SE050E2HQ1_I2C waveform is distorted
kamiya
MPU:RZ/G2LC(Renesas)
SecureIC:SE050E2HQ1
When I send an I2C signal, there is no response from SE050.
When I looked at the SCL and SDA waveforms, they were distorted.
(CH1:SDA,CH2:SCL)
The I2C waveforms used by other ports are not distorted.
What could be the reason why there is no response and the waveform is distorted?
Kan_Li
Hi @kamiya ,
What does "Not connected" mean on your schematics? Were the pull-ups on SDA and SCL not connected? Please kindly clarify.
Kan
