PKCS11 cmake configuration giving build errors.
10,692 次查看
ajitsj3
I am getting the below mentioned error while doing cmake build in yocto for PKCS11 configuration.
| cc1: error: -Wformat-security ignored without -Wformat [-Werror=format-security]
| cc1: some warnings being treated as errors
I have pasted the log with the source code files as mentioned below.
| [128/340] ~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/recipe-sysroot-native/usr/bin/arm-poky-linux-gnueabi/arm-poky-linux-gnueabi-gcc -DFTR_FILE_SYSTEM -DMBEDTLS_USER_CONFIG_FILE=\"sss_x86_mbedtls_config.h\" -DSSS_USE_FTR_FILE -DT1oI2C -Dmbedtls_EXPORTS -DmqttconfigENABLE_METRICS=0 -I~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/simw-top/sss/port/default -I. -I~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/simw-top/ext/mbedtls/include -I~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/simw-top/ext/mbedtls/library -I~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/simw-top/sss/plugin/mbedtls -I~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/simw-top/sss/inc -I~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/simw-top/hostlib/hostLib/libCommon/infra -I~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/simw-top/hostlib/hostLib/inc -I~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/simw-top/ext/mbedtls/port/ksdk -I~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/simw-top/hostlib/hostLib/libCommon/log/. -I~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/simw-top/hostlib/hostLib/libCommon/log/../../platform/inc -I~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/simw-top/hostlib/hostLib/libCommon/log/../infra -march=armv7-a -mfpu=neon -mfloat-abi=hard -fstack-protector-strong -D_FORTIFY_SOURCE=2 -Wformat -Wformat-security -Werror=format-security --sysroot=~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/recipe-sysroot -O2 -pipe -g -feliminate-unused-debug-types -fmacro-prefix-map=~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0=/usr/src/debug/se05x-pkcs11/04.02.00-r0 -fdebug-prefix-map=~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0=/usr/src/debug/se05x-pkcs11/04.02.00-r0 -fdebug-prefix-map=~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/recipe-sysroot= -fdebug-prefix-map=~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/recipe-sysroot-native= -march=armv7-a -mfpu=neon -mfloat-abi=hard -fstack-protector-strong -D_FORTIFY_SOURCE=2 -Wformat -Wformat-security -Werror=format-security --sysroot=~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/recipe-sysroot -Wno-unused-result -fPIC -fPIC -DNDEBUG -fPIC -Wno-unused-function -Wno-error=pointer-sign -Wno-error=format -Wno-format -Wno-implicit-function-declaration -Wno-error=unused-const-variable -Wno-unused-const-variable -MD -MT ext/CMakeFiles/mbedtls.dir/mbedtls/library/ssl_tls.c.o -MF ext/CMakeFiles/mbedtls.dir/mbedtls/library/ssl_tls.c.o.d -o ext/CMakeFiles/mbedtls.dir/mbedtls/library/ssl_tls.c.o -c ~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/simw-top/ext/mbedtls/library/ssl_tls.c
| FAILED: ext/CMakeFiles/mbedtls.dir/mbedtls/library/ssl_tls.c.o
| [129/340] ~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/recipe-sysroot-native/usr/bin/arm-poky-linux-gnueabi/arm-poky-linux-gnueabi-gcc -DFTR_FILE_SYSTEM -DMBEDTLS -DMBEDTLS_USER_CONFIG_FILE=\"sss_x86_mbedtls_config.h\" -DPLATFORM_IMX -DSSS_USE_FTR_FILE -DT1oI2C -DmqttconfigENABLE_METRICS=0 -Dse05x_EXPORTS -I~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/simw-top/sss/port/default -I. -I~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/simw-top/hostlib/hostLib/se05x/../se05x_03_xx_xx -I~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/simw-top/sss/ex/inc -I~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/simw-top/sss/inc -I~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/simw-top/hostlib/hostLib/se05x/../libCommon/nxScp -I~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/simw-top/sss/port/x86 -I~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/simw-top/hostlib/hostLib/libCommon/smCom -I~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/simw-top/hostlib/hostLib/libCommon/infra -I~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/simw-top/hostlib/hostLib/libCommon/../inc -I~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/simw-top/hostlib/hostLib/libCommon/../platform/inc -I~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/simw-top/hostlib/hostLib/libCommon/../tstUtil -I~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/simw-top/hostlib/hostLib/libCommon/../accessManager/inc -I~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/simw-top/hostlib/hostLib/libCommon/log -I~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/simw-top/hostlib/hostLib/libCommon/smCom/T1oI2C -I~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/simw-top/hostlib/hostLib/libCommon/log/. -I~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/simw-top/hostlib/hostLib/libCommon/log/../../platform/inc -I~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/simw-top/hostlib/hostLib/libCommon/log/../infra -I~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/simw-top/ext/mbedtls/include -I~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/simw-top/ext/mbedtls/library -I~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/simw-top/sss/plugin/mbedtls -I~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/simw-top/hostlib/hostLib/inc -I~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/simw-top/ext/mbedtls/port/ksdk -march=armv7-a -mfpu=neon -mfloat-abi=hard -fstack-protector-strong -D_FORTIFY_SOURCE=2 -Wformat -Wformat-security -Werror=format-security --sysroot=~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/recipe-sysroot -O2 -pipe -g -feliminate-unused-debug-types -fmacro-prefix-map=~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0=/usr/src/debug/se05x-pkcs11/04.02.00-r0 -fdebug-prefix-map=~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0=/usr/src/debug/se05x-pkcs11/04.02.00-r0 -fdebug-prefix-map=~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/recipe-sysroot= -fdebug-prefix-map=~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/recipe-sysroot-native= -march=armv7-a -mfpu=neon -mfloat-abi=hard -fstack-protector-strong -D_FORTIFY_SOURCE=2 -Wformat -Wformat-security -Werror=format-security --sysroot=~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/recipe-sysroot -Wno-unused-result -fPIC -fPIC -DNDEBUG -fPIC -MD -MT hostlib/hostLib/se05x/CMakeFiles/se05x.dir/__/se05x_03_xx_xx/se05x_APDU.c.o -MF hostlib/hostLib/se05x/CMakeFiles/se05x.dir/__/se05x_03_xx_xx/se05x_APDU.c.o.d -o hostlib/hostLib/se05x/CMakeFiles/se05x.dir/__/se05x_03_xx_xx/se05x_APDU.c.o -c ~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/simw-top/hostlib/hostLib/se05x_03_xx_xx/se05x_APDU.c
Please help me out in resolving this error.
Thanks and regards
Ajit S J
13 回复数
10,685 次查看
Kan_Li
Hi @ajitsj3 ,
Are you using the latest MW? Is it possible to have your cmake options for a review? You may run "cmake . -L" in the building folder to have the cmake configuration.
Thanks for your patience!
Kan
10,682 次查看
ajitsj3
@Kan_Li ,
We are using yocto platform to build the pkcs11 engine for se05x. Please find the Cmake configuration below.
-DCMAKE_BUILD_TYPE=Release -DCMAKE_INSTALL_PREFIX=${exec_prefix} \
-DPTMW_Host=iMXLinux \
-DIOT=None -DPTMW_Applet=SE05X_C -DPTMW_SE05X_Ver=06_00 \
-DOPENSSL_INSTALL_PREFIX=${RECIPE_SYSROOT}/${exec_prefix}/ \
-DOPENSSL_ROOT_DIR=${RECIPE_SYSROOT}/${exec_prefix}/ \
-DSSS_HAVE_LOG_SILENT=1 \
-DPTMW_HostCrypto=MBEDTLS \
-DPTMW_mbedTLS_ALT=SSS \
-DPTMW_RTOS=Default \
-DWithSharedLIB=ON \
-DPTMW_SMCOM=T1oI2C \
-DPTMW_SE05X_Auth=None \
-DPTMW_SCP=None \
And yes, we are using latest MW version "04.02.00"
Thanks and regards
Ajit
标记 (2)
10,678 次查看
Kan_Li
Hi @ajitsj3 ,
Thanks for the information! Actually IOT option is not used by the MW, maybe you modified somewhere in the MW, but anyway, I tried your configuration based on imx8M, but no such issue met. Please kindly refer to the following for details.
My configuration is as below:
root@imx8mqevk:~/se05x_mw_v04.02.00_20220527_125816/simw-top_build/imx_native_se050_t1oi2c# cmake . -L
-- BUILD_TYPE: Release
-- Found: /usr/lib/libssl.so/usr/lib/libcrypto.so
-- CMAKE_CXX_COMPILER_ID = GNU
-- CMAKE_SYSTEM_NAME = Linux
-- PTMW_SE05X_Auth - None
-- Could not detect git directories. Using STUB Values for GIT Version
accessManager is not copied to default binary directory upon install
-- Configuring done
-- Generating done
-- Build files have been written to: /home/root/se05x_mw_v04.02.00_20220527_125816/simw-top_build/imx_native_se050_t1oi2c
-- Cache values
CMAKE_BUILD_TYPE:STRING=Release
CMAKE_INSTALL_PREFIX:PATH=/usr/local
LIB_ANL:FILEPATH=/usr/lib/libanl.so
NXPInternal:BOOL=OFF
OPENSSL_ROOT_DIR:PATH=
PAHO_BUILD_DEB_PACKAGE:BOOL=FALSE
PAHO_BUILD_DOCUMENTATION:BOOL=FALSE
PAHO_BUILD_SAMPLES:BOOL=FALSE
PAHO_BUILD_SHARED:BOOL=TRUE
PAHO_BUILD_STATIC:BOOL=FALSE
PAHO_ENABLE_CPACK:BOOL=TRUE
PAHO_ENABLE_TESTING:BOOL=FALSE
PAHO_WITH_SSL:BOOL=TRUE
PTMW_A71CH_AUTH:STRING=None
PTMW_Applet:STRING=SE05X_C
PTMW_FIPS:STRING=None
PTMW_Host:STRING=iMXLinux
PTMW_HostCrypto:STRING=MBEDTLS
PTMW_Log:STRING=Default
PTMW_RTOS:STRING=Default
PTMW_SBL:STRING=None
PTMW_SCP:STRING=None
PTMW_SE05X_Auth:STRING=None
PTMW_SE05X_Ver:STRING=06_00
PTMW_SMCOM:STRING=T1oI2C
PTMW_mbedTLS_ALT:STRING=SSS
SSSFTR_SE05X_AES:BOOL=ON
SSSFTR_SE05X_AuthECKey:BOOL=ON
SSSFTR_SE05X_AuthSession:BOOL=ON
SSSFTR_SE05X_CREATE_DELETE_CRYPTOOBJ:BOOL=ON
SSSFTR_SE05X_ECC:BOOL=ON
SSSFTR_SE05X_KEY_GET:BOOL=ON
SSSFTR_SE05X_KEY_SET:BOOL=ON
SSSFTR_SE05X_RSA:BOOL=ON
SSSFTR_SW_AES:BOOL=ON
SSSFTR_SW_ECC:BOOL=ON
SSSFTR_SW_KEY_GET:BOOL=ON
SSSFTR_SW_KEY_SET:BOOL=ON
SSSFTR_SW_RSA:BOOL=ON
SSSFTR_SW_TESTCOUNTERPART:BOOL=ON
WithAccessMgr_UnixSocket:BOOL=OFF
WithCodeCoverage:BOOL=OFF
WithExtCustomerTPMCode:BOOL=OFF
WithNXPNFCRdLib:BOOL=OFF
WithOPCUA_open62541:BOOL=OFF
WithSharedLIB:BOOL=ON
Maybe it is due to complier toolchain? gcc (GCC) 9.2.0 is used from here, what about yours?
Kan
10,670 次查看
ajitsj3
Hi @Kan_Li ,
The GCC version that we are using is "8.3.0".
Is there a minimum GCC version requirement to build PKCS11?
Because we are able to build the accessManager and JRCPV1 clients and demos with the same "8.3.0" version of GCC. We are facing issue only for this pkcs11 configuration.
Thanks and regards,
Ajit S J
10,662 次查看
Kan_Li
Hi @ajitsj3 ,
I am sorry, but I have no info regarding this topic, while referring to the guide , only gcc 9.2 is mentioned,  maybe you can use it as a reference.
Kan
10,645 次查看
ajitsj3
@Kan_Li ,
We now have upgraded the GCC compiler version to "9.3.0". But we are still facing the same issue when we build in yocto. I request you to help us resolve this issue ASAP.
Thanks and regards,
Ajit S J
标记 (2)
10,643 次查看
Kan_Li
Hello @ajitsj3 ,
I have no idea about how you updated the GCC from your side, but I am sure the cross tool chain installed in Ubuntu can work well as expected. Please kindly refer to the following for details.
arm-linux-gnueabihf-gcc (Ubuntu 9.4.0-1ubuntu1~20.04.1) 9.4.0
Copyright (C) 2019 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
You may install this under Ubuntu with the following instruction:
sudo apt-get install gcc-arm-linux-gnueabihf g++-arm-linux-gnueabihf
Please refer to https://www.acmesystems.it/arm9_toolchain for more details.
Hope that helps,
Kan
10,639 次查看
ajitsj3
@Kan_Li ,
We are not using ubuntu to cross-compile. We are using yocto build environment to build PKCS11. We upgraded the yocto build environment to get the latest gcc compiler. We have created a recipe for PKCS11 with the below mentioned configuration.
-DPTMW_SCP=None \
Is the configuration mentioned above correct? Or do we need to add anything else?
Thanks and regards
Ajit
10,632 次查看
ajitsj3
I was able to resolve the "-Wformat-security" issue by adding the line "PRIVATE -Wno-error=format-security" to the file "ext/mbedtls.cmake".
I also added the configurations as mentioned by you. Now the updated configurations for pkcs11 is as mentioned below.
-DOPENSSL_INSTALL_PREFIX=${RECIPE_SYSROOT}${exec_prefix} \
-DOPENSSL_ROOT_DIR=${RECIPE_SYSROOT}${exec_prefix} \
-DPTMW_SCP=None \
-DPAHO_BUILD_DEB_PACKAGE=OFF \
-DPAHO_BUILD_DOCUMENTATION=OFF \
-DPAHO_BUILD_SAMPLES=OFF \
-DPAHO_BUILD_SHARED=OFF \
-DPAHO_BUILD_STATIC=OFF \
-DPAHO_ENABLE_CPACK=ON \
-DPAHO_ENABLE_TESTING=OFF \
-DPAHO_WITH_SSL=ON \
-DSSSFTR_SE05X_AES=ON \
-DSSSFTR_SE05X_AuthECKey=ON \
-DSSSFTR_SE05X_AuthSession=ON \
-DSSSFTR_SE05X_CREATE_DELETE_CRYPTOOBJ=ON \
-DSSSFTR_SE05X_ECC=ON \
-DSSSFTR_SE05X_KEY_GET=ON \
-DSSSFTR_SE05X_KEY_SET=ON \
-DSSSFTR_SE05X_RSA=ON \
-DSSSFTR_SW_AES=ON \
-DSSSFTR_SW_ECC=ON \
-DSSSFTR_SW_KEY_GET=ON \
-DSSSFTR_SW_KEY_SET=ON \
-DSSSFTR_SW_RSA=ON \
-DSSSFTR_SW_TESTCOUNTERPART=ON \
-DWithAccessMgr_UnixSocket=OFF \
-DWithCodeCoverage=OFF \
-DWithExtCustomerTPMCode=OFF \
-DWithNXPNFCRdLib=OFF \
-DWithOPCUA_open62541=OFF \
Now we are getting undefined reference errors for function definitions. I have pasted a small snippet of the error log below.
| FAILED: bin/mbedtls_ex_orig_ssl_server2
| : && ~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/recipe-sysroot-native/usr/bin/arm-poky-linux-gnueabi/arm-poky-linux-gnueabi-gcc -march=armv7-a -mfpu=neon -mfloat-abi=hard -fstack-protector-strong -D_FORTIFY_SOURCE=2 -Wformat -Wformat-security -Werror=format-security --sysroot=~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/recipe-sysroot -O2 -pipe -g -feliminate-unused-debug-types -fmacro-prefix-map=~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0=/usr/src/debug/se05x-pkcs11/04.02.00-r0 -fdebug-prefix-map=~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0=/usr/src/debug/se05x-pkcs11/04.02.00-r0 -fdebug-prefix-map=~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/recipe-sysroot= -fdebug-prefix-map=~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/recipe-sysroot-native= -march=armv7-a -mfpu=neon -mfloat-abi=hard -fstack-protector-strong -D_FORTIFY_SOURCE=2 -Wformat -Wformat-security -Werror=format-security --sysroot=~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/recipe-sysroot -Wno-unused-result -fPIC -fPIC -DNDEBUG -march=armv7-a -mfpu=neon -mfloat-abi=hard -fstack-protector-strong -D_FORTIFY_SOURCE=2 -Wformat -Wformat-security -Werror=format-security --sysroot=~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/recipe-sysroot -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed -fstack-protector-strong -Wl,-z,relro,-z,now -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed -fstack-protector-strong -Wl,-z,relro,-z,now sss/ex/mbedtls/CMakeFiles/mbedtls_ex_orig_ssl_server2.dir/__/__/__/ext/mbedtls/programs/ssl/ssl_server2.c.o sss/ex/mbedtls/CMakeFiles/mbedtls_ex_orig_ssl_server2.dir/__/__/__/ext/mbedtls/programs/test/query_config.c.o sss/ex/mbedtls/CMakeFiles/mbedtls_ex_orig_ssl_server2.dir/__/__/__/ext/mbedtls/tests/src/helpers.c.o sss/ex/mbedtls/CMakeFiles/mbedtls_ex_orig_ssl_server2.dir/__/__/__/ext/mbedtls/programs/ssl/ssl_test_lib.c.o -o bin/mbedtls_ex_orig_ssl_server2 -Wl,-rpath,"\$ORIGIN/../sss:\$ORIGIN/../hostlib/hostLib/se05x:\$ORIGIN/../hostlib/hostLib:\$ORIGIN/../hostlib/hostLib/libCommon:\$ORIGIN/../ext:\$ORIGIN/../hostlib/hostLib/libCommon/log" sss/libSSS_APIs.so hostlib/hostLib/se05x/libse05x.so hostlib/hostLib/liba7x_utils.so hostlib/hostLib/libCommon/libsmCom.so ext/libmbedtls.so hostlib/hostLib/libCommon/log/libmwlog.so ~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/recipe-sysroot/usr/lib/libssl.so ~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/recipe-sysroot/usr/lib/libcrypto.so -lpthread && cd ~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/se05x-pkcs11-04.02.00/sss/ex/mbedtls && ~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/recipe-sysroot-native/usr/bin/cmake -E copy ~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/se05x-pkcs11-04.02.00/bin/mbedtls_ex_orig_ssl_server2 ~/work/build/workspace/sources/se05x-pkcs11/tools
| ~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/recipe-sysroot-native/usr/bin/arm-poky-linux-gnueabi/../../libexec/arm-poky-linux-gnueabi/gcc/arm-poky-linux-gnueabi/9.3.0/ld: ext/libmbedtls.so: undefined reference to `gecc_der_header_224k'
| ~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/recipe-sysroot-native/usr/bin/arm-poky-linux-gnueabi/../../libexec/arm-poky-linux-gnueabi/gcc/arm-poky-linux-gnueabi/9.3.0/ld: ext/libmbedtls.so: undefined reference to `gecc_der_header_nist192'
| ~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/recipe-sysroot-native/usr/bin/arm-poky-linux-gnueabi/../../libexec/arm-poky-linux-gnueabi/gcc/arm-poky-linux-gnueabi/9.3.0/ld: ext/libmbedtls.so: undefined reference to `gecc_der_header_bp384'
| ~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/recipe-sysroot-native/usr/bin/arm-poky-linux-gnueabi/../../libexec/arm-poky-linux-gnueabi/gcc/arm-poky-linux-gnueabi/9.3.0/ld: ext/libmbedtls.so: undefined reference to `der_ecc_224k_header_len'
| ~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/recipe-sysroot-native/usr/bin/arm-poky-linux-gnueabi/../../libexec/arm-poky-linux-gnueabi/gcc/arm-poky-linux-gnueabi/9.3.0/ld: ext/libmbedtls.so: undefined reference to `der_ecc_bp256_header_len'
| ~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/recipe-sysroot-native/usr/bin/arm-poky-linux-gnueabi/../../libexec/arm-poky-linux-gnueabi/gcc/arm-poky-linux-gnueabi/9.3.0/ld: ext/libmbedtls.so: undefined reference to `sss_asymmetric_verify_digest'
| ~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/recipe-sysroot-native/usr/bin/arm-poky-linux-gnueabi/../../libexec/arm-poky-linux-gnueabi/gcc/arm-poky-linux-gnueabi/9.3.0/ld: ext/libmbedtls.so: undefined reference to `sss_key_store_set_key'
Thanks and regards,
Ajit
10,623 次查看
Kan_Li
Hi @ajitsj3 ,
Actually I don't think adding the option "-Wno-error=format-security" solves this issue , it just ignores the error and let the building continue, but anyway, the new issue here is not relevant with this option, it looks like some kind of link issue, and as far as I know, some targets have to be built before building PKCS11 lib, such as SSS_APIs.
Did you build these targets as well? and since you mentioned Yocto was used in the building, would you please clarify if you followed the steps listed in simw-top/doc/dev-platforms/platform_imx8_linux.html  and simw-top/doc/dev-platforms/platform_imx8_linux.html?highlight=cross#imx8-plugandtrust-recipe ?  Is it possible to share your recipe for a review?
Kan
10,621 次查看
ajitsj3
@Kan_Li ,
I was able to get rid of the "-Wformat-security" issue by adding the line "PRIVATE -Wno-error=format-security" in the file "ext/mbedtls.cmake".
Now I am getting undefined reference errors for some function definitions. I have attached the errors mentioned below.
| ~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/recipe-sysroot-native/usr/bin/arm-poky-linux-gnueabi/../../libexec/arm-poky-linux-gnueabi/gcc/arm-poky-linux-gnueabi/9.3.0/ld: ext/libmbedtls.so: undefined reference to `sss_derive_key_dh'
| ~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/recipe-sysroot-native/usr/bin/arm-poky-linux-gnueabi/../../libexec/arm-poky-linux-gnueabi/gcc/arm-poky-linux-gnueabi/9.3.0/ld: ext/libmbedtls.so: undefined reference to `gecc_der_header_256k'
| ~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/recipe-sysroot-native/usr/bin/arm-poky-linux-gnueabi/../../libexec/arm-poky-linux-gnueabi/gcc/arm-poky-linux-gnueabi/9.3.0/ld: ext/libmbedtls.so: undefined reference to `gecc_der_header_bp512'
| ~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/recipe-sysroot-native/usr/bin/arm-poky-linux-gnueabi/../../libexec/arm-poky-linux-gnueabi/gcc/arm-poky-linux-gnueabi/9.3.0/ld: ext/libmbedtls.so: undefined reference to `der_ecc_bp512_header_len'
| ~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/recipe-sysroot-native/usr/bin/arm-poky-linux-gnueabi/../../libexec/arm-poky-linux-gnueabi/gcc/arm-poky-linux-gnueabi/9.3.0/ld: ext/libmbedtls.so: undefined reference to `der_ecc_nistp256_header_len'
| ~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/recipe-sysroot-native/usr/bin/arm-poky-linux-gnueabi/../../libexec/arm-poky-linux-gnueabi/gcc/arm-poky-linux-gnueabi/9.3.0/ld: ext/libmbedtls.so: undefined reference to `sss_derive_key_context_init'
| ~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/recipe-sysroot-native/usr/bin/arm-poky-linux-gnueabi/../../libexec/arm-poky-linux-gnueabi/gcc/arm-poky-linux-gnueabi/9.3.0/ld: ext/libmbedtls.so: undefined reference to `gecc_der_header_mont_dh_25519'
| ~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/recipe-sysroot-native/usr/bin/arm-poky-linux-gnueabi/../../libexec/arm-poky-linux-gnueabi/gcc/arm-poky-linux-gnueabi/9.3.0/ld: ext/libmbedtls.so: undefined reference to `gecc_der_header_192k'
| ~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/recipe-sysroot-native/usr/bin/arm-poky-linux-gnueabi/../../libexec/arm-poky-linux-gnueabi/gcc/arm-poky-linux-gnueabi/9.3.0/ld: ext/libmbedtls.so: undefined reference to `gecc_der_header_nist384'
| ~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/recipe-sysroot-native/usr/bin/arm-poky-linux-gnueabi/../../libexec/arm-poky-linux-gnueabi/gcc/arm-poky-linux-gnueabi/9.3.0/ld: ext/libmbedtls.so: undefined reference to `sss_key_object_allocate_handle'
| ~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/recipe-sysroot-native/usr/bin/arm-poky-linux-gnueabi/../../libexec/arm-poky-linux-gnueabi/gcc/arm-poky-linux-gnueabi/9.3.0/ld: ext/libmbedtls.so: undefined reference to `der_ecc_256k_header_len'
| ~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/recipe-sysroot-native/usr/bin/arm-poky-linux-gnueabi/../../libexec/arm-poky-linux-gnueabi/gcc/arm-poky-linux-gnueabi/9.3.0/ld: ext/libmbedtls.so: undefined reference to `der_ecc_mont_dh_25519_header_len'
| ~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/recipe-sysroot-native/usr/bin/arm-poky-linux-gnueabi/../../libexec/arm-poky-linux-gnueabi/gcc/arm-poky-linux-gnueabi/9.3.0/ld: ext/libmbedtls.so: undefined reference to `sss_util_asn1_rsa_parse_public'
| ~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/recipe-sysroot-native/usr/bin/arm-poky-linux-gnueabi/../../libexec/arm-poky-linux-gnueabi/gcc/arm-poky-linux-gnueabi/9.3.0/ld: ext/libmbedtls.so: undefined reference to `gecc_der_header_mont_dh_448'
| ~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/recipe-sysroot-native/usr/bin/arm-poky-linux-gnueabi/../../libexec/arm-poky-linux-gnueabi/gcc/arm-poky-linux-gnueabi/9.3.0/ld: ext/libmbedtls.so: undefined reference to `der_ecc_nistp192_header_len'
| ~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/recipe-sysroot-native/usr/bin/arm-poky-linux-gnueabi/../../libexec/arm-poky-linux-gnueabi/gcc/arm-poky-linux-gnueabi/9.3.0/ld: ext/libmbedtls.so: undefined reference to `sss_key_store_get_key'
| ~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/recipe-sysroot-native/usr/bin/arm-poky-linux-gnueabi/../../libexec/arm-poky-linux-gnueabi/gcc/arm-poky-linux-gnueabi/9.3.0/ld: ext/libmbedtls.so: undefined reference to `der_ecc_192k_header_len'
| ~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/recipe-sysroot-native/usr/bin/arm-poky-linux-gnueabi/../../libexec/arm-poky-linux-gnueabi/gcc/arm-poky-linux-gnueabi/9.3.0/ld: ext/libmbedtls.so: undefined reference to `gecc_der_header_nist224'
| ~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/recipe-sysroot-native/usr/bin/arm-poky-linux-gnueabi/../../libexec/arm-poky-linux-gnueabi/gcc/arm-poky-linux-gnueabi/9.3.0/ld: ext/libmbedtls.so: undefined reference to `der_ecc_mont_dh_448_header_len'
| ~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/recipe-sysroot-native/usr/bin/arm-poky-linux-gnueabi/../../libexec/arm-poky-linux-gnueabi/gcc/arm-poky-linux-gnueabi/9.3.0/ld: ext/libmbedtls.so: undefined reference to `der_ecc_bp384_header_len'
| ~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/recipe-sysroot-native/usr/bin/arm-poky-linux-gnueabi/../../libexec/arm-poky-linux-gnueabi/gcc/arm-poky-linux-gnueabi/9.3.0/ld: ext/libmbedtls.so: undefined reference to `sss_util_asn1_get_oid_from_sssObj'
| ~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/recipe-sysroot-native/usr/bin/arm-poky-linux-gnueabi/../../libexec/arm-poky-linux-gnueabi/gcc/arm-poky-linux-gnueabi/9.3.0/ld: ext/libmbedtls.so: undefined reference to `gecc_der_header_nist256'
| ~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/recipe-sysroot-native/usr/bin/arm-poky-linux-gnueabi/../../libexec/arm-poky-linux-gnueabi/gcc/arm-poky-linux-gnueabi/9.3.0/ld: ext/libmbedtls.so: undefined reference to `sss_key_object_free'
| ~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/recipe-sysroot-native/usr/bin/arm-poky-linux-gnueabi/../../libexec/arm-poky-linux-gnueabi/gcc/arm-poky-linux-gnueabi/9.3.0/ld: ext/libmbedtls.so: undefined reference to `der_ecc_nistp521_header_len'
| ~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/recipe-sysroot-native/usr/bin/arm-poky-linux-gnueabi/../../libexec/arm-poky-linux-gnueabi/gcc/arm-poky-linux-gnueabi/9.3.0/ld: ext/libmbedtls.so: undefined reference to `sss_asymmetric_context_init'
| ~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/recipe-sysroot-native/usr/bin/arm-poky-linux-gnueabi/../../libexec/arm-poky-linux-gnueabi/gcc/arm-poky-linux-gnueabi/9.3.0/ld: ext/libmbedtls.so: undefined reference to `gecc_der_header_nist521'
| ~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/recipe-sysroot-native/usr/bin/arm-poky-linux-gnueabi/../../libexec/arm-poky-linux-gnueabi/gcc/arm-poky-linux-gnueabi/9.3.0/ld: ext/libmbedtls.so: undefined reference to `sss_asymmetric_sign_digest'
| ~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/recipe-sysroot-native/usr/bin/arm-poky-linux-gnueabi/../../libexec/arm-poky-linux-gnueabi/gcc/arm-poky-linux-gnueabi/9.3.0/ld: ext/libmbedtls.so: undefined reference to `sss_key_object_init'
| ~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/recipe-sysroot-native/usr/bin/arm-poky-linux-gnueabi/../../libexec/arm-poky-linux-gnueabi/gcc/arm-poky-linux-gnueabi/9.3.0/ld: ext/libmbedtls.so: undefined reference to `der_ecc_nistp384_header_len'
| ~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/recipe-sysroot-native/usr/bin/arm-poky-linux-gnueabi/../../libexec/arm-poky-linux-gnueabi/gcc/arm-poky-linux-gnueabi/9.3.0/ld: ext/libmbedtls.so: undefined reference to `der_ecc_nistp224_header_len'
| ~/work/build/tmp/work/armv7ahf-neon-poky-linux-gnueabi/se05x-pkcs11/04.02.00-r0/recipe-sysroot-native/usr/bin/arm-poky-linux-gnueabi/../../libexec/arm-poky-linux-gnueabi/gcc/arm-poky-linux-gnueabi/9.3.0/ld: ext/libmbedtls.so: undefined reference to `gecc_der_header_bp256'
| collect2: error: ld returned 1 exit status
I request you to help us resolve this issue.
Thanks and regards
Ajit
8,982 次查看
msalvinik
Hi @ajitsj3 @Kan_Li
I'm building the SE050 middleware with PKCS#11 support, as ajitsj3. I have a Cmake configuration like the ajitsj3's one.
And I get the same "undefined reference" error during linking phase (after fixing the same compiling error about -Wno-error=format-security).
I'm using SE05x-MW v04.03.01 and GCC 11.3.0
Are there some updates about this issue?
Thanks in advance
[ 73%] Linking C executable ../../../bin/mbedtls_ex_orig_ssl_server2
/opt/toolchain//sysroots/x86_64-pokysdk-linux/usr/libexec/aarch64-poky-linux/gcc/aarch64-poky-linux/11.3.0/ld: ../../../ext/libmbedtls.so: undefined reference to `gecc_der_header_224k'
/opt/toolchain//sysroots/x86_64-pokysdk-linux/usr/libexec/aarch64-poky-linux/gcc/aarch64-poky-linux/11.3.0/ld: ../../../ext/libmbedtls.so: undefined reference to `gecc_der_header_nist192'
/opt/toolchain//sysroots/x86_64-pokysdk-linux/usr/libexec/aarch64-poky-linux/gcc/aarch64-poky-linux/11.3.0/ld: ../../../ext/libmbedtls.so: undefined reference to `gecc_der_header_bp384'
/opt/toolchain//sysroots/x86_64-pokysdk-linux/usr/libexec/aarch64-poky-linux/gcc/aarch64-poky-linux/11.3.0/ld: ../../../ext/libmbedtls.so: undefined reference to `der_ecc_224k_header_len'
/opt/toolchain//sysroots/x86_64-pokysdk-linux/usr/libexec/aarch64-poky-linux/gcc/aarch64-poky-linux/11.3.0/ld: ../../../ext/libmbedtls.so: undefined reference to `der_ecc_bp256_header_len'
/opt/toolchain//sysroots/x86_64-pokysdk-linux/usr/libexec/aarch64-poky-linux/gcc/aarch64-poky-linux/11.3.0/ld: ../../../ext/libmbedtls.so: undefined reference to `sss_asymmetric_verify_digest'
/opt/toolchain//sysroots/x86_64-pokysdk-linux/usr/libexec/aarch64-poky-linux/gcc/aarch64-poky-linux/11.3.0/ld: ../../../ext/libmbedtls.so: undefined reference to `sss_key_store_set_key'
/opt/toolchain//sysroots/x86_64-pokysdk-linux/usr/libexec/aarch64-poky-linux/gcc/aarch64-poky-linux/11.3.0/ld: ../../../ext/libmbedtls.so: undefined reference to `sss_derive_key_dh'
/opt/toolchain//sysroots/x86_64-pokysdk-linux/usr/libexec/aarch64-poky-linux/gcc/aarch64-poky-linux/11.3.0/ld: ../../../ext/libmbedtls.so: undefined reference to `gecc_der_header_256k'
/opt/toolchain//sysroots/x86_64-pokysdk-linux/usr/libexec/aarch64-poky-linux/gcc/aarch64-poky-linux/11.3.0/ld: ../../../ext/libmbedtls.so: undefined reference to `gecc_der_header_bp512'
/opt/toolchain//sysroots/x86_64-pokysdk-linux/usr/libexec/aarch64-poky-linux/gcc/aarch64-poky-linux/11.3.0/ld: ../../../ext/libmbedtls.so: undefined reference to `der_ecc_bp512_header_len'
/opt/toolchain//sysroots/x86_64-pokysdk-linux/usr/libexec/aarch64-poky-linux/gcc/aarch64-poky-linux/11.3.0/ld: ../../../ext/libmbedtls.so: undefined reference to `der_ecc_nistp256_header_len'
/opt/toolchain//sysroots/x86_64-pokysdk-linux/usr/libexec/aarch64-poky-linux/gcc/aarch64-poky-linux/11.3.0/ld: ../../../ext/libmbedtls.so: undefined reference to `sss_derive_key_context_init'
/opt/toolchain//sysroots/x86_64-pokysdk-linux/usr/libexec/aarch64-poky-linux/gcc/aarch64-poky-linux/11.3.0/ld: ../../../ext/libmbedtls.so: undefined reference to `gecc_der_header_mont_dh_25519'
/opt/toolchain//sysroots/x86_64-pokysdk-linux/usr/libexec/aarch64-poky-linux/gcc/aarch64-poky-linux/11.3.0/ld: ../../../ext/libmbedtls.so: undefined reference to `gecc_der_header_192k'
/opt/toolchain//sysroots/x86_64-pokysdk-linux/usr/libexec/aarch64-poky-linux/gcc/aarch64-poky-linux/11.3.0/ld: ../../../ext/libmbedtls.so: undefined reference to `gecc_der_header_nist384'
/opt/toolchain//sysroots/x86_64-pokysdk-linux/usr/libexec/aarch64-poky-linux/gcc/aarch64-poky-linux/11.3.0/ld: ../../../ext/libmbedtls.so: undefined reference to `sss_key_object_allocate_handle'
/opt/toolchain//sysroots/x86_64-pokysdk-linux/usr/libexec/aarch64-poky-linux/gcc/aarch64-poky-linux/11.3.0/ld: ../../../ext/libmbedtls.so: undefined reference to `der_ecc_256k_header_len'
/opt/toolchain//sysroots/x86_64-pokysdk-linux/usr/libexec/aarch64-poky-linux/gcc/aarch64-poky-linux/11.3.0/ld: ../../../ext/libmbedtls.so: undefined reference to `der_ecc_mont_dh_25519_header_len'
/opt/toolchain//sysroots/x86_64-pokysdk-linux/usr/libexec/aarch64-poky-linux/gcc/aarch64-poky-linux/11.3.0/ld: ../../../ext/libmbedtls.so: undefined reference to `gecc_der_header_mont_dh_448'
/opt/toolchain//sysroots/x86_64-pokysdk-linux/usr/libexec/aarch64-poky-linux/gcc/aarch64-poky-linux/11.3.0/ld: ../../../ext/libmbedtls.so: undefined reference to `der_ecc_nistp192_header_len'
/opt/toolchain//sysroots/x86_64-pokysdk-linux/usr/libexec/aarch64-poky-linux/gcc/aarch64-poky-linux/11.3.0/ld: ../../../ext/libmbedtls.so: undefined reference to `sss_key_store_get_key'
/opt/toolchain//sysroots/x86_64-pokysdk-linux/usr/libexec/aarch64-poky-linux/gcc/aarch64-poky-linux/11.3.0/ld: ../../../ext/libmbedtls.so: undefined reference to `der_ecc_192k_header_len'
/opt/toolchain//sysroots/x86_64-pokysdk-linux/usr/libexec/aarch64-poky-linux/gcc/aarch64-poky-linux/11.3.0/ld: ../../../ext/libmbedtls.so: undefined reference to `gecc_der_header_nist224'
/opt/toolchain//sysroots/x86_64-pokysdk-linux/usr/libexec/aarch64-poky-linux/gcc/aarch64-poky-linux/11.3.0/ld: ../../../ext/libmbedtls.so: undefined reference to `der_ecc_mont_dh_448_header_len'
/opt/toolchain//sysroots/x86_64-pokysdk-linux/usr/libexec/aarch64-poky-linux/gcc/aarch64-poky-linux/11.3.0/ld: ../../../ext/libmbedtls.so: undefined reference to `der_ecc_bp384_header_len'
/opt/toolchain//sysroots/x86_64-pokysdk-linux/usr/libexec/aarch64-poky-linux/gcc/aarch64-poky-linux/11.3.0/ld: ../../../ext/libmbedtls.so: undefined reference to `sss_util_asn1_get_oid_from_sssObj'
/opt/toolchain//sysroots/x86_64-pokysdk-linux/usr/libexec/aarch64-poky-linux/gcc/aarch64-poky-linux/11.3.0/ld: ../../../ext/libmbedtls.so: undefined reference to `gecc_der_header_nist256'
/opt/toolchain//sysroots/x86_64-pokysdk-linux/usr/libexec/aarch64-poky-linux/gcc/aarch64-poky-linux/11.3.0/ld: ../../../ext/libmbedtls.so: undefined reference to `sss_key_object_free'
/opt/toolchain//sysroots/x86_64-pokysdk-linux/usr/libexec/aarch64-poky-linux/gcc/aarch64-poky-linux/11.3.0/ld: ../../../ext/libmbedtls.so: undefined reference to `der_ecc_nistp521_header_len'
/opt/toolchain//sysroots/x86_64-pokysdk-linux/usr/libexec/aarch64-poky-linux/gcc/aarch64-poky-linux/11.3.0/ld: ../../../ext/libmbedtls.so: undefined reference to `sss_asymmetric_context_init'
/opt/toolchain//sysroots/x86_64-pokysdk-linux/usr/libexec/aarch64-poky-linux/gcc/aarch64-poky-linux/11.3.0/ld: ../../../ext/libmbedtls.so: undefined reference to `gecc_der_header_nist521'
/opt/toolchain//sysroots/x86_64-pokysdk-linux/usr/libexec/aarch64-poky-linux/gcc/aarch64-poky-linux/11.3.0/ld: ../../../ext/libmbedtls.so: undefined reference to `sss_asymmetric_sign_digest'
/opt/toolchain//sysroots/x86_64-pokysdk-linux/usr/libexec/aarch64-poky-linux/gcc/aarch64-poky-linux/11.3.0/ld: ../../../ext/libmbedtls.so: undefined reference to `sss_key_object_init'
/opt/toolchain//sysroots/x86_64-pokysdk-linux/usr/libexec/aarch64-poky-linux/gcc/aarch64-poky-linux/11.3.0/ld: ../../../ext/libmbedtls.so: undefined reference to `der_ecc_nistp384_header_len'
/opt/toolchain//sysroots/x86_64-pokysdk-linux/usr/libexec/aarch64-poky-linux/gcc/aarch64-poky-linux/11.3.0/ld: ../../../ext/libmbedtls.so: undefined reference to `der_ecc_nistp224_header_len'
/opt/toolchain//sysroots/x86_64-pokysdk-linux/usr/libexec/aarch64-poky-linux/gcc/aarch64-poky-linux/11.3.0/ld: ../../../ext/libmbedtls.so: undefined reference to `gecc_der_header_bp256'
gmake[2]: *** [sss/ex/mbedtls/CMakeFiles/mbedtls_ex_orig_ssl_server2.dir/build.make:153: bin/mbedtls_ex_orig_ssl_server2] Error 1
gmake[1]: *** [CMakeFiles/Makefile2:1631: sss/ex/mbedtls/CMakeFiles/mbedtls_ex_orig_ssl_server2.dir/all] Error 2
gmake: *** [Makefile:156: all] Error 2
8,890 次查看
msalvinik
Replying to myself, and for reference, this is a working configuration for MW 04.03.01 to build pkcs#11 library for SE050C
PAHO_BUILD_SHARED:BOOL=FALSE
PAHO_BUILD_STATIC:BOOL=TRUE
PTMW_OpenSSL:STRING=3_0
PTMW_SE05X_Ver:STRING=03_XX
PTMW_mbedTLS_ALT:STRING=None
