Setting AES-GCM Authentication Tag Length to 12 Bytes for DLMS with SE050E2
已解决
跳至解决方案
5,966 次查看
Faizy98
I am currently using the SE050E2 secure element for AES-GCM encryption and decryption operations. The encryption and decryption APIs work well, specifically the following function:
sss_status_t sss_aead_one_go( sss_aead_t *context, const uint8_t *srcData, uint8_t *destData, size_t size, uint8_t *nonce, size_t nonceLen, const uint8_t *aad, size_t aadLen, uint8_t *tag, size_t *tagLen);
This API functions perfectly when the authentication tag length is 16 bytes. However, I am working with DLMS protocol payloads that require the authentication tag to be only 12 bytes in length.
When I use this API to encrypt DLMS plain data, it generates an authentication tag of 16 bytes, but the DLMS standard expects a 12-byte tag. Similarly, for decryption, when the encrypted DLMS payload arrives with a 12-byte authentication tag, passing this 12-byte tag to the API results in a decryption failure, because the API expects the tag to be 16 bytes.
My question is:
Is there any way to configure or set the authentication tag length in the SE050E2 or its middleware so it can use a 12-byte tag as required by the DLMS standard?
Currently, the API always returns a 16-byte tag after encryption, and requires a 16-byte tag for decryption. I want to ensure compatibility with DLMS devices that use 12-byte tags without causing decryption errors.
Any guidance on configuring AES-GCM tag length for SE050E2, or recommended approaches for handling this DLMS tag size mismatch, would be highly appreciated.
Thanks in advance!
BR,
Faizy
1 解答
5,908 次查看
Kan_Li
Hi @Faizy98 ,
This is defined when you create the key for AEAD operation. please kindly refer to the following for details.
Kan
在原帖中查看解决方案
2 回复数
5,909 次查看
Kan_Li
Hi @Faizy98 ,
Kan
5,889 次查看
Faizy98
Thank you for your support.
BR,
Faizy
%3CLINGO-SUB%20id%3D%22lingo-sub-2150265%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%B0%86%E9%87%87%E7%94%A8%20SE050E2%20%E7%9A%84%20DLM%20%E7%9A%84%20AES-GCM%20%E8%BA%AB%E4%BB%BD%E9%AA%8C%E8%AF%81%E6%A0%87%E7%AD%BE%E9%95%BF%E5%BA%A6%E8%AE%BE%E7%BD%AE%E4%B8%BA%2012%20%E5%AD%97%E8%8A%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2150265%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20class%3D%22%22%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%20class%3D%22%22%3E%E6%88%91%E7%9B%AE%E5%89%8D%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20SE050E2%20%E5%AE%89%E5%85%A8%E5%85%83%E4%BB%B6%E8%BF%9B%E8%A1%8C%20AES-GCM%20%E5%8A%A0%E5%AF%86%E5%92%8C%E8%A7%A3%E5%AF%86%E6%93%8D%E4%BD%9C%E3%80%82%E5%8A%A0%E5%AF%86%E5%92%8C%E8%A7%A3%E5%AF%86%20API%20%E8%BF%90%E8%A1%8C%E8%89%AF%E5%A5%BD%EF%BC%8C%E7%89%B9%E5%88%AB%E6%98%AF%E4%BB%A5%E4%B8%8B%E5%8A%9F%E8%83%BD%EF%BC%9A%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3E%3CSTRONG%3Esss_status_t%20sss_aead_one_go(%20sss_aead_t%20*context%EF%BC%8Cconst%20uint8_t*srcData%EF%BC%8Cuint8_t%20*destData%EF%BC%8Csize_t%20size%EF%BC%8Cuint8_t%20*nonce%EF%BC%8Csize_t%20nonceLen%EF%BC%8Cconst%20uint8_t%20*aad%EF%BC%8Csize_t%20aadLen%EF%BC%8Cuint8_t%20*tag%EF%BC%8Csize_t%20*tagLen)%EF%BC%9B%3CBR%20%2F%3E%3C%2FSTRONG%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3E%E5%BD%93%E8%BA%AB%E4%BB%BD%E9%AA%8C%E8%AF%81%E6%A0%87%E7%AD%BE%E9%95%BF%E5%BA%A6%E4%B8%BA%2016%20%E5%AD%97%E8%8A%82%E6%97%B6%EF%BC%8C%E6%AD%A4%20API%20%E5%8F%AF%E4%BB%A5%E5%AE%8C%E7%BE%8E%E8%BF%90%E8%A1%8C%E3%80%82%E4%BD%86%E6%98%AF%EF%BC%8C%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%E8%A6%81%E6%B1%82%E8%BA%AB%E4%BB%BD%E9%AA%8C%E8%AF%81%E6%A0%87%E7%AD%BE%E9%95%BF%E5%BA%A6%E4%BB%85%E4%B8%BA%2012%20%E5%AD%97%E8%8A%82%E7%9A%84%20DLMS%20%E5%8D%8F%E8%AE%AE%E6%9C%89%E6%95%88%E8%B4%9F%E8%BD%BD%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CP%20class%3D%22%22%3E%E5%BD%93%E6%88%91%E4%BD%BF%E7%94%A8%E8%BF%99%E4%B8%AA%20API%20%E5%8A%A0%E5%AF%86%20DLMS%20%E7%BA%AF%E6%95%B0%E6%8D%AE%E6%97%B6%EF%BC%8C%E5%AE%83%E4%BC%9A%E7%94%9F%E6%88%90%2016%20%E5%AD%97%E8%8A%82%E7%9A%84%E8%BA%AB%E4%BB%BD%E9%AA%8C%E8%AF%81%E6%A0%87%E7%AD%BE%EF%BC%8C%E4%BD%86%E6%98%AF%20DLMS%20%E6%A0%87%E5%87%86%E9%9C%80%E8%A6%81%E4%B8%80%E4%B8%AA%2012%20%E5%AD%97%E8%8A%82%E7%9A%84%E6%A0%87%E7%AD%BE%E3%80%82%E5%90%8C%E6%A0%B7%EF%BC%8C%E5%AF%B9%E4%BA%8E%E8%A7%A3%E5%AF%86%E8%80%8C%E8%A8%80%EF%BC%8C%E5%BD%93%E5%8A%A0%E5%AF%86%E7%9A%84%20DLMS%20%E8%B4%9F%E8%BD%BD%E5%B8%A6%E6%9C%89%2012%20%E5%AD%97%E8%8A%82%E7%9A%84%E8%BA%AB%E4%BB%BD%E9%AA%8C%E8%AF%81%E6%A0%87%E7%AD%BE%E5%88%B0%E8%BE%BE%E6%97%B6%EF%BC%8C%E5%B0%86%E8%BF%99%E4%B8%AA%2012%20%E5%AD%97%E8%8A%82%E7%9A%84%E6%A0%87%E7%AD%BE%E4%BC%A0%E9%80%92%E7%BB%99%20API%20%E4%BC%9A%E5%AF%BC%E8%87%B4%E8%A7%A3%E5%AF%86%E5%A4%B1%E8%B4%A5%EF%BC%8C%E5%9B%A0%E4%B8%BA%20API%20%E9%A2%84%E8%AE%A1%E8%AF%A5%E6%A0%87%E7%AD%BE%E4%B8%BA%2016%20%E5%AD%97%E8%8A%82%E3%80%82%3C%2FP%3E%3CP%20class%3D%22%22%3E%E6%88%91%E7%9A%84%E9%97%AE%E9%A2%98%E6%98%AF%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSTRONG%3E%E6%9C%89%E6%B2%A1%E6%9C%89%E5%8A%9E%E6%B3%95%E5%9C%A8%20SE050E2%20%E6%88%96%E5%85%B6%E4%B8%AD%E9%97%B4%E4%BB%B6%E4%B8%AD%E9%85%8D%E7%BD%AE%E6%88%96%E8%AE%BE%E7%BD%AE%E8%BA%AB%E4%BB%BD%E9%AA%8C%E8%AF%81%E6%A0%87%E7%AD%BE%E9%95%BF%E5%BA%A6%EF%BC%8C%E4%BB%A5%E4%BE%BF%E5%AE%83%E5%8F%AF%E4%BB%A5%E6%8C%89%E7%85%A7%20DLMS%20%E6%A0%87%E5%87%86%E7%9A%84%E8%A6%81%E6%B1%82%E4%BD%BF%E7%94%A8%2012%20%E5%AD%97%E8%8A%82%E7%9A%84%E6%A0%87%E7%AD%BE%EF%BC%9F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%E5%BD%93%E5%89%8D%EF%BC%8CAPI%20%E5%9C%A8%E5%8A%A0%E5%AF%86%E5%90%8E%E5%A7%8B%E7%BB%88%E8%BF%94%E5%9B%9E%2016%20%E5%AD%97%E8%8A%82%E7%9A%84%E6%A0%87%E7%AD%BE%EF%BC%8C%E5%B9%B6%E4%B8%94%E9%9C%80%E8%A6%81%2016%20%E5%AD%97%E8%8A%82%E7%9A%84%E6%A0%87%E7%AD%BE%E6%89%8D%E8%83%BD%E8%A7%A3%E5%AF%86%E3%80%82%E6%88%91%E6%83%B3%E7%A1%AE%E4%BF%9D%E4%B8%8E%E4%BD%BF%E7%94%A8%2012%20%E5%AD%97%E8%8A%82%E6%A0%87%E7%AD%BE%E7%9A%84%20DLMS%20%E8%AE%BE%E5%A4%87%E5%85%BC%E5%AE%B9%EF%BC%8C%E8%80%8C%E4%B8%8D%E4%BC%9A%E5%AF%BC%E8%87%B4%E8%A7%A3%E5%AF%86%E9%94%99%E8%AF%AF%E3%80%82%3C%2FP%3E%3CP%20class%3D%22%22%3E%E5%A6%82%E8%83%BD%E5%B0%B1%20SE050E2%20%E7%9A%84%20AES-GCM%20%E6%A0%87%E7%AD%BE%E9%95%BF%E5%BA%A6%E9%85%8D%E7%BD%AE%E6%8F%90%E4%BE%9B%E6%8C%87%E5%AF%BC%EF%BC%8C%E6%88%96%E5%B0%B1%E5%A4%84%E7%90%86%20DLMS%20%E6%A0%87%E7%AD%BE%E5%A4%A7%E5%B0%8F%E4%B8%8D%E5%8C%B9%E9%85%8D%E7%9A%84%E5%BB%BA%E8%AE%AE%E6%96%B9%E6%B3%95%E6%8F%90%E4%BE%9B%E6%8C%87%E5%AF%BC%EF%BC%8C%E6%88%91%E4%BB%AC%E5%B0%86%E4%B8%8D%E8%83%9C%E6%84%9F%E6%BF%80%E3%80%82%3C%2FP%3E%3CP%20class%3D%22%22%3E%E5%85%88%E8%A1%8C%E6%84%9F%E8%B0%A2%EF%BC%81%3CBR%20%2F%3E%3CBR%20%2F%3EBR%2C%3CBR%20%2F%3EFaizy%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2152408%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Setting%20AES-GCM%20Authentication%20Tag%20Length%20to%2012%20Bytes%20for%20DLMS%20with%20SE050E2%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2152408%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E6%94%AF%E6%8C%81%E3%80%82%3C%2FP%3E%3CP%3EBR%E3%80%81%3C%2FP%3E%3CP%3EFaizy%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2152249%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Setting%20AES-GCM%20Authentication%20Tag%20Length%20to%2012%20Bytes%20for%20DLMS%20with%20SE050E2%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2152249%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F253702%22%20target%3D%22_blank%22%3E%40Faizy98%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E8%BF%99%E6%98%AF%E5%9C%A8%E5%88%9B%E5%BB%BA%20AEAD%20%E6%93%8D%E4%BD%9C%E5%AF%86%E9%92%A5%E6%97%B6%E5%AE%9A%E4%B9%89%E7%9A%84%E3%80%82%E8%AF%A6%E6%83%85%E8%AF%B7%E5%8F%82%E9%98%85%E4%B8%8B%E6%96%87%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Kan_Li_1-1755162576795.png%22%20style%3D%22width%3A%20569px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_1-1755162576795.png%22%20style%3D%22width%3A%20569px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F352423iF3080388BF9D9892%2Fimage-dimensions%2F569x498%3Fv%3Dv2%22%20width%3D%22569%22%20height%3D%22498%22%20role%3D%22button%22%20title%3D%22Kan_Li_1-1755162576795.png%22%20alt%3D%22Kan_Li_1-1755162576795.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E7%A5%9D%E6%82%A8%E6%84%89%E5%BF%AB%EF%BC%8C%3CBR%20%2F%3EKan%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%EF%BC%9A%3CBR%20%2F%3E-%20%E5%A6%82%E6%9E%9C%E6%9C%AC%E5%B8%96%E5%9B%9E%E7%AD%94%E4%BA%86%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E7%82%B9%E5%87%BB%22%E6%A0%87%E8%AE%B0%E6%AD%A3%E7%A1%AE%22%20%E6%8C%89%E9%92%AE%E3%80%82%E8%B0%A2%E8%B0%A2%EF%BC%81%3CBR%20%2F%3E-%20%E6%88%91%E4%BB%AC%E4%BC%9A%E5%9C%A8%E6%9C%80%E5%90%8E%E4%B8%80%E6%AC%A1%E5%8F%91%E5%B8%96%E5%90%8E%E7%9A%84%207%20%E5%91%A8%E5%86%85%E8%B7%9F%E8%B8%AA%E4%B8%BB%E9%A2%98%EF%BC%8C%E4%B9%8B%E5%90%8E%E7%9A%84%E5%9B%9E%E5%A4%8D%E5%B0%86%E8%A2%AB%E5%BF%BD%E7%95%A5%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E4%BB%A5%E5%90%8E%E6%9C%89%E7%9B%B8%E5%85%B3%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E5%8F%A6%E5%BC%80%E6%96%B0%E4%B8%BB%E9%A2%98%EF%BC%8C%E5%B9%B6%E5%8F%82%E8%80%83%E5%B7%B2%E5%85%B3%E9%97%AD%E7%9A%84%E4%B8%BB%E9%A2%98%E3%80%82%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
