SE051S AliroMW setup inquiry
AndrewChoi
Dear All
Looking at the SE051S AliroMW settings, ALIRO_KEYSLOT_KEYID_START and ALIRO_ISSUER_PUBK_KEYID_START are defined with the same value.
As far as I understand,
- Each Secure Object must have a unique ID
- The Issuer Public Key list and Key Slot list must be managed with different IDs
Is there any special intention behind setting these constants to the same value?
I'm concerned that this could cause a bug.
 Thank you
Kan_Li
Hi @AndrewChoi ,
I have got your internal ticket, let's continue the discussion there.
Thanks for your understanding and patience!
Kan
