MCUXpresso 10.3.0 ‘arm-none-eabi-gcc.exe’ error
3,588 次查看
pavankumar_vadh
MCUXpresso 10.3.0 is throwing ‘arm-none-eabi-gcc.exe’ error. Could you please let us know how to fix it?
标记 (2)
5 回复数
3,490 次查看
Kan_Li
Would you please specify the host package version? I will try it on my side.
Thanks for your patience!
Kan
3,490 次查看
pavankumar_vadh
How to see the host package version?
3,490 次查看
Kan_Li
Please tell me the similar info like below:
Kan
3,490 次查看
pavankumar_vadh
Hello.. It's A71CH_01.05.00
3,490 次查看
Kan_Li
Thanks for the information! Seems the latest is 01.06 so far, would you please upgrade it? The building is successful on my side.
The way I import the projects is as below:
Hope that helps,
Kan
