Publishing the device data using Mqtt
1,937件の閲覧回数
trialaccount12
Contributor V
       I m working with A71ch and following the documentation https://www.nxp.com/docs/en/application-note/AN12199.pdf . It states that
"If only one Cloud Pub/Sub is selected, all device telemetry will be published on that topic".  I do have a single PubsubTopic in my application.
      When I establish a connection and check the device status it shows the API's are being hit and Telemetry Event Received are showing updates. But I cannot find any way to see what data is flowing or where to find the data flow.
    In google support documentation it is stated as
Publishing telemetry events
A device can publish a telemetry event by issuing a PUBLISH message through the MQTT connection. Messages must be published to an MQTT topic in the following format:
/devices/{device-id}/events
The above way to send the data to the topic.
But the architecture in MCU seems a bit different. I tried updating my dummy data values in gcpPubSub.c but I was not successful.
For instance :
This "Value" field is from a cPayLoad function . In Watson IoT platform for same a71ch, they have specified where to check this. Where can I find this in google cloud?
(This is the default data which is being sent from demo)
Is there anywhere I can find the right syntax to do this job? I need to send the data from K64F with A71ch to google cloud and visually see the data flow/data.
Any help or pointers would be helpful.
regards
Niranjan
3 返答(返信)
1,589件の閲覧回数
estephania_mart
Let me check it and work on it so I can try to help you, as soon as I have an update, I'll let you know.
Estephania
1,589件の閲覧回数
trialaccount12
Contributor V
    Please let me know if the issue is resolvable. It would be helpful.
Niranjan
1,589件の閲覧回数
estephania_mart
Sorry for the delay response and the inconvenience this might cause you, we are still investigating and trying to reproduce the issue you are experiencing.
Estephania
