What is "Secure Box version"?
djdirkj
The GetVersion-APDU in AN12413 specification defines "VersionInfo" with a 2-byte "Secure Box version". There is no definition as to what is exactly is.
Why do I need this information?
I'm in the middle of a certification of a product with a notified body. This product uses a SE050 for certain security features and this is part of the certification since the SE050 also contains a form of firmware.
Kan_Li
Hi @djdirkj ,
Yes, all these parameters are static on SE050A.
Kan
Kan_Li
Hi @djdirkj ,
Please record the Secure Box version as part of the SE050 software/configuration evidence, but do not try to interpret it independently unless NXP provides a controlled definition; for certification, the full GetVersion / se05x_GetInfo output is the stronger traceability artifact.
Kan
djdirkj
Hi @Kan_Li ,
thank you for your response!
Let me rephrase the question:
I have a reel of about 500 SE050A2 components at our EMS. If I produce 500 products with these SE050, how can I be sure that every SE050 is exactly the same?
If there is a difference in the SE050 it does not adhere to the certificate and it needs amendments to the certificate. I hope you understand that this is not desirable.
Kan_Li
Hi @djdirkj ,
Please do not try to prove that all SE050A2 chips are literally identical; prove that they have the same OEF ID, platform build ID, OS patch level, applet version, and feature configuration, while recording unique serial/batch data for traceability.
Kan
djdirkj
Hi @Kan_Li ,
thank you for your timely reply, I appreciate it.
Can you confirm that every SE050A2 has the same:
OEF ID, platform build ID, OS patch level, applet version, and feature configuration.
And if we order a new batch, this does not change.
This is all I need to know regarding this topic.
Kind regards,
Dirk Jan
Kan_Li
Hi @djdirkj ,
Kan
%3CLINGO-SUB%20id%3D%22lingo-sub-2399237%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EWhat%20is%20%22Secure%20Box%20version%22%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2399237%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThe%20GetVersion-APDU%20in%20AN12413%20specification%20defines%20%22VersionInfo%22%20with%20a%202-byte%20%22Secure%20Box%20version%22.%20There%20is%20no%20definition%20as%20to%20what%20is%20exactly%20is.%3C%2FP%3E%3CP%3EWhy%20do%20I%20need%20this%20information%3F%3C%2FP%3E%3CP%3EI'm%20in%20the%20middle%20of%20a%20certification%20of%20a%20product%20with%20a%20notified%20body.%20This%20product%20uses%20a%20SE050%20for%20certain%20security%20features%20and%20this%20is%20part%20of%20the%20certification%20since%20the%20SE050%20also%20contains%20a%20form%20of%20firmware.%26nbsp%3B%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2399237%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3ESE050%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2399486%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%20translate%3D%22no%22%3ERe%3A%20What%20is%20%22Secure%20Box%20version%22%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2399486%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F59276%22%20target%3D%22_blank%22%3E%40Kan_Li%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%3CBR%20%2F%3E%3CP%3Ethank%20you%20for%20your%20timely%20reply%2C%20I%20appreciate%20it.%3C%2FP%3E%3CP%3ECan%20you%20confirm%20that%20every%20SE050A2%20has%20the%20same%3A%3C%2FP%3E%3CP%3E%3CSPAN%3EOEF%20ID%2C%20platform%20build%20ID%2C%20OS%20patch%20level%2C%20applet%20version%2C%20and%20feature%20configuration.%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3EAnd%20if%20we%20order%20a%20new%20batch%2C%20this%20does%20not%20change.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EThis%20is%20all%20I%20need%20to%20know%20regarding%20this%20topic.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EKind%20regards%2C%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EDirk%20Jan%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2399485%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20What%20is%20%22Secure%20Box%20version%22%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2399485%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F218188%22%20target%3D%22_blank%22%3E%40djdirkj%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EPlease%26nbsp%3B%3CSPAN%3Edo%20not%20try%20to%20prove%20that%20all%20SE050A2%20chips%20are%20literally%20identical%3B%20prove%20that%20they%20have%20the%20same%20OEF%20ID%2C%20platform%20build%20ID%2C%20OS%20patch%20level%2C%20applet%20version%2C%20and%20feature%20configuration%2C%20while%20recording%20unique%20serial%2Fbatch%20data%20for%20traceability.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EHave%20a%20great%20day%2C%3CBR%20%2F%3EKan%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3ENote%3A%3CBR%20%2F%3E-%20If%20this%20post%20answers%20your%20question%2C%20please%20click%20the%20%22Mark%20Correct%22%20button.%20Thank%20you!%3CBR%20%2F%3E-%20We%20are%20following%20threads%20for%207%20weeks%20after%20the%20last%20post%2C%20later%20replies%20are%20ignored%3CBR%20%2F%3EPlease%20open%20a%20new%20thread%20and%20refer%20to%20the%20closed%20one%2C%20if%20you%20have%20a%20related%20question%20at%20a%20later%20point%20in%20time.%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2399456%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20What%20is%20%22Secure%20Box%20version%22%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2399456%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F59276%22%20target%3D%22_blank%22%3E%40Kan_Li%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%3CBR%20%2F%3E%3CP%3Ethank%20you%20for%20your%20response!%3C%2FP%3E%3CP%3ELet%20me%20rephrase%20the%20question%3A%3C%2FP%3E%3CP%3EI%20have%20a%20reel%20of%20about%20500%20SE050A2%20components%20at%20our%20EMS.%20If%20I%20produce%20500%20products%20with%20these%20SE050%2C%20how%20can%20I%20be%20sure%20that%20every%20SE050%20is%20exactly%20the%20same%3F%3C%2FP%3E%3CP%3EIf%20there%20is%20a%20difference%20in%20the%20SE050%20it%20does%20not%20adhere%20to%20the%20certificate%20and%20it%20needs%20amendments%20to%20the%20certificate.%20I%20hope%20you%20understand%20that%20this%20is%20not%20desirable.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2399362%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20What%20is%20%22Secure%20Box%20version%22%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2399362%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F218188%22%20target%3D%22_blank%22%3E%40djdirkj%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3EPlease%20record%20the%20Secure%20Box%20version%20as%20part%20of%20the%20SE050%20software%2Fconfiguration%20evidence%2C%20but%20do%20not%20try%20to%20interpret%20it%20independently%20unless%20NXP%20provides%20a%20controlled%20definition%3B%20for%20certification%2C%20the%20full%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CCODE%20class%3D%22%22%3EGetVersion%3C%2FCODE%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E%2F%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CCODE%20class%3D%22%22%3Ese05x_GetInfo%3C%2FCODE%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3Eoutput%20is%20the%20stronger%20traceability%20artifact.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EHave%20a%20great%20day%2C%3CBR%20%2F%3EKan%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3ENote%3A%3CBR%20%2F%3E-%20If%20this%20post%20answers%20your%20question%2C%20please%20click%20the%20%22Mark%20Correct%22%20button.%20Thank%20you!%3CBR%20%2F%3E-%20We%20are%20following%20threads%20for%207%20weeks%20after%20the%20last%20post%2C%20later%20replies%20are%20ignored%3CBR%20%2F%3EPlease%20open%20a%20new%20thread%20and%20refer%20to%20the%20closed%20one%2C%20if%20you%20have%20a%20related%20question%20at%20a%20later%20point%20in%20time.%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2399777%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20What%20is%20%22Secure%20Box%20version%22%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2399777%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F218188%22%20target%3D%22_blank%22%3E%40djdirkj%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20data-teams%3D%22true%22%3E%20Yes%2C%20all%20these%20parameters%20are%20static%20on%20SE050A.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EHave%20a%20great%20day%2C%3CBR%20%2F%3EKan%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3ENote%3A%3CBR%20%2F%3E-%20If%20this%20post%20answers%20your%20question%2C%20please%20click%20the%20%22Mark%20Correct%22%20button.%20Thank%20you!%3CBR%20%2F%3E-%20We%20are%20following%20threads%20for%207%20weeks%20after%20the%20last%20post%2C%20later%20replies%20are%20ignored%3CBR%20%2F%3EPlease%20open%20a%20new%20thread%20and%20refer%20to%20the%20closed%20one%2C%20if%20you%20have%20a%20related%20question%20at%20a%20later%20point%20in%20time.%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E
