PKCS11 communication to SE050 via OpenSSL
1,957件の閲覧回数
Ryopo0802
Introduction
We want to access a private key stored on se050 from the mod_ssl (openssl-based) of the Apache web server and perform TLS communication.
https://httpd.apache.org/docs/2.4/mod/mod_ssl.html#page-header
# To use a private key from a PKCS#11 token:
SSLCertificateKeyFile  "pkcs11:token=My%20Token%20Name;id=45"
Hardware
  • SE050
Software
  • PlugAndTrust: v04.05.01
  • openssl: 3.0.12
Tried it
To verify communication with SE050 using pkcs#11, we first attempted to create a key.
# openssl genpkey \
> -provider pkcs11prov \
> -algorithm EC \
> -pkeyopt ec_paramgen_curve:P-256 \
> -pkeyopt pkcs11_id:01 \
> -pkeyopt pkcs11_label:MyNewKey
genpkey: Error setting pkcs11_id:01 parameter:
20001EBB7F000000:error:03000093:digital envelope routines:default_fixup_args:command not supported:crypto/evp/ctrl_params_translate.c:580:[action:2, state:4] name=pkcs11_id, value=01
openssl.cnf :
openssl_conf = openssl_init
[openssl_init]
providers = provider_sect
[provider_sect]
default = default_sect
pkcs11 = pkcs11_sect
[default_sect]
activate = 1
[pkcs11_sect]
identity = pkcs11prov
module = /usr/lib/ossl-modules/pkcs11prov.so
pkcs11_module = /usr/lib/libsss_pkcs11.so
activate = 1
Using the "-out" option successfully generated the key, but it was generated as a file.
# openssl genpkey -provider pkcs11prov -provider default \
> -algorithm EC \
> -out "pkcs11:id=%01;object=MyNewKey"
Questions
  1. Is it possible to communicate with SE050 using PKCS#11 with openssl3.x (provider-based)? The following is engine-based.
    https://docs.nxp.com/bundle/LLDPUG_L6.1.36_2.1.0/page/topics/pkcs_11_based_openssl_engine_third-part...
  2. Are the openssl.cnf file and the libraries being used incorrect?
  3. Is the command you used to generate the key incorrect?
I look forward to your response.
タグ(1)
5 返答(返信)
1,646件の閲覧回数
db16122
pkcs11-tool generates 2 private keys for keypairgen Which platform you are using for SE050
1,791件の閲覧回数
Kan_Li
Hi @Ryopo0802 ,
Which SE05x variant are you testing with? Was it SE050E2? Please kindly clarify.
Kan
1,786件の閲覧回数
Ryopo0802
Thank you, @Kan_Li .
I am using the following:
  • Type number: SE050F2HQ1/Z018H
  • SE050 Variant: SE050F2
タグ(1)
1,565件の閲覧回数
Kan_Li
Hi @Ryopo0802 ,
We checked pkcs#11 provider +nxp pkcs11 plugin is not working , we could replicate the error customer is getting. So it not works for now.  Moreover, here: pkcs11-provider/HOWTO.md at main · openssl-projects/pkcs11-provider · GitHub
for key generation they have given recommendation to use tools working with pkcs11 directly such as p11tool for key generation.
However, nxp's openssl provider can be used without pkcs 11: GitHub - NXPPlugNTrust/se05x-openssl-provider: This is the OpenSSL Provider for Se05x. · GitHub
If you don't want to use NXP's Openssl provider, I would be also interested to understand why is that.
Kan
1,259件の閲覧回数
Ryopo0802
Thank you, @Kan_Li
I want to use HTTPS communication from an Apache server with a private key in an NXP Secure Element. Apache can only access the private key via PKCS#11 using openssl-based mod_ssl. Therefore, openssl + PKCS#11 is required. Is there a solution?
%3CLINGO-SUB%20id%3D%22lingo-sub-2353683%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EOpenSSL%E7%B5%8C%E7%94%B1%E3%81%A7%E3%81%AESE050%E3%81%B8%E3%81%AEPKCS11%E9%80%9A%E4%BF%A1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2353683%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CH3%20id%3D%22toc-hId-2031024531%22%20id%3D%22toc-hId-2031141708%22%20id%3D%22toc-hId-2031141708%22%20id%3D%22toc-hId-2031141708%22%3E%E3%81%AF%E3%81%98%E3%82%81%E3%81%AB%3C%2FH3%3E%3CP%3EApache%E3%82%A6%E3%82%A7%E3%83%96%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%AEmod_ssl%EF%BC%88openssl%E3%83%99%E3%83%BC%E3%82%B9%EF%BC%89%E3%81%8B%E3%82%89se050%E3%81%AB%E4%BF%9D%E5%AD%98%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E7%A7%98%E5%AF%86%E9%8D%B5%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%97%E3%80%81TLS%E9%80%9A%E4%BF%A1%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E8%80%83%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fhttpd.apache.org%2Fdocs%2F2.4%2Fmod%2Fmod_ssl.html%23page-header%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%3CFONT%3E%3CFONT%3Ehttps%3A%2F%2Fhttpd.apache.org%2Fdocs%2F2.4%2Fmod%2Fmod_ssl.html%23page-header%3C%2FFONT%3E%3C%2FFONT%3E%3C%2FA%3E%3C%2FP%3E%3CPRE%20translate%3D%22no%22%3E%23%20To%20use%20a%20private%20key%20from%20a%20PKCS%2311%20token%3A%0A%3CSPAN%20class%3D%22%22%3E%3CFONT%3E%3CFONT%3ESSLCertificateKeyFile%20%3C%2FFONT%3E%3C%2FFONT%3E%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22%22%3E%3CFONT%3E%3CFONT%3E%22pkcs11%3Atoken%3DMy%2520Token%2520Name%3Bid%3D45%22%3C%2FFONT%3E%3C%2FFONT%3E%3C%2FSPAN%3E%3C%2FPRE%3E%3CH3%20id%3D%22toc-hId-223570068%22%20id%3D%22toc-hId-223687245%22%20id%3D%22toc-hId-223687245%22%20id%3D%22toc-hId-223687245%22%3E%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%3C%2FH3%3E%3CUL%3E%3CLI%3E%3CFONT%3E%3CFONT%3ESE050%3C%2FFONT%3E%3C%2FFONT%3E%3C%2FLI%3E%3C%2FUL%3E%3CH3%20id%3D%22toc-hId--1583884395%22%20id%3D%22toc-hId--1583767218%22%20id%3D%22toc-hId--1583767218%22%20id%3D%22toc-hId--1583767218%22%3E%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%3C%2FH3%3E%3CUL%3E%3CLI%3E%3CFONT%3E%3CFONT%3EPlugAndTrust%3A%20v04.05.01%3C%2FFONT%3E%3C%2FFONT%3E%3C%2FLI%3E%3CLI%3E%3CFONT%3E%3CFONT%3Eopenssl%3A%203.0.12%3C%2FFONT%3E%3C%2FFONT%3E%3C%2FLI%3E%3C%2FUL%3E%3CH3%20id%3D%22toc-hId-903628438%22%20id%3D%22toc-hId-903745615%22%20id%3D%22toc-hId-903745615%22%20id%3D%22toc-hId-903745615%22%3E%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%3C%2FH3%3E%3CP%3Epkcs%2311%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6SE050%E3%81%A8%E3%81%AE%E9%80%9A%E4%BF%A1%E3%82%92%E6%A4%9C%E8%A8%BC%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E3%81%BE%E3%81%9A%E9%8D%B5%E3%81%AE%E4%BD%9C%E6%88%90%E3%82%92%E8%A9%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CPRE%20translate%3D%22no%22%3E%3CFONT%3E%3CFONT%3E%23%20openssl%20genpkey%20%5C%20%3C%2FFONT%3E%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%3E%3CFONT%3E%26gt%3B%20-provider%20pkcs11prov%20%5C%20%3C%2FFONT%3E%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%3E%3CFONT%3E%26gt%3B%20-algorithm%20EC%20%5C%20%3C%2FFONT%3E%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%3E%3CFONT%3E%26gt%3B%20-pkeyopt%20ec_paramgen_curve%3AP-256%20%5C%20%3C%2FFONT%3E%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%3E%3CFONT%3E%26gt%3B%20-pkeyopt%20pkcs11_id%3A01%20%5C%20%3C%2FFONT%3E%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%3E%3CFONT%3E%26gt%3B%20-pkeyopt%20pkcs11_label%3AMyNewKey%20%3C%2FFONT%3E%3C%2FFONT%3E%3CBR%20%2F%3Egenpkey%3A%20Error%20setting%20pkcs11_id%3A01%20parameter%3A%3CBR%20%2F%3E20001EBB7F000000%3Aerror%3A03000093%3Adigital%20envelope%20routines%3Adefault_fixup_args%3Acommand%20not%20supported%3Acrypto%2Fevp%2Fctrl_params_translate.c%3A580%3A%5Baction%3A2%2C%20state%3A4%5D%20name%3Dpkcs11_id%2C%20value%3D01%3C%2FPRE%3E%3CP%3E%3CSPAN%3E%3CEM%3E%3CFONT%3E%3CFONT%3Eopenssl.cnf%3C%2FFONT%3E%3C%2FFONT%3E%3C%2FEM%3E%20%3CFONT%3E%3CFONT%3E%3A%3C%2FFONT%3E%3C%2FFONT%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20translate%3D%22no%22%3E%3CFONT%3E%3CFONT%3Eopenssl_conf%20%3D%20openssl_init%20%3C%2FFONT%3E%3C%2FFONT%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CFONT%3E%3CFONT%3E%5Bopenssl_init%5D%20%3C%2FFONT%3E%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%3E%3CFONT%3Eproviders%20%3D%20provider_sect%20%3C%2FFONT%3E%3C%2FFONT%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CFONT%3E%3CFONT%3E%5Bprovider_sect%5D%20%3C%2FFONT%3E%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%3E%3CFONT%3Edefault%20%3D%20default_sect%20%3C%2FFONT%3E%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%3E%3CFONT%3Epkcs11%20%3D%20pkcs11_sect%20%3C%2FFONT%3E%3C%2FFONT%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CFONT%3E%3CFONT%3E%5Bdefault_sect%5D%20%3C%2FFONT%3E%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%3E%3CFONT%3Eactivate%20%3D%201%20%3C%2FFONT%3E%3C%2FFONT%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CFONT%3E%3CFONT%3E%5Bpkcs11_sect%5D%20%3C%2FFONT%3E%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%3E%3CFONT%3Eidentity%20%3D%20pkcs11prov%20%3C%2FFONT%3E%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%3E%3CFONT%3Emodule%20%3D%20%2Fusr%2Flib%2Fossl-modules%2Fpkcs11prov.so%20%3C%2FFONT%3E%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%3E%3CFONT%3Epkcs11_module%20%3D%20%2Fusr%2Flib%2Flibsss_pkcs11.so%20%3C%2FFONT%3E%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%3E%3CFONT%3Eactivate%20%3D%201%3C%2FFONT%3E%3C%2FFONT%3E%3C%2FPRE%3E%3CP%3E%E3%80%8C-out%E3%80%8D%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%82%AD%E3%83%BC%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A8%E3%81%97%E3%81%A6%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CPRE%20translate%3D%22no%22%3E%3CFONT%3E%3CFONT%3E%23%20openssl%20genpkey%20-provider%20pkcs11prov%20-provider%20default%20%5C%20%3C%2FFONT%3E%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%3E%3CFONT%3E%26gt%3B%20-algorithm%20EC%20%5C%20%3C%2FFONT%3E%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%3E%3CFONT%3E%26gt%3B%20-pkeyopt%20ec_paramgen_curve%3AP-256%20%5C%20%3C%2FFONT%3E%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%3E%3CFONT%3E%26gt%3B%20-out%20%22pkcs11%3Aid%3D%2501%3Bobject%3DMyNewKey%22%3C%2FFONT%3E%3C%2FFONT%3E%3C%2FPRE%3E%3CH3%20id%3D%22toc-hId--903826025%22%20id%3D%22toc-hId--903708848%22%20id%3D%22toc-hId--903708848%22%20id%3D%22toc-hId--903708848%22%3E%E8%B3%AA%E5%95%8F%3C%2FH3%3E%3COL%3E%3CLI%3E%3CFONT%3E%3CFONT%3Eopenssl3.x%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6PKCS%2311%E3%81%A7SE050%E3%81%A8%E9%80%9A%E4%BF%A1%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%EF%BC%88%E3%83%97%E3%83%AD%E3%83%90%E3%82%A4%E3%83%80%E3%83%BC%E3%83%99%E3%83%BC%E3%82%B9%EF%BC%89%EF%BC%9F%E4%BB%A5%E4%B8%8B%E3%81%AF%E3%82%A8%E3%83%B3%E3%82%B8%E3%83%B3%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AE%E6%83%85%E5%A0%B1%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fdocs.nxp.com%2Fbundle%2FLLDPUG_L6.1.36_2.1.0%2Fpage%2Ftopics%2Fpkcs_11_based_openssl_engine_third-party_opensc_li.html%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fdocs.nxp.com%2Fbundle%2FLLDPUG_L6.1.36_2.1.0%2Fpage%2Ftopics%2Fpkcs_11_based_openssl_engine_third-party_opensc_li.html%3C%2FA%3E%3C%2FFONT%3E%3C%2FFONT%3E%3C%2FLI%3E%3CLI%3E%3CEM%3Eopenssl.cnf%3C%2FEM%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A8%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%AB%E8%AA%A4%E3%82%8A%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FLI%3E%3CLI%3E%E3%82%AD%E3%83%BC%E3%82%92%E7%94%9F%E6%88%90%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3CBR%20%2F%3E%E3%81%94%E5%9B%9E%E7%AD%94%E3%82%92%E3%81%8A%E5%BE%85%E3%81%A1%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2353683%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3ESE050%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2356780%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20PKCS11%20communication%20to%20SE050%20via%20OpenSSL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2356780%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FSecure-Authentication%2Fpkcs11-tool-generates-2-private-keys-for-keypairgen%2Fm-p%2F1855553%22%20target%3D%22_blank%22%3Epkcs11-tool%20%E3%81%AF%20keypairgen%20%E7%94%A8%E3%81%AB%202%20%E3%81%A4%E3%81%AE%E7%A7%98%E5%AF%86%E9%8D%B5%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82SE050%3C%2FA%3E%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%AE%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2355548%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20PKCS11%20communication%20to%20SE050%20via%20OpenSSL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2355548%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F59276%22%20target%3D%22_blank%22%3E%40Kan_Li%20%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%81%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%82%E3%81%AE%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CUL%3E%3CLI%3E%E5%9E%8B%E7%95%AA%EF%BC%9A%20%3CSTRONG%3ESE050F2HQ1%2FZ018H%3C%2FSTRONG%3E%3C%2FLI%3E%3CLI%3ESE050%20%E3%83%90%E3%83%AA%E3%82%A2%E3%83%B3%E3%83%88%3A%20%3CSTRONG%3ESE050F2%3C%2FSTRONG%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2355532%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20PKCS11%20communication%20to%20SE050%20via%20OpenSSL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2355532%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F260575%22%20target%3D%22_blank%22%3E%40Ryopo0802%20%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%A9%E3%81%AESE05x%E3%83%90%E3%83%AA%E3%82%A2%E3%83%B3%E3%83%88%E3%81%A7%E3%83%86%E3%82%B9%E3%83%88%E3%82%92%E8%A1%8C%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9FSE050E2%E3%81%A7%E3%81%97%E3%81%9F%E3%81%8B%EF%BC%9F%E3%81%94%E8%AA%AC%E6%98%8E%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%99%E3%81%A6%E3%81%8D%E3%81%AA%E4%B8%80%E6%97%A5%E3%82%92%E3%80%81%3CBR%20%2F%3E%E3%82%AB%E3%83%B3%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%E8%A8%98%EF%BC%9A%3CBR%20%2F%3E%E3%81%93%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%8C%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%B8%E3%81%AE%E5%9B%9E%E7%AD%94%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%80%8C%E6%AD%A3%E8%A7%A3%E3%81%A8%E3%81%97%E3%81%A6%E3%83%9E%E3%83%BC%E3%82%AF%E3%80%8D%E3%83%9C%E3%82%BF%E3%83%B3%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%EF%BC%81%3CBR%20%2F%3E%20-%20%E6%9C%80%E5%BE%8C%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%8B%E3%82%897%E9%80%B1%E9%96%93%E3%81%AFThread%E3%82%92%E3%83%95%E3%82%A9%E3%83%AD%E3%83%BC%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%9D%E3%82%8C%E4%BB%A5%E9%99%8D%E3%81%AE%E8%BF%94%E4%BF%A1%E3%81%AF%E7%84%A1%E8%A6%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E5%BE%8C%E6%97%A5%E3%80%81%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E6%96%B0%E3%81%97%E3%81%84Thread%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81%E9%96%89%E3%81%98%E3%82%89%E3%82%8C%E3%81%9F%20Thread%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2358329%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20PKCS11%20communication%20to%20SE050%20via%20OpenSSL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2358329%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F260575%22%20target%3D%22_blank%22%3E%40Ryopo0802%20%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3Epkcs%2311%20%E3%83%97%E3%83%AD%E3%83%90%E3%82%A4%E3%83%80%E3%83%BC%20%2Bnxp%20pkcs11%20%E3%83%97%E3%83%A9%E3%82%B0%E3%82%A4%E3%83%B3%E3%81%8C%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%8C%E5%8F%97%E3%81%91%E5%8F%96%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%92%E5%86%8D%E7%8F%BE%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%A4%E3%81%BE%E3%82%8A%E3%80%81%E4%BB%8A%E3%81%AE%E3%81%A8%E3%81%93%E3%82%8D%E3%81%AF%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%AA%E3%81%84%E3%81%A8%E3%81%84%E3%81%86%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%E3%81%95%E3%82%89%E3%81%AB%E3%80%81%E3%81%93%E3%81%A1%E3%82%89%EF%BC%9A%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fopenssl-projects%2Fpkcs11-provider%2Fblob%2Fmain%2FHOWTO.md%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Epkcs11-provider%2FHOWTO.md%20at%20main%20%C2%B7%20openssl-projects%2Fpkcs11-provider%20%C2%B7%20GitHub%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E9%8D%B5%E7%94%9F%E6%88%90%E3%81%AB%E9%96%A2%E3%81%97%E3%81%A6%E3%81%AF%3CSPAN%3E%E3%80%81p11tool%E3%81%AA%E3%81%A9%E3%81%AEpkcs11%E3%82%92%E7%9B%B4%E6%8E%A5%E6%89%B1%E3%81%86%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E6%8E%A8%E5%A5%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81NXP%E3%81%AEopenssl%E3%83%97%E3%83%AD%E3%83%90%E3%82%A4%E3%83%80%E3%81%AFPKCS%2011%E3%81%AA%E3%81%97%E3%81%A7%E3%82%82%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82GitHub%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FNXPPlugNTrust%2Fse05x-openssl-provider%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E-%20NXPPlugNTrust%2Fse05x-openssl-provider%3A%20%E3%81%93%E3%82%8C%E3%81%AFSe05x%E7%94%A8%E3%81%AEOpenSSL%E3%83%97%E3%83%AD%E3%83%90%E3%82%A4%E3%83%80%E3%81%A7%E3%81%99%E3%80%82%E3%83%BBGitHub%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ENXP%E3%81%AEOpenssl%E3%83%97%E3%83%AD%E3%83%90%E3%82%A4%E3%83%80%E3%82%92%E4%BD%BF%E3%81%84%E3%81%9F%E3%81%8F%E3%81%AA%E3%81%84%E3%81%AE%E3%81%A7%E3%81%82%E3%82%8C%E3%81%B0%E3%80%81%E3%81%9D%E3%81%AE%E7%90%86%E7%94%B1%E3%82%82%E3%81%9C%E3%81%B2%E7%9F%A5%E3%82%8A%E3%81%9F%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%99%E3%81%A6%E3%81%8D%E3%81%AA%E4%B8%80%E6%97%A5%E3%82%92%E3%80%81%3CBR%20%2F%3E%E3%82%AB%E3%83%B3%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%E8%A8%98%EF%BC%9A%3CBR%20%2F%3E%E3%81%93%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%8C%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%B8%E3%81%AE%E5%9B%9E%E7%AD%94%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%80%8C%E6%AD%A3%E8%A7%A3%E3%81%A8%E3%81%97%E3%81%A6%E3%83%9E%E3%83%BC%E3%82%AF%E3%80%8D%E3%83%9C%E3%82%BF%E3%83%B3%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%EF%BC%81%3CBR%20%2F%3E%20-%20%E6%9C%80%E5%BE%8C%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%8B%E3%82%897%E9%80%B1%E9%96%93%E3%81%AFThread%E3%82%92%E3%83%95%E3%82%A9%E3%83%AD%E3%83%BC%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%9D%E3%82%8C%E4%BB%A5%E9%99%8D%E3%81%AE%E8%BF%94%E4%BF%A1%E3%81%AF%E7%84%A1%E8%A6%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E5%BE%8C%E6%97%A5%E3%80%81%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E6%96%B0%E3%81%97%E3%81%84Thread%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81%E9%96%89%E3%81%98%E3%82%89%E3%82%8C%E3%81%9F%20Thread%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2363769%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20PKCS11%20communication%20to%20SE050%20via%20OpenSSL%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2363769%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F59276%22%20target%3D%22_blank%22%3E%40Kan_Li%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ENXP%E3%81%AEOpenssl%E3%83%97%E3%83%AD%E3%83%90%E3%82%A4%E3%83%80%E3%82%92%E4%BD%BF%E3%81%84%E3%81%9F%E3%81%8F%E3%81%AA%E3%81%84%E3%81%AE%E3%81%A7%E3%81%82%E3%82%8C%E3%81%B0%E3%80%81%E3%81%9D%E3%81%AE%E7%90%86%E7%94%B1%E3%82%82%E3%81%9C%E3%81%B2%E7%9F%A5%E3%82%8A%E3%81%9F%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3ENXP%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%82%A8%E3%83%AC%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AB%E6%A0%BC%E7%B4%8D%E3%81%95%E3%82%8C%E3%81%9F%E7%A7%98%E5%AF%86%E9%8D%B5%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81Apache%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%8B%E3%82%89HTTPS%E9%80%9A%E4%BF%A1%E3%82%92%E8%A1%8C%E3%81%84%E3%81%9F%E3%81%84%E3%80%82Apache%20%E3%81%AF%20openssl%20%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AE%3CEM%3Emod_ssl%3C%2FEM%3E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20PKCS%2311%20%E7%B5%8C%E7%94%B1%E3%81%A7%E3%81%AE%E3%81%BF%E7%A7%98%E5%AF%86%E9%8D%B5%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81openssl%E3%81%A8PKCS%2311%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%81%AF%E3%81%82%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fhttpd.apache.org%2Fdocs%2F2.4%2Fmod%2Fmod_ssl.html%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fhttpd.apache.org%2Fdocs%2F2.4%2Fmod%2Fmod_ssl.html%3C%2FA%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
