253Fcode%253DFRDM-KL25Z%22%20target%3D%22_blank%22%3EFRDM-KL25Z%20%E5%B9%B3%E5%8F%B0%3C%2FA%3E%E5%92%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fwww.freescale.com%252Fwebapp%252Fsps%252Fsite%252Fprod_summary.jsp%253Fcode%253DFRDM-FXS-MULTI-B%22%20target%3D%22_blank%22%3EFRDM-FXS-MULTI(-B)%20%E4%BC%A0%E6%84%9F%E5%99%A8%E6%89%A9%E5%B1%95%E6%9D%BF%EF%BC%8C%E8%AF%A5%E6%89%A9%E5%B1%95%E6%9D%BF%3C%2FA%3E%E5%85%B7%E6%9C%89%E8%AE%B8%E5%A4%9A%20Xtrinsic%20%E4%BC%A0%E6%84%9F%E5%99%A8%EF%BC%8C%E5%8C%85%E6%8B%AC%20FXOS8700CQ%E3%80%82%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fwww.freescale.com%252Fwebapp%252Fsps%252Fsite%252Fprod_summary.jsp%253Fcode%253DFREEMASTER%22%20target%3D%22_blank%22%3EFreeMASTER%20%E5%B7%A5%E5%85%B7%3C%2FA%3E%E7%94%A8%E4%BA%8E%E5%8F%AF%E8%A7%86%E5%8C%96%E9%80%9A%E8%BF%87%20I%20%3CSUP%3E2%3C%2FSUP%3E%20C%20%E6%8E%A5%E5%8F%A3%E4%BD%BF%E7%94%A8%E4%B8%AD%E6%96%AD%E6%8A%80%E6%9C%AF%E4%BB%8E%20FXOS8700CQ%20%E8%AF%BB%E5%8F%96%E7%9A%84%E5%8A%A0%E9%80%9F%E5%BA%A6%E5%92%8C%E7%A3%81%E5%9C%BA%E6%95%B0%E6%8D%AE%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20background%3A%20white%3B%22%3E%E6%AD%A4%E7%A4%BA%E4%BE%8B%E8%AF%B4%E6%98%8E%EF%BC%9A%3C%2FP%3E%0A%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E1.%20MKL25Z128%20MCU%20%E7%9A%84%E5%88%9D%E5%A7%8B%E5%8C%96%EF%BC%88%E4%B8%BB%E8%A6%81%E6%98%AF%20I2C%20%E5%92%8C%20PORT%20%E6%A8%A1%E5%9D%97%EF%BC%89%E3%80%82%3C%2FP%3E%0A%3CP%3E2.%20%3CSUP%3EI2C%3C%2FSUP%3E%E6%95%B0%E6%8D%AE%E5%86%99%E5%85%A5%E3%80%81%E8%AF%BB%E5%8F%96%E6%93%8D%E4%BD%9C%E3%80%82%3C%2FP%3E%0A%3CP%3E3.FXOS8700CQ%E7%9A%84%E5%88%9D%E5%A7%8B%E5%8C%96%E3%80%82%3C%2FP%3E%0A%3CP%3E4.%E5%9F%BA%E4%BA%8E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fwww.freescale.com%252Ffiles%252Fsensors%252Fdoc%252Fapp_note%252FAN4069.pdf%22%20target%3D%22_blank%22%3EAN4069%E7%9A%84%3C%2FA%3E%E7%AE%80%E5%8D%95%E5%8A%A0%E9%80%9F%E5%BA%A6%E8%AE%A1%E5%81%8F%E7%A7%BB%E6%A0%A1%E5%87%86%E3%80%82%3C%2FP%3E%0A%3CP%3E5.%E7%AE%80%E5%8D%95%E7%9A%84%E7%A3%81%E6%80%A7%E7%A1%AC%E9%93%81%E5%81%8F%E7%A7%BB%E6%A0%A1%E5%87%86%E3%80%82%3C%2FP%3E%0A%3CP%3E6.%E9%87%87%E7%94%A8%E4%B8%AD%E6%96%AD%E6%8A%80%E6%9C%AF%E8%BE%93%E5%87%BA%E6%95%B0%E6%8D%AE%E8%AF%BB%E5%8F%96%E3%80%82%3C%2FP%3E%0A%3CP%3E7.%20%E5%B0%86%E5%AF%84%E5%AD%98%E5%99%A8%200x01%20%E2%80%93%200x06%20%E5%92%8C%200x33%20%E2%80%93%200x38%20%E7%9A%84%E8%BE%93%E5%87%BA%E5%80%BC%E8%BD%AC%E6%8D%A2%E4%B8%BA%20g%20%E5%92%8C%20%C2%B5T%20%E4%B8%AD%E7%9A%84%E5%AE%9E%E9%99%85%E5%80%BC%E4%BB%A5%E5%8F%8A%E7%AE%80%E5%8D%95%E7%9A%84%E8%88%AA%E5%90%91%E8%A7%92%E8%AE%A1%E7%AE%97%E3%80%82%3C%2FP%3E%0A%3CP%3E8.%20%E5%9C%A8%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fwww.freescale.com%252Fwebapp%252Fsps%252Fsite%252Fprod_summary.jsp%253Fcode%253DFREEMASTER%22%20target%3D%22_blank%22%3EFreeMASTER%20%E5%B7%A5%E5%85%B7%3C%2FA%3E%E4%B8%AD%E5%8F%AF%E8%A7%86%E5%8C%96%E8%AE%A1%E7%AE%97%E5%80%BC%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E1.%20%E5%A6%82%3C%2FSPAN%3E%3CSPAN%20style%3D%22line-height%3A%201.5em%3B%20font-size%3A%2010pt%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fcache.freescale.com%252Ffiles%252Fsensors%252Fdoc%252Fsupport_info%252FFRDM-FXS-MULTI-B.pdf%22%20target%3D%22_blank%22%3E%20FRDM-FXS-MULTI(-B)%3C%2FA%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%20%2F%3C%2FSPAN%3E%3CSPAN%20style%3D%22line-height%3A%201.5em%3B%20font-size%3A%2010pt%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fcache.freescale.com%252Ffiles%252Fsoft_dev_tools%252Fhardware_tools%252Fschematics%252FFRDM-KL25Z_SCH_REV_E.pdf%22%20target%3D%22_blank%22%3E%20FRDM-KL25Z%3C%2FA%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%20%E5%8E%9F%E7%90%86%E5%9B%BE%E5%92%8C%E4%B8%8B%E5%9B%BE%20%E6%89%80%E7%A4%BA%20%EF%BC%8CI2C%20%E4%BF%A1%E5%8F%B7%E8%B7%AF%E7%94%B1%E8%87%B3%20KL25Z%20MCU%20%E7%9A%84%20I2C1%20%E6%A8%A1%E5%9D%97%EF%BC%88PTC1%20%E5%92%8C%20PTC2%20%E5%BC%95%E8%84%9A%EF%BC%89%EF%BC%8CINT1%20%E8%BE%93%E5%87%BA%E8%BF%9E%E6%8E%A5%E8%87%B3%20PTD4%20%E5%BC%95%E8%84%9A%EF%BC%88%E7%A1%AE%E4%BF%9D%E4%BC%A0%E6%84%9F%E5%99%A8%E6%89%A9%E5%B1%95%E6%9D%BF%E4%B8%8A%20J3%20%E7%9A%84%201-2%20%E5%BC%95%E8%84%9A%E4%BD%BF%E7%94%A8%E8%B7%B3%E7%BA%BF%E8%BF%9E%E6%8E%A5%E5%9C%A8%E4%B8%80%E8%B5%B7%EF%BC%89%E3%80%82FXOS8700CQ%20%E7%9A%84%20INT1%20%E8%BE%93%E5%87%BA%E9%85%8D%E7%BD%AE%E4%B8%BA%E6%8E%A8%E6%8C%BD%E5%BC%8F%E4%BD%8E%E7%94%B5%E5%B9%B3%E6%9C%89%E6%95%88%E8%BE%93%E5%87%BA%EF%BC%8C%E5%9B%A0%E6%AD%A4%E7%9B%B8%E5%BA%94%E7%9A%84%20PTD4%20%E5%BC%95%E8%84%9A%E9%85%8D%E7%BD%AE%E4%B8%BA%20GPIO%EF%BC%8C%E5%B9%B6%E5%9C%A8%E4%B8%8B%E9%99%8D%E6%B2%BF%E8%A7%A6%E5%8F%91%E4%B8%AD%E6%96%AD%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%2212193_12193.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2212193_12193.jpg%22%20style%3D%22width%3A%20797px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117220iD30D076CC0C7AA65%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2212193_12193.jpg%22%20alt%3D%2212193_12193.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E12193_12193.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E5%9B%A0%E6%AD%A4%EF%BC%8CMCU%20%E9%85%8D%E7%BD%AE%E5%A6%82%E4%B8%8B%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3Evoid%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%20%3CSTRONG%3EMCU_Init%3C%2FSTRONG%3E(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3Evoid%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E)%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F%2FI2C1%20module%20initialization%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3ESIM_SCGC4%20%7C%3D%20SIM_SCGC4_I2C1_MASK%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20%E6%89%93%E5%BC%80%20I2C1%20%E6%A8%A1%E5%9D%97%E7%9A%84%E6%97%B6%E9%92%9F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3ESIM_SCGC5%20%7C%3D%20SIM_SCGC5_PORTC_MASK%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20%E6%89%93%E5%BC%80%E7%AB%AF%E5%8F%A3%20C%20%E6%A8%A1%E5%9D%97%E7%9A%84%E6%97%B6%E9%92%9F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EPORTC_PCR1%20%7C%3D%20PORT_PCR_MUX(0x2)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20PTC1%20%E5%BC%95%E8%84%9A%E4%B8%BA%20I2C1%20SCL%20%E7%BA%BF%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EPORTC_PCR2%20%7C%3D%20PORT_PCR_MUX(0x2)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20PTC2%20%E5%BC%95%E8%84%9A%E4%B8%BA%20I2C1%20SDA%20%E7%BA%BF%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EI2C1_F%20%7C%3D%20I2C_F_ICR(0x14)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20SDA%20%E4%BF%9D%E6%8C%81%E6%97%B6%E9%97%B4%20%3D%202.125us%EF%BC%8CSCL%20%E5%90%AF%E5%8A%A8%E4%BF%9D%E6%8C%81%E6%97%B6%E9%97%B4%20%3D%204.25us%EF%BC%8CSCL%20%E5%81%9C%E6%AD%A2%E4%BF%9D%E6%8C%81%E6%97%B6%E9%97%B4%20%3D%205.125us%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EI2C1_C1%20%7C%3D%20I2C_C1_IICEN_MASK%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20%E5%90%AF%E7%94%A8%20I2C0%20%E6%A8%A1%E5%9D%97%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%E9%85%8D%E7%BD%AE%20PTD4%20%E5%BC%95%E8%84%9A%EF%BC%88%E8%BF%9E%E6%8E%A5%E5%88%B0%20FXOS8700CQ%20%E7%9A%84%20INT1%EF%BC%89%E7%94%A8%E4%BA%8E%E4%B8%8B%E9%99%8D%E6%B2%BF%E4%B8%AD%E6%96%AD%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3ESIM_SCGC5%20%7C%3D%20SIM_SCGC5_PORTD_MASK%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20%E6%89%93%E5%BC%80%E7%AB%AF%E5%8F%A3%20A%20%E6%A8%A1%E5%9D%97%E7%9A%84%E6%97%B6%E9%92%9F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EPORTD_PCR4%20%7C%3D%20(0%7CPORT_PCR_ISF_MASK%7C%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%E6%B8%85%E9%99%A4%E4%B8%AD%E6%96%AD%E6%A0%87%E5%BF%97%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EPORT_PCR_MUX(0x1)%7C%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20PTD4%20%E9%85%8D%E7%BD%AE%E4%B8%BA%20GPIO%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EPORT_PCR_IRQC(0xA))%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20PTD4%20%E9%85%8D%E7%BD%AE%E4%B8%BA%E4%B8%8B%E9%99%8D%E6%B2%BF%E4%B8%AD%E6%96%AD%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%E5%9C%A8NVIC%E4%B8%8A%E5%90%AF%E7%94%A8PORTD%E4%B8%AD%E6%96%AD%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3ENVIC_ICPR%20%7C%3D%201%20%26lt%3B%26lt%3B%20((%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%230000c0%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CEM%3EINT_PORTD%3C%2FEM%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E-%2016)%2532)%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3ENVIC_ISER%20%7C%3D%201%20%26lt%3B%26lt%3B%20((%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%230000c0%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CEM%3EINT_PORTD%3C%2FEM%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E-%2016)%2532)%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E2.%20FXOS8700CQ%20%E7%9A%84%207%20%E4%BD%8D%20I2C%20%E5%9C%B0%E5%9D%80%E4%B8%BA%200x1E%EF%BC%8C%E5%9B%A0%E4%B8%BA%20SA0%20%E5%92%8C%20SA1%20%E7%BA%BF%E5%9D%87%E4%BD%BF%E7%94%A8%E4%BC%A0%E6%84%9F%E5%99%A8%E6%9D%BF%E4%B8%8A%E7%9A%84%E8%B7%B3%E7%BA%BF%20J21%20%E5%92%8C%20J23%20%E7%9F%AD%E6%8E%A5%E8%87%B3%20GND%E3%80%82%E5%A6%82%E4%B8%8A%E6%89%80%E7%A4%BA%EF%BC%8CSCL%20%E7%BA%BF%E8%BF%9E%E6%8E%A5%E5%88%B0%20PTC1%20%E5%BC%95%E8%84%9A%EF%BC%8CSDA%20%E7%BA%BF%E8%BF%9E%E6%8E%A5%E5%88%B0%20PTC2%20%E5%BC%95%E8%84%9A%E3%80%82I2C%E6%97%B6%E9%92%9F%E9%A2%91%E7%8E%87%E4%B8%BA125%20kHz%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%E4%B8%8B%E9%9D%A2%E7%9A%84%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%E6%98%BE%E7%A4%BA%E4%BA%86%E5%B0%86%E5%80%BC%200x35%20%E5%86%99%E5%85%A5%20CTRL_REG1%20(0x2A)%20%E7%9A%84%E5%86%99%E5%85%A5%E6%93%8D%E4%BD%9C%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%2212189_12189.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2212189_12189.jpg%22%20style%3D%22width%3A%20847px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117221i86D0C92628294F56%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2212189_12189.jpg%22%20alt%3D%2212189_12189.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E12189_12189.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%E8%BF%99%E6%98%AF%E4%BB%8E%20WHO_AM_I%20%E5%AF%84%E5%AD%98%E5%99%A8%200x0D%20%E8%AF%BB%E5%8F%96%E7%9A%84%E5%8D%95%E4%B8%AA%E5%AD%97%E8%8A%82%E3%80%82%E5%A6%82%E6%82%A8%E6%89%80%E8%A7%81%EF%BC%8C%E5%AE%83%E8%BF%94%E5%9B%9E%E6%AD%A3%E7%A1%AE%E7%9A%84%E5%80%BC%200xC7%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%2212188_12188.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2212188_12188.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117222i3C47D141E8974197%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2212188_12188.jpg%22%20alt%3D%2212188_12188.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E12188_12188.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%E5%9C%A8%E6%94%B6%E5%88%B0%E6%AF%8F%E4%B8%AA%20FXOS8700CQ%20%E7%A1%AE%E8%AE%A4%20(AK)%20%E5%90%8E%EF%BC%8C%E5%8F%AF%E4%BB%A5%E4%BB%8E%E8%BF%9E%E7%BB%AD%E5%AF%84%E5%AD%98%E5%99%A8%E8%AF%BB%E5%8F%96%E5%A4%9A%E4%B8%AA%E5%AD%97%E8%8A%82%E7%9A%84%E6%95%B0%E6%8D%AE%EF%BC%8C%E7%9B%B4%E5%88%B0%20KL25Z%20%E5%87%BA%E7%8E%B0%E6%97%A0%E7%A1%AE%E8%AE%A4%20(NAK)%EF%BC%8C%E7%84%B6%E5%90%8E%E5%87%BA%E7%8E%B0%E8%A1%A8%E7%A4%BA%E4%BC%A0%E8%BE%93%E7%BB%93%E6%9D%9F%E7%9A%84%E5%81%9C%E6%AD%A2%E6%9D%A1%E4%BB%B6%20(SP)%E3%80%82%E4%B8%8B%E9%9D%A2%E6%98%BE%E7%A4%BA%E4%BA%86%E5%9C%A8%E6%A0%A1%E5%87%86%E4%BE%8B%E7%A8%8B%E2%80%9CFXOS8700CQ_Mag_Calibration()%E2%80%9D%E4%B8%AD%E6%89%A7%E8%A1%8C%E7%9A%84%E4%BB%8E%E5%AF%84%E5%AD%98%E5%99%A8%200x33%20%E5%88%B0%200x38%20%E7%9A%84%206%20%E4%B8%AA%E5%AD%97%E8%8A%82%E7%9A%84%E7%AA%81%E5%8F%91%E8%AF%BB%E5%8F%96%E3%80%82%E5%AE%83%E8%BF%98%E6%98%BE%E7%A4%BA%20INT1%20%E5%BC%95%E8%84%9A%E4%BD%95%E6%97%B6%E8%87%AA%E5%8A%A8%E6%B8%85%E9%99%A4%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%2212190_12190.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2212190_12190.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117223iF34B10A56FA4FD01%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2212190_12190.jpg%22%20alt%3D%2212190_12190.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E12190_12190.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E3.%20%E5%9C%A8%E5%88%9D%E5%A7%8B%E5%8C%96%E5%BC%80%E5%A7%8B%E6%97%B6%EF%BC%8C%E9%80%9A%E8%BF%87%E8%AE%BE%E7%BD%AE%20CTRL_REG2%20%E5%AF%84%E5%AD%98%E5%99%A8%E7%9A%84%20RST%20%E4%BD%8D%E5%B0%86%E6%89%80%E6%9C%89%E5%AF%84%E5%AD%98%E5%99%A8%E9%87%8D%E7%BD%AE%E4%B8%BA%E5%85%B6%E9%BB%98%E8%AE%A4%E5%80%BC%E3%80%82%E7%84%B6%E5%90%8EFXOS8700CQ%E5%88%9D%E5%A7%8B%E5%8C%96%E5%A6%82%E4%B8%8B%E5%9B%BE%E6%89%80%E7%A4%BA%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3Evoid%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%20%3CSTRONG%3EFXOS8700CQ_Init%3C%2FSTRONG%3E%20(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3Evoid%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E)%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EI2C_WriteRegister(FXOS8700CQ_I2C_ADDRESS%2C%20CTRL_REG2%2C%200x40)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20%E5%B0%86%E6%89%80%E6%9C%89%E5%AF%84%E5%AD%98%E5%99%A8%E9%87%8D%E7%BD%AE%E4%B8%BA%20POR%20%E5%80%BC%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%E6%9A%82%E5%81%9C%EF%BC%880x631%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%E5%BB%B6%E8%BF%9F%E7%BA%A6%201%20%E6%AF%AB%E7%A7%92%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EI2C_WriteRegister(FXOS8700CQ_I2C_ADDRESS%2C%20XYZ_DATA_CFG_REG%2C%200x00)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20%2B%2F-2g%20%E8%8C%83%E5%9B%B4%EF%BC%8C0.244mg%2FLSB%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EI2C_WriteRegister(FXOS8700CQ_I2C_ADDRESS%2C%20M_CTRL_REG1%2C%200x1F)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%E6%B7%B7%E5%90%88%E6%A8%A1%E5%BC%8F%EF%BC%88%E5%8A%A0%E9%80%9F%E5%BA%A6%E8%AE%A1%2B%E7%A3%81%E5%8A%9B%E8%AE%A1%EF%BC%89%EF%BC%8C%E6%9C%80%E5%A4%A7OSR%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EI2C_WriteRegister(FXOS8700CQ_I2C_ADDRESS%2C%20M_CTRL_REG2%2C%200x20)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20M_OUT_X_MSB%20%E5%AF%84%E5%AD%98%E5%99%A8%200x33%20%E8%B7%9F%E9%9A%8F%20OUT_Z_LSB%20%E5%AF%84%E5%AD%98%E5%99%A8%200x06%EF%BC%88%E7%94%A8%E4%BA%8E%E7%AA%81%E5%8F%91%E8%AF%BB%E5%8F%96%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EI2C_WriteRegister(FXOS8700CQ_I2C_ADDRESS%2C%20CTRL_REG2%2C%200x02)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%E9%AB%98%E5%88%86%E8%BE%A8%E7%8E%87%E6%A8%A1%E5%BC%8F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EI2C_WriteRegister(FXOS8700CQ_I2C_ADDRESS%2C%20CTRL_REG3%2C%200x00)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%E6%8E%A8%E6%8C%BD%EF%BC%8C%E4%BD%8E%E7%94%B5%E5%B9%B3%E6%9C%89%E6%95%88%E4%B8%AD%E6%96%AD%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EI2C_WriteRegister(FXOS8700CQ_I2C_ADDRESS%2C%20CTRL_REG4%2C%200x01)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%E5%90%AF%E7%94%A8DRDY%E4%B8%AD%E6%96%AD%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EI2C_WriteRegister(FXOS8700CQ_I2C_ADDRESS%2C%20CTRL_REG5%2C%200x01)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2FDRDY%E4%B8%AD%E6%96%AD%E8%B7%AF%E7%94%B1%E5%88%B0INT1%20-%20PTD4%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EI2C_WriteRegister(FXOS8700CQ_I2C_ADDRESS%2C%20CTRL_REG1%2C%200x35)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20ODR%20%3D%203.125Hz%EF%BC%8C%E9%99%8D%E4%BD%8E%E5%99%AA%E9%9F%B3%EF%BC%8C%E4%B8%BB%E5%8A%A8%E6%A8%A1%E5%BC%8F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E4.%E6%A0%B9%E6%8D%AE%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fwww.freescale.com%252Ffiles%252Fsensors%252Fdoc%252Fapp_note%252FAN4069.pdf%22%20target%3D%22_blank%22%3EAN4069%3C%2FA%3E%E5%AE%9E%E7%8E%B0%E4%BA%86%E4%B8%80%E7%A7%8D%E7%AE%80%E5%8D%95%E7%9A%84%E5%8A%A0%E9%80%9F%E5%BA%A6%E8%AE%A1%E5%A4%B1%E8%B0%83%E6%A0%A1%E5%87%86%E6%96%B9%E6%B3%95%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3Evoid%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%20%3CSTRONG%3EFXOS8700CQ_Accel_Calibration%3C%2FSTRONG%3E%20(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3Evoid%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E)%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3Echar%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EX_Accel_offset%EF%BC%8CY_Accel_offset%EF%BC%8CZ_Accel_offset%EF%BC%9B%3C%2FSPAN%3E%20%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%E6%95%B0%E6%8D%AE%E5%B0%B1%E7%BB%AA%3D0%EF%BC%9B%20%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3Ewhile%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E(!DataReady)%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%7B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%7D%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20%E7%AC%AC%E4%B8%80%E7%BB%84%E6%95%B0%E6%8D%AE%E6%98%AF%E5%90%A6%E5%87%86%E5%A4%87%E5%A5%BD%E4%BA%86%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%E6%95%B0%E6%8D%AE%E5%B0%B1%E7%BB%AA%3D0%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EI2C_WriteRegister(FXOS8700CQ_I2C_ADDRESS%2C%20CTRL_REG1%2C%200x00)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%E5%BE%85%E6%9C%BA%E6%A8%A1%E5%BC%8F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EI2C_ReadMultiRegisters(FXOS8700CQ_I2C_ADDRESS%2C%20OUT_X_MSB_REG%2C%206%2C%20AccelMagData)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%E8%AF%BB%E5%8F%96%E6%95%B0%E6%8D%AE%E8%BE%93%E5%87%BA%E5%AF%84%E5%AD%98%E5%99%A80x01-0x06%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EXout_Accel_14_bit%20%3D%20((%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3Eshort%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E)%20(AccelMagData%5B0%5D%26lt%3B%26lt%3B8%20%7C%20AccelMagData%5B1%5D))%20%26gt%3B%26gt%3B%202%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%E8%AE%A1%E7%AE%9714%E4%BD%8DX%E8%BD%B4%E5%8A%A0%E9%80%9F%E5%BA%A6%E8%BE%93%E5%87%BA%E5%80%BC%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EYout_Accel_14_bit%20%3D%20((%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3Eshort%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E)%20(AccelMagData%5B2%5D%26lt%3B%26lt%3B8%20%7C%20AccelMagData%5B3%5D))%20%26gt%3B%26gt%3B%202%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20%E8%AE%A1%E7%AE%97%2014%20%E4%BD%8D%20Y%20%E8%BD%B4%E5%8A%A0%E9%80%9F%E5%BA%A6%E8%BE%93%E5%87%BA%E5%80%BC%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EZout_Accel_14_bit%20%3D%20((%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3Eshort%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E)%20(AccelMagData%5B4%5D%26lt%3B%26lt%3B8%20%7C%20AccelMagData%5B5%5D))%20%26gt%3B%26gt%3B%202%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%E8%AE%A1%E7%AE%9714%E4%BD%8DZ%E8%BD%B4%E5%8A%A0%E9%80%9F%E5%BA%A6%E8%BE%93%E5%87%BA%E5%80%BC%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EX_Accel_offset%20%3D%20Xout_Accel_14_bit%20%2F%208%20*%20(-1)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%E8%AE%A1%E7%AE%97X%E8%BD%B4%E5%81%8F%E7%A7%BB%E6%A0%A1%E6%AD%A3%E5%80%BC%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EY_Accel_offset%20%3D%20Yout_Accel_14_bit%20%2F%208%20*%20(-1)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%E8%AE%A1%E7%AE%97Y%E8%BD%B4%E5%81%8F%E7%A7%BB%E6%A0%A1%E6%AD%A3%E5%80%BC%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EZ_Accel_offset%20%3D%20(Zout_Accel_14_bit%20-%20SENSITIVITY_2G)%20%2F%208%20*%20(-1)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%E8%AE%A1%E7%AE%97Z%E8%BD%B4%E5%81%8F%E7%A7%BB%E6%A0%A1%E6%AD%A3%E5%80%BC%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EI2C_WriteRegister%EF%BC%88FXOS8700CQ_I2C_ADDRESS%EF%BC%8COFF_X_REG%EF%BC%8CX_Accel_offset%EF%BC%89%EF%BC%9B%20%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EI2C_WriteRegister%EF%BC%88FXOS8700CQ_I2C_ADDRESS%EF%BC%8COFF_Y_REG%EF%BC%8CY_Accel_offset%EF%BC%89%EF%BC%9B%20%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EI2C_WriteRegister%EF%BC%88FXOS8700CQ_I2C_ADDRESS%EF%BC%8COFF_Z_REG%EF%BC%8CZ_Accel_offset%EF%BC%89%EF%BC%9B%20%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EI2C_WriteRegister(FXOS8700CQ_I2C_ADDRESS%2C%20CTRL_REG1%2C%200x35)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%E5%86%8D%E6%AC%A1%E8%BF%9B%E5%85%A5%E6%B4%BB%E5%8A%A8%E6%A8%A1%E5%BC%8F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E5.%20%E7%A3%81%E6%80%A7%E7%A1%AC%E9%93%81%E5%81%8F%E7%A7%BB%E7%9A%84%E7%AE%80%E5%8D%95%E8%BD%AF%E4%BB%B6%E6%A0%A1%E5%87%86%E5%8C%85%E6%8B%AC%E5%9C%A8%E6%B0%B4%E5%B9%B3%E5%92%8C%E5%9E%82%E7%9B%B4%E6%97%8B%E8%BD%AC%E6%9D%BF%E6%97%B6%E8%AE%B0%E5%BD%95%E7%A3%81%E5%8A%9B%E8%AE%A1%E7%9A%84%E6%9C%80%E5%B0%8F%E5%92%8C%E6%9C%80%E5%A4%A7%E8%AF%BB%E6%95%B0%EF%BC%8C%E7%84%B6%E5%90%8E%E6%A0%B9%E6%8D%AE%E5%AE%83%E4%BB%AC%E7%9A%84%E5%B9%B3%E5%9D%87%E5%80%BC%E8%AE%A1%E7%AE%97%E6%A0%A1%E5%87%86%E5%80%BC%E3%80%82%E6%A0%A1%E5%87%86%E6%97%B6%E9%97%B4%E7%94%B1%E6%A0%A1%E5%87%86%E6%9C%9F%E9%97%B4%E9%87%87%E9%9B%86%E7%9A%84%E6%A0%B7%E6%9C%AC%E6%95%B0%EF%BC%88while%20%E5%BE%AA%E7%8E%AF%E4%B8%AD%E7%9A%84%E5%B1%80%E9%83%A8%E5%8F%98%E9%87%8F%E2%80%9Ci%E2%80%9D%EF%BC%89%E5%92%8C%E6%89%80%E9%80%89%E7%9A%84%20ODR%20%E5%AE%9A%E4%B9%89%E3%80%82%E5%9C%A8%E6%88%91%E7%9A%84%E4%BE%8B%E5%AD%90%E4%B8%AD%EF%BC%8C%E6%88%91%E4%BD%BF%E7%94%A8%E4%BA%86%203.125Hz%20%E7%9A%84%2094%20%E4%B8%AA%E6%A0%B7%E6%9C%AC%EF%BC%8C%E5%9B%A0%E6%AD%A4%E6%A0%A1%E5%87%86%E7%A8%8B%E5%BA%8F%E9%9C%80%E8%A6%81%2030%20%E7%A7%92%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3Evoid%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%20%3CSTRONG%3EFXOS8700CQ_Mag_Calibration%3C%2FSTRONG%3E%20(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3Evoid%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E)%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3E%E7%9F%AD%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EXout_Mag_16_bit_avg%E3%80%81Yout_Mag_16_bit_avg%E3%80%81Zout_Mag_16_bit_avg%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3E%E7%9F%AD%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EXout_Mag_16_bit_max%E3%80%81Yout_Mag_16_bit_max%E3%80%81Zout_Mag_16_bit_max%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3E%E7%9F%AD%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EXout_Mag_16_bit_min%E3%80%81Yout_Mag_16_bit_min%E3%80%81Zout_Mag_16_bit_min%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20char%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%20i%20%3D%200%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%E6%95%B0%E6%8D%AE%E5%B0%B1%E7%BB%AA%3D0%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3Ewhile%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E(i%20%26lt%3B%2094)%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20%E8%BF%99%E9%9C%80%E8%A6%81~30%E7%A7%92%EF%BC%8894%E4%B8%AA%E6%A0%B7%E6%9C%AC*1%20%2F%203.125%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3Eif%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E(DataReady)%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20%E6%96%B0%E7%9A%84%E4%B8%80%E7%BB%84%E6%95%B0%E6%8D%AE%E6%98%AF%E5%90%A6%E5%87%86%E5%A4%87%E5%A5%BD%E4%BA%86%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%7B%20%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%E6%95%B0%E6%8D%AE%E5%B0%B1%E7%BB%AA%3D0%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EI2C_ReadMultiRegisters(FXOS8700CQ_I2C_ADDRESS%2C%20MOUT_X_MSB_REG%2C%206%2C%20AccelMagData)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%E8%AF%BB%E5%8F%96%E6%95%B0%E6%8D%AE%E8%BE%93%E5%87%BA%E5%AF%84%E5%AD%98%E5%99%A8%200x33%20-%200x38%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EXout_Mag_16_bit%20%3D%20(%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3Eshort%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E)%20(AccelMagData%5B0%5D%26lt%3B%26lt%3B8%20%7C%20AccelMagData%5B1%5D)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%E8%AE%A1%E7%AE%9716%E4%BD%8DX%E8%BD%B4%E7%A3%81%E8%BE%93%E5%87%BA%E5%80%BC%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EYout_Mag_16_bit%20%3D%20(%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3Eshort%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E)%20(AccelMagData%5B2%5D%26lt%3B%26lt%3B8%20%7C%20AccelMagData%5B3%5D)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20%E8%AE%A1%E7%AE%97%2016%20%E4%BD%8D%20Y%20%E8%BD%B4%E7%A3%81%E8%BE%93%E5%87%BA%E5%80%BC%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EZout_Mag_16_bit%20%3D%20(%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3Eshort%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E)%20(AccelMagData%5B4%5D%26lt%3B%26lt%3B8%20%7C%20AccelMagData%5B5%5D)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%E8%AE%A1%E7%AE%9716%E4%BD%8DZ%E8%BD%B4%E7%A3%81%E8%BE%93%E5%87%BA%E5%80%BC%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%233f7f5f%3B%20font-family%3A%20Consolas%3B%22%3E%2F%2F%20%E5%B0%86%E7%AC%AC%E4%B8%80%E4%B8%AA%E6%A0%B7%E6%9C%AC%E5%88%86%E9%85%8D%E7%BB%99%E6%9C%80%E5%A4%A7%E5%80%BC%E5%92%8C%E6%9C%80%E5%B0%8F%E5%80%BC%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3Eif%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%20(i%20%3D%3D%200)%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Xout_Mag_16_bit_max%20%3D%20Xout_Mag_16_bit%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Xout_Mag_16_bit_min%20%3D%20Xout_Mag_16_bit%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EYout_Mag_16_bit_max%20%3D%20Yout_Mag_16_bit%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EYout_Mag_16_bit_min%20%3D%20Yout_Mag_16_bit%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Zout_Mag_16_bit_max%20%3D%20Zout_Mag_16_bit%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Zout_Mag_16_bit_min%20%3D%20Zout_Mag_16_bit%3B%20%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20%E6%A3%80%E6%9F%A5%E5%BD%93%E5%89%8D%E6%A0%B7%E6%9C%AC%E6%98%AF%E5%90%A6%E6%98%AF%20X%20%E8%BD%B4%E7%9A%84%E6%9C%80%E5%A4%A7%E5%80%BC%E6%88%96%E6%9C%80%E5%B0%8F%E5%80%BC%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3Eif%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%20(Xout_Mag_16_bit%20%26gt%3B%20Xout_Mag_16_bit_max)%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7BXout_Mag_16_bit_max%20%3D%20Xout_Mag_16_bit%3B%7D%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3Eif%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%20(Xout_Mag_16_bit%20%26lt%3B%20Xout_Mag_16_bit_min)%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7BXout_Mag_16_bit_min%20%3D%20Xout_Mag_16_bit%3B%7D%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20%E6%A3%80%E6%9F%A5%E5%BD%93%E5%89%8D%E6%A0%B7%E6%9C%AC%E6%98%AF%E5%90%A6%E6%98%AF%20Y%20%E8%BD%B4%E7%9A%84%E6%9C%80%E5%A4%A7%E5%80%BC%E6%88%96%E6%9C%80%E5%B0%8F%E5%80%BC%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3E%E5%A6%82%E6%9E%9C%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%EF%BC%88Yout_Mag_16_bit%26gt%3BYout_Mag_16_bit_max%EF%BC%89%7BYout_Mag_16_bit_max%20%3D%20Yout_Mag_16_bit%3B%7D%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3E%E5%A6%82%E6%9E%9C%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E(Yout_Mag_16_bit%20%26lt%3B%20Yout_Mag_16_bit_min)%20%7BYout_Mag_16_bit_min%20%3D%20Yout_Mag_16_bit%3B%7D%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20%E6%A3%80%E6%9F%A5%E5%BD%93%E5%89%8D%E6%A0%B7%E6%9C%AC%E6%98%AF%E5%90%A6%E6%98%AF%E6%9C%80%E5%A4%A7%E6%88%96%E6%9C%80%E5%B0%8F%20Z%20%E8%BD%B4%E5%80%BC%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3Eif%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%20(Zout_Mag_16_bit%20%26gt%3B%20Zout_Mag_16_bit_max)%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7BZout_Mag_16_bit_max%20%3D%20Zout_Mag_16_bit%3B%7D%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3Eif%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%20(Zout_Mag_16_bit%20%26lt%3B%20Zout_Mag_16_bit_min)%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7BZout_Mag_16_bit_min%20%3D%20Zout_Mag_16_bit%3B%7D%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%E6%88%91%2B%2B%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%7D%20%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-family%3A%20Consolas%3B%20font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EXout_Mag_16_bit_avg%20%3D%20(Xout_Mag_16_bit_max%20%2B%20Xout_Mag_16_bit_min)%20%2F%202%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20X%E8%BD%B4%E7%A1%AC%E9%93%81%E5%81%8F%E7%A7%BB%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EYout_Mag_16_bit_avg%20%3D%20(Yout_Mag_16_bit_max%20%2B%20Yout_Mag_16_bit_min)%20%2F%202%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20Y%E8%BD%B4%E7%A1%AC%E9%93%81%E5%81%8F%E7%A7%BB%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EZout_Mag_16_bit_avg%20%3D%20(Zout_Mag_16_bit_max%20%2B%20Zout_Mag_16_bit_min)%20%2F%202%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20Z%E8%BD%B4%E7%A1%AC%E9%93%81%E5%81%8F%E7%A7%BB%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20%E5%B7%A6%E7%A7%BB%E4%B8%80%E4%BD%8D%EF%BC%8C%E5%9B%A0%E4%B8%BA%E7%A3%81%E5%8A%9B%E8%AE%A1%E5%81%8F%E7%A7%BB%E5%AF%84%E5%AD%98%E5%99%A8%E5%8F%AA%E6%9C%89%2015%20%E4%BD%8D%EF%BC%8C%E5%B7%A6%E5%AF%B9%E9%BD%90%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EXout_Mag_16_bit_avg%20%26lt%3B%26lt%3B%3D%201%3B%20%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EYout_Mag_16_bit_avg%20%26lt%3B%26lt%3B%3D%201%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EZout_Mag_16_bit_avg%20%26lt%3B%26lt%3B%3D%201%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EI2C_WriteRegister(FXOS8700CQ_I2C_ADDRESS%2C%20CTRL_REG1%2C%200x00)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%E5%BE%85%E6%9C%BA%E6%A8%A1%E5%BC%8F%EF%BC%8C%E5%85%81%E8%AE%B8%E5%86%99%E5%85%A5%E5%81%8F%E7%A7%BB%E5%AF%84%E5%AD%98%E5%99%A8%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EI2C_WriteRegister(FXOS8700CQ_I2C_ADDRESS%EF%BC%8CMOFF_X_LSB_REG%EF%BC%8C(%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3Echar%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E)(Xout_Mag_16_bit_avg%26amp%3B0xFF))%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EI2C_WriteRegister(FXOS8700CQ_I2C_ADDRESS%EF%BC%8CMOFF_X_MSB_REG%EF%BC%8C%EF%BC%88%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3E%E5%AD%97%E7%AC%A6%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%EF%BC%89%EF%BC%88%EF%BC%88Xout_Mag_16_bit_avg%20%26gt%3B%26gt%3B%20%3CLI-EMOJI%20id%3D%22lia_smiling-face-with-sunglasses%22%20title%3D%22%3Asmiling_face_with_sunglasses%3A%22%3E%3C%2FLI-EMOJI%3E%20%26amp%3B%200xFF))%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EI2C_WriteRegister%EF%BC%88FXOS8700CQ_I2C_ADDRESS%EF%BC%8CMOFF_Y_LSB_REG%EF%BC%8C%EF%BC%88%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3Echar%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%EF%BC%89%EF%BC%88Yout_Mag_16_bit_avg%EF%BC%860xFF%EF%BC%89%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EI2C_WriteRegister%EF%BC%88FXOS8700CQ_I2C_ADDRESS%EF%BC%8CMOFF_Y_MSB_REG%EF%BC%8C%EF%BC%88%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3Echar%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%EF%BC%89%EF%BC%88%EF%BC%88Yout_Mag_16_bit_avg%20%26gt%3B%26gt%3B%20%3CLI-EMOJI%20id%3D%22lia_smiling-face-with-sunglasses%22%20title%3D%22%3Asmiling_face_with_sunglasses%3A%22%3E%3C%2FLI-EMOJI%3E%20%26amp%3B%200xFF))%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EI2C_WriteRegister(FXOS8700CQ_I2C_ADDRESS%2C%20MOFF_Z_LSB_REG%2C%20(%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3Echar%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E)%20(Zout_Mag_16_bit_avg%20%26amp%3B%200xFF))%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EI2C_WriteRegister(FXOS8700CQ_I2C_ADDRESS%2C%20MOFF_Z_MSB_REG%2C%20(%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3Echar%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E)%20((Zout_Mag_16_bit_avg%20%26gt%3B%26gt%3B%20%3CLI-EMOJI%20id%3D%22lia_smiling-face-with-sunglasses%22%20title%3D%22%3Asmiling_face_with_sunglasses%3A%22%3E%3C%2FLI-EMOJI%3E%20%26amp%3B%200xFF))%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EI2C_WriteRegister(FXOS8700CQ_I2C_ADDRESS%2C%20CTRL_REG1%2C%200x35)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%E5%86%8D%E6%AC%A1%E8%BF%9B%E5%85%A5%E6%B4%BB%E5%8A%A8%E6%A8%A1%E5%BC%8F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20black%3B%20font-family%3A%20Consolas%3B%20font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E6.%E5%9C%A8ISR%E4%B8%AD%EF%BC%8C%E4%BB%85%E6%B8%85%E9%99%A4%E4%B8%AD%E6%96%AD%E6%A0%87%E5%BF%97%E5%B9%B6%E8%AE%BE%E7%BD%AEDataReady%E5%8F%98%E9%87%8F%E4%BB%A5%E6%8C%87%E7%A4%BA%E6%96%B0%E6%95%B0%E6%8D%AE%E7%9A%84%E5%88%B0%E8%BE%BE%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3Evoid%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%20%3CSTRONG%3EPORTD_IRQHandler%3C%2FSTRONG%3E()%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EPORTD_PCR4%20%7C%3D%20PORT_PCR_ISF_MASK%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%E6%B8%85%E9%99%A4%E4%B8%AD%E6%96%AD%E6%A0%87%E5%BF%97%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%E6%95%B0%E6%8D%AE%E5%B0%B1%E7%BB%AA%3D1%EF%BC%9B%20%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E7.%20%E5%8A%A0%E9%80%9F%E5%BA%A6%E8%AE%A1%E5%AF%84%E5%AD%98%E5%99%A8%200x01%20%E2%80%93%200x06%20%E7%9A%84%E8%BE%93%E5%87%BA%E5%80%BC%E9%A6%96%E5%85%88%E8%BD%AC%E6%8D%A2%E4%B8%BA%E6%9C%89%E7%AC%A6%E5%8F%B7%E7%9A%84%2014%20%E4%BD%8D%E6%95%B4%E6%95%B0%E5%80%BC%EF%BC%8C%E7%84%B6%E5%90%8E%E8%BD%AC%E6%8D%A2%E4%B8%BA%20g%20%E7%9A%84%E5%AE%9E%E5%80%BC%E3%80%82%E7%B1%BB%E4%BC%BC%E5%9C%B0%EF%BC%8C%E7%A3%81%E5%8A%9B%E8%AE%A1%E5%AF%84%E5%AD%98%E5%99%A8%200x33%20%E2%80%93%200x38%20%E7%9A%84%E8%BE%93%E5%87%BA%E5%80%BC%E9%A6%96%E5%85%88%E8%BD%AC%E6%8D%A2%E4%B8%BA%E6%9C%89%E7%AC%A6%E5%8F%B7%E7%9A%84%2016%20%E4%BD%8D%E6%95%B4%E6%95%B0%E5%80%BC%EF%BC%8C%E7%84%B6%E5%90%8E%E8%BD%AC%E6%8D%A2%E4%B8%BA%E5%BE%AE%E7%89%B9%E6%96%AF%E6%8B%89%20(%C2%B5T)%20%E7%9A%84%E5%AE%9E%E5%80%BC%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E6%9C%A8%E6%9D%BF%E4%BF%9D%E6%8C%81%E5%B9%B3%E5%9D%A6%EF%BC%8C%E5%88%99%E7%BD%97%E7%9B%98%E8%88%AA%E5%90%91%E5%8F%AF%E4%BB%A5%E7%AE%80%E5%8D%95%E5%9C%B0%E9%80%9A%E8%BF%87%E4%B8%A4%E4%B8%AA%E6%B0%B4%E5%B9%B3%E7%A3%81%E5%9C%BA%E5%88%86%E9%87%8F%E4%B9%8B%E6%AF%94%E7%9A%84%E5%8F%8D%E6%AD%A3%E5%88%87%E6%9D%A5%E8%AE%A1%E7%AE%97%E3%80%82%E6%88%91%E4%BD%BF%E7%94%A8%E4%BA%86%20atan2%20%E5%87%BD%E6%95%B0%EF%BC%8C%E5%AE%83%E4%BB%A5%E5%BC%A7%E5%BA%A6%EF%BC%88-%CF%80%20%E5%92%8C%20%CF%80%EF%BC%89%E8%BF%94%E5%9B%9E%E7%BB%93%E6%9E%9C%EF%BC%8C%E5%9B%A0%E6%AD%A4%E6%88%91%E5%B0%86%E5%85%B6%E4%B9%98%E4%BB%A5%20180%2F%CF%80%20%E5%BE%97%E5%88%B0%E5%BA%A6%E6%95%B0%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E5%AF%B9%E5%B8%A6%E6%9C%89%E8%BD%AF%E9%93%81%E6%A0%A1%E5%87%86%E7%9A%84%E5%80%BE%E6%96%9C%E8%A1%A5%E5%81%BF%E7%94%B5%E5%AD%90%E7%BD%97%E7%9B%98%E7%9A%84%E6%9B%B4%E5%A4%8D%E6%9D%82%E7%AE%97%E6%B3%95%E6%84%9F%E5%85%B4%E8%B6%A3%EF%BC%8C%E8%AF%B7%E5%8F%82%E9%98%85%E6%88%91%E4%BB%AC%E7%9A%84%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fwww.freescale.com%252Fwebapp%252Fsps%252Fsite%252Fprod_summary.jsp%253Fcode%253DE-Compass%22%20target%3D%22_blank%22%3E%E7%94%B5%E5%AD%90%E7%BD%97%E7%9B%98%E8%BD%AF%E4%BB%B6%3C%2FA%3E%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3Eif%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E(DataReady)%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20%E6%96%B0%E7%9A%84%E4%B8%80%E7%BB%84%E6%95%B0%E6%8D%AE%E6%98%AF%E5%90%A6%E5%87%86%E5%A4%87%E5%A5%BD%E4%BA%86%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%7B%20%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%E6%95%B0%E6%8D%AE%E5%B0%B1%E7%BB%AA%3D0%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EI2C_ReadMultiRegisters(FXOS8700CQ_I2C_ADDRESS%2C%20OUT_X_MSB_REG%2C%2012%2C%20AccelMagData)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%E8%AF%BB%E5%8F%96%E6%95%B0%E6%8D%AE%E8%BE%93%E5%87%BA%E5%AF%84%E5%AD%98%E5%99%A8%200x01-0x06%20%E5%92%8C%200x33%20-%200x38%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%2014-bit%20accelerometer%20data%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EXout_Accel_14_bit%20%3D%20((%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3Eshort%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E)%20(AccelMagData%5B0%5D%26lt%3B%26lt%3B8%20%7C%20AccelMagData%5B1%5D))%20%26gt%3B%26gt%3B%202%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%E8%AE%A1%E7%AE%9714%E4%BD%8DX%E8%BD%B4%E5%8A%A0%E9%80%9F%E5%BA%A6%E8%BE%93%E5%87%BA%E5%80%BC%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EYout_Accel_14_bit%20%3D%20((%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3Eshort%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E)%20(AccelMagData%5B2%5D%26lt%3B%26lt%3B8%20%7C%20AccelMagData%5B3%5D))%20%26gt%3B%26gt%3B%202%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20%E8%AE%A1%E7%AE%97%2014%20%E4%BD%8D%20Y%20%E8%BD%B4%E5%8A%A0%E9%80%9F%E5%BA%A6%E8%BE%93%E5%87%BA%E5%80%BC%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EZout_Accel_14_bit%20%3D%20((%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3Eshort%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E)%20(AccelMagData%5B4%5D%26lt%3B%26lt%3B8%20%7C%20AccelMagData%5B5%5D))%20%26gt%3B%26gt%3B%202%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%E8%AE%A1%E7%AE%9714%E4%BD%8DZ%E8%BD%B4%E5%8A%A0%E9%80%9F%E5%BA%A6%E8%BE%93%E5%87%BA%E5%80%BC%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20%E5%8A%A0%E9%80%9F%E5%BA%A6%E8%AE%A1%E6%95%B0%E6%8D%AE%E8%BD%AC%E6%8D%A2%E4%B8%BA%20g%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EXout_g%20%3D%20((%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3Efloat%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E)%20Xout_Accel_14_bit)%20%2F%20SENSITIVITY_2G%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20%E8%AE%A1%E7%AE%97%20X%20%E8%BD%B4%E8%BE%93%E5%87%BA%E5%80%BC%EF%BC%88%E5%8D%95%E4%BD%8D%E4%B8%BA%20g%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EYout_g%20%3D%20((%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3Efloat%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E)%20Yout_Accel_14_bit)%20%2F%20SENSITIVITY_2G%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20%E8%AE%A1%E7%AE%97%20Y%20%E8%BD%B4%E8%BE%93%E5%87%BA%E5%80%BC%EF%BC%88%E5%8D%95%E4%BD%8D%E4%B8%BA%20g%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EZout_g%20%3D%20((%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3Efloat%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E)%20Zout_Accel_14_bit)%20%2F%20SENSITIVITY_2G%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20%E8%AE%A1%E7%AE%97%20g%20%E4%B8%AD%E7%9A%84%20Z%20%E8%BD%B4%E8%BE%93%E5%87%BA%E5%80%BC%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%2016-bit%20magnetometer%20data%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EXout_Mag_16_bit%20%3D%20(%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3Eshort%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E)%20(AccelMagData%5B6%5D%26lt%3B%26lt%3B8%20%7C%20AccelMagData%5B7%5D)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%E8%AE%A1%E7%AE%9716%E4%BD%8DX%E8%BD%B4%E7%A3%81%E8%BE%93%E5%87%BA%E5%80%BC%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EYout_Mag_16_bit%20%3D%20(%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3Eshort%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E)%20(AccelMagData%5B8%5D%26lt%3B%26lt%3B8%20%7C%20AccelMagData%5B9%5D)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20%E8%AE%A1%E7%AE%97%2016%20%E4%BD%8D%20Y%20%E8%BD%B4%E7%A3%81%E8%BE%93%E5%87%BA%E5%80%BC%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EZout_Mag_16_bit%20%3D%20(%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3Eshort%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E)%20(AccelMagData%5B10%5D%26lt%3B%26lt%3B8%20%7C%20AccelMagData%5B11%5D)%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%E8%AE%A1%E7%AE%9716%E4%BD%8DZ%E8%BD%B4%E7%A3%81%E8%BE%93%E5%87%BA%E5%80%BC%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20%E7%A3%81%E5%8A%9B%E8%AE%A1%E6%95%B0%E6%8D%AE%E8%BD%AC%E6%8D%A2%E4%B8%BA%E5%BE%AE%E7%89%B9%E6%96%AF%E6%8B%89%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EXout_uT%20%3D%20(%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3Efloat%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E)%20(Xout_Mag_16_bit)%20%2F%20SENSITIVITY_MAG%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20%E8%AE%A1%E7%AE%97%20X%20%E8%BD%B4%E8%BE%93%E5%87%BA%E7%A3%81%E5%9C%BA%E5%80%BC%EF%BC%88%E5%8D%95%E4%BD%8D%E4%B8%BA%20uT%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EYout_uT%20%3D%20(%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3Efloat%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E)%20(Yout_Mag_16_bit)%20%2F%20SENSITIVITY_MAG%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20%E8%AE%A1%E7%AE%97%20Y%20%E8%BD%B4%E8%BE%93%E5%87%BA%E7%A3%81%E5%80%BC%EF%BC%88%E5%8D%95%E4%BD%8D%E4%B8%BA%20uT%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EZout_uT%20%3D%20(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%237f0055%3B%20font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%22%3E%3CSTRONG%3E%E6%B5%AE%E7%82%B9%E6%95%B0%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E)%20(Zout_Mag_16_bit)%20%2F%20SENSITIVITY_MAG%3B%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20%E8%AE%A1%E7%AE%97%20Z%20%E8%BD%B4%E8%BE%93%E5%87%BA%E7%A3%81%E5%80%BC%EF%BC%88%E4%BB%A5%20uT%20%E4%B8%BA%E5%8D%95%E4%BD%8D%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Heading%20%3D%20atan2%20(Yout_uT%2C%20Xout_uT)%20*%20180%20%2F%20PI%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20%233f7f5f%3B%22%3E%2F%2F%20Compute%20Yaw%20angle%20%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%7D%20%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%209pt%3B%20line-height%3A%201.5em%3B%20background-color%3A%20white%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E8.%20%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%9C%A8%E8%B0%83%E8%AF%95%E8%A7%86%E8%A7%92%E5%8F%B3%E4%B8%8A%E8%A7%92%E7%9A%84%E2%80%9C%E5%8F%98%E9%87%8F%E2%80%9D%E7%AA%97%E5%8F%A3%E6%88%96%20FreeMASTER%20%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E4%B8%AD%E6%9F%A5%E7%9C%8B%E8%AE%A1%E7%AE%97%E5%80%BC%E3%80%82%E8%A6%81%E6%89%93%E5%BC%80%E5%B9%B6%E8%BF%90%E8%A1%8C%20FreeMASTER%20%E9%A1%B9%E7%9B%AE%EF%BC%8C%E8%AF%B7%E5%AE%89%E8%A3%85%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fwww.freescale.com%252Fwebapp%252Fsps%252Fsite%252Fprod_summary.jsp%253Fcode%253DFREEMASTER%2526fpsp%253D1%2526tab%253DDesign_Tools_Tab%22%20target%3D%22_blank%22%3EFreeMASTER%201.4%20%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%3C%2FA%3E%E5%92%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fwww.freescale.com%252Fwebapp%252Fsps%252Fsite%252Fprod_summary.jsp%253Fcode%253DFREEMASTER%2526fpsp%253D1%2526tab%253DDesign_Tools_Tab%22%20target%3D%22_blank%22%3EFreeMASTER%20%E9%80%9A%E4%BF%A1%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FA%3E%E3%80%82%3C%2FP%3E%0A%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%2212191_12191.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2212191_12191.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117224i68EF8044FD2EE967%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2212191_12191.jpg%22%20alt%3D%2212191_12191.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E12191_12191.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%2212216_12216.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2212216_12216.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117225i09397BAD896E140C%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2212216_12216.jpg%22%20alt%3D%2212216_12216.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E12216_12216.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%22%3E%E9%99%84%E4%BB%B6%E4%B8%AD%E6%82%A8%E5%8F%AF%E4%BB%A5%E6%89%BE%E5%88%B0%E7%94%A8%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20color%3A%20%236a737b%3B%22%3E%3CA%20class%3D%22jive-link-external-small%22%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-family%3A%20inherit%3B%20color%3A%20%236a737b%3B%22%20href%3D%22http%3A%2F%2Fwww.freescale.com%2Fwebapp%2Fsps%2Fsite%2Fprod_summary.jsp%3Fcode%3DCW-MCU10%22%20data-content-finding%3D%22Community%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%20CW%20%E7%BC%96%E5%86%99%E7%9A%84%20MCU%20v10.5%3C%2FA%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-size%3A%2010pt%3B%22%3E%20%E7%9A%84%20%E5%AE%8C%E6%95%B4%E6%BA%90%E4%BB%A3%E7%A0%81%EF%BC%8C%20%E5%8C%85%E6%8B%AC%20FreeMASTER%20%E9%A1%B9%E7%9B%AE%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%22%3E%E5%A6%82%E6%9E%9C%E5%AF%B9%E8%BF%99%E4%B8%AA%E7%AE%80%E5%8D%95%E7%9A%84%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E6%9C%89%E4%BB%BB%E4%BD%95%E7%96%91%E9%97%AE%EF%BC%8C%E8%AF%B7%E9%9A%8F%E6%97%B6%E5%9C%A8%E4%B8%8B%E9%9D%A2%E6%8F%90%E9%97%AE%E3%80%82%E4%B9%9F%E6%AC%A2%E8%BF%8E%E6%82%A8%E6%8F%90%E4%BE%9B%E5%8F%8D%E9%A6%88%E6%88%96%E5%BB%BA%E8%AE%AE%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%22%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%233d3d3d%3B%22%3E%3CSPAN%20style%3D%22font-weight%3A%20inherit%3B%20font-style%3A%20inherit%3B%22%3ETomas%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%E5%8E%9F%E5%A7%8B%E9%99%84%E4%BB%B6%E5%B7%B2%E7%A7%BB%E8%87%B3%EF%BC%9A%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-339248%22%20target%3D%22_blank%22%3EFRDM-KL25Z-FXOS8700CQ-Basic-read-using-I2C-and-interrupt.zip%3C%2FA%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%E5%8E%9F%E5%A7%8B%E9%99%84%E4%BB%B6%E5%B7%B2%E7%A7%BB%E8%87%B3%EF%BC%9A%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-339248%22%20target%3D%22_blank%22%3EFreeMASTER---FRDM-KL25Z-FXOS8700CQ-Basic-read-using-I2C-and-interrupt.zip%3C%2FA%3E%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1103701%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E5%8A%A0%E9%80%9F%E5%BA%A6%E4%BC%A0%E6%84%9F%E5%99%A8%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3E%E7%A3%81%E5%8A%9B%E4%BC%A0%E6%84%9F%E5%99%A8%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103716%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFXOS8700CQ%20-%20%E8%A3%B8%E6%9C%BA%E7%A4%BA%E4%BE%8B%E9%A1%B9%E7%9B%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103716%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Tomas%2C%3C%2FP%3E%3CP%3E%E6%88%91%E5%AF%B9%E8%BF%99%E4%BA%9B%E8%AE%BE%E5%A4%87%E8%BF%98%E4%B8%8D%E7%86%9F%E6%82%89%EF%BC%8C%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E5%B0%86%E5%8A%A0%E9%80%9F%E5%BA%A6%E8%AE%A1%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3EFXOS8700CQ%20%E5%BA%94%E7%94%A8%E4%BA%8E%20FRDM-K66F%20%E5%BC%80%E5%8F%91%E6%9D%BF%E3%80%82%E6%88%91%E6%83%B3%E5%AD%A6%E4%B9%A0%E5%A6%82%E4%BD%95%3CSPAN%3E%E5%9C%A8%20FRDM-K66F%20%E4%B8%AD%E6%BF%80%E6%B4%BB%20FXOS8700CQ%20%E4%BC%A0%E6%84%9F%E5%99%A8%E3%80%82%E8%AF%B7%E9%97%AE%E5%9C%A8%E5%93%AA%E9%87%8C%E5%8F%AF%E4%BB%A5%E6%89%BE%E5%88%B0%E4%B8%80%E4%BA%9B%E5%AD%A6%E4%B9%A0%E8%B5%84%E6%96%99%EF%BC%8C%E6%AF%94%E5%A6%82%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%EF%BC%9F%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%3CSPAN%3E%E9%9F%93%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103715%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFXOS8700CQ%20-%20%E8%A3%B8%E6%9C%BA%E7%A4%BA%E4%BE%8B%E9%A1%B9%E7%9B%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103715%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Alexandre%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ESENSITIVITY_2G%20%E5%AF%B9%E5%BA%94%20fs%5B1%3A0%5D%20%3D%200b00%EF%BC%8CSENSITIVITY_4G%20%E5%AF%B9%E5%BA%94%20fs%5B1%3A0%5D%20%3D%200b01%EF%BC%8CSENSITIVITY_8G%20%E5%AF%B9%E5%BA%94%20fs%5B1%3A0%5D%20%3D%200b10%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%AF%B7%E6%B3%A8%E6%84%8F%EF%BC%8COFF_X%EF%BC%88YZ%EF%BC%89%E5%AF%84%E5%AD%98%E5%99%A8%E7%9A%84%E5%88%86%E8%BE%A8%E7%8E%87%E4%B8%BA%E6%AF%8F%20LSB%202mg%EF%BC%8C%E8%BF%99%E5%B0%B1%E6%98%AF%E6%88%91%E4%BD%BF%E7%94%A8%E6%95%B0%E5%AD%97%208%20%E8%A1%A8%E7%A4%BA%202g%20%E7%9A%84%E5%8E%9F%E5%9B%A0%E3%80%82%E5%AF%B9%E4%BA%8E%204g%EF%BC%8C%E8%AF%A5%E6%95%B0%E5%AD%97%E4%B8%BA%204%EF%BC%8C%E5%AF%B9%E4%BA%8E%208g%EF%BC%8C%E8%AF%A5%E6%95%B0%E5%AD%97%E4%B8%BA%202%E3%80%82%E6%9C%89%E5%85%B3%E6%9B%B4%E5%A4%9A%E4%BF%A1%E6%81%AF%EF%BC%8C%E8%AF%B7%E5%8F%82%E9%98%85%20AN4069%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3ETomas%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103714%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFXOS8700CQ%20-%20%E8%A3%B8%E6%9C%BA%E7%A4%BA%E4%BE%8B%E9%A1%B9%E7%9B%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103714%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9C%A8%202g%20%E7%81%B5%E6%95%8F%E5%BA%A6%E7%9A%84%E5%8A%A0%E9%80%9F%E5%BA%A6%E8%AE%A1%E6%A0%A1%E5%87%86%E4%B8%AD%E4%BD%BF%E7%94%A8%E4%BB%A5%E4%B8%8B%E6%96%B9%E7%A8%8B%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2013.3333px%3B%22%3EZ_Accel_offset%20%3D%20(Zout_Accel_14_bit%20-%20SENSITIVITY_2G)%20%2F%208%20*%20(-1)%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E7%9A%84%E9%97%AE%E9%A2%98%E6%98%AF%EF%BC%8C%E4%BB%80%E4%B9%88%E6%97%B6%E5%80%99%E5%BA%94%E8%AF%A5%E4%BD%BF%E7%94%A8%E7%81%B5%E6%95%8F%E5%BA%A6%204g%20%E5%92%8C%208g%EF%BC%9F%3CBR%20%2F%3E%E8%BF%98%E6%98%AF%E7%9B%B8%E5%90%8C%E7%9A%84%E7%AD%89%E5%BC%8F%E5%90%97%EF%BC%9F%E7%AD%89%E5%BC%8F%E7%AC%AC%E4%B8%80%E9%83%A8%E5%88%86%E9%99%A4%E4%BB%A5%208%20%E5%BE%97%E5%88%B0%E7%9A%84%E5%80%BC%E5%A7%8B%E7%BB%88%E6%98%AF%E8%BF%99%E4%B8%AA%E5%80%BC%EF%BC%8C%E6%97%A0%E8%AE%BA%E6%98%AF%202g%E3%80%814g%20%E8%BF%98%E6%98%AF%208g%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9C%A8%E6%88%91%E7%9A%84%E9%A1%B9%E7%9B%AE%E4%B8%AD%EF%BC%8C%E6%88%91%E9%9C%80%E8%A6%81%E6%94%B9%E5%8F%98%E7%81%B5%E6%95%8F%E5%BA%A6%EF%BC%8C%E5%B9%B6%E4%B8%94%E6%88%91%E6%83%B3%E6%A0%A1%E5%87%86%E8%BF%99%E4%B8%AA%E6%96%B0%E7%9A%84%E7%81%B5%E6%95%8F%E5%BA%A6%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%E9%97%AE%E5%80%99%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EAlexandre%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103713%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFXOS8700CQ%20-%20%E8%A3%B8%E6%9C%BA%E7%A4%BA%E4%BE%8B%E9%A1%B9%E7%9B%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103713%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Anil%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E7%9B%B8%E4%BF%A1%E5%AE%83%E5%BA%94%E8%AF%A5%E9%9D%9E%E5%B8%B8%E7%AE%80%E5%8D%95%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3EHeading%20%3D%20180%20%2B%20atan2%20(Yout_uT%2C%20Xout_uT)%20*%20180%20%2F%20PI%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3ETomas%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103712%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFXOS8700CQ%20-%20%E8%A3%B8%E6%9C%BA%E7%A4%BA%E4%BE%8B%E9%A1%B9%E7%9B%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103712%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Thomas%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%BD%AC%E6%8D%A2%E5%8E%9F%E5%A7%8B%E5%80%BC%E5%90%8E%EF%BC%8C%E8%88%AA%E5%90%91%E8%A7%92%E6%98%BE%E7%A4%BA%E5%9C%A8%20-180%20%E5%88%B0%20%2B180%20%E4%B9%8B%E9%97%B4%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%A6%82%E4%BD%95%E4%BB%8E%20-180%20%E5%88%B0%20%2B180%20%E8%BD%AC%E6%8D%A2%E4%B8%BA%200%20%E5%88%B0%20360%20%E8%A7%92%E5%BA%A6%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3EAnil%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103711%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFXOS8700CQ%20-%20%E8%A3%B8%E6%9C%BA%E7%A4%BA%E4%BE%8B%E9%A1%B9%E7%9B%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103711%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Anil%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%BF%99%E6%98%AF%E5%9C%A8%20FXOS8700CQ.h%20%E4%B8%AD%E5%AE%9A%E4%B9%89%E7%9A%84%E6%96%87%E4%BB%B6%EF%BC%88Project_Headers%2FFXOS8700CQ.h%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%2F%2FFXOS8700CQ%20%E7%81%B5%E6%95%8F%E5%BA%A6%3C%2FP%3E%3CP%3E%23%E5%AE%9A%E4%B9%89%20SENSITIVITY_2G%204096%3CBR%20%2F%3E%20%23%E5%AE%9A%E4%B9%89%20SENSITIVITY_4G%202048%3CBR%20%2F%3E%20%23%E5%AE%9A%E4%B9%89%20SENSITIVITY_8G%201024%3CBR%20%2F%3E%20%23%E5%AE%9A%E4%B9%89%20SENSITIVITY_MAG%2010%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3ETomas%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103710%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFXOS8700CQ%20-%20%E8%A3%B8%E6%9C%BA%E7%A4%BA%E4%BE%8B%E9%A1%B9%E7%9B%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103710%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CDIV%20class%3D%22%22%3E%3CP%3EHi%20Thomas%2C%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3ESENSITIVITY_MAG%3D%3F%3F%3F%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%E5%92%8C%20SENSITIVITY_2G%3D%3F%3F%3C%2FSPAN%3E%E7%9A%84%E5%80%BC%E6%98%AF%E5%A4%9A%E5%B0%91%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%E6%88%91%E5%8F%AA%E6%98%AF%E8%A1%A5%E5%85%85%E4%B8%80%E4%B8%8B%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%E7%81%B5%E6%95%8F%E5%BA%A6_2G%20%3D%3C%2FSPAN%3E%200.244%EF%BC%88%E6%AF%AB%E5%85%8B%EF%BC%89%3C%2FP%3E%3CP%3ESENSITIVITY_MAG%20%3D%200.1%20(uT)%3C%2FP%3E%3CP%3E%E5%9C%A8%E4%BB%A3%E7%A0%81%E4%B8%AD%E5%BA%94%E7%94%A8%E4%B8%8A%E8%BF%B0%E5%80%BC%E3%80%82%E5%AF%B9%E5%90%97%EF%BC%9F%E6%88%96%E4%BB%BB%E4%BD%95%E5%85%B6%E4%BB%96%E9%9C%80%E8%A6%81%E6%8C%87%E5%AE%9A%E7%9A%84%E5%80%BC%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3Eanil%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103709%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFXOS8700CQ%20-%20%E8%A3%B8%E6%9C%BA%E7%A4%BA%E4%BE%8B%E9%A1%B9%E7%9B%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103709%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%97%A8%EF%BC%8CTommy%EF%BC%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ESENSITIVITY_MAG%3D%3F%3F%3F%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%20font-family%3A%20Consolas%3B%20color%3A%20black%3B%22%3E%E5%92%8C%20SENSITIVITY_2G%3D%3F%3F%3C%2FSPAN%3E%E7%9A%84%E5%80%BC%E6%98%AF%E5%A4%9A%E5%B0%91%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3Eanil%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103708%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFXOS8700CQ%20-%20%E8%A3%B8%E6%9C%BA%E7%A4%BA%E4%BE%8B%E9%A1%B9%E7%9B%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103708%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Tomas%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%88%A9%E7%94%A8%E7%9C%9F%E5%AE%9E%E7%9A%84%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3Eg%20%E5%92%8C%20%C2%B5T%20%E6%95%B0%E6%8D%AE%EF%BC%8C%E6%98%AF%E5%90%A6%E6%9C%89%E7%AE%97%E6%B3%95%E5%8F%AF%E4%BB%A5%E8%AE%A1%E7%AE%97%E7%9C%9F%E5%AE%9E%E4%BD%8D%E7%BD%AE%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E6%B1%A4%E7%B1%B3%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103707%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFXOS8700CQ%20-%20%E8%A3%B8%E6%9C%BA%E7%A4%BA%E4%BE%8B%E9%A1%B9%E7%9B%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103707%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E7%A9%86%E6%96%AF%E5%A1%94%E6%B3%95%EF%BC%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%9C%8B%E7%9C%8B%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-104587%22%20target%3D%22_blank%22%3E%E8%BF%99%E4%B8%AA%3C%2FA%3E%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%E6%88%96%3CA%20href%3D%22http%3A%2F%2Fblogs.freescale.com%2Fsensors%2F2015%2F04%2Fcreating-a-data-logger-embedded-application-using-the-intelligent-sensing-framework-isf-2-1%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E8%BF%99%E7%AF%87%3C%2FA%3E%E6%96%87%E7%AB%A0%E3%80%82%E5%B8%8C%E6%9C%9B%E6%9C%89%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3ETomas%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103706%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFXOS8700CQ%20-%20%E8%A3%B8%E6%9C%BA%E7%A4%BA%E4%BE%8B%E9%A1%B9%E7%9B%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103706%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20David%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BD%A0%E6%9C%89%E5%8F%AF%E8%83%BD%E8%AE%A9%E5%AE%83%E5%8F%91%E6%8C%A5%E4%BD%9C%E7%94%A8%E5%90%97%EF%BC%9F%3CBR%20%2F%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E5%81%9A%E4%B8%80%E4%B8%AA%E7%A0%94%E7%A9%B6%E7%94%9F%E9%A1%B9%E7%9B%AE%EF%BC%8C%E9%9C%80%E8%A6%81%E5%90%8C%E6%A0%B7%E7%9A%84%20K64f%20%E6%9D%BF%E6%9D%A5%E5%B7%A5%E4%BD%9C%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%20%3CIMG%20id%3D%22smileyhappy%22%20class%3D%22emoticon%20emoticon-smileyhappy%22%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fi%2Fsmilies%2F16x16_smiley-happy.png%22%20alt%3D%22Smiley%20Happy%22%20title%3D%22Smiley%20Happy%22%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CP%3E%3C%2FP%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103705%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFXOS8700CQ%20-%20%E8%A3%B8%E6%9C%BA%E7%A4%BA%E4%BE%8B%E9%A1%B9%E7%9B%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103705%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Luke%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%AF%B7%E5%8F%82%E9%98%85%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fmessage%2F520588%22%20target%3D%22_blank%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%BB%85%E8%AE%BE%E7%BD%AE%20FXOS8700CQ%20%E7%A3%81%E5%8A%9B%E8%AE%A1%E4%BE%A7%EF%BC%9F%3C%2FA%3E%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3ETomas%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103704%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFXOS8700CQ%20-%20%E8%A3%B8%E6%9C%BA%E7%A4%BA%E4%BE%8B%E9%A1%B9%E7%9B%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103704%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%AF%B9%E8%BF%99%E4%BA%9B%E8%AE%BE%E5%A4%87%E8%BF%98%E4%B8%8D%E7%86%9F%E6%82%89%E3%80%82%E6%88%91%E8%A2%AB%E8%B5%8B%E4%BA%88%E5%9C%A8%E6%88%91%E4%BB%AC%E7%9A%84%E4%B8%80%E4%B8%AA%E9%A1%B9%E7%9B%AE%E4%B8%AD%E8%AE%BE%E7%BD%AE%20FXOS8700CQ%20%E7%9A%84%E4%BB%BB%E5%8A%A1%E3%80%82%E6%88%91%E5%8F%AA%E6%89%93%E7%AE%97%E4%BD%BF%E7%94%A8%E8%AF%A5%E8%AE%BE%E5%A4%87%E7%9A%84%E7%A3%81%E5%8A%9B%E8%AE%A1%E4%BE%A7%E3%80%82%E6%88%91%E6%83%B3%E5%9C%A8%E6%95%B0%E6%8D%AE%E5%8F%AF%E7%94%A8%E6%97%B6%E4%BD%BF%E7%94%A8%E4%B8%AD%E6%96%AD%E6%9D%A5%E6%9B%B4%E6%96%B0%E5%87%BD%E6%95%B0%EF%BC%8C%E4%BB%A5%E4%BE%BF%E5%AE%83%E5%8F%AF%E4%BB%A5%E8%8E%B7%E5%8F%96%E4%B8%80%E4%BA%9B%E6%95%B0%E6%8D%AE%E3%80%82%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%88%91%E4%BB%85%E4%BD%BF%E7%94%A8%E7%A3%81%E5%8A%9B%E8%AE%A1%E7%AB%AF%EF%BC%8C%E6%88%91%E9%9C%80%E8%A6%81%E9%85%8D%E7%BD%AE%E5%93%AA%E4%BA%9B%E5%AF%84%E5%AD%98%E5%99%A8%E3%80%82%E5%A6%82%E4%BD%95%E6%A0%A1%E5%87%86%E7%A3%81%E5%8A%9B%E4%BB%AA%E5%B9%B6%E8%AF%BB%E5%8F%96%E7%A3%81%E5%8A%9B%E4%BB%AA%E7%9A%84%E4%B8%80%E8%88%AC%E6%95%B0%E6%8D%AE%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3E%E8%B7%AF%E5%8A%A0%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103703%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFXOS8700CQ%20-%20%E8%A3%B8%E6%9C%BA%E7%A4%BA%E4%BE%8B%E9%A1%B9%E7%9B%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103703%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20David%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3E%3CSPAN%3E%E8%AF%B7%E5%B0%9D%E8%AF%95%E8%81%94%E7%B3%BB%20Mike%20Stanley%20(%3C%2FSPAN%3E%20%3CA%20class%3D%22jive-link-email-small%22%20href%3D%22mailto%3AMike.Stanley%40freescale.com%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EMike.Stanley%40freescale.com%3C%2FA%3E%20%3CSPAN%3E)%EF%BC%8C%E4%BB%96%E5%92%8C%E4%BB%96%E7%9A%84%E5%9B%A2%E9%98%9F%E4%B8%80%E7%9B%B4%E8%87%B4%E5%8A%9B%E4%BA%8E%3C%2FSPAN%3E%E5%9F%BA%E4%BA%8E%20MQX%20Lite%20RTOS%20%E7%9A%84%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fcommunity%2Fthe-embedded-beat%2Fblog%2F2014%2F05%2F30%2Ffreescalecomsensorfusion%22%20target%3D%22_blank%22%3EKinetis%20MCU%20%E7%9A%84%20Xtrinsic%20%E4%BC%A0%E6%84%9F%E5%99%A8%E8%9E%8D%E5%90%88%E5%BA%93%EF%BC%8C%3C%2FA%3E%E5%B9%B6%E4%B8%94%E4%BB%96%E4%BB%AC%E6%9C%80%E8%BF%91%E5%A2%9E%E5%8A%A0%E4%BA%86%E5%AF%B9%20FRDM-K64F%20%E6%9D%BF%E7%9A%84%E6%94%AF%E6%8C%81%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%209.0pt%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%20color%3A%20black%3B%20background%3A%20white%3B%22%3ETomas%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1103702%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AFXOS8700CQ%20-%20%E8%A3%B8%E6%9C%BA%E7%A4%BA%E4%BE%8B%E9%A1%B9%E7%9B%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103702%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Tomas%2C%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E5%8F%91%E5%B8%83%E8%BF%99%E4%B8%AA%E9%A1%B9%E7%9B%AE%EF%BC%81%E6%88%91%E6%83%B3%E4%BD%BF%E7%94%A8%20FRDM%20K64F%20%E6%9D%BF%E4%B8%8A%E7%9A%84%20FXOS8700CQ%20%E5%92%8C%20MQX%20%E5%88%B6%E4%BD%9C%E4%B8%80%E4%B8%AA%E7%B1%BB%E4%BC%BC%E7%9A%84%E9%A1%B9%E7%9B%AE%E3%80%82%E4%BD%A0%E7%9F%A5%E9%81%93%E6%98%AF%E5%90%A6%E6%9C%89%E4%BA%BA%E8%BF%99%E6%A0%B7%E5%81%9A%E8%BF%87%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%8C%3CBR%20%2F%3E%E5%A4%A7%E5%8D%AB%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎02-03-2026 05:18 PM
更新人:
